  4. [Neuer Adapter] LinkedDevices
    6.0k
adapter
464 Beiträge 68 Kommentatoren 172.9k Aufrufe 57 Beobachtet
  • J jack99n
    Bei mir wirft der Adapter Fehler bei der Wandlung von String zu Nummer.
    linkeddevices.0	2019-12-14 13:27:30.008	error	at process._tickCallback (internal/process/next_tick.js:189:7)
    linkeddevices.0	2019-12-14 13:27:30.008	error	at <anonymous>
    linkeddevices.0	2019-12-14 13:27:30.008	error	at Linkeddevices.getConvertedValue (/opt/iobroker/node_modules/iobroker.linkeddevices/main.js:1653:40)
    linkeddevices.0	2019-12-14 13:27:30.008	error	(27105) [createLinkedObject] stack: TypeError: value.replace is not a function
    linkeddevices.0	2019-12-14 13:27:30.008	error	(27105) [createLinkedObject] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set', linkedObject 'linkeddevices.0.LED-Wohnzimmer.set' error: value.replace is not a function
    linkeddevices.0	2019-12-14 13:27:29.990	info	(27105) [onObjectChange] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set' properties changed
    linkeddevices.0	2019-12-14 13:26:00.523	info	(27105) [onObjectChange] count of active linkedObjects: 1
    linkeddevices.0	2019-12-14 13:26:00.522	info	(27105) [createLinkedObject] linked object 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set' merged to 'linkeddevices.0.LED-Wohnzimmer.set'
    linkeddevices.0	2019-12-14 13:26:00.453	info	(27105) [onObjectChange] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set' properties changed
    linkeddevices.0	2019-12-14 13:23:32.087	info	(27105) [initialObjects] finished
    linkeddevices.0	2019-12-14 13:23:32.081	info	(27105) [createAllLinkedObjects] count of active linkedObjects: 1
    linkeddevices.0	2019-12-14 13:23:32.067	error	at process._tickCallback (internal/process/next_tick.js:189:7)
    linkeddevices.0	2019-12-14 13:23:32.067	error	at <anonymous>
    linkeddevices.0	2019-12-14 13:23:32.067	error	at Linkeddevices.getConvertedValue (/opt/iobroker/node_modules/iobroker.linkeddevices/main.js:1653:40)
    linkeddevices.0	2019-12-14 13:23:32.067	error	(27105) [createLinkedObject] stack: TypeError: value.replace is not a function
    linkeddevices.0	2019-12-14 13:23:32.065	error	(27105) [createLinkedObject] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set', linkedObject 'linkeddevices.0.LED-Wohnzimmer.set' error: value.replace is not a function
    linkeddevices.0	2019-12-14 13:23:31.486	info	(27105) [initialObjects] started...
    linkeddevices.0	2019-12-14 13:23:31.455	info	(27105) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linkeddevices, node: v8.16.2
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    schrieb am zuletzt editiert von Scrounger
    #161
    @jack99n
    Poste Mal bitte die raw Daten von 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set'
    • J Offline
      jack99n
      schrieb am zuletzt editiert von jack99n
      #162
      Sorry das ich es als Bild eingestellt habe bekomme es mit dem iPad nicht markiert :man-facepalming:
      ScroungerS 1 Antwort Letzte Antwort
      • J jack99n
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #163
        @jack99n
        Damit kann ich nix anfangen. Vorallem weil der Screenshot genau da aufhört, wo die Daten kommen, die wichtig zur Fehlerbehbung sind.
        Außerdem will ich per copy paste deinen Datenpunkt testen.
        Welchen Werte hat der Datenpunkt?
        Edit: Welche nodejs Version verwendest du?
        • J Offline
          jack99n
          #164
          So jetzt vom PC aus.
            "common": {
              "name": "/h801/switch/ESPURNA_318C6C/brightness/set",
              "write": true,
              "read": true,
              "role": "variable",
              "desc": "mqtt server variable",
              "type": "string",
              "custom": {
                "linkeddevices.0": {
                  "enabled": true,
                  "number_unit": "",
                  "linkedId": "Wohnzimmer-LED.set",
                  "name": "",
                  "role": "",
                  "mergeSettingsOnRestart": false,
                  "expertSettings": true,
                  "number_convertTo": "",
                  "number_maxDecimal": "",
                  "number_min": "",
                  "number_max": "",
                  "number_calculation": "",
                  "number_calculation_readOnly": "",
                  "number_to_boolean_condition": "",
                  "number_to_boolean_value_true": "",
                  "number_to_boolean_value_false": "",
                  "number_to_string_condition": "",
                  "number_to_duration_convert_seconds": "",
                  "number_to_duration_format": "",
                  "number_to_datetime_convert_seconds": "",
                  "number_to_datetime_format": "",
                  "number_to_multi_condition": "",
                  "boolean_convertTo": "",
                  "boolean_to_string_value_true": "",
                  "boolean_to_string_value_false": "",
                  "string_convertTo": "number",
                  "string_prefix": "",
                  "string_suffix": "",
                  "string_to_boolean_value_true": "",
                  "string_to_boolean_value_false": "",
                  "string_to_number_unit": "",
                  "string_to_number_maxDecimal": "",
                  "string_to_number_calculation": "",
                  "string_to_number_calculation_readOnly": "",
                  "string_to_duration_format": "",
                  "string_to_datetime_parser": "",
                  "string_to_datetime_format": ""
            "native": {
              "topic": "/h801/switch/ESPURNA_318C6C/brightness/set"
            "type": "state",
            "from": "system.adapter.mqtt.0",
            "ts": 1558882360477,
            "_id": "mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set",
            "acl": {
              "object": 1636,
              "state": 1636,
              "owner": "system.user.admin",
            "user": "system.user.admin"
          • J jack99n
              "common": {
                "write": true,
                "read": true,
                "role": "variable",
                "type": "string",
                "custom": {
                    "enabled": true,
                    "number_unit": "",
                    "name": "",
                    "role": "",
                    "number_min": "",
                    "number_max": "",
              "native": {
              "type": "state",
              "acl": {
                "object": 1636,
                "state": 1636,
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            #165
            @jack99n
            Welchen Wert hat der Datenpunkt?
            Welche nodejs Version?
            • J Offline
              jack99n
              #166
              Ich hoffe du meinst mit Wert was der Orginal Datenpunkt hat? 0 bis 255
              v 8.16.2
              • J jack99n
                v 8.16.2
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                #167
                @jack99n
                Habs glaub gefunden, teste bitte den aktuellen master von github.
                • J Offline
                  jack99n
                  #168
                  Hat sich leider nicht geändert.
                  linkeddevices.0	2019-12-15 18:33:55.371	info	(17341) [createAllLinkedObjects] count of active linkedObjects: 1
                  linkeddevices.0	2019-12-15 18:33:55.356	error	at process._tickCallback (internal/process/next_tick.js:189:7)
                  linkeddevices.0	2019-12-15 18:33:55.356	error	at <anonymous>
                  linkeddevices.0	2019-12-15 18:33:55.356	error	at Linkeddevices.getConvertedValue (/opt/iobroker/node_modules/iobroker.linkeddevices/main.js:1653:20)
                  linkeddevices.0	2019-12-15 18:33:55.356	error	(17341) [createLinkedObject] stack: TypeError: value.replace is not a function
                  linkeddevices.0	2019-12-15 18:33:55.354	error	(17341) [createLinkedObject] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set', linkedObject 'linkeddevices.0.LED-Level.set' error: value.replace is not a function
                  linkeddevices.0	2019-12-15 18:33:54.651	info	(17341) [initialObjects] started...
                  linkeddevices.0	2019-12-15 18:33:54.626	info	(17341) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linkeddevices, node: v8.16.2
                  • J jack99n
                    ScroungerS Offline
                    ScroungerS Offline
                    Scrounger
                    #169
                    @jack99n
                    stell den adapter mal bitte auf debug modus, starte ihn neu und poste das gesamte log.
                    • J Offline
                      jack99n
                      #170
                      linkeddevices.0	2019-12-15 19:31:43.201	info	(19155) [initialObjects] finished
                      linkeddevices.0	2019-12-15 19:31:43.197	debug	(19155) [initialObjects] 'dicLinkedObjectsStatus' items count: 1
                      linkeddevices.0	2019-12-15 19:31:43.196	debug	(19155) [createAllLinkedObjects] active linkedObjects {"mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set":"linkeddevices.0.LED-Level.set"}
                      linkeddevices.0	2019-12-15 19:31:43.196	info	(19155) [createAllLinkedObjects] count of active linkedObjects: 1
                      linkeddevices.0	2019-12-15 19:31:43.195	debug	(19155) [createAllLinkedObjects] 'dicLinkedObjectsStatus' items count: 1
                      linkeddevices.0	2019-12-15 19:31:43.179	error	at process._tickCallback (internal/process/next_tick.js:189:7)
                      linkeddevices.0	2019-12-15 19:31:43.179	error	at <anonymous>
                      linkeddevices.0	2019-12-15 19:31:43.179	error	at Linkeddevices.getConvertedValue (/opt/iobroker/node_modules/iobroker.linkeddevices/main.js:1653:20)
                      linkeddevices.0	2019-12-15 19:31:43.179	error	(19155) [createLinkedObject] stack: TypeError: value.replace is not a function
                      linkeddevices.0	2019-12-15 19:31:43.178	error	(19155) [createLinkedObject] parentObject 'mqtt.0.h801.switch.ESPURNA_318C6C.brightness.set', linkedObject 'linkeddevices.0.LED-Level.set' error: value.replace is not a function
                      linkeddevices.0	2019-12-15 19:31:43.115	debug	(19155) [createLinkedObject] native data set for 'linkeddevices.0.LED-Level.set' ("native":{"topic":"/h801/switch/ESPURNA_318C6C/brightness/set"})
                      linkeddevices.0	2019-12-15 19:31:43.115	debug	(19155) [getCustomData] custom expert settings for 'linkeddevices.0.LED-Level.set': {"mergeSettingsOnRestart":true}
                      linkeddevices.0	2019-12-15 19:31:43.082	debug	(19155) [getCommonData] common expert settings for 'linkeddevices.0.LED-Level.set': {"type":"number"}
                      linkeddevices.0	2019-12-15 19:31:43.079	debug	(19155) [createLinkedObjectChannel] channel 'linkeddevices.0.LED-Level' already exist!
                      linkeddevices.0	2019-12-15 19:31:42.691	debug	(19155) [resetAllLinkedObjectsStatus] 'dicLinkedObjectsStatus' items count: 1
                      linkeddevices.0	2019-12-15 19:31:42.691	debug	(19155) [resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.LED-Level.set'
                      linkeddevices.0	2019-12-15 19:31:42.356	debug	(19155) [getSystemConfig] system configs successful loaded: '{"language":"de","dateFormat":"DD.MM.YYYY","durationFormat":"dd[T] hh[h] mm[m]"}'
                      linkeddevices.0	2019-12-15 19:31:42.310	info	(19155) [initialObjects] started...
                      linkeddevices.0	2019-12-15 19:31:42.309	debug	(19155) [onReady] deleteDeadLinkedObjects: 'true'
                      linkeddevices.0	2019-12-15 19:31:42.283	info	(19155) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.linkeddevices, node: v8.16.2
                      linkeddevices.0	2019-12-15 19:31:41.502	debug	(19155) States connected to redis: 127.0.0.1:9000
                      linkeddevices.0	2019-12-15 19:31:41.448	debug	(19155) statesDB connected
                      linkeddevices.0	2019-12-15 19:31:41.447	debug	(19155) States create PubSub Client
                      linkeddevices.0	2019-12-15 19:31:41.441	debug	(19155) Objects connected to redis: 127.0.0.1:9001
                      linkeddevices.0	2019-12-15 19:31:41.438	debug	(19155) Redis States: Use Redis connection: 127.0.0.1:9000
                      linkeddevices.0	2019-12-15 19:31:41.435	debug	(19155) objectDB connected
                      linkeddevices.0	2019-12-15 19:31:41.420	debug	(19155) Objects client initialize lua scripts
                      linkeddevices.0	2019-12-15 19:31:41.419	debug	(19155) Objects create PubSub Client
                      linkeddevices.0	2019-12-15 19:31:41.414	debug	(19155) Objects client ready ... initialize now
                      linkeddevices.0	2019-12-15 19:31:41.369	debug	(19155) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.home	2019-12-15 19:31:39.894	info	instance system.adapter.linkeddevices.0 started with pid 19155
                      host.home	2019-12-15 19:31:37.912	info	instance system.adapter.linkeddevices.0 terminated with code 156 (156)
                      linkeddevices.0	2019-12-15 19:31:37.394	info	(17341) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      linkeddevices.0	2019-12-15 19:31:37.393	info	(17341) terminating
                      linkeddevices.0	2019-12-15 19:31:37.392	info	(17341) cleaned everything up...
                      linkeddevices.0	2019-12-15 19:31:37.389	info	(17341) Got terminate signal TERMINATE_YOURSELF
                      host.home	2019-12-15 19:31:37.384	info	stopInstance system.adapter.linkeddevices.0 send kill signal
                      • J jack99n
                        ScroungerS Offline
                        ScroungerS Offline
                        Scrounger
                        #171
                        @jack99n
                        Nächster Versuch, bitte den aktuellen master testen.
                        Wenn das auch nicht geht, bitte mal auf nodejs 10 updaten, da ich den fehler nicht reproduzieren kann.
                        • J Offline
                          jack99n
                          #172
                          Cool jetzt geht es, danke für deine Mühe!
                          • E Offline
                            enricoh831
                            #173
                            Hi Scrounger,
                            Toller Adapter hat mir jetzt schon mal weiter geholfen, die Temperatur Werte für Alexa dürfen keine nach Komma stellen haben. Ich hab das immer in einem Script umgerechnet jetzt kann ich einfach ein Link erstellen der automatisch umrechnet.
                            Ich habe alle Eingänge und Ausgänge als MQTT Geräte da bekommt man schlecht Struktur rein. Mit deinem Adapter wird das einfacher.
                            Aber einen Verbesserungsvorschlag habe ich:
                            in der Adapter Einstellung müsste man noch für die verlinkungen den Smartdevice namen einstellen können am besten alles gleich so machen das man nicht mehr in den Cloud Adapter muss. wenn man da 40 Geräte anlegen müsste würde man einen tag brauchen.
                            Kannst ja mal gucken ob du sowas mit rein bekommst.
                            Schöne Grüße
                            Enrico
                            • E Offline
                              enricoh831
                              #174
                              Habe einen Bug gefunden....
                              hatte bei "Präfix für ID des verlinkten Objektes" den namen Flur EG eingetragen.
                              danach lief kein JS Script mehr.
                              nach ändereung auf Flur_EG klappe es.
                              der Device adapter macht automatisch bei leerzeile einen _.
                              • E enricoh831
                                Hi Scrounger,
                                Schöne Grüße
                                Enrico
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                #175
                                @enricoh831 sagte in [Neuer Adapter] LinkedDevices:
                                Kannst du mir hier mal ein genaues Beispiel geben, z.B. raw Daten wie das aussehen sollte, dann kann ich das sicher mit einbauen. Ich selber nutze den Cloud Adapter nicht und kenne das deshalb überhaupt nicht.
                                Mhhh, dachte ich hab das eingebaut, ok werd ich mir anschauen.
                                • E Offline
                                  enricoh831
                                  #176
                                  Ich habe das im RAW auch schon mal von Hand eingetragen aber Die Objekte erscheinen dann nicht im Cloud adapter.
                                  da muss es noch etwas anderes geben.
                                  Da müssten wir mal Bluefox fragen der hat den ja glaube ich geschrieben.
                                    Mike Hellracer
                                    #177
                                    Hallo. Ich bekomme es einfach nicht hin die linkeddevices in der Material-ui anzeigen zu lassen. Habe schon sämtliche dp wie das original angelegt. Das original wird als Tür angezeigt aber das Link device wird nicht angezeigt.kann mir jemand helfen?
                                    • Ivan AndricI Offline
                                      Ivan Andric
                                      #178
                                      Frage eines Anfängers...
                                      Soweit funktioniert linkeddevices bei mir gut. Habe jedoch jetzt einen Shelly Sensor bei dem ich den Wert für die Luftfeuchtigkeit anpassen muss. Dazu habe ich im Feld "Umrechnung für verlinktes 'read' Objekt" einfach ein "-12" eingetragen. Der Link wird angelegt jedoch erfolgt keine Umrechnung. Der Sensor selber ist "read only".
                                      Was mache ich da falsch...?
                                      Vielen Dank!
                                      Anbei der RAW-Auszug:
                                        "from": "system.adapter.shelly.0",
                                        "user": "system.user.admin",
                                        "ts": 1580067822367,
                                        "common": {
                                          "name": "Relative humidity",
                                          "type": "number",
                                          "role": "value.humidity",
                                          "unit": "%",
                                          "min": 0,
                                          "max": 100,
                                          "read": true,
                                          "write": false,
                                          "custom": {
                                              "enabled": true,
                                              "number_unit": "%",
                                              "linkedId": "TempSensoren.Wanne.humidity",
                                              "name": "Luftfeuchtigkeit",
                                              "role": "",
                                              "number_maxDecimal": 1,
                                              "number_min": "",
                                              "number_max": "",
                                              "number_calculation_readOnly": -12,
                                              "string_convertTo": "",
                                        "native": {},
                                        "acl": {
                                          "object": 1638,
                                          "state": 1638
                                        "_id": "shelly.0.SHHT-1#F3ADBB#1.hum.value",
                                        "type": "state"
                                      • Ivan AndricI Ivan Andric
                                        Vielen Dank!
                                          "common": {
                                            "type": "number",
                                            "unit": "%",
                                            "min": 0,
                                            "max": 100,
                                            "read": true,
                                            "write": false,
                                            "custom": {
                                                "enabled": true,
                                                "number_unit": "%",
                                                "role": "",
                                                "number_min": "",
                                                "number_max": "",
                                          "native": {},
                                          "acl": {
                                            "object": 1638,
                                            "state": 1638
                                          "type": "state"
                                        #179
                                        @Ivan-Andric sagte:
                                        Hast Du es so manuell in die RAW-Ansicht eingetragen ? Der Adapter macht es so:
                                                "number_calculation_readOnly": "-12",
                                        Ivan AndricI 1 Antwort Letzte Antwort
                                          @Ivan-Andric sagte:
                                          Ivan Andric
                                          #180
                                          @paul53 Nein, ich habe nichts manuell in der RAW-Ansicht angepasst. Habe es jetzt gemacht und es funktioniert. Habe es mal bei einem anderen Sensor ausprobiert und da gab es keine Probleme. Weshalb die Anführungszeichen gefehlt haben kann ich mir nicht erklären. Ich schaue mal was bei den nächsten Sensoren passiert.
                                          Vielen Dank!
