  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 727.7k Aufrufe 95 Beobachtet
    @malz1902 sollte auch egal sein angegeben ist das es bei 16, 18 und 20 gehen soll. Nur 14 wurde entfernt. Besteht der Fehler weiterhin wenn du auf Version 2.9.2 gehst?
    Malz1902
    #1361
    @ciddi89 bin runter bis Version 2.8.2. immer der gleiche Fehler:
    host.iobroker
    	2023-08-01 09:24:22.173	error	instance system.adapter.device-watcher.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: Node.js v18.17.0
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: }
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.device-watcher/main.js' ]
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:11:20)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.device-watcher/main.js
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: Require stack:
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: Error: Cannot find module 'cron-parser'
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: ^
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: throw err;
    host.iobroker
    	2023-08-01 09:24:22.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
    • M Malz1902
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      Malz1902
      #1362
      Habe in der Javascript Instanz jetzt cron-parser als npm Modul angegeben, dann geht es
      ? 1 Antwort Letzte Antwort
      • M Malz1902
        #1363
        @malz1902 hmm okay... Evtl wurde das Modul von einem anderen Adapter gelöscht oder so? Ist nur komisch, normalerweise sollte er das neu laden wenn der Adapter neu installiert wird.
        • FredFF Online
          FredFF Online
          FredF
          Most Active Forum Testing
          #1364
          @ciddi89 Ich habe nichts gefunden darüber... vielleicht auch falsch gesucht...
          Der ble Adapter hat den Datenpunkt ble.0.info.driverState, überwacht dein Adapter den auch?
          Bei Updates geht der gerne vom Status poweredOn auf unauthorized und empfängt dann keine Daten mehr.
           "_id": "ble.0.info.driverState",
           "type": "state",
           "common": {
             "role": "indicator.state",
             "name": "bluetooth driver state",
             "desc": "The current state of the bluetooth driver",
             "type": "string",
             "read": true,
             "write": false,
             "def": "poweredOff"
           "native": {},
           "from": "system.adapter.ble.0",
           "ts": 1691677391808,
           "acl": {
             "object": 1636,
             "state": 1636,
             "owner": "system.user.admin",
           "user": "system.user.admin"
          • FredFF FredF
             "type": "state",
             "common": {
               "type": "string",
               "read": true,
               "write": false,
               "def": "poweredOff"
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
            #1365
            @fredf ne den überwacht der Adapter nicht. Sollte dann aber nicht besser der Ble Adapter auf ‚Nicht verbunden mit Gerät oder Dienst‘ gehen? Nutze selber Ble nicht mehr in Verbindung mit iobroker daher weiß ich nicht mehr ob der das dann so macht. Ich glaube nicht, wäre aber meiner Meinung sinnvoller.
            FredFF 1 Antwort Letzte Antwort
              FredFF Online
              FredFF Online
              FredF
              #1366
              @ciddi89 ok muss ich mal beobachten. Mache dann ein issue beim ble Adapter auf
              • J Offline
                jerzimeik
                #1367
                ich habe den Adapter über Github installiert und bekomme nach dem Starten des Adapters folgende Fehlermeldung:
                Im Javascript-Adapter habe ich den Eintrag gesetzt:
                Wo könnte noch der Fehler liegen?
                da_WoodyD Merlin123M crunchipC 3 Antworten Letzte Antwort
                • J jerzimeik
                  da_WoodyD Online
                  da_WoodyD Online
                  da_Woody
                  #1368
                  @jerzimeik keine Screenshots von logs.
                  Die gehören kopiert und in codetags eingefügt.
                  gruß vom Woody
                  • J jerzimeik
                    Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    #1369
                    @jerzimeik Die neu 2er Version läuft nur mit js-controller > 5.0. Welchen js-controller hast Du im Einsatz?
                    Beta-Tester
                    • J jerzimeik
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #1370
                      @jerzimeik sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                      ist normalerweise gar nicht nötig
                      nodejs 18.11 ist mittlerweile auch nicht mehr der neuste Stand, da du aus deinem anderen Thread auch Probleme hast, shelly im iot hinzu zu fügen, zeig mal die Ausgabe von iob diag
                      • J Offline
                        jerzimeik
                        schrieb am zuletzt editiert von jerzimeik
                        #1371
                        iob upgrade self
                        bringt komischerweise auch nichts Neues.
                        Die Ausgabe von iob diag :
                                             v.2023-04-16
                        Operatingsystem:        Ubuntu 21.04
                        Kernel:                 5.11.22-4-pve
                        Installation:           lxc
                        Timezone:               Europe/Berlin (CEST, +0200)
                        User-ID:                0
                        X-Server:               false
                        Pending OS-Updates:     0
                        Pending iob updates:    0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.11.0
                                                /usr/bin/node           v18.11.0
                                                /usr/bin/npm            8.19.2
                                                /usr/bin/npx            8.19.2
                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                        MEMORY:
                        Mem:           7.7G        156M        6.4G          0B        1.2G        7.6G
                        Swap:          7.2G        2.0M        7.2G
                        Total:          14G        159M         13G
                        Active iob-Instances:   2
                        Active repo(s): stable
                        ioBroker Core:          js-controller           4.0.24
                                                admin                   6.8.0
                        ioBroker Status:        iobroker is not running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                          system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
                          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects:                57729
                        States:                 43526
                        Size of iob-Database:
                        65M     /opt/iobroker/iobroker-data/objects.jsonl
                        35M     /opt/iobroker/iobroker-data/objects.json.migrated
                        35M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        90M     /opt/iobroker/iobroker-data/states.jsonl
                        5.7M    /opt/iobroker/iobroker-data/states.json.migrated
                        5.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                        • J jerzimeik
                          iob upgrade self
                                               v.2023-04-16
                          Installation:           lxc
                          User-ID:                0
                          X-Server:               false
                                                  /usr/bin/npm            8.19.2
                                                  /usr/bin/npx            8.19.2
                          MEMORY:
                          Total:          14G        159M         13G
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                57729
                          States:                 43526
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #1372
                          Ubuntu 21.04
                          Hat seit Januar 2022 das EOL erreicht.
                          v18.11.0
                          18.17.1 ist aktuell.
                          Da würde ich als erstes mal ansetzen.
                          Lehrling seit 1975 !!!
                          • J Offline
                            jerzimeik
                            #1373
                            Nach
                            sudo apt purge --autoremove nodejs* npm node-*
                            und
                            curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                            sudo apt install nodejs
                            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                            bleibt aber die Version
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            v18.11.0
                            v18.11.0
                            8.19.2
                            8.19.2
                            Vorher habe ich natürlich apt update und apt upgrade gemacht.
                            JLegJ DJMarc75D 2 Antworten Letzte Antwort
                            • J jerzimeik
                              Nach
                              und
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              /usr/bin/npx
                              v18.11.0
                              v18.11.0
                              8.19.2
                              8.19.2
                              JLegJ Offline
                              JLegJ Offline
                              JLeg
                              #1374
                              @jerzimeik ...die Antwort hierauf wird in der Ausgabe deiner o.g. Kommandos stehen...
                              Btw, die "offiziell" der nodejs-V18 zugeordnete npm-Version ist "9.x" - d.h. deine 8.x ist schonmal ziemlich daneben. Siehe auch https://nodejs.org/en/download/releases
                              • J jerzimeik
                                Nach
                                und
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                /usr/bin/npx
                                v18.11.0
                                v18.11.0
                                8.19.2
                                8.19.2
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #1375
                                @jerzimeik mach das nach folgender Anleitung
                                aber bitte nicht in diesem Beitrag weiter kommunizieren - hier gehts um den Adapter ;)
                                • Merlin123M Offline
                                  Merlin123M Offline
                                  Merlin123
                                  schrieb am zuletzt editiert von Merlin123
                                  #1376
                                  Hmmm... Irgendwie mag der Adapter seit 2.x nicht mehr.
                                  Vielleicht steh ich aber auch grad auf dem Schlauch...
                                  Ich habe meine Spülmaschine neu eingetragen. DPs für Verbrauch und Schalten stimmen, in den DPs des Adapters sehe ich die richtige Live comsumption. Das Starten bekommt er auch richtig mit, aber das Beenden nicht.
                                  Die spülmaschine zieht 0W und ist aus, der Adapter zeigt auch 0W an, sagt aber weiterhin "in action".
                                  Was mach ich denn da falsch? Beim alten Adapter lief das.
                                  Edit: nach so 15 Minuten hat der Adapter gemerkt, dass sie fertig ist
                                  Beta-Tester
                                  • Merlin123M Merlin123
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    da_Woody
                                    #1377
                                    @merlin123 sorry, wir quatschen noch im alten fred.
                                    https://forum.iobroker.net/topic/40573/test-adapter-device-reminder-v-1-x/554
                                    der sollte eigentlich geschlossen werden...
                                    gruß vom Woody
                                    Merlin123M 1 Antwort Letzte Antwort
                                    • da_WoodyD da_Woody
                                      Merlin123M Offline
                                      Merlin123M Offline
                                      Merlin123
                                      #1378
                                      @da_woody ok. Poste ich dort nochmal :)
                                      Beta-Tester
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        da_Woody
                                        #1379
                                        @merlin123 oops, hab ich 2 adapter durcheinander gebracht!
                                        gruß vom Woody
                                        • D3ltoroxpD Offline
                                          D3ltoroxpD Offline
                                          D3ltoroxp
                                          #1380
                                          Sagt mal, was genau passiert hier ?
                                          Wenn der Adapter Fehler hat, wird er nach 250 Sekunden deaktiviert und das in meinem Beispiel für 250 Sekunden ?
                                          Folgendes Problem, mein ph803w Adapter, verliert immer wieder die Verbindung, weil wohl das WLAN im Poolhaus immer wieder abbricht. Das geht nur paar Sekunden dann ist der Adapter und die Verbindung zum Gerät wieder da. Aber ständig wird der Adapter deaktiviert. Daher hatte ich das mal mit den extra Einstellungen probiert. Hatte beides auf 120 stehen, aber auch hier wurde der Adapter immer wieder deaktiviert ? Was muss ich denn wo hochsetzten, das die Toleranz und Reaktion darauf, größer wird. Oder der Adapter gar nicht deaktiviert wird, wenn er Gelb ist, also keine Verbindung zum Gerät hat.
