  4. Beta Test js-controller 3.2.x auf GitHub
    apollon77A
js-controller
287 Beiträge 25 Kommentatoren 89.4k Aufrufe 29 Beobachtet
  • lobomauL lobomau
    @apollon77 ich habe mal auf einem slave ausprobiert einem Pi3 mit node 12.20.1 und npm 6.14.10.
    Scheint nicht geklappt zu haben:
    pi@Pi3:~ $ cd /opt/iobroker
    pi@Pi3:/opt/iobroker $ sudo iobroker stop
    pi@Pi3:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
    > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js                                           -controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.10
    > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-co                                           ntroller
    > node iobroker.js setup first
    Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/io                                           broker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                                           /iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.                                           bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                                           /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                                           /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
    internal/fs/utils.js:269
        throw err;
    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-                                           controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:921:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/                                           setupSetup.js:835:16)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/set                                           up.js:272:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-con                                           troller/lib/setup.js:2643:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob                                           roker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:999:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js                                           :60:12) {
      errno: -13,
      syscall: 'mkdir',
      code: 'EACCES',
      path: '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch                                           okidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                           2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                           )
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@3.2.4 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.2.4 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional log                                           ging output above.
    npm ERR!     /root/.npm/_logs/2021-01-10T08_01_16_275Z-debug.log
    apollon77A
    apollon77A
    #81
    @lobomau iobroker fix bitte, dann nochmal versuchen. Danke
    lobomauL 1 Antwort Letzte Antwort
    • FeuersturmF Feuersturm
      @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
      @Feuersturm noch frage: dB ist file oder redis?
      Ich verstehe die Frage leider nicht. Worauf bezieht sich deine Frage?
      apollon77A
      apollon77A
      #82
      @Feuersturm was sagt „iobroker setup custom“ bei der objects databank für einen Typ? File oder redis?
      • apollon77A apollon77
        lobomauL
        lobomauL
        lobomau
        schrieb am zuletzt editiert von lobomau
        #83
        @apollon77 hab ich kein ioBroker mehr!?
        der zweite Befehl mit fix.sh hatte auch nicht geklappt.
        Nun läuft gerade durch:
        sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
        Host: NUC8i3 mit Proxmox:
        • Slave: Pi4
        • lobomauL lobomau
          lobomauL
          lobomauL
          lobomau
          #84
          @apollon77 ich glaube es hat geklappt:
          pi@Pi3:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
          library: loaded
          Library version=2020-12-07
          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          pi@Pi3:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-cont                                                        roller
          object 0_userdata.0.example_state created
          object _design/system updated
          ioBroker configuration updated
          > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
          > node scripts/postinstall
          + iobroker.js-controller@3.2.4
          added 87 packages from 45 contributors, removed 3 packages and moved 1 package i                                                        n 178.757s
          11 packages are looking for funding
            run `npm fund` for details
          pi@Pi3:/opt/iobroker $ sudo npm fund
          iobroker.inst@2.0.3
          ├─┬ https://github.com/sponsors/isaacs
          │ └── glob@7.1.6
          ├─┬ https://github.com/sponsors/epoberezkin
          │ └── ajv@6.12.3
          ├─┬ https://github.com/sponsors/RubenVerborgh
          │ └── follow-redirects@1.13.0
          ├─┬ https://github.com/sponsors/ljharb
          │ └── is-nan@1.3.0, resolve@1.17.0, has-symbols@1.0.1
          ├─┬ https://opencollective.com/ioredis
          │ └── ioredis@4.19.4
          ├─┬ https://github.com/sponsors/jonschlinkert
          │ └── picomatch@2.2.2
          ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
          │ └── wrap-ansi@7.0.0
          ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
          │ └── ansi-styles@4.3.0
          ├─┬ https://github.com/sponsors/feross
          │ └── safe-buffer@5.2.1, simple-concat@1.0.1
          ├─┬ https://www.patreon.com/feross
          ├─┬ https://feross.org/support
          └─┬ https://github.com/sponsors/sindresorhus
            └── mimic-response@2.1.0
          pi@Pi3:/opt/iobroker $ sudo iobroker start
          • Slave: Pi4
          • lobomauL lobomau
            library: loaded
            iobroker.inst@2.0.3
            │ └── glob@7.1.6
            │ └── ajv@6.12.3
            apollon77A
            apollon77A
            #85
            @lobomau passt.
              @lobomau passt.
              lobomauL
              lobomauL
              lobomau
              #86
              @apollon77 hab mir den nächsten slave einen Pi1 vorgenommen. Diesmal zuerst den fix gestartet, aber fürhrt zum gleichen Fehler (?) wie beim Pi3. Ich mache dann gleich wieder den Schritt wie beim Pi3.
              pi@raspberrypi:~ $ cd /opt/iobroker
              pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
              pi@raspberrypi:/opt/iobroker $ sudo iobroker fix
              library: loaded
                  Welcome to the ioBroker installation fixer!
                  Script version: 2020-12-07
                  Installing prerequisites (1/3)
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
              Reading package lists... Done
              Installed gcc-c++
                  Checking ioBroker user and directory permissions (2/3)
              Created /etc/sudoers.d/iobroker
                  Checking autostart (3/3)
              Enabling autostart...
              Autostart enabled!
              pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
              Could not check npm version: Error: Timeout
              Assuming that correct version is installed.
              fs.js:114
                  throw err;
                  at Object.mkdirSync (fs.js:757:3)
                  at Module._compile (internal/modules/cjs/loader.js:778:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                  at Module.load (internal/modules/cjs/loader.js:653:32)
                  at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                  at Function.Module._load (internal/modules/cjs/loader.js:585:3)
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /root/.npm/_logs/2021-01-10T08_43_13_360Z-debug.log
              • Slave: Pi4
              • lobomauL lobomau
                library: loaded
                Installed gcc-c++
                Autostart enabled!
                fs.js:114
                    throw err;
                npm ERR! errno 1
                npm ERR!
                lobomauL
                lobomauL
                lobomau
                #87
                @apollon77 ich habe alle Geräte auf 3.2.4 angehoben und alle Adapter sind grün.
                ABER: es klappte immer nur mit
                Und der Fix brachte auch nichts.
                • Slave: Pi4
                • SBorgS
                  SBorgS
                  SBorg
                  #88
                  @apollon77 Moin Ingo, den VIS-Dateimanager kann ich unter file-DB bestätigen. Er "bastelt" da pro Klick auf den /vis.0/ - Ordner jedes mal einen neuen Slash mit an ;)
                  LG SBorg ( SBorg auf GitHub)
                  apollon77A sigi234S 2 Antworten Letzte Antwort
                  • lobomauL lobomau
                    Thomas BraunT
                    Thomas BraunT
                    #89
                    @lobomau
                    Man macht das auch ja nicht mit
                    sudo npm
                    oder
                    sudo iobroker
                    Damit haust du das ganze als root ins System! Das ist falsch.
                      @lobomau
                      sudo npm
                      oder
                      sudo iobroker
                      apollon77A
                      apollon77A
                      #90
                      @Thomas-Braun da hast du recht hab ich gar nicht gesehen gehabt ;-))
                      • SBorgS SBorg
                        apollon77A
                        apollon77A
                        #91
                        @SBorg konnte es lokal nachstellen. Schaue ich nachher an
                        • SBorgS SBorg
                          sigi234S
                          sigi234S
                          sigi234
                          #92
                          @SBorg sagte in Beta Test js-controller 3.2.x auf GitHub:
                          Jupp, und der Ordner Projekt ist auch weg!
                          Immer Daten sichern!
                          • WalW
                            WalW
                            Wal
                            #93
                            Eben mal den Controller aktualisiert, habe sonst nichts zu tun :-)
                            Ohne Fehler durchgelaufen.
                            Installierte Adapter:
                            Proxmox System:
                            Walter
                            DoorIO-Adapter
                            • SBorgS
                              SBorgS
                              SBorg
                              #94
                              Ich hatte es zwar schon lt. Anzeige im ioB bemerkt, aber er braucht wohl offensichtlich weniger RAM :)
                              Ich weiß nur gerade nicht ob der aktuelle 3.1.6 auch satte 2GB beim starten braucht, könnte aber auch dem da gerade durchgeführtem Update auf die 3.2.4 geschuldet sein...
                              WalW 1 Antwort Letzte Antwort
                                Mal andere Frage: Schaut mal ob jemand hier einejn Eintrag hat (unter "Objekte", Expertenmodus, "system.host.NAME.notifications" ... Falls das bei jemandem nicht leer ist bitte iobroker mal stoppen und in iobroker-data nach der notifications.json schauen und den Inhalt mal posten ... Danke :-)
                                #95
                                Bitteschön, beim Server, sollte Enigma, Mihome-Vacuum gewesen sein...
                                {"restartLoop":{"count":4}}
                                mehr steht da leider nicht, hab auf den Datenpunkt mal die History angesetzt und lass mir das in der View anzeigen, bzw. einfach per Telegram schicken, wenn sich was ändert.. :-)
                                  lobomauL
                                  lobomauL
                                  lobomau
                                  #96
                                  bei meinem Pi3 slave steht
                                  {"restartLoop":{"count":1}}
                                  notifivation.json leer:
                                  pi@raspberrypi:/opt $ cd iobroker
                                  pi@raspberrypi:/opt/iobroker $ cd iobroker-data
                                  pi@raspberrypi:/opt/iobroker/iobroker-data $ ls
                                  backup-objects  iobroker.json       objects.json      states.json
                                  files           notifications.json  objects.json.bak  states.json.bak
                                  pi@raspberrypi:/opt/iobroker/iobroker-data $ sudo nano notifications.json
                                    GNU nano 3.2                   notifications.json
                                  • Slave: Pi4
                                    Thomas BraunT
                                    Thomas BraunT
                                    #97
                                    @apollon77
                                    notifications.json
                                    {"system":{"restartLoop":{"system.adapter.mihome-vacuum.0":[{"message":"Restart loop detected","ts":1610197549296}],"system.adapter.zigbee.0":[{"message":"Restart loop detected","ts":1610196881536}]}}}
                                      FeuersturmF
                                      FeuersturmF
                                      Feuersturm
                                      #98
                                      Ich nutze dann wohl file :-)
                                      proxmox@ioBrokerBETA:~$ iobroker setup custom
                                      Current configuration:
                                      - Objects database:
                                        - Type: file
                                      • lobomauL
                                        lobomauL
                                        lobomau
                                        #99
                                        Bei mir machen RAM und CPU folgendes. Ursache kenne ich noch nicht.
                                        • Slave: Pi4
                                        • SBorgS SBorg
                                          WalW
                                          WalW
                                          Wal
                                          #100
                                          @SBorg ,
                                          nicht schlecht dein Speicherverbrauch. Bei mir sind es ca. 200MB weniger, von 1,4GB auf 1,14GB.
                                          Instanzen siehe oben, Grafana läuft auch noch im gleichen Container.
                                          Walter
                                          DoorIO-Adapter
                                          84.0k
                                          1.4m
