  4. Javascript - Blockly wird oft nicht gespeichert
    6.0k
javascript blockly
363 Beiträge 31 Kommentatoren 79.8k Aufrufe 31 Beobachtet
  • Christoph1337C Christoph1337
    Bringe diese Logs etwas?
    DevTools failed to load SourceMap: Could not load content for chrome-extension://dafgdjggglmmknipkhngniifhplpcldb/browser-polyfill.min.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
    jquery.fancytree-all.js:113 Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead.
    v @ vendor.js:1
    warn @ vendor.js:1
    e.ui.fancytree._FancytreeClass.filterNodes @ vendor.js:1
    (anonymous) @ admin.js:17
    setTimeout (async)
    dispatch @ vendor.js:1
    m.handle @ vendor.js:1
    trigger @ vendor.js:1
    (anonymous) @ vendor.js:1
    each @ vendor.js:1
    each @ vendor.js:1
    i @ admin.js:17
    Adapters.prepare @ admin.js:17
    setTimeout (async)
    r.onack @ index.js:83
    r.onpacket @ index.js:83
    (anonymous) @ index.js:83
    r.emit @ index.js:83
    r.ondecoded @ index.js:83
    a.add @ index.js:83
    r.ondata @ index.js:83
    r.onPacket @ index.js:83
    r.onData @ index.js:83
    ws.onmessage @ index.js:83
    DevTools failed to load SourceMap: Could not load content for http://iobroker.fritz.box:8081/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    index.js:15 iobroker.javascript@4.6.17
    DevTools failed to load SourceMap: Could not load content for http://iobroker.fritz.box:8081/adapter/min-maps/vs/loader.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load SourceMap: Could not load content for http://iobroker.fritz.box:8081/adapter/min-maps/vs/editor/editor.main.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load SourceMap: Could not load content for http://iobroker.fritz.box:8081/adapter/min-maps/vs/editor/editor.main.nls.de.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    saeft_2003
    #101
    @Christoph1337 sagte in Javascript - Blockly wird oft nicht gespeichert:
    v @ vendor.js:1
    warn @ vendor.js:1
    setTimeout (async)
    each @ vendor.js:1
    each @ vendor.js:1
    i @ admin.js:17
    setTimeout (async)
    a.add @ index.js:83
    @apollon77
      v @ vendor.js:1
      warn @ vendor.js:1
      setTimeout (async)
      each @ vendor.js:1
      each @ vendor.js:1
      i @ admin.js:17
      setTimeout (async)
      a.add @ index.js:83
      #102
      @Christoph1337 Ohne zu wissen wann davon was kommt bringt das wenig. Die ".map nicht gefunden " kannst Du ignorieren, das mit dem Fancytree an sich auch egal.
      Alles was ich hier lesen mit den 30s bis UI Dinge kommen bringt mich eher zu der Frage wie es dem Rechner geht w Dein Browser drauf läuft und was da ist ... das klingt alles eher Browserseitig... was aber nur geraten ist
      Christoph1337C S 2 Antworten Letzte Antwort
      • apollon77A apollon77
        Christoph1337C Offline
        Christoph1337
        #103
        @apollon77 Dann lass uns doch mal gemeinsam auf mein System gucken. Dann kannst du explizit danach gucken was dir wichtig erscheint. Andere haben sich dafür ja auch bereits angeboten.
        • liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          #104
          um den browser auszunehmen könnte man einen neuen w10 user anlegen, sich damit anmelden und anschliessend den browser aufrufen - dadurch bekommst du einen "frischen" browser
          ist der fehler immer noch liegt es nicht am browser
          ich kenne das problem mit FF. aber ich hatte es auch schon ein paar mal mit chrome, dass nicht gespeichert wird - was allerdings auch bei mir ist, es dauert länger, bis der speichern button unter blockly kommt (manchmal garnicht - ich muss dann einen block etwas verschieben und dann funktioniert es)
          Christoph1337C 1 Antwort Letzte Antwort
          • liv-in-skyL liv-in-sky
            Christoph1337
            #105
            @liv-in-sky Eine VM wäre auch kein Problem.
              saeft_2003
              #106
              @apollon77 sagte in Javascript - Blockly wird oft nicht gespeichert:
              Also ich habe das Problem auf zwei verschiedenen Rechnern mit FF, chrome und edge. Auf dem iphone auch mit safari. Daher glaube ich persönlich nicht an ein browser Problem, lasse mich aber auch gern eines Besseren belehren...
                saeft_2003
                #107
                Gibts dazu schon irgendwas neues? Ich musste grad etwas an einem skript machen und hätte vor Frust mein laptop fast gegen die Wand gefeuert...
                Nächstes Jahr will ich auf homematic ip wired umsteigen, wenn das dann immer noch so ist, brauch ich erst gar nicht anfangen 😰
                • Christoph1337C Offline
                  Christoph1337
                  #108
                  Mir gehts genauso.
                  @apollon77 ich konnte das Problem nun bei mir mehrfach wie folge reproduzieren. Hab davon mal ein Video gemacht und das Log aus der Console angehängt. Vielleicht hilft es.
                  Video
                  Log
                  • crunchipC Offline
                    crunchipC Offline
                    #109
                    wen man nur den tab javascript geöffnet lässt, ohne irgend etwas zu machen, kommt nach einiger Zeit, egal welcher Browser, Rechner, Tablet, Handy
                    fcb8daa1-057b-43fa-8e3a-2bdbe639ef22-image.png 28c91b8c-5eef-469e-9d97-f526b1475374-image.png
                      Christoph1337
                      #110
                      @crunchip jau das hatte ich auch schon öfter
                        saeft_2003
                        #111
                        @crunchip
                        Genau diesen xhr post error habe ich auch. Vorher wie noch alles funktioniert hatte kam der nie.
                        Was ich jetzt auch schon hatte das ich die Seite neu laden musste das ich wieder speichern konnte.
                          Mir gehts genauso.
                          Video
                          Log
                          #112
                          @Christoph1337 ALso diese ganzen
                          helpers.ts:110 Uncaught TypeError: Cannot read property 'dragBlock' of null
                          at Blockly.TouchGesture.Blockly.Gesture.handleMove (blockly_compressed.js:433)
                          at Blockly.TouchGesture.handleMove (blockly_compressed.js:730)
                          at HTMLDocument.h (blockly_compressed.js:866)
                          at HTMLDocument.r (helpers.ts:85)
                          die können nicht gut sein. Issue anlegen. Das kann schon die Ursache sein. Das JS stirbt halt be den Aktionen ... warum, keine Ahnung
                            Christoph1337
                            #113
                            @apollon77 warum issue anlegen? gibts doch schon einige zu ;)
                              #114
                              @Christoph1337 Zeig mir das issue mit dieser Fehlermeldung
                                Christoph1337
                                #115
                                @apollon77 https://github.com/ioBroker/ioBroker.javascript/issues/608
                                Hab ne neue gemacht
                                  saeft_2003
                                  #116
                                  @apollon77
                                  es wird immer schlimmer... gerade eben hat es mir beim speichern, das komplette Skript zerschossen!!! Auch nach dem neuladen war es immer noch zerschossen ich musste ein backup einspielen.
                                  Wie kann sowas passieren, das hatte ich noch nie?
                                  • S saeft_2003
                                    @apollon77
                                    #117
                                    @saeft_2003 Browser Konsole irgendwas?
                                      saeft_2003
                                      #118
                                      @apollon77
                                      Tut mir leid kann ich dir nicht sagen, da kenn ich mich nicht mit aus :-(
                                      • S saeft_2003
                                        @apollon77
                                        #119
                                        @saeft_2003 Im Browder meisten bei Tools/Weitere Tools -> ENtwickler Tools und dort Konsole
                                          saeft_2003
                                          #120
                                          @apollon77
                                          Meinst du das?
