  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 756.5k Aufrufe 95 Beobachtet
  • M Markus_
    Hallo ciddi89
    Danke für den Adapter. Aber ich habe ein Problem.
    Ich bekommen nur Nachrichten bei Offline Geräten. Aber nicht wenn Batteriestand zu gering.
    Habe die stabel + github Version getestet.
    Der Datenpunkt lowBatteryCount = 11 --> es sollte also was zum senden geben.
    Ich habe den Adapter gerade mit debug log laufen und bekommen die ganze zeit folgende Meldungen:
    device-watcher.0
    2022-11-22 16:52:40.033	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:39.655	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:39.567	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:39.562	debug	Function finished: resetVars
    device-watcher.0
    2022-11-22 16:52:39.562	debug	Function started: resetVars
    device-watcher.0
    2022-11-22 16:52:39.562	debug	Function started: createDataOfAllAdapter
    device-watcher.0
    2022-11-22 16:52:39.561	debug	Function started: main
    device-watcher.0
    2022-11-22 16:52:39.561	debug	Updating Data
    device-watcher.0
    2022-11-22 16:52:29.560	debug	Function finished: main
    device-watcher.0
    2022-11-22 16:52:29.560	debug	Created and filled data for all adapters
    device-watcher.0
    2022-11-22 16:52:29.560	debug	Function finished: createDataOfAllAdapter
    device-watcher.0
    2022-11-22 16:52:29.559	debug	Function finished: writeDatapoints
    device-watcher.0
    2022-11-22 16:52:29.444	debug	Start the function: writeDatapoints
    device-watcher.0
    2022-11-22 16:52:29.443	debug	Finished the function: sendOfflineNotifications
    device-watcher.0
    2022-11-22 16:52:29.443	debug	Start the function: sendOfflineNotifications
    device-watcher.0
    2022-11-22 16:52:29.182	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:28.795	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:28.671	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:28.654	debug	Function finished: resetVars
    device-watcher.0
    2022-11-22 16:52:28.654	debug	Function started: resetVars
    device-watcher.0
    2022-11-22 16:52:28.653	debug	Function started: createDataOfAllAdapter
    device-watcher.0
    2022-11-22 16:52:28.653	debug	Function started: main
    device-watcher.0
    2022-11-22 16:52:28.652	debug	Updating Data
    device-watcher.0
    2022-11-22 16:52:18.651	debug	Function finished: main
    device-watcher.0
    2022-11-22 16:52:18.651	debug	Created and filled data for all adapters
    device-watcher.0
    2022-11-22 16:52:18.650	debug	Function finished: createDataOfAllAdapter
    device-watcher.0
    2022-11-22 16:52:18.650	debug	Function finished: writeDatapoints
    device-watcher.0
    2022-11-22 16:52:18.540	debug	Start the function: writeDatapoints
    device-watcher.0
    2022-11-22 16:52:18.540	debug	Finished the function: sendOfflineNotifications
    device-watcher.0
    2022-11-22 16:52:18.539	debug	Start the function: sendOfflineNotifications
    device-watcher.0
    2022-11-22 16:52:18.291	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:17.693	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-22 16:52:17.599	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    Brauchst du weitere Infos?
    DANKE schon mal für deine Hilfe.
    #721
    @markus_ hi danke für die Meldung. Bitte mal noch mal GitHub Version testen. sollte gefixt sein.
      Markus_
      #722
      @ciddi89
      DANKE für den schnellen fix.
      Ich bekomme jetzt eine Benachrichtigung erhalten.👍
      Darin fehlt allerdings mein Shelly Button
      https://www.shelly.cloud/knowledge-base/devices/shelly-button-1/
      hast du diesen schon implementiert ?
      Das wäre der Datenpunkt der den Batterie Status anzeigt
        "type": "state",
        "common": {
          "name": "value",
          "type": "number",
          "role": "value.battery",
          "read": true,
          "write": false,
          "min": 0,
          "max": 100,
          "unit": "%"
        "native": {},
        "from": "system.adapter.shelly.0",
        "user": "system.user.admin",
        "ts": 1669128127316,
        "_id": "shelly.0.SHBTN-1#48551902D56E#1.bat.value",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      ? 1 Antwort Letzte Antwort
      • M Markus_
        @ciddi89
          "type": "state",
          "common": {
            "name": "value",
            "type": "number",
            "read": true,
            "write": false,
            "min": 0,
            "max": 100,
            "unit": "%"
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
        #723
        @markus_ okay test again. Sollte nun mit drin sein. :)
          Markus_
          schrieb am zuletzt editiert von Markus_
          #724
          @ciddi89
          Der shelly button wird jetzt angezeigt. DANKE
          nächstes Problem: Homematic-IP HmIP-KRC4.
          https://homematic-ip.com/de/produkt/schluesselbundfernbedienung-4-tasten/downloads
          https://de.elv.com/elv-homematic-ip-arr-bausatz-schluesselbundfernbedienung-mit-4-tasten-hmip-krc4-fuer-smart-home-und-hausautomation-152606
          Das ist der Datenpunkt der Batteriespannung.
            "type": "state",
            "common": {
              "name": "XXXXX:0.OPERATING_VOLTAGE",
              "role": "value.voltage",
              "def": 0,
              "type": "number",
              "read": true,
              "write": false,
              "min": 0,
              "max": 25.2,
              "unit": "V"
            "native": {
              "MIN": 0,
              "OPERATIONS": 5,
              "MAX": 25.2,
              "FLAGS": 1,
              "ID": "OPERATING_VOLTAGE",
              "TYPE": "FLOAT",
              "DEFAULT": 0
            "from": "system.adapter.hm-rega.0",
            "ts": 1667845499723,
            "_id": "hm-rpc.2.0002DD8991XXX.0.OPERATING_VOLTAGE",
            "acl": {
              "object": 1636,
              "state": 1636,
          Anscheinend ist der max Wert des Datenpunkts falsch. Aber wer hat hier dann den Fehler gemacht? Der Programmierer des HM-RPC Adapter? Oder liegt er bei der Datenquelle also Homematic?
          • M Markus_
            @ciddi89
              "type": "state",
              "common": {
                "def": 0,
                "type": "number",
                "read": true,
                "write": false,
                "min": 0,
                "max": 25.2,
                "unit": "V"
              "native": {
                "MIN": 0,
                "OPERATIONS": 5,
                "MAX": 25.2,
                "FLAGS": 1,
                "TYPE": "FLOAT",
                "DEFAULT": 0
              "acl": {
                "object": 1636,
                "state": 1636,
            #725
            @markus_ was ist denn der wert der geliefert wird? Ist auf jeden Fall hm-rpc Fehler und dafür musst du dann ein issue anlegen auf GitHub. Den kannst du aber händisch selbst ändern. Wird aber wohl möglich bei Updates überschrieben. Es gibt aber mehrere Geräte wo der Max wert von verschiedenen Geräten/Datenpunkte nicht stimmen. Hab auch so ein Gerät, weiß garnicht mehr was das für ein Datenpunkt es war aber im Log kam dann auch immer die Meldung „32 is greater than the max value 8“ oder so ähnlich. Aber seitdem ich es selbst angepasst habe ist Ruhe.
              Markus_
              #726
              @ciddi89
              Danke für die Info.
              Es wird hier die Spannung in Volt angezeigt.
              Ich habe ein Issue auf Github aufgemacht
              Nächstes Problem:
              Ich habe die Einstellung "Nur Geräte mit Batterien auflisten" aktiv und mir werden viele Homemmatic IP Wired Geräte angezeigt. Woher weißt du ob ein Gerät eine Batterie hat? Bei mir werden sie aufgelistet obwohl sie immer mit Netzteil versorgt werden.
              z.B. https://homematic-ip.com/de/produkt/wired-access-point
              ? 2 Antworten Letzte Antwort
              • M Markus_
                @ciddi89
                Danke für die Info.
                Nächstes Problem:
                #727
                @markus_ ah okay danke für die Info. Ja der Adapter guckt nach operating_voltage oder low bat Datenpunkte. Homematic Wired hatte ich noch nicht aufn Schirm somit bist du mir eine große Hilfe :) werde heute Abend aber n Filter einbauen der die Geräte raus nimmt. Melde mich dann noch mal :)
                • M Markus_
                  @ciddi89
                  Danke für die Info.
                  Nächstes Problem:
                  #728
                  @markus_ Geräte mit einer höheren Spannung werden nun nicht mehr als Batterie Geräte angezeigt. Kannst du ja noch einmal testen. :)
                  B 1 Antwort Letzte Antwort
                    Markus_
                    #729
                    @ciddi89
                    Die Homematic Ip Wired Geräte werden jetzt nicht mehr aufgelistet.
                    SUPER DANKE 🤘
                    Ich habe jetzt bei den Batterie betriebenen Geräten versucht den Max Wert manuell anzupassen. Das hat leider nichts gebracht. Bei den Geräten erhalte ich keine "low battery" Meldung.
                      "type": "state",
                      "common": {
                        "name": "XXX:0.OPERATING_VOLTAGE",
                        "def": 0,
                        "type": "number",
                        "read": true,
                        "write": false,
                        "min": 0,
                        "max": 1.5,
                        "unit": "V"
                      "native": {
                        "MIN": 0,
                        "OPERATIONS": 5,
                        "MAX": 1.5,
                        "FLAGS": 1,
                        "TYPE": "FLOAT",
                        "DEFAULT": 0
                      "_id": "XXX.0.OPERATING_VOLTAGE",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "ts": 1669238162413
                    • M Markus_
                      @ciddi89
                      SUPER DANKE 🤘
                        "type": "state",
                        "common": {
                          "def": 0,
                          "type": "number",
                          "read": true,
                          "write": false,
                          "min": 0,
                          "max": 1.5,
                          "unit": "V"
                        "native": {
                          "MIN": 0,
                          "OPERATIONS": 5,
                          "MAX": 1.5,
                          "FLAGS": 1,
                          "TYPE": "FLOAT",
                          "DEFAULT": 0
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                        "ts": 1669238162413
                      #730
                      @markus_ verstehe ich nun nicht. Der Max wert definiert den maximalen Wert vom Datenpunkt. Das hat nichts damit zu tun wann er als low bat device gelten soll. Dafür haben die einen Datenpunkt namens lowbat/low_bat dieser wird aber vom Gerät bestimmt wann dieser auf true springen soll.
                        Markus_
                        #731
                        @ciddi89
                        Ich glaube ich habe die Funktion deines Adapters falsch interpretiert.
                        Bei Homematic Geräten greift die Einstellung "Ab wie viel min % würden Sie eine Nachricht bekommen" im Adapter nicht. Hier wird nur der "low_bat" Datenpunkt ausgewertet.
                        Ich habe um die Funktion des Adapters zu testen "Ab wie viel min % würden Sie eine Nachricht bekommen" auf 99 gestellt und habe mich gewundert warum ich keine Benachrichtigungen bekomme....
                        • M Markus_
                          @ciddi89
                          #732
                          @markus_ genau, bei Geräten mit low bat Datenpunkt, wird dieser als Indikator genutzt.
                          • ? Offline
                            #733
                            @ciddi89
                            Hi, vielen Dank erstmal fuer den tollen Adapter!
                            Ich haette da vielleicht n feature-request, vielleicht kanns der ein oder andere auch gebrauchen und du findest es auch sinnvoll:
                            Zusaetzlicher Datenpunkt
                            "lostdevices, type number" - differenz der Anzahl Devices insgesamt vom letzten und aktuellen Scan, wenn Anzahl niedriger als vorher
                            "lostdeviceslist" - json oder html liste der verlorenen Devices
                            Mein Problem:
                            Der Zigbee-Adapter verliert bei mir ab und zu mal ein Device, das ist dann einfach weg, als waere es nie da gewesen...
                            Da ist es auch egal, ob Batterie oder Netzgeraet.. von daher waere es eine sinnvolle Erweiterung :) ???
                              @ciddi89
                              Mein Problem:
                              #734
                              @ilovegym die Frage ist: warum verliert dein System einfach ein Gerät? Ich denke man sollte mal der Sache auf die Spur gehen. Das ist nicht normal gerade bei Zigbee sehr untypisch :)
                              Zu deiner Idee: ganz am Anfang hatte ich schon mal mit den Gedanken gespielt eine Liste/Anzahl zu erstellen mit Geräten die Fehler usw. aufweisen. So wie bei Homematic als Beispiel „Kommunikation gestört“ usw. Da könnte man evtl. sowas mit reinpacken. Hab mich aber noch nicht weiter damit befasst da ich noch aktuell andere Dinge umsetzen muss und ich garnicht weiß ob es überhaupt sinnvoll ist, da nicht alle Geräte/Adapter solche Datenpunkte liefern um sowas zu überwachen.
                                #735
                                @ciddi89 ...wenn ich das wuesste! Angeblich passiert das ja nicht.. bei 220 Zigbee Devices ist die Uebersicht halt auch schwer..
                                und das echt doofe ist ja, dass dann ein Device mitsamt der Datenstruktur weg ist, als waere es nie da gewesen..
                                Merke das nur, wenn auf einmal was nicht mehr funktioniert oder ein Script meckert, weil der Datenpunkt weg ist.. oder nicht laeuft, weil der Trigger nicht mehr geht..
                                Ok, dann schreib ich mir was zusammen, muss ja nur die Max-Anzahl festlegen und auf Aenderung triggern, wie es weniger wird, dann muss eins fehlen.. und dann die Device-List vergleichen..
                                  #736
                                  @ilovegym hmm ist wirklich komisch.
                                  Ja mit blocky oder JavaScript ist da ja schnell was kleines zusammen gebastelt.
                                    Rushmed
                                    #737
                                    Hallo, danke für den tollen adapter und die Doku.
                                    Kann ich irgendwo den Pegel für geringe Batterie definieren.
                                    Ich hab in meiner Liste Geräte mit über 30%, das interessiert mich noch lange nicht.
                                    • R Rushmed
                                      #738
                                      @rushmed hey erstmal danke. Ja das kannst du definieren der ist versteckt unter Benachrichtigung wenn du den Haken bei Batteriemeldungen setzt. Ich glaube aber der Menüpunkt ist dort falsch untergebracht weil er für die Listen und den Nachrichten gilt. Mal schauen ob ich den woanders unterbringen kann.
                                      • W Offline
                                        W Offline
                                        watcherkb
                                        #739
                                        Hi, gibt es auch die Möglichkeit bei Telegram Benachrichtigung einen bestimmten User anzugeben? Meine zweite Hälfte muss und möchte nicht alles wissen was im Smarthome gerade offline ist.
                                        CC2538+CC2592 PA-Zigbee-Funkmodul
                                        • W watcherkb
                                          D Online
                                          D Online
                                          DennisMenger
                                          #740
                                          @watcherkb Ja, das geht. Man kann unten im Adapter bei den Telegram-Benachrichtigungen eine Geräte-ID oder Chat-ID eintragen
                                          W 1 Antwort Letzte Antwort
