  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.5k Aufrufe 39 Beobachtet
  • apollon77A apollon77
    @dieter_p Dann bitte "Iob custom" aufrufen und die Ausgabe zeigen. kannst DU mit CTRL-C abbrechen. Und bitte auch zeigen was ein "iob start" im ioBroker log bringt
    Dieter_P
    #84
    @apollon77 said in Server Cannot start inMem-objects on port 9001:
    Iob custom
    Danke. Der Befehl "custom" fehlt oder ich mach was falsch
    pi@raspberrypi:~ $ iob custom
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    pi@raspberrypi:~ $ iob info
    No connection to databases possible ...
    pi@raspberrypi:~ $ iob start
    pi@raspberrypi:~ $ iob status
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    pi@raspberrypi:~ $
    • D Dieter_P
      Iob custom
      iobroker [command]
      Commands:
      Options:
      pi@raspberrypi:~ $
      #85
      @dieter_p
      iobroker setup custom
      D apollon77A 2 Antworten Letzte Antwort
        @dieter_p
        Dieter_P
        #86
        @thomas-braun said in Server Cannot start inMem-objects on port 9001:
        pi@raspberrypi:~ $ iobroker setup custom
        Current configuration:
        - Objects database:
          - Type: jsonl
          - Host/Unix Socket: 127.0.0.1
          - Port: 9001
        - States database:
          - Type: jsonl
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
        • D Dieter_P
          - Objects database:
            - Type: jsonl
            - Port: 9001
          - States database:
            - Type: jsonl
            - Port: 9000
          #87
          @dieter_p
          Und wie sieht ein Start im LogFile aus?
          Mit
          tail -f /opt/iobroker/log/iobroker.current.log
          in einer zweiten Session nachschauen.
            @dieter_p
            Mit
            Dieter_P
            #88
            Hab die MAC Adressen mal "angepasst" die sollten hier doch nichts zu beitragen, oder?
            2022-07-08 10:24:44.819  - info: host.raspberrypi iobroker _restart
            2022-07-08 10:24:53.399  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
            2022-07-08 10:24:53.424  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-07-08 10:24:53.427  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.3
            2022-07-08 10:24:53.429  - info: host.raspberrypi ip addresses: 192.168.0.38 2a02:908:13b7:xxxx:xxxx:4331:xxxxx:82ad fe80::xxx:b07e:xxxx:49ba 10.0.1.2
            2022-07-08 10:25:23.502  - error: host.raspberrypi No connection to databases possible, restart
            2022-07-08 10:25:23.559  - info: host.raspberrypi iobroker _restart
            • D Dieter_P
              #89
              @dieter_p
              Läuft das im Docker oder sowas?
                @dieter_p
                Dieter_P
                #90
                Nein ganz klassisch auf nem RPI2 nur mit SD-Karte und nem ZigbeeStick.
                Installiert über die Installationsanleitung aus der Doku hier.
                  @dieter_p
                  #91
                  @thomas-braun ÄÄähhmm ja .. danke ...war zu spät gestern Abend am Handy. Sorry
                  • D Dieter_P
                    #92
                    @dieter_p Komisch ... zeig mal "ip a" Ausgabe (hoffe das geht da). Ich will mal die Netzwerkinterfaces sehen. Weil erste Vermutung ist das die 127.0.0.1 whyever nicht auf sich selbst auflöst
                      Dieter_P
                      #93
                      @apollon77
                      Thx. Warum das jetzt auf einmal auftritt kommt mir auch komisch vor. Diese Konfig läuft so unverändert ca seit 1 Jahr inkl. Wireguard
                      pi@raspberrypi:~ $ ip a
                      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                          inet 127.0.0.1/8 scope host lo
                             valid_lft forever preferred_lft forever
                          inet6 ::1/128 scope host
                      2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                          link/ether b8:27:xx:c2:xx:be brd ff:ff:ff:ff:ff:ff
                          inet 192.168.0.38/24 brd 192.168.0.255 scope global noprefixroute eth0
                          inet6 2a02:xxx:13b7:xxxx:64ad:4331:xxxx:82ad/64 scope global dynamic mngtmpaddr noprefixroute
                             valid_lft 68729sec preferred_lft 25529sec
                          inet6 fe80::xxx:b07e:xxxx:49ba/64 scope link
                      3: wgclient0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
                          link/none
                          inet 10.0.1.2/24 scope global wgclient0
                      • apollon77A Offline
                        #94
                        Also das ganze funktioniert so. ioBroker startet und startet die DB auf dem Port 9000 und 9001 und die "Listenen" auf der IP (127.0.01 in deinem Fall) die angegeben ist. Sobald die DB gestartet ist versucht ein DB-Client in der Software sich darauf zu verbinden. Und DAS geht bei dir nicht, deswegen sagt der Client nach 30s ... da passt was net. Meine Vermutung ist das er bei diesem "eigentlich lokalen" verbindungsversuch nicht "lokal" rumkommt und daher das Listen auf 127.0.01 es blockt.
                        Auch wenn ich nicht verstehe warum die 127.0.01 nicht geht (vllt hat Thomas noch ne Idee), ändere mal in /opt/iobroker/iobroker-data/iobroker.json in den objects und state Abschnitten die 127.0.01 gegen 0.0.0.0 und versuch dann mal. Damit "Listened" er auf "egal woher die verbindung kommt". Wenn das geht hast Du nen Workaround ...
                          Dieter_P
                          #95
                          Vielen Dank auch für Deine für mich verständliche Erklärung! In Object und states angepasst aber leider immer noch der Zugriffsfehler:
                          pi@raspberrypi:~ $ sudo nano /opt/iobroker/iobroker-data/iobroker.json
                          pi@raspberrypi:~ $ iob stop
                          pi@raspberrypi:~ $
                          • D Dieter_P
                            @dieter_p läuft was anderes auf dem Host auf Port 9000 oder 9001?
                            Versuche mal ob ich das heraus bekomme aber wissentlich nein.
                            Auf dem Pi läuft noch ein WireGuard Client aber der nicht auf 9000/9001 und das auch nicht erst seit gestern sondern schon Monate. Sonst ist nichts installiert.
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #96
                            @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
                            Komischerweise ist er bei dir nicht aufgelistet !?
                            Kannst du das nochmal zeigen :
                            sudo netstat -ntlp | grep LISTEN
                            • GlasfaserG Glasfaser
                              Dieter_P
                              #97
                              @glasfaser said in Server Cannot start inMem-objects on port 9001:
                              pi@raspberrypi:~ $ sudo netstat -ntlp | grep LISTEN
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      443/sshd
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      329/cupsd
                              tcp6       0      0 :::22                   :::*                    LISTEN      443/sshd
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      329/cupsd
                              Funktionieren, sollte er da ich auch über den Tunnel aktuell arbeiten kann.
                              • D Dieter_P
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #98
                                Wie hast du denn gerade Zugriff auf deinem Pi !?
                                  Dieter_P
                                  #99
                                  @glasfaser
                                  Auf diesen Pi direkt im lokalen Netz über Putty
                                  Wireguard verbindet bei mir 2 Netze. Ich sitze lokal im Netz des IOBroker der aktuell probleme macht. Da gibt es auch Routingtabellen ins andere Netz die aber liegen jeweils auf den Clients und nicht zentral am RPI da das nicht so einfach war, wenn ich das noch richtig zusammen bekomme.
                                  Das aber alles unverändert seit ca. 1 Jahr wo es lief.
                                  • D Dieter_P
                                    pi@raspberrypi:~ $
                                    #100
                                    @dieter_p Lass iobroker mal bitte aus ... und dann iob status. eil jetzt ists wieder anderer Fehler. Zeig mal den Inhalt von /opt/iobroker/iobroker-data/ bitte
                                      Dieter_P
                                      #101
                                      pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -l
                                      insgesamt 636684
                                      drwxrwxr-x+   2 iobroker iobroker      4096 Mär 11 08:42 backitup
                                      drwxrwxr-x+   2 iobroker iobroker      4096 Jul  7 14:13 backup-objects
                                      drwxrwxr-x+   3 iobroker iobroker      4096 Jan 10 12:58 esphome.0
                                      drwxrwxr-x+  23 iobroker iobroker      4096 Jan  7 13:19 files
                                      drwxrwxr-x+ 253 iobroker iobroker      4096 Jul  7 00:13 history
                                      -rw-rwxr--+   1 iobroker iobroker      5124 Jul  8 11:28 iobroker.json
                                      -rw-rwxr--+   1 iobroker iobroker         3 Jul  7 15:19 notifications.json
                                      -rw-rwxr--+   1 iobroker iobroker   6255293 Mär 11 09:16 objects.json.bak.migrated
                                      -rw-rwxr--+   1 iobroker iobroker 628237946 Jul  7 15:17 objects.jsonl
                                      -rw-rwxr--+   1 iobroker iobroker   6255293 Mär 11 09:16 objects.json.migrated
                                      -rw-rwxr--+   1 iobroker iobroker    458322 Mär 11 09:17 states.json.bak.migrated
                                      -rw-rwxr--+   1 iobroker iobroker         0 Feb  4 19:44 states.json.broken
                                      -rw-rwxr--+   1 iobroker iobroker  10235951 Jul  7 15:19 states.jsonl
                                      -rw-rwxr--+   1 iobroker iobroker    458322 Mär 11 09:17 states.json.migrated
                                      drwxrwxr-x+   2 iobroker iobroker     12288 Jul  7 15:19 zigbee_0
                                      • D Dieter_P
                                        insgesamt 636684
                                        #102
                                        @dieter_p Sieht auch gut aus. So langsam gehen mir die ideen aus. "Iob fix "hattest Du versucht falls rechtemäßig was verbogen ist?
                                        Also : iobroker bitte ausschalten, dann schauen das im Logfile innerhalb von 2-3 Minuten NICHTS rein kommt ... ann nochmals iob status bitte versuchen
                                        GlasfaserG D 2 Antworten Letzte Antwort
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #103
                                          @apollon77 sagte in Server Cannot start inMem-objects on port 9001:
                                          ??! schauen was läuft mit :
                                          ps auxww
