  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    2.5k
    4.4k
1.2k Beiträge 100 Kommentatoren 463.5k Aufrufe 82 Beobachtet
  • haselchenH haselchen
    @christian-wöhrle
    Und wie sieht das Log beim Adapterstart aus ?
    Christian WöhrleC Offline
    Christian Wöhrle
    schrieb am zuletzt editiert von Christian Wöhrle
    #1041
    @haselchen said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
    @christian-wöhrle
    2023-04-07 23:01:41.796 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    2023-04-07 23:01:41.796 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2023-04-07 23:01:41.797 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2023-04-07 23:01:48.245 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" disabled
    2023-04-07 23:01:52.053 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
    2023-04-07 23:01:52.555 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2400
    2023-04-07 23:01:55.365 - info: mihome-vacuum.0 (2400) starting. Version 3.9.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.19.0, js-controller: 4.0.24
    2023-04-07 23:01:55.503 - info: mihome-vacuum.0 (2400) IOT enabled, create state
    2023-04-07 23:01:55.627 - info: mihome-vacuum.0 (2400) select standard vacuum protocol....
    2023-04-07 23:01:56.219 - info: mihome-vacuum.0 (2400) settest next timer: not available
    2023-04-07 23:01:56.443 - info: mihome-vacuum.0 (2400) change states from State control.fan_power
    2023-04-07 23:01:56.531 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120053.roomFanPower
    2023-04-07 23:01:56.532 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120054.roomFanPower
    2023-04-07 23:01:56.533 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120055.roomFanPower
    2023-04-07 23:01:56.533 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120417.roomFanPower
    2023-04-07 23:01:56.534 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001392968.roomFanPower
    2023-04-07 23:01:56.535 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001392970.roomFanPower
    2023-04-07 23:01:56.536 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001398141.roomFanPower
    2023-04-07 23:01:57.434 - info: mihome-vacuum.0 (2400) create state for carpet_mode
    2023-04-07 23:01:59.336 - error: host.raspberrypi Caught by controller[0]: free(): invalid pointer
    2023-04-07 23:01:59.336 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    2023-04-07 23:01:59.336 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2023-04-07 23:01:59.336 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2023-04-07 23:02:29.560 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2849
    2023-04-07 23:02:32.478 - info: mihome-vacuum.0 (2849) starting. Version 3.9.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.19.0, js-controller: 4.0.24
    2023-04-07 23:02:32.661 - info: mihome-vacuum.0 (2849) IOT enabled, create state
    2023-04-07 23:02:42.763 - error: mihome-vacuum.0 (2849) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
    2023-04-07 23:02:42.764 - warn: mihome-vacuum.0 (2849) No Answer for DeviceModel use old one
    2023-04-07 23:02:42.765 - warn: mihome-vacuum.0 (2849) No Answer for DeviceModel use model from Config
    2023-04-07 23:02:42.829 - info: mihome-vacuum.0 (2849) select standard vacuum protocol....
    2023-04-07 23:02:43.458 - info: mihome-vacuum.0 (2849) settest next timer: not available
    2023-04-07 23:04:50.220 - info: mihome-vacuum.0 (2849) change states from State control.fan_power
    2023-04-07 23:04:50.342 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120053.roomFanPower
    2023-04-07 23:04:50.344 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120054.roomFanPower
    2023-04-07 23:04:50.344 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120055.roomFanPower
    2023-04-07 23:04:50.346 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120417.roomFanPower
    2023-04-07 23:04:50.347 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001392968.roomFanPower
    2023-04-07 23:04:50.348 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001392970.roomFanPower
    2023-04-07 23:04:50.350 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001398141.roomFanPower
    2023-04-07 23:04:51.326 - info: mihome-vacuum.0 (2849) create state for carpet_mode
    haselchenH D 2 Antworten Letzte Antwort
    • Christian WöhrleC Christian Wöhrle
      @christian-wöhrle
      haselchenH Offline
      haselchenH Offline
      haselchen
      #1042
      @christian-wöhrle
      Und jetzt noch die Adaptereinstellungen
      Christian WöhrleC 1 Antwort Letzte Antwort
        @christian-wöhrle
        Christian Wöhrle
        #1043
        @haselchen
          @haselchen
          haselchenH Offline
          haselchenH Offline
          haselchen
          #1044
          @christian-wöhrle
          Ich würde den Server mal auf Deutschland umstellen.
          Und dann nochmal auf get Device im Adapter, eventuell bekommste einen neuen Token.
          Ansonsten , wenn ich das so sehe, werden doch Datenpunkte angelegt?!
          Und im Log steht, dass du 10min warten sollst, nach Adapterstart, bis es losgehen kann.
          Aber ich würde trotzdem erstmal den Server auf Deutschland umstellen.
          Vermutlich musste das in der App das zuerst machen.
          Damrak2022D Christian WöhrleC 2 Antworten Letzte Antwort
          • Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #1045
            @wildbill Das gleiche Problem habe ich momentan auch mit meinem S7 Habe ihn via App in die Küche geschickt, allerdings sind im Datenpunkt goto keine Koordinaten zu finden:
            Der Datenpunkt sieht so aus:
              "_id": "mihome-vacuum.0.control.goTo",
              "type": "state",
              "common": {
                "name": "Go to point",
                "type": "string",
                "read": true,
                "write": true,
                "desc": "let the vacuum go to a point on the map"
              "native": {},
              "from": "system.adapter.mihome-vacuum.0",
              "user": "system.user.admin",
              "ts": 1680642958482,
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
            Oder wird das garnicht mehr unterstützt, was ich schade finden würde?
            Mit besten Grüßen
            Andy
              @christian-wöhrle
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              schrieb am zuletzt editiert von Damrak2022
              #1046
              @haselchen Guten Morgen,
              ich habe nochmal eine Frage an Dich, da Du mir ja erklärt hast was ich bei der VIS für die Anzeige der Karte eingeben muss. Das Ganze lief bis heute gut. Eben habe ich den Sauger gestartet und jetzt ist wieder das Problem vorhanden, das sich der Staubsauger nicht in Echtzeit auf derKarte bewegt, sondern stur an seinem Ladeplatz angezeigt wird. Habe auch extra mal die Vis geöffnet und im Browser angezeigt - hilft aber nichts. Passiert das bei Dir auch und hast Du eine Idee, woran es liegen könnte?
              Und wenn ich gerade dabei bin: Wofür ist denn der Datenpunkt: dustCollect und kann man den eventuell noch sinnvoll einbinden?
              Mit besten Grüßen
              Andy
                @christian-wöhrle
                Christian Wöhrle
                #1047
                Der Sauger ist über die Deutschland-Server nicht verfügbar. Habe trotzdem natürlich versucht umzustellen. Jetzt muss ich schauen dass ich ihn wieder in den Instanzen aktivieren kann ;)
                Datenpunkte sind alle vorhanden.
                  @christian-wöhrle
                  dirkhe
                  #1048
                  @christian-wöhrle mach nal bitte die karte aus, kb er dann immer noch abstürzt, dann könnte es auch am canvas liegen, das läuft nicht so gut bis gar nicht auf einem raspi, da canvas 32 bit nicht mehr unterstützt
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    #1049
                    @christian-wöhrle
                    Heisst das jetzt, dass es geht oder nicht?!
                    Aus deinem Post kann man das nicht so herauslesen.
                    • Damrak2022D Damrak2022
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #1050
                      @damrak2022
                      Diese "nicht bewegen Probleme" hab ich nicht.
                      Sauger ist sauber eingebunden und ebenso in der VIS mit dem entsprechenden Widget und Datenpunkt.
                      Ich hab das nicht mehr auf dem Schirm.
                      Zeig mal bitte deine Datenpunkte (erstmal die Maps Datenpunkte) und den Ausschnitt aus der VIS wie du es eingebunden hast.
                        @damrak2022
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #1051
                        @haselchen So sehen die Datenpunkte aus:
                        Map64
                          "_id": "mihome-vacuum.0.cleanmap.map64",
                          "type": "state",
                          "common": {
                            "name": "Map64",
                            "type": "string",
                            "role": "vacuum.map.base64",
                            "read": true,
                            "write": false,
                            "desc": "Map in a decoded Base64 PNG"
                          "native": {},
                          "ts": 1680642959378,
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        So die VIS
                        Mit besten Grüßen
                        Andy
                        haselchenH 2 Antworten Letzte Antwort
                        • D dirkhe
                          Christian Wöhrle
                          #1052
                          @dirkhe said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                          @christian-wöhrle
                          Habe die Instanz mal komplett gelöscht, wieder installiert, Karte deaktiviert. Leider wird jetzt garnichts mehr gefunden.
                          Damrak2022D haselchenH 2 Antworten Letzte Antwort
                            @christian-wöhrle
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #1053
                            @christian-wöhrle sorry falsch gepostet
                            Mit besten Grüßen
                            Andy
                              @christian-wöhrle
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #1054
                              @christian-wöhrle
                              Gleiche Spiel von vorne .
                              Bekommst du im Adapter einen Token , sprich , wird dein Gerät gefunden ?
                              Was sagt das Debug Log beim Adapterstart.
                                Map64
                                  "type": "state",
                                  "common": {
                                    "name": "Map64",
                                    "type": "string",
                                    "read": true,
                                    "write": false,
                                  "native": {},
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                So die VIS
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                #1055
                                @damrak2022
                                Gucke ich mir gleich an …..
                                  @damrak2022
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #1056
                                  @haselchen Okay, danke
                                  Mit besten Grüßen
                                  Andy
                                  • D3ltoroxpD Offline
                                    D3ltoroxpD Offline
                                    D3ltoroxp
                                    #1057
                                    Hallo zusammen, ich habe grad mal mein System wieder auf den neusten Stand gebracht. Nach Upgrade auf nodejs 18.x kommt nun folgendes.
                                    mihome-vacuum.0
                                    2023-04-09 10:46:14.741	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                                    unter dem Link gibts nichts. Wie installiere ich denn dieses Canvas Package ? Und wurde das beim Upgrade nach Anleitung gelöscht ?
                                    Thomas BraunT T 2 Antworten Letzte Antwort
                                    • D3ltoroxpD D3ltoroxp
                                      mihome-vacuum.0
                                      #1058
                                      @d3ltoroxp
                                      Den Fixer mal ausgeführt?
                                      Um was für ein System geht es? 32bit? 64bit?
                                      D3ltoroxpD 1 Antwort Letzte Antwort
                                        mihome-vacuum.0
                                        tritor
                                        #1059
                                        hi,
                                        habe auch die waterbox Level error message in der Version 3.10.0
                                        	State value to set for "mihome-vacuum.0.control.water_box_level" has value "42" greater than max "30"
                                        Gerät: Roborock S5 Max
                                        Denke der Issue ist ja schon auf GitHub erfasst.
                                        Gernot
                                        Host: i9 server Proxmox , Debian 13.4 for ioBroker
                                        ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
                                        Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
                                        Grafana 13.0.1 / InfluxDB 2.8.0
                                          @d3ltoroxp
                                          D3ltoroxpD Offline
                                          D3ltoroxpD Offline
                                          D3ltoroxp
                                          #1060
                                          @thomas-braun Nach dem ganzen Upgrade hab ich iob fix eingegeben, so wie in der Anleitung, falls du diesen Fix meinst.
                                          Sollte ein 64Bit sein. Debian 11
