  4. Server Cannot start inMem-objects on port 9001
    1.0k
    6.1k
429 Beiträge 40 Kommentatoren 126.7k Aufrufe 39 Beobachtet
    @dieter_p sagte in Server Cannot start inMem-objects on port 9001:
    Sorry da stimmte was nicht:
    Da stimmt immer noch was nicht...
    Egal.
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    Dieter_P
    #72
    @thomas-braun said in Server Cannot start inMem-objects on port 9001:
    das kommt raus:
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.17
    > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    No connection to databases possible ...
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm ERR! code ELIFECYCLE
    npm ERR! errno 22
    npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-07T14_57_18_192Z-debug.log
    • D Dieter_P
      das kommt raus:
      npm ERR! errno 22
      npm ERR!
      #73
      @dieter_p läuft was anderes auf dem Host auf Port 9000 oder 9001?
      • apollon77A apollon77
        Dieter_P
        #74
        @apollon77 said in Server Cannot start inMem-objects on port 9001:
        Versuche mal ob ich das heraus bekomme aber wissentlich nein.
        Auf dem Pi läuft noch ein WireGuard Client aber der nicht auf 9000/9001 und das auch nicht erst seit gestern sondern schon Monate. Sonst ist nichts installiert.
        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
        • D Dieter_P
          #75
          @dieter_p
          Kannst ja damit mal schauen:
          sudo netstat -tulpen
          Was mich auch wundert:
          Das müsste eigentlich auf allen Kanälen die 4.0.23 sein. Keine Ahnung wo das bei dir herkommt. Vielleicht aus dem npm cache.
            @dieter_p
            Dieter_P
            #76
            da scheint nichts zu laufen:
            pi@raspberrypi:~ $ netstat -an | grep 9000
            pi@raspberrypi:~ $ netstat -an | grep 9001
            pi@raspberrypi:~ $ man lsof
            pi@raspberrypi:~ $ lsof -i:9000
            pi@raspberrypi:~ $ lsof -i:9001
            pi@raspberrypi:~ $ sudo netstat -tulpen
            Aktive Internetverbindungen (Nur Server)
            Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16710      442/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14477      287/cupsd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          16712      442/sshd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14476      287/cupsd
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16749      364/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14298      371/cups-browsed
            udp        0      0 0.0.0.0:36489           0.0.0.0:*                           108        14190      298/avahi-daemon: r
            udp        0      0 0.0.0.0:48820           0.0.0.0:*                           0          16853      -
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14188      298/avahi-daemon: r
            udp6       0      0 :::48820                :::*                                0          16854      -
            udp6       0      0 :::50885                :::*                                108        14191      298/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        14189      298/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          16765      364/dhcpcd
            pi@raspberrypi:~ $
            • D Dieter_P
              pi@raspberrypi:~ $
              #77
              @dieter_p
              Vermutlich aber eine Desktop-Umgebung am Start.
                @dieter_p
                Dieter_P
                #78
                Da Du immer darauf verweist und ich mir bewusst war mit dem RPI2 am Limit zu sein, bin ich mir zu 99,9% sicher nein ;)
                Edit:
                pi@raspberrypi:~ $ who -r
                         Runlevel 3   2022-07-07 16:20
                • D Dieter_P
                  Edit:
                  #79
                  @dieter_p
                  Den cupsd fängt man sich halt bevorzugt mit einem Desktop ein, deswegen komme ich darauf.
                  npm cache mal gelöscht?
                    @dieter_p
                    Dieter_P
                    #80
                    @dieter_p
                    Sollte man das forcen?
                    pi@raspberrypi:~ $ sudo npm cache clean
                    npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                    npm ERR!
                    npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
                    npm ERR!     /root/.npm/_logs/2022-07-07T16_39_18_206Z-debug.log
                    Edit: Durch ein Verify des caches ergab sich keine Änderung:
                    pi@raspberrypi:~ $ npm cache verify
                    Cache verified and compressed (~/.npm/_cacache):
                    Content verified: 1864 (82698644 bytes)
                    Index entries: 2895
                    Finished in 41.415s
                    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    npm ERR! errno 24
                    npm ERR! Exit status 24
                    npm ERR!
                    npm ERR!     /home/iobroker/.npm/_logs/2022-07-07T16_47_48_644Z-debug.log
                    Edit2: Etwas blöd, dass mir erst jetzt auffällt das ich in der Cloud nur BackUps bis zum 02.05.2022 liegen hab. Da scheint schon was länger nicht einwandfrei zu laufen. Sonst wäre eine Neuinstallation sicher der bessere Weg.
                    • apollon77A Offline
                      #81
                      Dann ersuch mal Controller auf 4.0.23 ohne die install Skripte.
                      Also
                      cd /opt/iobroker
                      npm i iobroker.js-controller@4.0.23 --ignore-scripts
                      Dann mal
                      iob status Bzw iob update
                      Edit:und vorher sicherstellen das wirklich aus ist. Also auch das im logfile unter /opt/iobroker/log nix neues kommt.
                        Also
                        cd /opt/iobroker
                        Dann mal
                        Dieter_P
                        #82
                        @apollon77
                        Danke. Leider noch gleiche Meldungen:
                        pi@raspberrypi:/opt/iobroker/log $ nano iobroker.2022-07-08.log
                        pi@raspberrypi:/opt/iobroker/log $ cd /opt/iobroker
                        pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@4.0.23 --ignore-scripts
                        + iobroker.js-controller@4.0.23
                        added 6 packages from 10 contributors and removed 3 packages in 156.871s
                        87 packages are looking for funding
                          run `npm fund` for details
                        pi@raspberrypi:/opt/iobroker $ cd
                        pi@raspberrypi:~ $ iob status
                        pi@raspberrypi:~ $ iob update
                        pi@raspberrypi:~ $ npm fund
                        /home/pi
                           │      New major version of npm available! 6.14.17 → 8.13.2      │
                           │   Changelog: https://github.com/npm/cli/releases/tag/v8.13.2   │
                           │               Run npm install -g npm to update!                │
                        pi@raspberrypi:~ $
                        • D Dieter_P
                          @apollon77
                          /home/pi
                          pi@raspberrypi:~ $
                          #83
                          @dieter_p Dann bitte "Iob custom" aufrufen und die Ausgabe zeigen. kannst DU mit CTRL-C abbrechen. Und bitte auch zeigen was ein "iob start" im ioBroker log bringt
                            Dieter_P
                            #84
                            Iob custom
                            Danke. Der Befehl "custom" fehlt oder ich mach was falsch
                            pi@raspberrypi:~ $ iob custom
                            iobroker [command]
                            Commands:
                              iobroker setup                                               Setup ioBroker
                              iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                              iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                              iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                              iobroker info                                                Shows the host info
                              iobroker logs [<adapter>]                                    Monitor log
                              iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                              iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                              iobroker rebuild [<module>]                                  Rebuild all native modules or path
                              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                              iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                              iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                              iobroker update [<repositoryUrl>]                            Update repository and list adapters
                              iobroker upgrade                                             Upgrade management
                              iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                              iobroker object                                              Object management  [aliases: o]
                              iobroker state                                               State management  [aliases: s]
                              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                              iobroker list <type> [<filter>]                              List all entries, like objects
                              iobroker chmod <mode> <file>                                 Change file rights
                              iobroker chown <user> <group> <file>                         Change file ownership
                              iobroker touch <file>                                        Touch file
                              iobroker rm <file>                                           Remove file
                              iobroker file                                                File management
                              iobroker user                                                User commands
                              iobroker group                                               group management
                              iobroker host <hostname>                                     Set host to given hostname
                              iobroker set <adapter>.<instance>                            Change settings of adapter config
                              iobroker license <license.file or license.text>              Update license by given file
                              iobroker cert                                                Certificate management
                              iobroker clean <yes>                                         Clears all objects and states
                              iobroker backup                                              Create backup
                              iobroker restore <backup name or path>                       Restore a specified backup
                              iobroker validate <backup name or path>                      Validate a specified backup
                              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                              iobroker repo [<name>]                                       Show repo information
                              iobroker uuid                                                Show uuid of the installation  [aliases: id]
                              iobroker unsetup                                             Reset license, installation secret and language
                              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                              iobroker multihost                                           Multihost management
                              iobroker compact                                             compact group management
                              iobroker plugin                                              Plugin management
                              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                            Options:
                              --help  Show help  [boolean]
                            pi@raspberrypi:~ $ iob info
                            pi@raspberrypi:~ $ iob start
                            pi@raspberrypi:~ $
                            • D Dieter_P
                              Iob custom
                              iobroker [command]
                              Commands:
                              Options:
                              pi@raspberrypi:~ $
                              #85
                              @dieter_p
                              iobroker setup custom
                              D apollon77A 2 Antworten Letzte Antwort
                                @dieter_p
                                Dieter_P
                                #86
                                pi@raspberrypi:~ $ iobroker setup custom
                                Current configuration:
                                - Objects database:
                                  - Type: jsonl
                                  - Host/Unix Socket: 127.0.0.1
                                  - Port: 9001
                                - States database:
                                  - Type: jsonl
                                  - Port: 9000
                                - Data Directory: ../../iobroker-data/
                                Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
                                • D Dieter_P
                                  - Objects database:
                                    - Type: jsonl
                                    - Port: 9001
                                  - States database:
                                    - Type: jsonl
                                    - Port: 9000
                                  #87
                                  @dieter_p
                                  Und wie sieht ein Start im LogFile aus?
                                  Mit
                                  tail -f /opt/iobroker/log/iobroker.current.log
                                  in einer zweiten Session nachschauen.
                                    @dieter_p
                                    Mit
                                    Dieter_P
                                    #88
                                    Hab die MAC Adressen mal "angepasst" die sollten hier doch nichts zu beitragen, oder?
                                    2022-07-08 10:24:44.819  - info: host.raspberrypi iobroker _restart
                                    2022-07-08 10:24:53.399  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-07-08 10:24:53.424  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-07-08 10:24:53.427  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.3
                                    2022-07-08 10:24:53.429  - info: host.raspberrypi ip addresses: 192.168.0.38 2a02:908:13b7:xxxx:xxxx:4331:xxxxx:82ad fe80::xxx:b07e:xxxx:49ba 10.0.1.2
                                    2022-07-08 10:25:23.502  - error: host.raspberrypi No connection to databases possible, restart
                                    2022-07-08 10:25:23.559  - info: host.raspberrypi iobroker _restart
                                    • D Dieter_P
                                      #89
                                      @dieter_p
                                      Läuft das im Docker oder sowas?
                                        @dieter_p
                                        Dieter_P
                                        #90
                                        Nein ganz klassisch auf nem RPI2 nur mit SD-Karte und nem ZigbeeStick.
                                        Installiert über die Installationsanleitung aus der Doku hier.
                                          @dieter_p
                                          #91
                                          @thomas-braun ÄÄähhmm ja .. danke ...war zu spät gestern Abend am Handy. Sorry
