  4. Fully Browser sensorinfo
    6.0k
46 Beiträge 7 Kommentatoren 6.1k Aufrufe 9 Beobachtet
  • L luie
    @arteck
    021-12-17 07:05:40.529 - info: host.raspberrypi "system.adapter.fullybrowser.0" enabled
    2021-12-17 07:05:40.657 - info: host.raspberrypi instance system.adapter.fullybrowser.0 started with pid 225583
    2021-12-17 07:05:41.760 - debug: fullybrowser.0 (225583) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-12-17 07:05:41.825 - debug: fullybrowser.0 (225583) Objects client ready ... initialize now
    2021-12-17 07:05:41.829 - debug: fullybrowser.0 (225583) Objects create System PubSub Client
    2021-12-17 07:05:41.831 - debug: fullybrowser.0 (225583) Objects create User PubSub Client
    2021-12-17 07:05:41.833 - debug: fullybrowser.0 (225583) Objects client initialize lua scripts
    2021-12-17 07:05:41.878 - debug: fullybrowser.0 (225583) Objects connected to redis: 127.0.0.1:9001
    2021-12-17 07:05:41.889 - debug: fullybrowser.0 (225583) objectDB connected
    2021-12-17 07:05:41.893 - debug: fullybrowser.0 (225583) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-12-17 07:05:41.939 - debug: fullybrowser.0 (225583) States create System PubSub Client
    2021-12-17 07:05:41.942 - debug: fullybrowser.0 (225583) States create User PubSub Client
    2021-12-17 07:05:42.037 - debug: fullybrowser.0 (225583) States connected to redis: 127.0.0.1:9000
    2021-12-17 07:05:42.039 - debug: fullybrowser.0 (225583) statesDB connected
    2021-12-17 07:05:42.694 - info: fullybrowser.0 (225583) starting. Version 2.0.10 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v16.13.1, js-controller: 3.3.21
    2021-12-17 07:05:42.726 - debug: fullybrowser.0 (225583) create state
    2021-12-17 07:05:42.728 - info: fullybrowser.0 (225583) Start with IP : 192.168.0.192
    2021-12-17 07:05:44.096 - warn: fullybrowser.0 (225583) Used invalid characters: fullybrowser.0.192_168_0_192.Info."sensorInfo" changed to fullybrowser.0.192_168_0_192.Info._sensorInfo_
    2021-12-17 07:05:44.121 - info: fullybrowser.0 (225583) undefined is not a valid state value for id "fullybrowser.0.192_168_0_192.Info."sensorInfo""
    2021-12-17 07:05:44.629 - debug: fullybrowser.0 (225583) get Information
    2021-12-17 07:05:45.335 - warn: fullybrowser.0 (225583) State "fullybrowser.0.192_168_0_192.Info.sensorInfo" has no existing object, this might lead to an error in future versions
    arteckA Offline
    arteckA Offline
    arteck
    @luie nochmal :-)
    L 1 Antwort Letzte Antwort
    • arteckA arteck
      @luie nochmal :-)
      luie
      @arteck
      und jetzt kommt das🙂
      2021-12-17 07:32:52.787 - debug: fullybrowser.0 (231991) create state
      2021-12-17 07:32:52.789 - info: fullybrowser.0 (231991) Start with IP : 192.168.0.192
      2021-12-17 07:32:53.226 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.batteryLevel" has to be type "number" but received type "string"
      2021-12-17 07:32:53.246 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isPlugged" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.393 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.wifiSignalLevel" has to be type "number" but received type "string"
      2021-12-17 07:32:53.414 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isMobileDataEnabled" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.430 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenOrientation" has to be type "number" but received type "string"
      2021-12-17 07:32:53.451 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenBrightness" has to be type "number" but received type "string"
      2021-12-17 07:32:53.473 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenLocked" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.497 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.screenOn" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.516 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.batteryTemperature" has to be type "number" but received type "string"
      2021-12-17 07:32:53.538 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.plugged" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.553 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.keyguardLocked" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.671 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.motionDetectorStatus" has to be type "number" but received type "string"
      2021-12-17 07:32:53.689 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isDeviceAdmin" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.707 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isDeviceOwner" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.752 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.internalStorageFreeSpace" has to be type "number" but received type "string"
      2021-12-17 07:32:53.784 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.internalStorageTotalSpace" has to be type "number" but received type "string"
      2021-12-17 07:32:53.806 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.externalStorageFreeSpace" has to be type "number" but received type "string"
      2021-12-17 07:32:53.826 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.externalStorageTotalSpace" has to be type "number" but received type "string"
      2021-12-17 07:32:53.848 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramUsedMemory" has to be type "number" but received type "string"
      2021-12-17 07:32:53.865 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramFreeMemory" has to be type "number" but received type "string"
      2021-12-17 07:32:53.882 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.ramTotalMemory" has to be type "number" but received type "string"
      2021-12-17 07:32:53.897 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appUsedMemory" has to be type "number" but received type "string"
      2021-12-17 07:32:53.917 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appFreeMemory" has to be type "number" but received type "string"
      2021-12-17 07:32:53.938 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appTotalMemory" has to be type "number" but received type "string"
      2021-12-17 07:32:53.956 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.scopedStorage" has to be type "boolean" but received type "string"
      2021-12-17 07:32:53.969 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.displayHeightPixels" has to be type "number" but received type "string"
      2021-12-17 07:32:53.986 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.displayWidthPixels" has to be type "number" but received type "string"
      2021-12-17 07:32:54.000 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isMenuOpen" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.027 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInDaydream" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.044 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isRooted" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.060 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isLicensed" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.078 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInScreensaver" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.092 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.kioskLocked" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.109 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.isInForcedSleep" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.123 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.maintenanceMode" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.140 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.kioskMode" has to be type "boolean" but received type "string"
      2021-12-17 07:32:54.167 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.currentTabIndex" has to be type "number" but received type "string"
      2021-12-17 07:32:54.195 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.appVersionCode" has to be type "number" but received type "string"
      2021-12-17 07:32:54.222 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.androidSdk" has to be type "number" but received type "string"
      2021-12-17 07:32:54.752 - debug: fullybrowser.0 (231991) get Information
      2021-12-17 07:32:55.275 - info: fullybrowser.0 (231991) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
      debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
      • arteckA Offline
        arteckA Offline
        arteck
        nochmal :-)
        • arteckA arteck
          nochmal :-)
          luie
          @arteck
          büdde🙂
          2021-12-17 07:46:18.496 - debug: fullybrowser.0 (234691) create state
          2021-12-17 07:46:18.499 - info: fullybrowser.0 (234691) Start with IP : 192.168.0.192
          2021-12-17 07:46:19.989 - info: fullybrowser.0 (234691) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
          2021-12-17 07:46:20.421 - debug: fullybrowser.0 (234691) get Information
          2021-12-17 07:46:21.163 - info: fullybrowser.0 (234691) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
          • arteckA Offline
            arteckA Offline
            arteck
            lassmal so probieren..
            • arteckA arteck
              luie
              @arteck
              wenn noch Einer muss🙂
              2021-12-17 07:56:54.475 - debug: fullybrowser.0 (237000) create state
              2021-12-17 07:56:54.477 - info: fullybrowser.0 (237000) Start with IP : 192.168.0.192
              2021-12-17 07:56:56.277 - warn: fullybrowser.0 (237000) Generate State problem 192_168_0_192 {}
              2021-12-17 07:56:56.694 - debug: fullybrowser.0 (237000) get Information
              2021-12-17 07:56:58.153 - info: fullybrowser.0 (237000) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
              • L luie
                @arteck
                arteckA Offline
                arteckA Offline
                arteck
                @luie so jetzt nochmal..
                wenn nicht dann würde ich gerne mal auf dein system drauf.. kein plan was da drin steht
                • arteckA arteck
                  luie
                  @arteck
                  das war es wohl auch nicht und dein Angebot zur "Systembesichtigung" nehme ich gerne an. Danke für deinen Einsatz und die Zeit.
                  2021-12-17 08:11:37.340 - debug: fullybrowser.0 (240254) create state
                  2021-12-17 08:11:37.341 - info: fullybrowser.0 (240254) Start with IP : 192.168.0.192
                  2021-12-17 08:11:38.841 - info: fullybrowser.0 (240254) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                  2021-12-17 08:11:39.246 - debug: fullybrowser.0 (240254) get Information
                  2021-12-17 08:11:39.854 - info: fullybrowser.0 (240254) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be stringified but received type "object"
                  • L luie
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @luie hast die datenunkte auch gelöscht ?
                    • arteckA arteck
                      luie
                      @arteck
                      jepp und nochmal getestet mit dem gleichem Ergebnis
                      • L luie
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @luie so jetzt aber.. mensch mensch mensch...wenn nicht dann heute abend
                        • arteckA arteck
                          luie
                          @arteck
                          leider wieder nüscht☺ , dann aber heute Abend
                          2021-12-17 13:53:43.814 - debug: fullybrowser.0 (313156) create state
                          2021-12-17 13:53:43.816 - info: fullybrowser.0 (313156) Start with IP : 192.168.0.192
                          2021-12-17 13:53:45.493 - info: fullybrowser.0 (313156) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
                          2021-12-17 13:53:46.002 - debug: fullybrowser.0 (313156) get Information
                          2021-12-17 13:53:46.534 - info: fullybrowser.0 (313156) State value to set for "fullybrowser.0.192_168_0_192.Info.sensorInfo" has to be type "string" but received type "object"
                          • L Offline
                            luie
                            schrieb am zuletzt editiert von luie
                            @mcu
                            @arteck hat das Problem mit dem "sensorInfo" - Fehler gelöst und eine aktuelle Version hochgeladen.
                            Danke nochmal für die Zeit und den Einsatz zur Lösung dieses "einmaligen" Fehlers.👍
                            • L luie
                              @mcu
                              MCU
                              @arteck
                              Zunächst einmal Frohe Weihnachten.
                              Adapter-Version 2.0.12
                              Es kommen immer wieder die gleichen Meldungen:
                              Zusätzlich wird jetzt immer im LOG dies angezeigt:
                              State "fullybrowser.0.192_168_178_20.Info.foregroundActivity" has no existing object, this might lead to an error in future versions
                              Obwohl der FullyBrowser auf einem Gerät (192.168.178.20) gestartet ist , wird dieses als "nicht verbunden" angezeigt.
                              Ich kann aber trotzdem textTpSpeech nutzen?
                              Objekte habe ich einmal komplett gelöscht, Instanz neugestartet.
                              Was kann ich sonst noch tun?
                              Vielen Dank.
                              • M MCU
                                @arteck
                                Vielen Dank.
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @mcu deine Fehler haben nix mit dem Adapter zu tun.. wenn die ien UpdateDeviceError hast dann antwortet dein Tablet nicht in der vorgegebenen Zeit..
                                ist so.. entweder liegts am WLAN bie dir oder am Tablet.. nicht am Adapter...
                                der Datenpunkt foregroundActivity wurde bestimmt nicht angelegt.. da hier jedes Tablet was anderes an datenpunkten liefert ..
                                stoppe den adapter
                                lösche alle object und
                                starte den adapter wieder
                                die Datenpunkte werden jetzt alle nochmal dynamisch angelegt.. so wie es sein soll.. zumindest so der plan..
                                @MCU
                                • FullyBrowser auf einem Gerät (192.168.178.20) gestartet ist
                                damit kann ich nix anfangen.. ist das Tablet nicht ereichbar .. weil kein WLAN ..oder schlechtes WLAN oder psw ist falsch oder ADMIN am Tablet nicht aktiviert...
                                also alles nochmal checken bitte..
                                • arteckA arteck
                                  stoppe den adapter
                                  @MCU
                                  MCU
                                  @arteck
                                  Sorry für die lange Wartezeit. System-Hardware-Defekt.
                                  Habe es nach Deiner Anleitung mit 2.0.12 versucht, funktionierte aber nicht. Bin auf 2.0.9 zurück und es funktioniert.
                                  Du hattest in der 2.0.10 glaube ich die Zeiten verändert, vielleicht liegt es daran?
                                  Was kann ich liefern, um das Problem einzugrenzen?
                                  • F Offline
                                    Frank63
                                    Ich habe auch diese Fehler mit der Version 2.0.12:
                                    fullybrowser.0
                                    2022-01-07 11:23:59.660	warn	updateDeviceERROR 192.168.2.165
                                    fullybrowser.0
                                    2022-01-07 11:22:59.133	warn	updateDeviceERROR 192.168.2.165
                                    fullybrowser.0
                                    2022-01-07 11:21:58.797	warn	updateDeviceERROR 192.168.2.165
                                    fullybrowser.0
                                    2022-01-07 11:20:58.419	warn	updateDeviceERROR 192.168.2.165
                                    fullybrowser.0
                                    2022-01-07 11:19:58.098	warn	updateDeviceERROR 192.168.2.165
                                    Das Tablet ist definitiv netzmäßig erreichbar und alle Datenpunkte des Adapters werden aktualisiert. Der Datenpunkt fullybrowser.0.192_168_2_165.isFullyAlive ist aber false. Nach dem Downgrade auf Version 2.0.10 läuft wieder alles, nur bekommen ich dann wieder diese Fehlermeldungen:
                                    fullybrowser.0
                                    2022-01-07 11:38:25.975	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                    fullybrowser.0
                                    2022-01-07 11:37:24.186	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                    fullybrowser.0
                                    2022-01-07 11:36:23.100	info	State value to set for "fullybrowser.0.192_168_2_165.Info.sensorInfo" has to be stringified but received type "object"
                                    • F Frank63
                                      fullybrowser.0
                                      fullybrowser.0
                                      fullybrowser.0
                                      fullybrowser.0
                                      fullybrowser.0
                                      fullybrowser.0
                                      fullybrowser.0
                                      fullybrowser.0
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @frank63 stell den adapter auf debug bitte
                                      F 1 Antwort Letzte Antwort
                                      • arteckA arteck
                                        Frank63
                                        @arteck
                                        Hier die Debugausgaben:
                                        fullybrowser.0
                                        2022-01-07 11:52:46.479	warn	updateDeviceERROR 192.168.2.165
                                        fullybrowser.0
                                        2022-01-07 11:52:45.440	debug	get Information
                                        fullybrowser.0
                                        2022-01-07 11:50:59.662	debug	mqtt.0.Smarthome.zigbee.bridge: logging {"level":"debug","message":"Saving state to file /opt/zigbee2mqtt/data/state.json"}
                                        fullybrowser.0
                                        2022-01-07 11:50:45.429	warn	updateDeviceERROR 192.168.2.165
                                        fullybrowser.0
                                        2022-01-07 11:50:44.954	debug	get Information
                                        fullybrowser.0
                                        2022-01-07 11:50:44.904	info	State value to set for "fullybrowser.0.192_168_2_165.Commands.screenBrightness" has to be type "number" but received type "string"
                                        fullybrowser.0
                                        2022-01-07 11:50:42.128	info	Start with IP : 192.168.2.165
                                        fullybrowser.0
                                        2022-01-07 11:50:42.127	debug	create state
                                        fullybrowser.0
                                        2022-01-07 11:50:42.079	info	starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v14.18.1, js-controller: 3.3.22
                                        fullybrowser.0
                                        2022-01-07 11:50:40.988	debug	statesDB connected
                                        fullybrowser.0
                                        2022-01-07 11:50:40.987	debug	States connected to redis: 127.0.0.1:9000
                                        fullybrowser.0
                                        2022-01-07 11:50:40.967	debug	States create User PubSub Client
                                        fullybrowser.0
                                        2022-01-07 11:50:40.966	debug	States create System PubSub Client
                                        fullybrowser.0
                                        2022-01-07 11:50:40.914	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                        fullybrowser.0
                                        2022-01-07 11:50:40.905	debug	objectDB connected
                                        fullybrowser.0
                                        2022-01-07 11:50:40.874	debug	Objects connected to redis: 127.0.0.1:9001
                                        fullybrowser.0
                                        2022-01-07 11:50:40.844	debug	Objects client initialize lua scripts
                                        fullybrowser.0
                                        2022-01-07 11:50:40.842	debug	Objects create User PubSub Client
                                        fullybrowser.0
                                        2022-01-07 11:50:40.840	debug	Objects create System PubSub Client
                                        fullybrowser.0
                                        2022-01-07 11:50:40.815	debug	Objects client ready ... initialize now
                                        fullybrowser.0
                                        2022-01-07 11:50:40.572	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        Den Timeout habe ich mal testweise von 2000 auf 5000 msec erhöht, hat aber nichts gebracht...
                                        • F Frank63
                                          @arteck
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          fullybrowser.0
                                          Frank63
                                          @arteck
                                          Ich habe mal ein paar debug Ausgaben eingebaut:
                                              async updateDevice(ip, port, psw) {
                                                  var id = ip.replace(/[.\s]+/g, '_');
                                                  var statusURL = 'http://' + ip + ':' + port + '/?cmd=deviceInfo&type=json&password=' + psw;
                                                  let fullyInfoObject = null;
                                                  // cre Info
                                                  try {
                                                      fullyInfoObject = await axios.get(statusURL);
                                                      if (fullyInfoObject.status !== '200') {
                                                          for (let lpEntry in fullyInfoObject.data) {
                                                              if (fullyInfoObject.data[lpEntry] != undefined && fullyInfoObject.data[lpEntry] != null) {
        let lpType = typeof fullyInfoObject.data[lpEntry]; // get Type of Variable as String, like string/number/boolean
        if (lpType == 'object') {
        await this.setState(`${id}.${infoStr}.${lpEntry}`, JSON.stringify(dpArray[0]), true);
        } else {
        await this.setState(`${id}.${infoStr}.${lpEntry}`, fullyInfoObject.data[lpEntry], true);
                                                          await this.setState(`${id}.isFullyAlive`, true, true);
                                                      } else {
                                                          await this.setState(`${id}.isFullyAlive`, false, true);
                                                  } catch (err) {
                                                      this.log.warn('updateDeviceERROR ' + statusURL + " : " + fullyInfoObject.status);
                                                      this.log.warn('error: ' + err);
                                                  await this.setState(`${id}.lastInfoUpdate`, Number(Date.now()), true);
                                          Und so sieht die Ausgabe aus:
                                          fullybrowser.0 2022-01-07 13:20:08.811	warn	error: ReferenceError: dpArray is not defined
                                          fullybrowser.0 2022-01-07 13:20:08.810	warn	updateDeviceERROR http://192.168.2.165:2323/?cmd=deviceInfo&type=json&password=1234 : 200
                                          Da kannst Du sehen, dass HTTP code 200 zurück kommt, also das Tablet erreichbar ist.
                                          Der Fehler hat scheinbar was mit dem Zerlegen des eines JSON Objects zu tun:
