  4. ZigBee neue Version 1.5.x
    6.5k
579 Beiträge 72 Kommentatoren 188.4k Aufrufe 74 Beobachtet
  • arteckA arteck
    @gosund hättest den Adapter nicht löschen müssen.. zumindest nicht aus der GUI raus
    hintenrum hätte auch gereicht und dir blieben alle Objekte erhalten
    gosund
    #421
    @arteck
    Zu früh gefreut. Der 1.5.6 Adapter kommt nicht mehr hoch:
    zigbee.0
    2021-06-09 16:15:12.631 info Try to reconnect. 1 attempts left
    zigbee.0
    2021-06-09 16:15:02.627 error Error herdsman start
    zigbee.0
    2021-06-09 16:15:02.626 error Failed to start Zigbee
    zigbee.0
    2021-06-09 16:15:02.624 error Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2021-06-09 16:14:43.017 info Installed Version: iobroker.zigbee@1.5.6
    zigbee.0
    2021-06-09 16:14:42.721 info Starting Zigbee npm ...
    zigbee.0
    2021-06-09 16:14:42.627 info starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.12
    zigbee.0
    2021-06-09 16:14:37.116 error Cannot read property 'getEntries' of null
    zigbee.0
    2021-06-09 16:14:37.115 error TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0
    2021-06-09 16:14:37.113 error unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0
    2021-06-09 16:14:37.112 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    G 1 Antwort Letzte Antwort
    • G gosund
      @arteck
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      gosund
      schrieb am zuletzt editiert von gosund
      #422
      @artek
      Was hat es eigentlich mit der PAN Id nach dem Update auf sich?
      Ich hatte diese unverändert auf 6754. Nach den ersten Problemen mit der 1.5.6 und dem Einspielen des Backups behauptete der Adapter im Log, die PAN wäre 6755. Nachdem ich umgestellt hatte, ging es -zumindest für ein paar Stunden.
      Nach der neuerlichen Aktion mit Downgrade auf 1.4.1 und jetzt wieder Update auf 1.5.6 behauptet der Adapter, die PAN Id wäre ist die 6756
      • G gosund
        @artek
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #423
        @gosund
        Hast du zufällig die verschiedenen nvbackup.json Dateien von den Versionen, in denen erkennbar ist das die panID hochgezählt wird ? Ich gehe davon aus das da etwas in der Konfiguration im Herdsman passiert - Wir brauchen dafür aber die Möglichkeit das nachzustellen.
        Ich kann verstehen wenn Du das mit deinem "live" Zigbee Netz nicht tun willst. In diesem Fall müsstest Du erst einmal auf die 1.4.1 zurück gehen. Ich hoffe immer noch darauf eine zigbee-herdsman version zu finden die
        • mit der 1.5.6 läuft
        • das Problem nicht hat.
        Sobald ich da etwas gefunden habe werde ich einen Link zur Testinstallation bereitstellen.
        A.
        E 1 Antwort Letzte Antwort
        • AsgothianA Asgothian
          @gosund
          A.
          ente34
          #424
          @asgothian
          Nach Stromausfall kommt zigbee nicht mehr hoch:
          zigbee.0	2021-06-09 19:29:22.325	warn	(3443) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
          zigbee.0	2021-06-09 19:29:22.311	error	(3443) Cannot read property 'getEntries' of null
          zigbee.0	2021-06-09 19:29:22.310	error	(3443) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
          zigbee.0	2021-06-09 19:29:22.306	error	(3443) unhandled promise rejection: Cannot read property 'getEntries' of null
          zigbee.0	2021-06-09 19:29:22.305	error	(3443) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0	2021-06-09 19:29:22.304	warn	(3443) Terminated (UNCAUGHT_EXCEPTION): Without reason
          zigbee.0	2021-06-09 19:29:22.302	info	(3443) terminating
          zigbee.0	2021-06-09 19:29:22.300	error	(3443) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
          zigbee.0	2021-06-09 19:29:22.296	info	(3443) Zigbee: disabling joining new devices.
          zigbee.0	2021-06-09 19:29:22.289	info	(3443) cleaned everything up...
          zigbee.0	2021-06-09 19:29:22.279	error	(3443) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00'
          zigbee.0	2021-06-09 19:29:22.278	error	(3443) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
          zigbee.0	2021-06-09 19:29:22.277	error	(3443) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218
          zigbee.0	2021-06-09 19:29:22.275	error	(3443) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0	2021-06-09 19:29:01.519	warn	(3443) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
          zigbee.0	2021-06-09 19:29:01.509	error	(3443) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
          zigbee.0	2021-06-09 19:29:01.508	error	(3443) Failed to start Zigbee
          zigbee.0	2021-06-09 19:29:01.326	info	(3443) Installed Version: iobroker.zigbee@1.5.6
          zigbee.0	2021-06-09 19:29:01.283	info	(3443) Starting Zigbee npm ...
          zigbee.0	2021-06-09 19:29:01.281	info	(3443) Try to reconnect. 1 attempts left
          zigbee.0	2021-06-09 19:28:51.283	warn	(3443) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
          zigbee.0	2021-06-09 19:28:51.281	error	(3443) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
          zigbee.0	2021-06-09 19:28:51.279	error	(3443) Failed to start Zigbee
          zigbee.0	2021-06-09 19:28:51.106	info	(3443) Installed Version: iobroker.zigbee@1.5.6
          zigbee.0	2021-06-09 19:28:51.101	warn	(3443) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
          zigbee.0	2021-06-09 19:28:50.914	info	(3443) Starting Zigbee npm ...
          zigbee.0	2021-06-09 19:28:50.821	info	(3443) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
          zigbee.0	2021-06-09 19:28:17.833	warn	(3367) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
          zigbee.0	2021-06-09 19:28:17.822	error	(3367) Cannot read property 'getEntries' of null
          zigbee.0	2021-06-09 19:28:17.821	error	(3367) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
          zigbee.0	2021-06-09 19:28:17.817	error	(3367) unhandled promise rejection: Cannot read property 'getEntries' of null
          zigbee.0	2021-06-09 19:28:17.816	error	(3367) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0	2021-06-09 19:28:17.815	warn	(3367) Terminated (UNCAUGHT_EXCEPTION): Without reason
          zigbee.0	2021-06-09 19:28:17.813	info	(3367) terminating
          zigbee.0	2021-06-09 19:28:17.808	error	(3367) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
          zigbee.0	2021-06-09 19:28:17.804	info	(3367) Zigbee: disabling joining new devices.
          zigbee.0	2021-06-09 19:28:17.797	info	(3367) cleaned everything up...
          zigbee.0	2021-06-09 19:28:17.783	error	(3367) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00'
          zigbee.0	2021-06-09 19:28:17.782	error	(3367) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
          zigbee.0	2021-06-09 19:28:17.781	error	(3367) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218
          zigbee.0	2021-06-09 19:28:17.779	error	(3367) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0	2021-06-09 19:27:57.012	warn	(3367) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
          zigbee.0	2021-06-09 19:27:57.008	error	(3367) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
          zigbee.0	2021-06-09 19:27:57.007	error	(3367) Failed to start Zigbee
          zigbee.0	2021-06-09 19:27:56.797	info	(3367) Installed Version: iobroker.zigbee@1.5.6
          zigbee.0	2021-06-09 19:27:56.777	info	(3367) Starting Zigbee npm ...
          zigbee.0	2021-06-09 19:27:56.776	info	(3367) Try to reconnect. 1 attempts left
          zigbee.0	2021-06-09 19:27:46.778	warn	(3367) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
          zigbee.0	2021-06-09 19:27:46.775	error	(3367) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
          zigbee.0	2021-06-09 19:27:46.773	error	(3367) Failed to start Zigbee
          zigbee.0	2021-06-09 19:27:46.630	info	(3367) Installed Version: iobroker.zigbee@1.5.6
          zigbee.0	2021-06-09 19:27:46.626	warn	(3367) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
          zigbee.0	2021-06-09 19:27:46.394	info	(3367) Starting Zigbee npm ...
          zigbee.0	2021-06-09 19:27:46.294	info	(3367) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
          zigbee.0	2021-06-09 19:27:13.360	warn	(3289) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
          zigbee.0	2021-06-09 19:27:13.349	error	(3289) Cannot read property 'getEntries' of null
          zigbee.0	2021-06-09 19:27:13.348	error	(3289) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
          zigbee.0	2021-06-09 19:27:13.342	error	(3289) unhandled promise rejection: Cannot read property 'getEntries' of null
          zigbee.0	2021-06-09 19:27:13.341	error	(3289) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0	2021-06-09 19:27:13.340	warn	(3289) Terminated (UNCAUGHT_EXCEPTION): Without reason
          zigbee.0	2021-06-09 19:27:13.338	info	(3289) terminating
          zigbee.0	2021-06-09 19:27:13.336	error	(3289) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
          zigbee.0	2021-06-09 19:27:13.332	info	(3289) Zigbee: disabling joining new devices.
          zigbee.0	2021-06-09 19:27:13.326	info	(3289) cleaned everything up...
          • E ente34
            @asgothian
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #425
            @ente34 sagte in ZigBee neue Version 1.5.x:
            Entweder fehlt am Anfang des Logs noch einiges oder der Zigbee Stick ist seit dem Stromausfall defekt:
            Nebenbei hast du mindestens 2 unterschiedliche Zigbee Versionen in deinem Log.
            • Welche version hattest du vor dem Stromausfall aktiv (und am laufen?)
            • Warum hast du gedacht das nach einem Stromausfall ein Update / Downgrade des Zigbee Adapters irgend etwas bewirkt ?
            A.
              A.
              ente34
              schrieb am zuletzt editiert von ente34
              #426
              @asgothian
              Habe versuchweise einen Downgrade durchgeführt.
              Bin jetzt wieder bei 1.5.6
              Nach reboot mit deaktiviertem Zigbee und dann nachdem alles hochgelaufen ist zigbee aktiviert:
              zigbee.0	2021-06-09 19:41:24.425	warn	(1903) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:41:24.423	error	(1903) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:41:24.421	error	(1903) Failed to start Zigbee
              zigbee.0	2021-06-09 19:41:24.264	info	(1903) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-09 19:41:24.258	warn	(1903) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:41:24.053	info	(1903) Starting Zigbee npm ...
              zigbee.0	2021-06-09 19:41:23.960	info	(1903) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
              host.raspi-iobroker	2021-06-09 19:41:21.617	info	instance system.adapter.zigbee.0 started with pid 1903
              host.raspi-iobroker	2021-06-09 19:40:51.545	info	Restart adapter system.adapter.zigbee.0 because enabled
              host.raspi-iobroker	2021-06-09 19:40:51.544	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              zigbee.0	2021-06-09 19:40:50.950	warn	(1827) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
              zigbee.0	2021-06-09 19:40:50.939	error	(1827) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:40:50.938	error	(1827) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
              zigbee.0	2021-06-09 19:40:50.931	error	(1827) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:40:50.928	error	(1827) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-09 19:40:50.926	warn	(1827) Terminated (UNCAUGHT_EXCEPTION): Without reason
              zigbee.0	2021-06-09 19:40:50.924	info	(1827) terminating
              zigbee.0	2021-06-09 19:40:50.922	error	(1827) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
              zigbee.0	2021-06-09 19:40:50.918	info	(1827) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-09 19:40:50.912	info	(1827) cleaned everything up...
              zigbee.0	2021-06-09 19:40:50.901	error	(1827) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00'
              zigbee.0	2021-06-09 19:40:50.900	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:40:50.899	error	(1827) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218
              zigbee.0	2021-06-09 19:40:50.897	error	(1827) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-09 19:40:30.083	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:40:30.078	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:40:30.077	error	(1827) Failed to start Zigbee
              zigbee.0	2021-06-09 19:40:29.922	info	(1827) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-09 19:40:29.893	info	(1827) Starting Zigbee npm ...
              zigbee.0	2021-06-09 19:40:29.892	info	(1827) Try to reconnect. 1 attempts left
              zigbee.0	2021-06-09 19:40:19.893	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:40:19.891	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:40:19.890	error	(1827) Failed to start Zigbee
              zigbee.0	2021-06-09 19:40:19.728	info	(1827) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-09 19:40:19.724	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:40:19.492	info	(1827) Starting Zigbee npm ...
              zigbee.0	2021-06-09 19:40:19.377	info	(1827) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
              host.raspi-iobroker	2021-06-09 19:40:16.846	info	instance system.adapter.zigbee.0 started with pid 1827
              host.raspi-iobroker	2021-06-09 19:40:16.799	info	"system.adapter.zigbee.0" enabled
              • E ente34
                @asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #427
                @asgothian
                Um dem Problem auf den Grund zu gehen musst du heraus bekommen warum der serielle Port nicht mehr verfügbar ist. Das Log sagt eindeutig das symlink nicht existiert.
                Insbesondere bei Stromausfällen / RaspberryPi Abstürzen / Proxxmox Updates die plötzlich einen laufenden Zigbee Adapter zerlegen ist zu 95% ein Problem mit der Verbindung zum Koordinator die Ursache.
                A.
                Nachtrag: Oh Wunder, auch in diesem Log findet sich bei jedem Startversuch die gleiche Meldung:
                Der Stick wird also immer noch nicht erkannt.
                E 2 Antworten Letzte Antwort
                  @asgothian
                  A.
                  ente34
                  #428
                  @asgothian
                  Habe einen neuen link 'serial1'
                  pi@raspi-iobroker:~ $ ls -l /dev/serial1
                  lrwxrwxrwx 1 root root 7 Jun  9 19:36 /dev/serial1 -> ttyAMA0
                    @asgothian
                    A.
                    ente34
                    #429
                    @asgothian
                    Erst mal vielen Dank für den schnellen Support!
                    • G Offline
                      gosund
                      #430
                      @asgothian
                      @artek
                      Schlechte Nachrichten: Das komplette löschen, installieren und neu Anlernen hat nichts gebracht.
                      Wie die letzten Tage auch hat sich der Adapter wieder innerhalb eines Tages aufgehängt. Ich mußte den Pi wieder komplett rebooten, damit es wieder geht.
                      Hilfe, ich weiß mir absolut nicht mehr zu helfen. Was kann ich noch versuchen?
                      R 1 Antwort Letzte Antwort
                      • G gosund
                        @asgothian
                        @artek
                        rewenode
                        #431
                        Ich weis echt nicht mehr weiter.
                        Bekomme einfach nicht das Update vom 1.5.5 auf 1.5.6 hin.
                        iob im Docker Container mit 4gb auf einem Rock64
                        node.js - v12.18.3
                        npm - 6.14.6
                        zigbee stick CC2538 + CC2592 von dimaiv
                        Bisher gab es nie die geringsten zigbee Updateprobleme. Nur die 1.5.6 bekomme ich nicht installiert.
                        Hier das Log:
                         01:23:20.786 - info: zigbee.0 (3129) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.2.16
                        2021-06-11 01:23:21.151 - info: zigbee.0 (3129) Starting Zigbee npm ...
                        2021-06-11 01:23:22.084 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
                        2021-06-11 01:23:23.678 - error: zigbee.0 (3129) Configuration is not consistent with adapter state/backup!
                        2021-06-11 01:23:23.681 - error: zigbee.0 (3129) - PAN ID: configured=6754, adapter=65535
                        2021-06-11 01:23:23.683 - error: zigbee.0 (3129) - Extended PAN ID: configured=00124b001940c0ba, adapter=0000000000000000
                        2021-06-11 01:23:23.685 - error: zigbee.0 (3129) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                        2021-06-11 01:23:23.686 - error: zigbee.0 (3129) - Channel List: configured=11, adapter=
                        2021-06-11 01:23:23.688 - error: zigbee.0 (3129) Please update configuration to prevent further issues.
                        2021-06-11 01:23:23.689 - error: zigbee.0 (3129) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                        2021-06-11 01:23:23.691 - error: zigbee.0 (3129) Re-commissioning your network will require re-pairing of all devices!
                        2021-06-11 01:23:23.694 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                        2021-06-11 01:23:23.695 - error: zigbee.0 (3129) Failed to start Zigbee
                        2021-06-11 01:23:23.697 - error: zigbee.0 (3129) Error herdsman start
                        2021-06-11 01:23:33.700 - info: zigbee.0 (3129) Try to reconnect. 1 attempts left
                        2021-06-11 01:23:33.702 - info: zigbee.0 (3129) Starting Zigbee npm ...
                        2021-06-11 01:23:33.735 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
                        2021-06-11 01:23:33.980 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                        2021-06-11 01:23:33.982 - error: zigbee.0 (3129) Failed to start Zigbee
                        2021-06-11 01:23:33.984 - error: zigbee.0 (3129) Error herdsman start
                        2021-06-11 01:25:09.693 - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                        2021-06-11 01:25:09.717 - info: mqtt.0 (705) send2Server system.adapter.zigbee.0.sigKill[iob/system/adapter/zigbee/0/sigKill]
                        2021-06-11 01:25:09.718 - info: zigbee.0 (3129) Got terminate signal TERMINATE_YOURSELF
                        2021-06-11 01:25:09.723 - info: zigbee.0 (3129) cleaned everything up...
                        2021-06-11 01:25:09.730 - info: zigbee.0 (3129) Zigbee: disabling joining new devices.
                        2021-06-11 01:25:09.733 - warn: zigbee.0 (3129) Failed to stop zigbee during startup
                        2021-06-11 01:25:09.735 - info: zigbee.0 (3129) terminating
                        2021-06-11 01:25:09.737 - info: zigbee.0 (3129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2021-06-11 01:25:09.739 - error: zigbee.0 (3129) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-06-11 01:25:09.740 - error: zigbee.0 (3129) unhandled promise rejection: Cannot read property 'getEntries' of null
                        2021-06-11 01:25:09.743 - error: zigbee.0 (3129) TypeError: Cannot read property 'getEntries' of null
                        at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
                        at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                        at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
                        Was kann ich noch tun ?
                        • R rewenode
                          node.js - v12.18.3
                          npm - 6.14.6
                          Hier das Log:
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #432
                          @rewenode geh auf version 1.4.1 und dann wieder auf die 1.5.6 gehts dann ?
                          • arteckA arteck
                            rewenode
                            #433
                            @arteck Reicht da ein Downgrade adapter->Bestimmte version installieren -> 1.4.1 ?
                            Oder muss erst den Adapter (1.5.5) löschen?
                            Und falls löschen, wie kann ich alle meine Geräte behalten ohne alle neu anlernen zu müssen?
                            Sry wenn die Fragen etwas naiv sein sollten. Ich sag ja, bisher reichte ein Knopfdruck und alles neu anlernen wäre hier ziemlich mit Arbeit verbunden bei kleinem Zeitfenster.
                            Jedenfalls schonmal danke für deine Hilfe.
                            • R rewenode
                              gosund
                              #434
                              @arteck @Asgothian
                              FYI: Hatte gestern Abend auf die 1.5.5 herunter gegraded. Das Problem besteht immer noch: nach ziemlich genau 24 Stunden hängt sich der Adapter auf. Ich mußte den Pi gerade eben wieder booten.
                              Irgend eine Idee, was ich noch machen kann?
                              Und nochwas: Seit dem Downgrade bekomme ich ständig folgende Meldung im Log:
                              zigbee.0 (1671) Failed to DeviceConfigure.onZigbeeEvent (Error: 'LED1623G12' has no configure
                                  at Object.getConfigureKey (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/configureKey.js:20:15)
                                  at DeviceConfigure.shouldConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:33:38)
                                  at DeviceConfigure.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:76:22)
                                  at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
                                  at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:14))
                              Woher kommt LED1623G12? Ich habe alle Devices umbenannt, kann also nicht sagen, welches er meint. Irgend eine Idee?
                                Rushmed
                                schrieb am zuletzt editiert von Rushmed
                                #435
                                ich komme gerade vom Ikea Einkauf und habe zwei kleine Probleme.
                                Die Fernbedienung STYRBAR wird vom Adapter als W2094 erkannt. Auf dem Gerät steht aber W2044 und in der Anleitung E2002. Das ist erstmal kein Problem für mich, allerdings funktionieren Druck und langer Druck nur bei den links/rechts Tasten. Die anderen beiden Tasten funktionieren garnicht. f750e091-c6d7-4da2-af97-ba27597956bb-grafik.png
                                Wenn ich STYRBAR direkt mit einer Lampe kopple geht alles.
                                Wenn ich den Adapter auf debug stelle kommen Tastendrücke an:
                                zigbee.0	2021-06-12 19:09:59.315	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:59.300	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                                zigbee.0	2021-06-12 19:09:59.299	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:59.297	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                                zigbee.0	2021-06-12 19:09:58.939	debug	(18506) Publish {"action":"brightness_move_down","action_rate":83,"action_group":901} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Type commandMove device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID"
                                zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMove', cluster 'genLevelCtrl', data '{"movemode":1,"rate":83}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:58.924	debug	(18506) handleMessage. {"type":"commandMove","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                                zigbee.0	2021-06-12 19:09:57.127	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:57.116	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                                zigbee.0	2021-06-12 19:09:57.114	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:57.113	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                                zigbee.0	2021-06-12 19:09:56.660	debug	(18506) Publish {"action":"brightness_move_up","action_rate":83,"action_group":901} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:56.644	debug	(18506) Type commandMoveWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                                zigbee.0	2021-06-12 19:09:56.643	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMoveWithOnOff', cluster 'genLevelCtrl', data '{"movemode":0,"rate":83}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:56.640	debug	(18506) handleMessage. {"type":"commandMoveWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                                zigbee.0	2021-06-12 19:09:54.926	debug	(18506) Publish {"action":"on","action_group":901} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:54.917	debug	(18506) Type commandOn device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":2
                                zigbee.0	2021-06-12 19:09:54.916	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:54.915	debug	(18506) handleMessage. {"type":"commandOn","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"
                                zigbee.0	2021-06-12 19:09:53.737	debug	(18506) Publish {"action":"arrow_right_click"} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:53.720	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
                                zigbee.0	2021-06-12 19:09:53.719	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":256,"value2":13}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:53.715	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
                                zigbee.0	2021-06-12 19:09:52.576	debug	(18506) Publish {"action":"off","action_group":901} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:52.563	debug	(18506) Type commandOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":
                                zigbee.0	2021-06-12 19:09:52.561	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOff', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:52.558	debug	(18506) handleMessage. {"type":"commandOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,
                                zigbee.0	2021-06-12 19:09:51.208	debug	(18506) Publish {"action":"arrow_left_click"} to "842e14fffe471ae1"
                                zigbee.0	2021-06-12 19:09:51.199	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
                                zigbee.0	2021-06-12 19:09:51.196	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":257,"value2":13}' from endpoint 1 with groupID 901
                                zigbee.0	2021-06-12 19:09:51.194	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
                                Der Timeout für die Erkennung des langen Drucks ist mit ca. 3 s auch sehr lang, kann man das irgendwo verstellen? Das ist zum Beispiel bei E1743 nur ca. 1 s, was viel besser passt.
                                Dann habe ich noch eine LED1924G9, die funktioniert soweit, außer die Effekte. Da tut sich garnichts.
                                Hat da jemand einen Tipp für mich?
                                L arteckA 2 Antworten Letzte Antwort
                                • R Rushmed
                                  locito09
                                  #436
                                  @rushmed
                                  hast du probiert das Gerät auszuschliessen?
                                  • L locito09
                                    @rushmed
                                    Rushmed
                                    #437
                                    @locito09 Wie ausschließen? Im Adapter? Nein.
                                    Edit: Habs probiert, geht nicht.
                                    • G gosund
                                      @arteck @Asgothian
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #438
                                      @gosund da sist der Technische name .. nicht dein umbenanntess.das kannst du in der Kachel sehen ..wenn du die umdrehst
                                      F 1 Antwort Letzte Antwort
                                      • arteckA arteck
                                        Frank579
                                        #439
                                        @Asgothian
                                        Habe gerade mein bastelsystem hochgezogen auf Admin5.
                                        Er spuckt mir jetzt für einige Geräte
                                        zigbee.0
                                        2021-06-13 09:52:06.290	warn	State value to set for "zigbee.0.0017880108279caf.link_quality" has value "255" greater than max "254"
                                        ins Log.
                                        Ist das schon bekannt?
                                        • F Frank579
                                          @Asgothian
                                          zigbee.0
                                          ins Log.
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #440
                                          @frank579 ohh Danke..habs korrigiert
