  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
    kakacs
    #66
    @meistertr das model ist viomi.vacuum.v19
    wenn ich den andapter von dir installiere kommt das bei der installation raus .
    $ ./iobroker url "https://github.com/MeisterTR/ioBroker.mihome-vacuum" --debug
    install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee
    NPM version: 6.14.11
    npm install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee --loglevel error --prefix "/opt/iobroker" (System call)
    canvas@2.7.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
    SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
    COPY Release/canvas-postbuild.node
    CXX(target) Release/obj.target/canvas/src/backend/Backend.o
    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
    ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
    ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
    CXX(target) Release/obj.target/canvas/src/Backends.o
    CXX(target) Release/obj.target/canvas/src/Canvas.o
    CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
    CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
    CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
    CXX(target) Release/obj.target/canvas/src/closure.o
    CXX(target) Release/obj.target/canvas/src/color.o
    CXX(target) Release/obj.target/canvas/src/Image.o
    CXX(target) Release/obj.target/canvas/src/ImageData.o
    CXX(target) Release/obj.target/canvas/src/init.o
    CXX(target) Release/obj.target/canvas/src/register_font.o
    SOLINK_MODULE(target) Release/obj.target/canvas.node
    COPY Release/canvas.node
    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
    • iobroker.mihome-vacuum@3.0.2added 23 packages from 15 contributors in 68.776s
    52 packages are looking for funding run npm fund for details
    upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
    upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
    upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
    upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
    upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
    upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
    upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
    upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
    upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
    upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
    upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
    upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
    process exited with code 0
    und das kommt beim log raus :
    mihome-vacuum.0 2021-04-04 10:59:11.969 warn (19248) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0 2021-04-04 10:59:11.967 info (19248) terminating
    mihome-vacuum.0 2021-04-04 10:59:11.942 error (19248) Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 10:59:11.941 error (19248) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
    mihome-vacuum.0 2021-04-04 10:59:11.939 error (19248) unhandled promise rejection: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 10:59:11.937 error (19248) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0 2021-04-04 10:59:01.898 info (19248) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 10:59:01.893 info (19248) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 10:59:01.687 info (19248) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-04-04 10:58:29.564 warn (19214) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0 2021-04-04 10:58:29.562 info (19214) terminating
    mihome-vacuum.0 2021-04-04 10:58:29.542 error (19214) Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 10:58:29.541 error (19214) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
    mihome-vacuum.0 2021-04-04 10:58:29.539 error (19214) unhandled promise rejection: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 10:58:29.538 error (19214) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0 2021-04-04 10:58:19.440 info (19214) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 10:58:19.435 info (19214) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 10:58:19.235 info (19214) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-04-04 10:57:47.070 warn (19187) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0 2021-04-04 10:57:47.068 info (19187) terminating
    mihome-vacuum.0 2021-04-04 10:57:47.044 error (19187) Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 10:57:47.043 error (19187) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
    mihome-vacuum.0 2021-04-04 10:57:47.040 error (19187) unhandled promise rejection: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 10:57:47.039 error (19187) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0 2021-04-04 09:57:36.943 info (19187) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 09:57:36.938 info (19187) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 09:57:36.729 info (19187) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-04-04 09:56:28.779 warn (19145) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0 2021-04-04 09:56:28.776 info (19145) terminating
    mihome-vacuum.0 2021-04-04 09:56:28.752 error (19145) Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:56:28.751 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
    mihome-vacuum.0 2021-04-04 09:56:28.751 error (19145) TypeError: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:56:28.748 error (19145) unhandled promise rejection: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:56:28.747 error (19145) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0 2021-04-04 09:56:18.711 info (19145) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 09:56:18.707 info (19145) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 09:56:18.498 info (19145) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-04-04 09:55:46.333 warn (19125) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0 2021-04-04 09:55:46.330 info (19125) terminating
    mihome-vacuum.0 2021-04-04 09:55:46.302 error (19125) Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:55:46.301 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
    mihome-vacuum.0 2021-04-04 09:55:46.301 error (19125) TypeError: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:55:46.299 error (19125) unhandled promise rejection: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:55:46.297 error (19125) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0 2021-04-04 09:55:36.204 info (19125) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 09:55:36.199 info (19125) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 09:55:35.993 info (19125) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-04-04 09:55:03.867 warn (19100) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0 2021-04-04 09:55:03.864 info (19100) terminating
    mihome-vacuum.0 2021-04-04 09:55:03.840 error (19100) Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:55:03.838 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
    mihome-vacuum.0 2021-04-04 09:55:03.838 error (19100) TypeError: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:55:03.836 error (19100) unhandled promise rejection: Cannot read property 'val' of null
    mihome-vacuum.0 2021-04-04 09:55:03.835 error (19100) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0 2021-04-04 09:54:53.734 info (19100) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 09:54:53.729 info (19100) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 09:54:53.507 info (19100) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-04-04 09:54:48.899 info (19033) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mihome-vacuum.0 2021-04-04 09:54:48.897 info (19033) terminating
    mihome-vacuum.0 2021-04-04 09:54:48.894 info (19033) Got terminate signal TERMINATE_YOURSELF
    mihome-vacuum.0 2021-04-04 09:52:32.454 info (19033) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 09:52:32.449 info (19033) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 09:52:32.235 info (19033) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    aber was mir auffällt ist das ein ganz andere token angezeigt wird als ich von der app ausgelesen habe.
    MeistertrM 1 Antwort Letzte Antwort
    • K kakacs
      MeistertrM Offline
      MeistertrM Offline
      Meistertr
      #67
      @kakacs sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
      viomi.vacuum.v19
      installiere mal über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3
      K A 2 Antworten Letzte Antwort
      • MeistertrM Meistertr
        viomi.vacuum.v19
        kakacs
        #68
        @meistertr super mit dem wird die instanz grün und unter objekten steht schon mal was Screenshot_2021-04-04 objects - ioBroker.png
        aber es ändert sich nichts an wenn ich den staubsauger starte im log habe ich das jetzt
        mihome-vacuum.0 2021-04-04 14:22:50.827 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
        mihome-vacuum.0 2021-04-04 13:21:50.822 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
        mihome-vacuum.0 2021-04-04 13:20:50.934 warn (23416) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
        mihome-vacuum.0 2021-04-04 13:20:50.718 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        mihome-vacuum.0 2021-04-04 13:20:50.639 info (23416) check group user admin group admin: false
        mihome-vacuum.0 2021-04-04 13:20:50.633 info (23416) check user admin pw iobroker: true
        mihome-vacuum.0 2021-04-04 13:20:50.408 info (23416) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
        mihome-vacuum.0 2021-04-04 13:20:45.741 info (23341) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mihome-vacuum.0 2021-04-04 13:20:45.739 info (23341) terminating
        mihome-vacuum.0 2021-04-04 13:20:45.736 info (23341) Got terminate signal TERMINATE_YOURSELF
        mihome-vacuum.0 2021-04-04 13:20:28.689 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        mihome-vacuum.0 2021-04-04 13:19:28.676 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        mihome-vacuum.0 2021-04-04 13:18:28.669 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        mihome-vacuum.0 2021-04-04 13:17:30.856 warn (23341) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
        mihome-vacuum.0 2021-04-04 13:17:28.662 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
        • K kakacs
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          #69
          @kakacs bitte mal auf debug stellen und den log posten
            kakacs
            #70
            @meistertr jetzt musst du mir helfen wie stell ich denn auf debug??
            • K kakacs
              MeistertrM Offline
              MeistertrM Offline
              Meistertr
              #71
              @kakacs https://www.google.com/search?q=wie+stelle+ich+iobroker+auf+debug&ie=utf-8&oe=utf-8&aq=t
              K 2 Antworten Letzte Antwort
                kakacs
                #72
                @meistertr danke
                mihome-vacuum.0 2021-04-04 14:47:43.491 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                mihome-vacuum.0 2021-04-04 14:47:43.488 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f1d1ffffffffffffffffffffffffffffffff
                mihome-vacuum.0 2021-04-04 14:46:43.720 warn (25026) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                mihome-vacuum.0 2021-04-04 14:46:43.720 debug (25026) DeviceModel selected to: viomi.vacuum.v19
                mihome-vacuum.0 2021-04-04 14:46:43.719 debug (25026) Get Device data from robot..
                mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) Get Device data..0
                mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) GETMODELFROMAPI:Data: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:C
                mihome-vacuum.0 2021-04-04 14:46:43.717 debug (25026) MIIO RECIVE: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw
                mihome-vacuum.0 2021-04-04 14:46:43.511 debug (25026) Message= {"id":1,"method":"miIO.info"}
                mihome-vacuum.0 2021-04-04 14:46:43.509 debug (25026) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617543894399,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
                mihome-vacuum.0 2021-04-04 14:46:43.396 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                mihome-vacuum.0 2021-04-04 14:46:43.393 debug (25026) MAIN: Connected to device, try to get model..
                mihome-vacuum.0 2021-04-04 14:46:43.392 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f195ffffffffffffffffffffffffffffffff
                mihome-vacuum.0 2021-04-04 14:46:43.306 debug (25026) server started on 0.0.0.0:53421
                mihome-vacuum.0 2021-04-04 14:46:43.298 debug (25026) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
                mihome-vacuum.0 2021-04-04 14:46:43.296 info (25026) check group user admin group admin: false
                mihome-vacuum.0 2021-04-04 14:46:43.291 info (25026) check user admin pw iobroker: true
                mihome-vacuum.0 2021-04-04 14:46:43.078 info (25026) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                mihome-vacuum.0 2021-04-04 14:46:42.875 debug (25026) statesDB connected
                mihome-vacuum.0 2021-04-04 14:46:42.874 debug (25026) States connected to redis: 127.0.0.1:9000
                mihome-vacuum.0 2021-04-04 14:46:42.862 debug (25026) States create User PubSub Client
                mihome-vacuum.0 2021-04-04 14:46:42.861 debug (25026) States create System PubSub Client
                mihome-vacuum.0 2021-04-04 14:46:42.849 debug (25026) Redis States: Use Redis connection: 127.0.0.1:9000
                mihome-vacuum.0 2021-04-04 14:46:42.847 debug (25026) objectDB connected
                mihome-vacuum.0 2021-04-04 14:46:42.837 debug (25026) Objects connected to redis: 127.0.0.1:9001
                mihome-vacuum.0 2021-04-04 14:46:42.819 debug (25026) Objects client initialize lua scripts
                mihome-vacuum.0 2021-04-04 14:46:42.818 debug (25026) Objects create User PubSub Client
                mihome-vacuum.0 2021-04-04 14:46:42.816 debug (25026) Objects create System PubSub Client
                mihome-vacuum.0 2021-04-04 14:46:42.805 debug (25026) Objects client ready ... initialize now
                mihome-vacuum.0 2021-04-04 14:46:42.764 debug (25026) Redis Objects: Use Redis connection: 127.0.0.1:9001
                mihome-vacuum.0 2021-04-04 14:46:38.420 info (24980) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                mihome-vacuum.0 2021-04-04 14:46:38.417 info (24980) terminating
                mihome-vacuum.0 2021-04-04 14:46:38.414 info (24980) Got terminate signal TERMINATE_YOURSELF
                  kakacs
                  #73
                  @meistertr
                  mihome-vacuum.0 2021-04-04 15:58:57.637 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                  mihome-vacuum.0 2021-04-04 15:58:57.635 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f474ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0 2021-04-04 15:58:56.681 debug (1208) system.adapter.admin.0: logging true
                  mihome-vacuum.0 2021-04-04 14:58:22.365 debug (1208) sendTo "discovery" to system.adapter.admin.0 from system.adapter.mihome-vacuum.0
                  mihome-vacuum.0 2021-04-04 14:58:22.364 debug (1208) discover__[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":"192.168.178.75","mac":"5C:6B:D7
                  mihome-vacuum.0 2021-04-04 14:58:22.362 debug (1208) {"code":0,"message":"ok","result":{"list":[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":
                  mihome-vacuum.0 2021-04-04 14:58:22.231 debug (1208) GET devices from:https://de.api.io.mi.com/app/home/device_list
                  mihome-vacuum.0 2021-04-04 14:58:22.223 debug (1208) Xiaomi Cloud: Login successful
                  mihome-vacuum.0 2021-04-04 14:58:22.222 debug (1208) Login step3: [{"key":"userId","value":"6432461162","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-04-04T13:58:22.179Z","lastAccessed":"2021-04-04T13:58:22.220Z"},{"k
                  mihome-vacuum.0 2021-04-04 14:58:21.945 debug (1208) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"XXyyLiOls5U1ionL2h/ygw==","code":0,"passToken":"V1:bOtEAOudpqEL/PTNVjfNjI1KRycqTK7DU62Fk/J18icmBS60DBX3c+rn/eV5WKs
                  mihome-vacuum.0 2021-04-04 14:58:21.340 debug (1208) Login step1: &&&START&&&{"serviceParam":"{"checkSafePhone":false,"checkSafeAddress":false,"lsrp_score":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callb
                  mihome-vacuum.0 2021-04-04 14:58:20.465 debug (1208) Xiaomi Cloud: Logging in
                  mihome-vacuum.0 2021-04-04 14:57:57.631 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                  mihome-vacuum.0 2021-04-04 14:57:57.629 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f438ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0 2021-04-04 14:57:53.101 debug (1208) system.adapter.admin.0: logging false
                  mihome-vacuum.0 2021-04-04 14:56:57.590 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                  mihome-vacuum.0 2021-04-04 14:56:57.589 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3fcffffffffffffffffffffffffffffffff
                  mihome-vacuum.0 2021-04-04 14:55:57.559 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                  mihome-vacuum.0 2021-04-04 14:55:57.558 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3bfffffffffffffffffffffffffffffffff
                  mihome-vacuum.0 2021-04-04 14:54:57.502 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                  mihome-vacuum.0 2021-04-04 14:54:57.500 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f383ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0 2021-04-04 14:53:57.741 warn (1208) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                  mihome-vacuum.0 2021-04-04 14:53:57.740 debug (1208) DeviceModel selected to: viomi.vacuum.v19
                  mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data from robot..
                  mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data..0
                  mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) GETMODELFROMAPI:Data: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA
                  mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) MIIO RECIVE: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw_
                  mihome-vacuum.0 2021-04-04 14:53:57.442 debug (1208) Message= {"id":1,"method":"miIO.info"}
                  mihome-vacuum.0 2021-04-04 14:53:57.440 debug (1208) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617544003728,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
                  mihome-vacuum.0 2021-04-04 14:53:57.436 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                  mihome-vacuum.0 2021-04-04 14:53:57.433 debug (1208) MAIN: Connected to device, try to get model..
                  mihome-vacuum.0 2021-04-04 14:53:57.432 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f347ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0 2021-04-04 14:53:57.340 debug (1208) server started on 0.0.0.0:53421
                  mihome-vacuum.0 2021-04-04 14:53:57.332 debug (1208) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
                  mihome-vacuum.0 2021-04-04 14:53:57.330 info (1208) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 14:53:57.325 info (1208) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 14:53:57.113 info (1208) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.0, js-controller: 3.2.16
                  mihome-vacuum.0 2021-04-04 14:53:56.874 debug (1208) statesDB connected
                  mihome-vacuum.0 2021-04-04 14:53:56.873 debug (1208) States connected to redis: 127.0.0.1:9000
                  mihome-vacuum.0 2021-04-04 14:53:56.866 debug (1208) States create User PubSub Client
                  mihome-vacuum.0 2021-04-04 14:53:56.864 debug (1208) States create System PubSub Client
                  mihome-vacuum.0 2021-04-04 14:53:56.857 debug (1208) Redis States: Use Redis connection: 127.0.0.1:9000
                  mihome-vacuum.0 2021-04-04 14:53:56.854 debug (1208) objectDB connected
                  mihome-vacuum.0 2021-04-04 14:53:56.845 debug (1208) Objects connected to redis: 127.0.0.1:9001
                  mihome-vacuum.0 2021-04-04 14:53:56.822 debug (1208) Objects client initialize lua scripts
                  mihome-vacuum.0 2021-04-04 14:53:56.821 debug (1208) Objects create User PubSub Client
                  mihome-vacuum.0 2021-04-04 14:53:56.819 debug (1208) Objects create System PubSub Client
                  mihome-vacuum.0 2021-04-04 14:53:56.816 debug (1208) Objects client ready ... initialize now
                  mihome-vacuum.0 2021-04-04 14:53:56.753 debug (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  • K kakacs
                    @meistertr
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    #74
                    viomi.vacuum.v19
                    bitte nochmal von git installieren und debug posten (bitte log in codetags)
                      viomi.vacuum.v19
                      kakacs
                      #75
                      @meistertr @meistertr said in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                      log in codetags
                      ok mache ich wie geht das mit log in code tags ??? bin noch nicht so fit mit iobroker sorry.
                      hast du geshen in dem log was ich gepostet habe ws bedeutet das
                      Time difference between Mihome Vacuum and ioBroker ich installier den adapter noch mal neu den du mir empfohlen hast richtig?? und soll ich erst wieder löschen ??
                        viomi.vacuum.v19
                        kakacs
                        #76
                        @meistertr hab den gelöscht und will den noch mal installieren und dann kommt das
                        $ ./iobroker url " https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
                        install "
                        npm install " --loglevel error --prefix "/opt/iobroker" (System call)
                        /bin/sh: 1: Syntax error: Unterminated quoted string
                        ERROR: host.raspberrypi Cannot install ": 2
                        • K kakacs
                          install "
                          MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          #77
                          leerzeichen davor
                          • K kakacs
                            log in codetags
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #78
                            @kakacs löschen brachst du ihn vor dem drüber installieren nicht. das sind nur kleine Änderungen die ich vornehme. Die Timedifference ist nebensächlich, das bedeutet nur dass der roboter und der adapter unterschiedliche uhrzeiten haben und die Nachrichten daran angepasst werden
                              kakacs
                              #79
                              @meistertr ok ich hab denn jetzt schon gelöscht wie meinst du leerzeichen davor
                              • K kakacs
                                audi1503
                                #80
                                @kakacs Du hattest vor dem Link nen Leerzeichen
                                • A audi1503
                                  kakacs
                                  #81
                                  @audi1503 hab ich gemerckt grins ist das normal alles was da steht beim installieren
                                  $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
                                  install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3
                                  NPM version: 6.14.11npm install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3 --loglevel error --prefix "/opt/iobroker" (System call)
                                  • iobroker.mihome-vacuum@3.0.0
                                    added 23 packages from 15 contributors in 70.367s
                                  das sagt der log jetzt
                                  mihome-vacuum.0 2021-04-04 17:14:52.696 debug (2687) system.adapter.admin.0: logging true
                                  mihome-vacuum.0 2021-04-04 16:14:51.546 debug (2687) Recievded params for viomi: {"result":[],"id":5,"exe_time":100}
                                  mihome-vacuum.0 2021-04-04 16:14:51.545 debug (2687) MIIO RECIVE: {"result":[],"id":5,"exe_time":100}
                                  mihome-vacuum.0 2021-04-04 16:14:51.206 debug (2687) Message= {"id":5,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                                  mihome-vacuum.0 2021-04-04 16:14:51.204 debug (2687) get params for Viomi
                                  mihome-vacuum.0 2021-04-04 16:14:49.851 warn (2687) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                                  mihome-vacuum.0 2021-04-04 16:14:49.849 debug (2687) Receive <<< Helo <<< 21310020000000001661f4ca0005063cffffffffffffffffffffffffffffffff
                                  mihome-vacuum.0 2021-04-04 16:14:31.203 debug (2687) Recievded params for viomi: {"result":[],"id":4,"exe_time":100}
                                  mihome-vacuum.0 2021-04-04 16:14:31.201 debug (2687) MIIO RECIVE: {"result":[],"id":4,"exe_time":100}
                                  mihome-vacuum.0 2021-04-04 16:14:30.897 debug (2687) system.adapter.admin.0: logging false
                                  mihome-vacuum.0 2021-04-04 16:14:30.649 debug (2687) Message= {"id":4,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                                  mihome-vacuum.0 2021-04-04 16:14:30.647 debug (2687) get params for Viomi
                                  mihome-vacuum.0 2021-04-04 16:14:10.645 debug (2687) Recievded params for viomi: {"result":[],"id":3,"exe_time":100}
                                  mihome-vacuum.0 2021-04-04 16:14:10.644 debug (2687) MIIO RECIVE: {"result":[],"id":3,"exe_time":100}
                                  mihome-vacuum.0 2021-04-04 16:14:10.420 debug (2687) Message= {"id":3,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                                  und es steht defentiv mehr drin Screenshot_2021-04-04 objects - ioBroker(1).png
                                    kakacs
                                    #82
                                    @meistertr also ich kann jetzt über objecte steuern super arbeit echt ist das den möglich das ich den über alexa starten kann weil ja da in einstellung von dem adapter gibt die option füge ein status für alexa zu ??
                                      viomi.vacuum.v19
                                      audi1503
                                      #83
                                      @meistertr Kann mit dem Adapter auch den mijia.vacuum.v2 steuern oder sind das auch andere Befehle wie mit dem Dreame.vacuum.mc1808. Diese beiden hab ich und die lassen sich noch nicht einbinden.
                                      • K kakacs
                                        MeistertrM Offline
                                        MeistertrM Offline
                                        Meistertr
                                        #84
                                        @kakacs aldos starten und stoppen geht?
                                          kakacs
                                          #85
                                          @meistertr ich kann unter xiaomi objecten den sauger starten und auch pausieren
                                          und zurück zur lade station schicken . das klappt super. jetzt würde ich ihn gern über alexa steuern also starten zu mindestens.
