  3. Einsteigerfragen
  4. Installation
  5. ioBroker Installation npm Err!
50 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
  • X Xerxes55
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.19.0
    v16.19.0
    8.19.3
    node:internal/modules/cjs/loader:998
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:22:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    pi@raspberrypi:~ $
    @xerxes55
    systemctl status iobroker.service
    X 1 Antwort Letzte Antwort
      @xerxes55
      X Offline
      X Offline
      Xerxes55
      pi@raspberrypi:~ $ systemctl status iobroker.service
      ● iobroker.service - ioBroker Server
           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
           Active: active (running) since Tue 2022-12-20 22:03:13 CET; 8min ago
             Docs: http://iobroker.net
         Main PID: 7918 (iobroker.js-con)
            Tasks: 11 (limit: 3720)
              CPU: 10.455s
           CGroup: /system.slice/iobroker.service
                   └─7918 iobroker.js-controller
      Dec 20 22:03:13 raspberrypi systemd[1]: Started ioBroker Server.
      Dec 20 22:03:15 raspberrypi sudo[7967]: iobroker : PWD=/ ; USER=root ; COMMAND=>
      Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session opened >
      Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session closed >
      Dec 20 22:03:16 raspberrypi bash[7918]: object system.meta.uuid created: 9c0c44>
      Dec 20 22:03:16 raspberrypi bash[7918]: object system.user.admin created
      lines 1-16/16 (END)...skipping...
              CPU: 10.455s
      lines 1-16/16 (END)
      • X Xerxes55
                CPU: 10.455s
                CPU: 10.455s
        lines 1-16/16 (END)
        @xerxes55 sagte in ioBroker Installation npm Err!:
        sudo systemctl stop iobroker
        iobroker fix
        sudo systemctl start iobroker
          iobroker fix
          X Offline
          X Offline
          Xerxes55
          pi@raspberrypi:~ $ sudo systemctl stop iobroker
          pi@raspberrypi:~ $ iobroker fix
          library: loaded
          Library version=2022-12-09
          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          pi@raspberrypi:~ $ sudo systemctl start iobroker
          pi@raspberrypi:~ $
          • X Xerxes55
            library: loaded
            pi@raspberrypi:~ $
            @xerxes55
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iobroker restart
            iobroker status
              @xerxes55
              cd /opt/iobroker
              iobroker restart
              iobroker status
              X Offline
              X Offline
              Xerxes55
              Habe die Installation noch mal gestartet und?
              pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
              library: loaded
                  Welcome to the ioBroker installer!
                  Installer version: 2022-12-09
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/4)
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
              Reading package lists... Done
              Changing npm registry to https://registry.npmjs.org
              Installed gcc-c++
                  Creating ioBroker user and directory (2/4)
              Directory /opt/iobroker created
                  Installing ioBroker (3/4)
                  Finalizing installation (4/4)
              Enabling autostart...
              Autostart enabled!
                  ioBroker was installed successfully
                  Open http://192.168.178.58:8081 in a browser and start configuring!
              You need to re-login before doing anything else on the console!
              pi@raspberrypi:~ $
              Hurra, jetzt geht es, aber warum?
              • X Xerxes55
                library: loaded
                Installed gcc-c++
                Autostart enabled!
                pi@raspberrypi:~ $
                aber warum?
                Weil jetzt die richtige nodeJS-Version installiert ist.
                • X Xerxes55
                  library: loaded
                  Installed gcc-c++
                  Autostart enabled!
                  pi@raspberrypi:~ $
                  @xerxes55
                  Und was sagt nun
                    aber warum?
                    X Offline
                    X Offline
                    Xerxes55
                    Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
                      @xerxes55
                      Und was sagt nun
                      X Offline
                      X Offline
                      Xerxes55
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.19.0
                      v16.19.0
                      8.19.3
                      4.0.23
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                      tty
                      /home/pi
                      nodejs:
                        Installed: 16.19.0-deb-1nodesource1
                        Candidate: 16.19.0-deb-1nodesource1
                        Version table:
                       *** 16.19.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                           12.22.12~dfsg-1~deb11u1 500
                      pi@raspberrypi:~ $
                      • X Xerxes55
                        Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
                        • X Xerxes55
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.19.0
                          v16.19.0
                          8.19.3
                          4.0.23
                          pi
                          tty
                          /home/pi
                          nodejs:
                            Version table:
                          pi@raspberrypi:~ $
                          X Offline
                          X Offline
                          Xerxes55
                          @xerxes55
                          Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
                          • X Xerxes55
                            @xerxes55
                            @xerxes55
                            Sollte passen.
                              X Offline
                              X Offline
                              Xerxes55
                              @thomas-braun said in ioBroker Installation npm Err!:
                              Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
                              • X Xerxes55
                                da muss aber beteits eine alte nodejs vor dem Aufruf des Installers drauf gewesen sein,
                                Deswegen wurde iobroker unvollständig installiert.
                                Entweder du, oder wenn noch nichts drauf is installiert iobroker die momentan aktuelle Version.
                                • X Xerxes55
                                  Das weiß ich. Und daher weiß ich auch, dass es genau so auch funktioniert.
                                    X Offline
                                    X Offline
                                    Xerxes55
                                    Ich habe die SD Karte komplett neu geschrieben, daher weiß ich nicht woher das kommt. Trotzdem vielen, vielen Dank!
                                    • C Offline
                                      Chris982
                                      Hey, habe ein ähnliches Problem, wollte das updateaus dem iobroker machen aber irgendwas ist schief gelaufen.
                                      Habe danach schon einiges versucht zu deinstallieren wie die node und iobroker aber jetzt geht gar nix mehr.
                                      wenn ich über den installtions link den iobroker neu installieren will kommt:
                                      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      OK:3 https://repos.influxdata.com/debian bullseye InRelease
                                      OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
                                      npm ERR! builtins is not a function
                                      npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
                                      Installed gcc-c++
                                      npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
                                      Autostart enabled!
                                      Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
                                      eine idee was ich machen kann? er ist definitv nicht mehr erreichbar
                                      • C Chris982
                                        Installed gcc-c++
                                        Autostart enabled!
                                        @chris982
                                        Setz das in CodeTags.
                                        C 1 Antwort Letzte Antwort
                                          @chris982
                                          Chris982
                                          Installed gcc-c++
                                          Autostart enabled!
                                          meinst du so?
