  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • D danny_v1
    @tt-tom Ja auf dem Panel sehe ich alles.
    Hier die PageConfig
    let WLED_Bad= <PageGrid>
                                "type": "cardGrid",
                                "heading": "WLED",
                                "useColor": true,
                                "subPage": true,
                                "parent": Bad,
                                "items": [
                                    <PageItem>{ id: "alias.0.Bad.BadWLED.Power", name: "Power", icon: "power", onColor: Blue, offColor: HMIOff},
                                    <PageItem>{ id: "alias.0.Bad.BadWLED.Synch", name: "Sync", icon: "sync", onColor: Blue, offColor: White},
                                    <PageItem>{ id: "alias.0.Bad.BadWLED.Timer", name: "Timer", icon: "moon-waxing-crescent", onColor: Blue, offColor: White},
                                    <PageItem>{ id: "alias.0.Bad.BadWLED.Presets", icon: "heart-outline", name: "Presets", onColor: White, modeList: ['Rainbow', 'Lake']},
                                    <PageItem>{ id: "alias.0.Bad.BadWLED.Colors", icon: "palette", name: "Colors", onColor: White,
                                                modeList: ['Default', '* Color 1', '* Color Gradient', '* Colors 1&2', '* Colors Only', '* Random Cycle', 'Analogus','April Night', 'Aqua Flash', 'Atlantica', 'Aurora', 'Beach', 'Beech', 'Blink Red', 'Breeze', 'C9', 'C9 New', 'Candy', 'Candy2', 'Cloud', 'Cyane', 'Departure', 'Drywet', 'Fairy Reaf', 'Fire', 'Forest', 'etc']},
                                    <PageItem>{ id: "alias.0.Bad.BadWLED.Effects", icon: "emoticon-outline", name: "Effects", onColor: White,
                                                modeList: ['Solid', 'Android', 'Aurora', 'Blends', 'Blink', 'Blink Rainbow', 'Bouncing Balls','Bpm', 'Breathe', 'Candle', 'Candle Multi', 'Candy Cane', 'Chase', 'Chase 1', 'Chase 2', 'Chase 3', 'Chase Flash', 'Chase Flash Rnd', 'Chase Rainbow', 'Chase Random', 'Chunchun', 'Colorful', 'Colorloop', 'Colortwinkles', 'Colorwaves', 'Dancing Shadows', 'etc']},
                                    //<PageItem>{ id: "alias.0.NSPanel_1.WLED.Example.Segments", icon: "layers", name: "Segments", onColor: White, modeList: ['Segment 0', 'Add Segment']},
    und hier das JS Skript
    // Pfad zum WLED-Modul
    const wledPath = 'wled.0.ecfabcc58b7f.';
    // Pfad zu 0_userdata Datenpunkten
    const userdataPath = '0_userdata.0.BadWLED.';
    // WLED Effektliste als Konstante (Favoriten)
    // Listen müssen gleiche Werte wie im Panel haben
    const presetList =    ['Rainbow', 'Lake'];
    const colorsList =    ['Default', '* Color 1', '* Color Gradient', '* Colors 1&2', '* Colors Only', '* Random Cycle', 'Analogus','April Night', 'Aqua Flash', 'Atlantica', 'Aurora',
    const effectsList =   ['Solid', 'Android', 'Aurora', 'Blends', 'Blink', 'Blink Rainbow', 'Bouncing Balls','Bpm', 'Breathe', 'Candle', 'Candle Multi',
    on({id: userdataPath + 'Presets', change: "ne"}, async function (obj) {
        console.log(wledPath + 'ps' + ' = ' + obj.state.val);
        setState(wledPath + 'ps', obj.state.val)
    // Trigger auf NSPanel Colors
    on({id: userdataPath + 'Colors', change: "ne"}, async function (obj) {
        let wledObj = getObject(wledPath + 'seg.0.pal');
        let tempStringColor = colorsList[obj.state.val]
        for (let i = 1; i < 71; i++) {
            if (wledObj.common.states[i] == undefined) {
                break;
            if (wledObj.common.states[i] == tempStringColor) {
                console.log(i + ' - ' + wledObj.common.states[i]);
                setState(wledPath + 'seg.0.pal', i)
                break;
    // Trigger auf NSPanel Effekte
    on({id: userdataPath + 'Effects', change: "ne"}, async function (obj) {
        let wledObj = getObject(wledPath + 'seg.0.fx');
        let tempStringEffect = effectsList[obj.state.val]
        for (let i = 1; i < 118; i++) {
                break;
            if (wledObj.common.states[i] == tempStringEffect) {
                setState(wledPath + 'seg.0.fx', i)
                break;
    Danke schon mal für die Hilfe!!!
    TT-Tom
    #2541
    @danny_v1
    Muss das Thema mal nach hinten schieben und bei mir erstmal einrichten und nachvollziehen. Vielleicht kann aber schon ein anderer User helfen
    Gruß Tom
    https://github.com/tt-tom17
    NSPanel Script Wiki
    NSPanel Adapter Wiki
    • D danny_v1
      @tt-tom
      Also wenn ich es richtig verstanden habe muss ich einfach bei name: ein getstate einbauen und der Text wird dann dynamisch.
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #2542
      @danny_v1
      ja, aber das getState als String übergeben name: "getState(...)"
      Daher dann auch auf Groß- und Kleinschreibung achten, da im String keine Syntaxprüfung erfolgt.
      • M marc_d0810
        Hey Tom,
        @tt-tom said in SONOFF NSPanel mit Lovelace UI:
        @marc_d0810 sagte in SONOFF NSPanel mit Lovelace UI:
        MQTT im iOBroker läuft und bekommt anscheinend auch die Werte vom Display gesendet.
        Kannst du bitte mal den Inhalt vom MQTT Datenpunkt NSPanel.cmnd.CustomSend zeigen.
        Ja klar:
        Und so sieht es in der Tasmota Console aus:
        Skript läuft auch und es tauchen keine Fehler auf.
        Hast du das Script bzw. die Java Instanz mal neu gestartet ?
        Ja wurde alles schon mehrfach neugestartet. :-(
        TT-Tom
        #2543
        @marc_d0810
        Deine Ausgaben in der Konsole sehen anders aus als bei mir. Vielleicht kann @Armilar nochmal rüber schauen. Dein MQTT sieht eigentlich richtig aus.
        Gruß Tom
        NSPanel Script Wiki
        • ArmilarA Armilar
          @danny_v1
          danny_v1
          #2544
          @armilar
          Ok alles klar, vielen Dank! Werd ich morgen mal testen.
          Hat jemand noch einen Tipp zu dem WLED Problem?
          ArmilarA T 3 Antworten Letzte Antwort
          • T TT-Tom
            @marc_d0810
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #2545
            @tt-tom @marc_d0810
            Sieht soweit okay aus. Hast du da irgendetwas eingestellt, dass das Log so ausführlich ist?
            Hast du mal versucht nachzusehen, ob der Berry-Driver okay ist? Ansonsten da nochmal die Dateien rauswerfen und erneuern.
            • D danny_v1
              @armilar
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #2546
              @danny_v1
              Müsste erstmal sehen, wo das Problem ist. Hatte gelesen, dass im Panel alles okay ist. Werden irgendwelche Fehler im Log ausgelöst, wenn du etwas auswählst?
              • GarganoG Offline
                GarganoG Offline
                Gargano
                #2547
                Wenn man außer Zahlen auch Text in der untersten Zeile anzeigen lassen will :
                Die Entity muss dann als Value den Typ "string" haben.
                 mrIcon1ScreensaverEntity:
                            ScreensaverEntity: '0_userdata.0.trashschedule.0.next.type',
                            ScreensaverEntityIconOn: null,,
                            ScreensaverEntityIconOff: null,
                            ScreensaverEntityValue: '0_userdata.0.trashschedule.0.next.type',
                            ScreensaverEntityValueDecimalPlace : 0,
                            ScreensaverEntityValueUnit: null,
                            ScreensaverEntityOnColor: MSRed,
                            ScreensaverEntityOffColor: Yellow
                Allerdings ist der Text auf 10 Zeichen begrenzt. Ich habe bei mir das HMI angepasst, deshalb geht da mehr rein.
                Aber evtl hat ja @joBr99 bald eine Lösung.
                Und bei mir ist nicht so kalt, das ist die Simulation :blush:
                Änderung im Script ( markiert mit //gargano) :
                // gargano new function
                function getMRIconcSreensaverValue (thisMRElement:ScreenSaverMRElement)
                    let payloadString='';
                    if (thisMRElement.ScreensaverEntityValue != null) {
                        if (typeof (getState(thisMRElement.ScreensaverEntityValue).val) == 'string') {
                            payloadString = (getState(thisMRElement.ScreensaverEntityValue).val);
                        } else {
                            payloadString = (getState(thisMRElement.ScreensaverEntityValue).val).toFixed(thisMRElement.ScreensaverEntityValueDecimalPlace);
                            payloadString += thisMRElement.ScreensaverEntityValueUnit;
                    return payloadString;
                function HandleScreensaverStatusIcons() : void {
                    try {
                        let payloadString = '';
                        let hwBtn1Col: any = config.mrIcon1ScreensaverEntity.ScreensaverEntityOffColor;
                        if (config.mrIcon1ScreensaverEntity.ScreensaverEntity != null) {
                            if (typeof (getState(config.mrIcon1ScreensaverEntity.ScreensaverEntity).val) == 'string') {
                                let hwBtn1: string = getState(config.mrIcon1ScreensaverEntity.ScreensaverEntity).val;
                                if (hwBtn1 == 'ON') {
                                    hwBtn1Col = config.mrIcon1ScreensaverEntity.ScreensaverEntityOnColor;
                                if (getState(config.mrIcon1ScreensaverEntity.ScreensaverEntity).val) {
                                    payloadString += Icons.GetIcon(config.mrIcon1ScreensaverEntity.ScreensaverEntityIconOn);
                                } else {
                                    if (config.mrIcon1ScreensaverEntity.ScreensaverEntityIconOff != null) {
                                        payloadString += Icons.GetIcon(config.mrIcon1ScreensaverEntity.ScreensaverEntityIconOff);
                                    } else {
                                // gargano
                                payloadString += getMRIconcSreensaverValue (config.mrIcon1ScreensaverEntity);
                                payloadString += '~' + rgb_dec565(hwBtn1Col) + '~';
                            } else if (typeof (getState(config.mrIcon1ScreensaverEntity.ScreensaverEntity).val) == 'boolean') {
                                let hwBtn1: boolean = getState(config.mrIcon1ScreensaverEntity.ScreensaverEntity).val;
                                if (hwBtn1) {
                                } else {
                                    } else {
                                // gargano
                        } else if (config.mrIcon1ScreensaverEntity.ScreensaverEntity == null && config.mrIcon1ScreensaverEntity.ScreensaverEntityValue != null){
                            if(config.mrIcon1ScreensaverEntity.ScreensaverEntityOnColor != null){
                            if(config.mrIcon1ScreensaverEntity.ScreensaverEntityIconOn != null){
                            // gargano
                        else {
                            hwBtn1Col = Black;
                            payloadString += '~~';
                        let hwBtn2Col: any = config.mrIcon2ScreensaverEntity.ScreensaverEntityOffColor;
                        if (config.mrIcon2ScreensaverEntity.ScreensaverEntity != null) {
                            if (typeof (getState(config.mrIcon2ScreensaverEntity.ScreensaverEntity).val) == 'string') {
                                let hwBtn2: string = getState(config.mrIcon2ScreensaverEntity.ScreensaverEntity).val;
                                if (hwBtn2 == 'ON') {
                                    hwBtn2Col = config.mrIcon2ScreensaverEntity.ScreensaverEntityOnColor;
                                if (getState(config.mrIcon2ScreensaverEntity.ScreensaverEntity).val) {
                                    payloadString += Icons.GetIcon(config.mrIcon2ScreensaverEntity.ScreensaverEntityIconOn);
                                } else {
                                    if (config.mrIcon2ScreensaverEntity.ScreensaverEntityIconOff != null) {
                                        payloadString += Icons.GetIcon(config.mrIcon2ScreensaverEntity.ScreensaverEntityIconOff);
                                    } else {
                                 // gargano
                                payloadString += getMRIconcSreensaverValue (config.mrIcon2ScreensaverEntity);
                                payloadString += '~' + rgb_dec565(hwBtn2Col) + '~';
                            } else if (typeof (getState(config.mrIcon2ScreensaverEntity.ScreensaverEntity).val) == 'boolean') {
                                let hwBtn2: boolean = getState(config.mrIcon2ScreensaverEntity.ScreensaverEntity).val;
                                if (hwBtn2) {
                                } else {
                                    } else {
                                 // gargano
                        } else if (config.mrIcon2ScreensaverEntity.ScreensaverEntity == null && config.mrIcon2ScreensaverEntity.ScreensaverEntityValue != null){
                            if(config.mrIcon2ScreensaverEntity.ScreensaverEntityOnColor != null){
                            if(config.mrIcon2ScreensaverEntity.ScreensaverEntityIconOn != null){
                            // gargano
                        } else {
                            hwBtn2Col = Black;
                        let alternateScreensaverMFRIcon1Size = getState(NSPanel_Path + 'Config.MRIcons.alternateMRIconSize.1').val
                        let alternateScreensaverMFRIcon2Size = getState(NSPanel_Path + 'Config.MRIcons.alternateMRIconSize.2').val
                        //Alternate MRIcon Size
                        if (alternateScreensaverMFRIcon1Size) {
                            payloadString += '1~';
                        } else {
                            payloadString += '~';
                        if (alternateScreensaverMFRIcon2Size) {
                        } else {
                        SendToPanel(<Payload>{ payload: 'statusUpdate~' + payloadString });
                    } catch (err) {
                        console.log('HandleScreensaverStatusIcons: ' + err.message);
                B 1 Antwort Letzte Antwort
                • D danny_v1
                  @armilar
                  TT-Tom
                  #2548
                  @danny_v1
                  so habe es bei mir mal eingestellt. Funktioniert mit den Standards aus dem Wiki.
                  Kontrolliere bitte deine Datenpunkte unter 0_userdata, ob die sich ändern, wenn du die Effekte oder Farbe veränderst.
                  Gleichzeitig kannst du im Log kontrolieren, ob das Script mitarbeitet.
                  Gruß Tom
                  NSPanel Script Wiki
                  • ArmilarA Armilar
                    @tt-tom @marc_d0810
                    marc_d0810
                    schrieb am zuletzt editiert von marc_d0810
                    #2549
                    @armilar said in SONOFF NSPanel mit Lovelace UI:
                    @tt-tom @marc_d0810
                    @tt-tom @marc_d0810
                    Ja ich hatte mal an irgendeiner Stelle das Loglevel hochgesetzt.
                    Hatte Gestern auch nochmal versucht das TFT mit der aktuellsten Version zu flashen, aber da komme ich wieder bei dem alten Fehler an. :-(
                    Something gone wrong....
                    Was ich Gestern noch gesehen habe, waren die Datenpunkte vom TFT.
                    Muss die Version so aussehen?
                    Wie kann ich den den BerryDriver checken?
                    • M marc_d0810
                      @tt-tom @marc_d0810
                      @tt-tom @marc_d0810
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #2550
                      @marc_d0810
                      Den Berry analog der Wiki-Beschreibung. Alle Dateien (autoexec.be, autoexec.bec, ...) rauswerfen (Flammensymbol) und dann nach einem Tasmota-Neustart den Berry-Treiber neu erstellen. Dann erneut Rebooten...
                      Kann auch daran liegen, dass die Version nicht ermittelt werden kann. Ebenso, dass das TFT sich nicht flashen lässt.
                      • ArmilarA Armilar
                        @marc_d0810
                        marc_d0810
                        #2551
                        @armilar Ich habe alles nochmal rausgeworfen und neu gemacht.
                        Aber es sieht schlecht aus :-(
                        Ist das Ding jetzt für die Tonne?
                        • M marc_d0810
                          TT-Tom
                          #2552
                          @marc_d0810
                          Ich würde tasmota komplett nochmal neu aufspielen. Achte dabei das der Speicher auch mit gelöscht wird.
                          Gruß Tom
                          NSPanel Script Wiki
                          • T TT-Tom
                            @marc_d0810
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #2553
                            @tt-tom @marc_d0810
                            https://forum.iobroker.net/post/960535
                            Versuche die FlashNextionAdv's in dem Post bitte alle
                            • T TT-Tom
                              @danny_v1
                              danny_v1
                              #2554
                              @tt-tom
                              Nein da ändert sich nichts. Im Log ist aber auch nichts zu finden.
                              D T 2 Antworten Letzte Antwort
                              • D danny_v1
                                @tt-tom
                                danny_v1
                                #2555
                                Bin gerade dabei mein zweites Panel in Betrieb zu nehmen. Nach dem Starten des Skripts kam folgende Fehlermeldung:
                                script.js.common.NSPanel_Kueche.NSPanelTS_403: schedule(cron=*/null * * * * *): cannot create schedule
                                Dann habe ich das Skript neu gestartet und seither ist nur der Kreisel mit waiting for content zu sehen. Woran könnte das liegen?
                                ArmilarA T 2 Antworten Letzte Antwort
                                • D danny_v1
                                  @tt-tom
                                  TT-Tom
                                  #2556
                                  @danny_v1 hast du das Panel komplett neu geflasht? Sprich als wenn es neu wäre.
                                  Gruß Tom
                                  NSPanel Script Wiki
                                  • D danny_v1
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #2557
                                    @danny_v1
                                    Sieht für mich wie ein Problem mit dem ioBroker aus.
                                    JS-Adapter/JS-Controller/nodeJS/etc.
                                    • D danny_v1
                                      TT-Tom
                                      #2558
                                      @danny_v1 ist für das neue Panel, der CustomSend angelegt worden? Hast du im Script die MQTT Punkte angepasst?
                                      Die Meldung hatte ich beim ersten Start auch.
                                      Dach lief es aber.
                                      Gruß Tom
                                      NSPanel Script Wiki
                                      • ArmilarA Armilar
                                        @tt-tom @marc_d0810
                                        marc_d0810
                                        #2559
                                        Erstmal Danke für deine Geduld ;-)
                                        Habe alles durch, aber da tut sich leider nichts.
                                        Something has gone wrong flashing display firmware [bytes('CFE6')]
                                        Kommt sofort ohne irgendwelche anderen Einträge.
                                        Könnte denn das neu Flashen, wie von @TT-Tom vorgeschlagen, helfen?
                                        • M marc_d0810
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #2560
                                          @marc_d0810
                                          Ich würde erstmal abwarten, ob @joBr99 noch einen Tipp hat. Ist eigentlich mehr ein TFT-Problem... Also Berry und Nextion
                                          32.6k
                                          82.1k
