  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
  • K kakacs
    @meistertr jetzt musst du mir helfen wie stell ich denn auf debug??
    MeistertrM Offline
    MeistertrM Offline
    Meistertr
    #71
    @kakacs https://www.google.com/search?q=wie+stelle+ich+iobroker+auf+debug&ie=utf-8&oe=utf-8&aq=t
    K 2 Antworten Letzte Antwort
    • MeistertrM Meistertr
      kakacs
      #72
      @meistertr danke
      mihome-vacuum.0 2021-04-04 14:47:43.491 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
      mihome-vacuum.0 2021-04-04 14:47:43.488 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f1d1ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 14:46:43.720 warn (25026) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
      mihome-vacuum.0 2021-04-04 14:46:43.720 debug (25026) DeviceModel selected to: viomi.vacuum.v19
      mihome-vacuum.0 2021-04-04 14:46:43.719 debug (25026) Get Device data from robot..
      mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) Get Device data..0
      mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) GETMODELFROMAPI:Data: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:C
      mihome-vacuum.0 2021-04-04 14:46:43.717 debug (25026) MIIO RECIVE: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw
      mihome-vacuum.0 2021-04-04 14:46:43.511 debug (25026) Message= {"id":1,"method":"miIO.info"}
      mihome-vacuum.0 2021-04-04 14:46:43.509 debug (25026) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617543894399,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
      mihome-vacuum.0 2021-04-04 14:46:43.396 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
      mihome-vacuum.0 2021-04-04 14:46:43.393 debug (25026) MAIN: Connected to device, try to get model..
      mihome-vacuum.0 2021-04-04 14:46:43.392 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f195ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 14:46:43.306 debug (25026) server started on 0.0.0.0:53421
      mihome-vacuum.0 2021-04-04 14:46:43.298 debug (25026) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
      mihome-vacuum.0 2021-04-04 14:46:43.296 info (25026) check group user admin group admin: false
      mihome-vacuum.0 2021-04-04 14:46:43.291 info (25026) check user admin pw iobroker: true
      mihome-vacuum.0 2021-04-04 14:46:43.078 info (25026) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
      mihome-vacuum.0 2021-04-04 14:46:42.875 debug (25026) statesDB connected
      mihome-vacuum.0 2021-04-04 14:46:42.874 debug (25026) States connected to redis: 127.0.0.1:9000
      mihome-vacuum.0 2021-04-04 14:46:42.862 debug (25026) States create User PubSub Client
      mihome-vacuum.0 2021-04-04 14:46:42.861 debug (25026) States create System PubSub Client
      mihome-vacuum.0 2021-04-04 14:46:42.849 debug (25026) Redis States: Use Redis connection: 127.0.0.1:9000
      mihome-vacuum.0 2021-04-04 14:46:42.847 debug (25026) objectDB connected
      mihome-vacuum.0 2021-04-04 14:46:42.837 debug (25026) Objects connected to redis: 127.0.0.1:9001
      mihome-vacuum.0 2021-04-04 14:46:42.819 debug (25026) Objects client initialize lua scripts
      mihome-vacuum.0 2021-04-04 14:46:42.818 debug (25026) Objects create User PubSub Client
      mihome-vacuum.0 2021-04-04 14:46:42.816 debug (25026) Objects create System PubSub Client
      mihome-vacuum.0 2021-04-04 14:46:42.805 debug (25026) Objects client ready ... initialize now
      mihome-vacuum.0 2021-04-04 14:46:42.764 debug (25026) Redis Objects: Use Redis connection: 127.0.0.1:9001
      mihome-vacuum.0 2021-04-04 14:46:38.420 info (24980) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      mihome-vacuum.0 2021-04-04 14:46:38.417 info (24980) terminating
      mihome-vacuum.0 2021-04-04 14:46:38.414 info (24980) Got terminate signal TERMINATE_YOURSELF
        kakacs
        #73
        @meistertr
        mihome-vacuum.0 2021-04-04 15:58:57.637 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
        mihome-vacuum.0 2021-04-04 15:58:57.635 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f474ffffffffffffffffffffffffffffffff
        mihome-vacuum.0 2021-04-04 15:58:56.681 debug (1208) system.adapter.admin.0: logging true
        mihome-vacuum.0 2021-04-04 14:58:22.365 debug (1208) sendTo "discovery" to system.adapter.admin.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0 2021-04-04 14:58:22.364 debug (1208) discover__[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":"192.168.178.75","mac":"5C:6B:D7
        mihome-vacuum.0 2021-04-04 14:58:22.362 debug (1208) {"code":0,"message":"ok","result":{"list":[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":
        mihome-vacuum.0 2021-04-04 14:58:22.231 debug (1208) GET devices from:https://de.api.io.mi.com/app/home/device_list
        mihome-vacuum.0 2021-04-04 14:58:22.223 debug (1208) Xiaomi Cloud: Login successful
        mihome-vacuum.0 2021-04-04 14:58:22.222 debug (1208) Login step3: [{"key":"userId","value":"6432461162","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-04-04T13:58:22.179Z","lastAccessed":"2021-04-04T13:58:22.220Z"},{"k
        mihome-vacuum.0 2021-04-04 14:58:21.945 debug (1208) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"XXyyLiOls5U1ionL2h/ygw==","code":0,"passToken":"V1:bOtEAOudpqEL/PTNVjfNjI1KRycqTK7DU62Fk/J18icmBS60DBX3c+rn/eV5WKs
        mihome-vacuum.0 2021-04-04 14:58:21.340 debug (1208) Login step1: &&&START&&&{"serviceParam":"{"checkSafePhone":false,"checkSafeAddress":false,"lsrp_score":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callb
        mihome-vacuum.0 2021-04-04 14:58:20.465 debug (1208) Xiaomi Cloud: Logging in
        mihome-vacuum.0 2021-04-04 14:57:57.631 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
        mihome-vacuum.0 2021-04-04 14:57:57.629 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f438ffffffffffffffffffffffffffffffff
        mihome-vacuum.0 2021-04-04 14:57:53.101 debug (1208) system.adapter.admin.0: logging false
        mihome-vacuum.0 2021-04-04 14:56:57.590 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
        mihome-vacuum.0 2021-04-04 14:56:57.589 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3fcffffffffffffffffffffffffffffffff
        mihome-vacuum.0 2021-04-04 14:55:57.559 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        mihome-vacuum.0 2021-04-04 14:55:57.558 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3bfffffffffffffffffffffffffffffffff
        mihome-vacuum.0 2021-04-04 14:54:57.502 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        mihome-vacuum.0 2021-04-04 14:54:57.500 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f383ffffffffffffffffffffffffffffffff
        mihome-vacuum.0 2021-04-04 14:53:57.741 warn (1208) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
        mihome-vacuum.0 2021-04-04 14:53:57.740 debug (1208) DeviceModel selected to: viomi.vacuum.v19
        mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data from robot..
        mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data..0
        mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) GETMODELFROMAPI:Data: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA
        mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) MIIO RECIVE: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw_
        mihome-vacuum.0 2021-04-04 14:53:57.442 debug (1208) Message= {"id":1,"method":"miIO.info"}
        mihome-vacuum.0 2021-04-04 14:53:57.440 debug (1208) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617544003728,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
        mihome-vacuum.0 2021-04-04 14:53:57.436 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        mihome-vacuum.0 2021-04-04 14:53:57.433 debug (1208) MAIN: Connected to device, try to get model..
        mihome-vacuum.0 2021-04-04 14:53:57.432 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f347ffffffffffffffffffffffffffffffff
        mihome-vacuum.0 2021-04-04 14:53:57.340 debug (1208) server started on 0.0.0.0:53421
        mihome-vacuum.0 2021-04-04 14:53:57.332 debug (1208) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
        mihome-vacuum.0 2021-04-04 14:53:57.330 info (1208) check group user admin group admin: false
        mihome-vacuum.0 2021-04-04 14:53:57.325 info (1208) check user admin pw iobroker: true
        mihome-vacuum.0 2021-04-04 14:53:57.113 info (1208) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.0, js-controller: 3.2.16
        mihome-vacuum.0 2021-04-04 14:53:56.874 debug (1208) statesDB connected
        mihome-vacuum.0 2021-04-04 14:53:56.873 debug (1208) States connected to redis: 127.0.0.1:9000
        mihome-vacuum.0 2021-04-04 14:53:56.866 debug (1208) States create User PubSub Client
        mihome-vacuum.0 2021-04-04 14:53:56.864 debug (1208) States create System PubSub Client
        mihome-vacuum.0 2021-04-04 14:53:56.857 debug (1208) Redis States: Use Redis connection: 127.0.0.1:9000
        mihome-vacuum.0 2021-04-04 14:53:56.854 debug (1208) objectDB connected
        mihome-vacuum.0 2021-04-04 14:53:56.845 debug (1208) Objects connected to redis: 127.0.0.1:9001
        mihome-vacuum.0 2021-04-04 14:53:56.822 debug (1208) Objects client initialize lua scripts
        mihome-vacuum.0 2021-04-04 14:53:56.821 debug (1208) Objects create User PubSub Client
        mihome-vacuum.0 2021-04-04 14:53:56.819 debug (1208) Objects create System PubSub Client
        mihome-vacuum.0 2021-04-04 14:53:56.816 debug (1208) Objects client ready ... initialize now
        mihome-vacuum.0 2021-04-04 14:53:56.753 debug (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
        MeistertrM 1 Antwort Letzte Antwort
        • K kakacs
          @meistertr
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          #74
          @kakacs sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
          viomi.vacuum.v19
          bitte nochmal von git installieren und debug posten (bitte log in codetags)
            viomi.vacuum.v19
            kakacs
            #75
            @meistertr @meistertr said in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
            log in codetags
            ok mache ich wie geht das mit log in code tags ??? bin noch nicht so fit mit iobroker sorry.
            hast du geshen in dem log was ich gepostet habe ws bedeutet das
            Time difference between Mihome Vacuum and ioBroker ich installier den adapter noch mal neu den du mir empfohlen hast richtig?? und soll ich erst wieder löschen ??
              viomi.vacuum.v19
              kakacs
              #76
              @meistertr hab den gelöscht und will den noch mal installieren und dann kommt das
              $ ./iobroker url " https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
              install "
              NPM version: 6.14.11
              npm install " --loglevel error --prefix "/opt/iobroker" (System call)
              /bin/sh: 1: Syntax error: Unterminated quoted string
              ERROR: host.raspberrypi Cannot install ": 2
              • K kakacs
                install "
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                #77
                leerzeichen davor
                • K kakacs
                  log in codetags
                  MeistertrM Offline
                  MeistertrM Offline
                  Meistertr
                  #78
                  @kakacs löschen brachst du ihn vor dem drüber installieren nicht. das sind nur kleine Änderungen die ich vornehme. Die Timedifference ist nebensächlich, das bedeutet nur dass der roboter und der adapter unterschiedliche uhrzeiten haben und die Nachrichten daran angepasst werden
                    kakacs
                    #79
                    @meistertr ok ich hab denn jetzt schon gelöscht wie meinst du leerzeichen davor
                    • K kakacs
                      audi1503
                      #80
                      @kakacs Du hattest vor dem Link nen Leerzeichen
                      • A audi1503
                        kakacs
                        #81
                        @audi1503 hab ich gemerckt grins ist das normal alles was da steht beim installieren
                        $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
                        install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3
                        NPM version: 6.14.11npm install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3 --loglevel error --prefix "/opt/iobroker" (System call)
                        canvas@2.7.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
                        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                        COPY Release/canvas-postbuild.node
                        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                        ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                        ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
                        ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
                        CXX(target) Release/obj.target/canvas/src/Backends.o
                        CXX(target) Release/obj.target/canvas/src/Canvas.o
                        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                        CXX(target) Release/obj.target/canvas/src/closure.o
                        CXX(target) Release/obj.target/canvas/src/color.o
                        CXX(target) Release/obj.target/canvas/src/Image.o
                        CXX(target) Release/obj.target/canvas/src/ImageData.o
                        CXX(target) Release/obj.target/canvas/src/init.o
                        CXX(target) Release/obj.target/canvas/src/register_font.o
                        SOLINK_MODULE(target) Release/obj.target/canvas.node
                        COPY Release/canvas.node
                        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                        • iobroker.mihome-vacuum@3.0.0
                          added 23 packages from 15 contributors in 70.367s
                        52 packages are looking for funding run npm fund for details
                        upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                        upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                        upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                        upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                        upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                        upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
                        upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                        upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                        upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                        upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                        upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                        upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                        process exited with code 0
                        das sagt der log jetzt
                        mihome-vacuum.0 2021-04-04 17:14:52.696 debug (2687) system.adapter.admin.0: logging true
                        mihome-vacuum.0 2021-04-04 16:14:51.546 debug (2687) Recievded params for viomi: {"result":[],"id":5,"exe_time":100}
                        mihome-vacuum.0 2021-04-04 16:14:51.545 debug (2687) MIIO RECIVE: {"result":[],"id":5,"exe_time":100}
                        mihome-vacuum.0 2021-04-04 16:14:51.206 debug (2687) Message= {"id":5,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                        mihome-vacuum.0 2021-04-04 16:14:51.204 debug (2687) get params for Viomi
                        mihome-vacuum.0 2021-04-04 16:14:49.851 warn (2687) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                        mihome-vacuum.0 2021-04-04 16:14:49.849 debug (2687) Receive <<< Helo <<< 21310020000000001661f4ca0005063cffffffffffffffffffffffffffffffff
                        mihome-vacuum.0 2021-04-04 16:14:31.203 debug (2687) Recievded params for viomi: {"result":[],"id":4,"exe_time":100}
                        mihome-vacuum.0 2021-04-04 16:14:31.201 debug (2687) MIIO RECIVE: {"result":[],"id":4,"exe_time":100}
                        mihome-vacuum.0 2021-04-04 16:14:30.897 debug (2687) system.adapter.admin.0: logging false
                        mihome-vacuum.0 2021-04-04 16:14:30.649 debug (2687) Message= {"id":4,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                        mihome-vacuum.0 2021-04-04 16:14:30.647 debug (2687) get params for Viomi
                        mihome-vacuum.0 2021-04-04 16:14:10.645 debug (2687) Recievded params for viomi: {"result":[],"id":3,"exe_time":100}
                        mihome-vacuum.0 2021-04-04 16:14:10.644 debug (2687) MIIO RECIVE: {"result":[],"id":3,"exe_time":100}
                        mihome-vacuum.0 2021-04-04 16:14:10.420 debug (2687) Message= {"id":3,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                        und es steht defentiv mehr drin Screenshot_2021-04-04 objects - ioBroker(1).png
                          kakacs
                          #82
                          @meistertr also ich kann jetzt über objecte steuern super arbeit echt ist das den möglich das ich den über alexa starten kann weil ja da in einstellung von dem adapter gibt die option füge ein status für alexa zu ??
                            viomi.vacuum.v19
                            installiere mal über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3
                            audi1503
                            #83
                            @meistertr Kann mit dem Adapter auch den mijia.vacuum.v2 steuern oder sind das auch andere Befehle wie mit dem Dreame.vacuum.mc1808. Diese beiden hab ich und die lassen sich noch nicht einbinden.
                            • K kakacs
                              MeistertrM Offline
                              MeistertrM Offline
                              Meistertr
                              #84
                              @kakacs aldos starten und stoppen geht?
                                kakacs
                                #85
                                @meistertr ich kann unter xiaomi objecten den sauger starten und auch pausieren
                                und zurück zur lade station schicken . das klappt super. jetzt würde ich ihn gern über alexa steuern also starten zu mindestens.
                                • K kakacs
                                  MeistertrM Offline
                                  MeistertrM Offline
                                  Meistertr
                                  schrieb am zuletzt editiert von Meistertr
                                  #86
                                  @kakacs hab da noch ein paar mehr anforderungen :) kannst du mal über sende eigene befehle (in der config aktivieren) ein paar sachen ausprobieren?
                                  get_status
                                  get_sound_volume
                                  get_consumable
                                  get_clean_summary
                                  get_map_v1
                                  und berichten was in response steht
                                    get_status
                                    get_sound_volume
                                    get_consumable
                                    get_clean_summary
                                    get_map_v1
                                    kakacs
                                    #87
                                    @meistertr ja klar kann ich gerne machen das ist kein problem
                                    • K kakacs
                                      MeistertrM Offline
                                      MeistertrM Offline
                                      Meistertr
                                      #88
                                      • A audi1503
                                        MeistertrM Offline
                                        MeistertrM Offline
                                        Meistertr
                                        #89
                                        @audi1503 sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                                        mijia.vacuum.v2
                                        bitte den Adapter installieren (rebulid3) einloggen und devices abrufen, Sauger auswählen eigene Kommandos aktivieren in config, speichern (nicht schließen) auf der ersten Seite oben rechts config downloaden2021-04-04_20h20_46.png
                                        deviceId in ein leeres Textfile speichern
                                        folgende Kommandos in untenstehender Form unter Objekten2021-04-04_19h53_04.png
                                        bei send_command eingeben
                                        Antworten bitte in ein Textfile kopieren, neben die Kommandos und posten
                                        Kommandos (PIID und SIID)
                                            # https://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:mijia-v1:1
                                            "battery": {"siid": 3, "piid": 1},
                                            "charge_state": {"siid": 3, "piid": 2},
                                            "error": {"siid": 2, "piid": 2},
                                            "state": {"siid": 2, "piid": 1},
                                            "fan_speed": {"siid": 2, "piid": 6},
                                            "operating_mode": {"siid": 2, "piid": 4},
                                            "mop_state": {"siid": 16, "piid": 1},
                                            "water_level": {"siid": 2, "piid": 5},
                                            "brush_life_level": {"siid": 14, "piid": 1},
                                            #  "brush_life_time": {"siid": 14, "piid": 2},
                                            "brush_life_level2": {"siid": 15, "piid": 1},
                                            #  "brush_life_time2": {"siid": 15, "piid": 2},
                                            "filter_life_level": {"siid": 11, "piid": 1},
                                            #  "filter_life_time": {"siid": 11, "piid": 2},
                                            "clean_area": {"siid": 9, "piid": 1},
                                            "clean_time": {"siid": 18, "piid": 5},
                                            "total_clean_count": {"siid": 9, "piid": 5},
                                            #   "total_clean_area": {"siid": 9, "piid": 3},
                                            #  "dnd_enabled": {"siid": 12, "piid": 2},
                                            #  "audio_volume": {"siid": 4, "piid": 2},
                                            #  "direction_key": {"siid": 8, "piid": 1}
                                        das ist die form wie es in das Objekt muss:
                                        get_properties;[{"did":"AUSCONFIG","siid":3,"piid":1}]
                                        Bitte einmal durchtesten
                                          audi1503
                                          schrieb am zuletzt editiert von audi1503
                                          #90
                                          @Meistertr
                                          Hier die angeforderten Antworten auf den Kommandos:
                                          "battery": {"siid": 3, "piid": 1},                = [{"did":"334314795","siid":3,"piid":1,"code":0,"value":100}]
                                          "charge_state": {"siid": 3, "piid": 2},           = [{"did":"334314795","siid":3,"piid":2,"code":0,"value":2}]
                                          "error": {"siid": 2, "piid": 2},                  = [{"did":"334314795","siid":2,"piid":2,"code":0,"value":0}]
                                          "state": {"siid": 2, "piid": 1},                  = [{"did":"334314795","siid":2,"piid":1,"code":0,"value":5}]
                                          "fan_speed": {"siid": 2, "piid": 6},              = [{"did":"334314795","siid":2,"piid":6,"code":0,"value":1}]
                                          "operating_mode": {"siid": 2, "piid": 4},         = [{"did":"334314795","siid":2,"piid":4,"code":0,"value":1}]
                                          "mop_state": {"siid": 16, "piid": 1},             = [{"did":"334314795","siid":16,"piid":1,"code":0,"value":0}]
                                          "water_level": {"siid": 2, "piid": 5},            = [{"did":"334314795","siid":2,"piid":5,"code":0,"value":2}]
                                          "brush_life_level": {"siid": 14, "piid": 1},      = [{"did":"334314795","siid":14,"piid":1,"code":0,"value":58}]
                                          #  "brush_life_time": {"siid": 14, "piid": 2},    = [{"did":"334314795","siid":14,"piid":2,"code":0,"value":10504}]
                                          "brush_life_level2": {"siid": 15, "piid": 1},     = [{"did":"334314795","siid":15,"piid":1,"code":0,"value":14}]
                                          #  "brush_life_time2": {"siid": 15, "piid": 2},   = [{"did":"334314795","siid":15,"piid":2,"code":0,"value":1280}]
                                          "filter_life_level": {"siid": 11, "piid": 1},     = [{"did":"334314795","siid":11,"piid":1,"code":0,"value":16}]
                                          #  "filter_life_time": {"siid": 11, "piid": 2},   = [{"did":"334314795","siid":11,"piid":2,"code":0,"value":1504}]
                                          "clean_area": {"siid": 9, "piid": 1},             = [{"did":"334314795","siid":9,"piid":1,"code":0,"value":0}]
                                          "clean_time": {"siid": 18, "piid": 5},            = [{"did":"334314795","siid":18,"piid":5,"code":-4003}]
                                          "total_clean_count": {"siid": 9, "piid": 5},      = [{"did":"334314795","siid":9,"piid":5,"code":0,"value":0}]
                                          #   "total_clean_area": {"siid": 9, "piid": 3},   = [{"did":"334314795","siid":9,"piid":3,"code":0,"value":0}]
                                          #  "dnd_enabled": {"siid": 12, "piid": 2},        = [{"did":"334314795","siid":12,"piid":2,"code":0,"value":false}]
                                          #  "audio_volume": {"siid": 4, "piid": 2},        = [MESSAGE TIMEOUT]
                                          #  "direction_key": {"siid": 8, "piid": 1}        = [{"did":"334314795","siid":8,"piid":1,"code":-4003}]
                                          Habe im Log auch noch Model mijia.vacuum.v2 not supported stehen
