  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • wendy2702W wendy2702
    @elmos04 Was hast du denn im Adapter alles ausgewählt ?
    elmos04
    #120
    @wendy2702
    Java Zigbee und den iobroker
    E wendy2702W 2 Antworten Letzte Antwort
    • E elmos04
      @wendy2702
      elmos04
      #121
      @elmos04
      das steht im iobroker Protokoll
      code_text
      p.0
      2022-02-13 17:52:31.393	error	[iobroker] chmod for Backup directory could not be completed: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please run "iobroker fix"!!
      backitup.0
      2022-02-13 17:52:30.642	info	[iobroker] backup was activated at 02:40 every 1 day(s)
      backitup.0
      2022-02-13 17:52:30.556	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
      host.raspberrypi
      2022-02-13 17:52:27.918	info	instance system.adapter.backitup.0 started with pid 26735
      host.raspberrypi
      2022-02-13 17:52:25.539	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      backitup.0
      2022-02-13 17:52:24.868	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      backitup.0
      2022-02-13 17:52:24.866	info	terminating
      backitup.0
      2022-02-13 17:52:24.865	info	cleaned everything up...
      host.raspberrypi
      2022-02-13 17:52:24.865	info	stopInstance system.adapter.backitup.0 send kill signal
      backitup.0
      2022-02-13 17:52:24.863	info	Got terminate signal TERMINATE_YOURSELF
      • E elmos04
        @wendy2702
        wendy2702W Online
        wendy2702W Online
        #122
        Was sind die xxx.json files? Sind das Widgets oder Views?
        Werden die noch benötigt?
        Kannst du mal den Inhalt eines solchen Files posten?
        Z.B.
        cat  /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json
        E 1 Antwort Letzte Antwort
        • E elmos04
          @elmos04
          code_text
          p.0
          backitup.0
          backitup.0
          host.raspberrypi
          host.raspberrypi
          backitup.0
          backitup.0
          backitup.0
          host.raspberrypi
          backitup.0
          wendy2702W Online
          wendy2702W Online
          #123
          @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
          @elmos04
          Du muss auch mal anfangen die Logfiles zu lesen. Da steht zumindest mal ein Hinweis drin was gemacht werden soll
          HomoranH E 2 Antworten Letzte Antwort
            @elmos04
            #124
            @wendy2702 sagte in Iobroker backitup error.. Wo liegt das problem:
            Lesen -Ja
            Verstehen - nein
              Lesen -Ja
              Verstehen - nein
              wendy2702W Online
              wendy2702W Online
              #125
              @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
              Lesen -Ja
              Verstehen - nein
              OK.
              Aber ich hoffe ja das die Leute auch Interesse haben das irgendwann mal zu verstehen.
                Z.B.
                elmos04
                #126
                code_text
                /* -- do not edit following lines - START --
                  "expert": true,
                  "engineType": "Blockly",
                  "debug": false,
                  "verbose": false
                -- do not edit previous lines - END --*/
                on({id: 'zigbee.0.04cf8cdf3c7d6fde.button_2_click', val: true}, async function (obj) {
                  var value = obj.state.val;
                  getState("hm-rpc.1.LTK0075338.1.STATE", function (err, state) {
                      setState("hm-rpc.1.LTK0075338.1.STATE"/*Blaulicht.STATE*/, state ? !state.val : true);
                  console.log('Blaulicht Taster geschaltet');
                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@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspberrypi:~ $
                • E elmos04
                  code_text
                    "expert": true,
                    "debug": false,
                    "verbose": false
                  #127
                  das sind skripte
                  Was machen die unter vis?
                    @elmos04
                    elmos04
                    #128
                    @wendy2702
                    Sorry aber ich weiss ja nicht was ich machen soll iobroker fix wurde schon gemacht
                      das sind skripte
                      elmos04
                      #129
                      @homoran das hat der Backitup adapter mir aus dem alten backup kopiert
                        das sind skripte
                        wendy2702W Online
                        wendy2702W Online
                        #130
                        das sind skripte
                        @elmos04 : weisst du wie deine Blocklys oder anderen Scripte alle heißen? Siehst du diese in iobroker?
                          das sind skripte
                          elmos04
                          #131
                          @wendy2702
                          ja das sind Skripte. die kenne ich
                          • E elmos04
                            @simatec
                            habe beides Copy und Paste gemacht.
                            Gleiche Meldung
                            code_text
                            Started iobroker ...
                            [DEBUG] [iobroker] - host.raspberrypi 8766 states saved
                            [DEBUG] [iobroker] - host.raspberrypi 10664 objects saved
                            [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json is not a valid json file
                            [DEBUG] [iobroker] - done
                            [DEBUG] [zigbee] - found zigbee database: zigbee.0
                            [DEBUG] [zigbee] - done
                            [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                            [DEBUG] [javascripts] - found Script: Garagentor_Status
                            [DEBUG] [javascripts] - found Script: Taster_6Fach
                            [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
                            [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
                            [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
                            [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
                            [DEBUG] [javascripts] - found Script: Gast_Wlan
                            [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
                            [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
                            [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
                            [DEBUG] [javascripts] - found Script: Überwachung_Temp
                            [DEBUG] [javascripts] - found Script: Rauchmelder
                            [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
                            [DEBUG] [javascripts] - found Script: Xiaomi_Taster
                            [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
                            [DEBUG] [javascripts] - found Script: Ikea_Taster_
                            [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
                            [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
                            [DEBUG] [javascripts] - found Script: Duty_Cycle
                            [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
                            [DEBUG] [javascripts] - found Script: Einbruch_erkannt
                            [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                            [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                            [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-17_52_40_ioBroker_backupiobroker.tar.gz
                            [DEBUG] [javascripts] - done
                            [DEBUG] [clean] - done
                            [DEBUG] [historyHTML] - new history html values created
                            [DEBUG] [historyHTML] - done
                            [DEBUG] [historyJSON] - new history json values created
                            [DEBUG] [historyJSON] - done
                            [EXIT] 26
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #132
                            Gleiche Meldung
                            Nein diesesmal ist es 6_Fach_Taster_2_Blaulicht.json
                            Da ist irgendwas krum. Was sind das überhaupt für Dateien? Sind die von dir?
                            • Besuche meine Github Seite
                            • HowTo Restore ioBroker
                            • simatecS simatec
                              Gleiche Meldung
                              elmos04
                              #133
                              @simatec
                              Ja das sind Skripte. Ein Blockly welches das Blaulicht einschaltet wenn der Taster gedrückt wird.
                              • E elmos04
                                @wendy2702
                                wendy2702W Online
                                wendy2702W Online
                                #134
                                @elmos04 OK. Siehst du diese Scripte im Script Tab?
                                Funktionieren Sie?
                                Ist das Script: 6_Fach_Taster_1_Büro_licht noch vorhanden und funktioniert?
                                  Funktionieren Sie?
                                  elmos04
                                  #135
                                  @wendy2702
                                  die Skripte habe ich alle neu gemacht. die alten habe ich gelöscht. viele Fehler
                                  • E elmos04
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #136
                                    Backitup macht nur das, was vorher konfiguriert wurde.
                                    Backitup legt keine Daten in VIS von alleine ab
                                    Mach folgendes
                                    sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json /home/pi/
                                    sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json
                                    • simatecS simatec
                                      Mach folgendes
                                      wendy2702W Online
                                      wendy2702W Online
                                      #137
                                      @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
                                      Mach folgendes
                                      Damit ist dann auch sein View weg
                                      • E elmos04
                                        @wendy2702
                                        #138
                                        @elmos04
                                        Wenn ich so versuche die brauchbaren Informationen aus deinen Posts zusammenzuklauben, dann ergibt sich mir folgendes Szenario am wahrscheinlichsten.
                                        Du hast mit einem Restore eines defekten Backups deine gesamte Installation zerschossen.
                                          Mach folgendes
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #139
                                          @wendy2702 Erstmal egal ... die können wir später zurück kopieren
                                          Erstmal muss er den ganzen Datenmüll da rausbekommen
