  3. Off Topic
  4. Proxmox
  5. Proxmox und iobroker
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
226 Beiträge 8 Kommentatoren 34.8k Aufrufe 5 Beobachtet
  • Marko1974M Marko1974
    @homoran Das habe ich doch oben im Thread alles schon getan....
    Debian GNU/Linux 11 ioBroker tty1
    ioBroker login: openhabian
    Password:
    Linux ioBroker 5.13.19-6-pve #1 SMP PVE 5.13.19-15 (Tue, 29 Mar 2022 15:59:50 +0200) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Fri Apr 29 20:37:07 CEST 2022 on tty1
    openhabian@ioBroker:~$ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2022-02-10
        Welcome to the ioBroker installer!
        Installer version: 2022-02-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    [sudo] password for openhabian:
    Hit:1 http://ftp.debian.org/debian bullseye InRelease
    Get:2 http://ftp.debian.org/debian bullseye-updates InRelease [39.4 kB]
    Hit:3 http://security.debian.org bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
    Fetched 39.4 kB in 1s (71.2 kB/s)
    Reading package lists... Done
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
    Installed python-dev
        Creating ioBroker user and directory (2/4)
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.0.73:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    openhabian@ioBroker:~$ iobroker list instances
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8112, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + instance is alive
    crunchipC Abwesend
    crunchipC Abwesend
    #61
    @marko1974 sagte in Proxmox und iobroker:
    das was wir aktuell von dir forderten, hast du uns nicht gezeigt
    also hattest du nur das vergessen, meinst du?
    das hat aber nichts mit dem laufenden iobroker zu tun
      Password:
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      + instance is alive
      #62
      also weit vorausschauend schon später angefragte Konsolenausgaben gepostet?
      es geht aber um die Ausgabe zur Zeit meiner Frage
      @homoran sagte in Proxmox und iobroker:
      was sagt er bei iobroker list instances ?
      kann ich nicht sehen
        Password:
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        + instance is alive
        crunchipC Abwesend
        crunchipC Abwesend
        #63
        @marko1974 oben war auch dein node.js Install nicht vorhanden, daher die Nachfrage auf ein Netzwerkproblem.
        Hast du den den LXC danach neu erstellt oder was umgestellt?
        Marko1974M 2 Antworten Letzte Antwort
          Marko1974M Offline
          Marko1974M Offline
          Marko1974
          #64
          @crunchip Ich glaube dass ich mich gestern einfach nicht ausgeloggt habe, sondern iobroker ohne ausloggen installieren wollte und das nicht geklappt hat.
          + instance is alive
          • L lessthanmore
            @marko1974 Gleiche IP Range bzw. Subnetz?
            Marko1974M Offline
            Marko1974M Offline
            Marko1974
            #65
            @lessthanmore said in Proxmox und iobroker:
              Marko1974M Offline
              Marko1974M Offline
              Marko1974
              #66
              @crunchip said in Proxmox und iobroker:
              Hmmm...eigentlich nicht...hatte ihn mal rebooten lassen.
              Jetzt würde ich die Backup Dateien von iobroker in /opt/iobroker/backups schieben und diese wiederherstellen.
              Die Frage ist, wenn ich dann alles stromlos mache und quasi 10 km weiter damit wandere und mich in einem anderen Netzwerk befinde....wie komme ich dann wieder auf Proxmox.....über den Browser eher nicht. Die Einstellung ist, wie oben gezeigt auf DHCP. Bekommt das Gerät dann einfach eine neue IP und ich kann wieder connecten? bzw....wie erfahre ich diese.
              Sinnig wäre auch dem Gerät die gleiche IP Adresse zu geben, die vorher der Raspberry hatte, der noch aktuell läuft.
              Heisst:
              1. Raspberry auf dem Netzwerk
              2. backup wäre schon drauf
              3. USB Ports durchreichen. Hab da nen Deconz Stick und nen CUL
                (Da muss ich nochmal lesen wie das geht)
              Kann das so funktionieren?
                + instance is alive
                crunchipC Abwesend
                crunchipC Abwesend
                #67
                wie kommst du zu diesem Port?
                • Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  schrieb am zuletzt editiert von Marko1974
                  #68
                  @crunchip den hatte ich gestern manuell angelegt und den admin.0 damit gestartet, weil ich dachte der sei vielleicht belegt....aber das Problem war ja ein anderes.
                  Ändere ich gleich besser.
                  + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  DONE
                    fertig habe quasi in ein anderes netzwerk mit dem Teil wande
                    Was heisst anderes Netzwerk?
                    Das heißt, dass ich hier alles fertig machen möchte und das Ding dann mit zu meinen Eltern nehme.
                    Bekommt also eine andere IP.
                    Ich hab hier was mit 192.168.0.1
                    Und die mit 178.1….wenn mir einer sagen kann wie ich das nachträglich anpasse wäre ich dankbar.
                    Zu dem Ping an Node.js komme ich gleich. Ich schmeiß das Ding gleich mal an, wenn ich zuhause bin.
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #69
                    wo soll denn der zukünftig laufen? naja, wenn Proxmox, sowie der LXC per DHCP eingerichtet ist, bekommt alle halt ne neue IP
                    nö, geht ja schlecht
                    sinnig wäre auch dem Gerät die gleiche IP Adresse zu geben,
                    Marko1974M 1 Antwort Letzte Antwort
                      Marko1974M Offline
                      Marko1974
                      #70
                      @crunchip Die man dann später doch auch wieder ändern kann, oder?
                        Marko1974M Offline
                        Marko1974M Offline
                        Marko1974
                        #71
                        Na doch....ich werde doch den Raspberry vom Netzwerk trennen und dann bekommt der iobroker LXC die gleiche IP wie vorher der Raspberry...mache ich dann über DHCP der Fritzbox
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #72
                          Na doch
                          Na Nein
                            Na doch
                            Na Nein
                            Marko1974M Offline
                            Marko1974M Offline
                            Marko1974
                            #73
                            @crunchip 😧 Ja wieso denn nicht.
                            Angenommen der Raspberry hat 192.168.178.72 und der Proxmox bekommt, wenn ich ihn ins Netzwerk hänge 192.168.178.73
                            dann kann ich doch, wenn der Raspberry nicht mehr da ist über fritz.box 192.168.178.72 an den Proxmox vergeben
                            ähm...ich meinte damit nicht, dass ich sie ihm jetzt schon gebe
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #74
                              hier schreibst du was von zwei verschiedenen Netzwerke
                              ich blicks nimmer
                              möchtest du vorübergehend den Rechner mitnehmen oder soll der generell zu deinen Eltern?
                                ich blicks nimmer
                                Marko1974M Offline
                                Marko1974M Offline
                                Marko1974
                                #75
                                @crunchip der soll da generell hin. Im moment steht da halt ein raspberry und ich habe vor einfach die beiden auszutauschen.
                                Wollte jetzt noch "eben" das Backup von iobroker einspielen und dann das komplette Teil mitnehmen.
                                Ich selbst bin jetzt aber bei MIR zuhause....also in einem völlig anderen Netzwerk
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #76
                                  @marko197 aber dann musst du doch eh anpassen, je nachdem was auf deinem Pi läuft, so wie ich schon weiter oben schrieb...shelly, sonoff...
                                  wenn nichts dergleichen in iobroker läuft, was direkt auf eine ip greift, dann kannst du dhcp lassen und sollte sich dort mit neuer ip anmelden
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    #77
                                    @crunchip Ich glaube ich drücke mich umständlich aus.
                                    Ich möchte vermeiden wieder irgendwelche Geräte konfigurieren zu muessen.
                                    Wollte mir vom Raspberry das iobroker Backup ziehen und danach den Raspberry abstecken, iobroker Backup in LXC iobroker einspielen, IP auf die vom alten Raspberry anpassen, fertig.
                                    E crunchipC 2 Antworten Letzte Antwort
                                      Einstein67
                                      schrieb am zuletzt editiert von Einstein67
                                      #78
                                      @marko1974 Die IP vom Container auf die IP vom RasPi zu ändern ist kein Problem. Allerdings musst du vorher die statische IP vom Proxmox-PVE (mit Tastatur und Monitor in der PVE-Konsole) an das neue Netz anpassen.
                                      Also von 0 auf 178. Wie man das (ohne GUI) richtig macht hab ich keinen Plan.
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #79
                                        Wie soll das gehen, 192. vs 178. Netz
                                          Marko1974M Offline
                                          Marko1974M Offline
                                          Marko1974
                                          #80
                                          @crunchip Auf dem Raspberry läuft nur iobroker und nichts anderes. Die Geräte die auf den Adapter verbinden sind ja im Backup gepflegt.
                                          Wie ziehen denn sonst andere Leute auf ein neues System um? Dafür gibt es doch auch das Backup oder?
                                          Ich sichere ein Backup auf dem alten System und spiele es dann ins neue ein.
                                          Nun ist es eben so, dass ich dies schon bei mir zuhause vorbereitet habe. Ich habe das Backup vom Raspberry auf dem im Container laufenden IoBroker importiert. Die Adapter sind alle installiert und IP Adressen und auch die Passwörter sind hinterlegt.
                                          Jetzt würde ich das Teil mit zu den Eltern nehmen, den Raspberry von Netz trennen und irgendwie versuchen dem Container die Ip zu geben.
                                          Ich komme auf die Konsole mit HDMI Kabel. Da kenne ich mich aber gar nicht aus.
