  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 579.0k Aufrufe 64 Beobachtet
  • hsteinmeH hsteinme
    @meerkat Setze bitte den Loglevel des Adapters auf Debug, wiederhole das Setzen der Zeiten und poste hier die zeitlich dazu passenden Logdatei-Zeilen. Dann sehen wir mal weiter.
    meerkat
    #480
    @hsteinme Anbei die Änderung unter Objekte und dann das Log, plus das was wieder gesetzt wurde
    Dann das Update vom adapter
    worx.0	2022-03-30 13:26:21.765	info	undefined is not a valid state value for id "worx.0.20193020910100031279.rawMqtt.weatherdata"
    worx.0	2022-03-30 13:26:21.665	debug	Test Status: 7
    worx.0	2022-03-30 13:26:21.664	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"13:26:20","dt":"30/03/2022","sc":{"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"p":0,"d":[["08:30",780,1],["08:30",720,0],["08:30",780,0],["09:30",780,1],["08:30",780,0],["08:30",780,0],["08:30",780,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["12:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[19,32,44,0],"mzv":[0,1,2,0,1,2,1,1,1,1],"rd":0,"sn":"20193020910100031279","al":{"lvl":0,"t":60},"tq":0,"modules":{"US":{"enabled":1},"DF":{"cut":1,"fh":1}}},"dat":{"mac":"98D86318CEA6","fw":3.26,"fwb":1,"bt":{"t":17.5,"v":19.36,"p":100,"nr":1144,"c":0,"m":0},"dmp":[1.2,4.4,351.2],"st":{"b":154893,"d":3122695,"wt":164618,"bl":170},"ls":7,"le":0,"lz":3,"rsi":-77,"lk":1,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":131,"l":131},"modules":{"US":{"stat":"ok"},"DF":{"stat":"ok"}}}}
    worx.0	2022-03-30 13:26:21.664	debug	Worxcloud MQTT get Message for mower Johnny 5 (20193020910100031279)
    worx.0	2022-03-30 13:25:55.958	debug	Onlinecheck: couldnt get data StatusCodeError: 401 - {"message":"Unauthorized","code":"401.000"}
    worx.0	2022-03-30 13:24:55.967	debug	Onlinecheck: couldnt get data StatusCodeError: 401 - {"message":"Unauthorized","code":"401.000"}
    worx.0	2022-03-30 13:23:55.967	debug	Onlinecheck: couldnt get data StatusCodeError: 401 - {"message":"Unauthorized","code":"401.000"}
    Und so sieht dann mein Objekt wieder aus
    hsteinmeH 1 Antwort Letzte Antwort
    • M meerkat
      hsteinmeH Offline
      hsteinmeH Offline
      hsteinme
      #481
      @meerkat Solange Du so sparsam mit Zitaten aus Deiner Logdatei umgehst, sehe ich wenig Chancen, Dein Problem hier untersuchen zu können.
      (1) Schalte mal probeweise "add raw data" und "enable weather data" in der Konfiguration Deiner worx Instanz aus. Bleiben jetzt Planänderungen erhalten?
      (2) Falls nein: In welcher Reihenfolge hast Du die Felder borderCut, startTime und workTime geändert? Für jede dieser Änderung müsste in der Logdatei eine Sequenz der folgenden Art stehen:
      • state change: ...
      • Mowing time change ...
      • Worxcloud MQTT sendMessage ...
      • test ...
      • Worxcloud MQTT get Message ...
      (3) Stell dann hier bitte folgendes vollständig ab:
      • diese 3 o.e. Sequenzen
      • alle worx Logeinträge zwischen diesen Sequenzen
      • alle worx Logeinträge in den zwei Minuten vor der ersten Sequenz
      M 2 Antworten Letzte Antwort
        • state change: ...
        • test ...
        meerkat
        #482
        @hsteinme mache ich. Mehr war aber nicht protokolliert. Sonst hätte ich dir mehr gegeben
          • state change: ...
          • test ...
          meerkat
          schrieb am zuletzt editiert von meerkat
          #483
          @hsteinme Hi, habe dir mal ein Video 20220331-084451_qYEfoG8f.mp4 beigefügt.
          In der Instanz habe ich raw data und weather ausgeschaltet.
          worx.0 	2022-03-31 08:47:04.391	debug	Mower Johnny 5 (20193020910100031279) online status = true
          worx.0 	2022-03-31 08:46:09.369	debug	Test Status: 1
          worx.0 	2022-03-31 08:46:09.367	debug	GET MQTT DATA from API: {"cfg":{"lg":"it","id":0,"dt":"31/03/2022","tm":"08:40:25","rd":0,"sn":"20193020910100031279","mz":[19,32,44,0],"mzv":[0,1,2,0,1,2,1,1,1,1],"sc":{"p":0,"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"al":{"lvl":0,"t":60},"modules":{"US":{"enabled":1}}},"dat":{"mac":"98D86318CEA6","fw":3.26,"fwb":1,"lz":4,"rsi":-61,"lk":1,"dmp":[0.3,-2.9,132.5],"st":{"b":154969,"d":3124078,"wt":164694,"bl":170},"rain":{"s":0,"cnt":0},"bt":{"t":4.4,"v":19.52,"p":100,"nr":1145,"c":0,"m":1},"le":0,"ls":1,"act":1,"conn":"wifi","modules":{"DF":{"stat":"ok"},"US":{"stat":"ok"}}}}
          worx.0	2022-03-31 08:46:06.749	info	Autolock found! Create State : AutoLockTimer
          worx.0	2022-03-31 08:46:06.748	info	Autolock found! Create State : AutoLock
          worx.0	2022-03-31 08:46:06.683	info	OffLimits Module found! Create State : OLMSwitch_FastHoming
          worx.0	2022-03-31 08:46:06.679	info	OffLimits Module found! Create State : OLMSwitch_Cutting
          worx.0	2022-03-31 08:46:06.456	info	found torque control, create states...
          worx.0	2022-03-31 08:46:06.445	debug	Test Status: 1
          worx.0	2022-03-31 08:46:06.442	debug	GET MQTT DATA from API: {"cfg":{"id":1,"lg":"it","tm":"08:46:04","dt":"31/03/2022","sc":{"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[19,32,44,0],"mzv":[0,1,2,0,1,2,1,1,1,1],"rd":0,"sn":"20193020910100031279","al":{"lvl":0,"t":60},"tq":0,"modules":{"US":{"enabled":1},"DF":{"cut":1,"fh":1}}},"dat":{"mac":"98D86318CEA6","fw":3.26,"fwb":1,"bt":{"t":4.4,"v":19.5,"p":100,"nr":1145,"c":0,"m":1},"dmp":[0.3,-2.9,132.5],"st":{"b":154969,"d":3124078,"wt":164694,"bl":170},"ls":1,"le":0,"lz":4,"rsi":-61,"lk":1,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0},"modules":{"US":{"stat":"ok"},"DF":{"stat":"ok"}}}}
          worx.0	2022-03-31 08:46:06.433	debug	Worxcloud MQTT get Message for mower Johnny 5 (20193020910100031279)
          worx.0	2022-03-31 08:46:04.456	debug	Worxcloud MQTT subscribe to PRM100/98D86318CEA6/commandOut
          worx.0	2022-03-31 08:46:04.455	debug	Worxcloud MQTT connected to: a1optpg91s0ydf-ats.iot.eu-west-1.amazonaws.com
          worx.0	2022-03-31 08:46:04.363	info	found PartyModus, create states...
          worx.0	2022-03-31 08:46:04.361	info	found OneTimeShedule, create states...
          worx.0	2022-03-31 08:46:04.358	info	found DoubleShedule, create states...
          worx.0	2022-03-31 08:46:04.027	debug	2 Recieve User Devices: [{"id":288109,"product_id":52,"user_id":204067,"serial_number":"20193020910100031279","mac_address":"98D86318CEA6","name":"Johnny 5","locked":true,"firmware_version":3.26,"firmware_auto_upgrade":false,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":"ABBA","registered_at":"2019-06-04 00:00:00","online":true,"app_settings":null,"accessories":{"digital_fence":true,"ultrasonic":true},"features":{"provisionable":true,"wifi_pairing":"smartlink","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"lcd","input_type":"keyboard_arrow_keys","lock":true,"pin":true,"rain_delay":true,"chassis":"l_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_display"},"pending_radio_link_validation":null,"mqtt_topics":{"command_in":"PRM100/98D86318CEA6/commandIn","command_out":"PRM100/98D86318CEA6/commandOut"},"warranty_registered":true,"purchased_at":"2019-06-03 00:00:00","warranty_expires_at":"2022-06-03 00:00:00","setup_location":{"latitude":52.6601108,"longitude":8.7336641},"city":{"id":2817841,"country_id":276,"name":"Varrel","latitude":52.621498,"longitude":8.7331,"created_at":"2018-02-15 22:24:35","updated_at":"2018-02-15 22:24:35"},"time_zone":"Europe/Berlin","lawn_size":1500,"lawn_perimeter":170,"auto_schedule_settings":{"boost":0,"nutrition":null,"irrigation":true,"soil_type":"sand","grass_type":"mixed_species","exclusion_scheduler":{"exclude_nights":false,"days":[{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1230,"duration":210,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]},{"exclude_day":false,"slots":[{"start_time":1290,"duration":150,"reason":"generic"},{"start_time":0,"duration":450,"reason":"generic"},{"start_time":1320,"duration":120,"reason":"irrigation"},{"start_time":0,"duration":390,"reason":"irrigation"}]}]}},"auto_schedule":false,"distance_covered":3124078,"mower_work_time":164694,"blade_work_time":154969,"blade_work_time_reset":114083,"blade_work_time_reset_at":"2021-06-07 20:01:06","battery_charge_cycles":1145,"battery_charge_cycles_reset":null,"battery_charge_cycles_reset_at":null,"messages_in":1439,"messages_out":82924,"raw_messages_in":15890,"raw_messages_out":82924,"created_at":"2019-01-22 07:15:04","updated_at":"2021-10-11 16:11:24"}]
          worx.0	2022-03-31 08:46:03.750	debug	1 Recieve User Certificate
          worx.0	2022-03-31 08:46:03.460	debug	0 Recieve MqttServer Endpoint: a1optpg91s0ydf-ats.iot.eu-west-1.amazonaws.com
          worx.0	2022-03-31 08:46:03.237	debug	Sucess connect to Worx Server!
          worx.0	2022-03-31 08:46:01.999	debug	Connect to worx....
          worx.0	2022-03-31 08:46:01.998	info	worx is selected
          worx.0	2022-03-31 08:46:01.943	info	starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.worx, node: v14.19.1, js-controller: 4.0.15
          worx.0	2022-03-31 08:46:01.257	debug	Plugin sentry Initialize Plugin (enabled=true)
          worx.0	2022-03-31 08:45:53.974	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          worx.0	2022-03-31 08:45:53.973	debug	Plugin sentry destroyed
          worx.0	2022-03-31 08:45:53.970	info	terminating
          worx.0	2022-03-31 08:45:53.966	info	cleaned everything up...
          worx.0	2022-03-31 08:45:53.963	info	Got terminate signal TERMINATE_YOURSELF
          worx.0	2022-03-31 08:45:18.516	debug	Mower Johnny 5 (20193020910100031279) online status = true
          worx.0	2022-03-31 08:44:18.475	debug	Mower Johnny 5 (20193020910100031279) online status = true
          worx.0	2022-03-31 08:43:18.536	debug	Mower Johnny 5 (20193020910100031279) online status = true
          worx.0	2022-03-31 08:42:18.567	debug	Mower Johnny 5 (20193020910100031279) online status = true
          worx.0	2022-03-31 08:41:18.499	debug	Mower Johnny 5 (20193020910100031279) online status = true
          Was mir auffällt, es werden keine Einträge gesendet
          • M meerkat
            hsteinmeH Offline
            hsteinmeH Offline
            hsteinme
            #484
            @meerkat sagte in Adapter: Worx Landroid:
            Das war eine gute Idee!
            Dann sag mir mal, was im Log Neues steht, wenn Du bei der Feldänderung NICHT das Häkchen für Bestätigt anklickst 😄
              meerkat
              #485
              @hsteinme Danke. Und schon funktioniert es 😠 . Dann baue ich mein Script auch entsprechend um.
              • M meerkat
                hsteinmeH Offline
                hsteinmeH Offline
                hsteinme
                #486
                @meerkat
                Grundsätzlich kannst Du Datenpunkte mit zweierlei verschiedenen Zielsetzungen befüllen:
                • mit gesetztem Bestätigt-Flag: Damit aktualisierst Du lediglich den Wert im Feld (im Sinne eines Status).
                • ohne gesetztes Bestätigt-Flag: Dann wird der Wert als ein Auftrag verstanden, der gegenüber dem zugehörigen Gerät auszuführen ist. In diesem Fall sendet das Gerät nach Erledigung den Wert zurück - mit gesetztem Bestätigt-Flag.
                Nur im zweiten Fall sieht sich ein Adapter in der Pflicht, den Datenpunkt zum Gerät zu senden.
                • M muro82
                  Hi hab den Api zum laufen gebracht versuche den Status des Landi in Grafana nicht als Zahl sonder als Text anzuzeigen bis jetzt hab ich es nicht hinbekommen.
                  "0": "IDLE",
                  "1": "Home",
                  "2": "Start sequence",
                  "3": "Leaving home",
                  "4": "Follow wire",
                  "5": "Searching home",
                  "6": "Searching wire",
                  Falls jemand das schon hat wäre ich dankbar um Unterstützung
                  Gruß Danke
                  crunchipC Offline
                  crunchipC Offline
                  #487
                  @muro82 https://grafana.com/docs/grafana/latest/panels/format-data/about-value-mapping/
                  • crunchipC Offline
                    crunchipC Offline
                    #488
                    hat jemand schon das update von gemacht? Bei mir ging das eben in die Hose, iob nicht mehr ansprechbar.
                    @apollon77 seh auf git das du gerade daran arbeitest
                      apollon77A Online
                      apollon77A Online
                      #489
                      @crunchip Bitte 1.6.1 versuchen (und was heisst "nicht ansprechbar)?
                      • apollon77A apollon77
                        crunchipC Offline
                        crunchipC Offline
                        #490
                        @apollon77 no connection to database, drehender kreisel, hat mir das ganze log zugeballert
                        2022-06-17 11:42:29.981  - info: host.IoBroker iobroker Update worx from @1.5.5 to @1.6.0
                        2022-06-17 11:42:30.431  - info: host.IoBroker iobroker NPM version: 6.14.17Installing iobroker.worx@1.6.0... (System call)
                        2022-06-17 11:43:25.232  - info: host.IoBroker iobroker > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                        2022-06-17 11:43:27.113  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings/build“ wird betreten
                        2022-06-17 11:43:27.124  - info: host.IoBroker iobroker   CXX(target) Release/obj.target/bindings/src/serialport.o
                        2022-06-17 11:43:28.484  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings/build“ wird verlassen
                        2022-06-17 11:43:28.503  - info: host.IoBroker iobroker > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                        2022-06-17 11:43:29.913  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings/build“ wird betreten
                        2022-06-17 11:43:29.915  - info: host.IoBroker iobroker   CXX(target) Release/obj.target/bindings/src/serialport.o
                        2022-06-17 11:43:31.391  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings/build“ wird verlassen
                        2022-06-17 11:43:36.567  - info: host.IoBroker iobroker + iobroker.worx@1.6.0added 17 packages from 31 contributors and updated 2 packages in 65.133s
                        2022-06-17 11:43:41.735  - info: host.IoBroker iobroker 187 packages are looking for funding
                        2022-06-17 11:43:41.737  - info: host.IoBroker iobroker   run `npm fund` for details
                        2022-06-17 11:43:41.965  - info: host.IoBroker iobroker Update "system.adapter.worx.0"
                        2022-06-17 11:43:41.994  - info: host.IoBroker stopInstance system.adapter.worx.0 (force=false, process=true)
                        2022-06-17 11:43:42.021  - info: host.IoBroker stopInstance system.adapter.worx.0 send kill signal
                        2022-06-17 11:43:42.041  - info: host.IoBroker iobroker upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                        2022-06-17 11:43:42.533  - info: host.IoBroker iobroker upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/style.css style.css text/css
                        2022-06-17 11:43:42.554  - info: host.IoBroker iobroker upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/words.js words.js application/javascript
                        2022-06-17 11:43:42.627  - info: host.IoBroker iobroker upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                        2022-06-17 11:43:42.639  - info: host.IoBroker iobroker upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx_ada2.png worx_ada2.png image/png
                        2022-06-17 11:43:42.874  - info: host.IoBroker instance system.adapter.worx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2022-06-17 11:43:43.923  - info: host.IoBroker iobroker exit 0
                        2022-06-17 11:43:45.616  - info: host.IoBroker instance system.adapter.worx.0 started with pid 1795320
                        2022-06-17 11:43:53.012  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.connect is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:43:53.015  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        2022-06-17 11:43:53.017  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.found is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:43:53.017  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        2022-06-17 11:43:53.018  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.mqtt is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:43:53.019  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        2022-06-17 11:43:53.020  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.online is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:43:53.020  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        2022-06-17 11:43:53.021  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.offline is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:43:53.022  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        .geht so endlos weiter
                        2022-06-17 11:44:38.570  - error: worx.0 (1795320) Error: Invalid ID: worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.pluginHandler.settings.parentPackage.files.admin{,/!(src)/**}/!(tsconfig|tsconfig.*).json
                        2022-06-17 11:44:38.571  - error: worx.0 (1795320) Error: Invalid ID: worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.pluginHandler.settings.parentPackage.files.admin{,/!(src)/**}/*.{html,css,png,svg,jpg,js}
                        2022-06-17 11:44:55.339  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._events.prefinish is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:44:55.340  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        2022-06-17 11:44:55.340  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._events.error is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:44:55.341  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        2022-06-17 11:44:55.341  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._writableState.onwrite is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:44:55.342  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        2022-06-17 11:44:55.342  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._transformState.afterTransform is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
                        2022-06-17 11:44:55.343  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
                        hab dann versucht den Adapter zu stoppen
                         iob stop worx
                         Connection is closed.
                        Uncaught Rejection: Error: States DB is not allowed to start in the current Mult        ihost environment
                            at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/l        ib/states/statesInRedisClient.js:579:23)
                            at processTicksAndRejections (internal/process/task_queues.js:95:5)
                         Unable to subscribe to expiry Keyspace events from Redis Server: Connection is        closed.
                         Unable to subscribe to evicted Keyspace events from Redis Server: Connection is        closed.
                         Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                        root@IoBroker:~# iob list instances
                         Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
                        Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                            at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
                        root@IoBroker:~#
                        dann die VM neu gestartet, iob startete aber nicht mehr, iob status zeigte irgendwas von lua script an, hab die Meldung aber nimmer, da ich das von der Proxmox Konsole aus aufgerufen hatte .
                        letztendlich Backup zurück gespielt
                        ich habe weder redis noch multihost
                           iob stop worx
                          root@IoBroker:~#
                          apollon77A Online
                          apollon77A Online
                          #491
                          @crunchip Ja... sind schon dran .... stay tuned for 1.6.2
                          • apollon77A Online
                            apollon77A Online
                            #492
                            1.6.2 bitte nutzen ... Repo update kommt 14 Uhr eh
                            crunchipC L 2 Antworten Letzte Antwort
                              crunchipC Offline
                              crunchipC Offline
                              #493
                              @apollon77 ich teste gleich
                              Install verlief problemlos👍
                                lessthanmore
                                schrieb am zuletzt editiert von lessthanmore
                                #494
                                @apollon77 Danke. Läuft bislang.
                                Ich habe gesehen, dass der Issue bzgl. Wetter geschlossen wurde. Bei wird weiterhin jeder Datenpunkt mit (null) "bewertet". Übersehe ich hier etwas?
                                worx.0 2022-06-17 16:03:04.500	debug	Error while get Weather: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"}
                                Danke vorab.
                                Hat sich glaube ich schon erledigt. Glaube das geht/ ging nur mit den "älteren" Modellen.
                                • L lessthanmore
                                  Danke vorab.
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #495
                                  @lessthanmore ich glaube es wurde entfernt egal welcher mover.. ich hatte es gehabt.. jetzt steht da wie bei dir null.. ergo die Daten werden nicht gesendet..vom Mover
                                  • L Online
                                    L Online
                                    Lucky_ESA
                                    #496
                                    ist es eigentlich angedacht den Adapter um einige Funktionen zu erweitern wie z. Bsp. das Aktivitätenprotokoll? Würde mir das gerne in VIS und IQontrol ausgeben lassen.
                                    Gruß//Lucky
                                    • L Lucky_ESA
                                      Gruß//Lucky
                                      hsteinmeH Offline
                                      hsteinmeH Offline
                                      hsteinme
                                      #497
                                      @lucky_esa Das Aktivitätenprotokoll ist kein Teil des Datenverkehrs zwischen Adapter und Cloud/Mäher. Also kann der Adapter sich diese Infomationen nicht abholen.
                                      Falls Dir dieser Punkt aber wichtig ist, kannst Du Dir selbst eine Lösung "basteln", in dem Du per Skript die status und error Datenpunkte überwachst und bei besonderen Ereignissen diese in einen eigenen Datenpunkt schreibst, den Du dann mit Deiner Visualisierung abgreifen kannst.
                                      L 1 Antwort Letzte Antwort
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        #498
                                        @hsteinme sagte in Adapter: Worx Landroid:
                                        Hi hsteinme, das kann ich leider nicht bestätigen. Wenn man 2 Handys hat und dort Änderungen vornimmt, dann werden die Daten über die Cloud übermittelt.
                                        Habe den Adapter bereits angepasst und das wären die Daten:
                                        {"_id":"a5255e83-8a9a-4ccc-8e73-40c9c0fcd372","timestamp":"2022-07-01 16:08:47","product_item_id":576622,"payload":{"cfg":{"tm":"18:08:48","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"6854c326-062f-46d7-a4a8-f5243dffdd2c","timestamp":"2022-07-01 15:03:56","product_item_id":576622,"payload":{"cfg":{"tm":"17:03:56","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"a881e7db-65b8-4d82-af9a-66c2fe2a0411","timestamp":"2022-07-01 15:00:06","product_item_id":576622,"payload":{"cfg":{"tm":"17:00:06","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"aef0a320-b98c-4445-a66d-5009bdf6a039","timestamp":"2022-07-01 13:30:30","product_item_id":576622,"payload":{"cfg":{"tm":"15:30:30","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"58a00596-4582-405d-a20c-18d1c91f30b2","timestamp":"2022-07-01 11:44:18","product_item_id":576622,"payload":{"cfg":{"tm":"13:44:18","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"79122829-32c2-4cc4-b6aa-073288790498","timestamp":"2022-07-01 10:29:19","product_item_id":576622,"payload":{"cfg":{"tm":"12:29:18","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"e465930e-ee5e-4413-9c15-250415ddd17c","timestamp":"2022-07-01 10:26:58","product_item_id":576622,"payload":{"cfg":{"tm":"12:26:58","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"e1f9b40a-6b18-4b67-8fa9-9cfd1220043b","timestamp":"2022-07-01 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"992e775b-1871-4a9c-9492-8eb9173bfb36","timestamp":"2022-06-30 10:32:10","product_item_id":576622,"payload":{"cfg":{"tm":"12:32:10","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"c8886c6b-75bd-4313-8331-4d6f947bbe56","timestamp":"2022-06-30 10:02:32","product_item_id":576622,"payload":{"cfg":{"tm":"12:02:33","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"cd9e7576-9b39-453e-8b8b-32024f17b5d6","timestamp":"2022-06-30 10:00:12","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:12","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"305ca311-9b3f-418a-a705-9ad9dd8a6780","timestamp":"2022-06-30 09:50:54","product_item_id":576622,"payload":{"cfg":{"tm":"11:50:54","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"9dfb5c42-ea4a-4f63-b1e4-7495250876c2","timestamp":"2022-06-30 09:38:27","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:27","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":32,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"df656351-4a20-45ba-aa43-1c352a52a375","timestamp":"2022-06-30 09:38:24","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:24","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":3,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"7f379719-2724-47d8-a189-20fe45ede06f","timestamp":"2022-06-30 09:37:52","product_item_id":576622,"payload":{"cfg":{"tm":"11:37:52","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"14ceaf6e-c5f8-4df6-bdcd-2a58d58cbdcd","timestamp":"2022-06-30 02:57:50","product_item_id":576622,"payload":{"cfg":{"tm":"04:57:50","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"2cc10579-c7ef-44de-906b-2956c92fea7e","timestamp":"2022-06-29 10:54:04","product_item_id":576622,"payload":{"cfg":{"tm":"12:54:05","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"3e5ad39e-a316-48b8-92df-b4a219fe1c31","timestamp":"2022-06-29 10:04:07","product_item_id":576622,"payload":{"cfg":{"tm":"12:04:08","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"7d2baaaf-a7ba-4854-996f-ffc5b8e50a7c","timestamp":"2022-06-29 10:00:23","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:23","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"2caf68ad-894d-4d2f-b605-1097f79ab149","timestamp":"2022-06-29 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"8c9f200c-f46d-4b49-ae2b-d55e73ce8f97","timestamp":"2022-06-28 11:01:02","product_item_id":576622,"payload":{"cfg":{"tm":"13:01:02","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"1bf374d3-4660-4560-9169-a1ff26e94f7d","timestamp":"2022-06-28 10:00:45","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:45","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"ced74ed2-0dc8-4e4a-837f-100b802eaa44","timestamp":"2022-06-28 10:00:25","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:24","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"c7373178-024f-4510-b23d-4f9fae1958c2","timestamp":"2022-06-28 09:00:39","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:38","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"9cc88327-1a23-4181-8489-18e07f51a741","timestamp":"2022-06-28 09:00:08","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:08","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"8969f118-52c8-4d5a-a22c-18ee254fa86b","timestamp":"2022-06-28 00:00:07","product_item_id":576622,"payload":{"cfg":{"tm":"02:00:06","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"14037c67-e340-4297-a069-a4b859fd6ee7","timestamp":"2022-06-27 10:51:54","product_item_id":576622,"payload":{"cfg":{"tm":"12:51:55","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"04e072e4-c218-4ff2-920c-93c5cfa47907","timestamp":"2022-06-27 10:00:23","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:24","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"9e13685b-92cb-47e9-82d4-0265ee313a02","timestamp":"2022-06-27 10:00:01","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:02","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"b7e32262-1835-4e7a-b621-fbb3dc05e1a3","timestamp":"2022-06-27 09:09:22","product_item_id":576622,"payload":{"cfg":{"tm":"11:09:23","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"517d3ba4-b9c0-4f98-91d4-ca8bcc05b1f4","timestamp":"2022-06-27 09:00:35","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:36","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":32,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"8e0b38ae-b52f-4542-a38f-cd46d317f9db","timestamp":"2022-06-27 09:00:32","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:32","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":3,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"82c7a2c4-7cf2-4771-9a44-c28f490a7370","timestamp":"2022-06-27 05:03:17","product_item_id":576622,"payload":{"cfg":{"tm":"07:03:18","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"fbae575c-c178-4f99-b6be-065263c9bec5","timestamp":"2022-06-27 01:43:17","product_item_id":576622,"payload":{"cfg":{"tm":"03:43:17","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"e94b47f0-1cfc-41db-bbb4-2e55156a1651","timestamp":"2022-06-26 07:47:48","product_item_id":576622,"payload":{"cfg":{"tm":"09:47:47","dt":"26/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"00ebe528-921b-46aa-8ee0-8ac3e9709d66","timestamp":"2022-06-26 02:27:47","product_item_id":576622,"payload":{"cfg":{"tm":"04:27:46","dt":"26/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"b8fee210-a87a-44eb-96e8-3e249b21e8bf","timestamp":"2022-06-25 15:03:30","product_item_id":576622,"payload":{"cfg":{"tm":"17:03:29","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"1aea3fa0-1733-4ecc-a605-13a5eec8a696","timestamp":"2022-06-25 14:01:04","product_item_id":576622,"payload":{"cfg":{"tm":"16:01:02","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"ed227710-e61c-45b0-8492-f572b9ad71ac","timestamp":"2022-06-25 14:00:12","product_item_id":576622,"payload":{"cfg":{"tm":"16:00:10","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"5278aa0a-8bac-4058-a6b5-3f3210920a86","timestamp":"2022-06-25 12:30:33","product_item_id":576622,"payload":{"cfg":{"tm":"14:30:33","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"93353540-d365-4fb5-99b7-b02b6a7d7605","timestamp":"2022-06-25 11:34:08","product_item_id":576622,"payload":{"cfg":{"tm":"13:34:08","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                                        {"_id":"90d68100-854b-4564-addd-021683c3fb53","timestamp":"2022-06-25 10:21:25","product_item_id":576622,"payload":{"cfg":{"tm":"12:21:26","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"f74b5396-690c-4569-ba84-74882b44677c","timestamp":"2022-06-25 10:18:36","product_item_id":576622,"payload":{"cfg":{"tm":"12:18:36","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"f963c67b-d9a8-4ee3-b9c3-b2cba98a55d3","timestamp":"2022-06-25 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:31","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"56b7b10c-bb1a-4321-932b-f0a8ac5f682e","timestamp":"2022-06-25 08:53:48","product_item_id":576622,"payload":{"cfg":{"tm":"10:53:47","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"085d9439-7555-4509-a3e6-c0f57bbd1f79","timestamp":"2022-06-24 20:33:45","product_item_id":576622,"payload":{"cfg":{"tm":"22:33:47","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"eb152b8f-f825-463a-8201-19651bdcc5cb","timestamp":"2022-06-24 20:26:25","product_item_id":576622,"payload":{"cfg":{"tm":"22:26:27","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"9c0584ae-964c-4d7b-a040-3c8aed571f49","timestamp":"2022-06-24 17:16:25","product_item_id":576622,"payload":{"cfg":{"tm":"19:16:26","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"87bdda49-c482-4660-9ab1-8d7ff9fd6e6d","timestamp":"2022-06-24 14:58:54","product_item_id":576622,"payload":{"cfg":{"tm":"16:58:55","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"5433a492-d4d5-4b88-b6b7-981d6971dc39","timestamp":"2022-06-24 14:58:24","product_item_id":576622,"payload":{"cfg":{"tm":"16:58:25","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"3eceaa5c-99e3-406f-883c-aef9c0a0dd3e","timestamp":"2022-06-24 09:38:34","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:35","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":6,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"8fe27c11-2561-4ca1-8072-d4093435a253","timestamp":"2022-06-23 10:00:29","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:29","dt":"23/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"5888af81-e06a-4dfd-9aa5-5e359530c416","timestamp":"2022-06-23 09:10:14","product_item_id":576622,"payload":{"cfg":{"tm":"11:10:15","dt":"23/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                                        {"_id":"9fe6db9e-04c2-49a1-ae27-0b52d313681f","timestamp":"2022-06-21 10:01:12","product_item_id":576622,"payload":{"cfg":{"tm":"12:01:13","dt":"21/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                                        {"_id":"0fda7fad-5614-491b-9681-e10ea67a6521","timestamp":"2022-06-17 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"17/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}}
                                        Ich muss mir mal überlegen wie ich die als DP anlege. Fängt schon damit an, dass ich nicht weiß ob die Anzahl an Events auf 55 beschränkt ist. Hinzu kommt das der Timestamp 2 Std. vor tm liegt...Komisch, ob das bei jedem so ist...
                                        Gruß//Lucky
                                        • L Lucky_ESA
                                          Gruß//Lucky
                                          hsteinmeH Offline
                                          hsteinmeH Offline
                                          hsteinme
                                          schrieb am zuletzt editiert von hsteinme
                                          #499
                                          @lucky_esa Hier reden wir wohl ein klein wenig aneinander vorbei. Bei Aktivitätenprotokoll denke ich an eine "zusammengedampfte" und knapp aufbereitete Form der Informationen zum Mäherzustand über einen gewissen Zeitraum hinweg. Diese zusammengedampfte Form, wie sie in der App dargestellt wird, sehe ich nicht im Datenstream zwischen Adapter und Cloud/Mäher.
                                          Was Du abgerufen und oben zitiert hast sind historische Rohdaten, die einen Teil der Daten darstellen, die eh schon zwischen Cloud/Mäher und Adapter ausgetauscht worden sind. Das "Eindampfen" der Daten müsste also noch vom Adapter durchgeführt werden.
                                          Zu Deiner Frage nach der Datenpunkt-Darstellung. Hier sollte zunächst geklärt werden, welche der gelieferten Daten überhaupt dargestellt werden sollen. Diese Daten alle dem Adapter-Anwender anzubieten, bietet diesem nur einen geringen Mehrwert.
                                          Wenn ich mir die App-Darstellung so ansehe, so sehe ich im wesentlichen drei Felder:
                                          • Ereignis
                                          • Kennzeichen Information oder Fehler
                                          • Zeitstempel
                                          Aufgabe des Adapters wäre es nun, das Ereignis aus den Feldern Deiner obigen Darstellung heraus zu ziehen, In den meisen Fällen wären dies wohl dat.ls und dat.le. Ob noch andere in Frage kommen, müsste man duch Vergleichen mit der App-Darstellung herausfinden.
                                          Als Datenpunkt könnte man ähnlich wie calendar.calJson ein Array von Arrays verwenden. In den inneren Arrays könnten als Elemente stehen:
                                          • Text für Ereignis
                                          • Zahlen 0/1 für Info/Error (oder Zeichen I/E)
                                          • Text für Zeitstempel.
                                          Hier müsste noch die Zeitzonenfrage geklärt werden. Vielleicht kann man sich an rawMqtt.raw.created_at dabei orientieren.
