  4. Fully Browser sensorinfo
    6.0k
46 Beiträge 7 Kommentatoren 6.1k Aufrufe 9 Beobachtet
  • arteckA arteck
    jetzt sind wir ein stückchen weiter..installier nochmal Bitte
    löschen der objekte nicht vergessen
    luie
    @arteck
    021-12-17 07:05:40.529 - info: host.raspberrypi "system.adapter.fullybrowser.0" enabled
    2021-12-17 07:05:40.657 - info: host.raspberrypi instance system.adapter.fullybrowser.0 started with pid 225583
    2021-12-17 07:05:41.760 - debug: fullybrowser.0 (225583) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-12-17 07:05:41.825 - debug: fullybrowser.0 (225583) Objects client ready ... initialize now
    2021-12-17 07:05:41.829 - debug: fullybrowser.0 (225583) Objects create System PubSub Client
    2021-12-17 07:05:41.831 - debug: fullybrowser.0 (225583) Objects create User PubSub Client
    2021-12-17 07:05:41.833 - debug: fullybrowser.0 (225583) Objects client initialize lua scripts
    2021-12-17 07:05:41.878 - debug: fullybrowser.0 (225583) Objects connected to redis: 127.0.0.1:9001
    2021-12-17 07:05:41.889 - debug: fullybrowser.0 (225583) objectDB connected
    2021-12-17 07:05:41.893 - debug: fullybrowser.0 (225583) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-12-17 07:05:41.939 - debug: fullybrowser.0 (225583) States create System PubSub Client
    2021-12-17 07:05:41.942 - debug: fullybrowser.0 (225583) States create User PubSub Client
    2021-12-17 07:05:42.037 - debug: fullybrowser.0 (225583) States connected to redis: 127.0.0.1:9000
    2021-12-17 07:05:42.039 - debug: fullybrowser.0 (225583) statesDB connected
    2021-12-17 07:05:42.694 - info: fullybrowser.0 (225583) starting. Version 2.0.10 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v16.13.1, js-controller: 3.3.21
    2021-12-17 07:05:42.726 - debug: fullybrowser.0 (225583) create state
    2021-12-17 07:05:42.728 - info: fullybrowser.0 (225583) Start with IP : 192.168.0.192
    2021-12-17 07:05:44.096 - warn: fullybrowser.0 (225583) Used invalid characters: fullybrowser.0.192_168_0_192.Info."sensorInfo" changed to fullybrowser.0.192_168_0_192.Info._sensorInfo_
    2021-12-17 07:05:44.121 - info: fullybrowser.0 (225583) undefined is not a valid state value for id "fullybrowser.0.192_168_0_192.Info."sensorInfo""
    2021-12-17 07:05:44.629 - debug: fullybrowser.0 (225583) get Information
    2021-12-17 07:05:45.335 - warn: fullybrowser.0 (225583) State "fullybrowser.0.192_168_0_192.Info.sensorInfo" has no existing object, this might lead to an error in future versions
    debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
    • L luie
      @arteck
      arteckA Offline
      arteckA Offline
      arteck
      @luie nochmal :-)
      L 1 Antwort Letzte Antwort
      • arteckA arteck
        @luie nochmal :-)
        luie
        @arteck
        und jetzt kommt das🙂
        2021-12-17 07:32:52.787 - debug: fullybrowser.0 (231991) create state
        2021-12-17 07:32:52.789 - info: fullybrowser.0 (231991) Start with IP : 192.168.0.192
        2021-12-17 07:32:53.226 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.batteryLevel" has to be type "number" but received type "string"
        2021-12-17 07:32:53.246 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isPlugged" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.393 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.wifiSignalLevel" has to be type "number" but received type "string"
        2021-12-17 07:32:53.414 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isMobileDataEnabled" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.430 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenOrientation" has to be type "number" but received type "string"
        2021-12-17 07:32:53.451 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenBrightness" has to be type "number" but received type "string"
        2021-12-17 07:32:53.473 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenLocked" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.497 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenOn" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.516 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.batteryTemperature" has to be type "number" but received type "string"
        2021-12-17 07:32:53.538 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.plugged" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.553 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.keyguardLocked" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.671 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.motionDetectorStatus" has to be type "number" but received type "string"
        2021-12-17 07:32:53.689 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isDeviceAdmin" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.707 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isDeviceOwner" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.752 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.internalStorageFreeSpace" has to be type "number" but received type "string"
        2021-12-17 07:32:53.784 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.internalStorageTotalSpace" has to be type "number" but received type "string"
        2021-12-17 07:32:53.806 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.externalStorageFreeSpace" has to be type "number" but received type "string"
        2021-12-17 07:32:53.826 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.externalStorageTotalSpace" has to be type "number" but received type "string"
        2021-12-17 07:32:53.848 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramUsedMemory" has to be type "number" but received type "string"
        2021-12-17 07:32:53.865 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramFreeMemory" has to be type "number" but received type "string"
        2021-12-17 07:32:53.882 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramTotalMemory" has to be type "number" but received type "string"
        2021-12-17 07:32:53.897 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appUsedMemory" has to be type "number" but received type "string"
        2021-12-17 07:32:53.917 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appFreeMemory" has to be type "number" but received type "string"
        2021-12-17 07:32:53.938 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appTotalMemory" has to be type "number" but received type "string"
        2021-12-17 07:32:53.956 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.scopedStorage" has to be type "boolean" but received type "string"
        2021-12-17 07:32:53.969 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.displayHeightPixels" has to be type "number" but received type "string"
        2021-12-17 07:32:53.986 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.displayWidthPixels" has to be type "number" but received type "string"
        2021-12-17 07:32:54.000 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isMenuOpen" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.027 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInDaydream" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.044 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isRooted" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.060 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isLicensed" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.078 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInScreensaver" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.092 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.kioskLocked" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.109 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInForcedSleep" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.123 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.maintenanceMode" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.140 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.kioskMode" has to be type "boolean" but received type "string"
        2021-12-17 07:32:54.167 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.currentTabIndex" has to be type "number" but received type "string"
        2021-12-17 07:32:54.195 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appVersionCode" has to be type "number" but received type "string"
        2021-12-17 07:32:54.222 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.androidSdk" has to be type "number" but received type "string"
        2021-12-17 07:32:54.752 - debug: fullybrowser.0 (231991) get Information
        2021-12-17 07:32:55.275 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
        • arteckA Offline
          arteckA Offline
          arteck
          nochmal :-)
          • arteckA arteck
            nochmal :-)
            luie
            @arteck
            büdde🙂
            2021-12-17 07:46:18.496 - debug: fullybrowser.0 (234691) create state
            2021-12-17 07:46:18.499 - info: fullybrowser.0 (234691) Start with IP : 192.168.0.192
            2021-12-17 07:46:19.989 - info: fullybrowser.0 (234691) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
            2021-12-17 07:46:20.421 - debug: fullybrowser.0 (234691) get Information
            2021-12-17 07:46:21.163 - info: fullybrowser.0 (234691) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
            • arteckA Offline
              arteckA Offline
              arteck
              lassmal so probieren..
              • arteckA arteck
                luie
                @arteck
                wenn noch Einer muss🙂
                2021-12-17 07:56:54.475 - debug: fullybrowser.0 (237000) create state
                2021-12-17 07:56:54.477 - info: fullybrowser.0 (237000) Start with IP : 192.168.0.192
                2021-12-17 07:56:56.277 - warn: fullybrowser.0 (237000) Generate State problem 192_168_0_192 {}
                2021-12-17 07:56:56.694 - debug: fullybrowser.0 (237000) get Information
                2021-12-17 07:56:58.153 - info: fullybrowser.0 (237000) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                • L luie
                  @arteck
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @luie so jetzt nochmal..
                  wenn nicht dann würde ich gerne mal auf dein system drauf.. kein plan was da drin steht
                  • arteckA arteck
                    luie
                    @arteck
                    das war es wohl auch nicht und dein Angebot zur "Systembesichtigung" nehme ich gerne an. Danke für deinen Einsatz und die Zeit.
                    2021-12-17 08:11:37.340 - debug: fullybrowser.0 (240254) create state
                    2021-12-17 08:11:37.341 - info: fullybrowser.0 (240254) Start with IP : 192.168.0.192
                    2021-12-17 08:11:38.841 - info: fullybrowser.0 (240254) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                    2021-12-17 08:11:39.246 - debug: fullybrowser.0 (240254) get Information
                    2021-12-17 08:11:39.854 - info: fullybrowser.0 (240254) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                    • L luie
                      @arteck
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @luie hast die datenunkte auch gelöscht ?
                      • arteckA arteck
                        luie
                        @arteck
                        jepp und nochmal getestet mit dem gleichem Ergebnis
                        • L luie
                          @arteck
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @luie so jetzt aber.. mensch mensch mensch...wenn nicht dann heute abend
                          • arteckA arteck
                            luie
                            @arteck
                            leider wieder nüscht☺ , dann aber heute Abend
                            2021-12-17 13:53:43.814 - debug: fullybrowser.0 (313156) create state
                            2021-12-17 13:53:43.816 - info: fullybrowser.0 (313156) Start with IP : 192.168.0.192
                            2021-12-17 13:53:45.493 - info: fullybrowser.0 (313156) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
                            2021-12-17 13:53:46.002 - debug: fullybrowser.0 (313156) get Information
                            2021-12-17 13:53:46.534 - info: fullybrowser.0 (313156) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
                            • L Offline
                              luie
                              schrieb am zuletzt editiert von luie
                              @mcu
                              @arteck hat das Problem mit dem "sensorInfo" - Fehler gelöst und eine aktuelle Version hochgeladen.
                              Danke nochmal für die Zeit und den Einsatz zur Lösung dieses "einmaligen" Fehlers.👍
                              • L luie
                                @mcu
                                MCU
                                @arteck
                                Zunächst einmal Frohe Weihnachten.
                                Adapter-Version 2.0.12
                                Es kommen immer wieder die gleichen Meldungen:
                                Zusätzlich wird jetzt immer im LOG dies angezeigt:
                                State "fullybrowser.0.192_168_178_20.Info.foregroundActivity" has no existing object, this might lead to an error in future versions
                                Obwohl der FullyBrowser auf einem Gerät (192.168.178.20) gestartet ist , wird dieses als "nicht verbunden" angezeigt.
                                Ich kann aber trotzdem textTpSpeech nutzen?
                                Objekte habe ich einmal komplett gelöscht, Instanz neugestartet.
                                Was kann ich sonst noch tun?
                                Vielen Dank.
                                • M MCU
                                  @arteck
                                  Vielen Dank.
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @mcu deine Fehler haben nix mit dem Adapter zu tun.. wenn die ien UpdateDeviceError hast dann antwortet dein Tablet nicht in der vorgegebenen Zeit..
                                  ist so.. entweder liegts am WLAN bie dir oder am Tablet.. nicht am Adapter...
                                  der Datenpunkt foregroundActivity wurde bestimmt nicht angelegt.. da hier jedes Tablet was anderes an datenpunkten liefert ..
                                  stoppe den adapter
                                  lösche alle object und
                                  starte den adapter wieder
                                  die Datenpunkte werden jetzt alle nochmal dynamisch angelegt.. so wie es sein soll.. zumindest so der plan..
                                  @MCU
                                  • FullyBrowser auf einem Gerät (192.168.178.20) gestartet ist
                                  damit kann ich nix anfangen.. ist das Tablet nicht ereichbar .. weil kein WLAN ..oder schlechtes WLAN oder psw ist falsch oder ADMIN am Tablet nicht aktiviert...
                                  also alles nochmal checken bitte..
                                  • arteckA arteck
                                    stoppe den adapter
                                    @MCU
                                    MCU
                                    @arteck
                                    Sorry für die lange Wartezeit. System-Hardware-Defekt.
                                    Habe es nach Deiner Anleitung mit 2.0.12 versucht, funktionierte aber nicht. Bin auf 2.0.9 zurück und es funktioniert.
                                    Du hattest in der 2.0.10 glaube ich die Zeiten verändert, vielleicht liegt es daran?
                                    Was kann ich liefern, um das Problem einzugrenzen?
                                    • F Offline
                                      Frank63
                                      Ich habe auch diese Fehler mit der Version 2.0.12:
                                      fullybrowser.0
                                      2022-01-07 11:23:59.660	warn	updateDeviceERROR 192.168.2.165
                                      fullybrowser.0
                                      2022-01-07 11:22:59.133	warn	updateDeviceERROR 192.168.2.165
                                      fullybrowser.0
                                      2022-01-07 11:21:58.797	warn	updateDeviceERROR 192.168.2.165
                                      fullybrowser.0
                                      2022-01-07 11:20:58.419	warn	updateDeviceERROR 192.168.2.165
                                      fullybrowser.0
                                      2022-01-07 11:19:58.098	warn	updateDeviceERROR 192.168.2.165
                                      Das Tablet ist definitiv netzmäßig erreichbar und alle Datenpunkte des Adapters werden aktualisiert. Der Datenpunkt fullybrowser.0.192_168_2_165.isFullyAlive ist aber false. Nach dem Downgrade auf Version 2.0.10 läuft wieder alles, nur bekommen ich dann wieder diese Fehlermeldungen:
                                      fullybrowser.0
                                      2022-01-07 11:38:25.975	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                      fullybrowser.0
                                      2022-01-07 11:37:24.186	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                      fullybrowser.0
                                      2022-01-07 11:36:23.100	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                      • F Frank63
                                        fullybrowser.0
                                        fullybrowser.0
                                        fullybrowser.0
                                        fullybrowser.0
                                        fullybrowser.0
                                        fullybrowser.0
                                        fullybrowser.0
                                        fullybrowser.0
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @frank63 stell den adapter auf debug bitte
                                        F 1 Antwort Letzte Antwort
                                        • arteckA arteck
                                          Frank63
                                          @arteck
                                          Hier die Debugausgaben:
                                          fullybrowser.0
                                          2022-01-07 11:52:46.479	warn	updateDeviceERROR 192.168.2.165
                                          fullybrowser.0
                                          2022-01-07 11:52:45.440	debug	get Information
                                          fullybrowser.0
                                          2022-01-07 11:50:59.662	debug	mqtt.0.Smarthome.zigbee.bridge: logging {"level":"debug","message":"Saving state to file /opt/zigbee2mqtt/data/state.json"}
                                          fullybrowser.0
                                          2022-01-07 11:50:45.429	warn	updateDeviceERROR 192.168.2.165
                                          fullybrowser.0
                                          2022-01-07 11:50:44.954	debug	get Information
                                          fullybrowser.0
                                          2022-01-07 11:50:44.904	info	State value to set for "fullybrowser.0.192_168_2_165.Commands.screenBrightness" has to be type "number" but received type "string"
                                          fullybrowser.0
                                          2022-01-07 11:50:42.128	info	Start with IP : 192.168.2.165
                                          fullybrowser.0
                                          2022-01-07 11:50:42.127	debug	create state
                                          fullybrowser.0
                                          2022-01-07 11:50:42.079	info	starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v14.18.1, js-controller: 3.3.22
                                          fullybrowser.0
                                          2022-01-07 11:50:40.988	debug	statesDB connected
                                          fullybrowser.0
                                          2022-01-07 11:50:40.987	debug	States connected to redis: 127.0.0.1:9000
                                          fullybrowser.0
                                          2022-01-07 11:50:40.967	debug	States create User PubSub Client
                                          fullybrowser.0
                                          2022-01-07 11:50:40.966	debug	States create System PubSub Client
                                          fullybrowser.0
                                          2022-01-07 11:50:40.914	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                          fullybrowser.0
                                          2022-01-07 11:50:40.905	debug	objectDB connected
                                          fullybrowser.0
                                          2022-01-07 11:50:40.874	debug	Objects connected to redis: 127.0.0.1:9001
                                          fullybrowser.0
                                          2022-01-07 11:50:40.844	debug	Objects client initialize lua scripts
                                          fullybrowser.0
                                          2022-01-07 11:50:40.842	debug	Objects create User PubSub Client
                                          fullybrowser.0
                                          2022-01-07 11:50:40.840	debug	Objects create System PubSub Client
                                          fullybrowser.0
                                          2022-01-07 11:50:40.815	debug	Objects client ready ... initialize now
                                          fullybrowser.0
                                          2022-01-07 11:50:40.572	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          Den Timeout habe ich mal testweise von 2000 auf 5000 msec erhöht, hat aber nichts gebracht...
