  5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
    5.8k
1.5k Beiträge 53 Kommentatoren 672.3k Aufrufe 52 Beobachtet
  • P PrinzEisenherz1
    Hi zusammen.
    Habe seit den hohen UV-Werten und dadurch resultierenden Warnungen durch DWD folgende Fehlermeldung im Log
    2020-06-24 09:20:09.142 - warn: javascript.0 (1125) You are assigning a number to the state "0_userdata.0.wetterwarnung.alert.dwd.UV_Warnungen.color" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2020-06-24 09:20:09.146 - warn: javascript.0 (1125) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-06-24 09:20:09.146 - warn: javascript.0 (1125) at setAlertState (script.js.Meldungen.DWD_UWZ_Nina_script:838:21)
    2020-06-24 09:20:09.146 - warn: javascript.0 (1125) at addDatabaseData (script.js.Meldungen.DWD_UWZ_Nina_script:1655:17)
    2020-06-24 09:20:09.147 - warn: javascript.0 (1125) at onChange (script.js.Meldungen.DWD_UWZ_Nina_script:1502:9)
    2020-06-24 09:20:09.147 - warn: javascript.0 (1125) at Object.onChangeDWD (script.js.Meldungen.DWD_UWZ_Nina_script:1487:5)
    2020-06-24 09:20:09.147 - warn: javascript.0 (1125) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-06-24 09:20:09.148 - warn: javascript.0 (1125) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-06-24 09:20:09.148 - warn: javascript.0 (1125) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-06-24 09:20:09.148 - warn: javascript.0 (1125) at runCallback (timers.js:705:18)
    2020-06-24 09:20:09.148 - warn: javascript.0 (1125) at tryOnImmediate (timers.js:676:5)
    2020-06-24 09:20:09.149 - warn: javascript.0 (1125) at processImmediate (timers.js:658:5)
    2020-06-24 09:20:09.149 - warn: javascript.0 (1125) at process.topLevelDomainCallback (domain.js:126:23)
    Habe nur ich die Fehlermeldung?
    Ich verwende die aktuelle Version aus m git
    Johnny
    crunchipC Abwesend
    crunchipC Abwesend
    #381
    @PrinzEisenherz1 jetzt wo ich hier das gerade lese, ist mir aufgefallen
    • Keine Fehlermeldungen
    • Aber auch gar keine Benachrichtigung!?
    • P PrinzEisenherz1
      Hi zusammen.
      Johnny
      ticaki
      #382
      @PrinzEisenherz1 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
      Fehler ist gefunden, könntest du mir den Level der Warnung nennen oder den Json posten. Werde das bei Gelegenheit im Code ändern.
      Spenden
      P 1 Antwort Letzte Antwort
        ich habe alle meine Scripte unter:
        0_userdata.0.Eigene_Datenpunkte
        wenn ich die Zeile im Script:
        var mainStatePath = 'javascript.0.wetterwarnung_test.';
        nach:
        var mainStatePath = '0_userdata.0.Eigene_Datenpunkte.Wetterwarnung.';
        ändere, erhalte ich folgenden Fehler:
        avascript.0	2020-06-07 04:12:17.881	error	(19433) at Script.runInContext (vm.js:131:20)
        javascript.0	2020-06-07 04:12:17.881	error	(19433) at script.js.myscripts.scripte.Wetterwarnung:117:1
        javascript.0	2020-06-07 04:12:17.881	error	(19433) ReferenceError: mainStatePath is not defined
        javascript.0	2020-06-07 04:12:17.880	error	(19433) ^
        javascript.0	2020-06-07 04:12:17.880	error	(19433) if(mainStatePath[mainStatePath.length - 1] != '.') mainStatePath += '.';
        javascript.0	2020-06-07 04:12:17.880	error	(19433) script.js.myscripts.scripte.Wetterwarnung: script.js.myscripts.scripte.Wetterwarnung:117
        Gruß Ralf
        ticaki
        #383
        @Murmelbaerchen69
        sry das ich mich nicht gemeldet habe, aber ich verstehe nicht wieso das passiert. Sicher das du keinen Fehler im übertragen ins Forum gemacht hast?
        Spenden
        ? 1 Antwort Letzte Antwort
        • T ticaki
          @Murmelbaerchen69
          #384
          @ticaki Hallo, ich ändere ja nur die eine Zeile im Script und schon erhalte ich die Fehlermeldung. Lasse ich die Zeile, läuft das Script einwandfrei.
          Gruß Ralf
            Gruß Ralf
            ticaki
            #385
            @Murmelbaerchen69
            Und das verstehe ich nicht, wenn du die Zeile änderst wird dadurch die ganze Zeile ungültig, lt. Fehlermeldung. Folglich müsste irgendein Zeichen in deiner Änderung diesen Fehler auslösen.
            Spenden
              ticaki
              #386
              Update:
              v97.16
              • color wird auf grün gesetzt wenn level nicht zwischen 0 und 5 liegt.
              • glaube das ich das letzte Update nicht hochgeladen habe.
              • kk
              Spenden
              • T ticaki
                PrinzEisenherz1
                #387
                @ticaki Leider kann ich Dir den Level der Warnung nicht mehr sagen. Habe ich leider nicht mitgeplottet.
                Da müsstest Du warten bis wieder so eine warning auftaucht.
                Oder hast de den Fehler schon gefunden und korrigiert?
                Johnny
                Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                • P PrinzEisenherz1
                  Johnny
                  ticaki
                  #388
                  @PrinzEisenherz1
                  Der Fehler war zwar ein Fehler sollte aber nie auftretten g. Am Ende der Funktion stand ein return 0 was aber eigentlich nicht aufgerufen werden sollte. Jetzt steht dort der String für grün.
                  Spenden
                    PrinzEisenherz1
                    #389
                    Super, danke! Mal schaun obs funktioniert bei der Nächsten UV Warnung g
                    • T ticaki
                      Update:
                      v97.16
                      • kk
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #390
                      @ticaki habe das update von v97.14 auf v97.16 gemacht, jedoch mit Fehlermeldung...
                      EDIT: hatte https://forum.iobroker.net/post/440288 übersehen
                      • T ticaki
                        @Murmelbaerchen69
                        #391
                        @ticaki Fehler gefunden:
                        hatte die orginal Zeile falsch auskommentiert:
                        /* var mainStatePath = 'javascript.0.wetterwarnung_test.';
                        so ist es richtig und funktioniert auch
                        // var mainStatePath = 'javascript.0.wetterwarnung_test.';
                        • J Offline
                          jwerlsdf
                          #392
                          kann mir bitte jemand helfen:
                          Bei mir wird die Wetterwarnung an telegram immer zwei Mal verschickt. Egal ob es DWD ist oder UWZ. Ich habe das Skript UWZ bereits deaktiviert. Leider brachte das für UWZ keinen Erfolg. Benötigt man überhaupt dieses Extraskript noch? Weiterhin habe ich noch den Pfad mit allen Objekten gelöscht (var mainStatePath = 'javascript.0.wetterwarnung), sodass es nur noch den Pfad 'javascript.0.wetterwarnung_test. im Reiter Objekte gibt
                          DWD.txt
                          • J jwerlsdf
                            DWD.txt
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #393
                            @jwerlsdf ja das Script wird noch benötigt, es liefert ja die Daten. Doppelte Telegramm Meldungen hatte ich auch kürzlich, aber bei allen Meldungen, nicht nur wegen dem Wetter.
                            Abhilfe schaffte Javascript einmal neu starten.
                            J 1 Antwort Letzte Antwort
                              jwerlsdf
                              #394
                              @crunchip
                              (leider) gibt es nur die Doppelten Nachrichten bei diesem Skript. Habe auch den Pi mal neu gestartet, aber das Problem bleibt. UWZ und DWD doppelte Nachrichten. Bei allen anderen Skripten habe ich das Problem nicht.
                                ticaki
                                #395
                                Eventuell ist es das: Wenn du telegramUser und telegramChatId ausgefüllt hast, wird eine Nachricht an die genannten User und eine an die genannten ChatIds versand.
                                Spenden
                                • T ticaki
                                  jwerlsdf
                                  schrieb am zuletzt editiert von jwerlsdf
                                  #396
                                  @ticaki
                                  Daran lag es. Ich habe die ChatID rausgelöscht und schon gab es nur noch 1 Nachricht. Vielen Dank!
                                    PrinzEisenherz1
                                    #397
                                    @ticaki
                                    erstmal n riesen Lob was Du da aus dem Script gemacht hast. Echt klasse.
                                    Jetzt habe ich aber n kleines Problem.
                                    DWD sendet letzter Zeit identische Warnmeldungen innerhalb kurzer Zeit wo sich nur "gültig vom" die Uhrzeit um ein paar Minuten geändert hat oder wo sich die "gültig bis" um eine Halbe Stunde nach vorne verschiebt.
                                    Hier mal ein Auszug aus meinem Log
                                    2020-07-02 14:15:26.340 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 14:15 Uhr bis 02.07.20 15:30 Uhr
                                    Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 km/h (18m/s, 35kn, Bft 8) sowie Starkregen mit Niederschlagsmengen um 20 l/m² pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 14:15:26.341 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 14:15 Uhr bis 2 Juli 15:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 14:20:26.351 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 14:20 Uhr bis 02.07.20 15:30 Uhr
                                    2020-07-02 14:20:26.352 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 14:20 Uhr bis 2 Juli 15:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 14:30:26.820 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 14:28 Uhr bis 02.07.20 15:30 Uhr
                                    2020-07-02 14:30:26.820 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 14:28 Uhr bis 2 Juli 15:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 14:45:26.269 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 14:44 Uhr bis 02.07.20 15:30 Uhr
                                    2020-07-02 14:45:26.270 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 14:44 Uhr bis 2 Juli 15:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 15:30:26.640 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 15:29 Uhr bis 02.07.20 16:30 Uhr
                                    2020-07-02 15:30:26.641 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 15:29 Uhr bis 2 Juli 16:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 15:35:25.770 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 15:32 Uhr bis 02.07.20 16:30 Uhr
                                    2020-07-02 15:35:25.771 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 15:32 Uhr bis 2 Juli 16:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 15:40:26.292 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 15:38 Uhr bis 02.07.20 16:30 Uhr
                                    2020-07-02 15:40:26.293 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 15:38 Uhr bis 2 Juli 16:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 16:10:25.754 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 16:06 Uhr bis 02.07.20 17:30 Uhr
                                    2020-07-02 16:10:25.755 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 16:06 Uhr bis 2 Juli 17:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 16:25:25.952 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 16:21 Uhr bis 02.07.20 17:30 Uhr
                                    2020-07-02 16:25:25.954 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 16:21 Uhr bis 2 Juli 17:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 16:35:26.583 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 16:34 Uhr bis 02.07.20 17:30 Uhr
                                    2020-07-02 16:35:26.584 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 16:34 Uhr bis 2 Juli 17:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 17:05:26.165 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 17:04 Uhr bis 02.07.20 18:30 Uhr
                                    2020-07-02 17:05:26.166 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 17:04 Uhr bis 2 Juli 18:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 17:25:26.706 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 17:23 Uhr bis 02.07.20 18:30 Uhr
                                    2020-07-02 17:25:26.708 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 17:23 Uhr bis 2 Juli 18:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 17:30:27.345 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 17:26 Uhr bis 02.07.20 18:30 Uhr
                                    2020-07-02 17:30:27.347 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 17:26 Uhr bis 2 Juli 18:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 17:35:26.334 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 17:34 Uhr bis 02.07.20 18:30 Uhr
                                    2020-07-02 17:35:26.335 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis gültig vom 2 Juli 17:34 Uhr bis 2 Juli 18:30 Uhr. Von Südwesten ziehen Gewitter auf. Dabei gibt es Sturmböen mit Geschwindigkeiten um 65 Kilometer pro Stunde sowie Starkregen mit Niederschlagsmengen um 20 Liter pro Quadratmeter pro Stunde und kleinkörnigen Hagel.
                                    2020-07-02 18:30:27.200 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Alle Warnmeldungen des DWD wurden aufgehoben.
                                    2020-07-02 18:30:27.201 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: Alle Warnmeldungen des DWD wurden aufgehoben.
                                    2020-07-02 23:20:25.598 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 23:20 Uhr bis 02.07.20 23:45 Uhr
                                    Es treten Gewitter auf. Dabei gibt es Starkregen mit Niederschlagsmengen um 15 l/m² pro Stunde sowie Windböen mit Geschwindigkeiten bis 60 km/h (17m/s, 33kn, Bft 7).
                                    2020-07-02 23:30:25.457 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 23:30 Uhr bis 03.07.20 00:00 Uhr
                                    2020-07-02 23:35:24.933 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 23:33 Uhr bis 03.07.20 00:00 Uhr
                                    2020-07-02 23:40:25.491 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 23:36 Uhr bis 03.07.20 00:00 Uhr
                                    2020-07-02 23:50:25.089 - info: javascript.0 (1188) script.js.Meldungen.DWD_UWZ_Nina_script: ⚡ Amtliche WARNUNG vor STARKEM GEWITTER des DWD für Heidekreis
                                    gültig vom 02.07.20 23:48 Uhr bis 03.07.20 00:30 Uhr
                                    Jetzt bekomme ich natürlich dauernd eine Benachrichtigung über Telegram und Alexa wenn sich bloß die Zeit ändert aber die Warnung trotzdem die gleiche ist.
                                    Besteht vielleicht eine Möglichkeit einen Filter einzubauen der Nachrichten verwirft die einen identischen Warntext haben aber sich nur die Zeit ändert?
                                    Also wenn z.B. innerhalb 2 Stunden (definierbare Zeit) nach erscheinen der ersten Warnmeldung die folgenden Warnmeldungen nur eine Änderung von-bis Zeit haben.
                                    Wäre klasse wenn so was gehen würde.
                                    Johnny
                                    • P PrinzEisenherz1
                                      @ticaki
                                      Johnny
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #398
                                      @PrinzEisenherz1 hatte ich schon mehrmals, selbe Warnmeldung, teilweise nur die Uhrzeit um 1Minute verschoben ...dadurch teilweise bis zu 15 Meldungen innerhalb kürzester Zeit
                                        maddingamer
                                        #399
                                        @crunchip @PrinzEisenherz1 habe ich teilweise auch, grade wenn Unwetter angesagt ist. Dann stoppe ich momentan das Script einfach. Wird sonst echt zu viel.
                                        Ähnliches Problem: Ich nutze DWD und Nina, wenn z.B. Unwetterwarnung sowohl über DWD alsauch Nina kommt, erhält man 2 Benachrichtigungen innerhalb kurzer Zeit welche inhaltlich identisch sind..
                                          PrinzEisenherz1
                                          #400
                                          @crunchip @maddingamer Genau, vorallem bei Umwetter laufen da ne menge Meldungen auf die aber inhaltlich Identisch (ausser Uhrzeiten) sind.
                                          Nervig ist es hald wenn bei einem Unwetter Alexa mehr redet als meine Frau oder die Kiddis. Und die quasseln scxhon nicht wenig. 😀
                                          Und dafür immer das Script stoppen wäre auch nicht die Lösung.
                                          Ein Filter mit delay wäre da vielleicht geschickter.
                                          Johnny
