  3. Einsteigerfragen
  4. Installation
  5. ioBroker Installation npm Err!
50 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
  • X Xerxes55
    Habe die Installation noch mal gestartet und?
    pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installer!
        Installer version: 2022-12-09
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.58:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    pi@raspberrypi:~ $
    Hurra, jetzt geht es, aber warum?
    @xerxes55
    Und was sagt nun
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    X 1 Antwort Letzte Antwort
      @xerxes55 sagte in ioBroker Installation npm Err!:
      aber warum?
      Weil jetzt die richtige nodeJS-Version installiert ist.
      X Offline
      X Offline
      Xerxes55
      Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
        @xerxes55
        Und was sagt nun
        X Offline
        X Offline
        Xerxes55
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.19.0
        v16.19.0
        8.19.3
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        tty
        /home/pi
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
             12.22.12~dfsg-1~deb11u1 500
        pi@raspberrypi:~ $
        • X Xerxes55
          Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
          • X Xerxes55
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.19.0
            v16.19.0
            8.19.3
            4.0.23
            pi
            tty
            /home/pi
            nodejs:
              Version table:
            pi@raspberrypi:~ $
            X Offline
            X Offline
            Xerxes55
            @xerxes55
            Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
            • X Xerxes55
              @xerxes55
              @xerxes55
              Sollte passen.
                X Offline
                X Offline
                Xerxes55
                @thomas-braun said in ioBroker Installation npm Err!:
                Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
                • X Xerxes55
                  da muss aber beteits eine alte nodejs vor dem Aufruf des Installers drauf gewesen sein,
                  Deswegen wurde iobroker unvollständig installiert.
                  Entweder du, oder wenn noch nichts drauf is installiert iobroker die momentan aktuelle Version.
                  • X Xerxes55
                    Das weiß ich. Und daher weiß ich auch, dass es genau so auch funktioniert.
                      X Offline
                      X Offline
                      Xerxes55
                      Ich habe die SD Karte komplett neu geschrieben, daher weiß ich nicht woher das kommt. Trotzdem vielen, vielen Dank!
                      • C Offline
                        Chris982
                        Hey, habe ein ähnliches Problem, wollte das updateaus dem iobroker machen aber irgendwas ist schief gelaufen.
                        Habe danach schon einiges versucht zu deinstallieren wie die node und iobroker aber jetzt geht gar nix mehr.
                        wenn ich über den installtions link den iobroker neu installieren will kommt:
                        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        OK:3 https://repos.influxdata.com/debian bullseye InRelease
                        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                        OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
                        npm ERR! builtins is not a function
                        npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
                        Installed gcc-c++
                        npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
                        Autostart enabled!
                        Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
                        eine idee was ich machen kann? er ist definitv nicht mehr erreichbar
                        • C Chris982
                          Installed gcc-c++
                          Autostart enabled!
                          @chris982
                          Setz das in CodeTags.
                          C 1 Antwort Letzte Antwort
                            @chris982
                            Chris982
                            Installed gcc-c++
                            Autostart enabled!
                            meinst du so?
                            • C Chris982
                              Installed gcc-c++
                              Autostart enabled!
                              meinst du so?
                              @chris982
                              Check deine nodejs-Installation. Ich vermute die ist/war mal krumm.
                                @chris982
                                Chris982
                                pi@raspberrypi:~ $ apt policy nodejs
                                nodejs
                                nodejs:
                                  Installiert:           16.19.0-deb-1nodesource1
                                  Installationskandidat: 16.19.0-deb-1nodesource1
                                  Versionstabelle:
                                Welcome to Node.js v16.19.0.
                                Type ".help" for more information.
                                ich denke auch weil da 2 nodejs installiert sind. aber wie kann ich die 12.22.12 löschen?
                                • C Chris982
                                  nodejs
                                  nodejs:
                                    Versionstabelle:
                                  @chris982
                                  Gar nicht. Die ist ja nicht (über den Paketmanager) installiert.
                                  Was sagt
                                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                  uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    @chris982
                                    Was sagt
                                    Chris982
                                    pi@raspberrypi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    armv7l
                                    Kein Docker
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.19.0
                                    v16.19.0
                                    8.19.3
                                    node:internal/modules/cjs/loader:998
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                        at node:internal/main/run_main_module:22:47 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                    pi@raspberrypi:~ $
                                    • C Chris982
                                      armv7l
                                      Kein Docker
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.19.0
                                      v16.19.0
                                      8.19.3
                                        throw err;
                                        requireStack: []
                                      pi@raspberrypi:~ $
                                      @chris982
                                      Ich weiß nicht wie oft das hier schon gefixt wurde. Such nach der Fehlermeldung.
                                        @chris982
                                        Chris982
                                        ok, mache mich nochmal auf die suche, hbe vorhin aber nichts wirkliches gefunden.
                                        Danke Dir schon mal
                                        • C Chris982
                                          Danke Dir schon mal
                                          @chris982
                                          Zuletzt genau in diesem Thread. Vor nicht mal 24 Stunden.
