  4. Iobroker backitup error.. Wo liegt das problem
    6.3k
283 Beiträge 14 Kommentatoren 39.3k Aufrufe 8 Beobachtet
  • E elmos04
    @simatec
    habe beides Copy und Paste gemacht.
    Gleiche Meldung
    code_text
    Started iobroker ...
    [DEBUG] [iobroker] - host.raspberrypi 8766 states saved
    [DEBUG] [iobroker] - host.raspberrypi 10664 objects saved
    [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json is not a valid json file
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Garagentor_Status
    [DEBUG] [javascripts] - found Script: Taster_6Fach
    [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
    [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
    [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
    [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
    [DEBUG] [javascripts] - found Script: Gast_Wlan
    [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
    [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
    [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
    [DEBUG] [javascripts] - found Script: Überwachung_Temp
    [DEBUG] [javascripts] - found Script: Rauchmelder
    [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
    [DEBUG] [javascripts] - found Script: Xiaomi_Taster
    [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
    [DEBUG] [javascripts] - found Script: Ikea_Taster_
    [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
    [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
    [DEBUG] [javascripts] - found Script: Duty_Cycle
    [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
    [DEBUG] [javascripts] - found Script: Einbruch_erkannt
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-17_52_40_ioBroker_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 26
    wendy2702W Online
    wendy2702W Online
    #116
    @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
    @simatec
    Gleiche Meldung
    Nicht die gleiche Meldung. Vorher war es das File
    6_Fach_Taster_1_Büro_licht.json
    • E Offline
      elmos04
      #117
      Ja wenn das Backup nun doch erstellt wird sage ich mal vielen vielen Dank an euch alle die mir dabei geholfen haben. Ich hoffe ich werde dieses Backup nie brauchen. Wenn ich nun auf wiederherstellen gehe sehe ich jedoch nur Javaskripte und Zigbee. Vielleicht sind dort aber dann auch die iobroker Daten gesichert.
      Vielen Dank
      wendy2702W HomoranH 2 Antworten Letzte Antwort
      • E elmos04
        Vielen Dank
        wendy2702W Online
        wendy2702W Online
        #118
        @elmos04 Was hast du denn im Adapter alles ausgewählt ?
        E 1 Antwort Letzte Antwort
        • E elmos04
          Vielen Dank
          #119
          wenn!
          ich habe diese lange Zeile nicht zu Ende gesehen.
          @Wendy hat recht.
          Jetzt das gleiche Spiel mit dem Blaulicht
          • wendy2702W wendy2702
            elmos04
            #120
            @wendy2702
            Java Zigbee und den iobroker
            E wendy2702W 2 Antworten Letzte Antwort
            • E elmos04
              @wendy2702
              elmos04
              #121
              @elmos04
              das steht im iobroker Protokoll
              code_text
              p.0
              2022-02-13 17:52:31.393	error	[iobroker] chmod for Backup directory could not be completed: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please run "iobroker fix"!!
              backitup.0
              2022-02-13 17:52:30.642	info	[iobroker] backup was activated at 02:40 every 1 day(s)
              backitup.0
              2022-02-13 17:52:30.556	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
              host.raspberrypi
              2022-02-13 17:52:27.918	info	instance system.adapter.backitup.0 started with pid 26735
              host.raspberrypi
              2022-02-13 17:52:25.539	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              backitup.0
              2022-02-13 17:52:24.868	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              backitup.0
              2022-02-13 17:52:24.866	info	terminating
              backitup.0
              2022-02-13 17:52:24.865	info	cleaned everything up...
              host.raspberrypi
              2022-02-13 17:52:24.865	info	stopInstance system.adapter.backitup.0 send kill signal
              backitup.0
              2022-02-13 17:52:24.863	info	Got terminate signal TERMINATE_YOURSELF
              • E elmos04
                @wendy2702
                wendy2702W Online
                wendy2702W Online
                #122
                Was sind die xxx.json files? Sind das Widgets oder Views?
                Werden die noch benötigt?
                Kannst du mal den Inhalt eines solchen Files posten?
                Z.B.
                cat  /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json
                • E elmos04
                  @elmos04
                  code_text
                  p.0
                  backitup.0
                  backitup.0
                  host.raspberrypi
                  host.raspberrypi
                  backitup.0
                  backitup.0
                  backitup.0
                  host.raspberrypi
                  backitup.0
                  wendy2702W Online
                  wendy2702W Online
                  #123
                  @elmos04
                  Du muss auch mal anfangen die Logfiles zu lesen. Da steht zumindest mal ein Hinweis drin was gemacht werden soll
                  HomoranH E 2 Antworten Letzte Antwort
                    @elmos04
                    #124
                    @wendy2702 sagte in Iobroker backitup error.. Wo liegt das problem:
                    Lesen -Ja
                    Verstehen - nein
                      Lesen -Ja
                      Verstehen - nein
                      wendy2702W Online
                      wendy2702W Online
                      #125
                      @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
                      Lesen -Ja
                      Verstehen - nein
                      OK.
                      Aber ich hoffe ja das die Leute auch Interesse haben das irgendwann mal zu verstehen.
                        Z.B.
                        elmos04
                        #126
                        code_text
                        /* -- do not edit following lines - START --
                          "expert": true,
                          "engineType": "Blockly",
                          "debug": false,
                          "verbose": false
                        -- do not edit previous lines - END --*/
                        on({id: 'zigbee.0.04cf8cdf3c7d6fde.button_2_click', val: true}, async function (obj) {
                          var value = obj.state.val;
                          getState("hm-rpc.1.LTK0075338.1.STATE", function (err, state) {
                              setState("hm-rpc.1.LTK0075338.1.STATE"/*Blaulicht.STATE*/, state ? !state.val : true);
                          console.log('Blaulicht Taster geschaltet');
                        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@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspberrypi:~ $
                        • E elmos04
                          code_text
                            "expert": true,
                            "debug": false,
                            "verbose": false
                          #127
                          das sind skripte
                          Was machen die unter vis?
                            @elmos04
                            elmos04
                            #128
                            @wendy2702
                            Sorry aber ich weiss ja nicht was ich machen soll iobroker fix wurde schon gemacht
                              das sind skripte
                              elmos04
                              #129
                              @homoran das hat der Backitup adapter mir aus dem alten backup kopiert
                                das sind skripte
                                wendy2702W Online
                                wendy2702W Online
                                #130
                                das sind skripte
                                @elmos04 : weisst du wie deine Blocklys oder anderen Scripte alle heißen? Siehst du diese in iobroker?
                                  das sind skripte
                                  elmos04
                                  #131
                                  @wendy2702
                                  ja das sind Skripte. die kenne ich
                                  • E elmos04
                                    @simatec
                                    Gleiche Meldung
                                    code_text
                                    [EXIT] 26
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #132
                                    Gleiche Meldung
                                    Nein diesesmal ist es 6_Fach_Taster_2_Blaulicht.json
                                    Da ist irgendwas krum. Was sind das überhaupt für Dateien? Sind die von dir?
                                    • Besuche meine Github Seite
                                    • HowTo Restore ioBroker
                                    • simatecS simatec
                                      Gleiche Meldung
                                      elmos04
                                      #133
                                      @simatec
                                      Ja das sind Skripte. Ein Blockly welches das Blaulicht einschaltet wenn der Taster gedrückt wird.
                                      • E elmos04
                                        @wendy2702
                                        wendy2702W Online
                                        wendy2702W Online
                                        #134
                                        @elmos04 OK. Siehst du diese Scripte im Script Tab?
                                        Funktionieren Sie?
                                        Ist das Script: 6_Fach_Taster_1_Büro_licht noch vorhanden und funktioniert?
                                          Funktionieren Sie?
                                          elmos04
                                          #135
                                          @wendy2702
                                          die Skripte habe ich alle neu gemacht. die alten habe ich gelöscht. viele Fehler
