  3. Einsteigerfragen
  4. Installation
  5. ioBroker Installation npm Err!
50 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
  • X Xerxes55
    pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Reading package lists... Done
    ## Confirming "bullseye" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/bullseye/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:3 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
    Get:4 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages [784 B]
    Fetched 5,370 B in 1s (4,860 B/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    pi@raspberrypi:~ $ sudo apt install nodejs
    The following packages were automatically installed and are no longer required:
      gyp libc-ares2 libfuse2 libjs-inherits libjs-is-typedarray libjs-psl
      libjs-typedarray-to-buffer libssl-dev libuv1-dev node-abbrev node-agent-base
      node-ajv node-ansi node-ansi-regex node-ansi-styles node-ansistyles
      node-aproba node-archy node-are-we-there-yet node-asap node-asn1
      node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match
      node-bcrypt-pbkdf node-brace-expansion node-builtins node-cacache
      node-caseless node-chalk node-chownr node-clone node-color-convert
      node-color-name node-colors node-columnify node-combined-stream
      node-concat-map node-console-control-strings node-copy-concurrently
      node-core-util-is node-dashdash node-debug node-defaults node-delayed-stream
      node-delegates node-depd node-ecc-jsbn node-encoding node-err-code
      node-escape-string-regexp node-extend node-extsprintf node-fast-deep-equal
      node-forever-agent node-form-data node-fs-write-stream-atomic
      node-fs.realpath node-function-bind node-gauge node-getpass node-glob
      node-graceful-fs node-har-schema node-har-validator node-has-flag
      node-has-unicode node-hosted-git-info node-http-signature
      node-https-proxy-agent node-iconv-lite node-iferr node-imurmurhash
      node-indent-string node-inflight node-inherits node-ini node-ip
      node-ip-regex node-is-typedarray node-isarray node-isexe node-isstream
      node-jsbn node-json-parse-better-errors node-json-schema
      node-json-schema-traverse node-json-stable-stringify
      node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
      node-jsprim node-leven node-lockfile node-lru-cache node-mime
      node-mime-types node-minimatch node-mkdirp node-move-concurrently node-ms
      node-mute-stream node-nopt node-normalize-package-data node-npm-bundled
      node-npm-package-arg node-npmlog node-number-is-nan node-oauth-sign
      node-object-assign node-once node-opener node-osenv node-p-map
      node-path-is-absolute node-performance-now node-process-nextick-args
      node-promise-inflight node-promise-retry node-promzard node-psl node-puka
      node-punycode node-qs node-read node-read-package-json node-readable-stream
      node-resolve node-resolve-from node-retry node-rimraf node-run-queue
      node-safe-buffer node-semver node-set-blocking node-signal-exit node-slash
      node-spdx-correct node-spdx-exceptions node-spdx-expression-parse
      node-spdx-license-ids node-sshpk node-ssri node-string-decoder
      node-string-width node-strip-ansi node-supports-color node-tar
      node-text-table node-through node-tunnel-agent node-tweetnacl
      node-typedarray-to-buffer node-unique-filename node-uri-js
      node-util-deprecate node-uuid node-validate-npm-package-license
      node-validate-npm-package-name node-verror node-wcwidth.js node-which
      node-wide-align node-wrappy node-write-file-atomic node-yallist
    Use 'sudo apt autoremove' to remove them.
    The following packages will be REMOVED:
      libnode-dev libnode72 node-gyp npm
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
    Need to get 24.2 MB of archives.
    After this operation, 82.2 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.0-deb-1nodesource1 [24.2 MB]
    Fetched 24.2 MB in 4s (5,772 kB/s)
    Reading changelogs... Done
    (Reading database ... 181133 files and directories currently installed.)
    Removing npm (7.5.2+ds-2) ...
    Removing node-gyp (7.1.2-4) ...
    Removing libnode-dev (12.22.12~dfsg-1~deb11u1) ...
    dpkg: libnode72:armhf: dependency problems, but removing anyway as you requested:
     nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u1).
    Removing libnode72:armhf (12.22.12~dfsg-1~deb11u1) ...
    (Reading database ... 180169 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (16.19.0-deb-1nodesource1) over (12.22.12~dfsg-1~deb11u1) ...
    Setting up nodejs (16.19.0-deb-1nodesource1) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -           library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installer!
        Installer version: 2022-12-09
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [311 kB]
    Fetched 334 kB in 1s (288 kB/s)
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm ERR! code 24
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c -- node iobroker.js setup first
    npm ERR! creating conf/iobroker.json
    npm ERR!  Cannot read system.config: null (OK when migrating or restoring)
    npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    npm ERR!     /home/pi/.npm/_logs/2022-12-20T21_02_15_028Z-debug-0.log
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.58:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    pi@raspberrypi:~ $
    Das sagt die Konsole!
    @xerxes55
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    sagt?
    X 1 Antwort Letzte Antwort
      @xerxes55
      sagt?
      X Offline
      X Offline
      Xerxes55
      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.19.0
      v16.19.0
      8.19.3
      node:internal/modules/cjs/loader:998
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:22:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      pi@raspberrypi:~ $
      • X Xerxes55
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.19.0
        v16.19.0
        8.19.3
          throw err;
          requireStack: []
        pi@raspberrypi:~ $
        @xerxes55
        systemctl status iobroker.service
          @xerxes55
          X Offline
          X Offline
          Xerxes55
          pi@raspberrypi:~ $ systemctl status iobroker.service
          ● iobroker.service - ioBroker Server
               Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
               Active: active (running) since Tue 2022-12-20 22:03:13 CET; 8min ago
                 Docs: http://iobroker.net
             Main PID: 7918 (iobroker.js-con)
                Tasks: 11 (limit: 3720)
                  CPU: 10.455s
               CGroup: /system.slice/iobroker.service
                       └─7918 iobroker.js-controller
          Dec 20 22:03:13 raspberrypi systemd[1]: Started ioBroker Server.
          Dec 20 22:03:15 raspberrypi sudo[7967]: iobroker : PWD=/ ; USER=root ; COMMAND=>
          Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session opened >
          Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session closed >
          Dec 20 22:03:16 raspberrypi bash[7918]: object system.meta.uuid created: 9c0c44>
          Dec 20 22:03:16 raspberrypi bash[7918]: object system.user.admin created
          lines 1-16/16 (END)...skipping...
                  CPU: 10.455s
          lines 1-16/16 (END)
          • X Xerxes55
                    CPU: 10.455s
                    CPU: 10.455s
            lines 1-16/16 (END)
            @xerxes55 sagte in ioBroker Installation npm Err!:
            sudo systemctl stop iobroker
            iobroker fix
            sudo systemctl start iobroker
              iobroker fix
              X Offline
              X Offline
              Xerxes55
              pi@raspberrypi:~ $ sudo systemctl stop iobroker
              pi@raspberrypi:~ $ iobroker fix
              library: loaded
              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
              pi@raspberrypi:~ $ sudo systemctl start iobroker
              pi@raspberrypi:~ $
              • X Xerxes55
                library: loaded
                pi@raspberrypi:~ $
                @xerxes55
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                iobroker restart
                iobroker status
                  @xerxes55
                  cd /opt/iobroker
                  iobroker restart
                  iobroker status
                  X Offline
                  X Offline
                  Xerxes55
                  Habe die Installation noch mal gestartet und?
                  library: loaded
                  Installed gcc-c++
                  Autostart enabled!
                  pi@raspberrypi:~ $
                  Hurra, jetzt geht es, aber warum?
                  • X Xerxes55
                    library: loaded
                    Installed gcc-c++
                    Autostart enabled!
                    pi@raspberrypi:~ $
                    aber warum?
                    Weil jetzt die richtige nodeJS-Version installiert ist.
                    • X Xerxes55
                      library: loaded
                      Installed gcc-c++
                      Autostart enabled!
                      pi@raspberrypi:~ $
                      @xerxes55
                      Und was sagt nun
                        aber warum?
                        X Offline
                        X Offline
                        Xerxes55
                        Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
                          @xerxes55
                          Und was sagt nun
                          X Offline
                          X Offline
                          Xerxes55
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.19.0
                          v16.19.0
                          8.19.3
                          4.0.23
                          pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          tty
                          /home/pi
                          nodejs:
                            Installed: 16.19.0-deb-1nodesource1
                            Candidate: 16.19.0-deb-1nodesource1
                            Version table:
                           *** 16.19.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                               12.22.12~dfsg-1~deb11u1 500
                          pi@raspberrypi:~ $
                          • X Xerxes55
                            Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
                            • X Xerxes55
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.19.0
                              v16.19.0
                              8.19.3
                              4.0.23
                              pi
                              tty
                              /home/pi
                              nodejs:
                                Version table:
                              pi@raspberrypi:~ $
                              X Offline
                              X Offline
                              Xerxes55
                              @xerxes55
                              Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
                              • X Xerxes55
                                @xerxes55
                                @xerxes55
                                Sollte passen.
                                  X Offline
                                  X Offline
                                  Xerxes55
                                  @thomas-braun said in ioBroker Installation npm Err!:
                                  Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
                                  • X Xerxes55
                                    da muss aber beteits eine alte nodejs vor dem Aufruf des Installers drauf gewesen sein,
                                    Deswegen wurde iobroker unvollständig installiert.
                                    Entweder du, oder wenn noch nichts drauf is installiert iobroker die momentan aktuelle Version.
                                    • X Xerxes55
                                      Das weiß ich. Und daher weiß ich auch, dass es genau so auch funktioniert.
                                        X Offline
                                        X Offline
                                        Xerxes55
                                        Ich habe die SD Karte komplett neu geschrieben, daher weiß ich nicht woher das kommt. Trotzdem vielen, vielen Dank!
                                        • C Offline
                                          Chris982
                                          Hey, habe ein ähnliches Problem, wollte das updateaus dem iobroker machen aber irgendwas ist schief gelaufen.
                                          Habe danach schon einiges versucht zu deinstallieren wie die node und iobroker aber jetzt geht gar nix mehr.
                                          wenn ich über den installtions link den iobroker neu installieren will kommt:
                                          OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                          OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          OK:3 https://repos.influxdata.com/debian bullseye InRelease
                                          OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
                                          npm ERR! builtins is not a function
                                          npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
                                          Installed gcc-c++
                                          npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
                                          Autostart enabled!
                                          Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
                                          eine idee was ich machen kann? er ist definitv nicht mehr erreichbar
