  4. jarvis v3.1.x - just another remarkable vis
    6.0k
1.9k Beiträge 94 Kommentatoren 902.6k Aufrufe 77 Beobachtet
    @titanflex sagte in jarvis v3.1.x - just another remarkable vis:
    iobroker backup gemacht habe
    Das hat man selbstredend ja immer zu Hand.
    Titanflex
    #561
    vielen Dank für die Hilfe. Hat geklappt.
    Ja ein Backup ist sehr sehr wichtig :)
    • T Titanflex
      #562
      @titanflex
      Was sagt jetzt der Check aus dem HowTo oder
      iob diag
        @titanflex
        iob diag
        Titanflex
        #563
        das sagt
        iob diag
        code_text
        ======== Start marking the full check here =========
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Architecture:   x86_64
        Docker:         false
        Virtualization: lxc
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         17:29:37 up 0 min,  1 user,  load average: 0.67, 0.59, 0.44
        CPU threads: 2
        *** Time and Time Zones ***
        Sun Mar  5 17:29:37 UTC 2023
        UTC +0000
        Etc/UTC
        *** User and Groups ***
        simon
        /home/simon
        simon sudo iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            4.1G        848M        3.0G        1.0M        238M        3.2G
        Swap:           1.0G          0B        1.0G
        Total:          5.1G        848M        4.0G
                 4096 M total memory
                  849 M used memory
                   75 M active memory
                  952 M inactive memory
                 3007 M free memory
                    0 M buffer memory
                  238 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--101--disk--0 ext4       32G  7.9G   22G  27% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
        tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs                            tmpfs     1.6G  1.5M  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        Messages in dmesg:
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems (real ones only):
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
        /var:
        737M    /var/
        425M    /var/cache
        418M    /var/cache/apt
        349M    /var/cache/apt/archives
        190M    /var/lib
        /opt/iobroker/backups:
        161M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        495M    /opt/iobroker/iobroker-data/
        330M    /opt/iobroker/iobroker-data/files
        103M    /opt/iobroker/iobroker-data/backup-objects
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        26M     /opt/iobroker/iobroker-data/objects.jsonl
        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.a5972028.js.map
        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        15M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.19.1
        /usr/bin/node           v16.19.1
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Installed: 16.19.1-deb-1nodesource1
          Candidate: 16.19.1-deb-1nodesource1
          Version table:
         *** 16.19.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u3 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://ftp.debian.org/debian stable/main amd64 Packages
             10.24.0~dfsg-1~deb10u3 500
                500 http://security.debian.org buster/updates/main amd64 Packages
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.6
        javascript:     7.0.1
        Adapters from github:   0
        Adapter State
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
          system.adapter.go-e.0                   : go-e                  : iobroker                                 - disabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
          system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 -  enabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
          system.adapter.mobile.0                 : mobile                : iobroker                                 -  enabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 2000, bind: 0.0.0.0
        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
          system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
          system.adapter.ocpp.0                   : ocpp                  : iobroker                                 - disabled, port: 9220
          system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          system.adapter.sonnen.0                 : sonnen                : iobroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 3306
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
          system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
        + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
          system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist-latest.json
        Installed ioBroker-Instances
        Adapter    "admin"        : 6.3.6    , installed 6.3.6
        Adapter    "backitup"     : 2.6.6    , installed 2.6.6
        Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "ems-esp"      : 1.26.0   , installed 1.26.0
        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
        Adapter    "fronius"      : 1.1.3    , installed 1.1.3
        Adapter    "go-e"         : 1.0.25   , installed 1.0.25
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
        Adapter    "ical"         : 1.13.2   , installed 1.13.2
        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
        Adapter    "jarvis"       : 3.1.3    , installed 3.1.3
        Adapter    "javascript"   : 7.0.1    , installed 7.0.1
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
        Adapter    "meteoalarm"   : 2.3.3    , installed 2.3.3
        Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "node-red"     : 4.0.0    , installed 4.0.0
        Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
        Adapter    "octoprint"    : 4.1.0    , installed 4.1.0
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
        Adapter    "shelly"       : 6.4.0    , installed 6.4.0
        Adapter    "socketio"     : 6.3.4    , installed 6.3.4
        Adapter    "sonnen"       : 1.16.0   , installed 1.16.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
        Adapter    "telegram"     : 1.15.6   , installed 1.15.6
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "unifi"        : 0.6.3    , installed 0.6.3
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
        Adapter    "web"          : 5.5.2    , installed 5.5.2
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "ws"           : 2.3.6    , installed 2.3.6
        Adapter    "yahka"        : 0.17.0   , installed 0.17.0
        Objects and States
        Objects:        11938
        States:         9351
        Hit:1 http://ftp.debian.org/debian stable InRelease
        Hit:2 http://security.debian.org buster/updates InRelease
        Hit:3 http://ftp.debian.org/debian buster-updates InRelease
        Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       6500319    504/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6502559    646/io.sonoff.0
        tcp        0      0 0.0.0.0:34377           0.0.0.0:*               LISTEN      1001       6505832    1496/io.yahka.0
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6500448    246/smbd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6499435    1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6497241    165/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6500449    246/smbd
        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       6501236    530/sshd: simon@pts
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6499877    146/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6499870    146/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6500511    324/master
        tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       6501235    530/sshd: simon@pts
        tcp6       0      0 :::445                  :::*                    LISTEN      0          6500446    246/smbd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          6499437    1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6500512    324/master
        tcp6       0      0 :::22                   :::*                    LISTEN      0          6497252    165/sshd: /usr/sbin
        tcp6       0      0 :::139                  :::*                    LISTEN      0          6500447    246/smbd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6500701    340/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6505105    1440/io.web.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6499552    75/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6499436    1/init
        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          6500385    147/nmbd
        udp        0      0 192.168.178.21:137      0.0.0.0:*                           0          6500384    147/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          6500371    147/nmbd
        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          6500387    147/nmbd
        udp        0      0 192.168.178.21:138      0.0.0.0:*                           0          6500386    147/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          6500372    147/nmbd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       6505829    1496/io.yahka.0
        udp        0      0 0.0.0.0:46740           0.0.0.0:*                           1001       6504961    1388/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          6499438    1/init
        2023-03-05 17:29:46.211  - info: net-tools.0 (908) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
        2023-03-05 17:29:48.378  - info: net-tools.0 (908) Port scan finished
        2023-03-05 17:29:49.058  - info: host.iobroker instance system.adapter.tankerkoenig.0 started with pid 1267
        2023-03-05 17:29:49.896  - info: tankerkoenig.0 (1267) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v16.19.1, js-controller: 4.0.24
        2023-03-05 17:29:49.919  - info: tankerkoenig.0 (1267) Adapter is already in daemon mode
        2023-03-05 17:29:49.919  - warn: tankerkoenig.0 (1267) Sync time was too short (5). New sync time is 10 min
        2023-03-05 17:29:49.920  - info: tankerkoenig.0 (1267) Sync time set to 10 minutes or 600000 ms
        2023-03-05 17:29:49.921  - error: tankerkoenig.0 (1267) No stations defined
        2023-03-05 17:29:53.047  - info: host.iobroker instance system.adapter.text2command.0 started with pid 1329
        2023-03-05 17:29:54.099  - info: text2command.0 (1329) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v16.19.1, js-controller: 4.0.24
        2023-03-05 17:29:57.063  - info: host.iobroker instance system.adapter.upnp.0 started with pid 1388
        2023-03-05 17:29:58.083  - info: upnp.0 (1388) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v16.19.1, js-controller: 4.0.24
        2023-03-05 17:29:58.098  - info: upnp.0 (1388) Auto discover: true
        2023-03-05 17:30:01.045  - info: host.iobroker instance system.adapter.web.0 started with pid 1440
        2023-03-05 17:30:02.305  - info: web.0 (1440) starting. Version 5.5.2 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.1, js-controller: 4.0.24
        2023-03-05 17:30:02.576  - info: web.0 (1440) socket.io server listening on port 8082
        2023-03-05 17:30:02.579  - info: web.0 (1440) http server listening on port 8082
        2023-03-05 17:30:05.014  - info: host.iobroker instance system.adapter.yahka.0 started with pid 1496
        2023-03-05 17:30:06.199  - info: yahka.0 (1496) starting. Version 0.17.0 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.19.1, js-controller: 4.0.24
        2023-03-05 17:30:06.217  - info: yahka.0 (1496) adapter ready, checking config
        2023-03-05 17:30:06.223  - info: yahka.0 (1496) adding Steckdose 3D Drucker with UUID: 2a4c30c5-52e2-4981-af31-49959a32f72c
        2023-03-05 17:30:06.227  - info: yahka.0 (1496) adding Licht with UUID: f5a9c7c8-3bf9-48b3-8441-909729e85566
        2023-03-05 17:30:06.229  - info: yahka.0 (1496) adding AußenTemp with UUID: 21b2351e-6fb0-4620-b6b5-6990fd029145
        2023-03-05 17:30:06.231  - info: yahka.0 (1496) publishing bridge Yahka-0 on 0.0.0.0 using avahi
        2023-03-05 17:30:09.050  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 2251
        iob diag has finished.
        • T Titanflex
          das sagt
          iob diag
          code_text
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Docker:         false
          Virtualization: lxc
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 2
          UTC +0000
          Etc/UTC
          simon
          /home/simon
          simon sudo iobroker
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
                   4096 M total memory
                    849 M used memory
                     75 M active memory
                   3007 M free memory
                      0 M buffer memory
                    238 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          *** FILESYSTEM ***
          Messages in dmesg:
          /var:
          737M    /var/
          425M    /var/cache
          418M    /var/cache/apt
          190M    /var/lib
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.6
          javascript:     7.0.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11938
          States:         9351
          Pending Updates: 0
          #564
          @titanflex
          Setz die Zeitzone und deine Quellen verweisen z.T. auf Buster, stell das richtig auf bullseye um.
            @titanflex
            Dominik F.D Offline
            Dominik F.D Offline
            Dominik F.
            #565
            es gibt ja das Widget JasonTable, das funktioniert super und sieht super aus. Gibt es die Möglichkeit, dieses auf den Inhalt eines PopUps anzuwenden?
            Sprich, dass ich eine JsonTable in einem PopUp darstellen kann?
            • M Online
              M Online
              MCU
              #566
              @dominik-f
              Nein. Feature Request erstellen?
              https://github.com/Zefau/ioBroker.jarvis/issues
              • Dominik F.D Offline
                Dominik F.D Offline
                Dominik F.
                schrieb am zuletzt editiert von Dominik F.
                #567
                @mcu
                Hab ich erstellt, ich danke dir für deine Info
                • Dominik F.D Dominik F.
                  @mcu
                  M Online
                  M Online
                  MCU
                  #568
                  @dominik-f
                  Also ich kann dir sowas anbieten. Geht nur für "normale" JSON.
                  https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/scripts-3.1.x-pro/statelist/jsontohtmlpopup
                  M-A HuebM Dominik F.D 2 Antworten Letzte Antwort
                  • M MCU
                    @dominik-f
                    M-A HuebM Offline
                    M-A HuebM Offline
                    M-A Hueb
                    schrieb am zuletzt editiert von M-A Hueb
                    #569
                    Ich habe auf meinem Tablett und auf dem iphone das Problem, dass das mit der lila Ecke zum Vollbild vergrößern nicht funktioniert. Kann man das Umstellen, dass es beim Tippen auf den Namen vergrößert?
                    iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                    • M-A HuebM M-A Hueb
                      M Online
                      M Online
                      MCU
                      #570
                      @m-a-hueb Doppelklick auf die Widget Überschrift.
                      M-A HuebM 1 Antwort Letzte Antwort
                      • M MCU
                        M-A HuebM Offline
                        M-A HuebM Offline
                        M-A Hueb
                        #571
                        @mcu geht bei Touch eingabe nicht :-(
                          M Online
                          M Online
                          MCU
                          #572
                          @m-a-hueb Normalerweise schon. Funktioniert momentan nur, wenn man anschließend Ansicht von Portrait auf Landscape ändert oder umgekehrt. Ist also ein Bug.
                          https://github.com/Zefau/ioBroker.jarvis/issues/2275
                          • M MCU
                            @dominik-f
                            Dominik F.D Offline
                            Dominik F.D Offline
                            Dominik F.
                            #573
                            @mcu
                            Das sieht schon sehr gut aus. Leider wird es bei vielen Zeilen doch sehr unübersichtlich
                            • M Online
                              M Online
                              MCU
                              #574
                              @dominik-f Wie viele Zeilen möchtest du maximal haben?
                              • M MCU
                                Dominik F.D Offline
                                Dominik F.D Offline
                                Dominik F.
                                #575
                                @mcu
                                Ich hab da momentan so um die 40 Zeilen und 4 Spalten, ich lasse mir die Batterien mittels eines Skriptes anzeigen. Ich müsste mir das ganze also zum einen Sortieren können und zum anderen die Zeilen etwas begrenzen, sagen wir auf 10 Zeilen.
                                • ZefauZ Zefau
                                  jarvis - just another remarkable vis
                                  Besonderes Dank an @MCU, @RkcCorian und die vielen Tester, die die alpha unermüdlich auf Bugs getestet haben.
                                  ❓ Was ist jarvis? // Warum jarvis?
                                  siehe https://forum.iobroker.net/post/711191
                                  ❗ v3.0.x vs. v3.1.x: Was ist zu beachten?
                                  Es gibt strukturelle Änderungen im Datenpunkt jarvis.X.widgets. Hier erfolgt eine Konvertierung beim Upgrade zu v3.1. Mit der Version v3.0.15 ist diese Änderungen auch rückwärtskompatibel, so dass einfach zwischen den Versionen gewechselt werden kann.
                                  🌟 v3.0.x vs. v3.1x: Was ist neu?
                                  siehe https://github.com/users/Zefau/projects/2/views/15
                                  Highlights ❗
                                  • (pro) Eigene Skripte laden / ausführen (#492), dadurch auch Nutzung von jQuery bzw. anderen Frameworks (#1805)
                                  • (pro) Laden externer CSS-Dateien (Import für CSS) (#1728)
                                  • (pro) Bindings: Für Seiten und Tabs (#1352)
                                  • (pro) Bindings: Erweitert auf Feld (Body Stil, Icon Stil, usw) und Ergebnis (#1021)
                                  • (pro) Bindings: selected TAB Stil definieren (#1733)
                                  • (pro) Auswahlwert mit Funktionen (#1018)
                                  • (pro) Log in / Authentication (#662)
                                  • (pro) Secure configuration / settings via password or pin (#166)
                                  • Widget Mobile Sortierung angeben (#571)
                                  • Modul ScriptStatus (neu): Überblick über alle Skripte von ioBroker.javascript inkl. starten / stoppen (#38)
                                  • Modul AdapterLog (neu): Überblick über das ioBroker Log (#37)
                                  • Modul Map: Standort-Verfolgung von Geräten (#1784)
                                  • Modul JsonTable: JSON-Objekte anzeigbar machen (#1829)
                                  • (pro) Modul HistoryGraph: Series-Einstellungen einstellbar (#1377)
                                  • (pro) Modul HistoryGraph: formatter Callback der yAchse(n) / xAchse konfigurierbar (#1459)
                                  • (pro) Modul HistoryGraph: min/max Callback der xAchse konfigurierbar (#2050)
                                  • Pro-Bezahlung per Überweisung (ohne PayPal) (#1900)
                                  Weitere Features
                                  • Modul iFrame: Interaktion verhindern (#1880)
                                  • Modul iFrame: Erweiterung Sandbox-Optionen (#1679)
                                  • Modul HomeKitTile: Geräte Icon als Icon verwenden (#1418)
                                  • Modul DisplayImage: Bild auf Basis eines Datenpunkts ein- / ausblenden (#1409)
                                  • Modul DateTime: Trennung von Datum- und Zeitangabe (zum dediziertem Styling) (#1724 / #1242)
                                  • Modul DateTime: Zeit wird serverzeitig (aus ioBroker) geladen und nicht client-seitig (#1951)
                                  • Widget per Button als Vollbild darstellen (#589)
                                  • Widget-Vollbild auch durch Doppelklick (#1732)
                                  • Untermenü auf mobiler Seite (#1348)
                                  • Sprung ins Layout direkt zur aktuellen Seite (via F9) (#1059)
                                  Komponenten
                                  • TimePickerBody/Action sowie DatePickerBody/Action (Zeitsteuerung & Timer) (#569)
                                  • ButtonGroup: mehrere Buttons nebeneinander (#871 / #572)
                                  • setOn / setOff als Callback (#1926), siehe Wiki
                                  • SaturationSliderBody / WhiteSliderBody (neu) (#1448)
                                  • LightHueAction / LightColorAction (ColorPicker) (#602)
                                  • SecondaryStates: Labels ein-/ausblenden (#690)
                                  • SecondaryStates: Farbgestaltung an-/ausschalten (#723)
                                  • BlindLevelAction: Auch für elektrische Fenster (#1583)
                                  • SwitchAction: Acknowledge flag (#647)
                                  • Impulsdauer Taster konfigurierbar (#1893)
                                  • LightColorState; Wählbares Icon mit der State-Farbe anzeigen (#1848)
                                  • LightHueBody: Max-HUE einstellbar machen (#1425)
                                  Einstellungen
                                  • Hamburger Menü für Seiten Navigation bei nur einer vorhandenen Seite ausblenden (#1624)
                                  • Hide Scrollbar (#287)
                                  • Option to disable Swipe (#1274)
                                  • regelmäßiger Reload konfigurierbar (#1952)
                                  Design
                                  • provide selected colours as CSS variable (#1406)
                                  • Geräte-Popup mit zusätzlicher Klasse (#1639)
                                  • HistoryGraph / Chart: Nutzung von CSS-Variablen für Farben (#1313)
                                  • HistoryGraph: zusätzliche CSS-Selektor-Klassen (#1522)
                                  AdapterImport
                                  • Import Silvercrest Branded HMIP Window Contacts (#1822)
                                  • Fehlende/unvollständige HM-IP Geräte (#1613)
                                  • Import / adapt devices and layout from ioBroker.zigbee2mqtt (#2033)
                                  • Neues HomematicIP Thermostat HmIP-eTRV-C-2 (#1957)
                                  • Homematic IP Geräte - HmIP-FSM16 - HmIP-PDT (#1683)
                                  • Asksin++ Homebrew Geräte (#1612)
                                  • Homematic IP Wired (#1746)
                                  • Sollten euch noch Geräte fehlen, bitte ein Issue auf GitHub öffnen (via https://github.com/Zefau/ioBroker.jarvis/issues)
                                  Sonstiges
                                  • Adapter Info in ioBroker - Link zum Wiki (#1620)
                                  • Upgrade to Vue 3 (#1214)
                                  • Refactor and Performance Improvements (#1655)
                                  • Prüfung verwendeter IDs auf Duplikate (#1366)
                                  🗣 jarvis übersetzen / translate jarvis
                                  Gibt es jemanden, der eine andere Sprache nativ als Muttersprache spricht und Lust hat, jarvis zu übersetzen?
                                  Siehe https://github.com/Zefau/jarvis.i18n
                                  __
                                  Anyone who speaks another language fluently / mother tongue and likes to translate jarvis?
                                  See https://github.com/Zefau/jarvis.i18n
                                  💗 v3: Unterstützung durch Pro-Account
                                  Die v3 führt einen Pro-Account ein, mit der diverse Pro-Features genutzt werden können. Ab v3 ist jarvis damit Freemium, was bedeutet, dass jarvis grundsätzlich in vielen Belangen kostenlos ist (und bleibt), ihr aber das Projekt unterstützen könnt und dann einen gewissen erweiterten Umfang habt. Eine Auflistung von Pro-Features gibt es via Github-Issues. Außerdem gibt es eine Diskussion zum Thema Pro-Account inkl. Feature-Auflistung.
                                  Das Abonnement kann in den jarvis Einstellungen via PayPal gekauft werden, ist jederzeit kündbar und läuft bei Kündigung bis zum bezahlten Ende fort (also mindestens 1 Jahr). Sofern es Schwierigkeiten gibt, meldet euch gerne bei mir via ioBroker.jarvis@mailbox.org.
                                  ❗ Nach dem Kauf bitte die Lizenz in den Datenpunkt jarvis.0.info.pro kopieren, sofern dies automatisch nicht geklappt haben sollte.
                                  Bitte versteht die eingeführte Möglichkeit des Abonnements nicht nur als reine Bezahlung, sondern auch als Unterstützung zur Weiterentwicklung des Adapters. Vielen Dank für euren Support!
                                  N Offline
                                  N Offline
                                  Nonixnarrez
                                  schrieb am zuletzt editiert von Nonixnarrez
                                  #576
                                  @zefau @MCU
                                  Moin zusammen,
                                  kann es sein, dass sich in der letzten oder vorletzten Jarvis Version die Interpretation bzw. das JSON Format für die Datenpunkteigenschaften verändert hat?
                                  Bisher funktionierte min/max und runden (1 Kommastelle) immer mit folgendem JSON Format für die Datenpunkt-Eigenschaften:
                                  {"min":15,"max":25,"value":"val => parseFloat(val).toFixed(1)"}
                                  Jetzt, unter Jarvis 3.1.3, klappt es bei mir leider nur noch entweder {"min":15,"max":25} oder {"value":"val => parseFloat(val).toFixed(1)"}.
                                  Ist das ein Bug (GitHub Issue) oder ein Feature? 🤔
                                  Viele Grüße /// Noni
                                  Raspberry Pi 4b (8GB), Trixie/aarch64, js-controller (v7.1.0), Node.js (v22.21.0), ioBroker.admin (v7.7.22), NPM (v10.9.4), Jarvis (v3.1.8), InfluxDB (v1.12.2-4), Grafana (v12.3.1), Sonoff Tasmota (v13.1.0.1), Pi-hole Core (v6.3), XigmaNAS (v13.2.0.5.9876), FRITZ!Box 6660 (v8.03)
                                  • Marc_el_KM Offline
                                    Marc_el_KM Offline
                                    Marc_el_K
                                    schrieb am zuletzt editiert von Marc_el_K
                                    #577
                                    @MCU Ich habe von einem anderen Adapter (ONVIF) einen Datenpunkt mit einem Kamera-Snapshot. Der Inhalt des Bilds beginnt mit: data:image/jpg;base64,.................
                                    Kannst du mir sagen, wie man dies in Jarvis integriert?
                                    Edit: Okay, habe es als Gerät hinzugefügt und dann via DisplayImage eingefügt.
                                    • M Online
                                      M Online
                                      MCU
                                      #578
                                      @nonixnarrez Bitte als Issue anlegen.
                                      N 1 Antwort Letzte Antwort
                                      • ZefauZ Zefau
                                        Highlights ❗
                                        Weitere Features
                                        Komponenten
                                        Einstellungen
                                        Design
                                        AdapterImport
                                        Sonstiges
                                        __
                                        funky4t
                                        schrieb am zuletzt editiert von funky4t
                                        #579
                                        Hallo liebe Jarvis Fans,
                                        ich hab mal eine dumme Frage, bin auf der 3.1.2 und verstehe einfach den Button "Change widget responsive order" nicht. Mir erschließt sich nicht, was beim Klick darauf genau passiert?! Normalerweise hätte ich gedacht, ich könnte die kleinen Nummern bei den Widgets so verschieben/ändern (manuell oder automatisch), das sich eine neue responsive Order ergibt. Das klappt bei mir jedoch nicht. So oft ich auch auf den Button klicke, es ändert sich keine Indexnummer noch kann ich die irgendwo neu eingeben, ergo ändert sich auch nicht die Responsive-View auf dem Smartphone. Ich hab auf Git geschaut, aber da steht lediglich, dass es ab 3.1.x mit dem Button möglich sein soll, aber mir erschließt sich einfach nicht, wie genau.
                                        Baum-Wald Problem oder User?? 😕
                                        1000 Dank falls mich jemand erleuchten kann, wie genau der Button funktionieren soll. 🤗
                                        Dominik F.D M 2 Antworten Letzte Antwort
                                        • F funky4t
                                          Dominik F.D Offline
                                          Dominik F.D Offline
                                          Dominik F.
                                          #580
                                          @funky4t
                                          Wenn du darauf klickst, erscheint ein PopUp wo du die verschiedenen Widgets neu ordnen kannst, also genau so wie du es erwartet hast.
                                          Ich nutze allerdings Version v3.1.4-beta.6, vielleicht geht es erst bei einer späteren Version^^
