  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 636.1k Aufrufe 118 Beobachtet
  • S seppel786
    Hi zusammen,
    ich bekomme die Karte ebenso nicht in den Objekten angezeigt.
    JS-Controller: 3.1.4
    Node.js: v12.16.3
    Adapter: 2.0.9
    Valetudo: 0.4
    FW: 3.3.9_003468 - rockrobo.vacuum.v1
    Anbei das Debuglog:
    mihome-vacuum.0	2020-05-28 10:32:09.274	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":768,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
    mihome-vacuum.0	2020-05-28 10:32:09.265	debug	(5526) sendMsg[1] >>> {"id":40,"method":"get_status"}
    mihome-vacuum.0	2020-05-28 10:31:49.269	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":767,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
    mihome-vacuum.0	2020-05-28 10:31:49.263	debug	(5526) sendMsg[1] >>> {"id":39,"method":"get_status"}
    mihome-vacuum.0	2020-05-28 10:31:36.702	warn	(5526) Could not receive Mappointer, giving up
    mihome-vacuum.0	2020-05-28 10:31:36.702	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":38}
    mihome-vacuum.0	2020-05-28 10:31:36.698	debug	(5526) 9. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:36.697	debug	(5526) sendMsg[1] >>> {"id":38,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:36.197	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":37}
    mihome-vacuum.0	2020-05-28 10:31:36.190	debug	(5526) 8. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:36.190	debug	(5526) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:35.689	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":36}
    mihome-vacuum.0	2020-05-28 10:31:35.681	debug	(5526) 7. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:35.681	debug	(5526) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:35.246	debug	(5526) CLEAN_LOGGING[{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"Ende":false},{"Datum":"25.5","Start":"15:23","Saugzeit":"0 min","Fläche":"0.75 m²","Error":0,"Ende
    mihome-vacuum.0	2020-05-28 10:31:35.181	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":35}
    mihome-vacuum.0	2020-05-28 10:31:35.177	debug	(5526) 6. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:35.177	debug	(5526) sendMsg[1] >>> {"id":35,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:35.050	debug	(5526) Receive <<< {"result":[[1589796884,1589796954,0,1200000,0,0]],"id":34}
    mihome-vacuum.0	2020-05-28 10:31:35.045	debug	(5526) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589796884]}
    mihome-vacuum.0	2020-05-28 10:31:34.850	debug	(5526) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":33}
    mihome-vacuum.0	2020-05-28 10:31:34.845	debug	(5526) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589801327]}
    mihome-vacuum.0	2020-05-28 10:31:34.676	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":32}
    mihome-vacuum.0	2020-05-28 10:31:34.673	debug	(5526) 5. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:34.672	debug	(5526) sendMsg[1] >>> {"id":32,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:34.649	debug	(5526) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":31}
    mihome-vacuum.0	2020-05-28 10:31:34.644	debug	(5526) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589802735]}
    mihome-vacuum.0	2020-05-28 10:31:34.449	debug	(5526) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":30}
    mihome-vacuum.0	2020-05-28 10:31:34.444	debug	(5526) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589804616]}
    mihome-vacuum.0	2020-05-28 10:31:34.248	debug	(5526) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":29}
    mihome-vacuum.0	2020-05-28 10:31:34.243	debug	(5526) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589804656]}
    mihome-vacuum.0	2020-05-28 10:31:34.173	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":28}
    mihome-vacuum.0	2020-05-28 10:31:34.169	debug	(5526) 4. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:34.169	debug	(5526) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:34.049	debug	(5526) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":27}
    mihome-vacuum.0	2020-05-28 10:31:34.042	debug	(5526) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589804971]}
    mihome-vacuum.0	2020-05-28 10:31:33.866	debug	(5526) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":26}
    mihome-vacuum.0	2020-05-28 10:31:33.841	debug	(5526) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589805818]}
    mihome-vacuum.0	2020-05-28 10:31:33.668	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":25}
    mihome-vacuum.0	2020-05-28 10:31:33.664	debug	(5526) 3. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:33.664	debug	(5526) sendMsg[1] >>> {"id":25,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:33.645	debug	(5526) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":24}
    mihome-vacuum.0	2020-05-28 10:31:33.640	debug	(5526) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1589806003]}
    mihome-vacuum.0	2020-05-28 10:31:33.448	debug	(5526) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":23}
    mihome-vacuum.0	2020-05-28 10:31:33.440	debug	(5526) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589807338]}
    mihome-vacuum.0	2020-05-28 10:31:33.244	debug	(5526) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":22}
    mihome-vacuum.0	2020-05-28 10:31:33.239	debug	(5526) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589807988]}
    mihome-vacuum.0	2020-05-28 10:31:33.156	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":21}
    mihome-vacuum.0	2020-05-28 10:31:33.153	debug	(5526) 2. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:33.152	debug	(5526) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:33.044	debug	(5526) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":20}
    mihome-vacuum.0	2020-05-28 10:31:33.039	debug	(5526) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1589811051]}
    mihome-vacuum.0	2020-05-28 10:31:32.843	debug	(5526) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":19}
    mihome-vacuum.0	2020-05-28 10:31:32.838	debug	(5526) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589811788]}
    mihome-vacuum.0	2020-05-28 10:31:32.653	debug	(5526) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":18}
    mihome-vacuum.0	2020-05-28 10:31:32.652	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":17}
    mihome-vacuum.0	2020-05-28 10:31:32.637	debug	(5526) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589811799]}
    mihome-vacuum.0	2020-05-28 10:31:32.631	debug	(5526) 1. Mappointer_nomap___map_upload_handler
    mihome-vacuum.0	2020-05-28 10:31:32.631	debug	(5526) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:32.442	debug	(5526) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":16}
    mihome-vacuum.0	2020-05-28 10:31:32.437	debug	(5526) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1589811915]}
    mihome-vacuum.0	2020-05-28 10:31:32.241	debug	(5526) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":15}
    mihome-vacuum.0	2020-05-28 10:31:32.236	debug	(5526) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1589812855]}
    mihome-vacuum.0	2020-05-28 10:31:32.130	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":14}
    mihome-vacuum.0	2020-05-28 10:31:32.126	debug	(5526) 0. Mappointer_nomap___retry
    mihome-vacuum.0	2020-05-28 10:31:32.126	debug	(5526) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:32.040	debug	(5526) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":13}
    mihome-vacuum.0	2020-05-28 10:31:32.035	debug	(5526) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1589813020]}
    mihome-vacuum.0	2020-05-28 10:31:31.838	debug	(5526) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":12}
    mihome-vacuum.0	2020-05-28 10:31:31.834	debug	(5526) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590047127]}
    mihome-vacuum.0	2020-05-28 10:31:31.643	debug	(5526) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":11}
    mihome-vacuum.0	2020-05-28 10:31:31.633	debug	(5526) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1590159774]}
    mihome-vacuum.0	2020-05-28 10:31:31.625	debug	(5526) Receive <<< {"result":["retry"],"id":10}
    mihome-vacuum.0	2020-05-28 10:31:31.621	debug	(5526) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
    mihome-vacuum.0	2020-05-28 10:31:31.439	debug	(5526) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":9}
    mihome-vacuum.0	2020-05-28 10:31:31.432	debug	(5526) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590412996]}
    mihome-vacuum.0	2020-05-28 10:31:31.426	debug	(5526) Receive <<< {"result":"unknown_method","id":8}
    mihome-vacuum.0	2020-05-28 10:31:31.426	info	(5526) create state for carpet_mode
    mihome-vacuum.0	2020-05-28 10:31:31.426	debug	(5526) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
    mihome-vacuum.0	2020-05-28 10:31:31.421	debug	(5526) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-05-28 10:31:31.420	debug	(5526) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-05-28 10:31:31.236	debug	(5526) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":6}
    mihome-vacuum.0	2020-05-28 10:31:31.231	debug	(5526) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1590653494]}
    mihome-vacuum.0	2020-05-28 10:31:31.231	debug	(5526) Receive <<< {"result":[373752,5385070000,197,[1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,1589806003,158
    mihome-vacuum.0	2020-05-28 10:31:31.221	debug	(5526) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-05-28 10:31:31.028	debug	(5526) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":4}
    mihome-vacuum.0	2020-05-28 10:31:31.020	debug	(5526) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
    mihome-vacuum.0	2020-05-28 10:31:30.825	debug	(5526) Receive <<< {"result":[80],"id":3}
    mihome-vacuum.0	2020-05-28 10:31:30.821	debug	(5526) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-05-28 10:31:30.625	debug	(5526) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-60},"netif":{"l
    mihome-vacuum.0	2020-05-28 10:31:30.621	debug	(5526) Next WiFi check: 28.05 10:32
    mihome-vacuum.0	2020-05-28 10:31:30.621	debug	(5526) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
    mihome-vacuum.0	2020-05-28 10:31:30.420	info	(5526) Connected
    mihome-vacuum.0	2020-05-28 10:31:30.044	debug	(5526) TypeError: Cannot read property 'id' of undefined
    mihome-vacuum.0	2020-05-28 10:31:30.040	debug	(5526) 25175
    mihome-vacuum.0	2020-05-28 10:31:30.005	debug	(5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-05-28 10:31:30.004	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":766,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id
    mihome-vacuum.0	2020-05-28 10:31:29.991	debug	(5526) sendMsg[1] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-05-28 10:31:29.972	debug	(5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-05-28 10:31:29.972	info	(5526) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-05-28 10:31:29.971	debug	(5526) Receive <<< Helo <<< 213100200000000005c604885ecf76e0ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-05-28 10:31:29.769	info	(5526) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-05-28 10:31:29.302	debug	(5526) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    mihome-vacuum.0	2020-05-28 10:31:29.296	info	(5526) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-05-28 10:31:29.264	debug	(5526) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-05-28 10:31:29.260	info	(5526) Cloud control disabled
    mihome-vacuum.0	2020-05-28 10:31:29.259	info	(5526) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-05-28 10:31:29.255	debug	(5526) load Map creator... true
    mihome-vacuum.0	2020-05-28 10:31:29.233	info	(5526) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4
    mihome-vacuum.0	2020-05-28 10:31:28.865	debug	(5526) statesDB connected
    mihome-vacuum.0	2020-05-28 10:31:28.865	debug	(5526) States connected to redis: 127.0.0.1:9000
    mihome-vacuum.0	2020-05-28 10:31:28.861	debug	(5526) States create System PubSub Client
    mihome-vacuum.0	2020-05-28 10:31:28.860	debug	(5526) States create User PubSub Client
    mihome-vacuum.0	2020-05-28 10:31:28.856	debug	(5526) Redis States: Use Redis connection: 127.0.0.1:9000
    mihome-vacuum.0	2020-05-28 10:31:28.855	debug	(5526) objectDB connected
    mihome-vacuum.0	2020-05-28 10:31:28.853	debug	(5526) Objects connected to redis: 127.0.0.1:9001
    mihome-vacuum.0	2020-05-28 10:31:28.842	debug	(5526) Objects client initialize lua scripts
    mihome-vacuum.0	2020-05-28 10:31:28.841	debug	(5526) Objects create User PubSub Client
    mihome-vacuum.0	2020-05-28 10:31:28.841	debug	(5526) Objects create System PubSub Client
    mihome-vacuum.0	2020-05-28 10:31:28.840	debug	(5526) Objects client ready ... initialize now
    mihome-vacuum.0	2020-05-28 10:31:28.725	debug	(5526) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.IoBroker	2020-05-28 10:31:28.510	info	instance system.adapter.mihome-vacuum.0 started with pid 5526
    Bin über jede Hilfe dankbar.
    Gruß Daniel
    Coffeelover
    #864
    @seppel786 Hast du die Beiträge von Xenon (https://forum.iobroker.net/topic/30137/test-adapter-mihome-vacuum-v2-0-x/862) und mir darüber gesehen / getestet?
    • C Coffeelover
      seppel786
      schrieb am zuletzt editiert von seppel786
      #865
      @Coffeelover
      folgende Schritte habe ich durchlaufen lassen:
      sudo iobroker stop
      cd /opt/iobroker
      sudo apt update
      sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
      sudo npm install canvas --unsafe-perm=true
      Anbei noch ein kurzer Auszug der Konsole:
      Zusätzlich habe ich noch eine neue VM auf meinem NUC aufgesetzt um auszuschließen, dass in meiner produktiven Umgebung
      irgendetwas "krumm" ist oder beim Update auf nodejs 12 irgendwas in die Hose gegangen ist (wie teilweise auf GIT schon berichtet).
      Auf der Test-VM habe ich allerdings dasselbe verhalten.
      Anbei das Debuglog nach dem Update von Canvas:
      mihome-vacuum.0	2020-05-28 11:22:39.288	debug	(6826) sendMsg[3] >>> {"id":52,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:22:37.298	debug	(6826) sendMsg[2] >>> {"id":53,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:34.288	debug	(6826) sendMsg[2] >>> {"id":52,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:22:32.297	debug	(6826) 9. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:32.297	debug	(6826) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:31.796	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":51}
      mihome-vacuum.0	2020-05-28 11:22:31.792	debug	(6826) sendMsg[2] >>> {"id":51,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:29.287	debug	(6826) sendMsg[1] >>> {"id":52,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:22:26.791	debug	(6826) 8. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:26.791	debug	(6826) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:26.290	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":50}
      mihome-vacuum.0	2020-05-28 11:22:26.286	debug	(6826) 7. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:26.286	debug	(6826) sendMsg[1] >>> {"id":50,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:25.785	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":49}
      mihome-vacuum.0	2020-05-28 11:22:25.782	debug	(6826) 6. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:25.781	debug	(6826) sendMsg[1] >>> {"id":49,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:25.280	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":48}
      mihome-vacuum.0	2020-05-28 11:22:25.276	debug	(6826) 5. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:25.276	debug	(6826) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:24.775	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":47}
      mihome-vacuum.0	2020-05-28 11:22:24.771	debug	(6826) 4. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:24.771	debug	(6826) sendMsg[1] >>> {"id":47,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:24.271	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":46}
      mihome-vacuum.0	2020-05-28 11:22:24.267	debug	(6826) 3. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:24.267	debug	(6826) sendMsg[1] >>> {"id":46,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:23.766	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":45}
      mihome-vacuum.0	2020-05-28 11:22:23.762	debug	(6826) 2. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:23.762	debug	(6826) sendMsg[1] >>> {"id":45,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:23.261	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":44}
      mihome-vacuum.0	2020-05-28 11:22:23.257	debug	(6826) 1. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:23.257	debug	(6826) sendMsg[1] >>> {"id":44,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:22.756	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":43}
      mihome-vacuum.0	2020-05-28 11:22:22.752	debug	(6826) 0. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:22.752	debug	(6826) sendMsg[1] >>> {"id":43,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:22.252	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":42}
      mihome-vacuum.0	2020-05-28 11:22:22.248	debug	(6826) sendMsg[1] >>> {"id":42,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:22.247	debug	(6826) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1590657742246,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589621974319}
      mihome-vacuum.0	2020-05-28 11:22:16.971	warn	(6826) Could not receive Mappointer, giving up
      mihome-vacuum.0	2020-05-28 11:22:16.970	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":41}
      mihome-vacuum.0	2020-05-28 11:22:16.964	debug	(6826) 9. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:16.963	debug	(6826) sendMsg[1] >>> {"id":41,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:16.464	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":40}
      mihome-vacuum.0	2020-05-28 11:22:16.460	debug	(6826) 8. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:16.459	debug	(6826) sendMsg[1] >>> {"id":40,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:15.959	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":39}
      mihome-vacuum.0	2020-05-28 11:22:15.956	debug	(6826) 7. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:15.955	debug	(6826) sendMsg[1] >>> {"id":39,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:15.456	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":38}
      mihome-vacuum.0	2020-05-28 11:22:15.451	debug	(6826) 6. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:15.451	debug	(6826) sendMsg[1] >>> {"id":38,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:14.950	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":37}
      mihome-vacuum.0	2020-05-28 11:22:14.946	debug	(6826) 5. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:14.946	debug	(6826) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:14.445	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":36}
      mihome-vacuum.0	2020-05-28 11:22:14.441	debug	(6826) 4. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:14.441	debug	(6826) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:14.123	debug	(6826) CLEAN_LOGGING[{"Datum":"28.5","Start":"11:20","Saugzeit":"0 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"End
      mihome-vacuum.0	2020-05-28 11:22:13.953	debug	(6826) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":35}
      mihome-vacuum.0	2020-05-28 11:22:13.950	debug	(6826) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":34}
      mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":33}
      mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":32}
      mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":31}
      mihome-vacuum.0	2020-05-28 11:22:13.948	debug	(6826) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":30}
      mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":29}
      mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":28}
      mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":27}
      mihome-vacuum.0	2020-05-28 11:22:13.921	debug	(6826) sendMsg[1] >>> {"id":35,"method":"get_clean_record","params":[1589801327]}
      mihome-vacuum.0	2020-05-28 11:22:13.721	debug	(6826) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589802735]}
      mihome-vacuum.0	2020-05-28 11:22:13.520	debug	(6826) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589804616]}
      mihome-vacuum.0	2020-05-28 11:22:13.319	debug	(6826) sendMsg[1] >>> {"id":32,"method":"get_clean_record","params":[1589804656]}
      mihome-vacuum.0	2020-05-28 11:22:13.118	debug	(6826) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589804971]}
      mihome-vacuum.0	2020-05-28 11:22:12.917	debug	(6826) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589805818]}
      mihome-vacuum.0	2020-05-28 11:22:12.716	debug	(6826) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589806003]}
      mihome-vacuum.0	2020-05-28 11:22:12.518	debug	(6826) 3. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:12.518	debug	(6826) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:12.515	debug	(6826) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589807338]}
      mihome-vacuum.0	2020-05-28 11:22:12.319	debug	(6826) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":26}
      mihome-vacuum.0	2020-05-28 11:22:12.314	debug	(6826) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589807988]}
      mihome-vacuum.0	2020-05-28 11:22:12.118	debug	(6826) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":25}
      mihome-vacuum.0	2020-05-28 11:22:12.113	debug	(6826) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1589811051]}
      mihome-vacuum.0	2020-05-28 11:22:12.018	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":24}
      mihome-vacuum.0	2020-05-28 11:22:12.015	debug	(6826) 2. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:12.014	debug	(6826) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:11.916	debug	(6826) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":23}
      mihome-vacuum.0	2020-05-28 11:22:11.912	debug	(6826) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589811788]}
      mihome-vacuum.0	2020-05-28 11:22:11.716	debug	(6826) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":22}
      mihome-vacuum.0	2020-05-28 11:22:11.711	debug	(6826) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589811799]}
      mihome-vacuum.0	2020-05-28 11:22:11.515	debug	(6826) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":21}
      mihome-vacuum.0	2020-05-28 11:22:11.515	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":20}
      mihome-vacuum.0	2020-05-28 11:22:11.510	debug	(6826) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1589811915]}
      mihome-vacuum.0	2020-05-28 11:22:11.510	debug	(6826) 1. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:11.509	debug	(6826) sendMsg[1] >>> {"id":20,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:11.314	debug	(6826) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":19}
      mihome-vacuum.0	2020-05-28 11:22:11.309	debug	(6826) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589812855]}
      mihome-vacuum.0	2020-05-28 11:22:11.114	debug	(6826) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":18}
      mihome-vacuum.0	2020-05-28 11:22:11.109	debug	(6826) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589813020]}
      mihome-vacuum.0	2020-05-28 11:22:11.009	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":17}
      mihome-vacuum.0	2020-05-28 11:22:11.005	debug	(6826) 0. Mappointer_nomap___map_upload_handler
      mihome-vacuum.0	2020-05-28 11:22:11.004	debug	(6826) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:10.913	debug	(6826) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":16}
      mihome-vacuum.0	2020-05-28 11:22:10.909	debug	(6826) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1590047127]}
      mihome-vacuum.0	2020-05-28 11:22:10.713	debug	(6826) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":15}
      mihome-vacuum.0	2020-05-28 11:22:10.708	debug	(6826) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1590159774]}
      mihome-vacuum.0	2020-05-28 11:22:10.512	debug	(6826) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":14}
      mihome-vacuum.0	2020-05-28 11:22:10.507	debug	(6826) sendMsg[1] >>> {"id":14,"method":"get_clean_record","params":[1590412996]}
      mihome-vacuum.0	2020-05-28 11:22:10.504	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":13}
      mihome-vacuum.0	2020-05-28 11:22:10.497	debug	(6826) sendMsg[1] >>> {"id":13,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:22:10.313	debug	(6826) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":12}
      mihome-vacuum.0	2020-05-28 11:22:10.306	debug	(6826) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590653494]}
      mihome-vacuum.0	2020-05-28 11:22:10.304	debug	(6826) Receive <<< {"result":"unknown_method","id":11}
      mihome-vacuum.0	2020-05-28 11:22:10.304	info	(6826) create state for carpet_mode
      mihome-vacuum.0	2020-05-28 11:22:10.303	debug	(6826) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":10}
      mihome-vacuum.0	2020-05-28 11:22:10.297	debug	(6826) sendMsg[1] >>> {"id":11,"method":"get_room_mapping"}
      mihome-vacuum.0	2020-05-28 11:22:10.296	debug	(6826) sendMsg[1] >>> {"id":10,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-05-28 11:22:10.110	debug	(6826) Receive <<< {"result":[[1590657608,1590657628,0,122500,0,0]],"id":9}
      mihome-vacuum.0	2020-05-28 11:22:10.105	debug	(6826) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590657608]}
      mihome-vacuum.0	2020-05-28 11:22:10.105	debug	(6826) Receive <<< {"result":[373752,5385192500,198,[1590657608,1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,158
      mihome-vacuum.0	2020-05-28 11:22:10.097	debug	(6826) sendMsg[1] >>> {"id":8,"method":"get_clean_summary"}
      mihome-vacuum.0	2020-05-28 11:22:09.906	debug	(6826) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":7}
      mihome-vacuum.0	2020-05-28 11:22:09.897	debug	(6826) sendMsg[1] >>> {"id":7,"method":"get_consumable"}
      mihome-vacuum.0	2020-05-28 11:22:09.702	debug	(6826) Receive <<< {"result":[80],"id":6}
      mihome-vacuum.0	2020-05-28 11:22:09.696	debug	(6826) sendMsg[1] >>> {"id":6,"method":"get_sound_volume"}
      mihome-vacuum.0	2020-05-28 11:22:09.501	debug	(6826) Receive <<< {"partner_id":"","id":5,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-54},"netif":{"l
      mihome-vacuum.0	2020-05-28 11:22:09.497	debug	(6826) Next WiFi check: 28.05 11:23
      mihome-vacuum.0	2020-05-28 11:22:09.497	debug	(6826) sendMsg[1] >>> {"id":5,"method":"miIO.info"}
      mihome-vacuum.0	2020-05-28 11:22:09.296	info	(6826) Connected
      mihome-vacuum.0	2020-05-28 11:22:09.295	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:22:09.295	debug	(6826) Receive <<< {"result":[{"msg_ver":8,"msg_seq":958,"state":3,"battery":97,"clean_time":0,"clean_area":122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
      mihome-vacuum.0	2020-05-28 11:22:09.290	debug	(6826) sendMsg[1] >>> {"id":4,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:22:09.289	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:22:09.289	info	(6826) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-05-28 11:22:09.289	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf82c0ffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2020-05-28 11:22:04.293	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:22:04.292	debug	(6826) no answer for undefined(id:3) received, giving up
      mihome-vacuum.0	2020-05-28 11:22:01.402	debug	(6826) system.adapter.admin.0: logging true
      mihome-vacuum.0	2020-05-28 11:21:59.291	debug	(6826) sendMsg[3] >>> {"id":3,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:54.291	debug	(6826) sendMsg[2] >>> {"id":3,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:49.290	debug	(6826) sendMsg[1] >>> {"id":3,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:49.289	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:21:49.289	info	(6826) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-05-28 11:21:49.289	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf82acffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2020-05-28 11:21:44.291	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:21:44.291	debug	(6826) no answer for undefined(id:2) received, giving up
      mihome-vacuum.0	2020-05-28 11:21:43.674	debug	(6826) system.adapter.admin.0: logging false
      mihome-vacuum.0	2020-05-28 11:21:39.290	debug	(6826) sendMsg[3] >>> {"id":2,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:34.290	debug	(6826) sendMsg[2] >>> {"id":2,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:29.289	debug	(6826) sendMsg[1] >>> {"id":2,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:29.288	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:21:29.288	info	(6826) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-05-28 11:21:29.288	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf8298ffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2020-05-28 11:21:24.359	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:21:24.359	debug	(6826) no answer for undefined(id:1) received, giving up
      mihome-vacuum.0	2020-05-28 11:21:19.358	debug	(6826) sendMsg[3] >>> {"id":1,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:14.357	debug	(6826) sendMsg[2] >>> {"id":1,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:13.343	debug	(6826) system.adapter.admin.0: logging true
      mihome-vacuum.0	2020-05-28 11:21:12.509	debug	(6826) system.adapter.admin.0: logging false
      mihome-vacuum.0	2020-05-28 11:21:09.800	info	(6826) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-05-28 11:21:09.397	debug	(6826) TypeError: Cannot read property 'id' of undefined
      mihome-vacuum.0	2020-05-28 11:21:09.396	debug	(6826) 25616
      mihome-vacuum.0	2020-05-28 11:21:09.356	debug	(6826) sendMsg[1] >>> {"id":1,"method":"get_status"}
      mihome-vacuum.0	2020-05-28 11:21:09.340	debug	(6826) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      mihome-vacuum.0	2020-05-28 11:21:09.334	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-05-28 11:21:09.334	info	(6826) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-05-28 11:21:09.334	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf8284ffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2020-05-28 11:21:09.324	info	(6826) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-05-28 11:21:09.287	debug	(6826) server started on 0.0.0.0:53421
      mihome-vacuum.0	2020-05-28 11:21:09.282	info	(6826) Cloud control disabled
      mihome-vacuum.0	2020-05-28 11:21:09.281	info	(6826) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-05-28 11:21:09.277	debug	(6826) load Map creator... true
      mihome-vacuum.0	2020-05-28 11:21:09.258	info	(6826) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4
      mihome-vacuum.0	2020-05-28 11:21:08.765	debug	(6826) statesDB connected
      mihome-vacuum.0	2020-05-28 11:21:08.765	debug	(6826) States connected to redis: 127.0.0.1:9000
      mihome-vacuum.0	2020-05-28 11:21:08.761	debug	(6826) States create System PubSub Client
      mihome-vacuum.0	2020-05-28 11:21:08.760	debug	(6826) States create User PubSub Client
      mihome-vacuum.0	2020-05-28 11:21:08.751	debug	(6826) Redis States: Use Redis connection: 127.0.0.1:9000
      mihome-vacuum.0	2020-05-28 11:21:08.750	debug	(6826) objectDB connected
      mihome-vacuum.0	2020-05-28 11:21:08.748	debug	(6826) Objects connected to redis: 127.0.0.1:9001
      mihome-vacuum.0	2020-05-28 11:21:08.742	debug	(6826) Objects client initialize lua scripts
      mihome-vacuum.0	2020-05-28 11:21:08.741	debug	(6826) Objects create User PubSub Client
      mihome-vacuum.0	2020-05-28 11:21:08.741	debug	(6826) Objects create System PubSub Client
      mihome-vacuum.0	2020-05-28 11:21:08.740	debug	(6826) Objects client ready ... initialize now
      mihome-vacuum.0	2020-05-28 11:21:08.627	debug	(6826) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.IoBroker	2020-05-28 11:21:08.414	info	instance system.adapter.mihome-vacuum.0 started with pid 6826
      host.IoBroker	2020-05-28 11:21:08.406	info	"system.adapter.mihome-vacuum.0" enabled
      host.IoBroker	2020-05-28 11:21:06.950	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.IoBroker	2020-05-28 11:21:06.437	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
      mihome-vacuum.0	2020-05-28 11:21:06.439	info	(6811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      mihome-vacuum.0	2020-05-28 11:21:06.439	info	(6811) terminating
      mihome-vacuum.0	2020-05-28 11:21:06.438	info	(6811) Got terminate signal TERMINATE_YOURSELF
      host.IoBroker	2020-05-28 11:21:06.436	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
      host.IoBroker	2020-05-28 11:21:06.436	info	"system.adapter.mihome-vacuum.0" disabled
      mihome-vacuum.0	2020-05-28 11:21:04.528	debug	(6811) sendMsg[2] >>> {"id":8,"method":"get_map_v1"}
      mihome-vacuum.0	2020-05-28 11:21:04.331	debug	(6811) sendMsg[2] >>> {"id":7,"method":"get_room_mapping"}
      mihome-vacuum.0	2020-05-28 11:21:04.331	debug	(6811) sendMsg[2] >>> {"id":6,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-05-28 11:21:04.129	debug	(6811) sendMsg[2] >>> {"id":5,"method":"get_clean_summary"}
      Gruß Daniel aka Seppel
      • DiginixD Offline
        DiginixD Offline
        Diginix
        #866
        @seppel786 sagte in Test Adapter mihome-vacuum v2.0.x:
        Node.js: v12.16.3
        Adapter: 2.0.9
        Hilft jetzt sicher nicht viel, aber genau mit dieser Konstellation läuft bei mir alles. nodejs 12 ist also kein generelles Problem.
        Abweichend bei mir ist es das Modell 1S und Karte aus der Xiaomi Cloud.
        ..:: So long! Tom ::..
        • DiginixD Diginix
          Node.js: v12.16.3
          Adapter: 2.0.9
          seppel786
          #867
          @Diginix
          Spannende Kiste...Vlt liegt es auch am Zusammenspiel mit Valetudo?! Wäre jetzt interessant zu wissen,
          ob das bei jemand in der gleichen Konstellation läuft oder ob das Problem wieder vor dem Bildschirm sitzt :-)
          C 1 Antwort Letzte Antwort
          • S seppel786
            @Diginix
            Coffeelover
            #868
            @seppel786 Bei mir genau das Setting von @Diginix Auch ein 1S, auch Xiaomi Cloud.
            • C Coffeelover
              seppel786
              #869
              @All: Hat jemand ein ähnliches Setting wie ich, wo die Karte in Verbindung mit Valetudo funktioniert?
              @Meistertr
              Ist ein "Problem" mit Valetudo bekannt?!
              • D Nicht stören
                D Nicht stören
                dirkhe
                #870
                Bei den Karten kenne ich mich nicht so gut aus, aber kann es sein, dass man nicht auf die roborock App zurück darf, wenn man ioBroker nutzen möchte?
                • D dirkhe
                  #871
                  @dirkhe die Karte funktioniert anscheinend nur, wenn der Sauger über die mihome App registriert ist.
                  • B backfisch88
                    NEUE FIRMWARE DRAUSSEN
                    Fasse mal kurz grob zusammen, da die neue Firmware jetzt auch in miHome verfügbar ist
                    Adapter läuft
                    mehrkarten speicherung auch... Ortung der Stockwerke scheint auch ganz gut zu funktionieren
                    WAS NICHT MEHR GEHT
                    Da ich 3 Stockwerke besitze habe ich bisher das mit den Stockwerken folgendermassen gelöst:
                    Ich sag Siri: Reinige das Obergeschoss es wird ne Variable gesetzt, dass der Roboter sich im 1. OG befindet map reset durchgeführt und als neue Karte machen lassen
                    aufm Rückweg hab ich ihn auf Position 0 fahren lassen und die Karte wiederhergestellt (aufs Erdgeschoss)
                    Map reset hab ich noch nicht ausprobiert, aber eine Vorhandene Map widerherstellen lassen geht auf alle fälle nicht (zumindest nicht über den recover_map;[xxx] Befehl
                    ist auch egal, da er sich eh vor JEDEM saugen oder bewegen ortet
                    Was ich später mal ausprobiere was passiert, wenn ich Ihn im Keller aussetze und das als neue Karte laufen lasse (was er macht, wenn er nicht weiss wo er ist... was dann passiert, wenn man ihn wieder zurück setzt)
                    ansonsten scheint alles zu laufen... soweit
                    UPDATE: reset_map klappt auch nicht
                    radierer
                    #872
                    @backfisch88 said in Test Adapter mihome-vacuum v2.0.x:
                    Moin .. wie genau und wo hast du denn den Befehl "recover_map;[xxx]" ausgeführt?
                    • XenonX Xenon
                      @dirkhe
                      damit habe ich die Canvas Fehler beseitigt
                      sudo iobroker stop
                      cd /opt/iobroker
                      sudo apt update
                      Nun sieht mein LOG so aus
                      mihome-vacuum.1	2020-05-27 15:59:50.091	warn	(2838) This object will not be created in future versions. Please report this to the developer.
                      mihome-vacuum.1	2020-05-27 15:59:50.090	warn	(2838) Object mihome-vacuum.1.rooms.room2.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                      mihome-vacuum.1	2020-05-27 15:59:50.089	warn	(2838) This object will not be created in future versions. Please report this to the developer.
                      mihome-vacuum.1	2020-05-27 15:59:50.088	warn	(2838) Object mihome-vacuum.1.rooms.room1.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                      mihome-vacuum.1	2020-05-27 15:59:50.087	warn	(2838) This object will not be created in future versions. Please report this to the developer.
                      mihome-vacuum.1	2020-05-27 15:59:50.087	warn	(2838) Object mihome-vacuum.1.rooms.room17.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                      mihome-vacuum.1	2020-05-27 15:59:50.085	warn	(2838) This object will not be created in future versions. Please report this to the developer.
                      mihome-vacuum.1	2020-05-27 15:59:50.084	warn	(2838) Object mihome-vacuum.1.rooms.room16.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                      mihome-vacuum.1	2020-05-27 15:59:50.059	info	(2838) create new room: room2
                      mihome-vacuum.1	2020-05-27 15:59:50.058	info	(2838) create new room: room1
                      mihome-vacuum.1	2020-05-27 15:59:50.056	info	(2838) create new room: room17
                      mihome-vacuum.1	2020-05-27 15:59:50.054	info	(2838) create new room: room16
                      mihome-vacuum.1	2020-05-27 15:59:48.069	info	(2838) create states for water box filter
                      mihome-vacuum.1	2020-05-27 15:59:48.068	info	(2838) create states for water box
                      mihome-vacuum.0	2020-05-27 15:59:47.391	warn	(2580) This object will not be created in future versions. Please report this to the developer.
                      mihome-vacuum.0	2020-05-27 15:59:47.391	warn	(2580) Object mihome-vacuum.0.rooms.room2.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                      mihome-vacuum.0	2020-05-27 15:59:47.386	warn	(2580) This object will not be created in future versions. Please report this to the developer.
                      mihome-vacuum.0	2020-05-27 15:59:47.385	warn	(2580) Object mihome-vacuum.0.rooms.room1.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
                      mihome-vacuum.0	2020-05-27 15:59:47.374	info	(2580) create new room: room2
                      mihome-vacuum.0	2020-05-27 15:59:47.373	info	(2580) create new room: room1
                      mihome-vacuum.0	2020-05-27 15:59:45.304	info	(2580) create states for water box filter
                      mihome-vacuum.0	2020-05-27 15:59:45.303	info	(2580) create states for water box
                      D3ltoroxpD Offline
                      D3ltoroxpD Offline
                      D3ltoroxp
                      schrieb am zuletzt editiert von D3ltoroxp
                      #873
                      @Xenon said in Test Adapter mihome-vacuum v2.0.x:
                      @dirkhe
                      sudo iobroker stop
                      cd /opt/iobroker
                      sudo apt update
                      Ok, das scheint bei mir auch funktioniert zu haben. Leider scheint jetzt Port 80 belegt zu sein, den ich eigentlich für Alexa und Node.js benötige...
                      Kann das was mit dem Canvas Update zu tun haben oder mit dem hier ?
                      Ich hatte gleich noch upgrade mit gemacht, aber wenn sich bestehende SW updatet, ändert sich doch nicht einfach der Port oder ?
                      • D3ltoroxpD D3ltoroxp
                        @dirkhe
                        sudo iobroker stop
                        cd /opt/iobroker
                        sudo apt update
                        Jaschkopf
                        #874
                        Servus. Ich habe zwei Roborock S50 im Betrieb. Beide laufen über das selbe Xiaomi Konto auf dem Europa Server. Jedoch bekomme ich bei einem keine Karte geladen. Instanz 0 (Erdgeschoss) lädt sie einfach nicht. Bei Instanz 1 (Obergeschoss) klappt das wunderbar. Beide Roboter laufen mit stock Firmware 3.5.7_002008.
                        Das Update von canvas hab ich schon Probiert, hat jedoch nichts gebracht. Hat jemand eine Idee?
                        Gruß Jaschkopf
                        • R radierer
                          backfisch88
                          #875
                          @radierer
                          Genau so. Hatte bisher immer funktioniert.
                          J R 2 Antworten Letzte Antwort
                          • B backfisch88
                            @radierer
                            Jaschkopf
                            #876
                            @backfisch88 Habe das auch gerade mal probiert und bekomme im Log folgenden Fehler:
                            mihome-vacuum.0	2020-06-05 18:18:00.833	warn	(28716) Could not receive Mappointer, giving up
                            mihome-vacuum.0	2020-06-05 18:16:56.282	error	(28716) [69](X_send_command) -> response time out
                            mihome-vacuum.0	2020-06-05 18:16:52.783	info	(28716) send message: Method: recover_map Params: [1]
                            mihome-vacuum.0	2020-06-05 18:16:51.820	info	(28716) send message: Method: get_recover_maps
                            Jetzt hat er zwar die Karte geladen, diese wird aber nicht aktualisiert wenn der Roboter saugt. Hat jemand noch eine Idee?
                            Gruß Jaschkopf
                            • D Nicht stören
                              D Nicht stören
                              dirkhe
                              #877
                              Einmal in die mihome App einloggen und nen Moment warten
                              • B backfisch88
                                @radierer
                                radierer
                                #878
                                @radierer
                                Besten Dank! Funktioniert wie gewünscht .. 👍🏻🙂
                                • D dirkhe
                                  Jaschkopf
                                  #879
                                  @dirkhe Ein Traum jetzt klappt es. Vielen Dank 💪💪
                                  • R radierer
                                    @radierer
                                    backfisch88
                                    #880
                                    @radierer bei mir sagt er nur „unknown command“ 🤣
                                    R 1 Antwort Letzte Antwort
                                    • B backfisch88
                                      radierer
                                      #881
                                      Hm .. seltsam. Ich hab ja nix anderes gemacht .. außer zusätzlich noch den Befehl zum zurückfahren an die Ladestation.
                                      Evtl. mal den Haken bei "eigene Befehle zulassen" in der Adapterkonfig raus- und wieder reinmachen!?
                                      • D3ltoroxpD Offline
                                        D3ltoroxpD Offline
                                        D3ltoroxp
                                        #882
                                        Sagt mal, wie kann ich denn noch mal die Map anschauen ?
                                        Das war doch irgendwie so im Browser ?
                                        http://192.168.178.31/mihome-vacuum.admin/actualMap_0.png
                                        http://192.168.178.31:54321/mihome-vacuum.admin/actualMap_0.png
                                        Habs auch mit dem Standardport probiert, ging auch nicht. Es ging aber mal so, was fehlt hier noch ?
                                        D3ltoroxpD 1 Antwort Letzte Antwort
                                        • KnallochseK Nicht stören
                                          Knallochse
                                          schrieb am zuletzt editiert von Knallochse
                                          #883
                                          Habe heute gemerkt, das die Prozessorlast meiner Synonolgy DS918+ erhöht war.
                                          Ich habe mir dann die Prozesse im IoBroker Docker angeschaut und dabei festgestellt, dass die 2 Instanzen des mihome-vacuum Adapters (2 Stück MiVacuum 1) die meiste Last (aller Adapter) beanspruchen. Ich hatte die Version vor 3 Tagen von 1.10.5 auf 2.0.9 angehoben. Nach einem Restart der Instanzen hat sich die Prozesslast wieder deutlich beruhigt.
                                          Mein System :
                                          Docker auf Syn918+
                                          Admin 4.0.9
                                          JS Controller 3.1.4
                                          Node.js 10.20.1
                                          Falls es weiter Informationen braucht, bitte melden.
                                          Ich beobachte es auf jeden Fall weiter.
                                          Edit: Habe gerade mal die Datenaufzeichnung der Prozessorlast meiner Synology DS918+ in Grafana angeschaut, und habe festgestellt das die Instanz des Saugers, welcher heute morgen seine Arbeit verrichtete, mit start des Saugvorgangs eine deutlich erhöhte Last verursachte, und dass ganze dann auf diesen Niveau blieb (auch nach Ende des Saugvorgangs bis zum Neustart der Instanz)
                                          Edit2: gerade hat ein Zeitgesteuerter Saugvorgang stattgefunden. Danach das gleiche Problem mit der ansteigenden Prozesslast.
                                          Ich hatte Log auf Debug gestellt, es kamen aber keine auffälligen Meldungen
