  4. Adapter Klipper-Moonraker
klippermoonrakeradapter update
163 Beiträge 26 Kommentatoren 33.8k Aufrufe 24 Beobachtet
  • Merlin123M Merlin123
    Kennt jemand ne gute Methode, das Thumbnail des aktuellen Drucks abzurufen bzw. in der VIS anzuzeigen?
    S Nicht stören
    S Nicht stören
    stenmic
    schrieb am zuletzt editiert von stenmic
    #101
    @merlin123
    so mach ich es
    (ip vom Drucker anpassen)
    <block xmlns="https://developers.google.com/blockly/xml" type="on" id="/Z2O}ZB#,a]kn33Dz4F$" x="116" y="2253">
     <field name="OID">mqtt.0.Mainsail.klipper.state.print_stats.filename</field>
     <statement name="STATEMENT">
       <block type="variables_set" id="y[Oc#E_92,_2BKo4(5~[">
         <field name="VAR" id="BXYL{xhaLkN~v2Ldl!%!">text</field>
         <value name="VALUE">
           <block type="get_attr" id="XXR]WqWt.=HMLUr3gR}@">
             <value name="PATH">
               <shadow type="text" id="rrx*$IEHd@w{;*~Z+8`n">
                 <field name="TEXT">value</field>
               </shadow>
             </value>
             <value name="OBJECT">
               <shadow type="get_object" id="^cMzi*_aj{`Pl0P725m~">
               </shadow>
               <block type="on_source" id="pgo{+7GzQz;]qj)e34}A">
               </block>
             </value>
           </block>
         </value>
         <next>
           <block type="update" id="bIOV@RC*Q+u,j_l+cDZ,">
             <field name="OID">0_userdata.0.Klipper.API.Printjob.Name</field>
               <block type="text_getSubstring" id=";P~^,bl^VhcaeFBrn4B7">
                 <mutation at1="false" at2="true"></mutation>
                 <field name="WHERE1">FIRST</field>
                 <field name="WHERE2">FROM_START</field>
                 <value name="STRING">
                   <block type="variables_get" id=".)~:q(Mh|eeSdPJRu*2!">
                   </block>
                 </value>
                 <value name="AT2">
                   <block type="math_arithmetic" id="~]oa3qPRWU)spG%YB1]]">
                     <value name="A">
                       <shadow type="math_number" id="PqrA)w7#cW-.+R7[s$Ut">
                         <field name="NUM">1</field>
                       </shadow>
                       <block type="text_indexOf" id="r51`DlwiN)v*}8k4q}5p">
                         <field name="END">FIRST</field>
                           <block type="variables_get" id="sqPwTzw6?t1]F1dwmj|P">
                           </block>
                         </value>
                         <value name="FIND">
                           <shadow type="text" id="NN88q$[rF?qy3R1S,=Fk">
                             <field name="TEXT">.gcode</field>
                           </shadow>
                         </value>
                       </block>
                     </value>
                     <value name="B">
                       <shadow type="math_number" id="Gp.#K1A?Y{{b4u]f,mK_">
                       </shadow>
                     </value>
                   </block>
                 </value>
               </block>
             </value>
             <next>
               <block type="update" id="v~`h#IPc]?2X#3=M{X[a">
                 <field name="OID">0_userdata.0.Klipper.API.Printjob.Thumbnail</field>
                   <block type="text_join" id="=uC)c{XD(`=yL3+qnM$/">
                     <value name="ADD0">
                       <block type="text" id="+hu6Z]DDV49vxZEG3^KI">
                         <field name="TEXT">http://192.168.178.113/server/files/gcodes/.thumbs/</field>
                       </block>
                     </value>
                     <value name="ADD1">
                       <block type="text_getSubstring" id=".jX}L{b`]tqX[lP+wIR2">
                           <block type="variables_get" id="ZUXf!~C]B[?oTqjrU3mF">
                           </block>
                         </value>
                         <value name="AT2">
                           <block type="math_arithmetic" id="rArUrH5JD`!U0PI6`=Lt">
                             <value name="A">
                               </shadow>
                               <block type="text_indexOf" id="Gji4dA%oP(rS[%9W%X(m">
                                   <block type="variables_get" id="i=BXKzmS]z$x=!47DA!B">
                                   </block>
                                 </value>
                                 <value name="FIND">
                                   <shadow type="text" id="nTgAoKx?A/?1e#g9JTXQ">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                               <shadow type="math_number" id="u3_-Ii7/U+4%YQw8Az@I">
                               </shadow>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                     <value name="ADD2">
                       <block type="text" id="sn3+k)T(}R(KvqNhQ6;v">
                         <field name="TEXT">.png</field>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </next>
           </block>
         </next>
       </block>
     </statement>
    </block>
    Merlin123M D NegaleinN 3 Antworten Letzte Antwort
    • S stenmic
      @merlin123
      so mach ich es
               <value name="PATH">
                 </shadow>
               </value>
                 </shadow>
                 </block>
               </value>
             </block>
           </value>
           <next>
                     </block>
                   </value>
                   <value name="AT2">
                       <value name="A">
                         </shadow>
                             </block>
                           </value>
                           <value name="FIND">
                             </shadow>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                         </shadow>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                       <value name="ADD0">
                         </block>
                       </value>
                       <value name="ADD1">
                             </block>
                           </value>
                           <value name="AT2">
                               <value name="A">
                                 </shadow>
                                     </block>
                                   </value>
                                   <value name="FIND">
                                     </shadow>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 </shadow>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="ADD2">
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
      </block>
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #102
      @stenmic Erstmal danke für das Script :)
      Die URL baut er richtig zusammen, aber unter der Adresse liefert mein Drucker kein Bild:
      http://192.168.0.252/server/files/gcodes/.thumbs/Plate%201%20-%20Charcoal%20Black_0.15mm_PLA_Generic%20Klipper%20Printer_6h52m.png
      Bei mir liegt das Thumbnail unter
      /usr/data/printer_data/gcodes/.thumbs/Plate 1 - Charcoal Black_0.15mm_PLA_Generic Klipper Printer_6h52m-100x100.png
      Weißt Du, was ich machen muss, damit der Drucker das via HTML ausliefert?
      Beta-Tester
      K S 2 Antworten Letzte Antwort
        Kammi_
        schrieb am zuletzt editiert von Kammi_
        #103
        @merlin123
        öffne deinen drucker im browser bei mir wäre das http://192.168.0.84 rechts klick auf das tumbnail -> Grafik im neuen tab öffnen und du hast deine Adresse wo du brauchst
        http://192.168.0.84/server/files/gcodes/.cache/.thumbs/Calibration%20Cube_PETG_22m3s-272x272.png?date=1735204837
        wäre es bei mir also genau das gleiche du musst nur deine ip austauschen
        Merlin123M 1 Antwort Letzte Antwort
          S Nicht stören
          S Nicht stören
          stenmic
          #104
          @merlin123 mach mal bitte zum test einen Druck mit einem einfachen Dateinamen und ohne Lehrzeichen.
          • K Kammi_
            @merlin123
            Merlin123M Offline
            Merlin123M Offline
            Merlin123
            #105
            @kammi_ Wenn das so einfach wäre ;)
            Wenn ich in Mailsail oder Fluidd nen Rechtsklick auf das Thumb mache kann ich das Bild nicht anzeigen. Der Seitenquelltext sagt nur "ohne Javescript geht da nix....."
            Beta-Tester
            • S stenmic
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              schrieb am zuletzt editiert von Merlin123
              #106
              @stenmic sagte in Adapter Klipper-Moonraker:
              Hab jetzt einen der Thumbs als test.png kopiert.
              Unter
              http://192.168.0.252/server/files/gcodes/.thumbs/test.png
              kommte trotzdem ein
              Die Website ist nicht erreichbar
              192.168.0.252 hat die Verbindung abgelehnt.
              Versuche Folgendes:
              Verbindung prüfen
              Proxy und Firewall prüfen
              ERR_CONNECTION_REFUSED
              Beta-Tester
                Unter
                kommte trotzdem ein
                Versuche Folgendes:
                Verbindung prüfen
                S Nicht stören
                S Nicht stören
                stenmic
                #107
                @merlin123 kommt das bild im browser wenn du den Pfad dort eingibst?
                • S stenmic
                  Merlin123M Offline
                  Merlin123M Offline
                  Merlin123
                  #108
                  @stenmic @Kammi_
                  Ursache gefunden....
                  Muss den Port mit angeben:
                  http://192.168.0.252:4409/server/files/gcodes/.thumbs/test.png
                  Jetzt nur noch das Anzeigen hinbekommen....
                  Beta-Tester
                    @stenmic @Kammi_
                    S Nicht stören
                    S Nicht stören
                    stenmic
                    #109
                    @merlin123 bei mir geht es über das Image Widget
                    Merlin123M 2 Antworten Letzte Antwort
                    • S stenmic
                      Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #110
                      @stenmic War mein erster Versuch... Aber.....
                      Rufe ich die URL
                      mit dem Browser auf kommt ein Download
                      Das gleiche, wenn ich den DP auf diese URL setzt und den als Quelle für nen iFrame nutze....
                      Beta-Tester
                      • S stenmic
                        Merlin123M Offline
                        Merlin123M Offline
                        Merlin123
                        #111
                        @stenmic Darüber ging ein erster Test, danke für den Hinweis! Aber die Auflösung scheint sehr gering zu sein (zumindest bei dem Testbild). Das war ein Temp-Tower, der in Mailsail eigentlich gut aussieht.
                        Beta-Tester
                          S Nicht stören
                          S Nicht stören
                          stenmic
                          #112
                          @merlin123 nuzt du cura?
                          bei mir haben die pngs eine Top Auflösung
                          • S stenmic
                            Merlin123M Offline
                            Merlin123M Offline
                            Merlin123
                            #113
                            @stenmic Problem gefunden :D
                            Ich hatte ein x-beliebiges File kopiert...
                            Bei mir werden immer 3 Thumbs erzeugt: 32x32, 100x100 und 320x320.
                            Ich hab ein 32x32 kopiert ;)
                            UND:
                            Ich muss an den Filenamen ein
                            -320x320
                            anhängen.
                            Damit geht es dann.
                            Also vielen Dank nochmal :)
                            Beta-Tester
                            • 1Topf1 1Topf
                              @kammi_
                              So. Ich bekomme die Zeit in den Objekten angezeigt, wenn ich in CURA das Script "Display Info on LCD" hinzufüge. Natürlich betrifft das nur die reine Druckzeit, hochheizen ist da nicht dabei.
                              Leider wird auch die Endzeit "Fertig um ..." nicht mit übermittelt.
                              Aber es gibt genug Datenpunkte, um den Drucker per smarter Steckdose auszuschalten, z.B. die Temperatur vom Druckbett.
                              Was momentan wirklich stört ist, daß der Adapter den Fehlerspeicher von ioB füllt, sobald die Verbindung zum Drucker weg ist. Und auch, daß der Adapter mit jedem neuen Druck einen Neustart benötigt.
                              Sonst hab ich nix zu meckern. 😀
                              V Offline
                              V Offline
                              Vetinari77
                              #114
                              @1topf
                              Wenn du den Drucker per Steckdose ein und ausschaltest, dann kannst du auch einfach die Instanz per script ein und ausschalten. Dann meckert das script auch nicht, das es keine Verbindung hat....
                              • 1Topf1 1Topf
                                @kammi_
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                schrieb am zuletzt editiert von Diginix
                                #115
                                @1topf sagte in Adapter Klipper-Moonraker:
                                Das mit dem Log kann ich bestätigen. Ich starte die Instanz sobald die Drucker IP pingbar ist bzw. der Drucker die MQTT Verbindung hergestellt hat (mqtt habe ich in Klipper ebenfalls aktiviert). Und sobald klipper-moonraker.0.info.connection false ist, wird die Instanz gestoppt. So bekomme ich im Log keinerlei Fehler. Wenn er einmal läuft und ich mache mehrere Drucke nacheinander, muss ich die Instanz allerdings nicht neu starten.
                                ..:: So long! Tom ::..
                                1Topf1 1 Antwort Letzte Antwort
                                • DiginixD Diginix
                                  1Topf1 Offline
                                  1Topf1 Offline
                                  1Topf
                                  #116
                                  @diginix
                                  Ich habe es anders gelöst. In der main.js /opt/iobroker/node_modules/iobroker.klipper-moonraker/main.js hab ich die Zeit für den reconnect von 10 auf 7200 Sekunden gesetzt. In Notepad++ ist das bei mir die Zeile 335.
                                  		// Handle closure of socket connection, try to connect again in 10seconds (if adapter enabled)
                                  		ws.on('close', () => {
                                  			console.log(`Connection closed`);
                                  			this.log.info(`Connection closed`);
                                  			this.setState('info.connection', false, true);
                                  			connectionState = false;
                                  			// Try to reconnect if connections is closed after 10 seconds
                                  			if (reconnectTimer) {
                                  				clearTimeout(reconnectTimer);
                                  				reconnectTimer = null;
                                  			reconnectTimer = setTimeout(() => {
                                  				console.log(`Trying to reconnect`);
                                  				this.log.info(`Trying to reconnect`);
                                  				if (this.config.auth) {
                                  					try {
                                  						this.getOneShotToken();
                                  					} catch (e) {
                                  						this.log.error(e.message);
                                  				this.handleWebSocket();
                                  			}, (7200_000));
                                  • 1Topf1 1Topf
                                    @diginix
                                    					try {
                                    					} catch (e) {
                                    			}, (7200_000));
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #117
                                    Wenn ich nicht übersehen habe ist der Adapter klipper-moonraker nicht in den Repositories verfügbar. Eine INstallation ist daher nur via GitHub möglich. Der Status des Adapters muss daher als im ALPHA Test definiert werden.
                                    Da dieses Topic nicht im Testerbereich liegt eine WARNING an alle User die sich nicht als ALPHA Tester bezeichnen:
                                    Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                                    GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                    Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                    Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                    Und falls es irgendwie unklar ist:
                                    ioBroker unterstützt folgende Arten von Installation:
                                    • aus dem STABLE Repository
                                      Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                                    • aus dem LATEST Repository
                                      Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                                    • direkt von GITHUB
                                      Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                                    • direkt von npm
                                      Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                                    Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit Sicherheit minimalistisch.
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • N Netcrusher
                                      Moin zusammen, ich habe mir ein Script geschrieben, welches periodisch die moonraker api nach den wichtigsten Infos abfragt und in iobroker Javascript States schreibt. Das wäre mit Hilfe der moonraker API-Dokumentation auch recht einfach erweiterbar.
                                      Falls es jemand gebrauchen kann (ohne Gewähr):
                                      const printerName = 'VORON'; // Replace with your actual printer name
                                      const printerBaseUrl = 'http://192.168.2.32'; // Replace with your actual moonraker ip
                                      const updateInterval = 20000; // 20 seconds
                                      // Function to make an HTTP request and return a promise
                                      function getPrinterStatus(url) {
                                          return new Promise((resolve, reject) => {
                                              const request = require('request');
                                              request(url, { json: true }, (err, res, body) => {
                                                  if (err) {
                                                      reject(err);
                                                  } else {
                                                      resolve(body);
                                      // Function to get metadata for the given filename
                                      function getFileMetadata(filename) {
                                          const metadataUrl = printerBaseUrl + `/server/files/metadata?filename=${encodeURIComponent(filename)}`;
                                          return getPrinterStatus(metadataUrl); // Reusing the HTTP request function
                                      // Function to convert seconds to HH:MM:SS
                                      function toHHMMSS(seconds) {
                                          const hours = Math.floor(seconds / 3600);
                                          const minutes = Math.floor((seconds % 3600) / 60);
                                          const sec = Math.floor(seconds % 60);
                                          return [hours, minutes, sec]
                                              .map(v => v < 10 ? "0" + v : v)
                                              .join(":");
                                      // Function to update the online status of the printer
                                      function updatePrinterOnlineStatus(isOnline) {
                                          const onlineStateName = `${printerName}.onlineStatus`;
                                          createOrUpdateState(onlineStateName, isOnline);
                                      // Function to create or update ioBroker states
                                      function createOrUpdateState(fullStateName, value, key='') {
                                          // Check if the key contains 'duration' and format it if it does
                                          if (key.includes('duration')) {
                                              value = toHHMMSS(value);
                                          // Check if the key contains 'progress' and multiply by 100 and round it if it does
                                          if (key.includes('progress')) {
                                              value = Math.round(value * 100); // Converts to percentage and rounds to the nearest integer
                                          if (!existsState(fullStateName)) {
                                              createState(fullStateName, {
                                                  type: typeof value,
                                                  read: true,
                                                  write: false,
                                                  desc: 'Printer status value'
                                                  setState(fullStateName, value, true);
                                          } else {
                                      // Function to process the printer status and update the ioBroker states
                                      function processPrinterStatus(printerData, parentKey = '') {
                                          Object.keys(printerData).forEach(key => {
                                              const value = printerData[key];
                                              let fullStateName = `${printerName}`;
                                              if (parentKey) {
                                                  fullStateName += `.${parentKey}`;
                                              fullStateName += `.${key}`;
                                              if (value !== null && typeof value === 'object' && !(value instanceof Array)) {
                                                  // It's a nested object, so we need to recurse
                                                  processPrinterStatus(value, key);
                                              } else {
                                                  // It's a value, so we create or update the state
                                                  createOrUpdateState(fullStateName, value, key);
                                      // Function to nullify file metadata states in ioBroker
                                      function nullifyFileMetadataStates() {
                                          var states = $(`*.${printerName}.file_metadata.*`/*Printer file metadata*/);
                                          states.each(function(id, i){
                                              setState(id, {val: null, ack: true});
                                      // Polling function
                                      function startPolling() {
                                          setInterval(() => {
                                              getPrinterStatus(printerBaseUrl + '/printer/objects/query?display_status&print_stats&extruder&heater_bed&system_stats')
                                                  .then(response => {
                                                      if (response && response.result) {
                                                          const printStats = response.result.status.print_stats || {};
                                                          const filename = printStats.filename;
                                                          // Update printer status
                                                          processPrinterStatus(response.result);
                                                          // If there is a filename, get and process the file metadata
                                                          if (filename) {
                                                              getFileMetadata(filename).then(metadataResponse => {
        if (metadataResponse && metadataResponse.result) {
        processPrinterStatus(metadataResponse.result, 'file_metadata');
                                                              }).catch(error => {
        console.error('Error fetching file metadata:', error);
                                                          } else {
                                                              // If filename is empty, nullify all file_metadata states
                                                              nullifyFileMetadataStates();
                                                          updatePrinterOnlineStatus(true); // Printer is online
                                                  .catch(error => {
                                                      console.log('Error fetching printer status... setting Printer offline');
                                                      updatePrinterOnlineStatus(false); // Printer is offline
                                          }, updateInterval);
                                      // Start the polling process
                                      startPolling();
                                      CaesarII
                                      #118
                                      @netcrusher
                                      dein Skript gefällt mir sehr gut. Ein dickes DANKE dafür.
                                      Allerdings hätte da 2 Wünsche.
                                      -Wäre es möglich dass der Ausgabepfad nicht in javascript.0 sondern ein Verzeichnis in 0_userdata die Daten schreibt?
                                      -Dann bekomme ich eine Fehlermeldung über "request package is deprecated - please use httpGet (or a stable lib like axios) instead!"
                                      Würde mich freuen wenn der Skript wieder ohne Fehlermeldungen funktioniert.
                                      • C CaesarII
                                        @netcrusher
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #119
                                        @caesarii auch gerne mal 0.1.1 probieren ob das problem behoben ist dass der reconnect nicht funktioniert.
                                        Videotutorials & mehr
                                        C 1 Antwort Letzte Antwort
                                        • foxriver76F foxriver76
                                          CaesarII
                                          #120
                                          @foxriver76
                                          0.1.1 installiert und auch getestet
                                          Jedoch startet der Adapter gerade bei meinem aktuellen Druck nicht richtig und liefert keine aktuellen Daten. Erst ein "Neu starten" löst das Problem. Dann funktioniert auch alles perfekt.
                                          Das andere Problem ist wenn der 3D-Drucker ausgeschaltet ist, bekomme ich quasi im Minutentackt die Error Meldung dass keine Verbindung zu moonraker besteht. Hab mir damit geholfen dass ich den Adapter erst dann starte nachdem auch den 3D-Drucker mit Spannung versorgt wird (timeout 30000).
                                          Wenn ich irgendwie behilflich sein kann kein Problem.
