  4. Fully Browser sensorinfo
    6.0k
46 Beiträge 7 Kommentatoren 6.1k Aufrufe 9 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    jetzt sind wir ein stückchen weiter..installier nochmal Bitte
    löschen der objekte nicht vergessen
    L 1 Antwort Letzte Antwort
    • arteckA arteck
      luie
      @arteck
      021-12-17 07:05:40.529 - info: host.raspberrypi "system.adapter.fullybrowser.0" enabled
      2021-12-17 07:05:40.657 - info: host.raspberrypi instance system.adapter.fullybrowser.0 started with pid 225583
      2021-12-17 07:05:41.760 - debug: fullybrowser.0 (225583) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-12-17 07:05:41.825 - debug: fullybrowser.0 (225583) Objects client ready ... initialize now
      2021-12-17 07:05:41.829 - debug: fullybrowser.0 (225583) Objects create System PubSub Client
      2021-12-17 07:05:41.831 - debug: fullybrowser.0 (225583) Objects create User PubSub Client
      2021-12-17 07:05:41.833 - debug: fullybrowser.0 (225583) Objects client initialize lua scripts
      2021-12-17 07:05:41.878 - debug: fullybrowser.0 (225583) Objects connected to redis: 127.0.0.1:9001
      2021-12-17 07:05:41.889 - debug: fullybrowser.0 (225583) objectDB connected
      2021-12-17 07:05:41.893 - debug: fullybrowser.0 (225583) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-12-17 07:05:41.939 - debug: fullybrowser.0 (225583) States create System PubSub Client
      2021-12-17 07:05:41.942 - debug: fullybrowser.0 (225583) States create User PubSub Client
      2021-12-17 07:05:42.037 - debug: fullybrowser.0 (225583) States connected to redis: 127.0.0.1:9000
      2021-12-17 07:05:42.039 - debug: fullybrowser.0 (225583) statesDB connected
      2021-12-17 07:05:42.694 - info: fullybrowser.0 (225583) starting. Version 2.0.10 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v16.13.1, js-controller: 3.3.21
      2021-12-17 07:05:42.726 - debug: fullybrowser.0 (225583) create state
      2021-12-17 07:05:42.728 - info: fullybrowser.0 (225583) Start with IP : 192.168.0.192
      2021-12-17 07:05:44.096 - warn: fullybrowser.0 (225583) Used invalid characters: fullybrowser.0.192_168_0_192.Info."sensorInfo" changed to fullybrowser.0.192_168_0_192.Info._sensorInfo_
      2021-12-17 07:05:44.121 - info: fullybrowser.0 (225583) undefined is not a valid state value for id "fullybrowser.0.192_168_0_192.Info."sensorInfo""
      2021-12-17 07:05:44.629 - debug: fullybrowser.0 (225583) get Information
      2021-12-17 07:05:45.335 - warn: fullybrowser.0 (225583) State "fullybrowser.0.192_168_0_192.Info.sensorInfo" has no existing object, this might lead to an error in future versions
      debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
      • L luie
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        @luie nochmal :-)
        • arteckA arteck
          @luie nochmal :-)
          luie
          @arteck
          und jetzt kommt das🙂
          2021-12-17 07:32:52.787 - debug: fullybrowser.0 (231991) create state
          2021-12-17 07:32:52.789 - info: fullybrowser.0 (231991) Start with IP : 192.168.0.192
          2021-12-17 07:32:53.226 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.batteryLevel" has to be type "number" but received type "string"
          2021-12-17 07:32:53.246 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isPlugged" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.393 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.wifiSignalLevel" has to be type "number" but received type "string"
          2021-12-17 07:32:53.414 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isMobileDataEnabled" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.430 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenOrientation" has to be type "number" but received type "string"
          2021-12-17 07:32:53.451 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenBrightness" has to be type "number" but received type "string"
          2021-12-17 07:32:53.473 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenLocked" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.497 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenOn" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.516 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.batteryTemperature" has to be type "number" but received type "string"
          2021-12-17 07:32:53.538 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.plugged" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.553 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.keyguardLocked" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.671 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.motionDetectorStatus" has to be type "number" but received type "string"
          2021-12-17 07:32:53.689 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isDeviceAdmin" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.707 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isDeviceOwner" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.752 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.internalStorageFreeSpace" has to be type "number" but received type "string"
          2021-12-17 07:32:53.784 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.internalStorageTotalSpace" has to be type "number" but received type "string"
          2021-12-17 07:32:53.806 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.externalStorageFreeSpace" has to be type "number" but received type "string"
          2021-12-17 07:32:53.826 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.externalStorageTotalSpace" has to be type "number" but received type "string"
          2021-12-17 07:32:53.848 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramUsedMemory" has to be type "number" but received type "string"
          2021-12-17 07:32:53.865 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramFreeMemory" has to be type "number" but received type "string"
          2021-12-17 07:32:53.882 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramTotalMemory" has to be type "number" but received type "string"
          2021-12-17 07:32:53.897 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appUsedMemory" has to be type "number" but received type "string"
          2021-12-17 07:32:53.917 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appFreeMemory" has to be type "number" but received type "string"
          2021-12-17 07:32:53.938 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appTotalMemory" has to be type "number" but received type "string"
          2021-12-17 07:32:53.956 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.scopedStorage" has to be type "boolean" but received type "string"
          2021-12-17 07:32:53.969 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.displayHeightPixels" has to be type "number" but received type "string"
          2021-12-17 07:32:53.986 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.displayWidthPixels" has to be type "number" but received type "string"
          2021-12-17 07:32:54.000 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isMenuOpen" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.027 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInDaydream" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.044 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isRooted" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.060 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isLicensed" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.078 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInScreensaver" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.092 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.kioskLocked" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.109 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInForcedSleep" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.123 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.maintenanceMode" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.140 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.kioskMode" has to be type "boolean" but received type "string"
          2021-12-17 07:32:54.167 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.currentTabIndex" has to be type "number" but received type "string"
          2021-12-17 07:32:54.195 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appVersionCode" has to be type "number" but received type "string"
          2021-12-17 07:32:54.222 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.androidSdk" has to be type "number" but received type "string"
          2021-12-17 07:32:54.752 - debug: fullybrowser.0 (231991) get Information
          2021-12-17 07:32:55.275 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
          • arteckA Offline
            arteckA Offline
            arteck
            nochmal :-)
            • arteckA arteck
              nochmal :-)
              luie
              @arteck
              büdde🙂
              2021-12-17 07:46:18.496 - debug: fullybrowser.0 (234691) create state
              2021-12-17 07:46:18.499 - info: fullybrowser.0 (234691) Start with IP : 192.168.0.192
              2021-12-17 07:46:19.989 - info: fullybrowser.0 (234691) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
              2021-12-17 07:46:20.421 - debug: fullybrowser.0 (234691) get Information
              2021-12-17 07:46:21.163 - info: fullybrowser.0 (234691) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
              • arteckA Offline
                arteckA Offline
                arteck
                lassmal so probieren..
                • arteckA arteck
                  luie
                  @arteck
                  wenn noch Einer muss🙂
                  2021-12-17 07:56:54.475 - debug: fullybrowser.0 (237000) create state
                  2021-12-17 07:56:54.477 - info: fullybrowser.0 (237000) Start with IP : 192.168.0.192
                  2021-12-17 07:56:56.277 - warn: fullybrowser.0 (237000) Generate State problem 192_168_0_192 {}
                  2021-12-17 07:56:56.694 - debug: fullybrowser.0 (237000) get Information
                  2021-12-17 07:56:58.153 - info: fullybrowser.0 (237000) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                  • L luie
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @luie so jetzt nochmal..
                    wenn nicht dann würde ich gerne mal auf dein system drauf.. kein plan was da drin steht
                    • arteckA arteck
                      luie
                      @arteck
                      das war es wohl auch nicht und dein Angebot zur "Systembesichtigung" nehme ich gerne an. Danke für deinen Einsatz und die Zeit.
                      2021-12-17 08:11:37.340 - debug: fullybrowser.0 (240254) create state
                      2021-12-17 08:11:37.341 - info: fullybrowser.0 (240254) Start with IP : 192.168.0.192
                      2021-12-17 08:11:38.841 - info: fullybrowser.0 (240254) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                      2021-12-17 08:11:39.246 - debug: fullybrowser.0 (240254) get Information
                      2021-12-17 08:11:39.854 - info: fullybrowser.0 (240254) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                      • L luie
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @luie hast die datenunkte auch gelöscht ?
                        • arteckA arteck
                          luie
                          @arteck
                          jepp und nochmal getestet mit dem gleichem Ergebnis
                          • L luie
                            @arteck
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @luie so jetzt aber.. mensch mensch mensch...wenn nicht dann heute abend
                            • arteckA arteck
                              luie
                              @arteck
                              leider wieder nüscht☺ , dann aber heute Abend
                              2021-12-17 13:53:43.814 - debug: fullybrowser.0 (313156) create state
                              2021-12-17 13:53:43.816 - info: fullybrowser.0 (313156) Start with IP : 192.168.0.192
                              2021-12-17 13:53:45.493 - info: fullybrowser.0 (313156) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
                              2021-12-17 13:53:46.002 - debug: fullybrowser.0 (313156) get Information
                              2021-12-17 13:53:46.534 - info: fullybrowser.0 (313156) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
                              • L Offline
                                luie
                                schrieb am zuletzt editiert von luie
                                @mcu
                                @arteck hat das Problem mit dem "sensorInfo" - Fehler gelöst und eine aktuelle Version hochgeladen.
                                Danke nochmal für die Zeit und den Einsatz zur Lösung dieses "einmaligen" Fehlers.👍
                                • L luie
                                  @mcu
                                  MCU
                                  @arteck
                                  Zunächst einmal Frohe Weihnachten.
                                  Adapter-Version 2.0.12
                                  Es kommen immer wieder die gleichen Meldungen:
                                  Zusätzlich wird jetzt immer im LOG dies angezeigt:
                                  State "fullybrowser.0.192_168_178_20.Info.foregroundActivity" has no existing object, this might lead to an error in future versions
                                  Obwohl der FullyBrowser auf einem Gerät (192.168.178.20) gestartet ist , wird dieses als "nicht verbunden" angezeigt.
                                  Ich kann aber trotzdem textTpSpeech nutzen?
                                  Objekte habe ich einmal komplett gelöscht, Instanz neugestartet.
                                  Was kann ich sonst noch tun?
                                  Vielen Dank.
                                  • M MCU
                                    @arteck
                                    Vielen Dank.
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @mcu deine Fehler haben nix mit dem Adapter zu tun.. wenn die ien UpdateDeviceError hast dann antwortet dein Tablet nicht in der vorgegebenen Zeit..
                                    ist so.. entweder liegts am WLAN bie dir oder am Tablet.. nicht am Adapter...
                                    der Datenpunkt foregroundActivity wurde bestimmt nicht angelegt.. da hier jedes Tablet was anderes an datenpunkten liefert ..
                                    stoppe den adapter
                                    lösche alle object und
                                    starte den adapter wieder
                                    die Datenpunkte werden jetzt alle nochmal dynamisch angelegt.. so wie es sein soll.. zumindest so der plan..
                                    @MCU
                                    • FullyBrowser auf einem Gerät (192.168.178.20) gestartet ist
                                    damit kann ich nix anfangen.. ist das Tablet nicht ereichbar .. weil kein WLAN ..oder schlechtes WLAN oder psw ist falsch oder ADMIN am Tablet nicht aktiviert...
                                    also alles nochmal checken bitte..
                                    • arteckA arteck
                                      stoppe den adapter
                                      @MCU
                                      MCU
                                      @arteck
                                      Sorry für die lange Wartezeit. System-Hardware-Defekt.
                                      Habe es nach Deiner Anleitung mit 2.0.12 versucht, funktionierte aber nicht. Bin auf 2.0.9 zurück und es funktioniert.
                                      Du hattest in der 2.0.10 glaube ich die Zeiten verändert, vielleicht liegt es daran?
                                      Was kann ich liefern, um das Problem einzugrenzen?
                                      • F Offline
                                        Frank63
                                        Ich habe auch diese Fehler mit der Version 2.0.12:
                                        fullybrowser.0
                                        2022-01-07 11:23:59.660	warn	updateDeviceERROR 192.168.2.165
                                        fullybrowser.0
                                        2022-01-07 11:22:59.133	warn	updateDeviceERROR 192.168.2.165
                                        fullybrowser.0
                                        2022-01-07 11:21:58.797	warn	updateDeviceERROR 192.168.2.165
                                        fullybrowser.0
                                        2022-01-07 11:20:58.419	warn	updateDeviceERROR 192.168.2.165
                                        fullybrowser.0
                                        2022-01-07 11:19:58.098	warn	updateDeviceERROR 192.168.2.165
                                        Das Tablet ist definitiv netzmäßig erreichbar und alle Datenpunkte des Adapters werden aktualisiert. Der Datenpunkt fullybrowser.0.192_168_2_165.isFullyAlive ist aber false. Nach dem Downgrade auf Version 2.0.10 läuft wieder alles, nur bekommen ich dann wieder diese Fehlermeldungen:
                                        fullybrowser.0
                                        2022-01-07 11:38:25.975	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                        fullybrowser.0
                                        2022-01-07 11:37:24.186	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                        fullybrowser.0
                                        2022-01-07 11:36:23.100	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                        • F Frank63
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @frank63 stell den adapter auf debug bitte
                                          F 1 Antwort Letzte Antwort
