  3. Einsteigerfragen
  4. Installation
  5. ioBroker Installation npm Err!
    6.3k
50 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
  • X Xerxes55
    Ich kann nicht alles aus der Konsole kopieren, weil ich nicht so weit Scrollen kann. Benutze Putty.
    @xerxes55 sagte in ioBroker Installation npm Err!:
    Benutze Putty.
    Selber schuld. Nimm die PowerShell.
    Aber auch in puTTY kann man zurückscrollen.
    • X Xerxes55
      @xerxes55
      curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
      sudo apt install nodejs
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      sagt?
      X 1 Antwort Letzte Antwort
      • X Xerxes55
        pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installer!
            Installer version: 2022-12-09
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Reading package lists... Done
        Changing npm registry to https://registry.npmjs.org
        Installed gcc-c++
            Creating ioBroker user and directory (2/4)
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
        npm ERR! code EBADENGINE
        npm ERR! engine Unsupported engine
        npm ERR! engine Not compatible with your version of node/npm: fs-extra@11.1.0
        npm ERR! notsup Not compatible with your version of node/npm: fs-extra@11.1.0
        npm ERR! notsup Required: {"node":">=14.14"}
        npm ERR! notsup Actual:   {"npm":"7.5.2","node":"v12.22.12"}
        npm ERR!     /home/pi/.npm/_logs/2022-12-20T20_48_12_106Z-debug.log
            Finalizing installation (4/4)
        Enabling autostart...
        Autostart enabled!
            ioBroker was installed successfully
            Open http://192.168.178.58:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        pi@raspberrypi:~ $
        Gleiche Fehler!
        HomoranH Offline
        HomoranH Offline
        Gleiche Fehler!
        Ja!
        da ist bereits ein veraltetes nodejs drauf!
        da kann dann der Installer nichts für.
          @xerxes55
          sagt?
          X Offline
          X Offline
          Xerxes55
          pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
          ## Installing the NodeSource Node.js 16.x repo...
          ## Populating apt-get cache...
          + apt-get update
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          ## Confirming "bullseye" is supported...
          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/bullseye/Release'
          ## Adding the NodeSource signing key to your keyring...
          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
          ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
          ## Running `apt-get update` for you...
          + apt-get update
          Get:3 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
          Get:4 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages [784 B]
          Fetched 5,370 B in 1s (4,860 B/s)
          ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
          ## You may also need development tools to build native addons:
               sudo apt-get install gcc g++ make
          ## To install the Yarn package manager, run:
               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
               sudo apt-get update && sudo apt-get install yarn
          pi@raspberrypi:~ $ sudo apt install nodejs
          The following packages were automatically installed and are no longer required:
            gyp libc-ares2 libfuse2 libjs-inherits libjs-is-typedarray libjs-psl
            libjs-typedarray-to-buffer libssl-dev libuv1-dev node-abbrev node-agent-base
            node-ajv node-ansi node-ansi-regex node-ansi-styles node-ansistyles
            node-aproba node-archy node-are-we-there-yet node-asap node-asn1
            node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match
            node-bcrypt-pbkdf node-brace-expansion node-builtins node-cacache
            node-caseless node-chalk node-chownr node-clone node-color-convert
            node-color-name node-colors node-columnify node-combined-stream
            node-concat-map node-console-control-strings node-copy-concurrently
            node-core-util-is node-dashdash node-debug node-defaults node-delayed-stream
            node-delegates node-depd node-ecc-jsbn node-encoding node-err-code
            node-escape-string-regexp node-extend node-extsprintf node-fast-deep-equal
            node-forever-agent node-form-data node-fs-write-stream-atomic
            node-fs.realpath node-function-bind node-gauge node-getpass node-glob
            node-graceful-fs node-har-schema node-har-validator node-has-flag
            node-has-unicode node-hosted-git-info node-http-signature
            node-https-proxy-agent node-iconv-lite node-iferr node-imurmurhash
            node-indent-string node-inflight node-inherits node-ini node-ip
            node-ip-regex node-is-typedarray node-isarray node-isexe node-isstream
            node-jsbn node-json-parse-better-errors node-json-schema
            node-json-schema-traverse node-json-stable-stringify
            node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
            node-jsprim node-leven node-lockfile node-lru-cache node-mime
            node-mime-types node-minimatch node-mkdirp node-move-concurrently node-ms
            node-mute-stream node-nopt node-normalize-package-data node-npm-bundled
            node-npm-package-arg node-npmlog node-number-is-nan node-oauth-sign
            node-object-assign node-once node-opener node-osenv node-p-map
            node-path-is-absolute node-performance-now node-process-nextick-args
            node-promise-inflight node-promise-retry node-promzard node-psl node-puka
            node-punycode node-qs node-read node-read-package-json node-readable-stream
            node-resolve node-resolve-from node-retry node-rimraf node-run-queue
            node-safe-buffer node-semver node-set-blocking node-signal-exit node-slash
            node-spdx-correct node-spdx-exceptions node-spdx-expression-parse
            node-spdx-license-ids node-sshpk node-ssri node-string-decoder
            node-string-width node-strip-ansi node-supports-color node-tar
            node-text-table node-through node-tunnel-agent node-tweetnacl
            node-typedarray-to-buffer node-unique-filename node-uri-js
            node-util-deprecate node-uuid node-validate-npm-package-license
            node-validate-npm-package-name node-verror node-wcwidth.js node-which
            node-wide-align node-wrappy node-write-file-atomic node-yallist
          Use 'sudo apt autoremove' to remove them.
          The following packages will be REMOVED:
            libnode-dev libnode72 node-gyp npm
          The following packages will be upgraded:
            nodejs
          1 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
          Need to get 24.2 MB of archives.
          After this operation, 82.2 MB of additional disk space will be used.
          Do you want to continue? [Y/n] y
          Get:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.0-deb-1nodesource1 [24.2 MB]
          Fetched 24.2 MB in 4s (5,772 kB/s)
          Reading changelogs... Done
          (Reading database ... 181133 files and directories currently installed.)
          Removing npm (7.5.2+ds-2) ...
          Removing node-gyp (7.1.2-4) ...
          Removing libnode-dev (12.22.12~dfsg-1~deb11u1) ...
          dpkg: libnode72:armhf: dependency problems, but removing anyway as you requested:
           nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u1).
          Removing libnode72:armhf (12.22.12~dfsg-1~deb11u1) ...
          (Reading database ... 180169 files and directories currently installed.)
          Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_armhf.deb ...
          Unpacking nodejs (16.19.0-deb-1nodesource1) over (12.22.12~dfsg-1~deb11u1) ...
          Setting up nodejs (16.19.0-deb-1nodesource1) ...
          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
          Processing triggers for man-db (2.9.4-2) ...
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -           library: loaded
          Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [311 kB]
          Fetched 334 kB in 1s (288 kB/s)
          Installed gcc-c++
          npm ERR! code 24
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh -c -- node iobroker.js setup first
          npm ERR! creating conf/iobroker.json
          npm ERR!  Cannot read system.config: null (OK when migrating or restoring)
          npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
          npm ERR!     /home/pi/.npm/_logs/2022-12-20T21_02_15_028Z-debug-0.log
          Autostart enabled!
          pi@raspberrypi:~ $
          Das sagt die Konsole!
          • X Xerxes55
            + apt-get update
            + apt-get update
              nodejs
            Installed gcc-c++
            npm ERR! code 24
            Autostart enabled!
            pi@raspberrypi:~ $
            @xerxes55
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
            sagt?
              @xerxes55
              sagt?
              X Offline
              X Offline
              Xerxes55
              pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.19.0
              v16.19.0
              8.19.3
              node:internal/modules/cjs/loader:998
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                  at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  at node:internal/main/run_main_module:22:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              pi@raspberrypi:~ $
              • X Xerxes55
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.19.0
                v16.19.0
                8.19.3
                  throw err;
                  requireStack: []
                pi@raspberrypi:~ $
                @xerxes55
                systemctl status iobroker.service
                  @xerxes55
                  X Offline
                  X Offline
                  Xerxes55
                  pi@raspberrypi:~ $ systemctl status iobroker.service
                  ● iobroker.service - ioBroker Server
                       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
                       Active: active (running) since Tue 2022-12-20 22:03:13 CET; 8min ago
                         Docs: http://iobroker.net
                     Main PID: 7918 (iobroker.js-con)
                        Tasks: 11 (limit: 3720)
                          CPU: 10.455s
                       CGroup: /system.slice/iobroker.service
                               └─7918 iobroker.js-controller
                  Dec 20 22:03:13 raspberrypi systemd[1]: Started ioBroker Server.
                  Dec 20 22:03:15 raspberrypi sudo[7967]: iobroker : PWD=/ ; USER=root ; COMMAND=>
                  Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session opened >
                  Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session closed >
                  Dec 20 22:03:16 raspberrypi bash[7918]: object system.meta.uuid created: 9c0c44>
                  Dec 20 22:03:16 raspberrypi bash[7918]: object system.user.admin created
                  lines 1-16/16 (END)...skipping...
                          CPU: 10.455s
                  lines 1-16/16 (END)
                  • X Xerxes55
                            CPU: 10.455s
                            CPU: 10.455s
                    lines 1-16/16 (END)
                    sudo systemctl stop iobroker
                    iobroker fix
                    sudo systemctl start iobroker
                      iobroker fix
                      X Offline
                      X Offline
                      Xerxes55
                      pi@raspberrypi:~ $ sudo systemctl stop iobroker
                      pi@raspberrypi:~ $ iobroker fix
                      library: loaded
                      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                      pi@raspberrypi:~ $ sudo systemctl start iobroker
                      pi@raspberrypi:~ $
                      • X Xerxes55
                        library: loaded
                        pi@raspberrypi:~ $
                        @xerxes55
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller
                        iobroker restart
                        iobroker status
                          @xerxes55
                          cd /opt/iobroker
                          iobroker restart
                          iobroker status
                          X Offline
                          X Offline
                          Xerxes55
                          Habe die Installation noch mal gestartet und?
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          pi@raspberrypi:~ $
                          Hurra, jetzt geht es, aber warum?
                          • X Xerxes55
                            library: loaded
                            Installed gcc-c++
                            Autostart enabled!
                            pi@raspberrypi:~ $
                            aber warum?
                            Weil jetzt die richtige nodeJS-Version installiert ist.
                            • X Xerxes55
                              library: loaded
                              Installed gcc-c++
                              Autostart enabled!
                              pi@raspberrypi:~ $
                              @xerxes55
                              Und was sagt nun
                                aber warum?
                                X Offline
                                X Offline
                                Xerxes55
                                Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
                                  @xerxes55
                                  Und was sagt nun
                                  X Offline
                                  X Offline
                                  Xerxes55
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.19.0
                                  v16.19.0
                                  8.19.3
                                  4.0.23
                                  pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                  tty
                                  /home/pi
                                  nodejs:
                                    Installed: 16.19.0-deb-1nodesource1
                                    Candidate: 16.19.0-deb-1nodesource1
                                    Version table:
                                   *** 16.19.0-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                       12.22.12~dfsg-1~deb11u1 500
                                  pi@raspberrypi:~ $
                                  • X Xerxes55
                                    Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
                                    • X Xerxes55
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.19.0
                                      v16.19.0
                                      8.19.3
                                      4.0.23
                                      pi
                                      tty
                                      /home/pi
                                      nodejs:
                                        Version table:
                                      pi@raspberrypi:~ $
                                      X Offline
                                      X Offline
                                      Xerxes55
                                      @xerxes55
                                      Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
                                      • X Xerxes55
                                        @xerxes55
                                        @xerxes55
                                        Sollte passen.
                                          X Offline
                                          X Offline
                                          Xerxes55
                                          @thomas-braun said in ioBroker Installation npm Err!:
                                          Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
