  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
    1.0k
1.6k Beiträge 101 Kommentatoren 759.0k Aufrufe 95 Beobachtet
  • J Offline
    jerzimeik
    schrieb am zuletzt editiert von jerzimeik
    #1371
    iob upgrade self
    bringt komischerweise auch nichts Neues.
    Die Ausgabe von iob diag :
                         v.2023-04-16
    Operatingsystem:        Ubuntu 21.04
    Kernel:                 5.11.22-4-pve
    Installation:           lxc
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.11.0
                            /usr/bin/node           v18.11.0
                            /usr/bin/npm            8.19.2
                            /usr/bin/npx            8.19.2
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           7.7G        156M        6.4G          0B        1.2G        7.6G
    Swap:          7.2G        2.0M        7.2G
    Total:          14G        159M         13G
    Active iob-Instances:   2
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.8.0
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
      system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                57729
    States:                 43526
    Size of iob-Database:
    65M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/objects.json.migrated
    35M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    90M     /opt/iobroker/iobroker-data/states.jsonl
    5.7M    /opt/iobroker/iobroker-data/states.json.migrated
    5.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    • J jerzimeik
      iob upgrade self
                           v.2023-04-16
      Installation:           lxc
      User-ID:                0
      X-Server:               false
                              /usr/bin/npm            8.19.2
                              /usr/bin/npx            8.19.2
      MEMORY:
      Total:          14G        159M         13G
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                57729
      States:                 43526
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #1372
      @jerzimeik sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
      Ubuntu 21.04
      Hat seit Januar 2022 das EOL erreicht.
      v18.11.0
      18.17.1 ist aktuell.
      Da würde ich als erstes mal ansetzen.
      Lehrling seit 1975 !!!
      • J Offline
        jerzimeik
        #1373
        Nach
        sudo apt purge --autoremove nodejs* npm node-*
        und
        curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
        sudo apt install nodejs
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        bleibt aber die Version
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v18.11.0
        v18.11.0
        8.19.2
        8.19.2
        Vorher habe ich natürlich apt update und apt upgrade gemacht.
        JLegJ DJMarc75D 2 Antworten Letzte Antwort
        • J jerzimeik
          Nach
          und
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v18.11.0
          v18.11.0
          8.19.2
          8.19.2
          JLegJ Offline
          JLegJ Offline
          JLeg
          #1374
          @jerzimeik ...die Antwort hierauf wird in der Ausgabe deiner o.g. Kommandos stehen...
          Btw, die "offiziell" der nodejs-V18 zugeordnete npm-Version ist "9.x" - d.h. deine 8.x ist schonmal ziemlich daneben. Siehe auch https://nodejs.org/en/download/releases
          • J jerzimeik
            Nach
            und
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            v18.11.0
            v18.11.0
            8.19.2
            8.19.2
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            #1375
            @jerzimeik mach das nach folgender Anleitung
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            aber bitte nicht in diesem Beitrag weiter kommunizieren - hier gehts um den Adapter ;)
            • Merlin123M Offline
              Merlin123M Offline
              Merlin123
              schrieb am zuletzt editiert von Merlin123
              #1376
              Hmmm... Irgendwie mag der Adapter seit 2.x nicht mehr.
              Vielleicht steh ich aber auch grad auf dem Schlauch...
              Ich habe meine Spülmaschine neu eingetragen. DPs für Verbrauch und Schalten stimmen, in den DPs des Adapters sehe ich die richtige Live comsumption. Das Starten bekommt er auch richtig mit, aber das Beenden nicht.
              Die spülmaschine zieht 0W und ist aus, der Adapter zeigt auch 0W an, sagt aber weiterhin "in action".
              Was mach ich denn da falsch? Beim alten Adapter lief das.
              Edit: nach so 15 Minuten hat der Adapter gemerkt, dass sie fertig ist
              Beta-Tester
              • Merlin123M Merlin123
                da_WoodyD Online
                da_WoodyD Online
                #1377
                @merlin123 sorry, wir quatschen noch im alten fred.
                https://forum.iobroker.net/topic/40573/test-adapter-device-reminder-v-1-x/554
                der sollte eigentlich geschlossen werden...
                Merlin123M 1 Antwort Letzte Antwort
                • da_WoodyD da_Woody
                  Merlin123M Offline
                  Merlin123M Offline
                  Merlin123
                  #1378
                  @da_woody ok. Poste ich dort nochmal :)
                  Beta-Tester
                    da_WoodyD Online
                    da_WoodyD Online
                    #1379
                    @merlin123 oops, hab ich 2 adapter durcheinander gebracht!
                    • D3ltoroxpD Offline
                      D3ltoroxpD Offline
                      D3ltoroxp
                      #1380
                      Sagt mal, was genau passiert hier ?
                      Wenn der Adapter Fehler hat, wird er nach 250 Sekunden deaktiviert und das in meinem Beispiel für 250 Sekunden ?
                      Folgendes Problem, mein ph803w Adapter, verliert immer wieder die Verbindung, weil wohl das WLAN im Poolhaus immer wieder abbricht. Das geht nur paar Sekunden dann ist der Adapter und die Verbindung zum Gerät wieder da. Aber ständig wird der Adapter deaktiviert. Daher hatte ich das mal mit den extra Einstellungen probiert. Hatte beides auf 120 stehen, aber auch hier wurde der Adapter immer wieder deaktiviert ? Was muss ich denn wo hochsetzten, das die Toleranz und Reaktion darauf, größer wird. Oder der Adapter gar nicht deaktiviert wird, wenn er Gelb ist, also keine Verbindung zum Gerät hat.
                      • D3ltoroxpD D3ltoroxp
                        #1381
                        @d3ltoroxp werde das mal bei Gelegenheit testen und gucken ob ich ein Fehler finde. Eigentlich sollte es so sein: wenn da eingegeben worden ist 120 Sekunden dann wird die Zeit durch zwei geteilt. Er wartet 60 Sekunden guckt ob das Gerät wieder erreichbar ist, wenn nicht wartet er nochmal 60 Sekunden und prüft es nochmal. Wenn es dann immer noch nicht online ist, wird das Gerät als offline eingestuft.
                        D3ltoroxpD 1 Antwort Letzte Antwort
                          D3ltoroxpD Offline
                          D3ltoroxpD Offline
                          D3ltoroxp
                          schrieb am zuletzt editiert von D3ltoroxp
                          #1382
                          @ciddi89 Das ist die Fehlerzeit , oder Deaktivierungszeit ? Und wenn die 120 Sekunden überschritten sind, wird der Adapter deaktiviert, für wie lange ?
                          Das bekomme ich ständig in Telegram.
                          Wenn ich das hier eintrage, bekomme ich dann nur keine Nachricht, oder wird er dann auch nicht mehr durch deinen Adapter deaktiviert ?
                            #1383
                            @d3ltoroxp ist in beiden fällen so. Und Zeit ist halt je nachdem was du angegeben hast sonst Standart war glaub ich 20 sek. Hab das nun nicht so im Kopf. Der Adapter deaktiviert aber nichts. Er reagiert nur auf state changes von den Datenpunkt connected und alive.
                            • mango1402M Offline
                              mango1402M Offline
                              mango1402
                              #1384
                              Hallo @ciddi89
                              Tolle Arbeit - Danke für den wirklich sinnvoll nutzbaren Adapter!
                              Ich hätte da noch eine Idee zu generisch brauchbaren Überwachungen:
                              Wie wärs, wenn man aus der 'Alias' Objektstruktur fix definierte Datenpunkte (also deren Namen und Zustände von Device-Watcher vorgegeben sind) überwachen könnte? Dann hätte man die Möglichkeit auch auf unbekannte Geräten bzw. Adaptern bzw. auf selbst gebaute Funktionen den Watcher drüberlaufen zu lassen.
                              z.B.: man baut sich ein Script, das irgendwas von einem IoT-Gerät was ausliest. Da kann man natürlich auch selbst eine onine-Überwachung einbauen, aber wenn man dann diesen Datenpunk als einen für DeviceWatcher nekannten Namen in die Alias-Struktur mappt könnte dessen Überwachung einheitlich zu allen anderen Geräten ausschauen.
                              Beschreibung klingt kompliziert, ich hoffe Du weißt was ich meine..... ;)
                              lg Manfred
                              • mango1402M mango1402
                                Hallo @ciddi89
                                lg Manfred
                                #1385
                                @mango1402 danke für dein Feedback und deine Idee. Klingt einfach zu intregieren. Ich habe dafür ein Issue bei Github aufgemacht damit ich das nicht vergesse. Habe inmoment leider viele andere Dinge um die Ohren, werde aber mal schauen das ich in absehbarer Zukunft mal alle Feature requests und Bugs abarbeite.
                                https://github.com/ciddi89/ioBroker.device-watcher/issues/230
                                  D3ltoroxpD Offline
                                  D3ltoroxpD Offline
                                  D3ltoroxp
                                  #1386
                                  @ciddi89 said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                                  Deaktiviert sich die Instanz dann jedes mal selber ?
                                    D3ltoroxpD Offline
                                    D3ltoroxp
                                    #1387
                                    Mal eine Frage, wäre das viel Aufwand, wenn man von mir aus einen neuen Unterordner macht im Adapter Ordner und dort dann von jedem Geräte ein DP anlegt, ob da oder nicht da. Somit könnte man sich das ein wenig mit in die VIS einbauen. Wenn dann ein Gerät nicht da ist, könnte man das bei Sichtbarkeit mit anwählen den DP und somit sieht man dann, wenn ein Wert nicht da ist, weil Gerät Offline.
                                    • ? Offline
                                      #1388
                                      Ich habe eine Frage zu der Batteriestand niedrig Benachrichtigung.
                                      Ich habe ein Zigbee Rauchmelder der nur den Status Batterie high and low kennt und den auch weitergibt, jedoch keinen Akkustand in %
                                      Somit erhalte ich immer eine Benachrichtigung in der Tabelle der Batteriestände.:
                                      Und eine Nachricht über den niedrigen Batteriestand:
                                      Leider lässt sich der Batteriestand für dieses Gerät nicht im Adapter ignorieren oder so einstellen das er den High oder low Wert nimmt oder sehe ich das falsch? Hat jemand eine Idee dazu?
                                      Mfg David
                                        Aktuelle Test Version NPM version
                                        Veröffentlichungsdatum 26.05.2022
                                        Github Link https://github.com/ciddi89/ioBroker.device-watcher
                                        🇩🇪 Deutsche Dokumentation
                                        Dies ist ein Watchdog für Geräte/Services und Adapter/Instanzen. Der Adapter sucht nach den verschiedenen Informationen über die Datenpunkte und erstellt JSON & HTML Listen davon:
                                        Geräte/Services:
                                        • Geräte mit Batterie,
                                        • Geräte mit niedrigem Batteriestand,
                                        • Geräte mit Verbindungsqualität,
                                        • Updates für Geräte, (only shelly & unifi yet)
                                        • Geräte offline
                                        • alle Geräte
                                        • und eine Raw-Liste mit allen verfügbaren Daten der oben genannten Liste.
                                        Adapter/Instanzen:
                                        • verfügbare Adapter Updates
                                        • Alle Instanzen
                                        • Ausgefallene Instanzen
                                        • Deaktivierte Instanzen
                                        Außerdem werden sie in denselben Kategorien gezählt. Die Listen und Zählungen können zum Beispiel für Grafana, Jarvis usw. verwendet werden.
                                        Unterstützte Adapter:
                                        Eine Liste mit den unterstützten Adaptern und welche Information pro Adapter genutzt werden / möglich sind, findest du in der Github Doku.
                                        Benachrichtigungen:
                                        Der Adapter hat verschiedene Möglichkeiten, Benachrichtigungen zu senden:
                                        • Ein Gerät ist nicht mehr erreichbar oder wieder erreichbar
                                        • Ein Gerät hat den niedrigen Batteriestand erreicht oder der Low-Bat-Status ist true
                                        • Wenn ein Update für ein Gerät verfügbar ist (shelly und unifi)
                                        • Zeitbasiert eine Liste der Offline-Geräte
                                        • Zeitbasierte Liste von Geräten mit niedrigem Batteriestand
                                        • Zeitbasiert eine Liste der Geräte, die aktualisiert werden können
                                        Derzeitige Unterstützte Adapter für Benachrichtigungen:
                                        • Telegram
                                        • Pushover
                                        • WhatsApp
                                        • Email
                                        • Jarvis
                                        • Lovelace
                                        • Signal
                                        • SynoChat
                                        • und einen Datenpunkt mit der zuletzt gesendeten Benachrichtigung.
                                        Blacklist
                                        Ist es notwendig, ein bestimmtes Gerät/Service oder Instanz zu ignorieren, kann es auf die schwarze Liste gesetzt werden und der Device-Watcher ignoriert es.
                                        Es ist möglich zu wählen:
                                        • In Benachrichtigungen ignorieren
                                        • In der Hauptliste ignorieren
                                        • In den eigenen Listen der Adapter ignorieren
                                        Feature Request & Bug Report
                                        Ich bitte euch der Übersicht halber Fehler und Feature Request auf der Githubseite zu erstellen.
                                        Seht Ihr dort ein Feature Request und euch gefällt die Idee, könnt Ihr auch dafür abstimmen. Dann sehe ich bei einigen Dingen, wo ich mir nicht sicher bin ob es Sinnvoll wäre oder nicht, ob überhaupt Interesse an sowas besteht.
                                        Wählt dafür einfach einen von den Emojis aus:
                                        Screenshots und weitere Informationen finder Ihr auf der Githubseite.
                                        #1389
                                        @ciddi89
                                        2 Anliegen habe ich.. :-)
                                        1. mir ist aufgefallen, dass bei mir device-watcher, wenn ein Device wieder bei Sonoff-Adapter erreichbar ist, die Msg 6-7 mal gesendet wird, ist auch so im Logfile:
                                        2023-11-03 05:42:41.587  - info: sonoff.0 (403) Client [Gosund11] connected with secret 1698986561586_5541
                                        2023-11-03 05:42:41.906  - info: device-watcher.0 (654) Folgendes Gerät ist wieder erreichbar:
                                        Sonoff: Gosund11 (2 Stunden)
                                        2023-11-03 05:42:41.908  - info: device-watcher.0 (654) Folgendes Gerät ist wieder erreichbar:
                                        2023-11-03 05:42:41.909  - info: device-watcher.0 (654) Folgendes Gerät ist wieder erreichbar:
                                        2023-11-03 05:42:41.910  - info: device-watcher.0 (654) Folgendes Gerät ist wieder erreichbar:
                                        2023-11-03 05:42:43.326  - info: sonoff.0 (403) Client [POW-3D-Drucker] connected with secret 1698986563326_2460
                                        2023-11-03 05:42:44.228  - info: device-watcher.0 (654) Folgendes Gerät ist wieder erreichbar:
                                        Sonoff: POW-3D-Drucker (2 Stunden)
                                        2023-11-03 05:42:44.229  - info: device-watcher.0 (654) Folgendes Gerät ist wieder erreichbar:
                                        2023-11-03 05:42:44.230  - info: device-watcher.0 (654) Folgendes Gerät ist wieder erreichbar:
                                        daher habe ich hier die Benachrichtigung deaktiviert.
                                        1. der Fullbrowser-Adapter ist in V3.x mit Aenderungen im Beta verfuegbar und funktioniert schon sehr gut und stabil.
                                          Hier wurde der nicht mehr weiterentwickelte Fully-Mqtt-Adapter mit integriert, und daher auch die Struktur etwas geaendert, hier muesste man im Device-Watcher dann noch eine Option fuer Fullybrowser >3.x hinzufuegen.
                                          Die Datenstruktur sieht z.bsp. dann so aus(die IP wurde durch den Namen ersetzt), ich denke, du triggerst auf Alive und Enabled:
                                          @ciddi89
                                          #1390
                                          @ilovegym ja ist das gleiche wie https://github.com/ciddi89/ioBroker.device-watcher/issues/244
                                          Ehrlich gesagt weiss ich da aber derzeit nicht weiter. Es ist nur bei Sonoff so. Und eigentlich besteht garnicht die Möglichkeit das es passieren kann weil der Datenpunkt für Erreichbarkeit erst wieder auf false sein muss damit er überhaupt reagiert. Beim Testen bekomme ich es auch nicht hin das er mir mehrere Nachrichten schickt das das Gerät wieder erreichbar ist.
                                          Fully nehme ich dann v3 mit auf.
                                          // Edit: Welche Datenpunkte gibt es noch im Ordner Info bei fully?
