  4. jarvis v3.1.x - just another remarkable vis
1.9k Beiträge 94 Kommentatoren 927.5k Aufrufe 77 Beobachtet
  • T Titanflex
    vielen Dank für die Hilfe. Hat geklappt.
    Ja ein Backup ist sehr sehr wichtig :)
    #562
    @titanflex
    Was sagt jetzt der Check aus dem HowTo oder
    iob diag
      @titanflex
      iob diag
      Titanflex
      #563
      das sagt
      iob diag
      code_text
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Architecture:   x86_64
      Docker:         false
      Virtualization: lxc
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       17:29:37 up 0 min,  1 user,  load average: 0.67, 0.59, 0.44
      CPU threads: 2
      *** Time and Time Zones ***
      Sun Mar  5 17:29:37 UTC 2023
      UTC +0000
      Etc/UTC
      *** User and Groups ***
      simon
      /home/simon
      simon sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            4.1G        848M        3.0G        1.0M        238M        3.2G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        848M        4.0G
               4096 M total memory
                849 M used memory
                 75 M active memory
                952 M inactive memory
               3007 M free memory
                  0 M buffer memory
                238 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       32G  7.9G   22G  27% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  1.5M  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Messages in dmesg:
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
      /var:
      737M    /var/
      425M    /var/cache
      418M    /var/cache/apt
      349M    /var/cache/apt/archives
      190M    /var/lib
      /opt/iobroker/backups:
      161M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      495M    /opt/iobroker/iobroker-data/
      330M    /opt/iobroker/iobroker-data/files
      103M    /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.a5972028.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      15M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.1
      /usr/bin/node           v16.19.1
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Candidate: 16.19.1-deb-1nodesource1
        Version table:
       *** 16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://ftp.debian.org/debian stable/main amd64 Packages
           10.24.0~dfsg-1~deb10u3 500
              500 http://security.debian.org buster/updates/main amd64 Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.6
      javascript:     7.0.1
      Adapters from github:   0
      Adapter State
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
        system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        system.adapter.go-e.0                   : go-e                  : iobroker                                 - disabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled
        system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
        system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker                                 -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 2000, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
        system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
        system.adapter.ocpp.0                   : ocpp                  : iobroker                                 - disabled, port: 9220
        system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.sonnen.0                 : sonnen                : iobroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
      + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
        system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.3.6    , installed 6.3.6
      Adapter    "backitup"     : 2.6.6    , installed 2.6.6
      Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
      Adapter    "ems-esp"      : 1.26.0   , installed 1.26.0
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "go-e"         : 1.0.25   , installed 1.0.25
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
      Adapter    "jarvis"       : 3.1.3    , installed 3.1.3
      Adapter    "javascript"   : 7.0.1    , installed 7.0.1
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "meteoalarm"   : 2.3.3    , installed 2.3.3
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
      Adapter    "octoprint"    : 4.1.0    , installed 4.1.0
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "shelly"       : 6.4.0    , installed 6.4.0
      Adapter    "socketio"     : 6.3.4    , installed 6.3.4
      Adapter    "sonnen"       : 1.16.0   , installed 1.16.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.15.6   , installed 1.15.6
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "unifi"        : 0.6.3    , installed 0.6.3
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "web"          : 5.5.2    , installed 5.5.2
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.3.6    , installed 2.3.6
      Adapter    "yahka"        : 0.17.0   , installed 0.17.0
      Objects and States
      Objects:        11938
      States:         9351
      Hit:1 http://ftp.debian.org/debian stable InRelease
      Hit:2 http://security.debian.org buster/updates InRelease
      Hit:3 http://ftp.debian.org/debian buster-updates InRelease
      Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       6500319    504/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6502559    646/io.sonoff.0
      tcp        0      0 0.0.0.0:34377           0.0.0.0:*               LISTEN      1001       6505832    1496/io.yahka.0
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6500448    246/smbd
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6499435    1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6497241    165/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6500449    246/smbd
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       6501236    530/sshd: simon@pts
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6499877    146/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6499870    146/iobroker.js-con
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6500511    324/master
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       6501235    530/sshd: simon@pts
      tcp6       0      0 :::445                  :::*                    LISTEN      0          6500446    246/smbd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          6499437    1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6500512    324/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6497252    165/sshd: /usr/sbin
      tcp6       0      0 :::139                  :::*                    LISTEN      0          6500447    246/smbd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6500701    340/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6505105    1440/io.web.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6499552    75/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6499436    1/init
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          6500385    147/nmbd
      udp        0      0 192.168.178.21:137      0.0.0.0:*                           0          6500384    147/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          6500371    147/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          6500387    147/nmbd
      udp        0      0 192.168.178.21:138      0.0.0.0:*                           0          6500386    147/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          6500372    147/nmbd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       6505829    1496/io.yahka.0
      udp        0      0 0.0.0.0:46740           0.0.0.0:*                           1001       6504961    1388/io.upnp.0
      udp6       0      0 :::111                  :::*                                0          6499438    1/init
      2023-03-05 17:29:46.211  - info: net-tools.0 (908) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
      2023-03-05 17:29:48.378  - info: net-tools.0 (908) Port scan finished
      2023-03-05 17:29:49.058  - info: host.iobroker instance system.adapter.tankerkoenig.0 started with pid 1267
      2023-03-05 17:29:49.896  - info: tankerkoenig.0 (1267) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v16.19.1, js-controller: 4.0.24
      2023-03-05 17:29:49.919  - info: tankerkoenig.0 (1267) Adapter is already in daemon mode
      2023-03-05 17:29:49.919  - warn: tankerkoenig.0 (1267) Sync time was too short (5). New sync time is 10 min
      2023-03-05 17:29:49.920  - info: tankerkoenig.0 (1267) Sync time set to 10 minutes or 600000 ms
      2023-03-05 17:29:49.921  - error: tankerkoenig.0 (1267) No stations defined
      2023-03-05 17:29:53.047  - info: host.iobroker instance system.adapter.text2command.0 started with pid 1329
      2023-03-05 17:29:54.099  - info: text2command.0 (1329) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v16.19.1, js-controller: 4.0.24
      2023-03-05 17:29:57.063  - info: host.iobroker instance system.adapter.upnp.0 started with pid 1388
      2023-03-05 17:29:58.083  - info: upnp.0 (1388) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v16.19.1, js-controller: 4.0.24
      2023-03-05 17:29:58.098  - info: upnp.0 (1388) Auto discover: true
      2023-03-05 17:30:01.045  - info: host.iobroker instance system.adapter.web.0 started with pid 1440
      2023-03-05 17:30:02.305  - info: web.0 (1440) starting. Version 5.5.2 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.1, js-controller: 4.0.24
      2023-03-05 17:30:02.576  - info: web.0 (1440) socket.io server listening on port 8082
      2023-03-05 17:30:02.579  - info: web.0 (1440) http server listening on port 8082
      2023-03-05 17:30:05.014  - info: host.iobroker instance system.adapter.yahka.0 started with pid 1496
      2023-03-05 17:30:06.199  - info: yahka.0 (1496) starting. Version 0.17.0 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.19.1, js-controller: 4.0.24
      2023-03-05 17:30:06.217  - info: yahka.0 (1496) adapter ready, checking config
      2023-03-05 17:30:06.223  - info: yahka.0 (1496) adding Steckdose 3D Drucker with UUID: 2a4c30c5-52e2-4981-af31-49959a32f72c
      2023-03-05 17:30:06.227  - info: yahka.0 (1496) adding Licht with UUID: f5a9c7c8-3bf9-48b3-8441-909729e85566
      2023-03-05 17:30:06.229  - info: yahka.0 (1496) adding AußenTemp with UUID: 21b2351e-6fb0-4620-b6b5-6990fd029145
      2023-03-05 17:30:06.231  - info: yahka.0 (1496) publishing bridge Yahka-0 on 0.0.0.0 using avahi
      2023-03-05 17:30:09.050  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 2251
      iob diag has finished.
      • T Titanflex
        das sagt
        iob diag
        code_text
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Docker:         false
        Virtualization: lxc
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 2
        UTC +0000
        Etc/UTC
        simon
        /home/simon
        simon sudo iobroker
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
                 4096 M total memory
                  849 M used memory
                   75 M active memory
                 3007 M free memory
                    0 M buffer memory
                  238 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        *** FILESYSTEM ***
        Messages in dmesg:
        /var:
        737M    /var/
        425M    /var/cache
        418M    /var/cache/apt
        190M    /var/lib
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.6
        javascript:     7.0.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        11938
        States:         9351
        Pending Updates: 0
        #564
        @titanflex
        Setz die Zeitzone und deine Quellen verweisen z.T. auf Buster, stell das richtig auf bullseye um.
          @titanflex
          Dominik F.D Offline
          Dominik F.D Offline
          Dominik F.
          #565
          es gibt ja das Widget JasonTable, das funktioniert super und sieht super aus. Gibt es die Möglichkeit, dieses auf den Inhalt eines PopUps anzuwenden?
          Sprich, dass ich eine JsonTable in einem PopUp darstellen kann?
            MCU
            #566
            @dominik-f
            Nein. Feature Request erstellen?
            https://github.com/Zefau/ioBroker.jarvis/issues
            • Dominik F.D Offline
              Dominik F.D Offline
              Dominik F.
              schrieb am zuletzt editiert von Dominik F.
              #567
              @mcu
              Hab ich erstellt, ich danke dir für deine Info
              • Dominik F.D Dominik F.
                @mcu
                MCU
                #568
                @dominik-f
                Also ich kann dir sowas anbieten. Geht nur für "normale" JSON.
                https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/scripts-3.1.x-pro/statelist/jsontohtmlpopup
                M-A HuebM Dominik F.D 2 Antworten Letzte Antwort
                • M MCU
                  @dominik-f
                  M-A HuebM Offline
                  M-A HuebM Offline
                  M-A Hueb
                  schrieb am zuletzt editiert von M-A Hueb
                  #569
                  Ich habe auf meinem Tablett und auf dem iphone das Problem, dass das mit der lila Ecke zum Vollbild vergrößern nicht funktioniert. Kann man das Umstellen, dass es beim Tippen auf den Namen vergrößert?
                  iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                  • M-A HuebM M-A Hueb
                    MCU
                    #570
                    @m-a-hueb Doppelklick auf die Widget Überschrift.
                    M-A HuebM 1 Antwort Letzte Antwort
                    • M MCU
                      M-A HuebM Offline
                      M-A HuebM Offline
                      M-A Hueb
                      #571
                      @mcu geht bei Touch eingabe nicht :-(
                        MCU
                        #572
                        @m-a-hueb Normalerweise schon. Funktioniert momentan nur, wenn man anschließend Ansicht von Portrait auf Landscape ändert oder umgekehrt. Ist also ein Bug.
                        https://github.com/Zefau/ioBroker.jarvis/issues/2275
                        • M MCU
                          @dominik-f
                          Dominik F.D Offline
                          Dominik F.D Offline
                          Dominik F.
                          #573
                          @mcu
                          Das sieht schon sehr gut aus. Leider wird es bei vielen Zeilen doch sehr unübersichtlich
                            MCU
                            #574
                            @dominik-f Wie viele Zeilen möchtest du maximal haben?
                            • M MCU
                              Dominik F.D Offline
                              Dominik F.D Offline
                              Dominik F.
                              #575
                              @mcu
                              Ich hab da momentan so um die 40 Zeilen und 4 Spalten, ich lasse mir die Batterien mittels eines Skriptes anzeigen. Ich müsste mir das ganze also zum einen Sortieren können und zum anderen die Zeilen etwas begrenzen, sagen wir auf 10 Zeilen.
                              • ZefauZ Zefau
                                jarvis - just another remarkable vis
                                Besonderes Dank an @MCU, @RkcCorian und die vielen Tester, die die alpha unermüdlich auf Bugs getestet haben.
                                ❓ Was ist jarvis? // Warum jarvis?
                                siehe https://forum.iobroker.net/post/711191
                                ❗ v3.0.x vs. v3.1.x: Was ist zu beachten?
                                Es gibt strukturelle Änderungen im Datenpunkt jarvis.X.widgets. Hier erfolgt eine Konvertierung beim Upgrade zu v3.1. Mit der Version v3.0.15 ist diese Änderungen auch rückwärtskompatibel, so dass einfach zwischen den Versionen gewechselt werden kann.
                                🌟 v3.0.x vs. v3.1x: Was ist neu?
                                siehe https://github.com/users/Zefau/projects/2/views/15
                                Highlights ❗
                                • (pro) Eigene Skripte laden / ausführen (#492), dadurch auch Nutzung von jQuery bzw. anderen Frameworks (#1805)
                                • (pro) Laden externer CSS-Dateien (Import für CSS) (#1728)
                                • (pro) Bindings: Für Seiten und Tabs (#1352)
                                • (pro) Bindings: Erweitert auf Feld (Body Stil, Icon Stil, usw) und Ergebnis (#1021)
                                • (pro) Bindings: selected TAB Stil definieren (#1733)
                                • (pro) Auswahlwert mit Funktionen (#1018)
                                • (pro) Log in / Authentication (#662)
                                • (pro) Secure configuration / settings via password or pin (#166)
                                • Widget Mobile Sortierung angeben (#571)
                                • Modul ScriptStatus (neu): Überblick über alle Skripte von ioBroker.javascript inkl. starten / stoppen (#38)
                                • Modul AdapterLog (neu): Überblick über das ioBroker Log (#37)
                                • Modul Map: Standort-Verfolgung von Geräten (#1784)
                                • Modul JsonTable: JSON-Objekte anzeigbar machen (#1829)
                                • (pro) Modul HistoryGraph: Series-Einstellungen einstellbar (#1377)
                                • (pro) Modul HistoryGraph: formatter Callback der yAchse(n) / xAchse konfigurierbar (#1459)
                                • (pro) Modul HistoryGraph: min/max Callback der xAchse konfigurierbar (#2050)
                                • Pro-Bezahlung per Überweisung (ohne PayPal) (#1900)
                                Weitere Features
                                • Modul iFrame: Interaktion verhindern (#1880)
                                • Modul iFrame: Erweiterung Sandbox-Optionen (#1679)
                                • Modul HomeKitTile: Geräte Icon als Icon verwenden (#1418)
                                • Modul DisplayImage: Bild auf Basis eines Datenpunkts ein- / ausblenden (#1409)
                                • Modul DateTime: Trennung von Datum- und Zeitangabe (zum dediziertem Styling) (#1724 / #1242)
                                • Modul DateTime: Zeit wird serverzeitig (aus ioBroker) geladen und nicht client-seitig (#1951)
                                • Widget per Button als Vollbild darstellen (#589)
                                • Widget-Vollbild auch durch Doppelklick (#1732)
                                • Untermenü auf mobiler Seite (#1348)
                                • Sprung ins Layout direkt zur aktuellen Seite (via F9) (#1059)
                                Komponenten
                                • TimePickerBody/Action sowie DatePickerBody/Action (Zeitsteuerung & Timer) (#569)
                                • ButtonGroup: mehrere Buttons nebeneinander (#871 / #572)
                                • setOn / setOff als Callback (#1926), siehe Wiki
                                • SaturationSliderBody / WhiteSliderBody (neu) (#1448)
                                • LightHueAction / LightColorAction (ColorPicker) (#602)
                                • SecondaryStates: Labels ein-/ausblenden (#690)
                                • SecondaryStates: Farbgestaltung an-/ausschalten (#723)
                                • BlindLevelAction: Auch für elektrische Fenster (#1583)
                                • SwitchAction: Acknowledge flag (#647)
                                • Impulsdauer Taster konfigurierbar (#1893)
                                • LightColorState; Wählbares Icon mit der State-Farbe anzeigen (#1848)
                                • LightHueBody: Max-HUE einstellbar machen (#1425)
                                Einstellungen
                                • Hamburger Menü für Seiten Navigation bei nur einer vorhandenen Seite ausblenden (#1624)
                                • Hide Scrollbar (#287)
                                • Option to disable Swipe (#1274)
                                • regelmäßiger Reload konfigurierbar (#1952)
                                Design
                                • provide selected colours as CSS variable (#1406)
                                • Geräte-Popup mit zusätzlicher Klasse (#1639)
                                • HistoryGraph / Chart: Nutzung von CSS-Variablen für Farben (#1313)
                                • HistoryGraph: zusätzliche CSS-Selektor-Klassen (#1522)
                                AdapterImport
                                • Import Silvercrest Branded HMIP Window Contacts (#1822)
                                • Fehlende/unvollständige HM-IP Geräte (#1613)
                                • Import / adapt devices and layout from ioBroker.zigbee2mqtt (#2033)
                                • Neues HomematicIP Thermostat HmIP-eTRV-C-2 (#1957)
                                • Homematic IP Geräte - HmIP-FSM16 - HmIP-PDT (#1683)
                                • Asksin++ Homebrew Geräte (#1612)
                                • Homematic IP Wired (#1746)
                                • Sollten euch noch Geräte fehlen, bitte ein Issue auf GitHub öffnen (via https://github.com/Zefau/ioBroker.jarvis/issues)
                                Sonstiges
                                • Adapter Info in ioBroker - Link zum Wiki (#1620)
                                • Upgrade to Vue 3 (#1214)
                                • Refactor and Performance Improvements (#1655)
                                • Prüfung verwendeter IDs auf Duplikate (#1366)
                                🗣 jarvis übersetzen / translate jarvis
                                Gibt es jemanden, der eine andere Sprache nativ als Muttersprache spricht und Lust hat, jarvis zu übersetzen?
                                Siehe https://github.com/Zefau/jarvis.i18n
                                __
                                Anyone who speaks another language fluently / mother tongue and likes to translate jarvis?
                                See https://github.com/Zefau/jarvis.i18n
                                💗 v3: Unterstützung durch Pro-Account
                                Die v3 führt einen Pro-Account ein, mit der diverse Pro-Features genutzt werden können. Ab v3 ist jarvis damit Freemium, was bedeutet, dass jarvis grundsätzlich in vielen Belangen kostenlos ist (und bleibt), ihr aber das Projekt unterstützen könnt und dann einen gewissen erweiterten Umfang habt. Eine Auflistung von Pro-Features gibt es via Github-Issues. Außerdem gibt es eine Diskussion zum Thema Pro-Account inkl. Feature-Auflistung.
                                Das Abonnement kann in den jarvis Einstellungen via PayPal gekauft werden, ist jederzeit kündbar und läuft bei Kündigung bis zum bezahlten Ende fort (also mindestens 1 Jahr). Sofern es Schwierigkeiten gibt, meldet euch gerne bei mir via ioBroker.jarvis@mailbox.org.
                                ❗ Nach dem Kauf bitte die Lizenz in den Datenpunkt jarvis.0.info.pro kopieren, sofern dies automatisch nicht geklappt haben sollte.
                                Bitte versteht die eingeführte Möglichkeit des Abonnements nicht nur als reine Bezahlung, sondern auch als Unterstützung zur Weiterentwicklung des Adapters. Vielen Dank für euren Support!
                                N Offline
                                N Offline
                                Nonixnarrez
                                schrieb am zuletzt editiert von Nonixnarrez
                                #576
                                @zefau @MCU
                                Moin zusammen,
                                kann es sein, dass sich in der letzten oder vorletzten Jarvis Version die Interpretation bzw. das JSON Format für die Datenpunkteigenschaften verändert hat?
                                Bisher funktionierte min/max und runden (1 Kommastelle) immer mit folgendem JSON Format für die Datenpunkt-Eigenschaften:
                                {"min":15,"max":25,"value":"val => parseFloat(val).toFixed(1)"}
                                Jetzt, unter Jarvis 3.1.3, klappt es bei mir leider nur noch entweder {"min":15,"max":25} oder {"value":"val => parseFloat(val).toFixed(1)"}.
                                Ist das ein Bug (GitHub Issue) oder ein Feature? 🤔
                                Viele Grüße /// Noni
                                Raspberry Pi 4b (8GB), Trixie/aarch64, js-controller (v7.1.0), Node.js (v22.21.0), ioBroker.admin (v7.7.22), NPM (v10.9.4), Jarvis (v3.1.8), InfluxDB (v1.12.2-4), Grafana (v12.3.1), Sonoff Tasmota (v13.1.0.1), Pi-hole Core (v6.3), XigmaNAS (v13.2.0.5.9876), FRITZ!Box 6660 (v8.03)
                                • Marc_el_KM Offline
                                  Marc_el_KM Offline
                                  Marc_el_K
                                  schrieb am zuletzt editiert von Marc_el_K
                                  #577
                                  @MCU Ich habe von einem anderen Adapter (ONVIF) einen Datenpunkt mit einem Kamera-Snapshot. Der Inhalt des Bilds beginnt mit: data:image/jpg;base64,.................
                                  Kannst du mir sagen, wie man dies in Jarvis integriert?
                                  Edit: Okay, habe es als Gerät hinzugefügt und dann via DisplayImage eingefügt.
                                    MCU
                                    #578
                                    @nonixnarrez Bitte als Issue anlegen.
                                    N 1 Antwort Letzte Antwort
                                    • ZefauZ Zefau
                                      Highlights ❗
                                      Weitere Features
                                      Komponenten
                                      Einstellungen
                                      Design
                                      AdapterImport
                                      Sonstiges
                                      __
                                      funky4t
                                      schrieb am zuletzt editiert von funky4t
                                      #579
                                      Hallo liebe Jarvis Fans,
                                      ich hab mal eine dumme Frage, bin auf der 3.1.2 und verstehe einfach den Button "Change widget responsive order" nicht. Mir erschließt sich nicht, was beim Klick darauf genau passiert?! Normalerweise hätte ich gedacht, ich könnte die kleinen Nummern bei den Widgets so verschieben/ändern (manuell oder automatisch), das sich eine neue responsive Order ergibt. Das klappt bei mir jedoch nicht. So oft ich auch auf den Button klicke, es ändert sich keine Indexnummer noch kann ich die irgendwo neu eingeben, ergo ändert sich auch nicht die Responsive-View auf dem Smartphone. Ich hab auf Git geschaut, aber da steht lediglich, dass es ab 3.1.x mit dem Button möglich sein soll, aber mir erschließt sich einfach nicht, wie genau.
                                      Baum-Wald Problem oder User?? 😕
                                      1000 Dank falls mich jemand erleuchten kann, wie genau der Button funktionieren soll. 🤗
                                      Dominik F.D M 2 Antworten Letzte Antwort
                                      • F funky4t
                                        Dominik F.D Offline
                                        Dominik F.D Offline
                                        Dominik F.
                                        #580
                                        @funky4t
                                        Wenn du darauf klickst, erscheint ein PopUp wo du die verschiedenen Widgets neu ordnen kannst, also genau so wie du es erwartet hast.
                                        Ich nutze allerdings Version v3.1.4-beta.6, vielleicht geht es erst bei einer späteren Version^^
                                        • F funky4t
                                          MCU
                                          #581
                                          @funky4t
                                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/widgets#widgets-reihenfolge-aendern-fuer-mobile-ansicht-v3.1.x
                                          Funktioniert auch mit v3.1.2.
                                          Evtl. auf der console:
                                          iob upload jarvis
                                          F 1 Antwort Letzte Antwort
