  4. Fully Browser sensorinfo
    6.0k
46 Beiträge 7 Kommentatoren 6.1k Aufrufe 9 Beobachtet
  • F Frank63
    @arteck
    Hier die Debugausgaben:
    fullybrowser.0
    2022-01-07 11:52:46.479	warn	updateDeviceERROR 192.168.2.165
    fullybrowser.0
    2022-01-07 11:52:45.440	debug	get Information
    fullybrowser.0
    2022-01-07 11:50:59.662	debug	mqtt.0.Smarthome.zigbee.bridge: logging {"level":"debug","message":"Saving state to file /opt/zigbee2mqtt/data/state.json"}
    fullybrowser.0
    2022-01-07 11:50:45.429	warn	updateDeviceERROR 192.168.2.165
    fullybrowser.0
    2022-01-07 11:50:44.954	debug	get Information
    fullybrowser.0
    2022-01-07 11:50:44.904	info	State value to set for "fullybrowser.0.192_168_2_165.Commands.screenBrightness" has to be type "number" but received type "string"
    fullybrowser.0
    2022-01-07 11:50:42.128	info	Start with IP : 192.168.2.165
    fullybrowser.0
    2022-01-07 11:50:42.127	debug	create state
    fullybrowser.0
    2022-01-07 11:50:42.079	info	starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v14.18.1, js-controller: 3.3.22
    fullybrowser.0
    2022-01-07 11:50:40.988	debug	statesDB connected
    fullybrowser.0
    2022-01-07 11:50:40.987	debug	States connected to redis: 127.0.0.1:9000
    fullybrowser.0
    2022-01-07 11:50:40.967	debug	States create User PubSub Client
    fullybrowser.0
    2022-01-07 11:50:40.966	debug	States create System PubSub Client
    fullybrowser.0
    2022-01-07 11:50:40.914	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    fullybrowser.0
    2022-01-07 11:50:40.905	debug	objectDB connected
    fullybrowser.0
    2022-01-07 11:50:40.874	debug	Objects connected to redis: 127.0.0.1:9001
    fullybrowser.0
    2022-01-07 11:50:40.844	debug	Objects client initialize lua scripts
    fullybrowser.0
    2022-01-07 11:50:40.842	debug	Objects create User PubSub Client
    fullybrowser.0
    2022-01-07 11:50:40.840	debug	Objects create System PubSub Client
    fullybrowser.0
    2022-01-07 11:50:40.815	debug	Objects client ready ... initialize now
    fullybrowser.0
    2022-01-07 11:50:40.572	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Den Timeout habe ich mal testweise von 2000 auf 5000 msec erhöht, hat aber nichts gebracht...
    Frank63
    #41
    @arteck
    Ich habe mal ein paar debug Ausgaben eingebaut:
        async updateDevice(ip, port, psw) {
            var id = ip.replace(/[.\s]+/g, '_');
            var statusURL = 'http://' + ip + ':' + port + '/?cmd=deviceInfo&type=json&password=' + psw;
            let fullyInfoObject = null;
            // cre Info
            try {
                fullyInfoObject = await axios.get(statusURL);
                if (fullyInfoObject.status !== '200') {
                    for (let lpEntry in fullyInfoObject.data) {
                        if (fullyInfoObject.data[lpEntry] != undefined && fullyInfoObject.data[lpEntry] != null) {
                            let lpType = typeof fullyInfoObject.data[lpEntry]; // get Type of Variable as String, like string/number/boolean
                            if (lpType == 'object') {
                                await this.setState(`${id}.${infoStr}.${lpEntry}`, JSON.stringify(dpArray[0]), true);
                            } else {
                                await this.setState(`${id}.${infoStr}.${lpEntry}`, fullyInfoObject.data[lpEntry], true);
                    await this.setState(`${id}.isFullyAlive`, true, true);
                } else {
                    await this.setState(`${id}.isFullyAlive`, false, true);
            } catch (err) {
                this.log.warn('updateDeviceERROR ' + statusURL + " : " + fullyInfoObject.status);
                this.log.warn('error: ' + err);
            await this.setState(`${id}.lastInfoUpdate`, Number(Date.now()), true);
    Und so sieht die Ausgabe aus:
    fullybrowser.0 2022-01-07 13:20:08.811	warn	error: ReferenceError: dpArray is not defined
    fullybrowser.0 2022-01-07 13:20:08.810	warn	updateDeviceERROR http://192.168.2.165:2323/?cmd=deviceInfo&type=json&password=1234 : 200
    Da kannst Du sehen, dass HTTP code 200 zurück kommt, also das Tablet erreichbar ist.
    Der Fehler hat scheinbar was mit dem Zerlegen des eines JSON Objects zu tun:
    F 1 Antwort Letzte Antwort
    • F Frank63
      @arteck
              // cre Info
              try {
                              } else {
                  } else {
              } catch (err) {
      Frank63
      #42
      Die JSON Antwort des Fullybrowsers sieht so aus:
        "deviceName": "Fire Tablet",
        "packageName": "de.ozerov.fully",
        "batteryLevel": 100,
        "isPlugged": true,
        "SSID": "<unknown ssid>",
        "BSSID": "XXX",
        "Mac": "XXX",
        "ip4": "192.168.2.165",
        "ip6": "XXX",
        "hostname4": "XXX",
        "hostname6": "XXX",
        "wifiSignalLevel": 9,
        "isMobileDataEnabled": false,
        "screenOrientation": 90,
        "screenBrightness": 65,
        "screenLocked": true,
        "screenOn": false,
        "batteryTemperature": 24,
        "plugged": true,
        "keyguardLocked": true,
        "locale": "de_DE",
        "serial": "unknown",
        "build": "PS7322",
        "androidVersion": "9",
        "webviewUA": "Mozilla/5.0 (Linux; Android 9; KFTRWI Build/PS7322; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/94.0.4606.118 Safari/537.36",
        "motionDetectorStatus": 2,
        "isDeviceAdmin": true,
        "isDeviceOwner": false,
        "internalStorageFreeSpace": 21382639616,
        "internalStorageTotalSpace": 25780625408,
        "ramUsedMemory": 2334187520,
        "ramFreeMemory": 598106112,
        "ramTotalMemory": 2932293632,
        "appUsedMemory": 10046824,
        "appFreeMemory": 124170904,
        "appTotalMemory": 134217728,
        "scopedStorage": false,
        "displayHeightPixels": 1200,
        "displayWidthPixels": 1920,
        "isMenuOpen": false,
        "topFragmentTag": "",
        "isInDaydream": false,
        "isRooted": false,
        "isLicensed": true,
        "isInScreensaver": false,
        "kioskLocked": false,
        "isInForcedSleep": false,
        "maintenanceMode": false,
        "kioskMode": false,
        "startUrl": "http://192.168.2.188:8082/vis/index.html#Kueche",
        "currentTabIndex": 0,
        "deviceID": "XXX",
        "appVersionCode": 100994,
        "appVersionName": "1.44.1-fire",
        "androidSdk": 28,
        "deviceModel": "KFTRWI",
        "deviceManufacturer": "Amazon",
        "foregroundApp": "de.ozerov.fully",
        "currentPage": "http://192.168.2.188:8082/vis/index.html#Kueche",
        "lastAppStart": "05.01.22 22:04:36",
        "sensorInfo": [
            "type": 5,
            "name": "LIGHT",
            "vendor": "MTK",
            "version": 1,
            "accuracy": -1,
            "values": [
            "lastValuesTime": 1641558070142,
            "lastAccuracyTime": -1
      • F Frank63
          "isPlugged": true,
          "BSSID": "XXX",
          "Mac": "XXX",
          "ip6": "XXX",
          "hostname4": "XXX",
          "hostname6": "XXX",
          "screenOn": false,
          "plugged": true,
          "locale": "de_DE",
          "build": "PS7322",
          "isRooted": false,
          "isLicensed": true,
          "kioskMode": false,
          "deviceID": "XXX",
          "androidSdk": 28,
          "sensorInfo": [
              "type": 5,
              "name": "LIGHT",
              "vendor": "MTK",
              "version": 1,
              "accuracy": -1,
              "values": [
        Frank63
        #43
        @arteck
        Ich hab die entsprechende Codestelle bei mir mal so angepasst:
                                    await this.setState(`${id}.${infoStr}.${lpEntry}`, JSON.stringify(fullyInfoObject.data[lpEntry]), true);
                                } else {
        d.h. dpArray in fullyInfoObject.data geändert. Ich bin jetzt nicht der javascript Profi und hab keine Ahnung, ob dies mit der dpArray Variable ein copy/paste Fehler von dir war? Gucke doch mal bitte drüber, ob das so ok. Zumindest kommt bei mir eine Fehlermeldung mehr...
        Eine Sache ist mir noch aufgefallen: Beim Datenpunkt sensorInfo kommt ein JSON Array zurück, welches nicht zerlegt wurde:
        [{"type":5,"name":"LIGHT","vendor":"MTK","version":1,"accuracy":-1,"values":[3],"lastValuesTime":1641561660434,"lastAccuracyTime":-1}]
        • F Frank63
          @arteck
                                  } else {
          arteckA Offline
          arteckA Offline
          arteck
          #44
          @frank63 jep hast recht.. war ein fehler von mir..... DANKE
          der ssensorInfo wird nicht zerlegt weil es ehh keine relevanten Infos sind..
          • Merlin123M Offline
            Merlin123M Offline
            Merlin123
            #45
            Kämpfe aktuell nach der Neuanschaffung eines Samsung A8 Tablets (wieder) mit der Meldung:
            fullybrowser.0
            2022-03-27 11:08:58.467	warn	State "fullybrowser.0.192,168,0,244.lastInfoUpdate" has no existing object, this might lead to an error in future versions
            fullybrowser.0
            2022-03-27 11:08:58.459	warn	State "fullybrowser.0.192,168,0,244.isFullyAlive" has no existing object, this might lead to an error in future versions
            fullybrowser.0
            2022-03-27 11:08:58.448	warn	updateDeviceERROR 192,168,0,244
            Die Objekte sind aber angelegt, wenn ich das richtig sehe.
            Hab noch ein Lenovo Tablet seit längerem im Einsatz, da kommt die Meldung nicht (mehr). Hatte am Anfang das Problem.
            Hab auch mal versucht die Instanz zu stoppen und die Objekte des Samsungs gelöscht und neu aufbauen lassen, leider keine Besserung :(
            Beta-Tester
            • Merlin123M Merlin123
              fullybrowser.0
              fullybrowser.0
              fullybrowser.0
              arteckA Offline
              arteckA Offline
              arteck
              #46
              @merlin123 hast du die Version von GIT genommen ?
