  5. Unifi WLAN Script 2 mit Anwesenheitskontrolle
    6.0k
javascriptmonitoring
1.4k Beiträge 46 Kommentatoren 588.0k Aufrufe 51 Beobachtet
  • liv-in-skyL liv-in-sky
    @dslraser hätte nochmal was zum testen
    habe mal versucht einen extra case zu machen
    unifi-skipt-mit-sondecase.txt
    dslraserD Offline
    dslraserD Offline
    dslraser
    #981
    @liv-in-sky sagte in Unifi WLAN Script 2 mit Anwesenheitskontrolle:
    läuft nicht...
    javascript.0	2019-12-10 15:02:09.567	error	(413) at Timer.processTimers (timers.js:223:10)
    javascript.0	2019-12-10 15:02:09.567	error	(413) at listOnTimeout (timers.js:263:5)
    javascript.0	2019-12-10 15:02:09.567	error	(413) at tryOnTimeout (timers.js:300:5)
    javascript.0	2019-12-10 15:02:09.567	error	(413) at ontimeout (timers.js:438:13)
    javascript.0	2019-12-10 15:02:09.567	error	(413) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2016:34)
    javascript.0	2019-12-10 15:02:09.566	error	(413) at Object.<anonymous> (script.js.09_Unifi.Unifi-Test-4-Sondercase:660:98)
    javascript.0	2019-12-10 15:02:09.565	error	(413) Error in callback: TypeError: Cannot read property 'name' of undefined
    10.12.2019, 15:03:05.863	[info ]: javascript.0 (413) Stop script script.js.09_Unifi.Unifi-Test-4-Sondercase
    10.12.2019, 15:03:06.555	[warn ]: javascript.0 (413)     at workAP (script.js.09_Unifi.Unifi-Test-4-Sondercase:1466:44)
    10.12.2019, 15:03:06.556	[warn ]: javascript.0 (413)     at Object.setInterval (script.js.09_Unifi.Unifi-Test-4-Sondercase:1900:38)
    10.12.2019, 15:03:06.556	[warn ]: javascript.0 (413)     at workAP (script.js.09_Unifi.Unifi-Test-4-Sondercase:1467:50)
    10.12.2019, 15:03:06.557	[warn ]: javascript.0 (413)     at Object.setInterval (script.js.09_Unifi.Unifi-Test-4-Sondercase:1900:38)
    10.12.2019, 15:03:06.558	[warn ]: javascript.0 (413)     at workAP (script.js.09_Unifi.Unifi-Test-4-Sondercase:1482:44)
    10.12.2019, 15:03:06.558	[warn ]: javascript.0 (413)     at Object.setInterval (script.js.09_Unifi.Unifi-Test-4-Sondercase:1900:38)
    10.12.2019, 15:03:06.558	[warn ]: javascript.0 (413)     at workAP (script.js.09_Unifi.Unifi-Test-4-Sondercase:1483:50)
    10.12.2019, 15:03:06.559	[warn ]: javascript.0 (413)     at Object.setInterval (script.js.09_Unifi.Unifi-Test-4-Sondercase:1900:38)
    10.12.2019, 15:03:09.485	[error]: javascript.0 (413)     at Object.<anonymous> (script.js.09_Unifi.Unifi-Test-4-Sondercase:660:98)
      dslraserD Offline
      dslraserD Offline
      dslraser
      #982
      @liv-in-sky
      1900:38
                                           workAP(apName[ap_name].aname); }
      660:98
                 if(!versuch[z].hasOwnProperty("_last_seen_by_uap") && wlanClientDB.includes(versuch[i][myname])) caseHelper=5;
      • dslraserD dslraser
        @liv-in-sky
        1900:38
        660:98
        liv-in-skyL Offline
        liv-in-skyL Offline
        liv-in-sky
        #983
        @dslraser bitte in zeile 660 - bitte das i in z ändern beim zweiten versuch[i]
        die andere zeile könnte dann verschwinden - an dieser stelle habe ich nichts verändert - unter zeile 1500 war ich schon lange nicht mehr - weiß garnicht, wie es da unten aussieht :-)
          @liv-in-sky
          1900:38
          660:98
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          #984
          @dslraser habe übrigens gute erfahrung mit anydesk gemacht - ein gemeinsamer test wäre cool - wenn es zeitlich wieder mal paßt
            dslraserD Offline
            dslraserD Offline
            dslraser
            #985
            läuft "fast" !
            Einmal von drei Versuchen blieb der DP false, obwohl am WLAN angemeldet und der AP Name in Wifi_Client_Network von noConn auf den AP Namen gewechselt hat. Danach nochmal WLAN an/aus, dann funktionierte es.
              läuft "fast" !
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              #986
              @dslraser es könnte sein, das am anfang das wifi gerät noch nicht als solches in meiner datenbank drinsteht - aber nur ein längerer test wird das zeigen - und auch ob nach jedem script start noch alles klappt
              der DP wird nur an einer stelle auf true gesetzt - und dies sollte immer geschehen, wenn der datenpunkt false ist und die daten einen last_seen_by_uap haben - was ja hoffentlich von unifi so kommt
              es müßten auch die html files (iqontrol und vis) kontrolliert werden - auch die sind im vergleich mit drin und sollten upgedatet werden
                dslraserD Offline
                dslraserD Offline
                dslraser
                #987
                @liv-in-sky
                okay, ich beobachte und werde berichten.
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  #988
                  @dslraser merci
                    dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #989
                    @liv-in-sky
                    Die DP funktionieren soweit, denke ich.
                    Nur ich glaube die Listen für iQontrol bekommen die geänderten Daten nicht oder vielleicht auch erst irgendwann später ? iQontrol habe ich mehrfach aktualisiert (also die Anzeige), aber mein Note10 (das habe ich probiert) zeigt in dem neuen Network DP alles richtig an, nur die iQontrol Liste zeigt noch den alten/vorherigen AP an.
                    Richtig: (Keller)
                    Liste-falsch: (Wohnzimmer)
                    Edit: letztes File Update in der Liste ist übrigens auch länger her, wahrscheinlich schreibst Du die Liste nur neu wenn sich true/false eines Gerätes ändert, aber nicht wenn der AP eines Gerätes wechselt ?
                    • F Frank579
                      @liv-in-sky
                      wenn du jemanden für ne Team Viewer benötigst melde dich mal bin zwar zur zeit Beruflich ziemlich eingespannt, aber vill passt es ja mal ..
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #990
                      @Frank579 wenn ich meine SSID auf hide stelle, können meine tablets und handys nicht mehr ins internet - alexa scheint zu funktionieren
                      wie ist das bei dir
                      F 1 Antwort Letzte Antwort
                        @liv-in-sky
                        Richtig: (Keller)
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        liv-in-sky
                        #991
                        @dslraser sagte in Unifi WLAN Script 2 mit Anwesenheitskontrolle:
                        yup - das kann gut sein - die netzwerkanehörigkeit kam erst später dazu - files werden nur geschrieben, wenn sich deren zustand ändert - kommt auf die liste
                          @liv-in-sky
                          Richtig: (Keller)
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #992
                          Richtig: (Keller)
                          hier sollte der ap-wechsel im file (also iqontrol) angezeigt werden - wird auch das noConn angezeigt ?
                          bitte sehr:
                          es wäre cool, wenn du auch mal in den vis-tables-dp nachsehen könntest, ob da noConn drinsteht
                            Richtig: (Keller)
                            bitte sehr:
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #993
                            bitte sehr:
                            So, ich denke es passt.👍👍👍
                            VIS nutze ich nicht. Die DP Werte müsste ich mir jetzt alle raus kopieren und in Textdateien ansehen, das schaffe ich heute nicht mehr.(ich muss mich gleich erstmal um was anderes kümmern)
                            iQontol passt denke ich. (ausser bei noConn steht ein undefined als WLAN Name, es sei denn es ist so gewollt, habe ich jetzt im Script nicht nachgesehen.)
                            Der DP Disconect (Anzahl ) kam etwas später.
                            Für mich für heute erstmal alles gut. Schöner Fortschritt👍. Dann hat sich das Telefonat und unsere gemeinsame Idee wohl ausgezahlt...
                            Ich werde weiter beobachten und berichten wenn mir was auffällt.
                              bitte sehr:
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              liv-in-sky
                              #994
                              @dslraser und wie sich das gelohnt hat - ohne unsere session wäre nicht viel erreicht worden - nochmals danke dafür und auch fürs testen
                              hier noch eine kleine verbesserung undefined sollte nirgends stehen ! daher
                              ich weiß, du benutzt vis nicht, aber es wäre trotzdem nett, wenn du mir die inhalte der datenpunkte sendest- oder kopiere sie einfach in eine datei und poste sie mir - vorallem im zustand noConn - wenn das handy nicht angemeldet ist !
                              diese inhalte wären es:
                              javascript.2.WLANUnifi.Wifi_Clients
                              javascript.2.WLANUnifi.Wifi_ClientsOnlyDISC
                              javascript.2.WLANUnifi.Wifi_ClientsOnlyLAN
                              javascript.2.WLANUnifi.Wifi_ClientsOnlyWLAN
                              dslraserD M 3 Antworten Letzte Antwort
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #995
                                <table><tr style="color:#01A9DB; font-family:Helvetica;font-style: italic;" ><td>Heiko-Note10&ensp;</td><td>noConn&ensp;&ensp;&ensp;&ensp;</td><td>noConn&ensp;&ensp;</td><td>noConn</td></tr><tr><td>Kerstin-Note8&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.101&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Kerstin-iPad&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.102&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Heiko-Uhr&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.103&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>CloudKey-Unif-Controller&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.111&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>DSHOME-LAN1&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.248&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>DSHOME-LAN2&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.249&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>DSHOME-macvlan&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.250&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>ECHO-Wohnzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.40&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>ECHO-Kueche&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.41&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>ECHO-Badezimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.42&ensp;&ensp;</td><td>Gästezimmer</td></tr><tr><td>ECHO-Gaeste-WC&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.43&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>ECHO-Gaestezimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.44&ensp;&ensp;</td><td>Gästezimmer</td></tr><tr><td>ECHO-Flur&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.45&ensp;&ensp;</td><td>Keller</td></tr><tr><td>ECHO-Schlafzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.46&ensp;&ensp;</td><td>Schlafzimmer</td></tr><tr><td>ECHO-Keller-Flur&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.47&ensp;&ensp;</td><td>Schlafzimmer</td></tr><tr><td>ECHO-Werkstatt&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.48&ensp;&ensp;</td><td>Keller</td></tr><tr><td>ECHO-Keller-Wohnzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.49&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Harmony-Hub-Wohnzimmer&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.50&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Harmony-Hub-Schlafzimmer&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.51&ensp;&ensp;</td><td>Gästezimmer</td></tr><tr><td>VU-Zero-Schlafzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.52&ensp;&ensp;</td><td>Keller</td></tr><tr><td>VUSOLO2&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.53&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Staubsauger&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.54&ensp;&ensp;</td><td>Schlafzimmer</td></tr><tr><td>CHROMECAST-ULTRA&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.56&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Kamera-Eingang&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.58&ensp;&ensp;</td><td>Switch_08</td></tr><tr><td>Kamera-Garten&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.59&ensp;&ensp;</td><td>Switch_08</td></tr><tr><td>Kamera-Parkplatz&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.60&ensp;&ensp;</td><td>Garage</td></tr><tr><td>DENON-AVR&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.61&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>TV-Wohnzimmer&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.63&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>HUE-BRIDGE&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.64&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Fritz-Box&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.65&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Raspberrymatic&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.66&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Heiko-Mac-Book-Pro&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.99&ensp;&ensp;</td><td>Wohnzimmer</td></tr></table>
                                <table><tr style="color:#01A9DB; font-family:Helvetica;font-style: italic;" ><td>Heiko-Note10&ensp;</td><td>noConn&ensp;&ensp;&ensp;&ensp;</td><td>noConn&ensp;&ensp;</td><td>noConn</td></tr></table>
                                <table><tr><td>CloudKey-Unif-Controller&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.111&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>DSHOME-LAN1&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.248&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>DSHOME-LAN2&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.249&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>DSHOME-macvlan&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.250&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>VUSOLO2&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.53&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>CHROMECAST-ULTRA&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.56&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Kamera-Eingang&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.58&ensp;&ensp;</td><td>Switch_08</td></tr><tr><td>Kamera-Garten&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.59&ensp;&ensp;</td><td>Switch_08</td></tr><tr><td>DENON-AVR&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.61&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>TV-Wohnzimmer&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.63&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>HUE-BRIDGE&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.64&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Fritz-Box&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.65&ensp;&ensp;</td><td>Switch_16</td></tr><tr><td>Raspberrymatic&ensp;</td><td>LAN&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.66&ensp;&ensp;</td><td>Switch_16</td></tr></table>
                                <table><tr><td>Kerstin-Note8&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.101&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Kerstin-iPad&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.102&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Heiko-Uhr&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.103&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>ECHO-Wohnzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.40&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>ECHO-Kueche&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.41&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>ECHO-Badezimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.42&ensp;&ensp;</td><td>Gästezimmer</td></tr><tr><td>ECHO-Gaeste-WC&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.43&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>ECHO-Gaestezimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.44&ensp;&ensp;</td><td>Gästezimmer</td></tr><tr><td>ECHO-Flur&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.45&ensp;&ensp;</td><td>Keller</td></tr><tr><td>ECHO-Schlafzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.46&ensp;&ensp;</td><td>Schlafzimmer</td></tr><tr><td>ECHO-Keller-Flur&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.47&ensp;&ensp;</td><td>Schlafzimmer</td></tr><tr><td>ECHO-Werkstatt&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.48&ensp;&ensp;</td><td>Keller</td></tr><tr><td>ECHO-Keller-Wohnzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.49&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Harmony-Hub-Wohnzimmer&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.50&ensp;&ensp;</td><td>Wohnzimmer</td></tr><tr><td>Harmony-Hub-Schlafzimmer&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.51&ensp;&ensp;</td><td>Gästezimmer</td></tr><tr><td>VU-Zero-Schlafzimmer&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.52&ensp;&ensp;</td><td>Keller</td></tr><tr><td>Staubsauger&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.54&ensp;&ensp;</td><td>Schlafzimmer</td></tr><tr><td>Kamera-Parkplatz&ensp;</td><td>HKH&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.60&ensp;&ensp;</td><td>Garage</td></tr><tr><td>Heiko-Mac-Book-Pro&ensp;</td><td>HKA&ensp;&ensp;&ensp;&ensp;</td><td>192.168.1.99&ensp;&ensp;</td><td>Wohnzimmer</td></tr></table>
                                Der hier passt gerade wieder nicht
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  #996
                                  @liv-in-sky
                                  ich glaube VIS dauert etwas länger, da zum Teil jetzt im DP javascript.2.WLANUnifi.Wifi_ClientsOnlyDISC
                                  Werte drinn stehen, habe ich eben oben im Beitrag ausgetauscht.
                                  Der ist jetzt auch richtig
                                  • F Frank579
                                    @liv-in-sky
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #997
                                    @Frank579 du könntest dieses file auch mal gerne ausprobieren - bei dir treten die fehler ja auch auf
                                    @hartwigm auch bei dir wäre es interessant das zu testen - du hast ja das problem (bug) nicht (noch nicht) - daher würde ich gerne wissen, ob das script bei dir noch stabil läuft
                                    gerne können wir das zusammen testen - dann einfach im chat melden
                                    im script ist nur der teil unter "AB HIER NICHTS MEHR ÄNDERN..." dabei - kopiert das momentan laufende script und stoppt es - dann im kopierten script den folgenden teil aus der datei ersetzen
                                      wie ist das bei dir
                                      Frank579
                                      #998
                                      @liv-in-sky
                                      Bei mir funktioniert alles musste nur einem Tablet sagen das es ein Verstecktes Netzwerk ist , da es das sonst nich gefunden hat. Wie gesagt bei mir sind die netzweke grundsätzlich augeblendet, außer wenn ich ein Shelly o.Ä. anlerne wo ich nur Netzwerke Auswählen und den Namen nicht schreiben kann, und dann wieder aus. Bis jetzt immer ohne Probleme ....
                                        Frank579
                                        #999
                                        @liv-in-sky
                                        ja werde ich mal Testen, weiß abe nicht ob ich Heute noch dazu komme :/ ....denke eher morgen melde mich dann bei dir
                                        • F Frank579
                                          @liv-in-sky
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          #1000
                                          @Frank579 sagte in Unifi WLAN Script 2 mit Anwesenheitskontrolle:
                                          @liv-in-sky
                                          gibt man das unter WLAN im handy an - ich kann keine solche einstellung finden
