  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
  • MeistertrM Meistertr
    @kakacs https://www.google.com/search?q=wie+stelle+ich+iobroker+auf+debug&ie=utf-8&oe=utf-8&aq=t
    kakacs
    #72
    @meistertr danke
    mihome-vacuum.0 2021-04-04 14:47:43.491 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
    mihome-vacuum.0 2021-04-04 14:47:43.488 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f1d1ffffffffffffffffffffffffffffffff
    mihome-vacuum.0 2021-04-04 14:46:43.720 warn (25026) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
    mihome-vacuum.0 2021-04-04 14:46:43.720 debug (25026) DeviceModel selected to: viomi.vacuum.v19
    mihome-vacuum.0 2021-04-04 14:46:43.719 debug (25026) Get Device data from robot..
    mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) Get Device data..0
    mihome-vacuum.0 2021-04-04 14:46:43.718 debug (25026) GETMODELFROMAPI:Data: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:C
    mihome-vacuum.0 2021-04-04 14:46:43.717 debug (25026) MIIO RECIVE: {"id":1,"result":{"life":323990,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw
    mihome-vacuum.0 2021-04-04 14:46:43.511 debug (25026) Message= {"id":1,"method":"miIO.info"}
    mihome-vacuum.0 2021-04-04 14:46:43.509 debug (25026) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617543894399,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
    mihome-vacuum.0 2021-04-04 14:46:43.396 warn (25026) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
    mihome-vacuum.0 2021-04-04 14:46:43.393 debug (25026) MAIN: Connected to device, try to get model..
    mihome-vacuum.0 2021-04-04 14:46:43.392 debug (25026) Receive <<< Helo <<< 21310020000000001661f4ca0004f195ffffffffffffffffffffffffffffffff
    mihome-vacuum.0 2021-04-04 14:46:43.306 debug (25026) server started on 0.0.0.0:53421
    mihome-vacuum.0 2021-04-04 14:46:43.298 debug (25026) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
    mihome-vacuum.0 2021-04-04 14:46:43.296 info (25026) check group user admin group admin: false
    mihome-vacuum.0 2021-04-04 14:46:43.291 info (25026) check user admin pw iobroker: true
    mihome-vacuum.0 2021-04-04 14:46:43.078 info (25026) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-04-04 14:46:42.875 debug (25026) statesDB connected
    mihome-vacuum.0 2021-04-04 14:46:42.874 debug (25026) States connected to redis: 127.0.0.1:9000
    mihome-vacuum.0 2021-04-04 14:46:42.862 debug (25026) States create User PubSub Client
    mihome-vacuum.0 2021-04-04 14:46:42.861 debug (25026) States create System PubSub Client
    mihome-vacuum.0 2021-04-04 14:46:42.849 debug (25026) Redis States: Use Redis connection: 127.0.0.1:9000
    mihome-vacuum.0 2021-04-04 14:46:42.847 debug (25026) objectDB connected
    mihome-vacuum.0 2021-04-04 14:46:42.837 debug (25026) Objects connected to redis: 127.0.0.1:9001
    mihome-vacuum.0 2021-04-04 14:46:42.819 debug (25026) Objects client initialize lua scripts
    mihome-vacuum.0 2021-04-04 14:46:42.818 debug (25026) Objects create User PubSub Client
    mihome-vacuum.0 2021-04-04 14:46:42.816 debug (25026) Objects create System PubSub Client
    mihome-vacuum.0 2021-04-04 14:46:42.805 debug (25026) Objects client ready ... initialize now
    mihome-vacuum.0 2021-04-04 14:46:42.764 debug (25026) Redis Objects: Use Redis connection: 127.0.0.1:9001
    mihome-vacuum.0 2021-04-04 14:46:38.420 info (24980) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mihome-vacuum.0 2021-04-04 14:46:38.417 info (24980) terminating
    mihome-vacuum.0 2021-04-04 14:46:38.414 info (24980) Got terminate signal TERMINATE_YOURSELF
      kakacs
      #73
      @meistertr
      mihome-vacuum.0 2021-04-04 15:58:57.637 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
      mihome-vacuum.0 2021-04-04 15:58:57.635 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f474ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 15:58:56.681 debug (1208) system.adapter.admin.0: logging true
      mihome-vacuum.0 2021-04-04 14:58:22.365 debug (1208) sendTo "discovery" to system.adapter.admin.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0 2021-04-04 14:58:22.364 debug (1208) discover__[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":"192.168.178.75","mac":"5C:6B:D7
      mihome-vacuum.0 2021-04-04 14:58:22.362 debug (1208) {"code":0,"message":"ok","result":{"list":[{"did":"375518410","token":"494a4234547a4874416c424646664652","longitude":"0.00000000","latitude":"0.00000000","name":"Viomi SE","pid":"0","localip":
      mihome-vacuum.0 2021-04-04 14:58:22.231 debug (1208) GET devices from:https://de.api.io.mi.com/app/home/device_list
      mihome-vacuum.0 2021-04-04 14:58:22.223 debug (1208) Xiaomi Cloud: Login successful
      mihome-vacuum.0 2021-04-04 14:58:22.222 debug (1208) Login step3: [{"key":"userId","value":"6432461162","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-04-04T13:58:22.179Z","lastAccessed":"2021-04-04T13:58:22.220Z"},{"k
      mihome-vacuum.0 2021-04-04 14:58:21.945 debug (1208) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"XXyyLiOls5U1ionL2h/ygw==","code":0,"passToken":"V1:bOtEAOudpqEL/PTNVjfNjI1KRycqTK7DU62Fk/J18icmBS60DBX3c+rn/eV5WKs
      mihome-vacuum.0 2021-04-04 14:58:21.340 debug (1208) Login step1: &&&START&&&{"serviceParam":"{"checkSafePhone":false,"checkSafeAddress":false,"lsrp_score":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callb
      mihome-vacuum.0 2021-04-04 14:58:20.465 debug (1208) Xiaomi Cloud: Logging in
      mihome-vacuum.0 2021-04-04 14:57:57.631 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
      mihome-vacuum.0 2021-04-04 14:57:57.629 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f438ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 14:57:53.101 debug (1208) system.adapter.admin.0: logging false
      mihome-vacuum.0 2021-04-04 14:56:57.590 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
      mihome-vacuum.0 2021-04-04 14:56:57.589 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3fcffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 14:55:57.559 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
      mihome-vacuum.0 2021-04-04 14:55:57.558 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f3bfffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 14:54:57.502 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
      mihome-vacuum.0 2021-04-04 14:54:57.500 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f383ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 14:53:57.741 warn (1208) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
      mihome-vacuum.0 2021-04-04 14:53:57.740 debug (1208) DeviceModel selected to: viomi.vacuum.v19
      mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data from robot..
      mihome-vacuum.0 2021-04-04 14:53:57.739 debug (1208) Get Device data..0
      mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) GETMODELFROMAPI:Data: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA
      mihome-vacuum.0 2021-04-04 14:53:57.738 debug (1208) MIIO RECIVE: {"id":1,"result":{"life":324424,"uid":6432461162,"model":"viomi.vacuum.v19","token":"494a4234547a4874416c424646664652","ipflag":1,"miio_ver":"0.0.8","mac":"5C:6B:D7:0B:CA:E7","fw_
      mihome-vacuum.0 2021-04-04 14:53:57.442 debug (1208) Message= {"id":1,"method":"miIO.info"}
      mihome-vacuum.0 2021-04-04 14:53:57.440 debug (1208) GETMODELFROMAPI: objModel: {"val":"viomi.vacuum.v19","ack":true,"ts":1617544003728,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1617538571877}
      mihome-vacuum.0 2021-04-04 14:53:57.436 warn (1208) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
      mihome-vacuum.0 2021-04-04 14:53:57.433 debug (1208) MAIN: Connected to device, try to get model..
      mihome-vacuum.0 2021-04-04 14:53:57.432 debug (1208) Receive <<< Helo <<< 21310020000000001661f4ca0004f347ffffffffffffffffffffffffffffffff
      mihome-vacuum.0 2021-04-04 14:53:57.340 debug (1208) server started on 0.0.0.0:53421
      mihome-vacuum.0 2021-04-04 14:53:57.332 debug (1208) MIIO: Config: ip:192.168.178.75 token: 494a4234547a4874416c424646664652
      mihome-vacuum.0 2021-04-04 14:53:57.330 info (1208) check group user admin group admin: false
      mihome-vacuum.0 2021-04-04 14:53:57.325 info (1208) check user admin pw iobroker: true
      mihome-vacuum.0 2021-04-04 14:53:57.113 info (1208) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.0, js-controller: 3.2.16
      mihome-vacuum.0 2021-04-04 14:53:56.874 debug (1208) statesDB connected
      mihome-vacuum.0 2021-04-04 14:53:56.873 debug (1208) States connected to redis: 127.0.0.1:9000
      mihome-vacuum.0 2021-04-04 14:53:56.866 debug (1208) States create User PubSub Client
      mihome-vacuum.0 2021-04-04 14:53:56.864 debug (1208) States create System PubSub Client
      mihome-vacuum.0 2021-04-04 14:53:56.857 debug (1208) Redis States: Use Redis connection: 127.0.0.1:9000
      mihome-vacuum.0 2021-04-04 14:53:56.854 debug (1208) objectDB connected
      mihome-vacuum.0 2021-04-04 14:53:56.845 debug (1208) Objects connected to redis: 127.0.0.1:9001
      mihome-vacuum.0 2021-04-04 14:53:56.822 debug (1208) Objects client initialize lua scripts
      mihome-vacuum.0 2021-04-04 14:53:56.821 debug (1208) Objects create User PubSub Client
      mihome-vacuum.0 2021-04-04 14:53:56.819 debug (1208) Objects create System PubSub Client
      mihome-vacuum.0 2021-04-04 14:53:56.816 debug (1208) Objects client ready ... initialize now
      mihome-vacuum.0 2021-04-04 14:53:56.753 debug (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
      MeistertrM 1 Antwort Letzte Antwort
      • K kakacs
        @meistertr
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        #74
        @kakacs sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
        viomi.vacuum.v19
        bitte nochmal von git installieren und debug posten (bitte log in codetags)
        K 2 Antworten Letzte Antwort
          viomi.vacuum.v19
          kakacs
          #75
          @meistertr @meistertr said in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
          log in codetags
          ok mache ich wie geht das mit log in code tags ??? bin noch nicht so fit mit iobroker sorry.
          hast du geshen in dem log was ich gepostet habe ws bedeutet das
          Time difference between Mihome Vacuum and ioBroker ich installier den adapter noch mal neu den du mir empfohlen hast richtig?? und soll ich erst wieder löschen ??
            viomi.vacuum.v19
            kakacs
            #76
            @meistertr hab den gelöscht und will den noch mal installieren und dann kommt das
            $ ./iobroker url " https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
            install "
            NPM version: 6.14.11
            npm install " --loglevel error --prefix "/opt/iobroker" (System call)
            /bin/sh: 1: Syntax error: Unterminated quoted string
            ERROR: host.raspberrypi Cannot install ": 2
            • K kakacs
              install "
              MeistertrM Offline
              MeistertrM Offline
              Meistertr
              #77
              leerzeichen davor
              • K kakacs
                log in codetags
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                #78
                @kakacs löschen brachst du ihn vor dem drüber installieren nicht. das sind nur kleine Änderungen die ich vornehme. Die Timedifference ist nebensächlich, das bedeutet nur dass der roboter und der adapter unterschiedliche uhrzeiten haben und die Nachrichten daran angepasst werden
                  kakacs
                  #79
                  @meistertr ok ich hab denn jetzt schon gelöscht wie meinst du leerzeichen davor
                  • K kakacs
                    audi1503
                    #80
                    @kakacs Du hattest vor dem Link nen Leerzeichen
                    • A audi1503
                      kakacs
                      #81
                      @audi1503 hab ich gemerckt grins ist das normal alles was da steht beim installieren
                      $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3" --debug
                      install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3
                      NPM version: 6.14.11npm install iobroker-community-adapters/ioBroker.mihome-vacuum#rebuild3 --loglevel error --prefix "/opt/iobroker" (System call)
                      canvas@2.7.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
                      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                      COPY Release/canvas-postbuild.node
                      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                      ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
                      ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
                      CXX(target) Release/obj.target/canvas/src/Backends.o
                      CXX(target) Release/obj.target/canvas/src/Canvas.o
                      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                      CXX(target) Release/obj.target/canvas/src/closure.o
                      CXX(target) Release/obj.target/canvas/src/color.o
                      CXX(target) Release/obj.target/canvas/src/Image.o
                      CXX(target) Release/obj.target/canvas/src/ImageData.o
                      CXX(target) Release/obj.target/canvas/src/init.o
                      CXX(target) Release/obj.target/canvas/src/register_font.o
                      SOLINK_MODULE(target) Release/obj.target/canvas.node
                      COPY Release/canvas.node
                      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                      • iobroker.mihome-vacuum@3.0.0
                        added 23 packages from 15 contributors in 70.367s
                      52 packages are looking for funding run npm fund for details
                      upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                      upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                      upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                      upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                      upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                      upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
                      upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                      upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                      upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                      upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                      upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                      upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                      process exited with code 0
                      das sagt der log jetzt
                      mihome-vacuum.0 2021-04-04 17:14:52.696 debug (2687) system.adapter.admin.0: logging true
                      mihome-vacuum.0 2021-04-04 16:14:51.546 debug (2687) Recievded params for viomi: {"result":[],"id":5,"exe_time":100}
                      mihome-vacuum.0 2021-04-04 16:14:51.545 debug (2687) MIIO RECIVE: {"result":[],"id":5,"exe_time":100}
                      mihome-vacuum.0 2021-04-04 16:14:51.206 debug (2687) Message= {"id":5,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                      mihome-vacuum.0 2021-04-04 16:14:51.204 debug (2687) get params for Viomi
                      mihome-vacuum.0 2021-04-04 16:14:49.851 warn (2687) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                      mihome-vacuum.0 2021-04-04 16:14:49.849 debug (2687) Receive <<< Helo <<< 21310020000000001661f4ca0005063cffffffffffffffffffffffffffffffff
                      mihome-vacuum.0 2021-04-04 16:14:31.203 debug (2687) Recievded params for viomi: {"result":[],"id":4,"exe_time":100}
                      mihome-vacuum.0 2021-04-04 16:14:31.201 debug (2687) MIIO RECIVE: {"result":[],"id":4,"exe_time":100}
                      mihome-vacuum.0 2021-04-04 16:14:30.897 debug (2687) system.adapter.admin.0: logging false
                      mihome-vacuum.0 2021-04-04 16:14:30.649 debug (2687) Message= {"id":4,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                      mihome-vacuum.0 2021-04-04 16:14:30.647 debug (2687) get params for Viomi
                      mihome-vacuum.0 2021-04-04 16:14:10.645 debug (2687) Recievded params for viomi: {"result":[],"id":3,"exe_time":100}
                      mihome-vacuum.0 2021-04-04 16:14:10.644 debug (2687) MIIO RECIVE: {"result":[],"id":3,"exe_time":100}
                      mihome-vacuum.0 2021-04-04 16:14:10.420 debug (2687) Message= {"id":3,"method":"get_prop","params":["run_state","suction_grade","mode","err_state","battary_life","start_time","order_time","s_time","s_area","v_state","zone_data","repeat_state","r
                      und es steht defentiv mehr drin Screenshot_2021-04-04 objects - ioBroker(1).png
                        kakacs
                        #82
                        @meistertr also ich kann jetzt über objecte steuern super arbeit echt ist das den möglich das ich den über alexa starten kann weil ja da in einstellung von dem adapter gibt die option füge ein status für alexa zu ??
                          viomi.vacuum.v19
                          installiere mal über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3
                          audi1503
                          #83
                          @meistertr Kann mit dem Adapter auch den mijia.vacuum.v2 steuern oder sind das auch andere Befehle wie mit dem Dreame.vacuum.mc1808. Diese beiden hab ich und die lassen sich noch nicht einbinden.
                          • K kakacs
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #84
                            @kakacs aldos starten und stoppen geht?
                              kakacs
                              #85
                              @meistertr ich kann unter xiaomi objecten den sauger starten und auch pausieren
                              und zurück zur lade station schicken . das klappt super. jetzt würde ich ihn gern über alexa steuern also starten zu mindestens.
                              • K kakacs
                                MeistertrM Offline
                                MeistertrM Offline
                                Meistertr
                                schrieb am zuletzt editiert von Meistertr
                                #86
                                @kakacs hab da noch ein paar mehr anforderungen :) kannst du mal über sende eigene befehle (in der config aktivieren) ein paar sachen ausprobieren?
                                get_status
                                get_sound_volume
                                get_consumable
                                get_clean_summary
                                get_map_v1
                                und berichten was in response steht
                                  get_status
                                  get_sound_volume
                                  get_consumable
                                  get_clean_summary
                                  get_map_v1
                                  kakacs
                                  #87
                                  @meistertr ja klar kann ich gerne machen das ist kein problem
                                  • K kakacs
                                    MeistertrM Offline
                                    MeistertrM Offline
                                    Meistertr
                                    #88
                                    • A audi1503
                                      MeistertrM Offline
                                      MeistertrM Offline
                                      Meistertr
                                      #89
                                      @audi1503 sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                                      mijia.vacuum.v2
                                      bitte den Adapter installieren (rebulid3) einloggen und devices abrufen, Sauger auswählen eigene Kommandos aktivieren in config, speichern (nicht schließen) auf der ersten Seite oben rechts config downloaden2021-04-04_20h20_46.png
                                      deviceId in ein leeres Textfile speichern
                                      folgende Kommandos in untenstehender Form unter Objekten2021-04-04_19h53_04.png
                                      bei send_command eingeben
                                      Antworten bitte in ein Textfile kopieren, neben die Kommandos und posten
                                      Kommandos (PIID und SIID)
                                          # https://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:mijia-v1:1
                                          "battery": {"siid": 3, "piid": 1},
                                          "charge_state": {"siid": 3, "piid": 2},
                                          "error": {"siid": 2, "piid": 2},
                                          "state": {"siid": 2, "piid": 1},
                                          "fan_speed": {"siid": 2, "piid": 6},
                                          "operating_mode": {"siid": 2, "piid": 4},
                                          "mop_state": {"siid": 16, "piid": 1},
                                          "water_level": {"siid": 2, "piid": 5},
                                          "brush_life_level": {"siid": 14, "piid": 1},
                                          #  "brush_life_time": {"siid": 14, "piid": 2},
                                          "brush_life_level2": {"siid": 15, "piid": 1},
                                          #  "brush_life_time2": {"siid": 15, "piid": 2},
                                          "filter_life_level": {"siid": 11, "piid": 1},
                                          #  "filter_life_time": {"siid": 11, "piid": 2},
                                          "clean_area": {"siid": 9, "piid": 1},
                                          "clean_time": {"siid": 18, "piid": 5},
                                          "total_clean_count": {"siid": 9, "piid": 5},
                                          #   "total_clean_area": {"siid": 9, "piid": 3},
                                          #  "dnd_enabled": {"siid": 12, "piid": 2},
                                          #  "audio_volume": {"siid": 4, "piid": 2},
                                          #  "direction_key": {"siid": 8, "piid": 1}
                                      das ist die form wie es in das Objekt muss:
                                      get_properties;[{"did":"AUSCONFIG","siid":3,"piid":1}]
                                      Bitte einmal durchtesten
                                        audi1503
                                        schrieb am zuletzt editiert von audi1503
                                        #90
                                        @Meistertr
                                        Hier die angeforderten Antworten auf den Kommandos:
                                        "battery": {"siid": 3, "piid": 1},                = [{"did":"334314795","siid":3,"piid":1,"code":0,"value":100}]
                                        "charge_state": {"siid": 3, "piid": 2},           = [{"did":"334314795","siid":3,"piid":2,"code":0,"value":2}]
                                        "error": {"siid": 2, "piid": 2},                  = [{"did":"334314795","siid":2,"piid":2,"code":0,"value":0}]
                                        "state": {"siid": 2, "piid": 1},                  = [{"did":"334314795","siid":2,"piid":1,"code":0,"value":5}]
                                        "fan_speed": {"siid": 2, "piid": 6},              = [{"did":"334314795","siid":2,"piid":6,"code":0,"value":1}]
                                        "operating_mode": {"siid": 2, "piid": 4},         = [{"did":"334314795","siid":2,"piid":4,"code":0,"value":1}]
                                        "mop_state": {"siid": 16, "piid": 1},             = [{"did":"334314795","siid":16,"piid":1,"code":0,"value":0}]
                                        "water_level": {"siid": 2, "piid": 5},            = [{"did":"334314795","siid":2,"piid":5,"code":0,"value":2}]
                                        "brush_life_level": {"siid": 14, "piid": 1},      = [{"did":"334314795","siid":14,"piid":1,"code":0,"value":58}]
                                        #  "brush_life_time": {"siid": 14, "piid": 2},    = [{"did":"334314795","siid":14,"piid":2,"code":0,"value":10504}]
                                        "brush_life_level2": {"siid": 15, "piid": 1},     = [{"did":"334314795","siid":15,"piid":1,"code":0,"value":14}]
                                        #  "brush_life_time2": {"siid": 15, "piid": 2},   = [{"did":"334314795","siid":15,"piid":2,"code":0,"value":1280}]
                                        "filter_life_level": {"siid": 11, "piid": 1},     = [{"did":"334314795","siid":11,"piid":1,"code":0,"value":16}]
                                        #  "filter_life_time": {"siid": 11, "piid": 2},   = [{"did":"334314795","siid":11,"piid":2,"code":0,"value":1504}]
                                        "clean_area": {"siid": 9, "piid": 1},             = [{"did":"334314795","siid":9,"piid":1,"code":0,"value":0}]
                                        "clean_time": {"siid": 18, "piid": 5},            = [{"did":"334314795","siid":18,"piid":5,"code":-4003}]
                                        "total_clean_count": {"siid": 9, "piid": 5},      = [{"did":"334314795","siid":9,"piid":5,"code":0,"value":0}]
                                        #   "total_clean_area": {"siid": 9, "piid": 3},   = [{"did":"334314795","siid":9,"piid":3,"code":0,"value":0}]
                                        #  "dnd_enabled": {"siid": 12, "piid": 2},        = [{"did":"334314795","siid":12,"piid":2,"code":0,"value":false}]
                                        #  "audio_volume": {"siid": 4, "piid": 2},        = [MESSAGE TIMEOUT]
                                        #  "direction_key": {"siid": 8, "piid": 1}        = [{"did":"334314795","siid":8,"piid":1,"code":-4003}]
                                        Habe im Log auch noch Model mijia.vacuum.v2 not supported stehen
                                          kakacs
                                          #91
                                          bei mir steht da nix
