  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 756.5k Aufrufe 95 Beobachtet
  • Axel KoenekeA Axel Koeneke
    @ciddi89 Moin, sorry habe die Version 2.0.2
    Leider bin ich im Github nicht so bewandert...
    Folgendes habe ich probiert und festgestellt:
    Alle anderen Abfragen funktionieren fehlerfrei, außer HM-RPC. Habe jetzt LOG auf DEBUG gestellt:
    device-watcher.0
    2022-11-19 09:51:25.841	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
    device-watcher.0
    2022-11-19 09:51:25.788	debug	Start the function: writeDatapoints
    device-watcher.0
    2022-11-19 09:51:25.323	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-19 09:51:25.259	debug	Function finished: resetVars
    device-watcher.0
    2022-11-19 09:51:25.259	debug	Function started: resetVars
    device-watcher.0
    2022-11-19 09:51:25.258	debug	Function started: createDataOfAllAdapter
    device-watcher.0
    2022-11-19 09:51:25.258	debug	Created and filled data for Hmrpc
    device-watcher.0
    2022-11-19 09:51:25.257	debug	Function finished: createDataForEachAdapter
    device-watcher.0
    2022-11-19 09:51:25.257	debug	Function finished: writeDatapoints
    device-watcher.0
    2022-11-19 09:51:25.223	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
    device-watcher.0
    2022-11-19 09:51:25.033	debug	Start the function: writeDatapoints
    device-watcher.0
    2022-11-19 09:51:24.578	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    device-watcher.0
    2022-11-19 09:51:24.569	debug	Function finished: resetVars
    device-watcher.0
    2022-11-19 09:51:24.569	debug	Function started: resetVars
    device-watcher.0
    2022-11-19 09:51:24.568	debug	Function started: createDataForEachAdapter
    device-watcher.0
    2022-11-19 09:51:24.567	debug	Function started: main
    device-watcher.0
    2022-11-19 09:51:24.560	debug	Created datapoints for Hmrpc
    device-watcher.0
    2022-11-19 09:51:24.479	debug	Function finished: createBlacklist
    device-watcher.0
    2022-11-19 09:51:24.478	debug	Function started: createBlacklist
    device-watcher.0
    2022-11-19 09:51:24.476	info	Number of selected adapters: 1. Loading data from: Hmrpc ...
    device-watcher.0
    2022-11-19 09:51:24.475	debug	[{"Selektor":"hm-rpc.*.UNREACH","adapterID":"hmrpc","adapter":"Homematic RPC","rssiState":".RSSI_DEVICE","rssiPeerState":".RSSI_PEER","battery":".OPERATING_VOLTAGE","reach":".UNREACH","isLowBat":".LOW_BAT","isLowBat2":".LOWBAT","stateValue":".1.STATE"}]
    device-watcher.0
    2022-11-19 09:51:24.471	debug	Adapter device-watcher was started
    device-watcher.0
    2022-11-19 09:51:24.430	info	starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v16.15.1, js-controller: 4.0.23
    device-watcher.0
    2022-11-19 09:51:23.671	debug	Plugin sentry Initialize Plugin (enabled=true)
    Zeile 63 sieht für mich interessant aus:
    "Selektor":"hm-rpc.*.UNREACH"........
    Datenpunkt:
    hm-rpc.2.000E9A498DFC2D.0.UNREACH
    Kann es sein das hier zwei Platzhalter fehlen?
    Also wenn der erste für die Instanz ist, dann müssten doch noch die Geräte ID und dann der Kanal kommen. und anschließend die Abfrage (UNREACH).
    Axel
    #711
    @axel-koeneke ok ich denke ich habe den Fehler gefunden und habe ein Fix eingebaut. Kannst du dann bitte mal die GitHub Version testen? Aber ich denke du wirst Irgendwo im HM-RPC Adapter ein Gerät haben wo er den Namen nicht korrekt ausgibt oder eine Datenleiche versteckt ist. Vielleicht kannst du mal schauen ob da irgendwo was auffälliges zu sehen ist.
      da_WoodyD Online
      da_WoodyD Online
      #712
      @ciddi89 sagte in Test Adapter Device-Watcher v1.x.x GitHub/Latest:
      möglicherweise sonderzeichen, oder sowas?
      • da_WoodyD da_Woody
        #713
        @da_woody Sonderzeichen kann natürlich auch sein. Wollte mal ein Filter dafür einbauen, denke mittlerweile wird es Zeit dafür 🫣 ich vergesse immer das nicht alle wissen das es nicht gesund ist bestimmte Zeichensätze in Namen zu setzen 🙇
        da_WoodyD Axel KoenekeA ScroungerS 3 Antworten Letzte Antwort
          da_WoodyD Online
          da_WoodyD Online
          #714
            Axel KoenekeA Offline
            Axel Koeneke
            #715
            @ciddi89 Huhu, was auch immer du gemacht hast, es hat funtioniert ! :)
            Super !!!
            Axel
              ScroungerS Offline
              ScroungerS Offline
              Scrounger
              #716
              @ciddi89
              Super adapter, bin ich gestern per zufall drüber gestolpert und echt begeistert, spart so viel zeit 👍
              Könntest du vlt. etwas implemnetieren das man z.b. auch eigene Geräte / Strukturen verwenden kann. Also z.B. hab ich ein paar mqtt Geräte, die ich gerne mit dem Adapter auch überwachen würde.
              Meine Idee wäre das man z.B. über die Adapterkonfig eigene Strukturen per json anlegen kann:
              	meineStruktur: {
              		Selektor: 'meineStruktur.*.rssi',
              		adapterID: 'meineStruktur',
              		adapter: 'meineStruktur',
              		battery: '.battery',
              		rssiState: '.rssi',
              		reach: 'none',
              		isLowBat: 'none',
              Was denkst du?
              da_WoodyD ? 2 Antworten Letzte Antwort
              • ScroungerS Scrounger
                @ciddi89
                	meineStruktur: {
                		rssiState: '.rssi',
                		reach: 'none',
                		isLowBat: 'none',
                Was denkst du?
                da_WoodyD Online
                da_WoodyD Online
                #717
                vllt kenn ich mich zu wenig aus, aber würde das nicht über sonoff funzen?
                  @ciddi89
                  	meineStruktur: {
                  		rssiState: '.rssi',
                  		reach: 'none',
                  		isLowBat: 'none',
                  Was denkst du?
                  #718
                  @scrounger danke für die Blumen. :)
                  Finde deine Idee sogar sehr gut, gerade für die ganzen mqtt Geräte. Habe ja auch einige am laufen aber es gibt so viele Unterschiede. Da könnte sich der User selbst seine Exoten einpflegen.
                  Werde das heute Abend mal mit reinnehmen und ausprobieren.
                  ScroungerS 1 Antwort Letzte Antwort
                    ScroungerS Offline
                    ScroungerS Offline
                    Scrounger
                    schrieb am zuletzt editiert von Scrounger
                    #719
                    @ciddi89
                    Super, vielen Dank schon mal, das wäre ne mega Funktion!
                    Das könnte man sogar so generisch aufbauen, dass das als Vorlage für neue Adapter genutzt werden kann und du ggf. nur noch die json struktur mergen musst und schon geht der neue Adapter - nur so ne idee ;-)
                      Markus_
                      schrieb am zuletzt editiert von Markus_
                      #720
                      Hallo ciddi89
                      Danke für den Adapter. Aber ich habe ein Problem.
                      Ich bekommen nur Nachrichten bei Offline Geräten. Aber nicht wenn Batteriestand zu gering.
                      Habe die stabel + github Version getestet.
                      Der Datenpunkt lowBatteryCount = 11 --> es sollte also was zum senden geben.
                      Ich habe den Adapter gerade mit debug log laufen und bekommen die ganze zeit folgende Meldungen:
                      device-watcher.0
                      2022-11-22 16:52:40.033	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:39.655	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:39.567	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:39.562	debug	Function finished: resetVars
                      device-watcher.0
                      2022-11-22 16:52:39.562	debug	Function started: resetVars
                      device-watcher.0
                      2022-11-22 16:52:39.562	debug	Function started: createDataOfAllAdapter
                      device-watcher.0
                      2022-11-22 16:52:39.561	debug	Function started: main
                      device-watcher.0
                      2022-11-22 16:52:39.561	debug	Updating Data
                      device-watcher.0
                      2022-11-22 16:52:29.560	debug	Function finished: main
                      device-watcher.0
                      2022-11-22 16:52:29.560	debug	Created and filled data for all adapters
                      device-watcher.0
                      2022-11-22 16:52:29.560	debug	Function finished: createDataOfAllAdapter
                      device-watcher.0
                      2022-11-22 16:52:29.559	debug	Function finished: writeDatapoints
                      device-watcher.0
                      2022-11-22 16:52:29.444	debug	Start the function: writeDatapoints
                      device-watcher.0
                      2022-11-22 16:52:29.443	debug	Finished the function: sendOfflineNotifications
                      device-watcher.0
                      2022-11-22 16:52:29.443	debug	Start the function: sendOfflineNotifications
                      device-watcher.0
                      2022-11-22 16:52:29.182	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:28.795	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:28.671	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:28.654	debug	Function finished: resetVars
                      device-watcher.0
                      2022-11-22 16:52:28.654	debug	Function started: resetVars
                      device-watcher.0
                      2022-11-22 16:52:28.653	debug	Function started: createDataOfAllAdapter
                      device-watcher.0
                      2022-11-22 16:52:28.653	debug	Function started: main
                      device-watcher.0
                      2022-11-22 16:52:28.652	debug	Updating Data
                      device-watcher.0
                      2022-11-22 16:52:18.651	debug	Function finished: main
                      device-watcher.0
                      2022-11-22 16:52:18.651	debug	Created and filled data for all adapters
                      device-watcher.0
                      2022-11-22 16:52:18.650	debug	Function finished: createDataOfAllAdapter
                      device-watcher.0
                      2022-11-22 16:52:18.650	debug	Function finished: writeDatapoints
                      device-watcher.0
                      2022-11-22 16:52:18.540	debug	Start the function: writeDatapoints
                      device-watcher.0
                      2022-11-22 16:52:18.540	debug	Finished the function: sendOfflineNotifications
                      device-watcher.0
                      2022-11-22 16:52:18.539	debug	Start the function: sendOfflineNotifications
                      device-watcher.0
                      2022-11-22 16:52:18.291	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:17.693	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      device-watcher.0
                      2022-11-22 16:52:17.599	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                      Brauchst du weitere Infos?
                      DANKE schon mal für deine Hilfe.
                      • M Markus_
                        Hallo ciddi89
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        device-watcher.0
                        #721
                        @markus_ hi danke für die Meldung. Bitte mal noch mal GitHub Version testen. sollte gefixt sein.
                          Markus_
                          #722
                          @ciddi89
                          DANKE für den schnellen fix.
                          Ich bekomme jetzt eine Benachrichtigung erhalten.👍
                          Darin fehlt allerdings mein Shelly Button
                          https://www.shelly.cloud/knowledge-base/devices/shelly-button-1/
                          hast du diesen schon implementiert ?
                          Das wäre der Datenpunkt der den Batterie Status anzeigt
                            "type": "state",
                            "common": {
                              "name": "value",
                              "type": "number",
                              "role": "value.battery",
                              "read": true,
                              "write": false,
                              "min": 0,
                              "max": 100,
                              "unit": "%"
                            "native": {},
                            "from": "system.adapter.shelly.0",
                            "user": "system.user.admin",
                            "ts": 1669128127316,
                            "_id": "shelly.0.SHBTN-1#48551902D56E#1.bat.value",
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                              "owner": "system.user.admin",
                          • M Markus_
                            @ciddi89
                              "type": "state",
                              "common": {
                                "name": "value",
                                "type": "number",
                                "read": true,
                                "write": false,
                                "min": 0,
                                "max": 100,
                                "unit": "%"
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                            #723
                            @markus_ okay test again. Sollte nun mit drin sein. :)
                              Markus_
                              #724
                              @ciddi89
                              Der shelly button wird jetzt angezeigt. DANKE
                              nächstes Problem: Homematic-IP HmIP-KRC4.
                              https://homematic-ip.com/de/produkt/schluesselbundfernbedienung-4-tasten/downloads
                              https://de.elv.com/elv-homematic-ip-arr-bausatz-schluesselbundfernbedienung-mit-4-tasten-hmip-krc4-fuer-smart-home-und-hausautomation-152606
                              Das ist der Datenpunkt der Batteriespannung.
                                "type": "state",
                                "common": {
                                  "name": "XXXXX:0.OPERATING_VOLTAGE",
                                  "role": "value.voltage",
                                  "def": 0,
                                  "type": "number",
                                  "read": true,
                                  "write": false,
                                  "min": 0,
                                  "max": 25.2,
                                  "unit": "V"
                                "native": {
                                  "MIN": 0,
                                  "OPERATIONS": 5,
                                  "MAX": 25.2,
                                  "FLAGS": 1,
                                  "ID": "OPERATING_VOLTAGE",
                                  "TYPE": "FLOAT",
                                  "DEFAULT": 0
                                "from": "system.adapter.hm-rega.0",
                                "ts": 1667845499723,
                                "_id": "hm-rpc.2.0002DD8991XXX.0.OPERATING_VOLTAGE",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              Anscheinend ist der max Wert des Datenpunkts falsch. Aber wer hat hier dann den Fehler gemacht? Der Programmierer des HM-RPC Adapter? Oder liegt er bei der Datenquelle also Homematic?
                              • M Markus_
                                @ciddi89
                                  "type": "state",
                                  "common": {
                                    "def": 0,
                                    "type": "number",
                                    "read": true,
                                    "write": false,
                                    "min": 0,
                                    "max": 25.2,
                                    "unit": "V"
                                  "native": {
                                    "MIN": 0,
                                    "OPERATIONS": 5,
                                    "MAX": 25.2,
                                    "FLAGS": 1,
                                    "TYPE": "FLOAT",
                                    "DEFAULT": 0
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                #725
                                @markus_ was ist denn der wert der geliefert wird? Ist auf jeden Fall hm-rpc Fehler und dafür musst du dann ein issue anlegen auf GitHub. Den kannst du aber händisch selbst ändern. Wird aber wohl möglich bei Updates überschrieben. Es gibt aber mehrere Geräte wo der Max wert von verschiedenen Geräten/Datenpunkte nicht stimmen. Hab auch so ein Gerät, weiß garnicht mehr was das für ein Datenpunkt es war aber im Log kam dann auch immer die Meldung „32 is greater than the max value 8“ oder so ähnlich. Aber seitdem ich es selbst angepasst habe ist Ruhe.
                                  Markus_
                                  #726
                                  @ciddi89
                                  Danke für die Info.
                                  Es wird hier die Spannung in Volt angezeigt.
                                  Ich habe ein Issue auf Github aufgemacht
                                  Nächstes Problem:
                                  Ich habe die Einstellung "Nur Geräte mit Batterien auflisten" aktiv und mir werden viele Homemmatic IP Wired Geräte angezeigt. Woher weißt du ob ein Gerät eine Batterie hat? Bei mir werden sie aufgelistet obwohl sie immer mit Netzteil versorgt werden.
                                  z.B. https://homematic-ip.com/de/produkt/wired-access-point
                                  • M Markus_
                                    @ciddi89
                                    Danke für die Info.
                                    Nächstes Problem:
                                    #727
                                    @markus_ ah okay danke für die Info. Ja der Adapter guckt nach operating_voltage oder low bat Datenpunkte. Homematic Wired hatte ich noch nicht aufn Schirm somit bist du mir eine große Hilfe :) werde heute Abend aber n Filter einbauen der die Geräte raus nimmt. Melde mich dann noch mal :)
                                    • M Markus_
                                      @ciddi89
                                      Danke für die Info.
                                      Nächstes Problem:
                                      #728
                                      @markus_ Geräte mit einer höheren Spannung werden nun nicht mehr als Batterie Geräte angezeigt. Kannst du ja noch einmal testen. :)
                                        Markus_
                                        #729
                                        @ciddi89
                                        Die Homematic Ip Wired Geräte werden jetzt nicht mehr aufgelistet.
                                        SUPER DANKE 🤘
                                        Ich habe jetzt bei den Batterie betriebenen Geräten versucht den Max Wert manuell anzupassen. Das hat leider nichts gebracht. Bei den Geräten erhalte ich keine "low battery" Meldung.
                                          "type": "state",
                                          "common": {
                                            "name": "XXX:0.OPERATING_VOLTAGE",
                                            "def": 0,
                                            "type": "number",
                                            "read": true,
                                            "write": false,
                                            "min": 0,
                                            "max": 1.5,
                                            "unit": "V"
                                          "native": {
                                            "MIN": 0,
                                            "OPERATIONS": 5,
                                            "MAX": 1.5,
                                            "FLAGS": 1,
                                            "TYPE": "FLOAT",
                                            "DEFAULT": 0
                                          "_id": "XXX.0.OPERATING_VOLTAGE",
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                          "ts": 1669238162413
                                        • M Markus_
                                          @ciddi89
                                          SUPER DANKE 🤘
                                            "type": "state",
                                            "common": {
                                              "def": 0,
                                              "type": "number",
                                              "read": true,
                                              "write": false,
                                              "min": 0,
                                              "max": 1.5,
                                              "unit": "V"
                                            "native": {
                                              "MIN": 0,
                                              "OPERATIONS": 5,
                                              "MAX": 1.5,
                                              "FLAGS": 1,
                                              "TYPE": "FLOAT",
                                              "DEFAULT": 0
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                            "ts": 1669238162413
                                          #730
                                          @markus_ verstehe ich nun nicht. Der Max wert definiert den maximalen Wert vom Datenpunkt. Das hat nichts damit zu tun wann er als low bat device gelten soll. Dafür haben die einen Datenpunkt namens lowbat/low_bat dieser wird aber vom Gerät bestimmt wann dieser auf true springen soll.
