  4. VIS für FireTablet *gelöst*
    5.2k
93 Beiträge 6 Kommentatoren 7.8k Aufrufe 5 Beobachtet
  • G gluecksmann
    @thomas-braun Nöe... beim Aufruf kommt dann...
    Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/lib/../www/index.html'
        at Object.openSync (node:fs:585:3)
        at Object.readFileSync (node:fs:453:35)
        at prepareIndex (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:200:27)
        at /opt/iobroker/node_modules/iobroker.admin/lib/web.js:763:46
        at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
        at next (/opt/iobroker/node_modules/express/lib/router/route.js:144:13)
        at Route.dispatch (/opt/iobroker/node_modules/express/lib/router/route.js:114:3)
        at /opt/iobroker/node_modules/express/lib/router/index.js:284:15
        at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
    @gluecksmann
    Mensch....
    Setz die `` in eine neue Zeile!
    • G gluecksmann
      crunchipC Offline
      crunchipC Offline
      @gluecksmann sagte in VIS für FireTablet:
      bei welchem Aufruf?
      ist dein admin nicht installiert, bzw Fehlerhaft
      zeig mal
      iob list instances
      iob list adapters
      G 2 Antworten Letzte Antwort
        bei welchem Aufruf?
        zeig mal
        iob list instances
        iob list adapters
        gluecksmann
        @crunchip sagte in VIS für FireTablet:
        iob list instances
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
            at node:internal/main/run_main_module:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        node:internal/modules/cjs/loader:936
          throw err;
        Error: Cannot find module './lib/setup'
        Require stack:
        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
            at Module.require (node:internal/modules/cjs/loader:1005:19)
            at require (node:internal/modules/cjs/helpers:102:18)
            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
            at Module._compile (node:internal/modules/cjs/loader:1105:14)
            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
            at Module.load (node:internal/modules/cjs/loader:981:32)
            at Function.Module._load (node:internal/modules/cjs/loader:822:12)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) {
          requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
        HomoranH crunchipC 2 Antworten Letzte Antwort
        • G gluecksmann
          iob list instances
            requireStack: []
            throw err;
          Require stack:
          @gluecksmann warum zeigst du nicht alles? incl. Befehl und prompt?
          crunchipC G 2 Antworten Letzte Antwort
          • G gluecksmann
            iob list instances
              requireStack: []
              throw err;
            Require stack:
            crunchipC Offline
            crunchipC Offline
            @gluecksmann mal ganz ehrlich, hast du ne weitere Sd-Karte rum liegen?
            dann installier dir ein neues raspi image, den iobroker drauf und spiel danach dein Backup ein
              das auf der anderen Karte liegt
                crunchipC Offline
                crunchipC Offline
                @homoran ist das vllt ein Fall fürs "neue Thomas Brown Tool" zum testen eines kaputten iobroker?😁
                @homoran sagte in VIS für FireTablet:
                tja:man-shrugging:
                  gluecksmann
                  @homoran kwinw Ahnung was Du meinst...
                  • G gluecksmann
                    crunchipC Offline
                    crunchipC Offline
                    @gluecksmann das gesamte , incl Eingabe und nicht nur nen Ausschnitt
                    https://de.wikipedia.org/wiki/Prompt
                    falls eine Neuinstallation auf 2te Karte in Frage kommt
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1667927946069
                    G 1 Antwort Letzte Antwort
                      gluecksmann
                      @crunchip
                      Es ging mir primär um die VIS zu retten....und nach meinen ganzen Fragen..traue ich mich nicht zu da irgendwas mit einerzweiten Karte zu machen
                        bei welchem Aufruf?
                        zeig mal
                        iob list instances
                        iob list adapters
                        gluecksmann
                        @crunchip
                        pi@raspberrypi:/opt/iobroker $ iob list instances
                          system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                          system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                          system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                          system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                          system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                          system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
                          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              - disabled
                          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                          system.adapter.govee.0                  : govee                 : raspberrypi                              - disabled
                          system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
                          system.adapter.history.0                : history               : raspberrypi                              - disabled
                          system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
                          system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                          system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                          system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                          system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                          system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              - disabled
                          system.adapter.musiccast.0              : musiccast             : raspberrypi                              - disabled
                          system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                          system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
                          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                          system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
                          system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                          system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
                          system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                          system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
                          system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
                          system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                          system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
                          system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                          system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                          system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                          system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyACM0
                        + instance is alive
                        pi@raspberrypi:/opt/iobroker $ iob list adapters
                        system.adapter.admin                   : admin          - v6.2.22
                        system.adapter.alexa2                  : alexa2         - v3.12.0
                        system.adapter.alias-manager           : alias-manager  - v1.2.6
                        system.adapter.backitup                : backitup       - v2.4.12
                        system.adapter.ble                     : ble            - v0.13.0
                        system.adapter.chromecast              : chromecast     - v2.3.1
                        system.adapter.daswetter               : daswetter      - v3.1.3
                        system.adapter.devices                 : devices        - v1.0.12
                        system.adapter.discovery               : discovery      - v3.0.5
                        system.adapter.dwd                     : dwd            - v2.8.3
                        system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.4
                        system.adapter.fullybrowser            : fullybrowser   - v2.1.2
                        system.adapter.govee                   : govee          - v0.0.5
                        system.adapter.gruenbeck               : gruenbeck      - v0.0.42
                        system.adapter.history                 : history        - v2.2.0
                        system.adapter.hue                     : hue            - v3.7.1
                        system.adapter.hue-extended            : hue-extended   - v2.0.0
                        system.adapter.ical                    : ical           - v1.13.1
                        system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
                        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                        system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                        system.adapter.info                    : info           - v1.9.19
                        system.adapter.iot                     : iot            - v1.11.9
                        system.adapter.javascript              : javascript     - v6.0.3
                        system.adapter.mielecloudservice       : mielecloudservice - v6.3.2
                        system.adapter.musiccast               : musiccast      - v0.2.2
                        system.adapter.net-tools               : net-tools      - v0.2.0
                        system.adapter.netatmo                 : netatmo        - v1.7.1
                        system.adapter.onvif                   : onvif          - v0.4.4
                        system.adapter.ping                    : ping           - v1.5.3
                        system.adapter.pollenflug              : pollenflug     - v1.0.6
                        system.adapter.scenes                  : scenes         - v2.3.9
                        system.adapter.schoolfree              : schoolfree     - v1.0.1
                        system.adapter.shelly                  : shelly         - v6.0.0
                        system.adapter.shuttercontrol          : shuttercontrol - v1.4.14
                        system.adapter.simple-api              : simple-api     - v2.7.0
                        system.adapter.smartcontrol            : smartcontrol   - v1.2.1
                        system.adapter.socketio                : socketio       - v6.1.7
                        system.adapter.sonoff                  : sonoff         - v2.5.1
                        system.adapter.sonos                   : sonos          - v2.2.3
                        system.adapter.trashschedule           : trashschedule  - v2.0.3
                        system.adapter.vis                     : vis            - v1.4.15
                        system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.3.0
                        system.adapter.vis-inventwo            : vis-inventwo   - v3.3.3
                        system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
                        system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.94
                        system.adapter.vis-metro               : vis-metro      - v1.2.0
                        system.adapter.vis-players             : vis-players    - v0.1.6
                        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                        system.adapter.vis-weather             : vis-weather    - v2.5.5
                        system.adapter.weatherunderground      : weatherunderground - v3.4.2
                        system.adapter.web                     : web            - v5.2.3
                        system.adapter.ws                      : ws             - v2.1.2
                        system.adapter.zigbee                  : zigbee         - v1.7.5
                          tja:man-shrugging:
                          @crunchip
                          • G gluecksmann
                            Hallo, habe aufgrund eines tragischen Umstands meine komplette VIS verloren... ich hatte mir relativ viel von Sigis VIS übernommen Leider sind diese für viel größere Anzeigen gedach. hat jemand eine aufgeräumte VIS für ein FireTablet im Querformat? Muß gar keine exotischen Sachen wie Benzinpreise machen...Lichter sollen geschaltet werden, Wetter vorhergeagt..Standart halt...Bei mr ist halt das Problem das optisch schick zu machen...
                            sigi234S Online
                            sigi234S Online
                            @gluecksmann
                            Alle meine Views im Inwentwo Design sind für 10 Zoll Tabletts gemacht.
                              tja:man-shrugging:
                              Na hoffentlich ist es kein Fall fürs "kaputte Thomas Brown Tool" zum testen eines neuen iobroker. :-D
                              Wobei mich die Ausgabe hier schon interessieren würde...
                              @gluecksmann
                              Magst du mal beim testen mithelfen? Siehe hier:
                              https://forum.iobroker.net/topic/59549/iob-diag-skript
                              Das aber in einem neuen Thread, das hat ja mit 'Showcases' nix mehr zu tun.
                                @gluecksmann
                                gluecksmann
                                @gluecksmann
                                Ähm, was? Du siehst meine Probleme hier.... da werde ich das garantiert nicht machen können...
                                • G gluecksmann
                                  @gluecksmann
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  Den Satz versteh ich nicht.
                                  @Thomas-Braun will helfen aber du stellst die Daten nicht zur Verfügung.
                                  Oder muss man deinen Satz anders verstehen.
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    gluecksmann
                                    @bahnuhr
                                    Ja, ich verstehe nicht was ich da machen soll.... würde gern helfen... aber es ist nicht für DAUs geschrieben
                                    • G gluecksmann
                                      @bahnuhr
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #66
                                      @bahnuhr
                                      Na, aber das steht doch im verlinkten thread von @Thomas-Braun
                                      Du sollst dich mit putty (oder etwas anderes) mit deinem iob verbinden. Einloggen und dann die 3 Befehle nacheinander angeben:
                                      curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
                                      chmod 744 iob_diag
                                      ./iob_diag
                                      Und dann bekommst du jede Menge Infos die du dann wieder hier einstellen sollst,
                                      Zum Schluss kommt dann auch noch ein summery, bei mir z.B. sowas:
                                                              v.0.0.6
                                      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                      Installation:           kvm
                                      Timezone:               Europe/Berlin
                                      User-ID:                1000
                                      X-Server:               false
                                      Pending OS-Updates:     16
                                      Nodejs-Installation:    /usr/bin/nodejs         v16.18.0
                                                              /usr/bin/node           v16.18.0
                                                              /usr/bin/npm            8.19.2
                                      ioBroker Core:          js-controller           4.0.23
                                                              admin                   6.2.23
                                      Pending iob updates:    0
                                      Active repo(s): stable
                                      Objects:                22543
                                      States:                 18226
                                      Size of iob-Database:
                                      37M     /opt/iobroker/iobroker-data/objects.jsonl
                                      22M     /opt/iobroker/iobroker-data/states.jsonl
                                      ====================== END OF SUMMARY ==================
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        @bahnuhr
                                        chmod 744 iob_diag
                                        ./iob_diag
        v.0.0.6
                                        Installation:           kvm
                                        User-ID:                1000
                                        X-Server:               false
        /usr/bin/npm            8.19.2
        admin                   6.2.23
                                        Objects:                22543
                                        States:                 18226
                                        gluecksmann
                                        schrieb am zuletzt editiert von gluecksmann
                                        #67
                                        @bahnuhr sagte in VIS für FireTablet:
                                        ./iob_diag
                                        OK...das bekomme ich hin...ich habe da was von Download usw gelesen...
                                        habe es gemacht.... leider ist das vorherige weg wenn die Zusammenfassung kommt..
                                        • G gluecksmann
                                          ./iob_diag
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #68
                                          richtig, deshalb ja vor dem summery das ganze markieren und kopieren und dann hier einfügen.
                                          Danke.
