  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 579.1k Aufrufe 64 Beobachtet
    @apollon77 no connection to database, drehender kreisel, hat mir das ganze log zugeballert
    2022-06-17 11:42:29.981  - info: host.IoBroker iobroker Update worx from @1.5.5 to @1.6.0
    2022-06-17 11:42:30.431  - info: host.IoBroker iobroker NPM version: 6.14.17Installing iobroker.worx@1.6.0... (System call)
    2022-06-17 11:43:25.232  - info: host.IoBroker iobroker > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    2022-06-17 11:43:27.113  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings/build“ wird betreten
    2022-06-17 11:43:27.124  - info: host.IoBroker iobroker   CXX(target) Release/obj.target/bindings/src/serialport.o
    2022-06-17 11:43:28.484  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/@serialport/bindings/build“ wird verlassen
    2022-06-17 11:43:28.503  - info: host.IoBroker iobroker > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    2022-06-17 11:43:29.913  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings/build“ wird betreten
    2022-06-17 11:43:29.915  - info: host.IoBroker iobroker   CXX(target) Release/obj.target/bindings/src/serialport.o
    2022-06-17 11:43:31.391  - info: host.IoBroker iobroker make: Verzeichnis „/opt/iobroker/node_modules/zigbee-shepherd-converters/node_modules/@serialport/bindings/build“ wird verlassen
    2022-06-17 11:43:36.567  - info: host.IoBroker iobroker + iobroker.worx@1.6.0added 17 packages from 31 contributors and updated 2 packages in 65.133s
    2022-06-17 11:43:41.735  - info: host.IoBroker iobroker 187 packages are looking for funding
    2022-06-17 11:43:41.737  - info: host.IoBroker iobroker   run `npm fund` for details
    2022-06-17 11:43:41.965  - info: host.IoBroker iobroker Update "system.adapter.worx.0"
    2022-06-17 11:43:41.994  - info: host.IoBroker stopInstance system.adapter.worx.0 (force=false, process=true)
    2022-06-17 11:43:42.021  - info: host.IoBroker stopInstance system.adapter.worx.0 send kill signal
    2022-06-17 11:43:42.041  - info: host.IoBroker iobroker upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
    2022-06-17 11:43:42.533  - info: host.IoBroker iobroker upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/style.css style.css text/css
    2022-06-17 11:43:42.554  - info: host.IoBroker iobroker upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/words.js words.js application/javascript
    2022-06-17 11:43:42.627  - info: host.IoBroker iobroker upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
    2022-06-17 11:43:42.639  - info: host.IoBroker iobroker upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx_ada2.png worx_ada2.png image/png
    2022-06-17 11:43:42.874  - info: host.IoBroker instance system.adapter.worx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-06-17 11:43:43.923  - info: host.IoBroker iobroker exit 0
    2022-06-17 11:43:45.616  - info: host.IoBroker instance system.adapter.worx.0 started with pid 1795320
    2022-06-17 11:43:53.012  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.connect is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:43:53.015  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    2022-06-17 11:43:53.017  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.found is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:43:53.017  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    2022-06-17 11:43:53.018  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.mqtt is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:43:53.019  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    2022-06-17 11:43:53.020  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.online is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:43:53.020  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    2022-06-17 11:43:53.021  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance._events.offline is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:43:53.022  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    .geht so endlos weiter
    2022-06-17 11:44:38.570  - error: worx.0 (1795320) Error: Invalid ID: worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.pluginHandler.settings.parentPackage.files.admin{,/!(src)/**}/!(tsconfig|tsconfig.*).json
    2022-06-17 11:44:38.571  - error: worx.0 (1795320) Error: Invalid ID: worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.pluginHandler.settings.parentPackage.files.admin{,/!(src)/**}/*.{html,css,png,svg,jpg,js}
    2022-06-17 11:44:55.339  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._events.prefinish is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:44:55.340  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    2022-06-17 11:44:55.340  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._events.error is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:44:55.341  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    2022-06-17 11:44:55.341  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._writableState.onwrite is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:44:55.342  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    2022-06-17 11:44:55.342  - warn: worx.0 (1795320) Object worx.0.202130267110002724D6.rawMqtt.worxInstance.adapter.log.logger._transformState.afterTransform is invalid: obj.common.type has an invalid value (function) but has to be one of number, string, boolean, array, object, mixed, file, json
    2022-06-17 11:44:55.343  - warn: worx.0 (1795320) This object will not be created in future versions. Please report this to the developer.
    hab dann versucht den Adapter zu stoppen
     iob stop worx
     Connection is closed.
    Uncaught Rejection: Error: States DB is not allowed to start in the current Mult        ihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/l        ib/states/statesInRedisClient.js:579:23)
        at processTicksAndRejections (internal/process/task_queues.js:95:5)
     Unable to subscribe to expiry Keyspace events from Redis Server: Connection is        closed.
     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is        closed.
     Unable to subscribe to meta namespace "meta." changes: Connection is closed.
    root@IoBroker:~# iob list instances
     Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
    Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
    root@IoBroker:~#
    dann die VM neu gestartet, iob startete aber nicht mehr, iob status zeigte irgendwas von lua script an, hab die Meldung aber nimmer, da ich das von der Proxmox Konsole aus aufgerufen hatte .
    letztendlich Backup zurück gespielt
    ich habe weder redis noch multihost
    apollon77A Online
    apollon77A Online
    #491
    @crunchip Ja... sind schon dran .... stay tuned for 1.6.2
    • apollon77A Online
      apollon77A Online
      #492
      1.6.2 bitte nutzen ... Repo update kommt 14 Uhr eh
      crunchipC L 2 Antworten Letzte Antwort
      • apollon77A apollon77
        crunchipC Offline
        crunchipC Offline
        #493
        @apollon77 ich teste gleich
        Install verlief problemlos👍
          lessthanmore
          schrieb am zuletzt editiert von lessthanmore
          #494
          @apollon77 Danke. Läuft bislang.
          Ich habe gesehen, dass der Issue bzgl. Wetter geschlossen wurde. Bei wird weiterhin jeder Datenpunkt mit (null) "bewertet". Übersehe ich hier etwas?
          worx.0 2022-06-17 16:03:04.500	debug	Error while get Weather: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"}
          Danke vorab.
          Hat sich glaube ich schon erledigt. Glaube das geht/ ging nur mit den "älteren" Modellen.
          • L lessthanmore
            Danke vorab.
            arteckA Offline
            arteckA Offline
            arteck
            #495
            @lessthanmore ich glaube es wurde entfernt egal welcher mover.. ich hatte es gehabt.. jetzt steht da wie bei dir null.. ergo die Daten werden nicht gesendet..vom Mover
            • L Online
              L Online
              Lucky_ESA
              #496
              ist es eigentlich angedacht den Adapter um einige Funktionen zu erweitern wie z. Bsp. das Aktivitätenprotokoll? Würde mir das gerne in VIS und IQontrol ausgeben lassen.
              Gruß//Lucky
              hsteinmeH 1 Antwort Letzte Antwort
              • L Lucky_ESA
                Gruß//Lucky
                hsteinmeH Offline
                hsteinmeH Offline
                hsteinme
                #497
                @lucky_esa Das Aktivitätenprotokoll ist kein Teil des Datenverkehrs zwischen Adapter und Cloud/Mäher. Also kann der Adapter sich diese Infomationen nicht abholen.
                Falls Dir dieser Punkt aber wichtig ist, kannst Du Dir selbst eine Lösung "basteln", in dem Du per Skript die status und error Datenpunkte überwachst und bei besonderen Ereignissen diese in einen eigenen Datenpunkt schreibst, den Du dann mit Deiner Visualisierung abgreifen kannst.
                L 1 Antwort Letzte Antwort
                • hsteinmeH hsteinme
                  L Online
                  L Online
                  Lucky_ESA
                  #498
                  @hsteinme sagte in Adapter: Worx Landroid:
                  Hi hsteinme, das kann ich leider nicht bestätigen. Wenn man 2 Handys hat und dort Änderungen vornimmt, dann werden die Daten über die Cloud übermittelt.
                  Habe den Adapter bereits angepasst und das wären die Daten:
                  {"_id":"a5255e83-8a9a-4ccc-8e73-40c9c0fcd372","timestamp":"2022-07-01 16:08:47","product_item_id":576622,"payload":{"cfg":{"tm":"18:08:48","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"6854c326-062f-46d7-a4a8-f5243dffdd2c","timestamp":"2022-07-01 15:03:56","product_item_id":576622,"payload":{"cfg":{"tm":"17:03:56","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"a881e7db-65b8-4d82-af9a-66c2fe2a0411","timestamp":"2022-07-01 15:00:06","product_item_id":576622,"payload":{"cfg":{"tm":"17:00:06","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"aef0a320-b98c-4445-a66d-5009bdf6a039","timestamp":"2022-07-01 13:30:30","product_item_id":576622,"payload":{"cfg":{"tm":"15:30:30","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"58a00596-4582-405d-a20c-18d1c91f30b2","timestamp":"2022-07-01 11:44:18","product_item_id":576622,"payload":{"cfg":{"tm":"13:44:18","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"79122829-32c2-4cc4-b6aa-073288790498","timestamp":"2022-07-01 10:29:19","product_item_id":576622,"payload":{"cfg":{"tm":"12:29:18","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"e465930e-ee5e-4413-9c15-250415ddd17c","timestamp":"2022-07-01 10:26:58","product_item_id":576622,"payload":{"cfg":{"tm":"12:26:58","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"e1f9b40a-6b18-4b67-8fa9-9cfd1220043b","timestamp":"2022-07-01 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"01/07/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"992e775b-1871-4a9c-9492-8eb9173bfb36","timestamp":"2022-06-30 10:32:10","product_item_id":576622,"payload":{"cfg":{"tm":"12:32:10","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"c8886c6b-75bd-4313-8331-4d6f947bbe56","timestamp":"2022-06-30 10:02:32","product_item_id":576622,"payload":{"cfg":{"tm":"12:02:33","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"cd9e7576-9b39-453e-8b8b-32024f17b5d6","timestamp":"2022-06-30 10:00:12","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:12","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"305ca311-9b3f-418a-a705-9ad9dd8a6780","timestamp":"2022-06-30 09:50:54","product_item_id":576622,"payload":{"cfg":{"tm":"11:50:54","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"9dfb5c42-ea4a-4f63-b1e4-7495250876c2","timestamp":"2022-06-30 09:38:27","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:27","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":32,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"df656351-4a20-45ba-aa43-1c352a52a375","timestamp":"2022-06-30 09:38:24","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:24","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":3,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"7f379719-2724-47d8-a189-20fe45ede06f","timestamp":"2022-06-30 09:37:52","product_item_id":576622,"payload":{"cfg":{"tm":"11:37:52","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"14ceaf6e-c5f8-4df6-bdcd-2a58d58cbdcd","timestamp":"2022-06-30 02:57:50","product_item_id":576622,"payload":{"cfg":{"tm":"04:57:50","dt":"30/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"2cc10579-c7ef-44de-906b-2956c92fea7e","timestamp":"2022-06-29 10:54:04","product_item_id":576622,"payload":{"cfg":{"tm":"12:54:05","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"3e5ad39e-a316-48b8-92df-b4a219fe1c31","timestamp":"2022-06-29 10:04:07","product_item_id":576622,"payload":{"cfg":{"tm":"12:04:08","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"7d2baaaf-a7ba-4854-996f-ffc5b8e50a7c","timestamp":"2022-06-29 10:00:23","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:23","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"2caf68ad-894d-4d2f-b605-1097f79ab149","timestamp":"2022-06-29 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"29/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"8c9f200c-f46d-4b49-ae2b-d55e73ce8f97","timestamp":"2022-06-28 11:01:02","product_item_id":576622,"payload":{"cfg":{"tm":"13:01:02","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"1bf374d3-4660-4560-9169-a1ff26e94f7d","timestamp":"2022-06-28 10:00:45","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:45","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"ced74ed2-0dc8-4e4a-837f-100b802eaa44","timestamp":"2022-06-28 10:00:25","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:24","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"c7373178-024f-4510-b23d-4f9fae1958c2","timestamp":"2022-06-28 09:00:39","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:38","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"9cc88327-1a23-4181-8489-18e07f51a741","timestamp":"2022-06-28 09:00:08","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:08","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"8969f118-52c8-4d5a-a22c-18ee254fa86b","timestamp":"2022-06-28 00:00:07","product_item_id":576622,"payload":{"cfg":{"tm":"02:00:06","dt":"28/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"14037c67-e340-4297-a069-a4b859fd6ee7","timestamp":"2022-06-27 10:51:54","product_item_id":576622,"payload":{"cfg":{"tm":"12:51:55","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"04e072e4-c218-4ff2-920c-93c5cfa47907","timestamp":"2022-06-27 10:00:23","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:24","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"9e13685b-92cb-47e9-82d4-0265ee313a02","timestamp":"2022-06-27 10:00:01","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:02","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"b7e32262-1835-4e7a-b621-fbb3dc05e1a3","timestamp":"2022-06-27 09:09:22","product_item_id":576622,"payload":{"cfg":{"tm":"11:09:23","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"517d3ba4-b9c0-4f98-91d4-ca8bcc05b1f4","timestamp":"2022-06-27 09:00:35","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:36","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":32,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"8e0b38ae-b52f-4542-a38f-cd46d317f9db","timestamp":"2022-06-27 09:00:32","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:32","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":3,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"82c7a2c4-7cf2-4771-9a44-c28f490a7370","timestamp":"2022-06-27 05:03:17","product_item_id":576622,"payload":{"cfg":{"tm":"07:03:18","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"fbae575c-c178-4f99-b6be-065263c9bec5","timestamp":"2022-06-27 01:43:17","product_item_id":576622,"payload":{"cfg":{"tm":"03:43:17","dt":"27/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"e94b47f0-1cfc-41db-bbb4-2e55156a1651","timestamp":"2022-06-26 07:47:48","product_item_id":576622,"payload":{"cfg":{"tm":"09:47:47","dt":"26/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"00ebe528-921b-46aa-8ee0-8ac3e9709d66","timestamp":"2022-06-26 02:27:47","product_item_id":576622,"payload":{"cfg":{"tm":"04:27:46","dt":"26/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"b8fee210-a87a-44eb-96e8-3e249b21e8bf","timestamp":"2022-06-25 15:03:30","product_item_id":576622,"payload":{"cfg":{"tm":"17:03:29","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"1aea3fa0-1733-4ecc-a605-13a5eec8a696","timestamp":"2022-06-25 14:01:04","product_item_id":576622,"payload":{"cfg":{"tm":"16:01:02","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"ed227710-e61c-45b0-8492-f572b9ad71ac","timestamp":"2022-06-25 14:00:12","product_item_id":576622,"payload":{"cfg":{"tm":"16:00:10","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"5278aa0a-8bac-4058-a6b5-3f3210920a86","timestamp":"2022-06-25 12:30:33","product_item_id":576622,"payload":{"cfg":{"tm":"14:30:33","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"93353540-d365-4fb5-99b7-b02b6a7d7605","timestamp":"2022-06-25 11:34:08","product_item_id":576622,"payload":{"cfg":{"tm":"13:34:08","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":0}}}},
                  {"_id":"90d68100-854b-4564-addd-021683c3fb53","timestamp":"2022-06-25 10:21:25","product_item_id":576622,"payload":{"cfg":{"tm":"12:21:26","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"f74b5396-690c-4569-ba84-74882b44677c","timestamp":"2022-06-25 10:18:36","product_item_id":576622,"payload":{"cfg":{"tm":"12:18:36","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"f963c67b-d9a8-4ee3-b9c3-b2cba98a55d3","timestamp":"2022-06-25 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:31","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"56b7b10c-bb1a-4321-932b-f0a8ac5f682e","timestamp":"2022-06-25 08:53:48","product_item_id":576622,"payload":{"cfg":{"tm":"10:53:47","dt":"25/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"085d9439-7555-4509-a3e6-c0f57bbd1f79","timestamp":"2022-06-24 20:33:45","product_item_id":576622,"payload":{"cfg":{"tm":"22:33:47","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"eb152b8f-f825-463a-8201-19651bdcc5cb","timestamp":"2022-06-24 20:26:25","product_item_id":576622,"payload":{"cfg":{"tm":"22:26:27","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"9c0584ae-964c-4d7b-a040-3c8aed571f49","timestamp":"2022-06-24 17:16:25","product_item_id":576622,"payload":{"cfg":{"tm":"19:16:26","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":5,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"87bdda49-c482-4660-9ab1-8d7ff9fd6e6d","timestamp":"2022-06-24 14:58:54","product_item_id":576622,"payload":{"cfg":{"tm":"16:58:55","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"5433a492-d4d5-4b88-b6b7-981d6971dc39","timestamp":"2022-06-24 14:58:24","product_item_id":576622,"payload":{"cfg":{"tm":"16:58:25","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"3eceaa5c-99e3-406f-883c-aef9c0a0dd3e","timestamp":"2022-06-24 09:38:34","product_item_id":576622,"payload":{"cfg":{"tm":"11:38:35","dt":"24/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":6,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"8fe27c11-2561-4ca1-8072-d4093435a253","timestamp":"2022-06-23 10:00:29","product_item_id":576622,"payload":{"cfg":{"tm":"12:00:29","dt":"23/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":30,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"5888af81-e06a-4dfd-9aa5-5e359530c416","timestamp":"2022-06-23 09:10:14","product_item_id":576622,"payload":{"cfg":{"tm":"11:10:15","dt":"23/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}},
                  {"_id":"9fe6db9e-04c2-49a1-ae27-0b52d313681f","timestamp":"2022-06-21 10:01:12","product_item_id":576622,"payload":{"cfg":{"tm":"12:01:13","dt":"21/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":1,"le":0,"lz":0,"lk":1,"bt":{"c":1,"m":0}}}},
                  {"_id":"0fda7fad-5614-491b-9681-e10ea67a6521","timestamp":"2022-06-17 09:00:30","product_item_id":576622,"payload":{"cfg":{"tm":"11:00:30","dt":"17/06/2022","mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"sc":{"m":1,"distm":0},"al":{"t":300,"lvl":1}},"dat":{"fw":3.26,"fwb":1,"ls":7,"le":0,"lz":0,"lk":1,"bt":{"c":0,"m":1}}}}
                  Ich muss mir mal überlegen wie ich die als DP anlege. Fängt schon damit an, dass ich nicht weiß ob die Anzahl an Events auf 55 beschränkt ist. Hinzu kommt das der Timestamp 2 Std. vor tm liegt...Komisch, ob das bei jedem so ist...
                  Gruß//Lucky
                  • L Lucky_ESA
                    Gruß//Lucky
                    hsteinmeH Offline
                    hsteinmeH Offline
                    hsteinme
                    schrieb am zuletzt editiert von hsteinme
                    #499
                    @lucky_esa Hier reden wir wohl ein klein wenig aneinander vorbei. Bei Aktivitätenprotokoll denke ich an eine "zusammengedampfte" und knapp aufbereitete Form der Informationen zum Mäherzustand über einen gewissen Zeitraum hinweg. Diese zusammengedampfte Form, wie sie in der App dargestellt wird, sehe ich nicht im Datenstream zwischen Adapter und Cloud/Mäher.
                    Was Du abgerufen und oben zitiert hast sind historische Rohdaten, die einen Teil der Daten darstellen, die eh schon zwischen Cloud/Mäher und Adapter ausgetauscht worden sind. Das "Eindampfen" der Daten müsste also noch vom Adapter durchgeführt werden.
                    Zu Deiner Frage nach der Datenpunkt-Darstellung. Hier sollte zunächst geklärt werden, welche der gelieferten Daten überhaupt dargestellt werden sollen. Diese Daten alle dem Adapter-Anwender anzubieten, bietet diesem nur einen geringen Mehrwert.
                    Wenn ich mir die App-Darstellung so ansehe, so sehe ich im wesentlichen drei Felder:
                    • Ereignis
                    • Kennzeichen Information oder Fehler
                    • Zeitstempel
                    Aufgabe des Adapters wäre es nun, das Ereignis aus den Feldern Deiner obigen Darstellung heraus zu ziehen, In den meisen Fällen wären dies wohl dat.ls und dat.le. Ob noch andere in Frage kommen, müsste man duch Vergleichen mit der App-Darstellung herausfinden.
                    Als Datenpunkt könnte man ähnlich wie calendar.calJson ein Array von Arrays verwenden. In den inneren Arrays könnten als Elemente stehen:
                    • Text für Ereignis
                    • Zahlen 0/1 für Info/Error (oder Zeichen I/E)
                    • Text für Zeitstempel.
                    Hier müsste noch die Zeitzonenfrage geklärt werden. Vielleicht kann man sich an rawMqtt.raw.created_at dabei orientieren.
                      • Ereignis
                      • Zeitstempel
                      • Text für Ereignis
                      L Online
                      L Online
                      Lucky_ESA
                      schrieb am zuletzt editiert von Lucky_ESA
                      #500
                      @hsteinme Vielen Dank für deine ausführliche Erklärung. Wie bei anderen Adapter bin ich mal wieder der einzige, der alles über den iobroker steuern möchte. Habe den Adapter so angepasst, dass der JSON vom Aktivitätensprotokoll in einem DB geschrieben wird. Diese Daten bearbeite ich dann per Blockly. Habe nun auch angefangen per put request alle RAW Daten an die Cloud zu übergeben. Kann jetzt eigentlich alles per IOBroker ändern. Habe allerdings noch keine Ahnung was ich für das zurücksetzen von Klingen-Arbeitszeit und Ladungen versenden muss. Habe da noch keine Werte von blade_work_time_reset_at, mal schauen ob ich hier im Forum einen Beitrag finden, wo ein Wert hinterlegt ist. Es ist für mich immer ein riesen Aufwand wenn es ein Update gibt, da ich dann den Adapter immer neu anpassen muss....Vielleicht überwinde ich mich irgendwann einen Pullrequest zu erstellen. Aber mein letzter mit dem ACS Modul wurde wochenlang nicht bearbeitet...
                      Edit:
                      P.S. Leider wurde die extractKeys.js abgeändert und daher werden die Datenpunkte nicht mehr chronologisch angelegt. Hat gestern dazu geführt, dass mein iobroker abgestürtzt ist und das weit über 100 Error Meldungen per sentry raus sind. Aber egal, muss dann auch diese Datei nach einem Update austauschen.
                      Gruß//Lucky
                      • L Lucky_ESA
                        Edit:
                        Gruß//Lucky
                        hsteinmeH Offline
                        hsteinmeH Offline
                        hsteinme
                        #501
                        @lucky_esa sagte in Adapter: Worx Landroid:
                        Alles?! Was verstehst Du unter "alles"? Letztlich liegt ja dem Zugriff auf die Cloud-Daten ein Berechtigungskonzept zugrunde, das sicherlich nicht "jedem" erlaubt, "alles" zu ändern.
                        Vielleicht findest Du hier noch für Dich brauchbare Informationen
                        • https://github.com/iobroker-community-adapters/ioBroker.worx/issues/67
                        • https://github.com/iobroker-community-adapters/ioBroker.worx/issues/257
                          L Online
                          L Online
                          Lucky_ESA
                          #502
                          @hsteinme Meine eigentliche Frage, ob der Adapter noch erweitert wird ist wohl damit beantwortet...NEIN...Nur über Pullrequest.
                          Was ich alles schalten kann? Mir ist wichtig "Mein Rasen" komplett über iobroker schalten zu können und das setzte ich gerade für mich selber um.
                          Habe es auch schon fast fertig...Weiß gerade nicht wie ich die ganzen Ordner auslesen soll. Aber hier wird mir schon was einfallen.
                          Die anderen Daten habe ich hier im Forum bereits gefunden. Deine Links sind mir bekannt.
                          Danke für deine Hilfe.
                          Gruß//Lucky
                            Sushibomba
                            #503
                            Wollte mal ne kurze Frage loswerden die mich schon die ganze Zeit beschäftigt.
                            Warum ist es nicht möglich den Mähfortschritt anhand einer visuellen Karte auszugeben, wie es auch die Staubsauger im Haus machen?
                            Ist das Absicht oder wurde es einfach noch nicht entwickelt?
                            • S Sushibomba
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #504
                              @sushibomba sagte in Adapter: Worx Landroid:
                              Staubsauger im Haus
                              haben einen Sensor somit wissen die wo die sich befinden.. der Mäher hat NUR ein Draht..
                              es gibt inzwischen GPS gesteuerte Mäher vielleicht haben die dann eine Karte
                              • arteckA arteck
                                Staubsauger im Haus
                                Sushibomba
                                #505
                                @arteck
                                Ja und ich dachte man könne die Daten des Sensors dann einfach visuell darstellen :)
                                arteckA HomoranH 2 Antworten Letzte Antwort
                                • S Sushibomba
                                  @arteck
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #506
                                  @sushibomba die api gibt das nicht her ..
                                  haselchenH S 2 Antworten Letzte Antwort
                                  • arteckA arteck
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #507
                                    @arteck
                                    Vom M500 ist das Wlan Modul defekt und die Garantie abgelaufen. Gibt es noch andere Möglichkeiten das Ding in Iobroker wieder reinzuprügeln? Radio Link Device ?
                                    • arteckA arteck
                                      Sushibomba
                                      #508
                                      @arteck OK wirklich schade. Das wäre Mal was wo die Entwickler Mal dran arbeiten sollten 🤗
                                      D HomoranH 2 Antworten Letzte Antwort
                                      -2
                                      • S Sushibomba
                                        dirkhe
                                        #509
                                        @sushibomba das ust schwierig, weil er nacb dem chaos prinzip fährt. und er fährt auch nicht immer wie eine billardkugel, sonder manchmal wechselt er suf langen strecken auch seine richtung, fährt halt nicht immer bis zum draht
                                        • D dirkhe
                                          Sushibomba
                                          #510
                                          @dirkhe
                                          Ja das ist richtig. Aber wenn er ja seine Position speichert, wäre das ja schon ausreichend anhand einer visuellen Karten dazustellen.
                                          Also einfach sowas:
                                          -1
