  4. Server Cannot start inMem-objects on port 9001
    5.8k
429 Beiträge 40 Kommentatoren 125.6k Aufrufe 39 Beobachtet
  • apollon77A Offline
    #81
    Dann ersuch mal Controller auf 4.0.23 ohne die install Skripte.
    Also
    cd /opt/iobroker
    npm i iobroker.js-controller@4.0.23 --ignore-scripts
    Dann mal
    iob status Bzw iob update
    Edit:und vorher sicherstellen das wirklich aus ist. Also auch das im logfile unter /opt/iobroker/log nix neues kommt.
    • apollon77A apollon77
      Also
      cd /opt/iobroker
      Dann mal
      Dieter_P
      #82
      @apollon77
      Danke. Leider noch gleiche Meldungen:
      pi@raspberrypi:/opt/iobroker/log $ nano iobroker.2022-07-08.log
      pi@raspberrypi:/opt/iobroker/log $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@4.0.23 --ignore-scripts
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
      + iobroker.js-controller@4.0.23
      added 6 packages from 10 contributors and removed 3 packages in 156.871s
      87 packages are looking for funding
        run `npm fund` for details
      pi@raspberrypi:/opt/iobroker $ cd
      pi@raspberrypi:~ $ iob status
      No connection to databases possible ...
      pi@raspberrypi:~ $ iob update
      pi@raspberrypi:~ $ npm fund
      /home/pi
         │      New major version of npm available! 6.14.17 → 8.13.2      │
         │   Changelog: https://github.com/npm/cli/releases/tag/v8.13.2   │
         │               Run npm install -g npm to update!                │
      pi@raspberrypi:~ $
      • D Dieter_P
        @apollon77
        /home/pi
        pi@raspberrypi:~ $
        #83
        @dieter_p Dann bitte "Iob custom" aufrufen und die Ausgabe zeigen. kannst DU mit CTRL-C abbrechen. Und bitte auch zeigen was ein "iob start" im ioBroker log bringt
          Dieter_P
          #84
          @apollon77 said in Server Cannot start inMem-objects on port 9001:
          Iob custom
          Danke. Der Befehl "custom" fehlt oder ich mach was falsch
          pi@raspberrypi:~ $ iob custom
          iobroker [command]
          Commands:
            iobroker setup                                               Setup ioBroker
            iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
            iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
            iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
            iobroker info                                                Shows the host info
            iobroker logs [<adapter>]                                    Monitor log
            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
            iobroker rebuild [<module>]                                  Rebuild all native modules or path
            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
            iobroker update [<repositoryUrl>]                            Update repository and list adapters
            iobroker upgrade                                             Upgrade management
            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
            iobroker object                                              Object management  [aliases: o]
            iobroker state                                               State management  [aliases: s]
            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
            iobroker list <type> [<filter>]                              List all entries, like objects
            iobroker chmod <mode> <file>                                 Change file rights
            iobroker chown <user> <group> <file>                         Change file ownership
            iobroker touch <file>                                        Touch file
            iobroker rm <file>                                           Remove file
            iobroker file                                                File management
            iobroker user                                                User commands
            iobroker group                                               group management
            iobroker host <hostname>                                     Set host to given hostname
            iobroker set <adapter>.<instance>                            Change settings of adapter config
            iobroker license <license.file or license.text>              Update license by given file
            iobroker cert                                                Certificate management
            iobroker clean <yes>                                         Clears all objects and states
            iobroker backup                                              Create backup
            iobroker restore <backup name or path>                       Restore a specified backup
            iobroker validate <backup name or path>                      Validate a specified backup
            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
            iobroker repo [<name>]                                       Show repo information
            iobroker uuid                                                Show uuid of the installation  [aliases: id]
            iobroker unsetup                                             Reset license, installation secret and language
            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
            iobroker multihost                                           Multihost management
            iobroker compact                                             compact group management
            iobroker plugin                                              Plugin management
            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
          Options:
            --help  Show help  [boolean]
          pi@raspberrypi:~ $ iob info
          pi@raspberrypi:~ $ iob start
          Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          pi@raspberrypi:~ $
          • D Dieter_P
            Iob custom
            iobroker [command]
            Commands:
            Options:
            pi@raspberrypi:~ $
            #85
            @dieter_p
            iobroker setup custom
            D apollon77A 2 Antworten Letzte Antwort
              @dieter_p
              Dieter_P
              #86
              @thomas-braun said in Server Cannot start inMem-objects on port 9001:
              pi@raspberrypi:~ $ iobroker setup custom
              Current configuration:
              - Objects database:
                - Type: jsonl
                - Host/Unix Socket: 127.0.0.1
                - Port: 9001
              - States database:
                - Type: jsonl
                - Port: 9000
              - Data Directory: ../../iobroker-data/
              Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
              • D Dieter_P
                - Objects database:
                  - Type: jsonl
                  - Port: 9001
                - States database:
                  - Type: jsonl
                  - Port: 9000
                #87
                @dieter_p
                Und wie sieht ein Start im LogFile aus?
                Mit
                tail -f /opt/iobroker/log/iobroker.current.log
                in einer zweiten Session nachschauen.
                  @dieter_p
                  Mit
                  Dieter_P
                  #88
                  Hab die MAC Adressen mal "angepasst" die sollten hier doch nichts zu beitragen, oder?
                  2022-07-08 10:24:44.819  - info: host.raspberrypi iobroker _restart
                  2022-07-08 10:24:53.399  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                  2022-07-08 10:24:53.424  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2022-07-08 10:24:53.427  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.3
                  2022-07-08 10:24:53.429  - info: host.raspberrypi ip addresses: 192.168.0.38 2a02:908:13b7:xxxx:xxxx:4331:xxxxx:82ad fe80::xxx:b07e:xxxx:49ba 10.0.1.2
                  2022-07-08 10:25:23.502  - error: host.raspberrypi No connection to databases possible, restart
                  2022-07-08 10:25:23.559  - info: host.raspberrypi iobroker _restart
                  • D Dieter_P
                    #89
                    @dieter_p
                    Läuft das im Docker oder sowas?
                      @dieter_p
                      Dieter_P
                      #90
                      Nein ganz klassisch auf nem RPI2 nur mit SD-Karte und nem ZigbeeStick.
                      Installiert über die Installationsanleitung aus der Doku hier.
                        @dieter_p
                        #91
                        @thomas-braun ÄÄähhmm ja .. danke ...war zu spät gestern Abend am Handy. Sorry
                        • D Dieter_P
                          #92
                          @dieter_p Komisch ... zeig mal "ip a" Ausgabe (hoffe das geht da). Ich will mal die Netzwerkinterfaces sehen. Weil erste Vermutung ist das die 127.0.0.1 whyever nicht auf sich selbst auflöst
                            Dieter_P
                            #93
                            @apollon77
                            Thx. Warum das jetzt auf einmal auftritt kommt mir auch komisch vor. Diese Konfig läuft so unverändert ca seit 1 Jahr inkl. Wireguard
                            pi@raspberrypi:~ $ ip a
                            1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                inet 127.0.0.1/8 scope host lo
                                   valid_lft forever preferred_lft forever
                                inet6 ::1/128 scope host
                            2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                link/ether b8:27:xx:c2:xx:be brd ff:ff:ff:ff:ff:ff
                                inet 192.168.0.38/24 brd 192.168.0.255 scope global noprefixroute eth0
                                inet6 2a02:xxx:13b7:xxxx:64ad:4331:xxxx:82ad/64 scope global dynamic mngtmpaddr noprefixroute
                                   valid_lft 68729sec preferred_lft 25529sec
                                inet6 fe80::xxx:b07e:xxxx:49ba/64 scope link
                            3: wgclient0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
                                link/none
                                inet 10.0.1.2/24 scope global wgclient0
                              #94
                              Also das ganze funktioniert so. ioBroker startet und startet die DB auf dem Port 9000 und 9001 und die "Listenen" auf der IP (127.0.01 in deinem Fall) die angegeben ist. Sobald die DB gestartet ist versucht ein DB-Client in der Software sich darauf zu verbinden. Und DAS geht bei dir nicht, deswegen sagt der Client nach 30s ... da passt was net. Meine Vermutung ist das er bei diesem "eigentlich lokalen" verbindungsversuch nicht "lokal" rumkommt und daher das Listen auf 127.0.01 es blockt.
                              Auch wenn ich nicht verstehe warum die 127.0.01 nicht geht (vllt hat Thomas noch ne Idee), ändere mal in /opt/iobroker/iobroker-data/iobroker.json in den objects und state Abschnitten die 127.0.01 gegen 0.0.0.0 und versuch dann mal. Damit "Listened" er auf "egal woher die verbindung kommt". Wenn das geht hast Du nen Workaround ...
                                Dieter_P
                                #95
                                Vielen Dank auch für Deine für mich verständliche Erklärung! In Object und states angepasst aber leider immer noch der Zugriffsfehler:
                                pi@raspberrypi:~ $ sudo nano /opt/iobroker/iobroker-data/iobroker.json
                                pi@raspberrypi:~ $ iob stop
                                pi@raspberrypi:~ $
                                • D Dieter_P
                                  @dieter_p läuft was anderes auf dem Host auf Port 9000 oder 9001?
                                  Versuche mal ob ich das heraus bekomme aber wissentlich nein.
                                  Auf dem Pi läuft noch ein WireGuard Client aber der nicht auf 9000/9001 und das auch nicht erst seit gestern sondern schon Monate. Sonst ist nichts installiert.
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #96
                                  @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
                                  Komischerweise ist er bei dir nicht aufgelistet !?
                                  Kannst du das nochmal zeigen :
                                  sudo netstat -ntlp | grep LISTEN
                                  • GlasfaserG Glasfaser
                                    Dieter_P
                                    #97
                                    @glasfaser said in Server Cannot start inMem-objects on port 9001:
                                    pi@raspberrypi:~ $ sudo netstat -ntlp | grep LISTEN
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      443/sshd
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      329/cupsd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      443/sshd
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      329/cupsd
                                    Funktionieren, sollte er da ich auch über den Tunnel aktuell arbeiten kann.
                                    • D Dieter_P
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      #98
                                      Wie hast du denn gerade Zugriff auf deinem Pi !?
                                        Dieter_P
                                        #99
                                        @glasfaser
                                        Auf diesen Pi direkt im lokalen Netz über Putty
                                        Wireguard verbindet bei mir 2 Netze. Ich sitze lokal im Netz des IOBroker der aktuell probleme macht. Da gibt es auch Routingtabellen ins andere Netz die aber liegen jeweils auf den Clients und nicht zentral am RPI da das nicht so einfach war, wenn ich das noch richtig zusammen bekomme.
                                        Das aber alles unverändert seit ca. 1 Jahr wo es lief.
                                        • D Dieter_P
                                          pi@raspberrypi:~ $
                                          #100
                                          @dieter_p Lass iobroker mal bitte aus ... und dann iob status. eil jetzt ists wieder anderer Fehler. Zeig mal den Inhalt von /opt/iobroker/iobroker-data/ bitte
