  5. Script fürTabelle der Batterie Zustände
    apollon77A
javascriptmonitoringtemplate
1.4k Beiträge 67 Kommentatoren 792.9k Aufrufe 86 Beobachtet
  • ub.privatU ub.privat
    @liv-in-sky
    Hallöle, leider kein Erfolg 😖 😕
    9.3.2020, 18:35:24.715	[info ]: javascript.0 (27455) Stop script script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:35:24.867	[info ]: javascript.0 (27455) Start javascript script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:35:24.927	[warn ]: javascript.0 (27455)     at tabelleFinish (script.js.Akku_MaterialDesignWidget:1306:36)
    9.3.2020, 18:35:24.927	[warn ]: javascript.0 (27455)     at writeHTML (script.js.Akku_MaterialDesignWidget:1145:6)
    9.3.2020, 18:35:24.927	[warn ]: javascript.0 (27455)     at script.js.Akku_MaterialDesignWidget:1160:1
    9.3.2020, 18:35:24.928	[info ]: javascript.0 (27455) script.js.Akku_MaterialDesignWidget: registered 0 subscriptions and 1 schedule
    9.3.2020, 18:37:18.620	[info ]: javascript.0 (27455) Stop script script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:37:18.678	[info ]: javascript.0 (27455) Start javascript script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:37:18.765	[warn ]: javascript.0 (27455)     at tabelleFinish (script.js.Akku_MaterialDesignWidget:1306:36)
    9.3.2020, 18:37:18.766	[warn ]: javascript.0 (27455)     at writeHTML (script.js.Akku_MaterialDesignWidget:1145:6)
    9.3.2020, 18:37:18.766	[warn ]: javascript.0 (27455)     at script.js.Akku_MaterialDesignWidget:1160:1
    9.3.2020, 18:37:18.766	[info ]: javascript.0 (27455) script.js.Akku_MaterialDesignWidget: registered 0 subscriptions and 1 schedule
    9.3.2020, 18:37:36.211	[info ]: javascript.0 (27455) Stop script script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:37:37.539	[info ]: javascript.0 (27455) Start javascript script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:37:37.629	[warn ]: javascript.0 (27455)     at tabelleFinish (script.js.Akku_MaterialDesignWidget:1306:36)
    9.3.2020, 18:37:37.630	[warn ]: javascript.0 (27455)     at writeHTML (script.js.Akku_MaterialDesignWidget:1145:6)
    9.3.2020, 18:37:37.630	[warn ]: javascript.0 (27455)     at script.js.Akku_MaterialDesignWidget:1160:1
    9.3.2020, 18:37:37.631	[info ]: javascript.0 (27455) script.js.Akku_MaterialDesignWidget: registered 0 subscriptions and 1 schedule
    9.3.2020, 18:38:03.665	[info ]: javascript.0 (27455) Stop script script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:38:05.485	[info ]: javascript.0 (27455) Start javascript script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:38:05.609	[warn ]: javascript.0 (27455)     at tabelleFinish (script.js.Akku_MaterialDesignWidget:1306:36)
    9.3.2020, 18:38:05.609	[warn ]: javascript.0 (27455)     at writeHTML (script.js.Akku_MaterialDesignWidget:1145:6)
    9.3.2020, 18:38:05.609	[warn ]: javascript.0 (27455)     at script.js.Akku_MaterialDesignWidget:1160:1
    9.3.2020, 18:38:05.610	[info ]: javascript.0 (27455) script.js.Akku_MaterialDesignWidget: registered 0 subscriptions and 1 schedule
    9.3.2020, 18:39:34.821	[info ]: javascript.0 (27455) Stop script script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:39:34.867	[info ]: javascript.0 (27455) Start javascript script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:39:34.941	[warn ]: javascript.0 (27455)     at tabelleFinish (script.js.Akku_MaterialDesignWidget:1306:36)
    9.3.2020, 18:39:34.941	[warn ]: javascript.0 (27455)     at writeHTML (script.js.Akku_MaterialDesignWidget:1145:6)
    9.3.2020, 18:39:34.941	[warn ]: javascript.0 (27455)     at script.js.Akku_MaterialDesignWidget:1160:1
    9.3.2020, 18:39:34.942	[info ]: javascript.0 (27455) script.js.Akku_MaterialDesignWidget: registered 0 subscriptions and 1 schedule
    9.3.2020, 18:39:39.226	[info ]: javascript.0 (27455) Stop script script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:39:39.498	[info ]: javascript.0 (27455) Start javascript script.js.Akku_MaterialDesignWidget
    9.3.2020, 18:39:39.607	[warn ]: javascript.0 (27455)     at tabelleFinish (script.js.Akku_MaterialDesignWidget:1306:36)
    9.3.2020, 18:39:39.608	[warn ]: javascript.0 (27455)     at writeHTML (script.js.Akku_MaterialDesignWidget:1145:6)
    9.3.2020, 18:39:39.608	[warn ]: javascript.0 (27455)     at script.js.Akku_MaterialDesignWidget:1160:1
    9.3.2020, 18:39:39.609	[info ]: javascript.0 (27455) script.js.Akku_MaterialDesignWidget: registered 0 subscriptions and 1 schedule
    Nach wie vor die Zeile 1306:
    Nur so richtig checke ich nicht, was er von mir will???
    Habe doch alle DP's ordenlich angelegt:
    Mysteriös, mysteriös....
    liv-in-skyL
    liv-in-skyL
    liv-in-sky
    #781
    @ub-privat
    füge mal unter homematic-ip diese zeile ein - zeile 895
    bei mir gehts dann
    ub.privatU 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      @Elirion du kannst das neue vom post drüber auch mal testen - disable einfach die widget erzeugung im setting bereich
      bei mir funktioniert es - aber nur, weil der erste battery punkt auch die daten drinstehen hat - wenn das anders wäre - also eine id ohne daten als erstes drinsteht: gibt es warnings
      #782
      @liv-in-sky sagte in Script fürTabelle der Batterie Zustände:
      Läuft jetzt ;) Hab die erste Version des Scripts genommen und dort den deconz-Teil ausgetauscht mit den entsprechenden Variablen ;)
        @ub-privat
        bei mir gehts dann
        ub.privatU
        ub.privatU
        ub.privat
        #783
        @liv-in-sky
        Habe ich getan.
        Nach unserer Löschung der DP-Inhalte (json) werden diese leider nicht mehr befüllt.
        Script gestartet, gestoppt, ioBroker Start-Stop - nix.
        Gibt's da noch einen Trick???
          @liv-in-sky
          Habe ich getan.
          liv-in-skyL
          liv-in-skyL
          liv-in-sky
          #784
          @ub-privat
          hast du oben in setting auf true gesetzt? brauche....
          let   braucheMaterialDesignWidget=true;
          let   braucheMaterialDesignWidgetTable=true;
            @ub-privat
            ub.privatU
            ub.privatU
            ub.privat
            #785
            @liv-in-sky
            perfekt! DANKE.
            Nun läuft alles!
            Kannst du mir nochmal sagen, in welchem %-Range die Farben spezifiziert sind?
            grün
            hellgrün
            gelb
            rot
            Mir ist schon klar, dass du verschiedene Spannungs-/Leistungswerte betrachtest.
            Muss aber intuitiv sein - Anwender nimmt halt die Farbe wahr und bewertet nach "gut oder schlecht"....
            Aber nun nochmal 👍 👍 hoch und DANKE für die klasse Arbeit und den Support!
              @liv-in-sky
              perfekt! DANKE.
              Nun läuft alles!
              grün
              hellgrün
              gelb
              rot
              liv-in-skyL
              liv-in-skyL
              liv-in-sky
              #786
              @ub-privat
              es gibt nur rot, gelb grün - aber es scheint, ich habe verschiedene grüns drin - das kommt durch die verschiedenen entwicklungsstufen des scripts - also grün hat keine unterteilung der werte ! sondern sind je nach tagesform genutzt worden
              muss ich nochmal durchsehen und in ordnung bringen
                @Knallix da ist der percentage wert leer - da muss was drin stehen - da stimmt etwas anderes nicht - ist die plug online ?
                O
                O
                Oli
                #787
                @liv-in-sky
                wie immer eine super Arbeit von dir, danke dafür.
                Ich benutze das Table Widget und wollte fragen, ob bei dir die Sortierung nach Werten funktioniert?
                Bei mir funktioniert das leider nicht, muss ich da im Widget noch was eingeben?
                Oliver
                • O Oli
                  @liv-in-sky
                  liv-in-skyL
                  liv-in-skyL
                  liv-in-sky
                  #788
                  @Oli das mit dem sortieren im material des.- widget habe ich noch nicht näher angesehen - im moment wird für die "normale tabelle" sortiert - wie das mit diesen widgets geht weiß ich noch nicht - da muss man wohl ein zusätzliches widget dazunehmen - wenn es da was neues gibt, poste ich das widget
                  sieht irgendwie so aus:
                  O 1 Antwort Letzte Antwort
                    O
                    O
                    Oli
                    #789
                    @liv-in-sky
                    ich meine das Table Widget, wenn hier auf die Überschriften gehst kann man normalerweise sortieren
                    Oliver
                    • O Oli
                      @liv-in-sky
                      liv-in-skyL
                      liv-in-skyL
                      liv-in-sky
                      #790
                      @Oli ok - also wenn ich im moment auf name sortiere, ist das noch nicht ganz richtig ( @Scrounger hast du da bei der sortierung nach namen eine idee?)
                      auf status funktioniert, der hersteller auch
                      auf wert wird wohl nie funktionieren, da in dieser spalte 3 verschiedene werte drin stehen können
                      low und high geht aber es gibt halt 1.5 V und 10%
                      das sind buchstaben oder auch zahlen - das kann der sortierungsmechanismus nicht abfangen - denke ich - dann müßte man dies je nach wert in eine eigene spalte schreiben
                      ScroungerS 1 Antwort Letzte Antwort
                        ScroungerS
                        ScroungerS
                        Scrounger
                        schrieb am zuletzt editiert von Scrounger
                        #791
                        @liv-in-sky
                        Steht der Name als reiner Name drin, also ohne HTML tags etc?
                        Wenn ja dann nutz Mal noch 'toLowerCase()' in der sortier Funktion.
                        Da ich mir jetzt nicht den wolf suchen möchte, wo ist das aktuelle Skript? Und ab welcher Zeile hast du deine Sortierung Funktion? Dann schau ich heute Abend Mal drauf.
                        Sortieren nach % V würde gehen, wenn du eine property mit den Zahlen werten einfuhrst. Die Spalte müsste dann per Widget Einstellungen ausgeblendet werden.
                        • ScroungerS Scrounger
                          @liv-in-sky
                          liv-in-skyL
                          liv-in-skyL
                          liv-in-sky
                          #792
                          @Scrounger danke -check ich mal -gebe dann bescheid
                            @liv-in-sky
                            liv-in-skyL
                            liv-in-skyL
                            liv-in-sky
                            #793
                            @Scrounger
                            wegen sortierung des namens: ich übergebe ja nur ein json - das ist nicht sortiert sondern sammelt alle daten der einzelnen devices - ich dachte, die sortierung wird in deinen table widget vorgenommen? meine sortierung hat doch damit nichts zu tun - wenn ich auf die spaltenüberschrift auf deinem widget drücke, hat das doch keine auswirkungen auf mein script?
                            nachtrag - hatte im widget etwas eingetragen - die sortierung des namen funktioniert jetzt ohne probleme
                            @Oli in meinem widget steht im spaltenlayout[0] unter Objectname zum Sortieren[0] etwas drin - das einfach rauslöschen)
                            • das mit dem extraproperty für zahlenwerte muss ich mir noch ansehen
                            hier das beispiel json
                               	"Device": "Comet DECT #2 Kueche",
                               	"Wert": "50 %",
                               	"Status": "?",
                               	"Hersteller": "/vis.0/armin/img/marken/fritzk.png"
                               	"Device": "Comet DECT #1 Zimmer",
                               	"Wert": "60 %",
                               	"Status": "?",
                               	"Device": "Comet DECT Flur",
                               	"Wert": "90 %",
                               	"Status": "?",
                               	"Device": "Comet DECTBad",
                               	"Wert": "60 %",
                               	"Status": "?",
                               	"Device": "FRITZ!DECT BAD",
                               	"Wert": "70 %",
                               	"Status": "?",
                               	"Device": "FRITZ!DECT KUECHE",
                               	"Wert": "80 %",
                               	"Status": "?",
                               	"Device": "FRITZ!DECT WOHNZIMMER",
                               	"Wert": "70 %",
                               	"Status": "?",
                               	"Device": "Außenmodul-Carport",
                               	"Wert": "5 %",
                               	"Status": "?",
                               	"Hersteller": "/vis.0/armin/img/marken/netatmok.png"
                               	"Device": "Regenmesser",
                               	"Wert": "33 %",
                               	"Status": "??",
                               	"Device": "Schlafzimmer",
                               	"Wert": "99 %",
                               	"Status": "?",
                               	"Device": "Windmesser",
                               	"Wert": "11 %",
                               	"Status": "?",
                               	"Device": "xmagnet",
                               	"Wert": "60.6 %",
                               	"Status": "?",
                               	"Hersteller": "/vis.0/armin/img/marken/xiaomki.png"
                               	"Device": "magnet",
                               	"Wert": "62.4 %",
                               	"Status": "?",
                               	"Device": "magnet",
                               	"Wert": "64.2 %",
                               	"Status": "?",
                               	"Device": "magnet",
                               	"Wert": "60.6 %",
                               	"Status": "?",
                               	"Device": "motion 2",
                               	"Wert": "66.1 %",
                               	"Status": "?",
                               	"Device": "motion 1",
                               	"Wert": "67.9 %",
                               	"Status": "?",
                               	"Device": "sensor_motion.aq2",
                               	"Wert": "60.6 %",
                               	"Status": "?",
                               	"Device": "switch",
                               	"Wert": "69.2 %",
                               	"Status": "?",
                               	"Device": "switch",
                               	"Wert": "71 %",
                               	"Status": "?",
                               	"Device": "vibration",
                               	"Wert": "64.2 %",
                               	"Status": "?",
                               	"Wert": "64.2 %",
                               	"Status": "?",
                               	"Device": "Fenster Küche",
                               	"Wert": "66 %",
                               	"Status": "?",
                               	"Hersteller": "/vis.0/armin/img/marken/deconzk.png"
                               	"Device": "Wasser Küche",
                               	"Wert": "33 %",
                               	"Status": "?",
                               	"Device": "Fenster Kinderzimmer rechts",
                               	"Wert": "66 %",
                               	"Status": "?",
                               	"Device": "Fenster Wohnzimmer",
                               	"Wert": "22 %",
                               	"Status": "?",
                               	"Device": "Temp Schlafzimmer",
                               	"Wert": "44 %",
                               	"Status": "?",
                               	"Device": "Fenster Schlafzimmer",
                               	"Wert": "99 %",
                               	"Status": "?",
                               	"Device": "Fenster Bad",
                               	"Wert": "44 %",
                               	"Status": "?",
                               	"Device": "Wasser Bad",
                               	"Wert": "33 %",
                               	"Status": "?",
                               	"Device": "Fenster Kinderzimmer links",
                               	"Wert": "5 %",
                               	"Status": "?",
                               	"Device": "Wintergarten",
                               	"Wert": "low",
                               	"Status": "?",
                               	"Hersteller": "/vis.0/armin/img/marken/tadok.png"
                               	"Device": "Tado Virtuell",
                               	"Wert": "high",
                               	"Status": "?",
                               	"Device": "Wohnzimmer",
                               	"Wert": "low",
                               	"Status": "?",
                               	"Device": "Küche",
                               	"Wert": "high",
                               	"Status": "?",
                               	"Wert": "high",
                               	"Status": "?",
                               	"Device": "Flur",
                               	"Wert": "high",
                               	"Status": "?",
                               	"Device": "Essbereich",
                               	"Wert": "high",
                               	"Status": "?",
                               	"Device": "Heizk_Hobby",
                               	"Wert": "3.5 V",
                               	"Status": "??",
                               	"Hersteller": "/vis.0/armin/img/marken/homematick.png"
                               	"Device": "TC_Bad_EG",
                               	"Wert": "1.5 V",
                               	"Status": "?",
                               	"Device": "RT_02_EG_WOHNEN",
                               	"Wert": "2.4 V",
                               	"Status": "??",
                               	"Device": "Fire Tablet",
                               	"Wert": "67 %",
                               	"Status": "?",
                               	"Hersteller": "/vis.0/armin/img/marken/fullyk.png"
                               	"Device": "Samsung Galaxy Tab 3",
                               	"Wert": "72 %",
                               	"Status": "?",
                               	"Device": "TrekStor SurfTab theatre 13.3",
                               	"Wert": "100 %",
                               	"Status": "?",
                               	"Device": "SM-T113-Tab",
                               	"Wert": "87 %",
                               	"Status": "?",
                               	"Device": "GalaxyTabS2",
                               	"Wert": "61 %",
                               	"Status": "?",
                               	"Device": "MediaPadT5",
                               	"Wert": "74 %",
                               	"Status": "?",
                              @Scrounger
                                 	"Wert": "50 %",
                                 	"Status": "?",
                                 	"Wert": "60 %",
                                 	"Status": "?",
                                 	"Wert": "90 %",
                                 	"Status": "?",
                                 	"Wert": "60 %",
                                 	"Status": "?",
                                 	"Wert": "70 %",
                                 	"Status": "?",
                                 	"Wert": "80 %",
                                 	"Status": "?",
                                 	"Wert": "70 %",
                                 	"Status": "?",
                                 	"Wert": "5 %",
                                 	"Status": "?",
                                 	"Wert": "33 %",
                                 	"Status": "??",
                                 	"Wert": "99 %",
                                 	"Status": "?",
                                 	"Wert": "11 %",
                                 	"Status": "?",
                                 	"Wert": "60.6 %",
                                 	"Status": "?",
                                 	"Device": "magnet",
                                 	"Wert": "62.4 %",
                                 	"Status": "?",
                                 	"Device": "magnet",
                                 	"Wert": "64.2 %",
                                 	"Status": "?",
                                 	"Device": "magnet",
                                 	"Wert": "60.6 %",
                                 	"Status": "?",
                                 	"Wert": "66.1 %",
                                 	"Status": "?",
                                 	"Wert": "67.9 %",
                                 	"Status": "?",
                                 	"Wert": "60.6 %",
                                 	"Status": "?",
                                 	"Device": "switch",
                                 	"Wert": "69.2 %",
                                 	"Status": "?",
                                 	"Device": "switch",
                                 	"Wert": "71 %",
                                 	"Status": "?",
                                 	"Wert": "64.2 %",
                                 	"Status": "?",
                                 	"Wert": "64.2 %",
                                 	"Status": "?",
                                 	"Wert": "66 %",
                                 	"Status": "?",
                                 	"Wert": "33 %",
                                 	"Status": "?",
                                 	"Wert": "66 %",
                                 	"Status": "?",
                                 	"Wert": "22 %",
                                 	"Status": "?",
                                 	"Wert": "44 %",
                                 	"Status": "?",
                                 	"Wert": "99 %",
                                 	"Status": "?",
                                 	"Wert": "44 %",
                                 	"Status": "?",
                                 	"Wert": "33 %",
                                 	"Status": "?",
                                 	"Wert": "5 %",
                                 	"Status": "?",
                                 	"Wert": "low",
                                 	"Status": "?",
                                 	"Wert": "high",
                                 	"Status": "?",
                                 	"Wert": "low",
                                 	"Status": "?",
                                 	"Device": "Küche",
                                 	"Wert": "high",
                                 	"Status": "?",
                                 	"Wert": "high",
                                 	"Status": "?",
                                 	"Device": "Flur",
                                 	"Wert": "high",
                                 	"Status": "?",
                                 	"Wert": "high",
                                 	"Status": "?",
                                 	"Wert": "3.5 V",
                                 	"Status": "??",
                                 	"Wert": "1.5 V",
                                 	"Status": "?",
                                 	"Wert": "2.4 V",
                                 	"Status": "??",
                                 	"Wert": "67 %",
                                 	"Status": "?",
                                 	"Wert": "72 %",
                                 	"Status": "?",
                                 	"Wert": "100 %",
                                 	"Status": "?",
                                 	"Wert": "87 %",
                                 	"Status": "?",
                                 	"Wert": "61 %",
                                 	"Status": "?",
                                 	"Wert": "74 %",
                                 	"Status": "?",
                              ScroungerS
                              ScroungerS
                              Scrounger
                              #794
                              @liv-in-sky
                              Hast natürlich Recht, die Sortierung wird vom Tablet Widget übernommen.
                              Bin voll im IconList Widget Modus ;-)
                              Mit dem Tablet Widget kannst dann auch nur nach % oder V sortieren. Oder die beiden mixen.
                              Dazu musst eine extra property im json Objekt einführen, wo nur die Zahl (Number) drin steht.
                              Den Namen der property muss dann in den Widget Einstellungen für die Spalte wert als Sortierungs eintragen.
                                @liv-in-sky
                                liv-in-skyL
                                liv-in-skyL
                                liv-in-sky
                                #795
                                @Scrounger bitte nochmal für dummies:
                                es gibt folgende werte in einer spalte
                                zahl in %
                                zahl in volt
                                string : low oder high
                                ich schleife 2 variablen variable mit , die letztlich im json landen - z.b prozentValue und voltValue
                                ich setze zusätzlich zum normalen wert die prozentValue, wenn eine prozent anzeige ist und gleichzeitig den voltwert auf 0
                                oder
                                ich setze zusätzlich zum normalen wert die voltValue, wenn eine voltanzeige ist und gleichzeitig den prozentwert auf 0
                                ich setze zusätzlich zum low/high wert die voltValue auf 0, und gleichzeitig den prozentwert auf 0
                                am ende sieht ds json-push so aus
                                myJsonWidget2.push({
                                                text: vax1,
                                                subText: mysubText,
                                                statusBarColor: vax5,
                                                image: vax4,
                                                imageColor: "",
                                                listType: "text",
                                                showValueLabel: false,
                                                status: vax3,
                                                voltValue:voltValue,
                                                prozentValue:prozentValue
                                im widget muss ich dann
                                kommt das ungefähr hin ode explodiert die vis oder das widget?
                                ScroungerS ub.privatU 2 Antworten Letzte Antwort
                                  zahl in %
                                  zahl in volt
                                  oder
                                                  text: vax1,
                                                  subText: mysubText,
                                                  image: vax4,
                                                  imageColor: "",
                                                  listType: "text",
                                                  status: vax3,
                                  ScroungerS
                                  ScroungerS
                                  Scrounger
                                  #796
                                  @liv-in-sky Objektname zum sortieren kann nur eine property verarbeiten.
                                    zahl in %
                                    zahl in volt
                                    oder
                                                    text: vax1,
                                                    subText: mysubText,
                                                    image: vax4,
                                                    imageColor: "",
                                                    listType: "text",
                                                    status: vax3,
                                    ub.privatU
                                    ub.privatU
                                    ub.privat
                                    #797
                                    @liv-in-sky
                                    Servus, wollte nur mal kurz anfragen, ob du das Akku-Script weiter "verfeinerst"?
                                    Hätte großes Interesse an den Filterfunktionen...
                                    Aber mach dir keine Umstände, auch ein "nein" ist ok...
                                    Beste Grüße 😉
                                      @liv-in-sky
                                      Beste Grüße 😉
                                      liv-in-skyL
                                      liv-in-skyL
                                      liv-in-sky
                                      #798
                                      @ub-privat
                                      habe es noch nicht genau kapiert - wenn ich nur nach einem sortieren kann, macht es keinen sinn bei 3 verschiedenen werten - es wird nie eine gute sortierung rauskommen
                                      ansonsten müßte ich tatsächlich mit 3 spalten für den wert arbeiten -also name,wert1,wert2,wert3,status,hersteller
                                      und werte für low/high stehen in wert1
                                      werte mit 1.3 V stehen in wert2
                                      und werte mit prozent in wert3
                                      ist nicht schön -
                                        hier ein beispiel für die Anzeige der Sensoren-Batterie-Zustände über ein html-Widget (oder iQontrol) - angelehnt an die scripte für html tabellen: https://forum.iobroker.net/topic/28021/html-table-für-vis-oder-iqontrol-js-und-blockly
                                        die MaterialDesign Widgets sind auch mit eingebunden https://forum.iobroker.net/post/389578
                                        export der widgets
                                        [{"tpl":"tplVis-materialdesign-Icon-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","wrapItems":true,"listItemDataMethod":"jsonStringObject","countListItems":"1","vibrateOnMobilDevices":"50","listLayout":"card","itemLayout":"horizontal","listType0":"text","showValueLabel0":"true","listType1":"text","showValueLabel1":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"maxItemsperRow":"4","json_string_oid":"controll-own.0.TABELLEN.AkkuMaterialWidget","labelFontSize":"22","subLabelFontSize":"14","labelFontFamily":"RobotoCondensed-Regular","horizontalIconContainerWidth":"70","buttonHeight":"70","iconHeight":"35","iconItemMinWidth":"300"},"style":{"left":"117px","top":"67px","width":"60.89%","height":"87.71%","overflow-y":"auto"},"widgetSet":"materialdesign"}]
                                        [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"controll-own.0.TABELLEN.AkkuMaterialWidgetTable","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"4","tableLayout":"standard","showHeader":"true","headerTextSize":"headline6","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"center","showColumn3":"true","colType3":"image","textAlign3":"center","dataJson":"","colTextSize0":"headline4","label1":"Wert","label0":"Name","label2":"Status","sortKey0":"","fontFamily0":"RobotoCondensed-Regular","padding_left0":"10","colTextColor0":"","colorBackground":"#ffffff","colorHeaderRowBackground":"#424242","colorHeaderRowText":"#b6b9b7","borderColor":"#000000","fontFamily1":"RobotoCondensed-Regular","colTextColor1":"#beb7b7","rowHeight":"19","label3":"Hersteller","imageSize3":"20","padding_right3":"-5","sortKey2":"","showColumn4":false,"colType4":"text","textAlign4":"center","sortKey1":"helpSort"},"style":{"left":"1110px","top":"61px","z-index":"0","width":"587px","height":"926px","overflow-y":"auto"},"widgetSet":"materialdesign"}]
                                        die javascript adapter version sollte 4.3.x sein !!!
                                        anzulegen und in das script einzutragen sind folgende datenpunkte
                                        • ein datenpunkt für die vis-anzeige unter dpVIS - ganz oben - im script - anschliessend kann man die tabelle so einstellen, dass sie in eure vis paßt (übr ein standard-html-widget mit binding auf diesen selbst-angelegten-datenpunkt)- ein html datei kann auf wunsch geschrieben werden - damit kann auch in iQontrol ein popup "gefüttert" werden und als anzeige dienen. auch die werte für warnung oder alarm sind einzutragen
                                        • ein datenpunkt für die anzahl der devices mit alarm (im script beschrieben)
                                        • ein datenpunkt für eine liste mit den devices mit einem alarm (im script beschrieben)
                                        wie legt man einen datenpunkt an: https://forum.iobroker.net/post/400338
                                        Script zum download bzw. mit Chrome!!! kopieren
                                        https://github.com/liv-in-sky/battery-iobroker-vis-table
                                        • bisher integriert
                                        hersteller
                                        iogok.png iogo adapter
                                        tadok.jpg tado
                                        homeek.jpg homee
                                        netatmok.jpg netatmo
                                        zwavek.jpg zwave
                                        fritzk.png fritzDect theermostate
                                        xiaomki.png xiaomi, mihome
                                        homematick.jpg homematic, homematic-Ip
                                        huek.jpg hue, hue-ext
                                        zwavek.jpg zwave
                                        tradfrik.png tradfri
                                        fullyk.png fully browser adapter
                                        zigbeek.jpg zigbee
                                        deconzk.png deconz
                                        sonoffk.png sonoff zb bridge
                                        busware-cul.png cul adapter
                                        rademacher.png rademacher homepilot
                                        shellyk.jpg shelly
                                        boschk.png bosch
                                        hamk.png ham (homebridge)
                                        nuki-extended
                                        ScroungerS
                                        ScroungerS
                                        Scrounger
                                        #799
                                        @liv-in-sky
                                        Bin grad auf die Idee gekommen, dass man doch aus der Spannung die Batterieladung in % umrechnen könnte. Das geht zumindest mit den Homematic / Homemativ ip devices, indem man das Delta vom Spannungswert bei neuen Batterie berechnet und durch die Spannung bei neuen Batterie - die Unterspannungsgrenze teilt.
                                        Ob das mit allen von dir unterstützten Geräten geht kann ich natürlich nicht sagen.
                                        Evtl. könntest du das noch mit in dein Skript ein bauen?
                                        Hier mein Skript wie ich die Berechnung mit meinen HM Devices mach - zur Inspiration, muss natürlich angepasst werden.
                                        // Batterie Spannung in % umrechnen -> Batterieladung ****************************************************************************************************
                                        // import
                                        const mathjs = require("mathjs");
                                        let selector = `[id=${myDevices.Sensoren.getId()}.*.Spannung]`
                                        let alleSensorenSpannung = $(selector);
                                        // Fehlermeldung ausgeben, wenn selector kein result liefert
                                        if (alleSensorenSpannung.length === 0) {
                                            console.error(`no result for selector '${selector}'`)
                                        // Trigger
                                        alleSensorenSpannung.on(SpannungToProzent);
                                        function SpannungToProzent() {
                                            try {
                                                for (var i = 0; i <= alleSensorenSpannung.length - 1; i++) {
                                                    let id = alleSensorenSpannung[i];
                                                    let val = getState(id).val;
                                                    if (val > 2) {
                                                        if (existsState(id.replace('.Spannung', '.Batterieladung'))) {
                                                            setState(id.replace('.Spannung', '.Batterieladung'), calcPercent(val, 2), true);
                                                    } else {
                                                            setState(id.replace('.Spannung', '.Batterieladung'), calcPercent(val, 1), true);
                                                    function calcPercent(val, factor){
                                                        let spannungNeueBatterie = 1.5 * factor;
                                                        let unterSpannungsGrenze = 1.1 * factor;
                                                        return mathjs.round( (val - unterSpannungsGrenze) / (spannungNeueBatterie - unterSpannungsGrenze) * 100, 0);
                                            } catch (err) {
                                                console.error(`[SpannungToProzent] error: ${err.message}, stack: ${err.stack}`);
                                        SpannungToProzent();
                                          @liv-in-sky
                                          // import
                                          // Trigger
                                              try {
                                                      if (val > 2) {
                                                      } else {
                                              } catch (err) {
                                          arteckA
                                          arteckA
                                          arteck
                                          #800
                                          @Scrounger im zigbee wird das so gemacht
                                          84.0k
                                          1.4m
