  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
  • A audi1503
    @kakacs Du hattest vor dem Link nen Leerzeichen
    kakacs
    #81
    @audi1503 hab ich gemerckt grins ist das normal alles was da steht beim installieren
    $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
    install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3
    NPM version: 6.14.11npm install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3 --loglevel error --prefix "/opt/iobroker" (System call)
    canvas@2.7.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
    SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
    COPY Release/canvas-postbuild.node
    CXX(target) Release/obj.target/canvas/src/backend/Backend.o
    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
    ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
    ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
    ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
    CXX(target) Release/obj.target/canvas/src/Backends.o
    CXX(target) Release/obj.target/canvas/src/Canvas.o
    CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
    CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
    CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
    CXX(target) Release/obj.target/canvas/src/closure.o
    CXX(target) Release/obj.target/canvas/src/color.o
    CXX(target) Release/obj.target/canvas/src/Image.o
    CXX(target) Release/obj.target/canvas/src/ImageData.o
    CXX(target) Release/obj.target/canvas/src/init.o
    CXX(target) Release/obj.target/canvas/src/register_font.o
    SOLINK_MODULE(target) Release/obj.target/canvas.node
    COPY Release/canvas.node
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
    • iobroker.mihome-vacuum@3.0.0
      added 23 packages from 15 contributors in 70.367s
    52 packages are looking for funding run npm fund for details
    upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
    upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
    upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
    upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
    upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
    upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
    upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
    upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
    upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
    upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
    upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
    upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
    process exited with code 0
    das sagt der log jetzt
    mihome-vacuum.0 2021-04-04 17:14:52.696 debug (2687) system.adapter.admin.0: logging true
    mihome-vacuum.0 2021-04-04 16:14:51.546 debug (2687) Recievded params for viomi: {"result":[],"id":5,"exe_time":100}
    mihome-vacuum.0 2021-04-04 16:14:51.545 debug (2687) MIIO RECIVE: {"result":[],"id":5,"exe_time":100}
    mihome-vacuum.0 2021-04-04 16:14:51.206 debug (2687) Message= {"id":5,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
    mihome-vacuum.0 2021-04-04 16:14:51.204 debug (2687) get params for Viomi
    mihome-vacuum.0 2021-04-04 16:14:49.851 warn (2687) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
    mihome-vacuum.0 2021-04-04 16:14:49.849 debug (2687) Receive <<< Helo <<< 21310020000000001661f4ca0005063cffffffffffffffffffffffffffffffff
    mihome-vacuum.0 2021-04-04 16:14:31.203 debug (2687) Recievded params for viomi: {"result":[],"id":4,"exe_time":100}
    mihome-vacuum.0 2021-04-04 16:14:31.201 debug (2687) MIIO RECIVE: {"result":[],"id":4,"exe_time":100}
    mihome-vacuum.0 2021-04-04 16:14:30.897 debug (2687) system.adapter.admin.0: logging false
    mihome-vacuum.0 2021-04-04 16:14:30.649 debug (2687) Message= {"id":4,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
    mihome-vacuum.0 2021-04-04 16:14:30.647 debug (2687) get params for Viomi
    mihome-vacuum.0 2021-04-04 16:14:10.645 debug (2687) Recievded params for viomi: {"result":[],"id":3,"exe_time":100}
    mihome-vacuum.0 2021-04-04 16:14:10.644 debug (2687) MIIO RECIVE: {"result":[],"id":3,"exe_time":100}
    mihome-vacuum.0 2021-04-04 16:14:10.420 debug (2687) Message= {"id":3,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
    und es steht defentiv mehr drin Screenshot_2021-04-04 objects - ioBroker(1).png
    • MeistertrM Meistertr
      @kakacs löschen brachst du ihn vor dem drüber installieren nicht. das sind nur kleine Änderungen die ich vornehme. Die Timedifference ist nebensächlich, das bedeutet nur dass der roboter und der adapter unterschiedliche uhrzeiten haben und die Nachrichten daran angepasst werden
      kakacs
      #82
      @meistertr also ich kann jetzt über objecte steuern super arbeit echt ist das den möglich das ich den über alexa starten kann weil ja da in einstellung von dem adapter gibt die option füge ein status für alexa zu ??
      MeistertrM 1 Antwort Letzte Antwort
        @kakacs sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
        viomi.vacuum.v19
        installiere mal über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3
        audi1503
        #83
        @meistertr Kann mit dem Adapter auch den mijia.vacuum.v2 steuern oder sind das auch andere Befehle wie mit dem Dreame.vacuum.mc1808. Diese beiden hab ich und die lassen sich noch nicht einbinden.
        • K kakacs
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          #84
          @kakacs aldos starten und stoppen geht?
          K 1 Antwort Letzte Antwort
            kakacs
            #85
            @meistertr ich kann unter xiaomi objecten den sauger starten und auch pausieren
            und zurück zur lade station schicken . das klappt super. jetzt würde ich ihn gern über alexa steuern also starten zu mindestens.
            • K kakacs
              MeistertrM Offline
              MeistertrM Offline
              Meistertr
              schrieb am zuletzt editiert von Meistertr
              #86
              @kakacs hab da noch ein paar mehr anforderungen :) kannst du mal über sende eigene befehle (in der config aktivieren) ein paar sachen ausprobieren?
              get_status
              get_sound_volume
              get_consumable
              get_clean_summary
              get_map_v1
              und berichten was in response steht
                get_status
                get_sound_volume
                get_consumable
                get_clean_summary
                get_map_v1
                kakacs
                #87
                @meistertr ja klar kann ich gerne machen das ist kein problem
                • K kakacs
                  MeistertrM Offline
                  MeistertrM Offline
                  Meistertr
                  #88
                  • A audi1503
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    #89
                    @audi1503 sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                    mijia.vacuum.v2
                    bitte den Adapter installieren (rebulid3) einloggen und devices abrufen, Sauger auswählen eigene Kommandos aktivieren in config, speichern (nicht schließen) auf der ersten Seite oben rechts config downloaden2021-04-04_20h20_46.png
                    deviceId in ein leeres Textfile speichern
                    folgende Kommandos in untenstehender Form unter Objekten2021-04-04_19h53_04.png
                    bei send_command eingeben
                    Antworten bitte in ein Textfile kopieren, neben die Kommandos und posten
                    Kommandos (PIID und SIID)
                        # https://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:mijia-v1:1
                        "battery": {"siid": 3, "piid": 1},
                        "charge_state": {"siid": 3, "piid": 2},
                        "error": {"siid": 2, "piid": 2},
                        "state": {"siid": 2, "piid": 1},
                        "fan_speed": {"siid": 2, "piid": 6},
                        "operating_mode": {"siid": 2, "piid": 4},
                        "mop_state": {"siid": 16, "piid": 1},
                        "water_level": {"siid": 2, "piid": 5},
                        "brush_life_level": {"siid": 14, "piid": 1},
                        #  "brush_life_time": {"siid": 14, "piid": 2},
                        "brush_life_level2": {"siid": 15, "piid": 1},
                        #  "brush_life_time2": {"siid": 15, "piid": 2},
                        "filter_life_level": {"siid": 11, "piid": 1},
                        #  "filter_life_time": {"siid": 11, "piid": 2},
                        "clean_area": {"siid": 9, "piid": 1},
                        "clean_time": {"siid": 18, "piid": 5},
                        "total_clean_count": {"siid": 9, "piid": 5},
                        #   "total_clean_area": {"siid": 9, "piid": 3},
                        #  "dnd_enabled": {"siid": 12, "piid": 2},
                        #  "audio_volume": {"siid": 4, "piid": 2},
                        #  "direction_key": {"siid": 8, "piid": 1}
                    das ist die form wie es in das Objekt muss:
                    get_properties;[{"did":"AUSCONFIG","siid":3,"piid":1}]
                    Bitte einmal durchtesten
                    K 2 Antworten Letzte Antwort
                      audi1503
                      schrieb am zuletzt editiert von audi1503
                      #90
                      @Meistertr
                      Hier die angeforderten Antworten auf den Kommandos:
                      "battery": {"siid": 3, "piid": 1},                = [{"did":"334314795","siid":3,"piid":1,"code":0,"value":100}]
                      "charge_state": {"siid": 3, "piid": 2},           = [{"did":"334314795","siid":3,"piid":2,"code":0,"value":2}]
                      "error": {"siid": 2, "piid": 2},                  = [{"did":"334314795","siid":2,"piid":2,"code":0,"value":0}]
                      "state": {"siid": 2, "piid": 1},                  = [{"did":"334314795","siid":2,"piid":1,"code":0,"value":5}]
                      "fan_speed": {"siid": 2, "piid": 6},              = [{"did":"334314795","siid":2,"piid":6,"code":0,"value":1}]
                      "operating_mode": {"siid": 2, "piid": 4},         = [{"did":"334314795","siid":2,"piid":4,"code":0,"value":1}]
                      "mop_state": {"siid": 16, "piid": 1},             = [{"did":"334314795","siid":16,"piid":1,"code":0,"value":0}]
                      "water_level": {"siid": 2, "piid": 5},            = [{"did":"334314795","siid":2,"piid":5,"code":0,"value":2}]
                      "brush_life_level": {"siid": 14, "piid": 1},      = [{"did":"334314795","siid":14,"piid":1,"code":0,"value":58}]
                      #  "brush_life_time": {"siid": 14, "piid": 2},    = [{"did":"334314795","siid":14,"piid":2,"code":0,"value":10504}]
                      "brush_life_level2": {"siid": 15, "piid": 1},     = [{"did":"334314795","siid":15,"piid":1,"code":0,"value":14}]
                      #  "brush_life_time2": {"siid": 15, "piid": 2},   = [{"did":"334314795","siid":15,"piid":2,"code":0,"value":1280}]
                      "filter_life_level": {"siid": 11, "piid": 1},     = [{"did":"334314795","siid":11,"piid":1,"code":0,"value":16}]
                      #  "filter_life_time": {"siid": 11, "piid": 2},   = [{"did":"334314795","siid":11,"piid":2,"code":0,"value":1504}]
                      "clean_area": {"siid": 9, "piid": 1},             = [{"did":"334314795","siid":9,"piid":1,"code":0,"value":0}]
                      "clean_time": {"siid": 18, "piid": 5},            = [{"did":"334314795","siid":18,"piid":5,"code":-4003}]
                      "total_clean_count": {"siid": 9, "piid": 5},      = [{"did":"334314795","siid":9,"piid":5,"code":0,"value":0}]
                      #   "total_clean_area": {"siid": 9, "piid": 3},   = [{"did":"334314795","siid":9,"piid":3,"code":0,"value":0}]
                      #  "dnd_enabled": {"siid": 12, "piid": 2},        = [{"did":"334314795","siid":12,"piid":2,"code":0,"value":false}]
                      #  "audio_volume": {"siid": 4, "piid": 2},        = [MESSAGE TIMEOUT]
                      #  "direction_key": {"siid": 8, "piid": 1}        = [{"did":"334314795","siid":8,"piid":1,"code":-4003}]
                      Habe im Log auch noch Model mijia.vacuum.v2 not supported stehen
                        kakacs
                        #91
                        bei mir steht da nix
                        A 1 Antwort Letzte Antwort
                        • K kakacs
                          audi1503
                          #92
                          @kakacs du musst in dem feld rechts den befehl eingeben get_status z.B dann steht dadrüber die Antwort
                          • A audi1503
                            @Meistertr
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #93
                            @audi1503 sehr cool, damit kann ich ihn einbinden, dauert aber noch ein paar tage bis den adapter umgeschrieben habe
                              audi1503
                              #94
                              @meistertr 👍 Kein Stress
                                mijia.vacuum.v2
                                kakacs
                                #95
                                @meistertr Screenshot_2021-04-04 objects - ioBroker(3).png Screenshot_2021-04-04 logs - ioBroker.png
                                • K kakacs
                                  kakacs
                                  #96
                                  @Meistertr @audi1503 ich habe es geschaft eine szene zu erstellen im iobroker und sie wird auch in alexa erkannt über iobroker.io. aber leider kann ich den staubsauger nicht starten. ich denke es liegt daran das der status unter objekten der xiaomi adapter sich nicht aktualiesiert. auch wenn ich den sauger über die app starte aktualiesiert sich da kein wert. kann man was da machen ??
                                  • K kakacs
                                    MeistertrM Offline
                                    MeistertrM Offline
                                    Meistertr
                                    #97
                                    @kakacs nein daran liegt es nicht, du musst im iot Adapter sagen dass es ein Button ist. Versuch mal die Nachrichten mit siid und piid zu senden vll ist der robo mit miot erreichbar
                                      kakacs
                                      #98
                                      @meistertr hi guten morgen wie meinst du das mit den nachrichten mit siid und pid zu senden ??
                                        kakacs
                                        #99
                                        @meistertr hab es hin bekommen super danke für die tolle hilfe
                                        • K kakacs
                                          kakacs
                                          #100
                                          @kakacs ich bekomm in jetzt gestartet aber macht er auch dann die karte die in der app ist. weil in objekten wo clean/home steht in werten steht da nix kann ich irgend wie die karte in den iobroker intregrieren??
