Test Adapter mihome-vacuum v2.0.x
Hi zusammen,
ich bekomme die Karte ebenso nicht in den Objekten angezeigt.
JS-Controller: 3.1.4
Node.js: v12.16.3
Adapter: 2.0.9
Valetudo: 0.4
FW: 3.3.9_003468 - rockrobo.vacuum.v1Anbei das Debuglog:
mihome-vacuum.0 2020-05-28 10:32:09.274 debug (5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":768,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id" mihome-vacuum.0 2020-05-28 10:32:09.265 debug (5526) sendMsg[1] >>> {"id":40,"method":"get_status"} mihome-vacuum.0 2020-05-28 10:31:49.269 debug (5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":767,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id" mihome-vacuum.0 2020-05-28 10:31:49.263 debug (5526) sendMsg[1] >>> {"id":39,"method":"get_status"} mihome-vacuum.0 2020-05-28 10:31:36.702 warn (5526) Could not receive Mappointer, giving up mihome-vacuum.0 2020-05-28 10:31:36.702 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":38} mihome-vacuum.0 2020-05-28 10:31:36.698 debug (5526) 9. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:36.697 debug (5526) sendMsg[1] >>> {"id":38,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:36.197 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":37} mihome-vacuum.0 2020-05-28 10:31:36.190 debug (5526) 8. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:36.190 debug (5526) sendMsg[1] >>> {"id":37,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:35.689 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":36} mihome-vacuum.0 2020-05-28 10:31:35.681 debug (5526) 7. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:35.681 debug (5526) sendMsg[1] >>> {"id":36,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:35.246 debug (5526) CLEAN_LOGGING[{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"Ende":false},{"Datum":"25.5","Start":"15:23","Saugzeit":"0 min","Fläche":"0.75 m²","Error":0,"Ende mihome-vacuum.0 2020-05-28 10:31:35.181 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":35} mihome-vacuum.0 2020-05-28 10:31:35.177 debug (5526) 6. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:35.177 debug (5526) sendMsg[1] >>> {"id":35,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:35.050 debug (5526) Receive <<< {"result":[[1589796884,1589796954,0,1200000,0,0]],"id":34} mihome-vacuum.0 2020-05-28 10:31:35.045 debug (5526) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589796884]} mihome-vacuum.0 2020-05-28 10:31:34.850 debug (5526) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":33} mihome-vacuum.0 2020-05-28 10:31:34.845 debug (5526) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589801327]} mihome-vacuum.0 2020-05-28 10:31:34.676 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":32} mihome-vacuum.0 2020-05-28 10:31:34.673 debug (5526) 5. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:34.672 debug (5526) sendMsg[1] >>> {"id":32,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:34.649 debug (5526) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":31} mihome-vacuum.0 2020-05-28 10:31:34.644 debug (5526) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589802735]} mihome-vacuum.0 2020-05-28 10:31:34.449 debug (5526) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":30} mihome-vacuum.0 2020-05-28 10:31:34.444 debug (5526) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589804616]} mihome-vacuum.0 2020-05-28 10:31:34.248 debug (5526) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":29} mihome-vacuum.0 2020-05-28 10:31:34.243 debug (5526) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589804656]} mihome-vacuum.0 2020-05-28 10:31:34.173 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":28} mihome-vacuum.0 2020-05-28 10:31:34.169 debug (5526) 4. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:34.169 debug (5526) sendMsg[1] >>> {"id":28,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:34.049 debug (5526) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":27} mihome-vacuum.0 2020-05-28 10:31:34.042 debug (5526) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589804971]} mihome-vacuum.0 2020-05-28 10:31:33.866 debug (5526) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":26} mihome-vacuum.0 2020-05-28 10:31:33.841 debug (5526) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589805818]} mihome-vacuum.0 2020-05-28 10:31:33.668 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":25} mihome-vacuum.0 2020-05-28 10:31:33.664 debug (5526) 3. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:33.664 debug (5526) sendMsg[1] >>> {"id":25,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:33.645 debug (5526) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":24} mihome-vacuum.0 2020-05-28 10:31:33.640 debug (5526) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1589806003]} mihome-vacuum.0 2020-05-28 10:31:33.448 debug (5526) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":23} mihome-vacuum.0 2020-05-28 10:31:33.440 debug (5526) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589807338]} mihome-vacuum.0 2020-05-28 10:31:33.244 debug (5526) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":22} mihome-vacuum.0 2020-05-28 10:31:33.239 debug (5526) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589807988]} mihome-vacuum.0 2020-05-28 10:31:33.156 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":21} mihome-vacuum.0 2020-05-28 10:31:33.153 debug (5526) 2. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:33.152 debug (5526) sendMsg[1] >>> {"id":21,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:33.044 debug (5526) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":20} mihome-vacuum.0 2020-05-28 10:31:33.039 debug (5526) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1589811051]} mihome-vacuum.0 2020-05-28 10:31:32.843 debug (5526) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":19} mihome-vacuum.0 2020-05-28 10:31:32.838 debug (5526) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589811788]} mihome-vacuum.0 2020-05-28 10:31:32.653 debug (5526) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":18} mihome-vacuum.0 2020-05-28 10:31:32.652 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":17} mihome-vacuum.0 2020-05-28 10:31:32.637 debug (5526) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589811799]} mihome-vacuum.0 2020-05-28 10:31:32.631 debug (5526) 1. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 10:31:32.631 debug (5526) sendMsg[1] >>> {"id":17,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:32.442 debug (5526) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":16} mihome-vacuum.0 2020-05-28 10:31:32.437 debug (5526) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1589811915]} mihome-vacuum.0 2020-05-28 10:31:32.241 debug (5526) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":15} mihome-vacuum.0 2020-05-28 10:31:32.236 debug (5526) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1589812855]} mihome-vacuum.0 2020-05-28 10:31:32.130 debug (5526) Receive <<< {"result":["map_upload_handler"],"id":14} mihome-vacuum.0 2020-05-28 10:31:32.126 debug (5526) 0. Mappointer_nomap___retry mihome-vacuum.0 2020-05-28 10:31:32.126 debug (5526) sendMsg[1] >>> {"id":14,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:32.040 debug (5526) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":13} mihome-vacuum.0 2020-05-28 10:31:32.035 debug (5526) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1589813020]} mihome-vacuum.0 2020-05-28 10:31:31.838 debug (5526) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":12} mihome-vacuum.0 2020-05-28 10:31:31.834 debug (5526) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590047127]} mihome-vacuum.0 2020-05-28 10:31:31.643 debug (5526) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":11} mihome-vacuum.0 2020-05-28 10:31:31.633 debug (5526) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1590159774]} mihome-vacuum.0 2020-05-28 10:31:31.625 debug (5526) Receive <<< {"result":["retry"],"id":10} mihome-vacuum.0 2020-05-28 10:31:31.621 debug (5526) sendMsg[1] >>> {"id":10,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 10:31:31.439 debug (5526) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":9} mihome-vacuum.0 2020-05-28 10:31:31.432 debug (5526) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590412996]} mihome-vacuum.0 2020-05-28 10:31:31.426 debug (5526) Receive <<< {"result":"unknown_method","id":8} mihome-vacuum.0 2020-05-28 10:31:31.426 info (5526) create state for carpet_mode mihome-vacuum.0 2020-05-28 10:31:31.426 debug (5526) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7} mihome-vacuum.0 2020-05-28 10:31:31.421 debug (5526) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"} mihome-vacuum.0 2020-05-28 10:31:31.420 debug (5526) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"} mihome-vacuum.0 2020-05-28 10:31:31.236 debug (5526) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":6} mihome-vacuum.0 2020-05-28 10:31:31.231 debug (5526) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1590653494]} mihome-vacuum.0 2020-05-28 10:31:31.231 debug (5526) Receive <<< {"result":[373752,5385070000,197,[1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,1589806003,158 mihome-vacuum.0 2020-05-28 10:31:31.221 debug (5526) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"} mihome-vacuum.0 2020-05-28 10:31:31.028 debug (5526) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":4} mihome-vacuum.0 2020-05-28 10:31:31.020 debug (5526) sendMsg[1] >>> {"id":4,"method":"get_consumable"} mihome-vacuum.0 2020-05-28 10:31:30.825 debug (5526) Receive <<< {"result":[80],"id":3} mihome-vacuum.0 2020-05-28 10:31:30.821 debug (5526) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"} mihome-vacuum.0 2020-05-28 10:31:30.625 debug (5526) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-60},"netif":{"l mihome-vacuum.0 2020-05-28 10:31:30.621 debug (5526) Next WiFi check: 28.05 10:32 mihome-vacuum.0 2020-05-28 10:31:30.621 debug (5526) sendMsg[1] >>> {"id":2,"method":"miIO.info"} mihome-vacuum.0 2020-05-28 10:31:30.420 info (5526) Connected mihome-vacuum.0 2020-05-28 10:31:30.044 debug (5526) TypeError: Cannot read property 'id' of undefined mihome-vacuum.0 2020-05-28 10:31:30.040 debug (5526) 25175 mihome-vacuum.0 2020-05-28 10:31:30.005 debug (5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 10:31:30.004 debug (5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":766,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id mihome-vacuum.0 2020-05-28 10:31:29.991 debug (5526) sendMsg[1] >>> {"id":1,"method":"get_status"} mihome-vacuum.0 2020-05-28 10:31:29.972 debug (5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 10:31:29.972 info (5526) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-05-28 10:31:29.971 debug (5526) Receive <<< Helo <<< 213100200000000005c604885ecf76e0ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-05-28 10:31:29.769 info (5526) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-05-28 10:31:29.302 debug (5526) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } mihome-vacuum.0 2020-05-28 10:31:29.296 info (5526) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean mihome-vacuum.0 2020-05-28 10:31:29.264 debug (5526) server started on 0.0.0.0:53421 mihome-vacuum.0 2020-05-28 10:31:29.260 info (5526) Cloud control disabled mihome-vacuum.0 2020-05-28 10:31:29.259 info (5526) Expert mode disabled, states deleted mihome-vacuum.0 2020-05-28 10:31:29.255 debug (5526) load Map creator... true mihome-vacuum.0 2020-05-28 10:31:29.233 info (5526) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4 mihome-vacuum.0 2020-05-28 10:31:28.865 debug (5526) statesDB connected mihome-vacuum.0 2020-05-28 10:31:28.865 debug (5526) States connected to redis: 127.0.0.1:9000 mihome-vacuum.0 2020-05-28 10:31:28.861 debug (5526) States create System PubSub Client mihome-vacuum.0 2020-05-28 10:31:28.860 debug (5526) States create User PubSub Client mihome-vacuum.0 2020-05-28 10:31:28.856 debug (5526) Redis States: Use Redis connection: 127.0.0.1:9000 mihome-vacuum.0 2020-05-28 10:31:28.855 debug (5526) objectDB connected mihome-vacuum.0 2020-05-28 10:31:28.853 debug (5526) Objects connected to redis: 127.0.0.1:9001 mihome-vacuum.0 2020-05-28 10:31:28.842 debug (5526) Objects client initialize lua scripts mihome-vacuum.0 2020-05-28 10:31:28.841 debug (5526) Objects create User PubSub Client mihome-vacuum.0 2020-05-28 10:31:28.841 debug (5526) Objects create System PubSub Client mihome-vacuum.0 2020-05-28 10:31:28.840 debug (5526) Objects client ready ... initialize now mihome-vacuum.0 2020-05-28 10:31:28.725 debug (5526) Redis Objects: Use Redis connection: 127.0.0.1:9001 host.IoBroker 2020-05-28 10:31:28.510 info instance system.adapter.mihome-vacuum.0 started with pid 5526 mihome-vacuum.0 2020-05-28 10:31:31.643 debug (5526) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":11} mihome-vacuum.0 2020-05-28 10:31:31.633 debug (5526) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1590159774]} mihome-vacuum.0 2020-05-28 10:31:31.625 debug (5526) Receive <<< {"result":["retry"],"id":10} mihome-vacuum.0 2020-05-28 10:31:31.621 debug (5526) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}Bin über jede Hilfe dankbar.
Gruß Daniel
Hi zusammen,
Node.js: v12.16.3
Adapter: 2.0.9
Valetudo: 0.4
Gruß Daniel
@seppel786 Hast du die Beiträge von Xenon (https://forum.iobroker.net/topic/30137/test-adapter-mihome-vacuum-v2-0-x/862) und mir darüber gesehen / getestet?
folgende Schritte habe ich durchlaufen lassen:
sudo iobroker stop cd /opt/iobroker sudo apt update sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev sudo npm install canvas --unsafe-perm=trueAnbei noch ein kurzer Auszug der Konsole:
Zusätzlich habe ich noch eine neue VM auf meinem NUC aufgesetzt um auszuschließen, dass in meiner produktiven Umgebung
irgendetwas "krumm" ist oder beim Update auf nodejs 12 irgendwas in die Hose gegangen ist (wie teilweise auf GIT schon berichtet).
Auf der Test-VM habe ich allerdings dasselbe verhalten.Anbei das Debuglog nach dem Update von Canvas:
mihome-vacuum.0 2020-05-28 11:22:39.288 debug (6826) sendMsg[3] >>> {"id":52,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:22:37.298 debug (6826) sendMsg[2] >>> {"id":53,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:34.288 debug (6826) sendMsg[2] >>> {"id":52,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:22:32.297 debug (6826) 9. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:32.297 debug (6826) sendMsg[1] >>> {"id":53,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:31.796 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":51} mihome-vacuum.0 2020-05-28 11:22:31.792 debug (6826) sendMsg[2] >>> {"id":51,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:29.287 debug (6826) sendMsg[1] >>> {"id":52,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:22:26.791 debug (6826) 8. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:26.791 debug (6826) sendMsg[1] >>> {"id":51,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:26.290 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":50} mihome-vacuum.0 2020-05-28 11:22:26.286 debug (6826) 7. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:26.286 debug (6826) sendMsg[1] >>> {"id":50,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:25.785 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":49} mihome-vacuum.0 2020-05-28 11:22:25.782 debug (6826) 6. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:25.781 debug (6826) sendMsg[1] >>> {"id":49,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:25.280 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":48} mihome-vacuum.0 2020-05-28 11:22:25.276 debug (6826) 5. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:25.276 debug (6826) sendMsg[1] >>> {"id":48,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:24.775 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":47} mihome-vacuum.0 2020-05-28 11:22:24.771 debug (6826) 4. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:24.771 debug (6826) sendMsg[1] >>> {"id":47,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:24.271 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":46} mihome-vacuum.0 2020-05-28 11:22:24.267 debug (6826) 3. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:24.267 debug (6826) sendMsg[1] >>> {"id":46,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:23.766 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":45} mihome-vacuum.0 2020-05-28 11:22:23.762 debug (6826) 2. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:23.762 debug (6826) sendMsg[1] >>> {"id":45,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:23.261 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":44} mihome-vacuum.0 2020-05-28 11:22:23.257 debug (6826) 1. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:23.257 debug (6826) sendMsg[1] >>> {"id":44,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:22.756 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":43} mihome-vacuum.0 2020-05-28 11:22:22.752 debug (6826) 0. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:22.752 debug (6826) sendMsg[1] >>> {"id":43,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:22.252 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":42} mihome-vacuum.0 2020-05-28 11:22:22.248 debug (6826) sendMsg[1] >>> {"id":42,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:22.247 debug (6826) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1590657742246,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589621974319} mihome-vacuum.0 2020-05-28 11:22:16.971 warn (6826) Could not receive Mappointer, giving up mihome-vacuum.0 2020-05-28 11:22:16.970 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":41} mihome-vacuum.0 2020-05-28 11:22:16.964 debug (6826) 9. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:16.963 debug (6826) sendMsg[1] >>> {"id":41,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:16.464 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":40} mihome-vacuum.0 2020-05-28 11:22:16.460 debug (6826) 8. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:16.459 debug (6826) sendMsg[1] >>> {"id":40,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:15.959 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":39} mihome-vacuum.0 2020-05-28 11:22:15.956 debug (6826) 7. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:15.955 debug (6826) sendMsg[1] >>> {"id":39,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:15.456 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":38} mihome-vacuum.0 2020-05-28 11:22:15.451 debug (6826) 6. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:15.451 debug (6826) sendMsg[1] >>> {"id":38,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:14.950 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":37} mihome-vacuum.0 2020-05-28 11:22:14.946 debug (6826) 5. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:14.946 debug (6826) sendMsg[1] >>> {"id":37,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:14.445 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":36} mihome-vacuum.0 2020-05-28 11:22:14.441 debug (6826) 4. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:14.441 debug (6826) sendMsg[1] >>> {"id":36,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:14.123 debug (6826) CLEAN_LOGGING[{"Datum":"28.5","Start":"11:20","Saugzeit":"0 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"End mihome-vacuum.0 2020-05-28 11:22:13.953 debug (6826) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":35} mihome-vacuum.0 2020-05-28 11:22:13.950 debug (6826) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":34} mihome-vacuum.0 2020-05-28 11:22:13.949 debug (6826) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":33} mihome-vacuum.0 2020-05-28 11:22:13.949 debug (6826) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":32} mihome-vacuum.0 2020-05-28 11:22:13.949 debug (6826) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":31} mihome-vacuum.0 2020-05-28 11:22:13.948 debug (6826) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":30} mihome-vacuum.0 2020-05-28 11:22:13.940 debug (6826) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":29} mihome-vacuum.0 2020-05-28 11:22:13.940 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":28} mihome-vacuum.0 2020-05-28 11:22:13.940 debug (6826) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":27} mihome-vacuum.0 2020-05-28 11:22:13.921 debug (6826) sendMsg[1] >>> {"id":35,"method":"get_clean_record","params":[1589801327]} mihome-vacuum.0 2020-05-28 11:22:13.721 debug (6826) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589802735]} mihome-vacuum.0 2020-05-28 11:22:13.520 debug (6826) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589804616]} mihome-vacuum.0 2020-05-28 11:22:13.319 debug (6826) sendMsg[1] >>> {"id":32,"method":"get_clean_record","params":[1589804656]} mihome-vacuum.0 2020-05-28 11:22:13.118 debug (6826) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589804971]} mihome-vacuum.0 2020-05-28 11:22:12.917 debug (6826) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589805818]} mihome-vacuum.0 2020-05-28 11:22:12.716 debug (6826) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589806003]} mihome-vacuum.0 2020-05-28 11:22:12.518 debug (6826) 3. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:12.518 debug (6826) sendMsg[1] >>> {"id":28,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:12.515 debug (6826) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589807338]} mihome-vacuum.0 2020-05-28 11:22:12.319 debug (6826) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":26} mihome-vacuum.0 2020-05-28 11:22:12.314 debug (6826) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589807988]} mihome-vacuum.0 2020-05-28 11:22:12.118 debug (6826) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":25} mihome-vacuum.0 2020-05-28 11:22:12.113 debug (6826) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1589811051]} mihome-vacuum.0 2020-05-28 11:22:12.018 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":24} mihome-vacuum.0 2020-05-28 11:22:12.015 debug (6826) 2. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:12.014 debug (6826) sendMsg[1] >>> {"id":24,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:11.916 debug (6826) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":23} mihome-vacuum.0 2020-05-28 11:22:11.912 debug (6826) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589811788]} mihome-vacuum.0 2020-05-28 11:22:11.716 debug (6826) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":22} mihome-vacuum.0 2020-05-28 11:22:11.711 debug (6826) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589811799]} mihome-vacuum.0 2020-05-28 11:22:11.515 debug (6826) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":21} mihome-vacuum.0 2020-05-28 11:22:11.515 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":20} mihome-vacuum.0 2020-05-28 11:22:11.510 debug (6826) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1589811915]} mihome-vacuum.0 2020-05-28 11:22:11.510 debug (6826) 1. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:11.509 debug (6826) sendMsg[1] >>> {"id":20,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:11.314 debug (6826) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":19} mihome-vacuum.0 2020-05-28 11:22:11.309 debug (6826) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589812855]} mihome-vacuum.0 2020-05-28 11:22:11.114 debug (6826) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":18} mihome-vacuum.0 2020-05-28 11:22:11.109 debug (6826) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589813020]} mihome-vacuum.0 2020-05-28 11:22:11.009 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":17} mihome-vacuum.0 2020-05-28 11:22:11.005 debug (6826) 0. Mappointer_nomap___map_upload_handler mihome-vacuum.0 2020-05-28 11:22:11.004 debug (6826) sendMsg[1] >>> {"id":17,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:10.913 debug (6826) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":16} mihome-vacuum.0 2020-05-28 11:22:10.909 debug (6826) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1590047127]} mihome-vacuum.0 2020-05-28 11:22:10.713 debug (6826) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":15} mihome-vacuum.0 2020-05-28 11:22:10.708 debug (6826) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1590159774]} mihome-vacuum.0 2020-05-28 11:22:10.512 debug (6826) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":14} mihome-vacuum.0 2020-05-28 11:22:10.507 debug (6826) sendMsg[1] >>> {"id":14,"method":"get_clean_record","params":[1590412996]} mihome-vacuum.0 2020-05-28 11:22:10.504 debug (6826) Receive <<< {"result":["map_upload_handler"],"id":13} mihome-vacuum.0 2020-05-28 11:22:10.497 debug (6826) sendMsg[1] >>> {"id":13,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:22:10.313 debug (6826) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":12} mihome-vacuum.0 2020-05-28 11:22:10.306 debug (6826) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590653494]} mihome-vacuum.0 2020-05-28 11:22:10.304 debug (6826) Receive <<< {"result":"unknown_method","id":11} mihome-vacuum.0 2020-05-28 11:22:10.304 info (6826) create state for carpet_mode mihome-vacuum.0 2020-05-28 11:22:10.303 debug (6826) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":10} mihome-vacuum.0 2020-05-28 11:22:10.297 debug (6826) sendMsg[1] >>> {"id":11,"method":"get_room_mapping"} mihome-vacuum.0 2020-05-28 11:22:10.296 debug (6826) sendMsg[1] >>> {"id":10,"method":"get_carpet_mode"} mihome-vacuum.0 2020-05-28 11:22:10.110 debug (6826) Receive <<< {"result":[[1590657608,1590657628,0,122500,0,0]],"id":9} mihome-vacuum.0 2020-05-28 11:22:10.105 debug (6826) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590657608]} mihome-vacuum.0 2020-05-28 11:22:10.105 debug (6826) Receive <<< {"result":[373752,5385192500,198,[1590657608,1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,158 mihome-vacuum.0 2020-05-28 11:22:10.097 debug (6826) sendMsg[1] >>> {"id":8,"method":"get_clean_summary"} mihome-vacuum.0 2020-05-28 11:22:09.906 debug (6826) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":7} mihome-vacuum.0 2020-05-28 11:22:09.897 debug (6826) sendMsg[1] >>> {"id":7,"method":"get_consumable"} mihome-vacuum.0 2020-05-28 11:22:09.702 debug (6826) Receive <<< {"result":[80],"id":6} mihome-vacuum.0 2020-05-28 11:22:09.696 debug (6826) sendMsg[1] >>> {"id":6,"method":"get_sound_volume"} mihome-vacuum.0 2020-05-28 11:22:09.501 debug (6826) Receive <<< {"partner_id":"","id":5,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-54},"netif":{"l mihome-vacuum.0 2020-05-28 11:22:09.497 debug (6826) Next WiFi check: 28.05 11:23 mihome-vacuum.0 2020-05-28 11:22:09.497 debug (6826) sendMsg[1] >>> {"id":5,"method":"miIO.info"} mihome-vacuum.0 2020-05-28 11:22:09.296 info (6826) Connected mihome-vacuum.0 2020-05-28 11:22:09.295 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:22:09.295 debug (6826) Receive <<< {"result":[{"msg_ver":8,"msg_seq":958,"state":3,"battery":97,"clean_time":0,"clean_area":122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id" mihome-vacuum.0 2020-05-28 11:22:09.290 debug (6826) sendMsg[1] >>> {"id":4,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:22:09.289 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:22:09.289 info (6826) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-05-28 11:22:09.289 debug (6826) Receive <<< Helo <<< 213100200000000005c604885ecf82c0ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-05-28 11:22:04.293 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:22:04.292 debug (6826) no answer for undefined(id:3) received, giving up mihome-vacuum.0 2020-05-28 11:22:01.402 debug (6826) system.adapter.admin.0: logging true mihome-vacuum.0 2020-05-28 11:21:59.291 debug (6826) sendMsg[3] >>> {"id":3,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:54.291 debug (6826) sendMsg[2] >>> {"id":3,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:49.290 debug (6826) sendMsg[1] >>> {"id":3,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:49.289 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:21:49.289 info (6826) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-05-28 11:21:49.289 debug (6826) Receive <<< Helo <<< 213100200000000005c604885ecf82acffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-05-28 11:21:44.291 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:21:44.291 debug (6826) no answer for undefined(id:2) received, giving up mihome-vacuum.0 2020-05-28 11:21:43.674 debug (6826) system.adapter.admin.0: logging false mihome-vacuum.0 2020-05-28 11:21:39.290 debug (6826) sendMsg[3] >>> {"id":2,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:34.290 debug (6826) sendMsg[2] >>> {"id":2,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:29.289 debug (6826) sendMsg[1] >>> {"id":2,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:29.288 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:21:29.288 info (6826) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-05-28 11:21:29.288 debug (6826) Receive <<< Helo <<< 213100200000000005c604885ecf8298ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-05-28 11:21:24.359 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:21:24.359 debug (6826) no answer for undefined(id:1) received, giving up mihome-vacuum.0 2020-05-28 11:21:19.358 debug (6826) sendMsg[3] >>> {"id":1,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:14.357 debug (6826) sendMsg[2] >>> {"id":1,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:13.343 debug (6826) system.adapter.admin.0: logging true mihome-vacuum.0 2020-05-28 11:21:12.509 debug (6826) system.adapter.admin.0: logging false mihome-vacuum.0 2020-05-28 11:21:09.800 info (6826) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-05-28 11:21:09.397 debug (6826) TypeError: Cannot read property 'id' of undefined mihome-vacuum.0 2020-05-28 11:21:09.396 debug (6826) 25616 mihome-vacuum.0 2020-05-28 11:21:09.356 debug (6826) sendMsg[1] >>> {"id":1,"method":"get_status"} mihome-vacuum.0 2020-05-28 11:21:09.340 debug (6826) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) } mihome-vacuum.0 2020-05-28 11:21:09.334 debug (6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-05-28 11:21:09.334 info (6826) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-05-28 11:21:09.334 debug (6826) Receive <<< Helo <<< 213100200000000005c604885ecf8284ffffffffffffffffffffffffffffffff mihome-vacuum.0 2020-05-28 11:21:09.324 info (6826) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean mihome-vacuum.0 2020-05-28 11:21:09.287 debug (6826) server started on 0.0.0.0:53421 mihome-vacuum.0 2020-05-28 11:21:09.282 info (6826) Cloud control disabled mihome-vacuum.0 2020-05-28 11:21:09.281 info (6826) Expert mode disabled, states deleted mihome-vacuum.0 2020-05-28 11:21:09.277 debug (6826) load Map creator... true mihome-vacuum.0 2020-05-28 11:21:09.258 info (6826) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4 mihome-vacuum.0 2020-05-28 11:21:08.765 debug (6826) statesDB connected mihome-vacuum.0 2020-05-28 11:21:08.765 debug (6826) States connected to redis: 127.0.0.1:9000 mihome-vacuum.0 2020-05-28 11:21:08.761 debug (6826) States create System PubSub Client mihome-vacuum.0 2020-05-28 11:21:08.760 debug (6826) States create User PubSub Client mihome-vacuum.0 2020-05-28 11:21:08.751 debug (6826) Redis States: Use Redis connection: 127.0.0.1:9000 mihome-vacuum.0 2020-05-28 11:21:08.750 debug (6826) objectDB connected mihome-vacuum.0 2020-05-28 11:21:08.748 debug (6826) Objects connected to redis: 127.0.0.1:9001 mihome-vacuum.0 2020-05-28 11:21:08.742 debug (6826) Objects client initialize lua scripts mihome-vacuum.0 2020-05-28 11:21:08.741 debug (6826) Objects create User PubSub Client mihome-vacuum.0 2020-05-28 11:21:08.741 debug (6826) Objects create System PubSub Client mihome-vacuum.0 2020-05-28 11:21:08.740 debug (6826) Objects client ready ... initialize now mihome-vacuum.0 2020-05-28 11:21:08.627 debug (6826) Redis Objects: Use Redis connection: 127.0.0.1:9001 host.IoBroker 2020-05-28 11:21:08.414 info instance system.adapter.mihome-vacuum.0 started with pid 6826 host.IoBroker 2020-05-28 11:21:08.406 info "system.adapter.mihome-vacuum.0" enabled host.IoBroker 2020-05-28 11:21:06.950 info instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) host.IoBroker 2020-05-28 11:21:06.437 info stopInstance system.adapter.mihome-vacuum.0 send kill signal mihome-vacuum.0 2020-05-28 11:21:06.439 info (6811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason mihome-vacuum.0 2020-05-28 11:21:06.439 info (6811) terminating mihome-vacuum.0 2020-05-28 11:21:06.438 info (6811) Got terminate signal TERMINATE_YOURSELF host.IoBroker 2020-05-28 11:21:06.436 info stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true) host.IoBroker 2020-05-28 11:21:06.436 info "system.adapter.mihome-vacuum.0" disabled mihome-vacuum.0 2020-05-28 11:21:04.528 debug (6811) sendMsg[2] >>> {"id":8,"method":"get_map_v1"} mihome-vacuum.0 2020-05-28 11:21:04.331 debug (6811) sendMsg[2] >>> {"id":7,"method":"get_room_mapping"} mihome-vacuum.0 2020-05-28 11:21:04.331 debug (6811) sendMsg[2] >>> {"id":6,"method":"get_carpet_mode"} mihome-vacuum.0 2020-05-28 11:21:04.129 debug (6811) sendMsg[2] >>> {"id":5,"method":"get_clean_summary"}Gruß Daniel aka Seppel
@seppel786 sagte in Test Adapter mihome-vacuum v2.0.x:
Node.js: v12.16.3
Adapter: 2.0.9Hilft jetzt sicher nicht viel, aber genau mit dieser Konstellation läuft bei mir alles. nodejs 12 ist also kein generelles Problem.
Abweichend bei mir ist es das Modell 1S und Karte aus der Xiaomi Cloud. -
Node.js: v12.16.3
Spannende Kiste...Vlt liegt es auch am Zusammenspiel mit Valetudo?! Wäre jetzt interessant zu wissen,
ob das bei jemand in der gleichen Konstellation läuft oder ob das Problem wieder vor dem Bildschirm sitzt :-)@seppel786 Bei mir genau das Setting von @Diginix Auch ein 1S, auch Xiaomi Cloud.
@All: Hat jemand ein ähnliches Setting wie ich, wo die Karte in Verbindung mit Valetudo funktioniert?
@Meistertr
Ist ein "Problem" mit Valetudo bekannt?! -
Bei den Karten kenne ich mich nicht so gut aus, aber kann es sein, dass man nicht auf die roborock App zurück darf, wenn man ioBroker nutzen möchte?
@dirkhe die Karte funktioniert anscheinend nur, wenn der Sauger über die mihome App registriert ist.
NEUE FIRMWARE DRAUSSEN
Fasse mal kurz grob zusammen, da die neue Firmware jetzt auch in miHome verfügbar ist
Adapter läuft
mehrkarten speicherung auch... Ortung der Stockwerke scheint auch ganz gut zu funktionierenWAS NICHT MEHR GEHT
Da ich 3 Stockwerke besitze habe ich bisher das mit den Stockwerken folgendermassen gelöst:
Ich sag Siri: Reinige das Obergeschoss es wird ne Variable gesetzt, dass der Roboter sich im 1. OG befindet map reset durchgeführt und als neue Karte machen lassen
aufm Rückweg hab ich ihn auf Position 0 fahren lassen und die Karte wiederhergestellt (aufs Erdgeschoss)
Map reset hab ich noch nicht ausprobiert, aber eine Vorhandene Map widerherstellen lassen geht auf alle fälle nicht (zumindest nicht über den recover_map;[xxx] Befehl
ist auch egal, da er sich eh vor JEDEM saugen oder bewegen ortet
Was ich später mal ausprobiere was passiert, wenn ich Ihn im Keller aussetze und das als neue Karte laufen lasse (was er macht, wenn er nicht weiss wo er ist... was dann passiert, wenn man ihn wieder zurück setzt)ansonsten scheint alles zu laufen... soweit
UPDATE: reset_map klappt auch nicht
@backfisch88 said in Test Adapter mihome-vacuum v2.0.x:
Moin .. wie genau und wo hast du denn den Befehl "recover_map;[xxx]" ausgeführt?
damit habe ich die Canvas Fehler beseitigt
sudo iobroker stop cd /opt/iobroker sudo apt update sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev sudo npm install canvas --unsafe-perm=trueNun sieht mein LOG so aus
mihome-vacuum.1 2020-05-27 15:59:50.091 warn (2838) This object will not be created in future versions. Please report this to the developer. mihome-vacuum.1 2020-05-27 15:59:50.090 warn (2838) Object mihome-vacuum.1.rooms.room2.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json mihome-vacuum.1 2020-05-27 15:59:50.089 warn (2838) This object will not be created in future versions. Please report this to the developer. mihome-vacuum.1 2020-05-27 15:59:50.088 warn (2838) Object mihome-vacuum.1.rooms.room1.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json mihome-vacuum.1 2020-05-27 15:59:50.087 warn (2838) This object will not be created in future versions. Please report this to the developer. mihome-vacuum.1 2020-05-27 15:59:50.087 warn (2838) Object mihome-vacuum.1.rooms.room17.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json mihome-vacuum.1 2020-05-27 15:59:50.085 warn (2838) This object will not be created in future versions. Please report this to the developer. mihome-vacuum.1 2020-05-27 15:59:50.084 warn (2838) Object mihome-vacuum.1.rooms.room16.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json mihome-vacuum.1 2020-05-27 15:59:50.059 info (2838) create new room: room2 mihome-vacuum.1 2020-05-27 15:59:50.058 info (2838) create new room: room1 mihome-vacuum.1 2020-05-27 15:59:50.056 info (2838) create new room: room17 mihome-vacuum.1 2020-05-27 15:59:50.054 info (2838) create new room: room16 mihome-vacuum.1 2020-05-27 15:59:48.069 info (2838) create states for water box filter mihome-vacuum.1 2020-05-27 15:59:48.068 info (2838) create states for water box mihome-vacuum.0 2020-05-27 15:59:47.391 warn (2580) This object will not be created in future versions. Please report this to the developer. mihome-vacuum.0 2020-05-27 15:59:47.391 warn (2580) Object mihome-vacuum.0.rooms.room2.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json mihome-vacuum.0 2020-05-27 15:59:47.386 warn (2580) This object will not be created in future versions. Please report this to the developer. mihome-vacuum.0 2020-05-27 15:59:47.385 warn (2580) Object mihome-vacuum.0.rooms.room1.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json mihome-vacuum.0 2020-05-27 15:59:47.374 info (2580) create new room: room2 mihome-vacuum.0 2020-05-27 15:59:47.373 info (2580) create new room: room1 mihome-vacuum.0 2020-05-27 15:59:45.304 info (2580) create states for water box filter mihome-vacuum.0 2020-05-27 15:59:45.303 info (2580) create states for water box@Xenon said in Test Adapter mihome-vacuum v2.0.x:
sudo iobroker stop cd /opt/iobroker sudo apt update sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev sudo npm install canvas --unsafe-perm=trueOk, das scheint bei mir auch funktioniert zu haben. Leider scheint jetzt Port 80 belegt zu sein, den ich eigentlich für Alexa und Node.js benötige...
Kann das was mit dem Canvas Update zu tun haben oder mit dem hier ?
sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-devIch hatte gleich noch upgrade mit gemacht, aber wenn sich bestehende SW updatet, ändert sich doch nicht einfach der Port oder ?
Servus. Ich habe zwei Roborock S50 im Betrieb. Beide laufen über das selbe Xiaomi Konto auf dem Europa Server. Jedoch bekomme ich bei einem keine Karte geladen. Instanz 0 (Erdgeschoss) lädt sie einfach nicht. Bei Instanz 1 (Obergeschoss) klappt das wunderbar. Beide Roboter laufen mit stock Firmware 3.5.7_002008.
Das Update von canvas hab ich schon Probiert, hat jedoch nichts gebracht. Hat jemand eine Idee?
Gruß Jaschkopf
@backfisch88 Habe das auch gerade mal probiert und bekomme im Log folgenden Fehler:
mihome-vacuum.0 2020-06-05 18:18:00.833 warn (28716) Could not receive Mappointer, giving up mihome-vacuum.0 2020-06-05 18:16:56.282 error (28716) [69](X_send_command) -> response time out mihome-vacuum.0 2020-06-05 18:16:52.783 info (28716) send message: Method: recover_map Params: [1] mihome-vacuum.0 2020-06-05 18:16:51.820 info (28716) send message: Method: get_recover_mapsJetzt hat er zwar die Karte geladen, diese wird aber nicht aktualisiert wenn der Roboter saugt. Hat jemand noch eine Idee?
Gruß Jaschkopf
Genau so. Hatte bisher immer funktioniert.
Besten Dank! Funktioniert wie gewünscht .. 👍🏻🙂
@radierer bei mir sagt er nur „unknown command“ 🤣
Hm .. seltsam. Ich hab ja nix anderes gemacht .. außer zusätzlich noch den Befehl zum zurückfahren an die Ladestation.
Evtl. mal den Haken bei "eigene Befehle zulassen" in der Adapterkonfig raus- und wieder reinmachen!?
Sagt mal, wie kann ich denn noch mal die Map anschauen ?
Das war doch irgendwie so im Browser ?
http://192.168.178.31/mihome-vacuum.admin/actualMap_0.pnghttp://192.168.178.31:54321/mihome-vacuum.admin/actualMap_0.pngHabs auch mit dem Standardport probiert, ging auch nicht. Es ging aber mal so, was fehlt hier noch ?
