  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 650.3k Aufrufe 118 Beobachtet
    mrMuppet
    #901
    ich hab mal wieder versucht den Adapter (von 1.1.5 auf 2.0.7) upzudaten. Leider gibts bei mir (unter FreeBSD) leider nur ne Fehlermeldung. Das ist übrigens der einzige von meinen 25 aktiven Instanzen, der diese Probleme hat.
    $ ./iobroker upgrade mihome-vacuum
    Update mihome-vacuum from @1.1.5 to @2.0.7
    NPM version: 6.14.5
    npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
    /bin/sh: pkg-config: not found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 127 while in binding.gyp. while trying to load binding.gyp
    gyp
    ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System FreeBSD 11.3-RELEASE-p9gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64" "--python=/usr/local/bin/python2.7"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR!
    node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp
    ERR! build error node-pre-gyp ERR!
    stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64 --python=/usr/local/bin/python2.7' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System FreeBSD 11.3-RELEASE-p9
    node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp
    ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
    ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-06-12T23_18_35_159Z-debug.log
    ERROR: host.iobroker-v1 Cannot install iobroker.mihome-vacuum@2.0.7: 1
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • M mrMuppet
      NPM version: 6.14.5
      gyp
      node-pre-gyp
      npm
      #902
      @mrMuppet Da muss wohl canvas von Hand gebaut werden. Aber von FreeBSD hab ich keine Ahnung...
        mrMuppet
        #903
        @Thomas-Braun sagte in Test Adapter mihome-vacuum v2.0.x:
        Was kann ich dafür tun? Kann gerne testen und logs hochladen etc.
        • D dirkhe
          @Diginix Hallo zusammen,
          Ich habe mal eine neuere Version hochgeladen, die fängt map_slot ab, weil das aktuell noch nicht verarbeitet wird.
          @Knallochse hatte aber noch die Version 2.0.7 installiert, die hatte unendlich versucht, die Map zu laden, das hatte ich in der Version 2.0.8 oder 2.0.9 bereits mal umgebaut, so dass er nach 10 Versuchen abbricht
          KnallochseK Nicht stören
          Knallochse
          #904
          @dirkhe Mit der 2.0.10.RC1 ist die gesamte Prozessorlast während eines Saugprogramms mit eingeschalteter Karte weniger. Und geht nach Beendigung des Saugvorgangs auf normale Werte zurück.
          Folgende Meldung wird zu Beginn und nach Beendigung des Saugvorgangs ins Log geschrieben
          mihome-vacuum.1 | 2020-06-13 11:36:13.861 | warn | (22979) answer map_slot is currently not supported!
          Ich bin sehr zufrieden und vielen Dank das du dich der Sache angenommen hast 👍
          HM&HMIP über 100 Geräte + IoBroker auf DS918+ uvm.
          • M mrMuppet
            #905
            @mrMuppet sagte in Test Adapter mihome-vacuum v2.0.x:
            Wie gesagt, von FreeBSD hab ich keine Ahnung.
            • R radierer
              @backfisch88 said in Test Adapter mihome-vacuum v2.0.x:
              @radierer bei mir sagt er nur „unknown command“ 🤣
              Hm .. seltsam. Ich hab ja nix anderes gemacht .. außer zusätzlich noch den Befehl zum zurückfahren an die Ladestation.
              Evtl. mal den Haken bei "eigene Befehle zulassen" in der Adapterkonfig raus- und wieder reinmachen!?
              backfisch88
              #906
              @radierer said in Test Adapter mihome-vacuum v2.0.x:
              Hast du auch die neuste Firmware drauf?
                darkiop
                #907
                @Meistertr Besteht die Möglichkeit über den Adapter eine Karte auszuwählen? Durch das neue Update bzgl. mehrere Etagen ist das bei mir der letzte Baustein um den Robo völlgig unabhängig von der App zu steuern.
                B 1 Antwort Letzte Antwort
                • D darkiop
                  backfisch88
                  #908
                  @darkiop
                  Ja sehe ich auch so
                    radierer
                    #909
                    @backfisch88 Ich habe den Mijia 1S und laut Xiaomi App ist die Firmware aktuell.
                    • R radierer
                      backfisch88
                      #910
                      @radierer
                      Bei mir funktioniert es seit der multifloor Erkennung nicht mehr.
                      • C Offline
                        charakterkopf
                        schrieb am zuletzt editiert von charakterkopf
                        #911
                        erledigt
                          dirkhe
                          #912
                          Ich habe die Version 2.0.10 hochgeladen. Darin habe ich mal einen fix gemacht, wenn der Robbi nicht anfängt zu saugen. Ich hatte das zwischendurch mal, aber ich glaube es liegt daran, das er sich bei mir in den Mesh Repater eingewählt hat, anstelle direkt in den Router. Aber der Adapter püft jetzt nach 16 sec, ob der Staubi seinen status auf cleaning gesetzt hat, sonst probiert er es noch weiter 2 mal.
                          ? 1 Antwort Letzte Antwort
                          • D dirkhe
                            #913
                            @dirkhe
                            ich hab gestern auf die Relaese 2.1.0 geupdated, leider wird dort die Karte nicht mehr aktualisiert..
                            ( ja, ich kanns auch kaum fassen.. das Thema ... )
                            Zurück auf die 2.0.10 geht nicht, kann nicht geladen werden.. ältere auch nicht..
                            Kannst du da mal drüber schauen, bitte?
                            Hier das debug log
                            mihome-vacuum.log.txt
                            • DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #914
                              Bei mir dasselbe mit diesen Logzeilen:
                              mihome-vacuum.0	2020-07-11 14:40:15.219	warn	(2578714) Could not receive Mappointer, giving up
                              mihome-vacuum.0	2020-07-11 14:40:15.137	warn	(2578714) Could not receive Mappointer, giving up
                              mihome-vacuum.0	2020-07-11 14:40:09.180	warn	(2578714) Could not receive Mappointer, giving up
                              Auch wenn die Entwicklung und die Möglichkeiten des Adapter super vorangeschritten sind, bleibt es irgendwie immer Lotto was nach einem Update noch funktioniert. Wirkt immer wie gar nicht getestet.
                              Zum Glück mache ich aus genau dieser Erfahrung heraus immer manuelle Backups der Altversionen und konnte so bequem auf 2.0.10 zurück mit dem Ergebnis dass die Karte sofort wieder funktioniert.
                              ..:: So long! Tom ::..
                              ? BluefoxB 2 Antworten Letzte Antwort
                              • DiginixD Diginix
                                #915
                                @Diginix gute Idee mit den manuellen Backups.. werde ich auch mal einführen...👍
                                  dirkhe
                                  #916
                                  Also 2.0.10 habe ich hochgeladen und das lief bei mir vorher schon ein paar Tage. Die Version 2.1.0 hat bluefox hochgeladen und hat da eine ganze Menge verändert. Das lief zwar immer unter formating aber das war so viel, dass ich es zumindest nicht mehr überblicken kann. Ich habe die Version bei mir auch noch nicht installiert. Was das Thema mit den Maps angeht, da habe ich leider keine Aktien drin, da ich es auch nicht nutze, da mein robbi ja noch nicht mal im Internet hängt. Daher habe ich auch noch nicht die neueste Firmware drauf.
                                  Wenn also die 2.0.10 noch geht, aber die 2.1.0 nicht mehr, müsste man sich also die Unterschiede ansehen, aber die bereits geschrieben, für mich sind das zu viel.
                                    dirkhe
                                    #917
                                    Ich habe mal einen Tag 2.0.10 gemacht. Wenn du willst, kannst du den Stand wieder nehmen.
                                    • V Offline
                                      V Offline
                                      vikk88
                                      #918
                                      ich habe nach langer Zeit meinen Roborock S5 auf die aktuelle Firmware geupdatet. Den Adapter habe ich dann auch auf die 2.0.7 aktualisiert. Ich habe auch eine Verbindung, die Instanz ist grün, jedoch kommt kein Befehl beim S5 an. Im Log kommt immer folgendes:
                                      Ich habe danach die aktuellste Version von github installiert, bei dieser wird die Instanz nicht mehr grün, im Log steht:
                                      connecting, this can take up to 10 minutes
                                      Hat jemand vielleicht eine Idee? Vor den Updates, mit der alten Firmware lief alles einwandfrei.
                                      Node.js v10.21.0
                                      NPM 6.14.4
                                      Admin 4.0.10
                                      • V vikk88
                                        Node.js v10.21.0
                                        NPM 6.14.4
                                        Admin 4.0.10
                                        #919
                                        Das Verhalten muss mit den Hardwareversionen zusammenhängen. Denn mein Staubsauber der ersten Generation startet ganz unauffällig:
                                        2020-07-11 18:25:23.364  - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 6930
                                        2020-07-11 18:25:28.295  - info: mihome-vacuum.0 (6930) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.5.0, js-controller: 3.1.6
                                        2020-07-11 18:25:28.407  - info: mihome-vacuum.0 (6930) Expert mode disabled, states deleted
                                        2020-07-11 18:25:28.412  - info: mihome-vacuum.0 (6930) Create state clean_home for controlling by cloud adapter
                                        2020-07-11 18:25:28.543  - info: mihome-vacuum.0 (6930) New generation or new fw(3.5.4,004007) detected, create new states goto and zoneclean
                                        2020-07-11 18:25:28.614  - info: mihome-vacuum.0 (6930) connecting, this can take up to 10 minutes ...
                                        2020-07-11 18:25:28.671  - info: mihome-vacuum.0 (6930) Connected
                                        2020-07-11 18:25:28.983  - info: mihome-vacuum.0 (6930) set nächster Timer: Nicht verfügbar
                                        2020-07-11 18:25:29.685  - info: mihome-vacuum.0 (6930) create state for carpet_mode
                                        V 1 Antwort Letzte Antwort
                                          Sneaker75
                                          #920
                                          Auch bei mir funktioniert seit dem Update auf 2.1.0 die Karte nicht mehr. Wieso wird sowas freigegeben und nicht richtig getestet? Wie komme ich denn jetzt auf eine ältere Version zurück, wo alles einwandfrei funktionierte?
                                          ? Thomas BraunT 2 Antworten Letzte Antwort
