  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 650.5k Aufrufe 118 Beobachtet
  • XenonX Offline
    XenonX Offline
    Xenon
    Forum Testing Developer
    schrieb am zuletzt editiert von Xenon
    #861
    @dirkhe
    damit habe ich die Canvas Fehler beseitigt
    sudo iobroker stop
    cd /opt/iobroker
    sudo apt update
    sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
    sudo npm install canvas --unsafe-perm=true
    Nun sieht mein LOG so aus
    mihome-vacuum.1	2020-05-27 15:59:50.091	warn	(2838) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.1	2020-05-27 15:59:50.090	warn	(2838) Object mihome-vacuum.1.rooms.room2.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.1	2020-05-27 15:59:50.089	warn	(2838) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.1	2020-05-27 15:59:50.088	warn	(2838) Object mihome-vacuum.1.rooms.room1.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.1	2020-05-27 15:59:50.087	warn	(2838) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.1	2020-05-27 15:59:50.087	warn	(2838) Object mihome-vacuum.1.rooms.room17.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.1	2020-05-27 15:59:50.085	warn	(2838) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.1	2020-05-27 15:59:50.084	warn	(2838) Object mihome-vacuum.1.rooms.room16.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.1	2020-05-27 15:59:50.059	info	(2838) create new room: room2
    mihome-vacuum.1	2020-05-27 15:59:50.058	info	(2838) create new room: room1
    mihome-vacuum.1	2020-05-27 15:59:50.056	info	(2838) create new room: room17
    mihome-vacuum.1	2020-05-27 15:59:50.054	info	(2838) create new room: room16
    mihome-vacuum.1	2020-05-27 15:59:48.069	info	(2838) create states for water box filter
    mihome-vacuum.1	2020-05-27 15:59:48.068	info	(2838) create states for water box
    mihome-vacuum.0	2020-05-27 15:59:47.391	warn	(2580) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.0	2020-05-27 15:59:47.391	warn	(2580) Object mihome-vacuum.0.rooms.room2.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.0	2020-05-27 15:59:47.386	warn	(2580) This object will not be created in future versions. Please report this to the developer.
    mihome-vacuum.0	2020-05-27 15:59:47.385	warn	(2580) Object mihome-vacuum.0.rooms.room1.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
    mihome-vacuum.0	2020-05-27 15:59:47.374	info	(2580) create new room: room2
    mihome-vacuum.0	2020-05-27 15:59:47.373	info	(2580) create new room: room1
    mihome-vacuum.0	2020-05-27 15:59:45.304	info	(2580) create states for water box filter
    mihome-vacuum.0	2020-05-27 15:59:45.303	info	(2580) create states for water box
    wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
    D D3ltoroxpD 2 Antworten Letzte Antwort
    • XenonX Xenon
      @dirkhe
      sudo iobroker stop
      cd /opt/iobroker
      sudo apt update
      dirkhe
      #862
      @Xenon das hat mswiege gefixt und ich habe das eben gemergt
        seppel786
        schrieb am zuletzt editiert von seppel786
        #863
        Hi zusammen,
        ich bekomme die Karte ebenso nicht in den Objekten angezeigt.
        JS-Controller: 3.1.4
        Node.js: v12.16.3
        Adapter: 2.0.9
        Valetudo: 0.4
        FW: 3.3.9_003468 - rockrobo.vacuum.v1
        Anbei das Debuglog:
        mihome-vacuum.0	2020-05-28 10:32:09.274	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":768,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
        mihome-vacuum.0	2020-05-28 10:32:09.265	debug	(5526) sendMsg[1] >>> {"id":40,"method":"get_status"}
        mihome-vacuum.0	2020-05-28 10:31:49.269	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":767,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
        mihome-vacuum.0	2020-05-28 10:31:49.263	debug	(5526) sendMsg[1] >>> {"id":39,"method":"get_status"}
        mihome-vacuum.0	2020-05-28 10:31:36.702	warn	(5526) Could not receive Mappointer, giving up
        mihome-vacuum.0	2020-05-28 10:31:36.702	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":38}
        mihome-vacuum.0	2020-05-28 10:31:36.698	debug	(5526) 9. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:36.697	debug	(5526) sendMsg[1] >>> {"id":38,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:36.197	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":37}
        mihome-vacuum.0	2020-05-28 10:31:36.190	debug	(5526) 8. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:36.190	debug	(5526) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:35.689	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":36}
        mihome-vacuum.0	2020-05-28 10:31:35.681	debug	(5526) 7. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:35.681	debug	(5526) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:35.246	debug	(5526) CLEAN_LOGGING[{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"Ende":false},{"Datum":"25.5","Start":"15:23","Saugzeit":"0 min","Fläche":"0.75 m²","Error":0,"Ende
        mihome-vacuum.0	2020-05-28 10:31:35.181	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":35}
        mihome-vacuum.0	2020-05-28 10:31:35.177	debug	(5526) 6. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:35.177	debug	(5526) sendMsg[1] >>> {"id":35,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:35.050	debug	(5526) Receive <<< {"result":[[1589796884,1589796954,0,1200000,0,0]],"id":34}
        mihome-vacuum.0	2020-05-28 10:31:35.045	debug	(5526) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589796884]}
        mihome-vacuum.0	2020-05-28 10:31:34.850	debug	(5526) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":33}
        mihome-vacuum.0	2020-05-28 10:31:34.845	debug	(5526) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589801327]}
        mihome-vacuum.0	2020-05-28 10:31:34.676	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":32}
        mihome-vacuum.0	2020-05-28 10:31:34.673	debug	(5526) 5. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:34.672	debug	(5526) sendMsg[1] >>> {"id":32,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:34.649	debug	(5526) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":31}
        mihome-vacuum.0	2020-05-28 10:31:34.644	debug	(5526) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589802735]}
        mihome-vacuum.0	2020-05-28 10:31:34.449	debug	(5526) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":30}
        mihome-vacuum.0	2020-05-28 10:31:34.444	debug	(5526) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589804616]}
        mihome-vacuum.0	2020-05-28 10:31:34.248	debug	(5526) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":29}
        mihome-vacuum.0	2020-05-28 10:31:34.243	debug	(5526) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589804656]}
        mihome-vacuum.0	2020-05-28 10:31:34.173	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":28}
        mihome-vacuum.0	2020-05-28 10:31:34.169	debug	(5526) 4. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:34.169	debug	(5526) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:34.049	debug	(5526) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":27}
        mihome-vacuum.0	2020-05-28 10:31:34.042	debug	(5526) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589804971]}
        mihome-vacuum.0	2020-05-28 10:31:33.866	debug	(5526) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":26}
        mihome-vacuum.0	2020-05-28 10:31:33.841	debug	(5526) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589805818]}
        mihome-vacuum.0	2020-05-28 10:31:33.668	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":25}
        mihome-vacuum.0	2020-05-28 10:31:33.664	debug	(5526) 3. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:33.664	debug	(5526) sendMsg[1] >>> {"id":25,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:33.645	debug	(5526) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":24}
        mihome-vacuum.0	2020-05-28 10:31:33.640	debug	(5526) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1589806003]}
        mihome-vacuum.0	2020-05-28 10:31:33.448	debug	(5526) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":23}
        mihome-vacuum.0	2020-05-28 10:31:33.440	debug	(5526) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589807338]}
        mihome-vacuum.0	2020-05-28 10:31:33.244	debug	(5526) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":22}
        mihome-vacuum.0	2020-05-28 10:31:33.239	debug	(5526) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589807988]}
        mihome-vacuum.0	2020-05-28 10:31:33.156	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":21}
        mihome-vacuum.0	2020-05-28 10:31:33.153	debug	(5526) 2. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:33.152	debug	(5526) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:33.044	debug	(5526) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":20}
        mihome-vacuum.0	2020-05-28 10:31:33.039	debug	(5526) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1589811051]}
        mihome-vacuum.0	2020-05-28 10:31:32.843	debug	(5526) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":19}
        mihome-vacuum.0	2020-05-28 10:31:32.838	debug	(5526) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589811788]}
        mihome-vacuum.0	2020-05-28 10:31:32.653	debug	(5526) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":18}
        mihome-vacuum.0	2020-05-28 10:31:32.652	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":17}
        mihome-vacuum.0	2020-05-28 10:31:32.637	debug	(5526) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589811799]}
        mihome-vacuum.0	2020-05-28 10:31:32.631	debug	(5526) 1. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:32.631	debug	(5526) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:32.442	debug	(5526) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":16}
        mihome-vacuum.0	2020-05-28 10:31:32.437	debug	(5526) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1589811915]}
        mihome-vacuum.0	2020-05-28 10:31:32.241	debug	(5526) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":15}
        mihome-vacuum.0	2020-05-28 10:31:32.236	debug	(5526) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1589812855]}
        mihome-vacuum.0	2020-05-28 10:31:32.130	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":14}
        mihome-vacuum.0	2020-05-28 10:31:32.126	debug	(5526) 0. Mappointer_nomap___retry
        mihome-vacuum.0	2020-05-28 10:31:32.126	debug	(5526) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:32.040	debug	(5526) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":13}
        mihome-vacuum.0	2020-05-28 10:31:32.035	debug	(5526) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1589813020]}
        mihome-vacuum.0	2020-05-28 10:31:31.838	debug	(5526) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":12}
        mihome-vacuum.0	2020-05-28 10:31:31.834	debug	(5526) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590047127]}
        mihome-vacuum.0	2020-05-28 10:31:31.643	debug	(5526) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":11}
        mihome-vacuum.0	2020-05-28 10:31:31.633	debug	(5526) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1590159774]}
        mihome-vacuum.0	2020-05-28 10:31:31.625	debug	(5526) Receive <<< {"result":["retry"],"id":10}
        mihome-vacuum.0	2020-05-28 10:31:31.621	debug	(5526) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:31.439	debug	(5526) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":9}
        mihome-vacuum.0	2020-05-28 10:31:31.432	debug	(5526) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590412996]}
        mihome-vacuum.0	2020-05-28 10:31:31.426	debug	(5526) Receive <<< {"result":"unknown_method","id":8}
        mihome-vacuum.0	2020-05-28 10:31:31.426	info	(5526) create state for carpet_mode
        mihome-vacuum.0	2020-05-28 10:31:31.426	debug	(5526) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
        mihome-vacuum.0	2020-05-28 10:31:31.421	debug	(5526) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
        mihome-vacuum.0	2020-05-28 10:31:31.420	debug	(5526) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
        mihome-vacuum.0	2020-05-28 10:31:31.236	debug	(5526) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":6}
        mihome-vacuum.0	2020-05-28 10:31:31.231	debug	(5526) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1590653494]}
        mihome-vacuum.0	2020-05-28 10:31:31.231	debug	(5526) Receive <<< {"result":[373752,5385070000,197,[1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,1589806003,158
        mihome-vacuum.0	2020-05-28 10:31:31.221	debug	(5526) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
        mihome-vacuum.0	2020-05-28 10:31:31.028	debug	(5526) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":4}
        mihome-vacuum.0	2020-05-28 10:31:31.020	debug	(5526) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
        mihome-vacuum.0	2020-05-28 10:31:30.825	debug	(5526) Receive <<< {"result":[80],"id":3}
        mihome-vacuum.0	2020-05-28 10:31:30.821	debug	(5526) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
        mihome-vacuum.0	2020-05-28 10:31:30.625	debug	(5526) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-60},"netif":{"l
        mihome-vacuum.0	2020-05-28 10:31:30.621	debug	(5526) Next WiFi check: 28.05 10:32
        mihome-vacuum.0	2020-05-28 10:31:30.621	debug	(5526) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
        mihome-vacuum.0	2020-05-28 10:31:30.420	info	(5526) Connected
        mihome-vacuum.0	2020-05-28 10:31:30.044	debug	(5526) TypeError: Cannot read property 'id' of undefined
        mihome-vacuum.0	2020-05-28 10:31:30.040	debug	(5526) 25175
        mihome-vacuum.0	2020-05-28 10:31:30.005	debug	(5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-05-28 10:31:30.004	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":766,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id
        mihome-vacuum.0	2020-05-28 10:31:29.991	debug	(5526) sendMsg[1] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-05-28 10:31:29.972	debug	(5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-05-28 10:31:29.972	info	(5526) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-05-28 10:31:29.971	debug	(5526) Receive <<< Helo <<< 213100200000000005c604885ecf76e0ffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-05-28 10:31:29.769	info	(5526) set nächster Timer: Nicht verfügbar
        mihome-vacuum.0	2020-05-28 10:31:29.302	debug	(5526) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        mihome-vacuum.0	2020-05-28 10:31:29.296	info	(5526) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
        mihome-vacuum.0	2020-05-28 10:31:29.264	debug	(5526) server started on 0.0.0.0:53421
        mihome-vacuum.0	2020-05-28 10:31:29.260	info	(5526) Cloud control disabled
        mihome-vacuum.0	2020-05-28 10:31:29.259	info	(5526) Expert mode disabled, states deleted
        mihome-vacuum.0	2020-05-28 10:31:29.255	debug	(5526) load Map creator... true
        mihome-vacuum.0	2020-05-28 10:31:29.233	info	(5526) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4
        mihome-vacuum.0	2020-05-28 10:31:28.865	debug	(5526) statesDB connected
        mihome-vacuum.0	2020-05-28 10:31:28.865	debug	(5526) States connected to redis: 127.0.0.1:9000
        mihome-vacuum.0	2020-05-28 10:31:28.861	debug	(5526) States create System PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.860	debug	(5526) States create User PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.856	debug	(5526) Redis States: Use Redis connection: 127.0.0.1:9000
        mihome-vacuum.0	2020-05-28 10:31:28.855	debug	(5526) objectDB connected
        mihome-vacuum.0	2020-05-28 10:31:28.853	debug	(5526) Objects connected to redis: 127.0.0.1:9001
        mihome-vacuum.0	2020-05-28 10:31:28.842	debug	(5526) Objects client initialize lua scripts
        mihome-vacuum.0	2020-05-28 10:31:28.841	debug	(5526) Objects create User PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.841	debug	(5526) Objects create System PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.840	debug	(5526) Objects client ready ... initialize now
        mihome-vacuum.0	2020-05-28 10:31:28.725	debug	(5526) Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.IoBroker	2020-05-28 10:31:28.510	info	instance system.adapter.mihome-vacuum.0 started with pid 5526
        Bin über jede Hilfe dankbar.
        Gruß Daniel
        C 1 Antwort Letzte Antwort
        • S seppel786
          Hi zusammen,
          Node.js: v12.16.3
          Adapter: 2.0.9
          Valetudo: 0.4
          Anbei das Debuglog:
          Gruß Daniel
          Coffeelover
          #864
          @seppel786 Hast du die Beiträge von Xenon (https://forum.iobroker.net/topic/30137/test-adapter-mihome-vacuum-v2-0-x/862) und mir darüber gesehen / getestet?
          • C Coffeelover
            seppel786
            #865
            @Coffeelover
            folgende Schritte habe ich durchlaufen lassen:
            sudo iobroker stop
            cd /opt/iobroker
            sudo apt update
            Anbei noch ein kurzer Auszug der Konsole:
            Zusätzlich habe ich noch eine neue VM auf meinem NUC aufgesetzt um auszuschließen, dass in meiner produktiven Umgebung
            irgendetwas "krumm" ist oder beim Update auf nodejs 12 irgendwas in die Hose gegangen ist (wie teilweise auf GIT schon berichtet).
            Auf der Test-VM habe ich allerdings dasselbe verhalten.
            Anbei das Debuglog nach dem Update von Canvas:
            mihome-vacuum.0	2020-05-28 11:22:39.288	debug	(6826) sendMsg[3] >>> {"id":52,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:37.298	debug	(6826) sendMsg[2] >>> {"id":53,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:34.288	debug	(6826) sendMsg[2] >>> {"id":52,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:32.297	debug	(6826) 9. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:32.297	debug	(6826) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:31.796	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":51}
            mihome-vacuum.0	2020-05-28 11:22:31.792	debug	(6826) sendMsg[2] >>> {"id":51,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:29.287	debug	(6826) sendMsg[1] >>> {"id":52,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:26.791	debug	(6826) 8. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:26.791	debug	(6826) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:26.290	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":50}
            mihome-vacuum.0	2020-05-28 11:22:26.286	debug	(6826) 7. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:26.286	debug	(6826) sendMsg[1] >>> {"id":50,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:25.785	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":49}
            mihome-vacuum.0	2020-05-28 11:22:25.782	debug	(6826) 6. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:25.781	debug	(6826) sendMsg[1] >>> {"id":49,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:25.280	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":48}
            mihome-vacuum.0	2020-05-28 11:22:25.276	debug	(6826) 5. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:25.276	debug	(6826) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:24.775	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":47}
            mihome-vacuum.0	2020-05-28 11:22:24.771	debug	(6826) 4. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:24.771	debug	(6826) sendMsg[1] >>> {"id":47,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:24.271	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":46}
            mihome-vacuum.0	2020-05-28 11:22:24.267	debug	(6826) 3. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:24.267	debug	(6826) sendMsg[1] >>> {"id":46,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:23.766	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":45}
            mihome-vacuum.0	2020-05-28 11:22:23.762	debug	(6826) 2. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:23.762	debug	(6826) sendMsg[1] >>> {"id":45,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:23.261	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":44}
            mihome-vacuum.0	2020-05-28 11:22:23.257	debug	(6826) 1. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:23.257	debug	(6826) sendMsg[1] >>> {"id":44,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:22.756	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":43}
            mihome-vacuum.0	2020-05-28 11:22:22.752	debug	(6826) 0. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:22.752	debug	(6826) sendMsg[1] >>> {"id":43,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:22.252	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":42}
            mihome-vacuum.0	2020-05-28 11:22:22.248	debug	(6826) sendMsg[1] >>> {"id":42,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:22.247	debug	(6826) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1590657742246,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589621974319}
            mihome-vacuum.0	2020-05-28 11:22:16.971	warn	(6826) Could not receive Mappointer, giving up
            mihome-vacuum.0	2020-05-28 11:22:16.970	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":41}
            mihome-vacuum.0	2020-05-28 11:22:16.964	debug	(6826) 9. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:16.963	debug	(6826) sendMsg[1] >>> {"id":41,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:16.464	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":40}
            mihome-vacuum.0	2020-05-28 11:22:16.460	debug	(6826) 8. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:16.459	debug	(6826) sendMsg[1] >>> {"id":40,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:15.959	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":39}
            mihome-vacuum.0	2020-05-28 11:22:15.956	debug	(6826) 7. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:15.955	debug	(6826) sendMsg[1] >>> {"id":39,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:15.456	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":38}
            mihome-vacuum.0	2020-05-28 11:22:15.451	debug	(6826) 6. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:15.451	debug	(6826) sendMsg[1] >>> {"id":38,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:14.950	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":37}
            mihome-vacuum.0	2020-05-28 11:22:14.946	debug	(6826) 5. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:14.946	debug	(6826) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:14.445	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":36}
            mihome-vacuum.0	2020-05-28 11:22:14.441	debug	(6826) 4. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:14.441	debug	(6826) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:14.123	debug	(6826) CLEAN_LOGGING[{"Datum":"28.5","Start":"11:20","Saugzeit":"0 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"End
            mihome-vacuum.0	2020-05-28 11:22:13.953	debug	(6826) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":35}
            mihome-vacuum.0	2020-05-28 11:22:13.950	debug	(6826) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":34}
            mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":33}
            mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":32}
            mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":31}
            mihome-vacuum.0	2020-05-28 11:22:13.948	debug	(6826) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":30}
            mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":29}
            mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":28}
            mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":27}
            mihome-vacuum.0	2020-05-28 11:22:13.921	debug	(6826) sendMsg[1] >>> {"id":35,"method":"get_clean_record","params":[1589801327]}
            mihome-vacuum.0	2020-05-28 11:22:13.721	debug	(6826) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589802735]}
            mihome-vacuum.0	2020-05-28 11:22:13.520	debug	(6826) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589804616]}
            mihome-vacuum.0	2020-05-28 11:22:13.319	debug	(6826) sendMsg[1] >>> {"id":32,"method":"get_clean_record","params":[1589804656]}
            mihome-vacuum.0	2020-05-28 11:22:13.118	debug	(6826) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589804971]}
            mihome-vacuum.0	2020-05-28 11:22:12.917	debug	(6826) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589805818]}
            mihome-vacuum.0	2020-05-28 11:22:12.716	debug	(6826) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589806003]}
            mihome-vacuum.0	2020-05-28 11:22:12.518	debug	(6826) 3. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:12.518	debug	(6826) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:12.515	debug	(6826) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589807338]}
            mihome-vacuum.0	2020-05-28 11:22:12.319	debug	(6826) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":26}
            mihome-vacuum.0	2020-05-28 11:22:12.314	debug	(6826) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589807988]}
            mihome-vacuum.0	2020-05-28 11:22:12.118	debug	(6826) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":25}
            mihome-vacuum.0	2020-05-28 11:22:12.113	debug	(6826) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1589811051]}
            mihome-vacuum.0	2020-05-28 11:22:12.018	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":24}
            mihome-vacuum.0	2020-05-28 11:22:12.015	debug	(6826) 2. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:12.014	debug	(6826) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:11.916	debug	(6826) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":23}
            mihome-vacuum.0	2020-05-28 11:22:11.912	debug	(6826) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589811788]}
            mihome-vacuum.0	2020-05-28 11:22:11.716	debug	(6826) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":22}
            mihome-vacuum.0	2020-05-28 11:22:11.711	debug	(6826) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589811799]}
            mihome-vacuum.0	2020-05-28 11:22:11.515	debug	(6826) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":21}
            mihome-vacuum.0	2020-05-28 11:22:11.515	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":20}
            mihome-vacuum.0	2020-05-28 11:22:11.510	debug	(6826) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1589811915]}
            mihome-vacuum.0	2020-05-28 11:22:11.510	debug	(6826) 1. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:11.509	debug	(6826) sendMsg[1] >>> {"id":20,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:11.314	debug	(6826) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":19}
            mihome-vacuum.0	2020-05-28 11:22:11.309	debug	(6826) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589812855]}
            mihome-vacuum.0	2020-05-28 11:22:11.114	debug	(6826) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":18}
            mihome-vacuum.0	2020-05-28 11:22:11.109	debug	(6826) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589813020]}
            mihome-vacuum.0	2020-05-28 11:22:11.009	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":17}
            mihome-vacuum.0	2020-05-28 11:22:11.005	debug	(6826) 0. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:11.004	debug	(6826) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:10.913	debug	(6826) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":16}
            mihome-vacuum.0	2020-05-28 11:22:10.909	debug	(6826) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1590047127]}
            mihome-vacuum.0	2020-05-28 11:22:10.713	debug	(6826) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":15}
            mihome-vacuum.0	2020-05-28 11:22:10.708	debug	(6826) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1590159774]}
            mihome-vacuum.0	2020-05-28 11:22:10.512	debug	(6826) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":14}
            mihome-vacuum.0	2020-05-28 11:22:10.507	debug	(6826) sendMsg[1] >>> {"id":14,"method":"get_clean_record","params":[1590412996]}
            mihome-vacuum.0	2020-05-28 11:22:10.504	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":13}
            mihome-vacuum.0	2020-05-28 11:22:10.497	debug	(6826) sendMsg[1] >>> {"id":13,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:10.313	debug	(6826) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":12}
            mihome-vacuum.0	2020-05-28 11:22:10.306	debug	(6826) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590653494]}
            mihome-vacuum.0	2020-05-28 11:22:10.304	debug	(6826) Receive <<< {"result":"unknown_method","id":11}
            mihome-vacuum.0	2020-05-28 11:22:10.304	info	(6826) create state for carpet_mode
            mihome-vacuum.0	2020-05-28 11:22:10.303	debug	(6826) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":10}
            mihome-vacuum.0	2020-05-28 11:22:10.297	debug	(6826) sendMsg[1] >>> {"id":11,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-05-28 11:22:10.296	debug	(6826) sendMsg[1] >>> {"id":10,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-05-28 11:22:10.110	debug	(6826) Receive <<< {"result":[[1590657608,1590657628,0,122500,0,0]],"id":9}
            mihome-vacuum.0	2020-05-28 11:22:10.105	debug	(6826) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590657608]}
            mihome-vacuum.0	2020-05-28 11:22:10.105	debug	(6826) Receive <<< {"result":[373752,5385192500,198,[1590657608,1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,158
            mihome-vacuum.0	2020-05-28 11:22:10.097	debug	(6826) sendMsg[1] >>> {"id":8,"method":"get_clean_summary"}
            mihome-vacuum.0	2020-05-28 11:22:09.906	debug	(6826) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":7}
            mihome-vacuum.0	2020-05-28 11:22:09.897	debug	(6826) sendMsg[1] >>> {"id":7,"method":"get_consumable"}
            mihome-vacuum.0	2020-05-28 11:22:09.702	debug	(6826) Receive <<< {"result":[80],"id":6}
            mihome-vacuum.0	2020-05-28 11:22:09.696	debug	(6826) sendMsg[1] >>> {"id":6,"method":"get_sound_volume"}
            mihome-vacuum.0	2020-05-28 11:22:09.501	debug	(6826) Receive <<< {"partner_id":"","id":5,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-54},"netif":{"l
            mihome-vacuum.0	2020-05-28 11:22:09.497	debug	(6826) Next WiFi check: 28.05 11:23
            mihome-vacuum.0	2020-05-28 11:22:09.497	debug	(6826) sendMsg[1] >>> {"id":5,"method":"miIO.info"}
            mihome-vacuum.0	2020-05-28 11:22:09.296	info	(6826) Connected
            mihome-vacuum.0	2020-05-28 11:22:09.295	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:22:09.295	debug	(6826) Receive <<< {"result":[{"msg_ver":8,"msg_seq":958,"state":3,"battery":97,"clean_time":0,"clean_area":122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
            mihome-vacuum.0	2020-05-28 11:22:09.290	debug	(6826) sendMsg[1] >>> {"id":4,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:09.289	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:22:09.289	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:22:09.289	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf82c0ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:22:04.293	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:22:04.292	debug	(6826) no answer for undefined(id:3) received, giving up
            mihome-vacuum.0	2020-05-28 11:22:01.402	debug	(6826) system.adapter.admin.0: logging true
            mihome-vacuum.0	2020-05-28 11:21:59.291	debug	(6826) sendMsg[3] >>> {"id":3,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:54.291	debug	(6826) sendMsg[2] >>> {"id":3,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:49.290	debug	(6826) sendMsg[1] >>> {"id":3,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:49.289	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:49.289	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:21:49.289	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf82acffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:21:44.291	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:44.291	debug	(6826) no answer for undefined(id:2) received, giving up
            mihome-vacuum.0	2020-05-28 11:21:43.674	debug	(6826) system.adapter.admin.0: logging false
            mihome-vacuum.0	2020-05-28 11:21:39.290	debug	(6826) sendMsg[3] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:34.290	debug	(6826) sendMsg[2] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:29.289	debug	(6826) sendMsg[1] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:29.288	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:29.288	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:21:29.288	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf8298ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:21:24.359	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:24.359	debug	(6826) no answer for undefined(id:1) received, giving up
            mihome-vacuum.0	2020-05-28 11:21:19.358	debug	(6826) sendMsg[3] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:14.357	debug	(6826) sendMsg[2] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:13.343	debug	(6826) system.adapter.admin.0: logging true
            mihome-vacuum.0	2020-05-28 11:21:12.509	debug	(6826) system.adapter.admin.0: logging false
            mihome-vacuum.0	2020-05-28 11:21:09.800	info	(6826) set nächster Timer: Nicht verfügbar
            mihome-vacuum.0	2020-05-28 11:21:09.397	debug	(6826) TypeError: Cannot read property 'id' of undefined
            mihome-vacuum.0	2020-05-28 11:21:09.396	debug	(6826) 25616
            mihome-vacuum.0	2020-05-28 11:21:09.356	debug	(6826) sendMsg[1] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:09.340	debug	(6826) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            mihome-vacuum.0	2020-05-28 11:21:09.334	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:09.334	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:21:09.334	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf8284ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:21:09.324	info	(6826) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
            mihome-vacuum.0	2020-05-28 11:21:09.287	debug	(6826) server started on 0.0.0.0:53421
            mihome-vacuum.0	2020-05-28 11:21:09.282	info	(6826) Cloud control disabled
            mihome-vacuum.0	2020-05-28 11:21:09.281	info	(6826) Expert mode disabled, states deleted
            mihome-vacuum.0	2020-05-28 11:21:09.277	debug	(6826) load Map creator... true
            mihome-vacuum.0	2020-05-28 11:21:09.258	info	(6826) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4
            mihome-vacuum.0	2020-05-28 11:21:08.765	debug	(6826) statesDB connected
            mihome-vacuum.0	2020-05-28 11:21:08.765	debug	(6826) States connected to redis: 127.0.0.1:9000
            mihome-vacuum.0	2020-05-28 11:21:08.761	debug	(6826) States create System PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.760	debug	(6826) States create User PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.751	debug	(6826) Redis States: Use Redis connection: 127.0.0.1:9000
            mihome-vacuum.0	2020-05-28 11:21:08.750	debug	(6826) objectDB connected
            mihome-vacuum.0	2020-05-28 11:21:08.748	debug	(6826) Objects connected to redis: 127.0.0.1:9001
            mihome-vacuum.0	2020-05-28 11:21:08.742	debug	(6826) Objects client initialize lua scripts
            mihome-vacuum.0	2020-05-28 11:21:08.741	debug	(6826) Objects create User PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.741	debug	(6826) Objects create System PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.740	debug	(6826) Objects client ready ... initialize now
            mihome-vacuum.0	2020-05-28 11:21:08.627	debug	(6826) Redis Objects: Use Redis connection: 127.0.0.1:9001
            host.IoBroker	2020-05-28 11:21:08.414	info	instance system.adapter.mihome-vacuum.0 started with pid 6826
            host.IoBroker	2020-05-28 11:21:08.406	info	"system.adapter.mihome-vacuum.0" enabled
            host.IoBroker	2020-05-28 11:21:06.950	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            host.IoBroker	2020-05-28 11:21:06.437	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
            mihome-vacuum.0	2020-05-28 11:21:06.439	info	(6811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            mihome-vacuum.0	2020-05-28 11:21:06.439	info	(6811) terminating
            mihome-vacuum.0	2020-05-28 11:21:06.438	info	(6811) Got terminate signal TERMINATE_YOURSELF
            host.IoBroker	2020-05-28 11:21:06.436	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
            host.IoBroker	2020-05-28 11:21:06.436	info	"system.adapter.mihome-vacuum.0" disabled
            mihome-vacuum.0	2020-05-28 11:21:04.528	debug	(6811) sendMsg[2] >>> {"id":8,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:21:04.331	debug	(6811) sendMsg[2] >>> {"id":7,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-05-28 11:21:04.331	debug	(6811) sendMsg[2] >>> {"id":6,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-05-28 11:21:04.129	debug	(6811) sendMsg[2] >>> {"id":5,"method":"get_clean_summary"}
            Gruß Daniel aka Seppel
            • DiginixD Offline
              DiginixD Offline
              Diginix
              #866
              @seppel786 sagte in Test Adapter mihome-vacuum v2.0.x:
              Node.js: v12.16.3
              Adapter: 2.0.9
              Hilft jetzt sicher nicht viel, aber genau mit dieser Konstellation läuft bei mir alles. nodejs 12 ist also kein generelles Problem.
              Abweichend bei mir ist es das Modell 1S und Karte aus der Xiaomi Cloud.
              ..:: So long! Tom ::..
              • DiginixD Diginix
                Node.js: v12.16.3
                Adapter: 2.0.9
                seppel786
                #867
                @Diginix
                Spannende Kiste...Vlt liegt es auch am Zusammenspiel mit Valetudo?! Wäre jetzt interessant zu wissen,
                ob das bei jemand in der gleichen Konstellation läuft oder ob das Problem wieder vor dem Bildschirm sitzt :-)
                • S seppel786
                  @Diginix
                  Coffeelover
                  #868
                  @seppel786 Bei mir genau das Setting von @Diginix Auch ein 1S, auch Xiaomi Cloud.
                  • C Coffeelover
                    seppel786
                    #869
                    @All: Hat jemand ein ähnliches Setting wie ich, wo die Karte in Verbindung mit Valetudo funktioniert?
                    @Meistertr
                    Ist ein "Problem" mit Valetudo bekannt?!
                      dirkhe
                      #870
                      Bei den Karten kenne ich mich nicht so gut aus, aber kann es sein, dass man nicht auf die roborock App zurück darf, wenn man ioBroker nutzen möchte?
                      ? 1 Antwort Letzte Antwort
                      • D dirkhe
                        #871
                        @dirkhe die Karte funktioniert anscheinend nur, wenn der Sauger über die mihome App registriert ist.
                        • B backfisch88
                          NEUE FIRMWARE DRAUSSEN
                          Fasse mal kurz grob zusammen, da die neue Firmware jetzt auch in miHome verfügbar ist
                          Adapter läuft
                          mehrkarten speicherung auch... Ortung der Stockwerke scheint auch ganz gut zu funktionieren
                          WAS NICHT MEHR GEHT
                          Da ich 3 Stockwerke besitze habe ich bisher das mit den Stockwerken folgendermassen gelöst:
                          Ich sag Siri: Reinige das Obergeschoss es wird ne Variable gesetzt, dass der Roboter sich im 1. OG befindet map reset durchgeführt und als neue Karte machen lassen
                          aufm Rückweg hab ich ihn auf Position 0 fahren lassen und die Karte wiederhergestellt (aufs Erdgeschoss)
                          Map reset hab ich noch nicht ausprobiert, aber eine Vorhandene Map widerherstellen lassen geht auf alle fälle nicht (zumindest nicht über den recover_map;[xxx] Befehl
                          ist auch egal, da er sich eh vor JEDEM saugen oder bewegen ortet
                          Was ich später mal ausprobiere was passiert, wenn ich Ihn im Keller aussetze und das als neue Karte laufen lasse (was er macht, wenn er nicht weiss wo er ist... was dann passiert, wenn man ihn wieder zurück setzt)
                          ansonsten scheint alles zu laufen... soweit
                          UPDATE: reset_map klappt auch nicht
                          radierer
                          #872
                          @backfisch88 said in Test Adapter mihome-vacuum v2.0.x:
                          Moin .. wie genau und wo hast du denn den Befehl "recover_map;[xxx]" ausgeführt?
                          B 1 Antwort Letzte Antwort
                          • XenonX Xenon
                            @dirkhe
                            sudo iobroker stop
                            cd /opt/iobroker
                            sudo apt update
                            D3ltoroxpD Offline
                            D3ltoroxpD Offline
                            D3ltoroxp
                            schrieb am zuletzt editiert von D3ltoroxp
                            #873
                            @Xenon said in Test Adapter mihome-vacuum v2.0.x:
                            @dirkhe
                            sudo iobroker stop
                            cd /opt/iobroker
                            sudo apt update
                            Ok, das scheint bei mir auch funktioniert zu haben. Leider scheint jetzt Port 80 belegt zu sein, den ich eigentlich für Alexa und Node.js benötige...
                            Kann das was mit dem Canvas Update zu tun haben oder mit dem hier ?
                            Ich hatte gleich noch upgrade mit gemacht, aber wenn sich bestehende SW updatet, ändert sich doch nicht einfach der Port oder ?
                            J 1 Antwort Letzte Antwort
                            • D3ltoroxpD D3ltoroxp
                              @dirkhe
                              sudo iobroker stop
                              cd /opt/iobroker
                              sudo apt update
                              Jaschkopf
                              #874
                              Servus. Ich habe zwei Roborock S50 im Betrieb. Beide laufen über das selbe Xiaomi Konto auf dem Europa Server. Jedoch bekomme ich bei einem keine Karte geladen. Instanz 0 (Erdgeschoss) lädt sie einfach nicht. Bei Instanz 1 (Obergeschoss) klappt das wunderbar. Beide Roboter laufen mit stock Firmware 3.5.7_002008.
                              Das Update von canvas hab ich schon Probiert, hat jedoch nichts gebracht. Hat jemand eine Idee?
                              Gruß Jaschkopf
                              • R radierer
                                backfisch88
                                #875
                                @radierer
                                Genau so. Hatte bisher immer funktioniert.
                                J R 2 Antworten Letzte Antwort
                                • B backfisch88
                                  @radierer
                                  Jaschkopf
                                  #876
                                  @backfisch88 Habe das auch gerade mal probiert und bekomme im Log folgenden Fehler:
                                  mihome-vacuum.0	2020-06-05 18:18:00.833	warn	(28716) Could not receive Mappointer, giving up
                                  mihome-vacuum.0	2020-06-05 18:16:56.282	error	(28716) [69](X_send_command) -> response time out
                                  mihome-vacuum.0	2020-06-05 18:16:52.783	info	(28716) send message: Method: recover_map Params: [1]
                                  mihome-vacuum.0	2020-06-05 18:16:51.820	info	(28716) send message: Method: get_recover_maps
                                  Jetzt hat er zwar die Karte geladen, diese wird aber nicht aktualisiert wenn der Roboter saugt. Hat jemand noch eine Idee?
                                  Gruß Jaschkopf
                                    dirkhe
                                    #877
                                    Einmal in die mihome App einloggen und nen Moment warten
                                    • B backfisch88
                                      @radierer
                                      radierer
                                      #878
                                      @radierer
                                      Besten Dank! Funktioniert wie gewünscht .. 👍🏻🙂
                                      • D dirkhe
                                        Jaschkopf
                                        #879
                                        @dirkhe Ein Traum jetzt klappt es. Vielen Dank 💪💪
                                        • R radierer
                                          @radierer
                                          backfisch88
                                          #880
                                          @radierer bei mir sagt er nur „unknown command“ 🤣
                                          R 1 Antwort Letzte Antwort
