  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 429.8k Aufrufe 35 Beobachtet
  • smartboartS smartboart
    @apollon77
    so hier der syslog..
    hier mal ein Auszug..Tauchen Sachen mit Spannungswerten auf...kann es aber nicht wirklich deuten. Google spuckt jede Menge dieser Einträge im Zusammenhang mit dem Rock64 aus.
    Oct 18 14:16:35 localhost kernel: [ 1.495918] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
    Oct 18 14:16:35 localhost armbian-ramlog[613]: debug
    Oct 18 14:16:35 localhost kernel: [ 1.495942] vcc_sd: unable to resolve supply
    Oct 18 14:16:35 localhost kernel: [ 1.495958] vcc_sd: 3300 mV
    Oct 18 14:16:35 localhost kernel: [ 1.496208] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
    Oct 18 14:16:35 localhost kernel: [ 1.496233] vcc_sd: regulator get failed, ret=-517
    Oct 18 14:16:35 localhost armbian-ramlog[613]: dpkg.log
    Oct 18 14:16:35 localhost kernel: [ 1.496250] reg-fixed-voltage sdmmc-regulator:
    syslog
    Oct 18 14:16:35 localhost fake-hwclock[246]: Current system time: 2019-10-18 12:16:33
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Booting Linux on physical CPU 0x0
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Initializing cgroup subsys cpuset
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Initializing cgroup subsys cpuacct
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Linux version 4.4.192-rockchip64 (root@builder) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02) ) #1 SMP Tue Oct 8 18:39:24 CEST 2019
    Oct 18 14:16:35 localhost fake-hwclock[246]: fake-hwclock saved clock information is in the past: 2019-10-18 11:17:01
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
    Oct 18 14:16:35 localhost kernel: [ 0.000000] earlycon: Early serial console at MMIO32 0xff130000 (options '')
    Oct 18 14:16:35 localhost kernel: [ 0.000000] bootconsole [uart0] enabled
    Oct 18 14:16:35 localhost kernel: [ 0.000000] On node 0 totalpages: 1043968
    Oct 18 14:16:35 localhost kernel: [ 0.000000] DMA zone: 16312 pages used for memmap
    Oct 18 14:16:35 localhost kernel: [ 0.000000] DMA zone: 0 pages reserved
    Oct 18 14:16:35 localhost fake-hwclock[246]: To set system time to this saved clock anyway, use "force"
    Oct 18 14:16:35 localhost kernel: [ 0.000000] DMA zone: 1043968 pages, LIFO batch:31
    Oct 18 14:16:35 localhost kernel: [ 0.000000] psci: probing for conduit method from DT.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
    Oct 18 14:16:35 localhost resolvconf[309]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
    Oct 18 14:16:35 localhost kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0fef1f000 s46312 r8192 d31512 u86016
    Oct 18 14:16:35 localhost kernel: [ 0.000000] pcpu-alloc: s46312 r8192 d31512 u86016 alloc=21*4096
    Oct 18 14:16:35 localhost kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    Oct 18 14:16:35 localhost systemd[1]: Started Create Static Device Nodes in /dev.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Detected VIPT I-cache on CPU0
    Oct 18 14:16:35 localhost kernel: [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027656
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff130000 swiotlb=1 kpti=0 no_console_suspend=1 usbcore.autosuspend=-1 root=UUID=37725f38-d37c-429c-89a6-9fc49158dcfe rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=b275bf8f-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    Oct 18 14:16:35 localhost kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
    Oct 18 14:16:35 localhost systemd[1]: Starting udev Kernel Device Manager...
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] software IO TLB: mapped [mem 0xfeed7000-0xfef17000] (0MB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Memory: 4078868K/4175872K available (11518K kernel code, 1488K rwdata, 4160K rodata, 1216K init, 699K bss, 97004K reserved, 0K cma-reserved)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Virtual kernel memory layout:
    Oct 18 14:16:35 localhost systemd[1]: Starting Flush Journal to Persistent Storage...
    Oct 18 14:16:35 localhost kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] .init : 0xffffff8008fe0000 - 0xffffff8009110000 ( 1216 KB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bc0000 ( 11520 KB)
    Oct 18 14:16:35 localhost systemd[1]: Started Flush Journal to Persistent Storage.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] .rodata : 0xffffff8008bc0000 - 0xffffff8008fe0000 ( 4224 KB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] .data : 0xffffff8009110000 - 0xffffff8009284008 ( 1489 KB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3fc0000 ( 63 MB actual)
    Oct 18 14:16:35 localhost systemd[1]: Started udev Kernel Device Manager.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
    Oct 18 14:16:35 localhost kernel: [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0ff000000 ( 4078 MB)
    Oct 18 14:16:35 localhost systemd[1]: Started Set the console keyboard layout.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Hierarchical RCU implementation.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
    Oct 18 14:16:35 localhost systemd[1]: Reached target Local File Systems (Pre).
    Oct 18 14:16:35 localhost kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
    Oct 18 14:16:35 localhost kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
    Oct 18 14:16:35 localhost systemd[1]: Mounting /tmp...
    Oct 18 14:16:35 localhost kernel: [ 0.000000] GIC: Using split EOI/Deactivate mode
    Oct 18 14:16:35 localhost kernel: [ 0.000000] rockchip_mmc_get_phase: invalid clk rate
    Oct 18 14:16:35 localhost systemd[1]: Mounted /tmp.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
    Oct 18 14:16:35 localhost systemd[1]: Reached target Local File Systems.
    Oct 18 14:16:35 localhost kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    Oct 18 14:16:35 localhost kernel: [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    Oct 18 14:16:35 localhost kernel: [ 0.001143] Console: colour dummy device 80x25
    Oct 18 14:16:35 localhost systemd[1]: Starting Preprocess NFS configuration...
    Oct 18 14:16:35 localhost kernel: [ 0.001159] console [tty1] enabled
    Oct 18 14:16:35 localhost kernel: [ 0.001170] bootconsole [uart0] disabled
    Oct 18 14:16:35 localhost kernel: [ 0.001195] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    Oct 18 14:16:35 localhost kernel: [ 0.001213] pid_max: default: 32768 minimum: 301
    Oct 18 14:16:35 localhost systemd[1]: Starting Armbian ZRAM config...
    Oct 18 14:16:35 localhost kernel: [ 0.001349] Security Framework initialized
    Oct 18 14:16:35 localhost kernel: [ 0.001362] Yama: becoming mindful.
    Oct 18 14:16:35 localhost kernel: [ 0.001387] AppArmor: AppArmor disabled by boot time parameter
    Oct 18 14:16:35 localhost systemd[1]: Starting Set console font and keymap...
    Oct 18 14:16:35 localhost kernel: [ 0.001451] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    Oct 18 14:16:35 localhost kernel: [ 0.001467] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
    Oct 18 14:16:35 localhost kernel: [ 0.002397] Initializing cgroup subsys io
    Oct 18 14:16:35 localhost kernel: [ 0.002421] Initializing cgroup subsys memory
    Oct 18 14:16:35 localhost kernel: [ 0.002458] Initializing cgroup subsys devices
    Oct 18 14:16:35 localhost kernel: [ 0.002476] Initializing cgroup subsys freezer
    Oct 18 14:16:35 localhost kernel: [ 0.002493] Initializing cgroup subsys net_cls
    Oct 18 14:16:35 localhost systemd[1]: Starting Create Volatile Files and Directories...
    Oct 18 14:16:35 localhost kernel: [ 0.002513] Initializing cgroup subsys perf_event
    Oct 18 14:16:35 localhost kernel: [ 0.002531] Initializing cgroup subsys net_prio
    Oct 18 14:16:35 localhost kernel: [ 0.002551] Initializing cgroup subsys hugetlb
    Oct 18 14:16:35 localhost kernel: [ 0.002565] Initializing cgroup subsys pids
    Oct 18 14:16:35 localhost systemd[1]: Starting Raise network interfaces...
    Oct 18 14:16:35 localhost kernel: [ 0.002619] ftrace: allocating 43805 entries in 172 pages
    Oct 18 14:16:35 localhost kernel: [ 0.134714] sched-energy: CPU device node has no sched-energy-costs
    Oct 18 14:16:35 localhost kernel: [ 0.134736] Invalid sched_group_energy for CPU0
    Oct 18 14:16:35 localhost kernel: [ 0.134746] CPU0: update cpu_capacity 1024
    Oct 18 14:16:35 localhost systemd[1]: Started Preprocess NFS configuration.
    Oct 18 14:16:35 localhost kernel: [ 0.134809] ASID allocator initialised with 32768 entries
    Oct 18 14:16:35 localhost kernel: [ 0.137693] Detected VIPT I-cache on CPU1
    Oct 18 14:16:35 localhost systemd[1]: Reached target NFS client services.
    Oct 18 14:16:35 localhost kernel: [ 0.137751] Invalid sched_group_energy for CPU1
    Oct 18 14:16:35 localhost kernel: [ 0.137757] CPU1: update cpu_capacity 1024
    Oct 18 14:16:35 localhost kernel: [ 0.137762] CPU1: Booted secondary processor [410fd034]
    Oct 18 14:16:35 localhost systemd[1]: Started Set console font and keymap.
    Oct 18 14:16:35 localhost kernel: [ 0.138511] Detected VIPT I-cache on CPU2
    Oct 18 14:16:35 localhost kernel: [ 0.138558] Invalid sched_group_energy for CPU2
    Oct 18 14:16:35 localhost kernel: [ 0.138563] CPU2: update cpu_capacity 1024
    Oct 18 14:16:35 localhost systemd[1]: Started udev Coldplug all Devices.
    Oct 18 14:16:35 localhost kernel: [ 0.138569] CPU2: Booted secondary processor [410fd034]
    Oct 18 14:16:35 localhost kernel: [ 0.139246] Detected VIPT I-cache on CPU3
    Oct 18 14:16:35 localhost kernel: [ 0.139291] Invalid sched_group_energy for CPU3
    Oct 18 14:16:35 localhost systemd[1]: Started Create Volatile Files and Directories.
    Oct 18 14:16:35 localhost kernel: [ 0.139297] CPU3: update cpu_capacity 1024
    Oct 18 14:16:35 localhost kernel: [ 0.139302] CPU3: Booted secondary processor [410fd034]
    Oct 18 14:16:35 localhost kernel: [ 0.139403] Brought up 4 CPUs
    Oct 18 14:16:35 localhost kernel: [ 0.139467] SMP: Total of 4 processors activated.
    Oct 18 14:16:35 localhost systemd[1]: Starting RPC bind portmap service...
    Oct 18 14:16:35 localhost kernel: [ 0.139482] CPU features: kernel page table isolation forced OFF by command line option
    Oct 18 14:16:35 localhost kernel: [ 0.139493] CPU features: detected feature: 32-bit EL0 Support
    Oct 18 14:16:35 localhost kernel: [ 0.139508] CPU: All CPU(s) started at EL2
    Oct 18 14:16:35 localhost kernel: [ 0.139547] alternatives: patching kernel code
    Oct 18 14:16:35 localhost systemd[1]: Reached target System Time Synchronized.
    Oct 18 14:16:35 localhost kernel: [ 0.139794] Invalid sched_group_energy for CPU3
    Oct 18 14:16:35 localhost kernel: [ 0.139808] Invalid sched_group_energy for Cluster3
    Oct 18 14:16:35 localhost kernel: [ 0.139817] Invalid sched_group_energy for CPU2
    Oct 18 14:16:35 localhost systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
    Oct 18 14:16:35 localhost kernel: [ 0.139827] Invalid sched_group_energy for Cluster2
    Oct 18 14:16:35 localhost kernel: [ 0.139837] Invalid sched_group_energy for CPU1
    Oct 18 14:16:35 localhost kernel: [ 0.139847] Invalid sched_group_energy for Cluster1
    Oct 18 14:16:35 localhost kernel: [ 0.139857] Invalid sched_group_energy for CPU0
    Oct 18 14:16:35 localhost systemd[1]: Starting Update UTMP about System Boot/Shutdown...
    Oct 18 14:16:35 localhost kernel: [ 0.139867] Invalid sched_group_energy for Cluster0
    Oct 18 14:16:35 localhost kernel: [ 0.140633] devtmpfs: initialized
    Oct 18 14:16:35 localhost kernel: [ 0.164712] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    Oct 18 14:16:35 localhost kernel: [ 0.164749] futex hash table entries: 1024 (order: 4, 65536 bytes)
    Oct 18 14:16:35 localhost systemd-udevd[382]: Process '/sbin/iwconfig wlan0 power off' failed with exit code 250.
    Oct 18 14:16:35 localhost kernel: [ 0.165346] xor: measuring software checksum speed
    Oct 18 14:16:35 localhost kernel: [ 0.202627] 8regs : 1080.000 MB/sec
    Oct 18 14:16:35 localhost kernel: [ 0.242708] 8regs_prefetch: 968.000 MB/sec
    Oct 18 14:16:35 localhost kernel: [ 0.282796] 32regs : 1458.000 MB/sec
    Oct 18 14:16:35 localhost systemd-udevd[380]: Process '/bin/mount -t fusectl fusectl /sys/fs/fuse/connections' failed with exit code 32.
    Oct 18 14:16:35 localhost kernel: [ 0.322881] 32regs_prefetch: 1224.000 MB/sec
    Oct 18 14:16:35 localhost kernel: [ 0.322893] xor: using function: 32regs (1458.000 MB/sec)
    Oct 18 14:16:35 localhost kernel: [ 0.322933] pinctrl core: initialized pinctrl subsystem
    Oct 18 14:16:35 localhost systemd[1]: Started Update UTMP about System Boot/Shutdown.
    Oct 18 14:16:35 localhost systemd[1]: Started RPC bind portmap service.
    Oct 18 14:16:35 localhost systemd[1]: Reached target RPC Port Mapper.
    Oct 18 14:16:35 localhost systemd[1]: Reached target Remote File Systems (Pre).
    Oct 18 14:16:35 localhost systemd[1]: Reached target Remote File Systems.
    Oct 18 14:16:35 localhost systemd[1]: Found device /dev/ttyS2.
    Oct 18 14:16:35 localhost armbian-zram-config[390]: Setting up swapspace version 1, size = 1024 MiB (1073737728 bytes)
    Oct 18 14:16:35 localhost armbian-zram-config[390]: no label, UUID=81bcee6b-4a7b-463d-8d7d-1fae520194a8
    Oct 18 14:16:35 localhost systemd-udevd[369]: link_config: could not get ethtool features for eth0
    Oct 18 14:16:35 localhost systemd-udevd[369]: Could not set offload features of eth0: Device or resource busy
    Oct 18 14:16:35 localhost systemd[1]: Reached target Sound Card.
    Oct 18 14:16:35 localhost systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    Oct 18 14:16:35 localhost armbian-zram-config[390]: mke2fs 1.43.4 (31-Jan-2017)
    Oct 18 14:16:35 localhost armbian-zram-config[390]: Geräteblöcke werden verworfen: 4096/12800#010#010#010#010#010#010#010#010#010#010#010 #010#010#010#010#010#010#010#010#010#010#010erledigt
    Oct 18 14:16:35 localhost armbian-zram-config[390]: Ein Dateisystems mit 12800 (4k) Blöcken und 12800 Inodes wird erzeugt.
    Oct 18 14:16:35 localhost armbian-zram-config[390]: beim Anfordern von Speicher für die Gruppentabellen: 0/1#010#010#010 #010#010#010erledigt
    Oct 18 14:16:35 localhost armbian-zram-config[390]: Inode-Tabellen werden geschrieben: 0/1#010#010#010 #010#010#010erledigt
    Oct 18 14:16:35 localhost armbian-zram-config[390]: Die Superblöcke und die Informationen über die Dateisystemnutzung werden
    Oct 18 14:16:35 localhost armbian-zram-config[390]: geschrieben: 0/1#010#010#010 #010#010#010erledigt
    Oct 18 14:16:35 localhost systemd[1]: Started Armbian ZRAM config.
    Oct 18 14:16:35 localhost systemd[1]: Starting Armbian memory supported logging...
    Oct 18 14:16:35 localhost kernel: [ 0.323289] regulator-dummy: no parameters
    Oct 18 14:16:35 localhost systemd[1]: Started Raise network interfaces.
    Oct 18 14:16:35 localhost kernel: [ 0.324240] NET: Registered protocol family 16
    Oct 18 14:16:35 localhost kernel: [ 0.334966] cpuidle: using governor ladder
    Oct 18 14:16:35 localhost kernel: [ 0.342065] cpuidle: using governor menu
    Oct 18 14:16:35 localhost armbian-ramlog[613]: Mounting /dev/zram0 as /var/log/
    Oct 18 14:16:35 localhost kernel: [ 0.342107] Registered FIQ tty driver
    Oct 18 14:16:35 localhost kernel: [ 0.343018] vdso: 2 pages (1 code @ ffffff8008bc6000, 1 data @ ffffff8009114000)
    Oct 18 14:16:35 localhost armbian-ramlog[613]: Fr 18. Okt 14:16:34 CEST 2019: Loading logs from storage
    Oct 18 14:16:35 localhost kernel: [ 0.343059] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    Oct 18 14:16:35 localhost kernel: [ 0.343921] DMA: preallocated 2048 KiB pool for atomic allocations
    Oct 18 14:16:35 localhost kernel: [ 0.362887] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
    Oct 18 14:16:35 localhost kernel: [ 0.363026] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
    Oct 18 14:16:35 localhost armbian-ramlog[613]: sending incremental file list
    Oct 18 14:16:35 localhost kernel: [ 0.363156] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
    Oct 18 14:16:35 localhost kernel: [ 0.363295] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
    Oct 18 14:16:35 localhost kernel: [ 0.471410] raid6: int64x1 gen() 203 MB/s
    Oct 18 14:16:35 localhost armbian-ramlog[613]: ./
    Oct 18 14:16:35 localhost kernel: [ 0.539448] raid6: int64x1 xor() 190 MB/s
    Oct 18 14:16:35 localhost kernel: [ 0.607456] raid6: int64x2 gen() 328 MB/s
    Oct 18 14:16:35 localhost kernel: [ 0.675648] raid6: int64x2 xor() 261 MB/s
    Oct 18 14:16:35 localhost kernel: [ 0.743744] raid6: int64x4 gen() 482 MB/s
    Oct 18 14:16:35 localhost armbian-ramlog[613]: alternatives.log
    Oct 18 14:16:35 localhost kernel: [ 0.811802] raid6: int64x4 xor() 329 MB/s
    Oct 18 14:16:35 localhost kernel: [ 0.880052] raid6: int64x8 gen() 388 MB/s
    Oct 18 14:16:35 localhost kernel: [ 0.948069] raid6: int64x8 xor() 304 MB/s
    Oct 18 14:16:35 localhost armbian-ramlog[613]: armbian-hardware-monitor.log
    Oct 18 14:16:35 localhost kernel: [ 1.016227] raid6: neonx1 gen() 364 MB/s
    Oct 18 14:16:35 localhost kernel: [ 1.084334] raid6: neonx1 xor() 341 MB/s
    Oct 18 14:16:35 localhost kernel: [ 1.152458] raid6: neonx2 gen() 552 MB/s
    Oct 18 14:16:35 localhost kernel: [ 1.220574] raid6: neonx2 xor() 500 MB/s
    Oct 18 14:16:35 localhost armbian-ramlog[613]: auth.log
    Oct 18 14:16:35 localhost kernel: [ 1.288724] raid6: neonx4 gen() 749 MB/s
    Oct 18 14:16:35 localhost kernel: [ 1.356781] raid6: neonx4 xor() 563 MB/s
    Oct 18 14:16:35 localhost kernel: [ 1.424942] raid6: neonx8 gen() 766 MB/s
    Oct 18 14:16:35 localhost armbian-ramlog[613]: bootstrap.log
    Oct 18 14:16:35 localhost kernel: [ 1.493006] raid6: neonx8 xor() 579 MB/s
    Oct 18 14:16:35 localhost kernel: [ 1.493018] raid6: using algorithm neonx8 gen() 766 MB/s
    Oct 18 14:16:35 localhost kernel: [ 1.493027] raid6: .... xor() 579 MB/s, rmw enabled
    Oct 18 14:16:35 localhost armbian-ramlog[613]: btmp
    Oct 18 14:16:35 localhost kernel: [ 1.493036] raid6: using intx1 recovery algorithm
    Oct 18 14:16:35 localhost kernel: [ 1.493532] mpp venc_srv: mpp_probe enter
    Oct 18 14:16:35 localhost kernel: [ 1.493568] mpp venc_srv: init success
    Oct 18 14:16:35 localhost armbian-ramlog[613]: daemon.log
    Oct 18 14:16:35 localhost kernel: [ 1.494392] rockchip-pm rockchip-suspend: not set wakeup-config
    Oct 18 14:16:35 localhost kernel: [ 1.494409] rockchip-pm rockchip-suspend: not set pwm-regulator-config
    Oct 18 14:16:35 localhost kernel: [ 1.495844] of_get_named_gpiod_flags: parsed 'gpio' property of node '/sdmmc-regulator[0]' - status (0)
    Oct 18 14:16:35 localhost kernel: [ 1.496250] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
    Oct 18 14:16:35 localhost kernel: [ 1.496269] vcc_sd: unable to resolve supply
    Oct 18 14:16:35 localhost kernel: [ 1.496286] reg-fixed-voltage sdmmc-regulator: vcc_sd supplying 3300000uV
    Oct 18 14:16:35 localhost armbian-ramlog[613]: faillog
    Oct 18 14:16:35 localhost kernel: [ 1.496544] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-5v-regulator[0]' - status (0)
    Oct 18 14:16:35 localhost kernel: [ 1.496605] reg-fixed-voltage vcc-host-5v-regulator: Looking up vin-supply from device tree
    Oct 18 14:16:35 localhost kernel: [ 1.496665] vcc_host_5v: unable to resolve supply
    Oct 18 14:16:35 localhost armbian-ramlog[613]: kern.log
    Oct 18 14:16:35 localhost kernel: [ 1.496687] vcc_host_5v: no parameters
    Oct 18 14:16:35 localhost kernel: [ 1.496964] reg-fixed-voltage vcc-host-5v-regulator: Looking up vin-supply from device tree
    Oct 18 14:16:35 localhost kernel: [ 1.497028] vcc_host_5v: regulator get failed, ret=-517
    apollon77A Online
    apollon77A Online
    #841
    @smartboart ohne da jetzt mega tief rein zu schauen klinge das doch mal interessant das irgendwas mit power war und damit kann es exakt das sein das die Netzwerk Hardware mal kurz weg war.
    smartboartS 2 Antworten Letzte Antwort
    • apollon77A apollon77
      smartboartS Offline
      smartboartS Offline
      smartboart
      #842
      @apollon77 ja vielen Dank für den Hinweis... Behalte das mal im Auge.. Dachte es hat mit dem neuen Controller zutun weil ich es vorher nicht hatte... Wie gesagt bekomme das ja durch die telegramm meldung mit wenn was neu startet..hänge mal ein Messgeraet / logger dran...
      • J Offline
        Jan1
        #843
        @apollon77
        ich habe ein paar Kleinigkeiten im Log nach einem iobroker restart und weiß nicht ob's vom controller kommt, oder von den Adaptern. Schaus mal bitte kurz an, laufen tut ja alles.
        history.0	2019-10-19 09:34:48.241	error	(COMPACT) Cannot find view "system" for search "instance" : Error: Connection is closed.
        alexa2.0	2019-10-19 09:34:48.244	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        web.0	2019-10-19 09:34:48.243	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        history.0	2019-10-19 09:34:48.240	error	(COMPACT) Cannot find view "system" for search "instance" : Error: Connection is closed.
        iot.0	2019-10-19 09:34:48.239	warn	(COMPACT) get state Error: Connection is closed.
        • J Jan1
          @apollon77
          apollon77A Online
          apollon77A Online
          #844
          @Jan1 Diese Meldungen kommen wenn ein Adapter sich beendet aber die Verbindung zur DB weg ist - der will dann noch ein paar Dinge aufräumen, schaffts aber nicht weil er die Daten nicht bekommt. Von daher in dem Fall ok
          J 1 Antwort Letzte Antwort
            Jan1
            #845
            @apollon77
            Alles klar, ist ja auch sonst nix negatives aufgefallen.
            IOBroker rennt bei mir derzeit richtig gut, schnell und ohne irgendwelche Auffälligkeiten, saubere Arbeit.
            • FredFF Online
              FredFF Online
              FredF
              Most Active Forum Testing
              #846
              @apollon77
              Bin jetzt auch auf 2.0.34 und kann nur das was @Jan1 schreibt bestätigen.
              Läuft wie schmitz katz.
              Ich sage mal Danke für deinen unermüdlichen Einsatz
              • FredFF FredF
                @apollon77
                apollon77A Online
                apollon77A Online
                #847
                @FredF danke. Wir werkeln gerade noch an drei Themen. Zwei sind schon done (noch ein alias fix und die Hänger bei Updates von 1.5. auf 2.0). Das dritte sind die permission Fehler bei files bzw vis ... das ist noch offen. Das kann ich noch nicht nachstellen :-( aber wir sind dran.
                • apollon77A Online
                  apollon77A Online
                  #848
                  Hi All,
                  Auf Github gibt es die 2.0.35 die heute Abend vorauss. ins Latest kommt.
                  Fixes:
                  • (Apollon77) Allow to use Redis password as "pass" parameter for States ad Objects
                  • (Apollon77) Prevent hangs on "iobroker upgrade self" from 1.5 to 2.0
                  • (bluefox) Update IPs information periodically
                  • (bluefox) Remove safe-replace, bluebird, pyconf packages
                  • (bluefox) Fix alias logic in some places
                  • (paul53/AlCalzone/Apollon77) Fix datatype of system.host.cpu and system.adapter.XY.Z.cpu
                  • (Apollon77) Make sure alias.0 and other controller objects are also checked and created if needed on setup first when updating
                  • (bluefox) Allow one state to multiple aliases connections
                  Einziges noch offenes Thema, was wir aber noch nicht nachstellen konnten ist das, das bisher bei 2 Usern nach dem Update Vis mit einem PermissionError nicht mehr lädt :-(
                  arteckA sigi234S 2 Antworten Letzte Antwort
                    Hi All,
                    Fixes:
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #849
                    @apollon77 hängts mit dem auth zusammen ??? vielleicht ?? also mein altes problem
                    • arteckA arteck
                      apollon77A Online
                      apollon77A Online
                      #850
                      @arteck Das Web bei Ihm läuft als Admin und so ... Also kein Auth im Spiel
                        Hi All,
                        Fixes:
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        #851
                        @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                        Geht nicht bei mir bleibt bei 34?
                        Immer Daten sichern!
                        • sigi234S sigi234
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          #852
                          @sigi234 sagte in [Aufruf] js-controller 2.0 Beta Test:
                          dito. bei mir auch, gerade probiert
                          • apollon77A Online
                            apollon77A Online
                            #853
                            ääähm ja .... commit auf der Strecke geblieben. Wenn alles final ist machen wir eine .36 draus damit es keine Verwirrung gibt. Wenn Ihr aber von GitHub aktualisiert habt habt Ihr die Änderungen erhalten auch wenn .34 dran steht ;-)
                            • dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #854
                              @apollon77
                              das hier taucht immer wieder im Log auf, wenn ich mich bei iQontrol an/abmelde bzw. es öffne. Gehört das zum js-controller oder web Adapter oder iQontrol ?
                              Error	2019-10-21 21:02:06.171	warn	from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.
                              web.0	2019-10-21 21:02:05.006	info	(985) ==>Connected system.user.admin from 192.168.1.99
                              web.0	2019-10-21 21:00:50.572	info	(985) <==Disconnect system.user.admin from 192.168.1.99 iqontrol.0
                              web.0	2019-10-21 20:43:01.606	info	(985) ==>Connected system.user.admin from 192.168.1.99
                              und was ist damit gemeint ? namespace cfg. ?
                              iQontrol 0.2.12
                              web 2.4.6
                              admin 3.6.10
                              js-controller 2.0.34
                              • N Offline
                                N Offline
                                NightWatcher
                                #855
                                Ich glaube, bei mir hat er heute nacht ein update ohne mein zutun gemacht. (es stand komischerweise noch 2.0.34 im Admin.
                                Die Weboberfläche tat noch, aber in der Console ging nichts mehr. Immer nur "No objects found".
                                Also mal iobroker restart... NICHTS...
                                Jetzt geht gar nichts mehr. Ich kann weder den ioBroker starten, noch ein Update fahren.
                                Wago 750-881 - mit über 200 Ein- und Ausgängen, DMX512 Art-Net für Beleuchtung, 1-Wire für Umweltsensoren Aussen und Innen, ioBroker als Visualisierung
                                arteckA apollon77A 2 Antworten Letzte Antwort
                                • N NightWatcher
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #856
                                  @NightWatcher sagte in [Aufruf] js-controller 2.0 Beta Test:
                                  nö..nie im leben... einfach so passiert da garnix
                                  was hast du in dem Ordner liegen ??
                                  • N Offline
                                    N Offline
                                    NightWatcher
                                    #857
                                    Welchen Ordner meinst du? c:\ioBroker ist mein iobroker Hauptverzeichnis.
                                    • N NightWatcher
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #858
                                      c:\ioBroker
                                      dann zeig den mal.. ist da was drin ??
                                      • N Offline
                                        N Offline
                                        NightWatcher
                                        #859
                                        • N NightWatcher
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #860
                                          @NightWatcher gestern um 19:22 hat sich der inhalt des Ordners node_modules geändert..
                                          zeigmnal das LOG
