  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • E elmos04
    @wendy2702
    Java Zigbee und den iobroker
    elmos04
    #121
    @elmos04
    das steht im iobroker Protokoll
    code_text
    p.0
    2022-02-13 17:52:31.393	error	[iobroker] chmod for Backup directory could not be completed: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please run "iobroker fix"!!
    backitup.0
    2022-02-13 17:52:30.642	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0
    2022-02-13 17:52:30.556	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
    host.raspberrypi
    2022-02-13 17:52:27.918	info	instance system.adapter.backitup.0 started with pid 26735
    host.raspberrypi
    2022-02-13 17:52:25.539	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    backitup.0
    2022-02-13 17:52:24.868	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0
    2022-02-13 17:52:24.866	info	terminating
    backitup.0
    2022-02-13 17:52:24.865	info	cleaned everything up...
    host.raspberrypi
    2022-02-13 17:52:24.865	info	stopInstance system.adapter.backitup.0 send kill signal
    backitup.0
    2022-02-13 17:52:24.863	info	Got terminate signal TERMINATE_YOURSELF
    • E elmos04
      @wendy2702
      wendy2702W Online
      wendy2702W Online
      wendy2702
      #122
      Was sind die xxx.json files? Sind das Widgets oder Views?
      Werden die noch benötigt?
      Kannst du mal den Inhalt eines solchen Files posten?
      Z.B.
      cat  /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json
      E 1 Antwort Letzte Antwort
      • E elmos04
        @elmos04
        code_text
        p.0
        backitup.0
        backitup.0
        host.raspberrypi
        host.raspberrypi
        backitup.0
        backitup.0
        backitup.0
        host.raspberrypi
        backitup.0
        wendy2702W Online
        wendy2702W Online
        wendy2702
        #123
        @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
        @elmos04
        Du muss auch mal anfangen die Logfiles zu lesen. Da steht zumindest mal ein Hinweis drin was gemacht werden soll
        HomoranH E 2 Antworten Letzte Antwort
        • wendy2702W wendy2702
          @elmos04
          #124
          @wendy2702 sagte in Iobroker backitup error.. Wo liegt das problem:
          Lesen -Ja
          Verstehen - nein
            Lesen -Ja
            Verstehen - nein
            wendy2702W Online
            wendy2702W Online
            wendy2702
            #125
            @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
            Lesen -Ja
            Verstehen - nein
            OK.
            Aber ich hoffe ja das die Leute auch Interesse haben das irgendwann mal zu verstehen.
              Z.B.
              elmos04
              #126
              code_text
              /* -- do not edit following lines - START --
                "expert": true,
                "engineType": "Blockly",
                "debug": false,
                "verbose": false
              -- do not edit previous lines - END --*/
              on({id: 'zigbee.0.04cf8cdf3c7d6fde.button_2_click', val: true}, async function (obj) {
                var value = obj.state.val;
                getState("hm-rpc.1.LTK0075338.1.STATE", function (err, state) {
                    setState("hm-rpc.1.LTK0075338.1.STATE"/*Blaulicht.STATE*/, state ? !state.val : true);
                console.log('Blaulicht Taster geschaltet');
              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@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspberrypi:~ $
              • E elmos04
                code_text
                  "expert": true,
                  "debug": false,
                  "verbose": false
                #127
                das sind skripte
                Was machen die unter vis?
                E wendy2702W 2 Antworten Letzte Antwort
                  @elmos04
                  elmos04
                  #128
                  @wendy2702
                  Sorry aber ich weiss ja nicht was ich machen soll iobroker fix wurde schon gemacht
                    das sind skripte
                    elmos04
                    #129
                    @homoran das hat der Backitup adapter mir aus dem alten backup kopiert
                      das sind skripte
                      wendy2702W Online
                      wendy2702W Online
                      wendy2702
                      #130
                      das sind skripte
                      @elmos04 : weisst du wie deine Blocklys oder anderen Scripte alle heißen? Siehst du diese in iobroker?
                        das sind skripte
                        elmos04
                        #131
                        @wendy2702
                        ja das sind Skripte. die kenne ich
                        • E elmos04
                          @simatec
                          habe beides Copy und Paste gemacht.
                          Gleiche Meldung
                          code_text
                          Started iobroker ...
                          [DEBUG] [iobroker] - host.raspberrypi 8766 states saved
                          [DEBUG] [iobroker] - host.raspberrypi 10664 objects saved
                          [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json is not a valid json file
                          [DEBUG] [iobroker] - done
                          [DEBUG] [zigbee] - found zigbee database: zigbee.0
                          [DEBUG] [zigbee] - done
                          [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                          [DEBUG] [javascripts] - found Script: Garagentor_Status
                          [DEBUG] [javascripts] - found Script: Taster_6Fach
                          [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
                          [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
                          [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
                          [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
                          [DEBUG] [javascripts] - found Script: Gast_Wlan
                          [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
                          [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
                          [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
                          [DEBUG] [javascripts] - found Script: Überwachung_Temp
                          [DEBUG] [javascripts] - found Script: Rauchmelder
                          [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
                          [DEBUG] [javascripts] - found Script: Xiaomi_Taster
                          [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
                          [DEBUG] [javascripts] - found Script: Ikea_Taster_
                          [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
                          [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
                          [DEBUG] [javascripts] - found Script: Duty_Cycle
                          [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
                          [DEBUG] [javascripts] - found Script: Einbruch_erkannt
                          [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                          [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                          [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-17_52_40_ioBroker_backupiobroker.tar.gz
                          [DEBUG] [javascripts] - done
                          [DEBUG] [clean] - done
                          [DEBUG] [historyHTML] - new history html values created
                          [DEBUG] [historyHTML] - done
                          [DEBUG] [historyJSON] - new history json values created
                          [DEBUG] [historyJSON] - done
                          [EXIT] 26
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #132
                          Gleiche Meldung
                          Nein diesesmal ist es 6_Fach_Taster_2_Blaulicht.json
                          Da ist irgendwas krum. Was sind das überhaupt für Dateien? Sind die von dir?
                          • Besuche meine Github Seite
                          • HowTo Restore ioBroker
                          • simatecS simatec
                            Gleiche Meldung
                            elmos04
                            #133
                            @simatec
                            Ja das sind Skripte. Ein Blockly welches das Blaulicht einschaltet wenn der Taster gedrückt wird.
                            • E elmos04
                              @wendy2702
                              wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              #134
                              @elmos04 OK. Siehst du diese Scripte im Script Tab?
                              Funktionieren Sie?
                              Ist das Script: 6_Fach_Taster_1_Büro_licht noch vorhanden und funktioniert?
                                Funktionieren Sie?
                                elmos04
                                #135
                                @wendy2702
                                die Skripte habe ich alle neu gemacht. die alten habe ich gelöscht. viele Fehler
                                • E elmos04
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #136
                                  Backitup macht nur das, was vorher konfiguriert wurde.
                                  Backitup legt keine Daten in VIS von alleine ab
                                  Mach folgendes
                                  sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json /home/pi/
                                  sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json
                                  • simatecS simatec
                                    Mach folgendes
                                    wendy2702W Online
                                    wendy2702W Online
                                    wendy2702
                                    #137
                                    @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
                                    Mach folgendes
                                    Damit ist dann auch sein View weg
                                    • E elmos04
                                      @wendy2702
                                      #138
                                      @elmos04
                                      Wenn ich so versuche die brauchbaren Informationen aus deinen Posts zusammenzuklauben, dann ergibt sich mir folgendes Szenario am wahrscheinlichsten.
                                      Du hast mit einem Restore eines defekten Backups deine gesamte Installation zerschossen.
                                        Mach folgendes
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #139
                                        @wendy2702 Erstmal egal ... die können wir später zurück kopieren
                                        Erstmal muss er den ganzen Datenmüll da rausbekommen
                                        • E Offline
                                          elmos04
                                          #140
                                          /home/pi/
                                          jetzt hab ich ein backup erstellen können
