  4. VIS für FireTablet *gelöst*
    2.0k
    2.5k
93 Beiträge 6 Kommentatoren 7.3k Aufrufe 5 Beobachtet
  • G gluecksmann
    Hmmm... hab ich alles gemacht...sieht aber trotzdem nicht danach aus das es funktioniert hat
    #41
    @gluecksmann sagte in VIS für FireTablet:
    Wie sieht / sah es denn aus?
    G 1 Antwort Letzte Antwort
      gluecksmann
      #42
      @thomas-braun ```
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN skipping integrity check for git dependency ssh://git@github.com/nbuenger/ioBroker.govee.git
      npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.icons-ultimate-png.git
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
      npm WARN deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
      npm WARN deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
      npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
      added 6 packages, removed 26 packages, and changed 1181 packages in 11m
      82 packages are looking for funding
      run npm fund for details
      • G gluecksmann
        @thomas-braun ```
        #43
        @gluecksmann
        Tip: Die Steuerzeichen (vor dem Konsolenoutput) gehören in eine neue, eigene Zeile.
        Ansonsten sieht das gut aus.
          @gluecksmann
          gluecksmann
          #44
          @thomas-braun Aber geht nicht...
          • G gluecksmann
            #45
            @gluecksmann
            Das heißt konkret?
            iobroker status
            sagt?
              @gluecksmann
              Das heißt konkret?
              iobroker status
              sagt?
              gluecksmann
              #46
              @thomas-braun sagte in VIS für FireTablet:
              iobroker status
              pi@raspberrypi:/opt/iobroker $ iobroker status
              Objects type: jsonl
              States type: jsonl
              • G gluecksmann
                iobroker status
                Objects type: jsonl
                States type: jsonl
                #47
                @gluecksmann
                Alles prima, ioBroker lüppt.
                  @gluecksmann
                  gluecksmann
                  schrieb am zuletzt editiert von gluecksmann
                  #48
                  @thomas-braun Nöe... beim Aufruf kommt dann...
                  Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/lib/../www/index.html'
                      at Object.openSync (node:fs:585:3)
                      at Object.readFileSync (node:fs:453:35)
                      at prepareIndex (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:200:27)
                      at /opt/iobroker/node_modules/iobroker.admin/lib/web.js:763:46
                      at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                      at next (/opt/iobroker/node_modules/express/lib/router/route.js:144:13)
                      at Route.dispatch (/opt/iobroker/node_modules/express/lib/router/route.js:114:3)
                      at /opt/iobroker/node_modules/express/lib/router/index.js:284:15
                      at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
                  • G gluecksmann
                    #49
                    @gluecksmann
                    Mensch....
                    Setz die `` in eine neue Zeile!
                    • G gluecksmann
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #50
                      bei welchem Aufruf?
                      ist dein admin nicht installiert, bzw Fehlerhaft
                      zeig mal
                      iob list instances
                      iob list adapters
                      G 2 Antworten Letzte Antwort
                        bei welchem Aufruf?
                        zeig mal
                        iob list instances
                        iob list adapters
                        gluecksmann
                        #51
                        @crunchip sagte in VIS für FireTablet:
                        iob list instances
                        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                            at node:internal/main/run_main_module:17:47 {
                          code: 'MODULE_NOT_FOUND',
                          requireStack: []
                        node:internal/modules/cjs/loader:936
                          throw err;
                        Error: Cannot find module './lib/setup'
                        Require stack:
                        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                            at Module.require (node:internal/modules/cjs/loader:1005:19)
                            at require (node:internal/modules/cjs/helpers:102:18)
                            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
                            at Module._compile (node:internal/modules/cjs/loader:1105:14)
                            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                            at Module.load (node:internal/modules/cjs/loader:981:32)
                            at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) {
                          requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
                        HomoranH crunchipC 2 Antworten Letzte Antwort
                        • G gluecksmann
                          iob list instances
                            requireStack: []
                            throw err;
                          Require stack:
                          #52
                          @gluecksmann warum zeigst du nicht alles? incl. Befehl und prompt?
                          crunchipC G 2 Antworten Letzte Antwort
                          • G gluecksmann
                            iob list instances
                              requireStack: []
                              throw err;
                            Require stack:
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #53
                            @gluecksmann mal ganz ehrlich, hast du ne weitere Sd-Karte rum liegen?
                            dann installier dir ein neues raspi image, den iobroker drauf und spiel danach dein Backup ein
                              #54
                              das auf der anderen Karte liegt
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #55
                                @homoran ist das vllt ein Fall fürs "neue Thomas Brown Tool" zum testen eines kaputten iobroker?😁
                                @homoran sagte in VIS für FireTablet:
                                tja:man-shrugging:
                                  gluecksmann
                                  #56
                                  @homoran kwinw Ahnung was Du meinst...
                                  • G gluecksmann
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #57
                                    @gluecksmann das gesamte , incl Eingabe und nicht nur nen Ausschnitt
                                    https://de.wikipedia.org/wiki/Prompt
                                    falls eine Neuinstallation auf 2te Karte in Frage kommt
                                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1667927946069
                                      gluecksmann
                                      #58
                                      @crunchip
                                      Es ging mir primär um die VIS zu retten....und nach meinen ganzen Fragen..traue ich mich nicht zu da irgendwas mit einerzweiten Karte zu machen
                                        bei welchem Aufruf?
                                        zeig mal
                                        iob list instances
                                        iob list adapters
                                        gluecksmann
                                        #59
                                        @crunchip
                                        pi@raspberrypi:/opt/iobroker $ iob list instances
                                        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                                          system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                          system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                                          system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
                                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                                          system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                                          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                          system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
                                          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              - disabled
                                          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                                          system.adapter.govee.0                  : govee                 : raspberrypi                              - disabled
                                          system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
                                          system.adapter.history.0                : history               : raspberrypi                              - disabled
                                          system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
                                          system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                                          system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                                          system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                                          system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                                          system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              - disabled
                                          system.adapter.musiccast.0              : musiccast             : raspberrypi                              - disabled
                                          system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                          system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
                                          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                          system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
                                          system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                                          system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
                                          system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                                          system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
                                          system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
                                          system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
                                          system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                          system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
                                          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                          system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                                          system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyACM0
                                        + instance is alive
                                        pi@raspberrypi:/opt/iobroker $ iob list adapters
                                        system.adapter.admin                   : admin          - v6.2.22
                                        system.adapter.alexa2                  : alexa2         - v3.12.0
                                        system.adapter.alias-manager           : alias-manager  - v1.2.6
                                        system.adapter.backitup                : backitup       - v2.4.12
                                        system.adapter.ble                     : ble            - v0.13.0
                                        system.adapter.chromecast              : chromecast     - v2.3.1
                                        system.adapter.daswetter               : daswetter      - v3.1.3
                                        system.adapter.devices                 : devices        - v1.0.12
                                        system.adapter.discovery               : discovery      - v3.0.5
                                        system.adapter.dwd                     : dwd            - v2.8.3
                                        system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.4
                                        system.adapter.fullybrowser            : fullybrowser   - v2.1.2
                                        system.adapter.govee                   : govee          - v0.0.5
                                        system.adapter.gruenbeck               : gruenbeck      - v0.0.42
                                        system.adapter.history                 : history        - v2.2.0
                                        system.adapter.hue                     : hue            - v3.7.1
                                        system.adapter.hue-extended            : hue-extended   - v2.0.0
                                        system.adapter.ical                    : ical           - v1.13.1
                                        system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
                                        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                                        system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                                        system.adapter.info                    : info           - v1.9.19
                                        system.adapter.iot                     : iot            - v1.11.9
                                        system.adapter.javascript              : javascript     - v6.0.3
                                        system.adapter.mielecloudservice       : mielecloudservice - v6.3.2
                                        system.adapter.musiccast               : musiccast      - v0.2.2
                                        system.adapter.net-tools               : net-tools      - v0.2.0
                                        system.adapter.netatmo                 : netatmo        - v1.7.1
                                        system.adapter.onvif                   : onvif          - v0.4.4
                                        system.adapter.ping                    : ping           - v1.5.3
                                        system.adapter.pollenflug              : pollenflug     - v1.0.6
                                        system.adapter.scenes                  : scenes         - v2.3.9
                                        system.adapter.schoolfree              : schoolfree     - v1.0.1
                                        system.adapter.shelly                  : shelly         - v6.0.0
                                        system.adapter.shuttercontrol          : shuttercontrol - v1.4.14
                                        system.adapter.simple-api              : simple-api     - v2.7.0
                                        system.adapter.smartcontrol            : smartcontrol   - v1.2.1
                                        system.adapter.socketio                : socketio       - v6.1.7
                                        system.adapter.sonoff                  : sonoff         - v2.5.1
                                        system.adapter.sonos                   : sonos          - v2.2.3
                                        system.adapter.trashschedule           : trashschedule  - v2.0.3
                                        system.adapter.vis                     : vis            - v1.4.15
                                        system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                                        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.3.0
                                        system.adapter.vis-inventwo            : vis-inventwo   - v3.3.3
                                        system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
                                        system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.94
                                        system.adapter.vis-metro               : vis-metro      - v1.2.0
                                        system.adapter.vis-players             : vis-players    - v0.1.6
                                        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                        system.adapter.vis-weather             : vis-weather    - v2.5.5
                                        system.adapter.weatherunderground      : weatherunderground - v3.4.2
                                        system.adapter.web                     : web            - v5.2.3
                                        system.adapter.ws                      : ws             - v2.1.2
                                        system.adapter.zigbee                  : zigbee         - v1.7.5
                                          tja:man-shrugging:
                                          #60
                                          @crunchip
                                          83.2k
