  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 579.7k Aufrufe 64 Beobachtet
  • M meerkat
    @hsteinme Anbei die Änderung unter Objekte und dann das Log, plus das was wieder gesetzt wurde
    Dann das Update vom adapter
    worx.0	2022-03-30 13:26:21.765	info	undefined is not a valid state value for id "worx.0.20193020910100031279.rawMqtt.weatherdata"
    worx.0	2022-03-30 13:26:21.665	debug	Test Status: 7
    worx.0	2022-03-30 13:26:21.664	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"13:26:20","dt":"30/03/2022","sc":{"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"p":0,"d":[["08:30",780,1],["08:30",720,0],["08:30",780,0],["09:30",780,1],["08:30",780,0],["08:30",780,0],["08:30",780,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["12:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[19,32,44,0],"mzv":[0,1,2,0,1,2,1,1,1,1],"rd":0,"sn":"20193020910100031279","al":{"lvl":0,"t":60},"tq":0,"modules":{"US":{"enabled":1},"DF":{"cut":1,"fh":1}}},"dat":{"mac":"98D86318CEA6","fw":3.26,"fwb":1,"bt":{"t":17.5,"v":19.36,"p":100,"nr":1144,"c":0,"m":0},"dmp":[1.2,4.4,351.2],"st":{"b":154893,"d":3122695,"wt":164618,"bl":170},"ls":7,"le":0,"lz":3,"rsi":-77,"lk":1,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":131,"l":131},"modules":{"US":{"stat":"ok"},"DF":{"stat":"ok"}}}}
    worx.0	2022-03-30 13:26:21.664	debug	Worxcloud MQTT get Message for mower Johnny 5 (20193020910100031279)
    worx.0	2022-03-30 13:25:55.958	debug	Onlinecheck: couldnt get data StatusCodeError: 401 - {"message":"Unauthorized","code":"401.000"}
    worx.0	2022-03-30 13:24:55.967	debug	Onlinecheck: couldnt get data StatusCodeError: 401 - {"message":"Unauthorized","code":"401.000"}
    worx.0	2022-03-30 13:23:55.967	debug	Onlinecheck: couldnt get data StatusCodeError: 401 - {"message":"Unauthorized","code":"401.000"}
    Und so sieht dann mein Objekt wieder aus
    hsteinmeH Offline
    hsteinmeH Offline
    hsteinme
    #481
    @meerkat Solange Du so sparsam mit Zitaten aus Deiner Logdatei umgehst, sehe ich wenig Chancen, Dein Problem hier untersuchen zu können.
    (1) Schalte mal probeweise "add raw data" und "enable weather data" in der Konfiguration Deiner worx Instanz aus. Bleiben jetzt Planänderungen erhalten?
    (2) Falls nein: In welcher Reihenfolge hast Du die Felder borderCut, startTime und workTime geändert? Für jede dieser Änderung müsste in der Logdatei eine Sequenz der folgenden Art stehen:
    • state change: ...
    • Mowing time change ...
    • Worxcloud MQTT sendMessage ...
    • test ...
    • Worxcloud MQTT get Message ...
    (3) Stell dann hier bitte folgendes vollständig ab:
    • diese 3 o.e. Sequenzen
    • alle worx Logeinträge zwischen diesen Sequenzen
    • alle worx Logeinträge in den zwei Minuten vor der ersten Sequenz
    M 2 Antworten Letzte Antwort
    • hsteinmeH hsteinme
      • state change: ...
      • test ...
      meerkat
      #482
      @hsteinme mache ich. Mehr war aber nicht protokolliert. Sonst hätte ich dir mehr gegeben
        • state change: ...
        • test ...
        meerkat
        schrieb am zuletzt editiert von meerkat
        #483
        @hsteinme Hi, habe dir mal ein Video 20220331-084451_qYEfoG8f.mp4 beigefügt.
        In der Instanz habe ich raw data und weather ausgeschaltet.
        worx.0 	2022-03-31 08:47:04.391	debug	Mower Johnny 5 (20193020910100031279) online status = true
        worx.0 	2022-03-31 08:46:09.369	debug	Test Status: 1
        worx.0 	2022-03-31 08:46:09.367	debug	GET MQTT DATA from API: {"cfg":{"lg":"it","id":0,"dt":"31/03/2022","tm":"08:40:25","rd":0,"sn":"20193020910100031279","mz":[19,32,44,0],"mzv":[0,1,2,0,1,2,1,1,1,1],"sc":{"p":0,"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"al":{"lvl":0,"t":60},"modules":{"US":{"enabled":1}}},"dat":{"mac":"98D86318CEA6","fw":3.26,"fwb":1,"lz":4,"rsi":-61,"lk":1,"dmp":[0.3,-2.9,132.5],"st":{"b":154969,"d":3124078,"wt":164694,"bl":170},"rain":{"s":0,"cnt":0},"bt":{"t":4.4,"v":19.52,"p":100,"nr":1145,"c":0,"m":1},"le":0,"ls":1,"act":1,"conn":"wifi","modules":{"DF":{"stat":"ok"},"US":{"stat":"ok"}}}}
        worx.0	2022-03-31 08:46:06.749	info	Autolock found! Create State : AutoLockTimer
        worx.0	2022-03-31 08:46:06.748	info	Autolock found! Create State : AutoLock
        worx.0	2022-03-31 08:46:06.683	info	OffLimits Module found! Create State : OLMSwitch_FastHoming
        worx.0	2022-03-31 08:46:06.679	info	OffLimits Module found! Create State : OLMSwitch_Cutting
        worx.0	2022-03-31 08:46:06.456	info	found torque control, create states...
        worx.0	2022-03-31 08:46:06.445	debug	Test Status: 1
        worx.0	2022-03-31 08:46:06.442	debug	GET MQTT DATA from API: {"cfg":{"id":1,"lg":"it","tm":"08:46:04","dt":"31/03/2022","sc":{"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[19,32,44,0],"mzv":[0,1,2,0,1,2,1,1,1,1],"rd":0,"sn":"20193020910100031279","al":{"lvl":0,"t":60},"tq":0,"modules":{"US":{"enabled":1},"DF":{"cut":1,"fh":1}}},"dat":{"mac":"98D86318CEA6","fw":3.26,"fwb":1,"bt":{"t":4.4,"v":19.5,"p":100,"nr":1145,"c":0,"m":1},"dmp":[0.3,-2.9,132.5],"st":{"b":154969,"d":3124078,"wt":164694,"bl":170},"ls":1,"le":0,"lz":4,"rsi":-61,"lk":1,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0},"modules":{"US":{"stat":"ok"},"DF":{"stat":"ok"}}}}
        worx.0	2022-03-31 08:46:06.433	debug	Worxcloud MQTT get Message for mower Johnny 5 (20193020910100031279)
        worx.0	2022-03-31 08:46:04.456	debug	Worxcloud MQTT subscribe to PRM100/98D86318CEA6/commandOut
        worx.0	2022-03-31 08:46:04.455	debug	Worxcloud MQTT connected to: a1optpg91s0ydf-ats.iot.eu-west-1.amazonaws.com
        worx.0	2022-03-31 08:46:04.363	info	found PartyModus, create states...
        worx.0	2022-03-31 08:46:04.361	info	found OneTimeShedule, create states...
        worx.0	2022-03-31 08:46:04.358	info	found DoubleShedule, create states...
        worx.0	2022-03-31 08:46:04.027	debug	2 Recieve User Devices: [{"id":288109,"product_id":52,"user_id":204067,"serial_number":"20193020910100031279","mac_address":"98D86318CEA6","name":"Johnny 5","locked":true,"firmware_version":3.26,"firmware_auto_upgrade":false,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":"ABBA","registered_at":"2019-06-04 00:00:00","online":true,"app_settings":null,"accessories":{"digital_fence":true,"ultrasonic":true},"features":{"provisionable":true,"wifi_pairing":"smartlink","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"lcd","input_type":"keyboard_arrow_keys","lock":true,"pin":true,"rain_delay":true,"chassis":"l_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_display"},"pending_radio_link_validation":null,"mqtt_topics":{"command_in":"PRM100/98D86318CEA6/commandIn","command_out":"PRM100/98D86318CEA6/commandOut"},"warranty_registered":true,"purchased_at":"2019-06-03 00:00:00","warranty_expires_at":"2022-06-03 00:00:00","setup_location":{"latitude":52.6601108,"longitude":8.7336641},"city":{"id":2817841,"country_id":276,"name":"Varrel","latitude":52.621498,"longitude":8.7331,"created_at":"2018-02-15 22:24:35","updated_at":"2018-02-15 22:24:35"},"time_zone":"Europe/Berlin","lawn_size":1500,"lawn_perimeter":170,"auto_schedule_settings":{"boost":0,"nutrition":null,"irrigation":true,"soil_type":"sand","grass_type":"mixed_species","exclusion_scheduler":{"exclude_nights":false,"days":[{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1230,"duration":210,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]}]}},"auto_schedule":false,"distance_covered":3124078,"mower_work_time":164694,"blade_work_time":154969,"blade_work_time_reset":114083,"blade_work_time_reset_at":"2021-06-07 20:01:06","battery_charge_cycles":1145,"battery_charge_cycles_reset":null,"battery_charge_cycles_reset_at":null,"messages_in":1439,"messages_out":82924,"raw_messages_in":15890,"raw_messages_out":82924,"created_at":"2019-01-22 07:15:04","updated_at":"2021-10-11 16:11:24"}]
        worx.0	2022-03-31 08:46:03.750	debug	1 Recieve User Certificate
        worx.0	2022-03-31 08:46:03.460	debug	0 Recieve MqttServer Endpoint: a1optpg91s0ydf-ats.iot.eu-west-1.amazonaws.com
        worx.0	2022-03-31 08:46:03.237	debug	Sucess connect to Worx Server!
        worx.0	2022-03-31 08:46:01.999	debug	Connect to worx....
        worx.0	2022-03-31 08:46:01.998	info	worx is selected
        worx.0	2022-03-31 08:46:01.943	info	starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.worx, node: v14.19.1, js-controller: 4.0.15
        worx.0	2022-03-31 08:46:01.257	debug	Plugin sentry Initialize Plugin (enabled=true)
        worx.0	2022-03-31 08:45:53.974	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        worx.0	2022-03-31 08:45:53.973	debug	Plugin sentry destroyed
        worx.0	2022-03-31 08:45:53.970	info	terminating
        worx.0	2022-03-31 08:45:53.966	info	cleaned everything up...
        worx.0	2022-03-31 08:45:53.963	info	Got terminate signal TERMINATE_YOURSELF
        worx.0	2022-03-31 08:45:18.516	debug	Mower Johnny 5 (20193020910100031279) online status = true
        worx.0	2022-03-31 08:44:18.475	debug	Mower Johnny 5 (20193020910100031279) online status = true
        worx.0	2022-03-31 08:43:18.536	debug	Mower Johnny 5 (20193020910100031279) online status = true
        worx.0	2022-03-31 08:42:18.567	debug	Mower Johnny 5 (20193020910100031279) online status = true
        worx.0	2022-03-31 08:41:18.499	debug	Mower Johnny 5 (20193020910100031279) online status = true
        Was mir auffällt, es werden keine Einträge gesendet
        hsteinmeH 1 Antwort Letzte Antwort
        • M meerkat
          hsteinmeH Offline
          hsteinmeH Offline
          hsteinme
          #484
          @meerkat sagte in Adapter: Worx Landroid:
          Das war eine gute Idee!
          Dann sag mir mal, was im Log Neues steht, wenn Du bei der Feldänderung NICHT das Häkchen für Bestätigt anklickst 😄
            meerkat
            #485
            @hsteinme Danke. Und schon funktioniert es 😠 . Dann baue ich mein Script auch entsprechend um.
            • M meerkat
              hsteinmeH Offline
              hsteinmeH Offline
              hsteinme
              #486
              @meerkat
              Grundsätzlich kannst Du Datenpunkte mit zweierlei verschiedenen Zielsetzungen befüllen:
              • mit gesetztem Bestätigt-Flag: Damit aktualisierst Du lediglich den Wert im Feld (im Sinne eines Status).
              • ohne gesetztes Bestätigt-Flag: Dann wird der Wert als ein Auftrag verstanden, der gegenüber dem zugehörigen Gerät auszuführen ist. In diesem Fall sendet das Gerät nach Erledigung den Wert zurück - mit gesetztem Bestätigt-Flag.
              Nur im zweiten Fall sieht sich ein Adapter in der Pflicht, den Datenpunkt zum Gerät zu senden.
              • M muro82
                Hi hab den Api zum laufen gebracht versuche den Status des Landi in Grafana nicht als Zahl sonder als Text anzuzeigen bis jetzt hab ich es nicht hinbekommen.
                "0": "IDLE",
                "1": "Home",
                "2": "Start sequence",
                "3": "Leaving home",
                "4": "Follow wire",
                "5": "Searching home",
                "6": "Searching wire",
                Falls jemand das schon hat wäre ich dankbar um Unterstützung
                Gruß Danke
                crunchipC Abwesend
                crunchipC Abwesend
                #487
                @muro82 https://grafana.com/docs/grafana/latest/panels/format-data/about-value-mapping/
                • crunchipC Abwesend
                  crunchipC Abwesend
                  #488
                  hat jemand schon das update von gemacht? Bei mir ging das eben in die Hose, iob nicht mehr ansprechbar.
                  @apollon77 seh auf git das du gerade daran arbeitest
                    #489
                    @crunchip Bitte 1.6.1 versuchen (und was heisst "nicht ansprechbar)?
                    • apollon77A apollon77
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #490
                      @apollon77 no connection to database, drehender kreisel, hat mir das ganze log zugeballert
                      2022-06-17 11:42:29.981  - info: host.IoBroker iobroker Update worx from @1.5.5 to @1.6.0
                      2022-06-17 11:42:30.431  - info: host.IoBroker iobroker NPM version: 6.14.17Installing iobroker.worx@1.6.0... (System call)
                      2022-06-17 11:43:25.232  - info: host.IoBroker iobroker > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                      2022-06-17 11:43:27.113  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings/build“ wird betreten
                      2022-06-17 11:43:27.124  - info: host.IoBroker iobroker   CXX(target) Release/obj.target/bindings/src/serialport.o
                      2022-06-17 11:43:28.484  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings/build“ wird verlassen
                      2022-06-17 11:43:28.503  - info: host.IoBroker iobroker > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                      2022-06-17 11:43:29.913  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings/build“ wird betreten
                      2022-06-17 11:43:29.915  - info: host.IoBroker iobroker   CXX(target) Release/obj.target/bindings/src/serialport.o
                      2022-06-17 11:43:31.391  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings/build“ wird verlassen
                      2022-06-17 11:43:36.567  - info: host.IoBroker iobroker + iobroker.worx@1.6.0added 17 packages from 31 contributors and updated 2 packages in 65.133s
                      2022-06-17 11:43:41.735  - info: host.IoBroker iobroker 187 packages are looking for funding
                      2022-06-17 11:43:41.737  - info: host.IoBroker iobroker   run `npm fund` for details
                      2022-06-17 11:43:41.965  - info: host.IoBroker iobroker Update "system.adapter.worx.0"
                      2022-06-17 11:43:41.994  - info: host.IoBroker stopInstance system.adapter.worx.0 (force=false, process=true)
                      2022-06-17 11:43:42.021  - info: host.IoBroker stopInstance system.adapter.worx.0 send kill signal
                      2022-06-17 11:43:42.041  - info: host.IoBroker iobroker upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                      2022-06-17 11:43:42.533  - info: host.IoBroker iobroker upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/style.css style.css text/css
                      2022-06-17 11:43:42.554  - info: host.IoBroker iobroker upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/words.js words.js application/javascript
                      2022-06-17 11:43:42.627  - info: host.IoBroker iobroker upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                      2022-06-17 11:43:42.639  - info: host.IoBroker iobroker upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx_ada2.png worx_ada2.png image/png
                      2022-06-17 11:43:42.874  - info: host.IoBroker instance system.adapter.worx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-06-17 11:43:43.923  - info: host.IoBroker iobroker exit 0
                      2022-06-17 11:43:45.616  - info: host.IoBroker instance system.adapter.worx.0 started with pid 1795320
                      2022-06-17 11:43:53.012  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.connect is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:43:53.015  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      2022-06-17 11:43:53.017  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.found is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:43:53.017  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      2022-06-17 11:43:53.018  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.mqtt is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:43:53.019  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      2022-06-17 11:43:53.020  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.online is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:43:53.020  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      2022-06-17 11:43:53.021  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.offline is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:43:53.022  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      .geht so endlos weiter
                      2022-06-17 11:44:38.570  - error: worx.0 (1795320) Error: Invalid ID: worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.pluginHandler.settings.parentPackage.files.admin{,/!(src)/**}/!(tsconfig|tsconfig.*).json
                      2022-06-17 11:44:38.571  - error: worx.0 (1795320) Error: Invalid ID: worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.pluginHandler.settings.parentPackage.files.admin{,/!(src)/**}/*.{html,css,png,svg,jpg,js}
                      2022-06-17 11:44:55.339  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._events.prefinish is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:44:55.340  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      2022-06-17 11:44:55.340  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._events.error is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:44:55.341  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      2022-06-17 11:44:55.341  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._writableState.onwrite is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:44:55.342  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      2022-06-17 11:44:55.342  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._transformState.afterTransform is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                      2022-06-17 11:44:55.343  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                      hab dann versucht den Adapter zu stoppen
                       iob stop worx
                       Connection is closed.
                      Uncaught Rejection: Error: States DB is not allowed to start in the current Mult        ihost environment
                          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/l        ib/states/statesInRedisClient.js:579:23)
                          at processTicksAndRejections (internal/process/task_queues.js:95:5)
                       Unable to subscribe to expiry Keyspace events from Redis Server: Connection is        closed.
                       Unable to subscribe to evicted Keyspace events from Redis Server: Connection is        closed.
                       Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                      root@IoBroker:~# iob list instances
                       Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
                      Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
                      root@IoBroker:~#
                      dann die VM neu gestartet, iob startete aber nicht mehr, iob status zeigte irgendwas von lua script an, hab die Meldung aber nimmer, da ich das von der Proxmox Konsole aus aufgerufen hatte .
                      letztendlich Backup zurück gespielt
                      ich habe weder redis noch multihost
                         iob stop worx
                        root@IoBroker:~#
                        #491
                        @crunchip Ja... sind schon dran .... stay tuned for 1.6.2
                        • apollon77A Offline
                          #492
                          1.6.2 bitte nutzen ... Repo update kommt 14 Uhr eh
                          crunchipC L 2 Antworten Letzte Antwort
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #493
                            @apollon77 ich teste gleich
                            Install verlief problemlos👍
                              lessthanmore
                              schrieb am zuletzt editiert von lessthanmore
                              #494
                              @apollon77 Danke. Läuft bislang.
                              Ich habe gesehen, dass der Issue bzgl. Wetter geschlossen wurde. Bei wird weiterhin jeder Datenpunkt mit (null) "bewertet". Übersehe ich hier etwas?
                              worx.0 2022-06-17 16:03:04.500	debug	Error while get Weather: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"}
                              Danke vorab.
                              Hat sich glaube ich schon erledigt. Glaube das geht/ ging nur mit den "älteren" Modellen.
                              • L lessthanmore
                                Danke vorab.
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #495
                                @lessthanmore ich glaube es wurde entfernt egal welcher mover.. ich hatte es gehabt.. jetzt steht da wie bei dir null.. ergo die Daten werden nicht gesendet..vom Mover
                                • L Online
                                  L Online
                                  Lucky_ESA
                                  #496
                                  ist es eigentlich angedacht den Adapter um einige Funktionen zu erweitern wie z. Bsp. das Aktivitätenprotokoll? Würde mir das gerne in VIS und IQontrol ausgeben lassen.
                                  Gruß//Lucky
                                  • L Lucky_ESA
                                    Gruß//Lucky
                                    hsteinmeH Offline
                                    hsteinmeH Offline
                                    hsteinme
                                    #497
                                    @lucky_esa Das Aktivitätenprotokoll ist kein Teil des Datenverkehrs zwischen Adapter und Cloud/Mäher. Also kann der Adapter sich diese Infomationen nicht abholen.
                                    Falls Dir dieser Punkt aber wichtig ist, kannst Du Dir selbst eine Lösung "basteln", in dem Du per Skript die status und error Datenpunkte überwachst und bei besonderen Ereignissen diese in einen eigenen Datenpunkt schreibst, den Du dann mit Deiner Visualisierung abgreifen kannst.
                                    L 1 Antwort Letzte Antwort
                                      L Online
                                      L Online
                                      Lucky_ESA
                                      #498
                                      @hsteinme sagte in Adapter: Worx Landroid:
                                      Hi hsteinme, das kann ich leider nicht bestätigen. Wenn man 2 Handys hat und dort Änderungen vornimmt, dann werden die Daten über die Cloud übermittelt.
                                      Habe den Adapter bereits angepasst und das wären die Daten:
                                      {"_id":"a5255e83-8a9a-4ccc-8e73-40c9c0fcd372","timestamp":"2022-07-01 16:08:47","product_item_id":576622,"payload":{"cfg":{"tm":"18:08:48","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"6854c326-062f-46d7-a4a8-f5243dffdd2c","timestamp":"2022-07-01 15:03:56","product_item_id":576622,"payload":{"cfg":{"tm":"17:03:56","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"a881e7db-65b8-4d82-af9a-66c2fe2a0411","timestamp":"2022-07-01 15:00:06","product_item_id":576622,"payload":{"cfg":{"tm":"17:00:06","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"aef0a320-b98c-4445-a66d-5009bdf6a039","timestamp":"2022-07-01 13:30:30","product_item_id":576622,"payload":{"cfg":{"tm":"15:30:30","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"58a00596-4582-405d-a20c-18d1c91f30b2","timestamp":"2022-07-01 11:44:18","product_item_id":576622,"payload":{"cfg":{"tm":"13:44:18","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"79122829-32c2-4cc4-b6aa-073288790498","timestamp":"2022-07-01 10:29:19","product_item_id":576622,"payload":{"cfg":{"tm":"12:29:18","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"e465930e-ee5e-4413-9c15-250415ddd17c","timestamp":"2022-07-01 10:26:58","product_item_id":576622,"payload":{"cfg":{"tm":"12:26:58","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"e1f9b40a-6b18-4b67-8fa9-9cfd1220043b","timestamp":"2022-07-01 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"992e775b-1871-4a9c-9492-8eb9173bfb36","timestamp":"2022-06-30 10:32:10","product_item_id":576622,"payload":{"cfg":{"tm":"12:32:10","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"c8886c6b-75bd-4313-8331-4d6f947bbe56","timestamp":"2022-06-30 10:02:32","product_item_id":576622,"payload":{"cfg":{"tm":"12:02:33","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"cd9e7576-9b39-453e-8b8b-32024f17b5d6","timestamp":"2022-06-30 10:00:12","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:12","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"305ca311-9b3f-418a-a705-9ad9dd8a6780","timestamp":"2022-06-30 09:50:54","product_item_id":576622,"payload":{"cfg":{"tm":"11:50:54","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"9dfb5c42-ea4a-4f63-b1e4-7495250876c2","timestamp":"2022-06-30 09:38:27","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:27","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":32,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"df656351-4a20-45ba-aa43-1c352a52a375","timestamp":"2022-06-30 09:38:24","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:24","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":3,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"7f379719-2724-47d8-a189-20fe45ede06f","timestamp":"2022-06-30 09:37:52","product_item_id":576622,"payload":{"cfg":{"tm":"11:37:52","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"14ceaf6e-c5f8-4df6-bdcd-2a58d58cbdcd","timestamp":"2022-06-30 02:57:50","product_item_id":576622,"payload":{"cfg":{"tm":"04:57:50","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"2cc10579-c7ef-44de-906b-2956c92fea7e","timestamp":"2022-06-29 10:54:04","product_item_id":576622,"payload":{"cfg":{"tm":"12:54:05","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"3e5ad39e-a316-48b8-92df-b4a219fe1c31","timestamp":"2022-06-29 10:04:07","product_item_id":576622,"payload":{"cfg":{"tm":"12:04:08","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"7d2baaaf-a7ba-4854-996f-ffc5b8e50a7c","timestamp":"2022-06-29 10:00:23","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:23","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"2caf68ad-894d-4d2f-b605-1097f79ab149","timestamp":"2022-06-29 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"8c9f200c-f46d-4b49-ae2b-d55e73ce8f97","timestamp":"2022-06-28 11:01:02","product_item_id":576622,"payload":{"cfg":{"tm":"13:01:02","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"1bf374d3-4660-4560-9169-a1ff26e94f7d","timestamp":"2022-06-28 10:00:45","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:45","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"ced74ed2-0dc8-4e4a-837f-100b802eaa44","timestamp":"2022-06-28 10:00:25","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:24","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"c7373178-024f-4510-b23d-4f9fae1958c2","timestamp":"2022-06-28 09:00:39","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:38","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"9cc88327-1a23-4181-8489-18e07f51a741","timestamp":"2022-06-28 09:00:08","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:08","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"8969f118-52c8-4d5a-a22c-18ee254fa86b","timestamp":"2022-06-28 00:00:07","product_item_id":576622,"payload":{"cfg":{"tm":"02:00:06","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"14037c67-e340-4297-a069-a4b859fd6ee7","timestamp":"2022-06-27 10:51:54","product_item_id":576622,"payload":{"cfg":{"tm":"12:51:55","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"04e072e4-c218-4ff2-920c-93c5cfa47907","timestamp":"2022-06-27 10:00:23","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:24","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"9e13685b-92cb-47e9-82d4-0265ee313a02","timestamp":"2022-06-27 10:00:01","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:02","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"b7e32262-1835-4e7a-b621-fbb3dc05e1a3","timestamp":"2022-06-27 09:09:22","product_item_id":576622,"payload":{"cfg":{"tm":"11:09:23","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"517d3ba4-b9c0-4f98-91d4-ca8bcc05b1f4","timestamp":"2022-06-27 09:00:35","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:36","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":32,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"8e0b38ae-b52f-4542-a38f-cd46d317f9db","timestamp":"2022-06-27 09:00:32","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:32","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":3,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"82c7a2c4-7cf2-4771-9a44-c28f490a7370","timestamp":"2022-06-27 05:03:17","product_item_id":576622,"payload":{"cfg":{"tm":"07:03:18","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"fbae575c-c178-4f99-b6be-065263c9bec5","timestamp":"2022-06-27 01:43:17","product_item_id":576622,"payload":{"cfg":{"tm":"03:43:17","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"e94b47f0-1cfc-41db-bbb4-2e55156a1651","timestamp":"2022-06-26 07:47:48","product_item_id":576622,"payload":{"cfg":{"tm":"09:47:47","dt":"26/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"00ebe528-921b-46aa-8ee0-8ac3e9709d66","timestamp":"2022-06-26 02:27:47","product_item_id":576622,"payload":{"cfg":{"tm":"04:27:46","dt":"26/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"b8fee210-a87a-44eb-96e8-3e249b21e8bf","timestamp":"2022-06-25 15:03:30","product_item_id":576622,"payload":{"cfg":{"tm":"17:03:29","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"1aea3fa0-1733-4ecc-a605-13a5eec8a696","timestamp":"2022-06-25 14:01:04","product_item_id":576622,"payload":{"cfg":{"tm":"16:01:02","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"ed227710-e61c-45b0-8492-f572b9ad71ac","timestamp":"2022-06-25 14:00:12","product_item_id":576622,"payload":{"cfg":{"tm":"16:00:10","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"5278aa0a-8bac-4058-a6b5-3f3210920a86","timestamp":"2022-06-25 12:30:33","product_item_id":576622,"payload":{"cfg":{"tm":"14:30:33","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"93353540-d365-4fb5-99b7-b02b6a7d7605","timestamp":"2022-06-25 11:34:08","product_item_id":576622,"payload":{"cfg":{"tm":"13:34:08","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                      {"_id":"90d68100-854b-4564-addd-021683c3fb53","timestamp":"2022-06-25 10:21:25","product_item_id":576622,"payload":{"cfg":{"tm":"12:21:26","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"f74b5396-690c-4569-ba84-74882b44677c","timestamp":"2022-06-25 10:18:36","product_item_id":576622,"payload":{"cfg":{"tm":"12:18:36","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"f963c67b-d9a8-4ee3-b9c3-b2cba98a55d3","timestamp":"2022-06-25 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:31","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"56b7b10c-bb1a-4321-932b-f0a8ac5f682e","timestamp":"2022-06-25 08:53:48","product_item_id":576622,"payload":{"cfg":{"tm":"10:53:47","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"085d9439-7555-4509-a3e6-c0f57bbd1f79","timestamp":"2022-06-24 20:33:45","product_item_id":576622,"payload":{"cfg":{"tm":"22:33:47","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"eb152b8f-f825-463a-8201-19651bdcc5cb","timestamp":"2022-06-24 20:26:25","product_item_id":576622,"payload":{"cfg":{"tm":"22:26:27","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"9c0584ae-964c-4d7b-a040-3c8aed571f49","timestamp":"2022-06-24 17:16:25","product_item_id":576622,"payload":{"cfg":{"tm":"19:16:26","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"87bdda49-c482-4660-9ab1-8d7ff9fd6e6d","timestamp":"2022-06-24 14:58:54","product_item_id":576622,"payload":{"cfg":{"tm":"16:58:55","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"5433a492-d4d5-4b88-b6b7-981d6971dc39","timestamp":"2022-06-24 14:58:24","product_item_id":576622,"payload":{"cfg":{"tm":"16:58:25","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"3eceaa5c-99e3-406f-883c-aef9c0a0dd3e","timestamp":"2022-06-24 09:38:34","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:35","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":6,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"8fe27c11-2561-4ca1-8072-d4093435a253","timestamp":"2022-06-23 10:00:29","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:29","dt":"23/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"5888af81-e06a-4dfd-9aa5-5e359530c416","timestamp":"2022-06-23 09:10:14","product_item_id":576622,"payload":{"cfg":{"tm":"11:10:15","dt":"23/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                      {"_id":"9fe6db9e-04c2-49a1-ae27-0b52d313681f","timestamp":"2022-06-21 10:01:12","product_item_id":576622,"payload":{"cfg":{"tm":"12:01:13","dt":"21/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                      {"_id":"0fda7fad-5614-491b-9681-e10ea67a6521","timestamp":"2022-06-17 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"17/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}}
                                      Ich muss mir mal überlegen wie ich die als DP anlege. Fängt schon damit an, dass ich nicht weiß ob die Anzahl an Events auf 55 beschränkt ist. Hinzu kommt das der Timestamp 2 Std. vor tm liegt...Komisch, ob das bei jedem so ist...
                                      Gruß//Lucky
                                      • L Lucky_ESA
                                        Gruß//Lucky
                                        hsteinmeH Offline
                                        hsteinmeH Offline
                                        hsteinme
                                        schrieb am zuletzt editiert von hsteinme
                                        #499
                                        @lucky_esa Hier reden wir wohl ein klein wenig aneinander vorbei. Bei Aktivitätenprotokoll denke ich an eine "zusammengedampfte" und knapp aufbereitete Form der Informationen zum Mäherzustand über einen gewissen Zeitraum hinweg. Diese zusammengedampfte Form, wie sie in der App dargestellt wird, sehe ich nicht im Datenstream zwischen Adapter und Cloud/Mäher.
                                        Was Du abgerufen und oben zitiert hast sind historische Rohdaten, die einen Teil der Daten darstellen, die eh schon zwischen Cloud/Mäher und Adapter ausgetauscht worden sind. Das "Eindampfen" der Daten müsste also noch vom Adapter durchgeführt werden.
                                        Zu Deiner Frage nach der Datenpunkt-Darstellung. Hier sollte zunächst geklärt werden, welche der gelieferten Daten überhaupt dargestellt werden sollen. Diese Daten alle dem Adapter-Anwender anzubieten, bietet diesem nur einen geringen Mehrwert.
                                        Wenn ich mir die App-Darstellung so ansehe, so sehe ich im wesentlichen drei Felder:
                                        • Ereignis
                                        • Kennzeichen Information oder Fehler
                                        • Zeitstempel
                                        Aufgabe des Adapters wäre es nun, das Ereignis aus den Feldern Deiner obigen Darstellung heraus zu ziehen, In den meisen Fällen wären dies wohl dat.ls und dat.le. Ob noch andere in Frage kommen, müsste man duch Vergleichen mit der App-Darstellung herausfinden.
                                        Als Datenpunkt könnte man ähnlich wie calendar.calJson ein Array von Arrays verwenden. In den inneren Arrays könnten als Elemente stehen:
                                        • Text für Ereignis
                                        • Zahlen 0/1 für Info/Error (oder Zeichen I/E)
                                        • Text für Zeitstempel.
                                        Hier müsste noch die Zeitzonenfrage geklärt werden. Vielleicht kann man sich an rawMqtt.raw.created_at dabei orientieren.
                                          • Ereignis
                                          • Zeitstempel
                                          • Text für Ereignis
                                          L Online
                                          L Online
                                          Lucky_ESA
                                          schrieb am zuletzt editiert von Lucky_ESA
                                          #500
                                          @hsteinme Vielen Dank für deine ausführliche Erklärung. Wie bei anderen Adapter bin ich mal wieder der einzige, der alles über den iobroker steuern möchte. Habe den Adapter so angepasst, dass der JSON vom Aktivitätensprotokoll in einem DB geschrieben wird. Diese Daten bearbeite ich dann per Blockly. Habe nun auch angefangen per put request alle RAW Daten an die Cloud zu übergeben. Kann jetzt eigentlich alles per IOBroker ändern. Habe allerdings noch keine Ahnung was ich für das zurücksetzen von Klingen-Arbeitszeit und Ladungen versenden muss. Habe da noch keine Werte von blade_work_time_reset_at, mal schauen ob ich hier im Forum einen Beitrag finden, wo ein Wert hinterlegt ist. Es ist für mich immer ein riesen Aufwand wenn es ein Update gibt, da ich dann den Adapter immer neu anpassen muss....Vielleicht überwinde ich mich irgendwann einen Pullrequest zu erstellen. Aber mein letzter mit dem ACS Modul wurde wochenlang nicht bearbeitet...
                                          Edit:
                                          P.S. Leider wurde die extractKeys.js abgeändert und daher werden die Datenpunkte nicht mehr chronologisch angelegt. Hat gestern dazu geführt, dass mein iobroker abgestürtzt ist und das weit über 100 Error Meldungen per sentry raus sind. Aber egal, muss dann auch diese Datei nach einem Update austauschen.
                                          Gruß//Lucky
