  3. Einsteigerfragen
  4. Installation
  5. ioBroker Installation npm Err!
Geplant Angeheftet Gesperrt Verschoben Installation
50 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
    @chris982
    Setz das in CodeTags.
    Chris982
    #41
     Welcome to the ioBroker installer!
        Installer version: 2022-12-09
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:3 https://repos.influxdata.com/debian bullseye InRelease
    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
    Changing npm registry to https://registry.npmjs.org
    npm ERR! builtins is not a function
    npm ERR!     /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm ERR!     /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    meinst du so?
    • C Chris982
      Installed gcc-c++
      Autostart enabled!
      meinst du so?
      #42
      @chris982
      Check deine nodejs-Installation. Ich vermute die ist/war mal krumm.
      C 1 Antwort Letzte Antwort
        @chris982
        Chris982
        #43
        pi@raspberrypi:~ $ apt policy nodejs
        nodejs
        nodejs:
          Installiert:           16.19.0-deb-1nodesource1
          Installationskandidat: 16.19.0-deb-1nodesource1
          Versionstabelle:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u1 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        Welcome to Node.js v16.19.0.
        Type ".help" for more information.
        ich denke auch weil da 2 nodejs installiert sind. aber wie kann ich die 12.22.12 löschen?
        • C Chris982
          nodejs
          nodejs:
            Versionstabelle:
          #44
          @chris982
          Gar nicht. Die ist ja nicht (über den Paketmanager) installiert.
          Was sagt
          sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            @chris982
            Was sagt
            Chris982
            #45
            pi@raspberrypi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            Kein Docker
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.19.0
            v16.19.0
            8.19.3
            node:internal/modules/cjs/loader:998
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                at node:internal/main/run_main_module:22:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            pi@raspberrypi:~ $
            • C Chris982
              armv7l
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.19.0
              v16.19.0
              8.19.3
                throw err;
                requireStack: []
              pi@raspberrypi:~ $
              #46
              @chris982
              Ich weiß nicht wie oft das hier schon gefixt wurde. Such nach der Fehlermeldung.
                @chris982
                Chris982
                #47
                ok, mache mich nochmal auf die suche, hbe vorhin aber nichts wirkliches gefunden.
                Danke Dir schon mal
                • C Chris982
                  Danke Dir schon mal
                  #48
                  @chris982
                  Zuletzt genau in diesem Thread. Vor nicht mal 24 Stunden.
                    @chris982
                    Chris982
                    #49
                    ja die sachen habe ich auch schon mehrfach gemacht aber es geht leider trotzdem nicht. oder habe ich noch was übersehen?
                    pi@raspberrypi:~ $ sudo systemctl stop iobroker
                    pi@raspberrypi:~ $ iobroker fix
                    library: loaded
                    Library version=2022-12-09
                    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                    pi@raspberrypi:~ $ sudo systemctl start iobroker
                    pi@raspberrypi:~ $ cd /opt/iobroker
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                    npm ERR!     /home/iobroker/.npm/_logs/2022-12-21T19_50_27_303Z-debug-0.log
                    pi@raspberrypi:/opt/iobroker $ iobroker restart
                    pi@raspberrypi:/opt/iobroker $ iobroker status
                      throw err;
                      requireStack: []
                    pi@raspberrypi:/opt/iobroker $ cd
                    pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                    library: loaded
                    npm ERR!     /home/pi/.npm/_logs/2022-12-21T19_51_38_882Z-debug-0.log
                    Installed gcc-c++
                    npm ERR!     /home/pi/.npm/_logs/2022-12-21T19_51_44_342Z-debug-0.log
                    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service.
                    Autostart enabled!
                    pi@raspberrypi:~ $
                    • Thomas BraunT Online
                      #50
                      @chris982 sagte in ioBroker Installation npm Err!:
                      iobroker stop
                      sudo apt update
                      sudo apt install --reinstall nodejs
                      type -P npm nodejs node
