  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
    kakacs
    @da_Woody
    so steht im log jetzt
      kakacs
      hätte einer vielleicht eine idee noch was das problem sein kann ???
      Danke im voraus
        kakacs
        @Meistertr @da_Woody
        hab es gerade noch mal versucht den adptar manuel installiert
        das gibt er mir raus bei installieren ist dieses loglevel error normal ?
        $ ./iobroker url "https://github.com/MeisterTR/ioBroker.mihome-vacuum" --debug
        install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee
        NPM version: 6.14.11
        npm install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee --loglevel error --prefix "/opt/iobroker" (System call)
        canvas@2.7.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
        COPY Release/canvas-postbuild.node
        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
        ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
        ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
        ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
        CXX(target) Release/obj.target/canvas/src/closure.o
        CXX(target) Release/obj.target/canvas/src/color.o
        CXX(target) Release/obj.target/canvas/src/Image.o
        CXX(target) Release/obj.target/canvas/src/ImageData.o
        CXX(target) Release/obj.target/canvas/src/init.o
        CXX(target) Release/obj.target/canvas/src/register_font.o
        SOLINK_MODULE(target) Release/obj.target/canvas.node
        COPY Release/canvas.node
        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
        • iobroker.mihome-vacuum@3.0.2added 22 packages from 16 contributors in 72.94s
          46 packages are looking for funding run npm fund for details
          upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
          upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
          upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
          upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
          upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
          upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
          upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
          upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
          upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
          upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
          upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
          upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
          process exited with code 0
        • MeistertrM Meistertr
          Aktuelle Test Version 3.0.1-alpha
          Veröffentlichungsdatum 22.09.2020
          Github Link https://github.com/MeisterTR/ioBroker.mihome-vacuum
          Hallo Leute in der letzten Zeit bring Xioami immer mehr Saugroboter auf den Markt die keine Eigenmarke sind und von der bisherigen Api vollkommen abweichen.
          Um diese und die Zukünftigen Geräte besser und schneller integrieren zu können, war ein kompletter rework des Adapters erforderlich.
          Was hat sich geändert:
          • erstmal alles
          • im alten Adapter wurden erstmal alle daten abgefragt ohne überhaupt zu wissen ob das Model überhaupt die Eigenschaften hat, jetzt wird erst das Model ermittelt und je nachdem dann die verschieden Dateien geladen. Das stabilisiert die Verbindung und führt zu keinen Verbindungsproblemen mehr
          • jede api/Model bekommt sein eigenes File wo ggf. Funktionen wie Raumreinigung und Karte geladen werden.
          in den ersten 3er Versionen geht es NUR im die Viomi Modelle (STYJ02YM /Mi Mop Pro und STYJ02YM)
          wenn die soweit laufen hole ich die anderen nach und nach mit an board
          GoodOld
          schrieb am zuletzt editiert von GoodOld
          @meistertr Moin, ich teste gerade den neuen (noch nicht auf dem Markt) den Dreame L10 Pro.
          Adapter ist grün, aber leider werden nur die Üblichen Datenpunkte erzeugt wie "device Info" & "info".
          Falls ich irgendwie helfen kann, einfach melden.
          PS: Aktuell lässte er sich nur über den China Server einbinden.
          mihome-vacuum.0	2021-04-02 18:57:10.832	warn	(1526) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
          mihome-vacuum.0	2021-04-02 18:57:10.832	debug	(1526) DeviceModel selected to: dreame.vacuum.p2029
          mihome-vacuum.0	2021-04-02 18:57:10.830	debug	(1526) Get Device data from robot..
          mihome-vacuum.0	2021-04-02 18:57:10.829	debug	(1526) Get Device data..1
          mihome-vacuum.0	2021-04-02 18:57:10.828	debug	(1526) GETMODELFROMAPI:Data: {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1038","ap":{"ssid":"Hust24","bssid":"xxxxxxx","rssi":-43},"netif":{"l
          mihome-vacuum.0	2021-04-02 18:57:10.821	debug	(1526) Get Device data..0
          mihome-vacuum.0	2021-04-02 18:57:08.812	debug	(1526) GETMODELFROMAPI: objModel: {"val":"dreame.vacuum.p2029","ack":true,"ts":1617xxxxx189,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":161xxxxx60}
          mihome-vacuum.0	2021-04-02 18:57:08.803	debug	(1526) MAIN: Connected to device, try to get model..
          mihome-vacuum.0	2021-04-02 18:57:08.794	debug	(1526) server started on 0.0.0.0:53421
          mihome-vacuum.0	2021-04-02 18:57:08.779	debug	(1526) MIIO: Config: ip:192.168.178.249 token: 737xxxxxxxxxxxxxxxxx4
          mihome-vacuum.0	2021-04-02 18:57:08.777	debug	(1526) load Map creator... true
          mihome-vacuum.0	2021-04-02 18:57:08.656	info	(1526) check group user admin group admin: false
          mihome-vacuum.0	2021-04-02 18:57:08.638	info	(1526) check user admin pw iobroker: false
          mihome-vacuum.0	2021-04-02 18:57:08.340	info	(1526) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
          mihome-vacuum.0	2021-04-02 18:57:07.541	debug	(1526) statesDB connected
          mihome-vacuum.0	2021-04-02 18:57:07.536	debug	(1526) States connected to redis: 127.0.0.1:9010
          mihome-vacuum.0	2021-04-02 18:57:07.489	debug	(1526) States create User PubSub Client
          mihome-vacuum.0	2021-04-02 18:57:07.488	debug	(1526) States create System PubSub Client
          mihome-vacuum.0	2021-04-02 18:57:07.464	debug	(1526) Redis States: Use Redis connection: 127.0.0.1:9010
          mihome-vacuum.0	2021-04-02 18:57:07.459	debug	(1526) objectDB connected
          mihome-vacuum.0	2021-04-02 18:57:07.436	debug	(1526) Objects connected to redis: 127.0.0.1:9011
          mihome-vacuum.0	2021-04-02 18:57:07.386	debug	(1526) Objects client initialize lua scripts
          mihome-vacuum.0	2021-04-02 18:57:07.385	debug	(1526) Objects create User PubSub Client
          mihome-vacuum.0	2021-04-02 18:57:07.383	debug	(1526) Objects create System PubSub Client
          mihome-vacuum.0	2021-04-02 18:57:07.377	debug	(1526) Objects client ready ... initialize now
          mihome-vacuum.0	2021-04-02 18:57:06.864	debug	(1526) Redis Objects: Use Redis connection: 127.0.0.1:9011
          mihome-vacuum.0	2021-04-02 18:57:01.857	info	(1122) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          mihome-vacuum.0	2021-04-02 18:57:01.855	info	(1122) terminating
          mihome-vacuum.0	2021-04-02 18:57:01.853	info	(1122) Got terminate signal TERMINATE_YOURSELF
          mihome-vacuum.0	2021-04-02 18:56:07.176	warn	(1122) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
          mihome-vacuum.0	2021-04-02 18:56:07.065	info	(1122) check group user admin group admin: false
          mihome-vacuum.0	2021-04-02 18:56:07.056	info	(1122) check user admin pw iobroker: false
          mihome-vacuum.0	2021-04-02 18:56:06.715	info	(1122) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
          mihome-vacuum.0	2021-04-02 18:55:59.896	info	(632) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          mihome-vacuum.0	2021-04-02 18:55:59.894	info	(632) terminating
          mihome-vacuum.0	2021-04-02 18:55:59.891	info	(632) Got terminate signal TERMINATE_YOURSELF
          mihome-vacuum.0	2021-04-02 18:55:09.233	warn	(632) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
          mihome-vacuum.0	2021-04-02 18:55:05.102	info	(632) check group user admin group admin: false
          mihome-vacuum.0	2021-04-02 18:55:05.093	info	(632) check user admin pw iobroker: false
          mihome-vacuum.0	2021-04-02 18:55:04.753	info	(632) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
          mihome-vacuum.0	2021-04-02 18:54:57.748	info	(32156) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          mihome-vacuum.0	2021-04-02 18:54:57.746	info	(32156) terminating
          mihome-vacuum.0	2021-04-02 18:54:57.743	info	(32156) Got terminate signal TERMINATE_YOURSEL
          MeistertrM 1 Antwort Letzte Antwort
          • G GoodOld
            MeistertrM Offline
            MeistertrM Offline
            Meistertr
            @goodold die Dream Modelle kommunizieren anders als die anderen nicht über miio sondern über miot das ist das neue Standartprotokoll von xiaomi mit DID (DeviceID kein Problem kommt mit über die cloud) SID (ServiceID) und PID (ParameterID) wie meine Nachforschungen ergeben haben geht diese Kommunikation auch verschlüsselt über udp wie beim miio (Schonmal gut somit kann man das alte nutzen) Ich bin gerade wieder mal an dem Adapter rewrite und baue es so, dass es Modular aufgebaut ist und schnell und einfach neue Geräte hinzugefügt werden können.
            Jetzt Kommt aber das ABER Das Testen der Nachrichten ist sehr zeitaufwendig. Hilfe bietet jeder an (das aber auch nur, wenn es um bugreport und testen geht) für miot gibt es eine webapi wo alle komandos beschrieben sind (Reschere über git adresse ist mi.spect....) Der Adapter bieten in allen Versionen die Möglichkeit eigene Komandos zu schicken. also eigentlich nichts weltbewegendes, was auch jeder Beginner kann.
            Ablauf:
            1: Komandos SID und PID aus der mi.spect suchen (da gibs für jedes device einen apiurl)
            2: config aus admin herunterladen und mit dem Texteditor öffen (unter devices müsste in einer json die DID stehen)
            3: am besten in einen Texteditor die Messages zusammenbauen und abschicken und sehen was zurückkommt.
            4: das ganze dokumentieren und mir zukommen lassen. dann ist der Roboter im nu eingebunden
            da fällt mir gerade ein dass es so mit dem adapter noch nciht geht weil die Nachricht auf miio standard geprüft wird. Wenn Interesse besteht mach ich eine Version fertig in der man raw daten senden kann.
              kakacs
              @Meistertr gild das auch für den xiaomi viomi se ??? ich bekomme denn nicht verbunden mit dem adapter ??
              • K kakacs
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                @kakacs gibt es da etwas nähere ausführungen? debuglog? wie ist die Modellbezeichnung also viomi.vacuum.xxx
                  kakacs
                  #66
                  @meistertr das model ist viomi.vacuum.v19
                  wenn ich den andapter von dir installiere kommt das bei der installation raus .
                  ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
                  • iobroker.mihome-vacuum@3.0.2added 23 packages from 15 contributors in 68.776s
                  52 packages are looking for funding run npm fund for details
                  und das kommt beim log raus :
                  mihome-vacuum.0 2021-04-04 10:59:11.969 warn (19248) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  mihome-vacuum.0 2021-04-04 10:59:11.967 info (19248) terminating
                  mihome-vacuum.0 2021-04-04 10:59:11.942 error (19248) Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 10:59:11.941 error (19248) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                  mihome-vacuum.0 2021-04-04 10:59:11.939 error (19248) unhandled promise rejection: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 10:59:11.937 error (19248) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  mihome-vacuum.0 2021-04-04 10:59:01.898 info (19248) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 10:59:01.893 info (19248) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 10:59:01.687 info (19248) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                  mihome-vacuum.0 2021-04-04 10:58:29.564 warn (19214) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  mihome-vacuum.0 2021-04-04 10:58:29.562 info (19214) terminating
                  mihome-vacuum.0 2021-04-04 10:58:29.542 error (19214) Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 10:58:29.541 error (19214) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                  mihome-vacuum.0 2021-04-04 10:58:29.539 error (19214) unhandled promise rejection: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 10:58:29.538 error (19214) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  mihome-vacuum.0 2021-04-04 10:58:19.440 info (19214) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 10:58:19.435 info (19214) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 10:58:19.235 info (19214) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                  mihome-vacuum.0 2021-04-04 10:57:47.070 warn (19187) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  mihome-vacuum.0 2021-04-04 10:57:47.068 info (19187) terminating
                  mihome-vacuum.0 2021-04-04 10:57:47.044 error (19187) Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 10:57:47.043 error (19187) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                  mihome-vacuum.0 2021-04-04 10:57:47.040 error (19187) unhandled promise rejection: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 10:57:47.039 error (19187) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  mihome-vacuum.0 2021-04-04 09:57:36.943 info (19187) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 09:57:36.938 info (19187) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 09:57:36.729 info (19187) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                  mihome-vacuum.0 2021-04-04 09:56:28.779 warn (19145) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  mihome-vacuum.0 2021-04-04 09:56:28.776 info (19145) terminating
                  mihome-vacuum.0 2021-04-04 09:56:28.752 error (19145) Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:56:28.751 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                  mihome-vacuum.0 2021-04-04 09:56:28.751 error (19145) TypeError: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:56:28.748 error (19145) unhandled promise rejection: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:56:28.747 error (19145) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  mihome-vacuum.0 2021-04-04 09:56:18.711 info (19145) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 09:56:18.707 info (19145) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 09:56:18.498 info (19145) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                  mihome-vacuum.0 2021-04-04 09:55:46.333 warn (19125) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  mihome-vacuum.0 2021-04-04 09:55:46.330 info (19125) terminating
                  mihome-vacuum.0 2021-04-04 09:55:46.302 error (19125) Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:55:46.301 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                  mihome-vacuum.0 2021-04-04 09:55:46.301 error (19125) TypeError: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:55:46.299 error (19125) unhandled promise rejection: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:55:46.297 error (19125) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  mihome-vacuum.0 2021-04-04 09:55:36.204 info (19125) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 09:55:36.199 info (19125) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 09:55:35.993 info (19125) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                  mihome-vacuum.0 2021-04-04 09:55:03.867 warn (19100) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  mihome-vacuum.0 2021-04-04 09:55:03.864 info (19100) terminating
                  mihome-vacuum.0 2021-04-04 09:55:03.840 error (19100) Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:55:03.838 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                  mihome-vacuum.0 2021-04-04 09:55:03.838 error (19100) TypeError: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:55:03.836 error (19100) unhandled promise rejection: Cannot read property 'val' of null
                  mihome-vacuum.0 2021-04-04 09:55:03.835 error (19100) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  mihome-vacuum.0 2021-04-04 09:54:53.734 info (19100) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 09:54:53.729 info (19100) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 09:54:53.507 info (19100) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                  mihome-vacuum.0 2021-04-04 09:54:48.899 info (19033) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  mihome-vacuum.0 2021-04-04 09:54:48.897 info (19033) terminating
                  mihome-vacuum.0 2021-04-04 09:54:48.894 info (19033) Got terminate signal TERMINATE_YOURSELF
                  mihome-vacuum.0 2021-04-04 09:52:32.454 info (19033) check group user admin group admin: false
                  mihome-vacuum.0 2021-04-04 09:52:32.449 info (19033) check user admin pw iobroker: true
                  mihome-vacuum.0 2021-04-04 09:52:32.235 info (19033) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                  aber was mir auffällt ist das ein ganz andere token angezeigt wird als ich von der app ausgelesen habe.
                  • K kakacs
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    #67
                    @kakacs sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                    viomi.vacuum.v19
                    installiere mal über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3
                    K A 2 Antworten Letzte Antwort
                      viomi.vacuum.v19
                      kakacs
                      #68
                      @meistertr super mit dem wird die instanz grün und unter objekten steht schon mal was Screenshot_2021-04-04 objects - ioBroker.png
                      aber es ändert sich nichts an wenn ich den staubsauger starte im log habe ich das jetzt
                      mihome-vacuum.0 2021-04-04 14:22:50.827 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                      mihome-vacuum.0 2021-04-04 13:21:50.822 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                      mihome-vacuum.0 2021-04-04 13:20:50.934 warn (23416) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                      mihome-vacuum.0 2021-04-04 13:20:50.718 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                      mihome-vacuum.0 2021-04-04 13:20:50.639 info (23416) check group user admin group admin: false
                      mihome-vacuum.0 2021-04-04 13:20:50.633 info (23416) check user admin pw iobroker: true
                      mihome-vacuum.0 2021-04-04 13:20:50.408 info (23416) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                      mihome-vacuum.0 2021-04-04 13:20:45.741 info (23341) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      mihome-vacuum.0 2021-04-04 13:20:45.739 info (23341) terminating
                      mihome-vacuum.0 2021-04-04 13:20:45.736 info (23341) Got terminate signal TERMINATE_YOURSELF
                      mihome-vacuum.0 2021-04-04 13:20:28.689 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                      mihome-vacuum.0 2021-04-04 13:19:28.676 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                      mihome-vacuum.0 2021-04-04 13:18:28.669 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                      mihome-vacuum.0 2021-04-04 13:17:30.856 warn (23341) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                      mihome-vacuum.0 2021-04-04 13:17:28.662 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                      • K kakacs
                        MeistertrM Offline
                        MeistertrM Offline
                        Meistertr
                        #69
                        @kakacs bitte mal auf debug stellen und den log posten
                          kakacs
                          #70
                          @meistertr jetzt musst du mir helfen wie stell ich denn auf debug??
                          • K kakacs
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #71
                            @kakacs https://www.google.com/search?q=wie+stelle+ich+iobroker+auf+debug&ie=utf-8&oe=utf-8&aq=t
                            K 2 Antworten Letzte Antwort
                              kakacs
                              #72
                              @meistertr danke
                              mihome-vacuum.0 2021-04-04 14:47:43.491 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                              mihome-vacuum.0 2021-04-04 14:47:43.488 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f1d1ffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 14:46:43.720 warn (25026) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                              mihome-vacuum.0 2021-04-04 14:46:43.720 debug (25026) DeviceModel selected to: viomi.vacuum.v19
                              mihome-vacuum.0 2021-04-04 14:46:43.719 debug (25026) Get Device data from robot..
                              mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) Get Device data..0
                              mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) GETMODELFROMAPI:Data: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:C
                              mihome-vacuum.0 2021-04-04 14:46:43.717 debug (25026) MIIO RECIVE: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw
                              mihome-vacuum.0 2021-04-04 14:46:43.511 debug (25026) Message= {"id":1,"method":"miIO.info"}
                              mihome-vacuum.0 2021-04-04 14:46:43.509 debug (25026) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617543894399,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
                              mihome-vacuum.0 2021-04-04 14:46:43.396 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                              mihome-vacuum.0 2021-04-04 14:46:43.393 debug (25026) MAIN: Connected to device, try to get model..
                              mihome-vacuum.0 2021-04-04 14:46:43.392 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f195ffffffffffffffffffffffffffffffff
                              mihome-vacuum.0 2021-04-04 14:46:43.306 debug (25026) server started on 0.0.0.0:53421
                              mihome-vacuum.0 2021-04-04 14:46:43.298 debug (25026) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
                              mihome-vacuum.0 2021-04-04 14:46:43.296 info (25026) check group user admin group admin: false
                              mihome-vacuum.0 2021-04-04 14:46:43.291 info (25026) check user admin pw iobroker: true
                              mihome-vacuum.0 2021-04-04 14:46:43.078 info (25026) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                              mihome-vacuum.0 2021-04-04 14:46:42.875 debug (25026) statesDB connected
                              mihome-vacuum.0 2021-04-04 14:46:42.874 debug (25026) States connected to redis: 127.0.0.1:9000
                              mihome-vacuum.0 2021-04-04 14:46:42.862 debug (25026) States create User PubSub Client
                              mihome-vacuum.0 2021-04-04 14:46:42.861 debug (25026) States create System PubSub Client
                              mihome-vacuum.0 2021-04-04 14:46:42.849 debug (25026) Redis States: Use Redis connection: 127.0.0.1:9000
                              mihome-vacuum.0 2021-04-04 14:46:42.847 debug (25026) objectDB connected
                              mihome-vacuum.0 2021-04-04 14:46:42.837 debug (25026) Objects connected to redis: 127.0.0.1:9001
                              mihome-vacuum.0 2021-04-04 14:46:42.819 debug (25026) Objects client initialize lua scripts
                              mihome-vacuum.0 2021-04-04 14:46:42.818 debug (25026) Objects create User PubSub Client
                              mihome-vacuum.0 2021-04-04 14:46:42.816 debug (25026) Objects create System PubSub Client
                              mihome-vacuum.0 2021-04-04 14:46:42.805 debug (25026) Objects client ready ... initialize now
                              mihome-vacuum.0 2021-04-04 14:46:42.764 debug (25026) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              mihome-vacuum.0 2021-04-04 14:46:38.420 info (24980) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              mihome-vacuum.0 2021-04-04 14:46:38.417 info (24980) terminating
                              mihome-vacuum.0 2021-04-04 14:46:38.414 info (24980) Got terminate signal TERMINATE_YOURSELF
                                kakacs
                                #73
                                @meistertr
                                mihome-vacuum.0 2021-04-04 15:58:57.637 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                                mihome-vacuum.0 2021-04-04 15:58:57.635 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f474ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0 2021-04-04 15:58:56.681 debug (1208) system.adapter.admin.0: logging true
                                mihome-vacuum.0 2021-04-04 14:58:22.365 debug (1208) sendTo "discovery" to system.adapter.admin.0 from system.adapter.mihome-vacuum.0
                                mihome-vacuum.0 2021-04-04 14:58:22.364 debug (1208) discover__[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":"192.168.178.75","mac":"5C:6B:D7
                                mihome-vacuum.0 2021-04-04 14:58:22.362 debug (1208) {"code":0,"message":"ok","result":{"list":[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":
                                mihome-vacuum.0 2021-04-04 14:58:22.231 debug (1208) GET devices from:https://de.api.io.mi.com/app/home/device_list
                                mihome-vacuum.0 2021-04-04 14:58:22.223 debug (1208) Xiaomi Cloud: Login successful
                                mihome-vacuum.0 2021-04-04 14:58:22.222 debug (1208) Login step3: [{"key":"userId","value":"6432461162","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-04-04T13:58:22.179Z","lastAccessed":"2021-04-04T13:58:22.220Z"},{"k
                                mihome-vacuum.0 2021-04-04 14:58:21.945 debug (1208) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"XXyyLiOls5U1ionL2h/ygw==","code":0,"passToken":"V1:bOtEAOudpqEL/PTNVjfNjI1KRycqTK7DU62Fk/J18icmBS60DBX3c+rn/eV5WKs
                                mihome-vacuum.0 2021-04-04 14:58:21.340 debug (1208) Login step1: &&&START&&&{"serviceParam":"{"checkSafePhone":false,"checkSafeAddress":false,"lsrp_score":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callb
                                mihome-vacuum.0 2021-04-04 14:58:20.465 debug (1208) Xiaomi Cloud: Logging in
                                mihome-vacuum.0 2021-04-04 14:57:57.631 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                                mihome-vacuum.0 2021-04-04 14:57:57.629 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f438ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0 2021-04-04 14:57:53.101 debug (1208) system.adapter.admin.0: logging false
                                mihome-vacuum.0 2021-04-04 14:56:57.590 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                                mihome-vacuum.0 2021-04-04 14:56:57.589 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3fcffffffffffffffffffffffffffffffff
                                mihome-vacuum.0 2021-04-04 14:55:57.559 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                                mihome-vacuum.0 2021-04-04 14:55:57.558 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3bfffffffffffffffffffffffffffffffff
                                mihome-vacuum.0 2021-04-04 14:54:57.502 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                                mihome-vacuum.0 2021-04-04 14:54:57.500 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f383ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0 2021-04-04 14:53:57.741 warn (1208) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                                mihome-vacuum.0 2021-04-04 14:53:57.740 debug (1208) DeviceModel selected to: viomi.vacuum.v19
                                mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data from robot..
                                mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data..0
                                mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) GETMODELFROMAPI:Data: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA
                                mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) MIIO RECIVE: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw_
                                mihome-vacuum.0 2021-04-04 14:53:57.442 debug (1208) Message= {"id":1,"method":"miIO.info"}
                                mihome-vacuum.0 2021-04-04 14:53:57.440 debug (1208) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617544003728,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
                                mihome-vacuum.0 2021-04-04 14:53:57.436 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                                mihome-vacuum.0 2021-04-04 14:53:57.433 debug (1208) MAIN: Connected to device, try to get model..
                                mihome-vacuum.0 2021-04-04 14:53:57.432 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f347ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0 2021-04-04 14:53:57.340 debug (1208) server started on 0.0.0.0:53421
                                mihome-vacuum.0 2021-04-04 14:53:57.332 debug (1208) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
                                mihome-vacuum.0 2021-04-04 14:53:57.330 info (1208) check group user admin group admin: false
                                mihome-vacuum.0 2021-04-04 14:53:57.325 info (1208) check user admin pw iobroker: true
                                mihome-vacuum.0 2021-04-04 14:53:57.113 info (1208) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.0, js-controller: 3.2.16
                                mihome-vacuum.0 2021-04-04 14:53:56.874 debug (1208) statesDB connected
                                mihome-vacuum.0 2021-04-04 14:53:56.873 debug (1208) States connected to redis: 127.0.0.1:9000
                                mihome-vacuum.0 2021-04-04 14:53:56.866 debug (1208) States create User PubSub Client
                                mihome-vacuum.0 2021-04-04 14:53:56.864 debug (1208) States create System PubSub Client
                                mihome-vacuum.0 2021-04-04 14:53:56.857 debug (1208) Redis States: Use Redis connection: 127.0.0.1:9000
                                mihome-vacuum.0 2021-04-04 14:53:56.854 debug (1208) objectDB connected
                                mihome-vacuum.0 2021-04-04 14:53:56.845 debug (1208) Objects connected to redis: 127.0.0.1:9001
                                mihome-vacuum.0 2021-04-04 14:53:56.822 debug (1208) Objects client initialize lua scripts
                                mihome-vacuum.0 2021-04-04 14:53:56.821 debug (1208) Objects create User PubSub Client
                                mihome-vacuum.0 2021-04-04 14:53:56.819 debug (1208) Objects create System PubSub Client
                                mihome-vacuum.0 2021-04-04 14:53:56.816 debug (1208) Objects client ready ... initialize now
                                mihome-vacuum.0 2021-04-04 14:53:56.753 debug (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                • K kakacs
                                  @meistertr
                                  MeistertrM Offline
                                  MeistertrM Offline
                                  Meistertr
                                  #74
                                  viomi.vacuum.v19
                                  bitte nochmal von git installieren und debug posten (bitte log in codetags)
                                    viomi.vacuum.v19
                                    kakacs
                                    #75
                                    @meistertr @meistertr said in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                                    log in codetags
                                    ok mache ich wie geht das mit log in code tags ??? bin noch nicht so fit mit iobroker sorry.
                                    hast du geshen in dem log was ich gepostet habe ws bedeutet das
                                    Time difference between Mihome Vacuum and ioBroker ich installier den adapter noch mal neu den du mir empfohlen hast richtig?? und soll ich erst wieder löschen ??
                                      viomi.vacuum.v19
                                      kakacs
                                      #76
                                      @meistertr hab den gelöscht und will den noch mal installieren und dann kommt das
                                      $ ./iobroker url " https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
                                      install "
                                      npm install " --loglevel error --prefix "/opt/iobroker" (System call)
                                      /bin/sh: 1: Syntax error: Unterminated quoted string
                                      ERROR: host.raspberrypi Cannot install ": 2
                                      • K kakacs
                                        install "
                                        MeistertrM Offline
                                        MeistertrM Offline
                                        Meistertr
                                        #77
                                        leerzeichen davor
                                        • K kakacs
                                          log in codetags
                                          MeistertrM Offline
                                          MeistertrM Offline
                                          Meistertr
                                          #78
                                          @kakacs löschen brachst du ihn vor dem drüber installieren nicht. das sind nur kleine Änderungen die ich vornehme. Die Timedifference ist nebensächlich, das bedeutet nur dass der roboter und der adapter unterschiedliche uhrzeiten haben und die Nachrichten daran angepasst werden
