  3. Off Topic
  4. Upgrade von Debian 10 'Buster' auf 11 'Bullseye'
309 Beiträge 43 Kommentatoren 110.6k Aufrufe 42 Beobachtet
  • S Supernils
    @thomas-braun said in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
    @supernils
    Das kann doch gar nicht sein.
    Bitte vollständige Ein- wie Ausgabezeilen posten. Inkl. login prompt.
    Linux raspberrypi4-iobroker 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Wed Oct 26 12:17:39 2022 from 192.168.192.2
    pi@raspberrypi4-iobroker:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
    W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
    W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
    pi@raspberrypi4-iobroker:~ $ cat /etc/debian_version
    10.13
    Thomas BraunT Offline
    #241
    @supernils sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
    Die Doubletten müssen aus den Dateien raus.
    Es darf pro Repo nur einen Eintrag im gesamten /etc/apt/* geben.
      Supernils
      #242
      Das hatte ich bereits gefixt. Hat aber nicht gebracht...
      Ich versuche es nochmal. Ich kommentiere den Eintrag
      deb http://raspbian.raspberrypi.org/raspbian/ bullseye main
      in pivpn-bullseye.list
      Ergebnis:
      Last login: Wed Oct 26 12:49:28 2022 from 192.168.192.2
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      • S Supernils
        Ergebnis:
        #243
        @supernils
        cat /etc/apt/sources.list
        cat /etc/apt/sources.list.d/*
        apt policy base-files
          @supernils
          Supernils
          #244
          @supernils
          pi@raspberrypi4-iobroker:~ $ cat /etc/apt/sources.list
          deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
          # Uncomment line below then 'apt-get update' to enable 'apt-get source'
          #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-fre        e rpi
          pi@raspberrypi4-iobroker:~ $ cat /etc/apt/sources.list.d/*
          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/no        de_16.x bullseye main
          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.co        m/node_16.x bullseye main
          #deb http://raspbian.raspberrypi.org/raspbian/ bullseye main
          deb http://archive.raspberrypi.org/debian/ bullseye main
          #deb-src http://archive.raspberrypi.org/debian/ bullseye main
          ### Disabled by raspberrypi-sys-mods ###
          pi@raspberrypi4-iobroker:~ $ apt policy base-files
          base-files:
            Installed: 10.3+rpi1+deb10u13
            Candidate: 10.3+rpi1+deb10u13
            Version table:
               11.1+rpi1+deb11u5 -1
                   -1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
           *** 10.3+rpi1+deb10u13 100
                  100 /var/lib/dpkg/status
          • S Supernils
            @supernils
            base-files:
              Version table:
            #245
            Da hast du aber mal mit dem Pinning/der Priority herumgespielt. Mit -1 gegen 100 kommt da natürlich nie was an bzw. wird nie aus dem bullseye Repo was installiert werden.
            Ich müsste aber jetzt auch buddeln, wo am das so einstellt. Es sollte in
            ls -lA /etc/apt/preferences.d/
            eine Definitionsdatei geben, wenn es richtig gemacht wurde.
              Supernils
              schrieb am zuletzt editiert von Supernils
              #246
              Ja dort liegt eine pivpn-limit-bullseye
              Package: *
              Pin: release n=bullseye
              Pin-Priority: -1
              Package: wireguard wireguard-dkms wireguard-tools
              Pin-Priority: 100
              Nach dem Löschen der Datei funktioniert das Update. Da wäre ich nie drauf gekommen. Vielen Dank.
              • S Supernils
                Package: *
                Pin-Priority: -1
                Pin-Priority: 100
                #247
                @supernils
                Das ist die Gefahr, wenn man da ThirdParty-Repos anlegt. Die können dir den Paketmanager komplett aus dem Ruder laufen lassen.
                Was ist denn pivpn-bullseye.list für Zeuch?
                  @supernils
                  Supernils
                  #248
                  @supernils
                  Das ist wireguard
                  • S Supernils
                    @supernils
                    Das ist wireguard
                    #249
                    @supernils
                    Die Quelle würde ich komplett stilllegen.
                    wireguard kommt auch über die regulären debian-Repos rein.
                      @supernils
                      Supernils
                      #250
                      @supernils
                      Aber erst nach dem Upgrade auf bullseye stilllegen, richtig? Was würde auf buster passieren?
                      • S Supernils
                        @supernils
                        #251
                        Nichts.
                          Nichts.
                          Supernils
                          #252
                          Nichts.
                          Sicher? Dann würde doch buster als Quelle verwendet werden. Unterscheiden sich die Pakete nicht?
                          • S Supernils
                            Nichts.
                            #253
                            @supernils Du hast doch jetzt alle Quellen auf bullseye gesetzt? Dann greift der Paketmanager auch auf diese Quellen zurück.
                            • S Supernils
                              Nichts.
                              #254
                              @supernils
                              Mit
                              apt policy wireguard*
                              siehst du die derzeitige Rangfolge.
                                Supernils
                                #255
                                Das bullseye Update ist nur ein Versuch auf einer 2. SD Karte. Mein Produktivsystem läuft noch auf buster. Kann ich dort auch die Quelle ändern? Dann laufe ich zukünftig nicht wieder in das Update Problem
                                • S Supernils
                                  #256
                                  Klar. Halt am besten mit den drei sed-Kommandos arbeiten, dann dürfte soweit alles umgestellt werden.
                                    Supernils
                                    #257
                                    Nach dem Upgrade auf bullseye kann ich mich nicht mit dem System verbinden. Naja egal ich bleibe dann erstmal auf buster. Ein Versuch war es wert. Ich habe etwas dazugelernt. Danke
                                    • S Supernils
                                      #258
                                      Mit welchem meinst du? Mit dem ioBroker oder mit dem Betriebssystem?
                                      Naja, wer weiß was da alles für 'schräges Zeug' installiert wurde.
                                        Supernils
                                        #259
                                        Keine Verbindung zum Betriebssystem. Oder das System bootet nicht mehr. Ich nutze übrigens eine SSD keine SD Karte.
                                        Auf dem PI wurde iobroker, wireguard und pi-hole installiert. Vielleicht sollte ich das System dann komplett neu aufsetzen.
                                        Thomas BraunT F 2 Antworten Letzte Antwort
                                        • S Supernils
                                          #260
                                          Ja, das ist auch eigentlich der vorgesehene Weg, wenn es beim Dist-Upgrade Schwierigkeiten mit den Dependencies gibt. Mit der Zahl an ThirdParty-Quellen steigt auch die Wahrscheinlichkeit sich da zu verheddern.
