  4. [Neuer Adapter] LinkedDevices
    6.0k
adapter
464 Beiträge 68 Kommentatoren 173.0k Aufrufe 57 Beobachtet
  • M MyMeyer
    @Scrounger Hallo Srounger , nutzt den Adapter auch seit ein paar Tagen.
    Heute bekomme ich plötzlich diese Meldung alle 15 Sekunden im Log.
    Kannst Du was zum Fehler sagen ? Wie kann ich den Fehler abstellen ? ?
    linkeddevices.0	2020-05-12 20:19:35.004	debug	(32320) [resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Rauchmelder Büro.lowbattery'
    linkeddevices.0	2020-05-12 20:19:34.999	debug	(32320) [resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Rauchmelder Büro.battery'
    linkeddevices.0	2020-05-12 20:19:34.952	debug	(32320) [resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Rauchmelder Büro.on'
    linkeddevices.0	2020-05-12 20:19:34.923	debug	(32320) [getSystemConfig] system configs successful loaded: '{"language":"de","dateFormat":"DD.MM.YYYY","durationFormat":"dd[T] hh[h] mm[m]"}'
    linkeddevices.0	2020-05-12 20:19:34.908	info	(32320) [initialObjects] started...
    linkeddevices.0	2020-05-12 20:19:34.907	debug	(32320) [onReady] deleteDeadLinkedObjects: 'false'
    linkeddevices.0	2020-05-12 20:19:34.886	info	(32320) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.linkeddevices, node: v10.19.0
    linkeddevices.0	2020-05-12 20:19:33.140	warn	(31695) Got terminate signal. Checking desired PID: 32320 vs own PID 31695
    linkeddevices.0	2020-05-12 20:19:33.139	info	(31695) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    linkeddevices.0	2020-05-12 20:19:33.138	info	(31695) terminating
    linkeddevices.0	2020-05-12 20:19:33.138	info	(31695) cleaned everything up...
    linkeddevices.0	2020-05-12 20:19:33.137	warn	(31695) Got terminate signal. Checking desired PID: 0 vs own PID 31695
    linkeddevices.0	2020-05-12 20:19:21.685	debug	(31695) [onStateChange] parentObject state 'mqtt.0.Gaszaehler.Zaehler_0.Entprellzeit' timestamp changed --> set linkedObject state 'linkeddevices.0.Gasverbrauch.Entprellzeit' to '1000'
    linkeddevices.0	2020-05-12 20:19:21.627	debug	(31695) [onStateChange] parentObject state 'mqtt.0.Gaszaehler.Zaehler_0.Impulse' timestamp changed --> set linkedObject state 'linkeddevices.0.Gasverbrauch.Impulse' to '1800'
    linkeddevices.0	2020-05-12 20:19:07.432	info	(31695) [initialObjects] finished
    Was ist das Problem ?
    arteckA Offline
    arteckA Offline
    arteck
    #201
    @MyMeyer welches Problem ??
    • ScroungerS Scrounger
      @MyMeyer sagte in [Neuer Adapter] LinkedDevices:
      Also laut log gibt es keinen Fehler, gibt keine error meldung
      Warum lässt du den Adapter im debug mode laufen?
      Im Debug Modus schreibt der natürlich sehr viel ins log.
      MyMeyer
      schrieb am zuletzt editiert von MyMeyer
      #202
      @Scrounger sagte in [Neuer Adapter] LinkedDevices:
      @Scrounger und @arteck Steht nicht im Log das der Adapter alle ca. 30 Sekunden neustartet und wäre das dann normal ? Ich hattet es als unnormal verstanden.
      host.iobroker 2020-05-14 09:44:53.837 info Restart adapter system.adapter.linkeddevices.0 because enabled
      host.iobroker 2020-05-14 09:44:53.836 error instance system.adapter.linkeddevices.0 terminated with code 156 (156)
      linkeddevices.0 2020-05-14 09:44:53.315 warn (1416) Got terminate signal. Checking desired PID: 2055 vs own PID 1416
      linkeddevices.0 2020-05-14 09:44:53.314 info (1416) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      linkeddevices.0 2020-05-14 09:44:53.314 info (1416) terminating
      linkeddevices.0 2020-05-14 09:44:53.313 info (1416) cleaned everything up...
      linkeddevices.0 2020-05-14 09:44:53.313 warn (1416) Got terminate signal. Checking desired PID: 0 vs own PID 1416
      host.iobroker 2020-05-14 09:44:53.310 info instance system.adapter.linkeddevices.0 started with pid 2055
      host.iobroker 2020-05-14 09:47:26.624 error instance system.adapter.linkeddevices.0 terminated with code 156 (156)
      host.iobroker 2020-05-14 09:46:56.072 error instance system.adapter.linkeddevices.0 terminated with code 156 (156)
      host.iobroker 2020-05-14 09:46:25.507 error instance system.adapter.linkeddevices.0 terminated with code 156 (156)
      host.iobroker 2020-05-14 09:45:54.962 error instance system.adapter.linkeddevices.0 terminated with code 156 (156)
      host.iobroker 2020-05-14 09:45:24.399 error instance system.adapter.linkeddevices.0 terminated with code 156 (156)
      So geht es alle 30 Sekunden.
      MyMeyer
      >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
      >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
        MyMeyer
        #203
        @Scrounger hmm...habe mal Reparatur Button gedrückt und nun läuft der Adapter durch. Bisher seit 60 Minuten. Was macht der Reparatur Button genau?
        MyMeyer
        ScroungerS 1 Antwort Letzte Antwort
        • M MyMeyer
          ScroungerS Offline
          ScroungerS Offline
          Scrounger
          #204
          https://forum.iobroker.net/topic/22301/neuer-adapter-linkeddevices/151
            ich möchte euch meinen neuen Adapter an dem ich aktuell arbeite vorstellen - LinkedDevices.
            Die Idee und insperation kommen aus dem Virtual Devices Skript von @Pman.
            https://github.com/Scrounger/ioBroker.linkeddevices
            Funktionsweise:
            Ihr könnt euch verlinkte Objekte (Datenpunkte) für all eure verwendeten Objekte (Datenpunkte) anlegen und dafür individuelle IDs vergeben, um Euch eine Struktur anzulegen, wie Ihr sie gerne haben möchtet.
            Vorteil ist, dass es nur noch einen Ort gibt, wo alle Objekte die Ihr im vis oder Skripten verwendet, definert sind. Weiterer Vorteil ist, wenn ihr mal die Hardware tauschen müsst, dann müsst ihr nur die verlinkten Objekte auf die neue Hardware anpassen und die Skripte und vis funktionieren sofort wieder.
            Später sollen noch Funktionen wie z.B. umrechnungen etc. dazu kommen, wie es im Virtual Devices Skript auch möglich ist
            Aktuell findet ihr im Repository einen Arbeitsstand (Alpha version!), deshalb bitte nicht im produktiv einsetzen, weil ich aktuell daran noch arbeite.
            Hier mal ein Beispiel wie eine selbstdefinierte Struktur aussehen kann:
            Bild Text
            paypal
            sigi234S Online
            sigi234S Online
            sigi234
            #205
            @Scrounger
            Hallo, irgendwo habe ich einen Fehler:
            linkeddevices.0	2020-06-07 10:57:11.560	error	(1576) [getConvertedValue] there is something wrong with your datetime parser, check your expert settings input for 'linkeddevices.0.Start Abend.startAbend'!
            linkeddevices.0	2020-06-07 10:57:11.559	error	(1576) [getConvertedValue] there is something wrong with your datetime parser, check your expert settings input for 'linkeddevices.0.Start Morgen.startMorgen'!
            RAW vom DP:
              "from": "system.adapter.gartenbewaesserung.0",
              "user": "system.user.admin",
              "ts": 1587042880603,
              "common": {
                "name": "startAbend",
                "role": "indicator",
                "type": "string",
                "unit": "Uhr",
                "write": false,
                "read": true,
                "custom": {
                  "linkeddevices.0": {
                    "enabled": true,
                    "number_unit": "",
                    "linkedId": "Start Abend.startAbend",
                    "name": "Start Abend",
                    "role": "",
                    "mergeSettingsOnRestart": false,
                    "expertSettings": true,
                    "number_convertTo": "",
                    "number_maxDecimal": "",
                    "number_min": "",
                    "number_max": "",
                    "number_calculation": "",
                    "number_calculation_readOnly": "",
                    "number_to_boolean_condition": "",
                    "number_to_boolean_value_true": "",
                    "number_to_boolean_value_false": "",
                    "number_to_string_condition": "",
                    "number_to_duration_convert_seconds": "",
                    "number_to_duration_format": "",
                    "number_to_datetime_convert_seconds": "",
                    "number_to_datetime_format": "",
                    "number_to_multi_condition": "",
                    "boolean_convertTo": "",
                    "boolean_to_string_value_true": "",
                    "boolean_to_string_value_false": "",
                    "string_convertTo": "datetime",
                    "string_prefix": "",
                    "string_suffix": "",
                    "string_to_boolean_value_true": "",
                    "string_to_boolean_value_false": "",
                    "string_to_number_unit": "",
                    "string_to_number_maxDecimal": "",
                    "string_to_number_calculation": "",
                    "string_to_number_calculation_readOnly": "",
                    "string_to_duration_format": "",
                    "string_to_datetime_parser": "'y[J] d[T] hh[h] mm[m]'",
                    "string_to_datetime_format": "LLLL"
              "native": {},
              "acl": {
                "object": 1636,
                "owner": "system.user.admin",
                "state": 1636
              "_id": "gartenbewaesserung.0.status.startAbend",
              "type": "state"
            Immer Daten sichern!
            • sigi234S sigi234
              @Scrounger
              RAW vom DP:
                "common": {
                  "type": "string",
                  "unit": "Uhr",
                  "write": false,
                  "read": true,
                  "custom": {
                      "enabled": true,
                      "number_unit": "",
                      "role": "",
                      "number_min": "",
                      "number_max": "",
                "native": {},
                "acl": {
                  "object": 1636,
                  "state": 1636
                "type": "state"
              ScroungerS Offline
              ScroungerS Offline
              Scrounger
              #206
              @sigi234
              Zeig Mal den Wert des Datenpunktes
                @sigi234
                sigi234S Online
                sigi234S Online
                sigi234
                #207
                @sigi234
                Sun Jun 07 2020 21:06:25 GMT+0200
                • sigi234S sigi234
                  @sigi234
                  ScroungerS Offline
                  ScroungerS Offline
                  Scrounger
                  #208
                  @sigi234 sagte in [Neuer Adapter] LinkedDevices:
                  Lass das feld mit parser format leer, dann müsste es gehen.
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    #209
                    Leider nein, bekomme dann ja das angezeigt was ich nicht will.
                    Bei sonnenaufgang funktioniert es:
                    Original Wert:
                    05:05:01 GMT+0200 (GMT+02:00)
                    Linkeddevice:
                    Dienstag, 9. Juni 2020 02:00
                    Ich denke entscheidend ist der Originalwert das Zeitformat:
                    linkeddevices.0	2020-06-08 11:52:41.865	info	(2584) [initialObjects] finished
                    linkeddevices.0	2020-06-08 11:52:41.863	info	(2584) [createAllLinkedObjects] count of active linkedObjects: 8
                    linkeddevices.0	2020-06-08 11:52:41.860	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.startAbend' to 'linkeddevices.0.Start Abend.startAbend'
                    linkeddevices.0	2020-06-08 11:52:41.856	error	(2584) [getCustomDataTypeString] no datetime parser set for parentObject 'gartenbewaesserung.0.status.startAbend' -> check your expertsettings!
                    linkeddevices.0	2020-06-08 11:52:41.854	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.startMorgen' to 'linkeddevices.0.Start Morgen.startMorgen'
                    linkeddevices.0	2020-06-08 11:52:41.850	error	(2584) [getCustomDataTypeString] no datetime parser set for parentObject 'gartenbewaesserung.0.status.startMorgen' -> check your expertsettings!
                    linkeddevices.0	2020-06-08 11:52:41.848	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.sonnenuntergang' to 'linkeddevices.0.Sonnenuntergang Garten.sonnenuntergang'
                    linkeddevices.0	2020-06-08 11:52:41.842	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.sonnenaufgang' to 'linkeddevices.0.Sonnenaufgang Garten.sonnenaufgang'
                    linkeddevices.0	2020-06-08 11:52:41.835	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.restzeit_sek' to 'linkeddevices.0.Restzeit Min.restzeit_sek'
                    linkeddevices.0	2020-06-08 11:52:41.829	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.lautzeit_gesamt_in_sek' to 'linkeddevices.0.Laufzeit Gesamt.lautzeit_gesamt_in_sek'
                    linkeddevices.0	2020-06-08 11:52:41.819	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.lautzeit_ende_uhrzeit' to 'linkeddevices.0.Laufzeit Ende Garten.lautzeit_ende_uhrzeit'
                    linkeddevices.0	2020-06-08 11:52:41.817	error	(2584) [getConvertedValue] there is something wrong with your datetime parser, check your expert settings input for 'linkeddevices.0.Laufzeit Ende Garten.lautzeit_ende_uhrzeit'!
                    linkeddevices.0	2020-06-08 11:52:41.713	info	(2584) [createLinkedObject] linked object 'wifilight.0.192_168_178_28.on' merged to 'linkeddevices.0.Led Wohnzimmer.on'
                    • sigi234S sigi234
                      Original Wert:
                      Linkeddevice:
                      ScroungerS Offline
                      ScroungerS Offline
                      Scrounger
                      #210
                      @sigi234
                      trag das bei parser ein ddd MMM MM YYYY hh:mm:ss.
                      sigi234S SBorgS 2 Antworten Letzte Antwort
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        #211
                        @sigi234
                        • sigi234S sigi234
                          @sigi234
                          ScroungerS Offline
                          ScroungerS Offline
                          Scrounger
                          #212
                          @sigi234
                          Steht 'Uhr' mit im Wert oder ist das die Unit?
                            @sigi234
                            sigi234S Online
                            sigi234S Online
                            sigi234
                            #213
                            ist das die Unit?
                            Ja
                            Unit gelöscht, geht auch nicht. Da kommt invalide date
                              @sigi234
                              SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #214
                              @sigi234
                              Wahrscheinlich blöde Idee, aber "MMM" für den Tag?
                              Sollte das nicht eher in der Art sein: ddd DD MM YYYY hh:mm:ss
                              LG SBorg ( SBorg auf GitHub)
                              • SBorgS SBorg
                                @sigi234
                                #215
                                @sigi234
                                Versuche mal: ddd MMM DD YYYY HH:mm:ss
                                  @sigi234
                                  sigi234S Online
                                  sigi234S Online
                                  sigi234
                                  #216
                                  @paul53 sagte in [Neuer Adapter] LinkedDevices:
                                  @sigi234
                                  Leider nein.
                                  Edit:
                                  LÖSUNG:
                                  HH:mm:ss
                                  • sigi234S sigi234
                                    @sigi234
                                    Leider nein.
                                    Edit:
                                    LÖSUNG:
                                    HH:mm:ss
                                    #217
                                    @sigi234 sagte:
                                    LÖSUNG:
                                    Ja, wenn die Uhrzeit ausreicht. Ich habe mal etwas getestet: Die Wochentags- und Monatsbezeichnung mit 3 Buchstaben funktioniert nicht. Schreibt man den Wochentag und den Monatsnamen aus, funktioniert das Parsen.
                                      @sigi234 sagte:
                                      LÖSUNG:
                                      sigi234S Online
                                      sigi234S Online
                                      sigi234
                                      #218
                                      Nö, kommt aber Richtig:
                                      paul53P ScroungerS 2 Antworten Letzte Antwort
                                      • sigi234S sigi234
                                        #219
                                        @sigi234 sagte:
                                        kommt aber Richtig:
                                        Nein, die Uhrzeit stimmt nicht mehr.
                                        • sigi234S sigi234
                                          ScroungerS Offline
                                          ScroungerS Offline
                                          Scrounger
                                          #220
                                          @sigi234
                                          Woher kommen die daten von gartenbewaesserung.0 ?
                                          Am besten wäre wenn die Datenpunkte timestamps zur Verfügung stellen würden und nicht "so komische" Format. Dann kann man das nämlich super in sein eigenes Format umwandeln - u.a. auch im VIS mit dem Timestamp Widget.
