  4. [Neuer Adapter] LinkedDevices
    6.7k
adapter
464 Beiträge 68 Kommentatoren 175.0k Aufrufe 57 Beobachtet
  • sigi234S sigi234
    @Scrounger
    Hallo, irgendwo habe ich einen Fehler:
    linkeddevices.0	2020-06-07 10:57:11.560	error	(1576) [getConvertedValue] there is something wrong with your datetime parser, check your expert settings input for 'linkeddevices.0.Start Abend.startAbend'!
    linkeddevices.0	2020-06-07 10:57:11.559	error	(1576) [getConvertedValue] there is something wrong with your datetime parser, check your expert settings input for 'linkeddevices.0.Start Morgen.startMorgen'!
    RAW vom DP:
      "from": "system.adapter.gartenbewaesserung.0",
      "user": "system.user.admin",
      "ts": 1587042880603,
      "common": {
        "name": "startAbend",
        "role": "indicator",
        "type": "string",
        "unit": "Uhr",
        "write": false,
        "read": true,
        "custom": {
          "linkeddevices.0": {
            "enabled": true,
            "number_unit": "",
            "linkedId": "Start Abend.startAbend",
            "name": "Start Abend",
            "role": "",
            "mergeSettingsOnRestart": false,
            "expertSettings": true,
            "number_convertTo": "",
            "number_maxDecimal": "",
            "number_min": "",
            "number_max": "",
            "number_calculation": "",
            "number_calculation_readOnly": "",
            "number_to_boolean_condition": "",
            "number_to_boolean_value_true": "",
            "number_to_boolean_value_false": "",
            "number_to_string_condition": "",
            "number_to_duration_convert_seconds": "",
            "number_to_duration_format": "",
            "number_to_datetime_convert_seconds": "",
            "number_to_datetime_format": "",
            "number_to_multi_condition": "",
            "boolean_convertTo": "",
            "boolean_to_string_value_true": "",
            "boolean_to_string_value_false": "",
            "string_convertTo": "datetime",
            "string_prefix": "",
            "string_suffix": "",
            "string_to_boolean_value_true": "",
            "string_to_boolean_value_false": "",
            "string_to_number_unit": "",
            "string_to_number_maxDecimal": "",
            "string_to_number_calculation": "",
            "string_to_number_calculation_readOnly": "",
            "string_to_duration_format": "",
            "string_to_datetime_parser": "'y[J] d[T] hh[h] mm[m]'",
            "string_to_datetime_format": "LLLL"
      "native": {},
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "gartenbewaesserung.0.status.startAbend",
      "type": "state"
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    #206
    @sigi234
    Zeig Mal den Wert des Datenpunktes
    • ScroungerS Scrounger
      @sigi234
      sigi234S Online
      sigi234S Online
      #207
      @Scrounger sagte in [Neuer Adapter] LinkedDevices:
      @sigi234
      Sun Jun 07 2020 21:06:25 GMT+0200
      ScroungerS 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @sigi234
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #208
        @sigi234 sagte in [Neuer Adapter] LinkedDevices:
        Lass das feld mit parser format leer, dann müsste es gehen.
          sigi234S Online
          sigi234S Online
          #209
          Leider nein, bekomme dann ja das angezeigt was ich nicht will.
          Bei sonnenaufgang funktioniert es:
          Original Wert:
          05:05:01 GMT+0200 (GMT+02:00)
          Linkeddevice:
          Dienstag, 9. Juni 2020 02:00
          Ich denke entscheidend ist der Originalwert das Zeitformat:
          linkeddevices.0	2020-06-08 11:52:41.865	info	(2584) [initialObjects] finished
          linkeddevices.0	2020-06-08 11:52:41.863	info	(2584) [createAllLinkedObjects] count of active linkedObjects: 8
          linkeddevices.0	2020-06-08 11:52:41.860	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.startAbend' to 'linkeddevices.0.Start Abend.startAbend'
          linkeddevices.0	2020-06-08 11:52:41.856	error	(2584) [getCustomDataTypeString] no datetime parser set for parentObject 'gartenbewaesserung.0.status.startAbend' -> check your expertsettings!
          linkeddevices.0	2020-06-08 11:52:41.854	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.startMorgen' to 'linkeddevices.0.Start Morgen.startMorgen'
          linkeddevices.0	2020-06-08 11:52:41.850	error	(2584) [getCustomDataTypeString] no datetime parser set for parentObject 'gartenbewaesserung.0.status.startMorgen' -> check your expertsettings!
          linkeddevices.0	2020-06-08 11:52:41.848	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.sonnenuntergang' to 'linkeddevices.0.Sonnenuntergang Garten.sonnenuntergang'
          linkeddevices.0	2020-06-08 11:52:41.842	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.sonnenaufgang' to 'linkeddevices.0.Sonnenaufgang Garten.sonnenaufgang'
          linkeddevices.0	2020-06-08 11:52:41.835	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.restzeit_sek' to 'linkeddevices.0.Restzeit Min.restzeit_sek'
          linkeddevices.0	2020-06-08 11:52:41.829	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.lautzeit_gesamt_in_sek' to 'linkeddevices.0.Laufzeit Gesamt.lautzeit_gesamt_in_sek'
          linkeddevices.0	2020-06-08 11:52:41.819	info	(2584) [createLinkedObject] linked object 'gartenbewaesserung.0.status.lautzeit_ende_uhrzeit' to 'linkeddevices.0.Laufzeit Ende Garten.lautzeit_ende_uhrzeit'
          linkeddevices.0	2020-06-08 11:52:41.817	error	(2584) [getConvertedValue] there is something wrong with your datetime parser, check your expert settings input for 'linkeddevices.0.Laufzeit Ende Garten.lautzeit_ende_uhrzeit'!
          linkeddevices.0	2020-06-08 11:52:41.713	info	(2584) [createLinkedObject] linked object 'wifilight.0.192_168_178_28.on' merged to 'linkeddevices.0.Led Wohnzimmer.on'
          • sigi234S sigi234
            Original Wert:
            Linkeddevice:
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            #210
            @sigi234
            trag das bei parser ein ddd MMM MM YYYY hh:mm:ss.
            sigi234S SBorgS 2 Antworten Letzte Antwort
              @sigi234
              sigi234S Online
              sigi234S Online
              #211
              @sigi234
              • sigi234S sigi234
                @sigi234
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                #212
                @sigi234
                Steht 'Uhr' mit im Wert oder ist das die Unit?
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  #213
                  ist das die Unit?
                  Ja
                  Unit gelöscht, geht auch nicht. Da kommt invalide date
                    @sigi234
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #214
                    @sigi234
                    Wahrscheinlich blöde Idee, aber "MMM" für den Tag?
                    Sollte das nicht eher in der Art sein: ddd DD MM YYYY hh:mm:ss
                    LG SBorg ( SBorg auf GitHub)
                    • SBorgS SBorg
                      @sigi234
                      #215
                      @sigi234
                      Versuche mal: ddd MMM DD YYYY HH:mm:ss
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        #216
                        @paul53 sagte in [Neuer Adapter] LinkedDevices:
                        @sigi234
                        Leider nein.
                        Edit:
                        LÖSUNG:
                        HH:mm:ss
                        • sigi234S sigi234
                          @sigi234
                          Leider nein.
                          Edit:
                          LÖSUNG:
                          HH:mm:ss
                          #217
                          @sigi234 sagte:
                          LÖSUNG:
                          Ja, wenn die Uhrzeit ausreicht. Ich habe mal etwas getestet: Die Wochentags- und Monatsbezeichnung mit 3 Buchstaben funktioniert nicht. Schreibt man den Wochentag und den Monatsnamen aus, funktioniert das Parsen.
                            @sigi234 sagte:
                            LÖSUNG:
                            sigi234S Online
                            sigi234S Online
                            #218
                            Nö, kommt aber Richtig:
                            paul53P ScroungerS 2 Antworten Letzte Antwort
                            • sigi234S sigi234
                              #219
                              @sigi234 sagte:
                              kommt aber Richtig:
                              Nein, die Uhrzeit stimmt nicht mehr.
                              • sigi234S sigi234
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                #220
                                @sigi234
                                Woher kommen die daten von gartenbewaesserung.0 ?
                                Am besten wäre wenn die Datenpunkte timestamps zur Verfügung stellen würden und nicht "so komische" Format. Dann kann man das nämlich super in sein eigenes Format umwandeln - u.a. auch im VIS mit dem Timestamp Widget.
                                  @sigi234
                                  sigi234S Online
                                  sigi234S Online
                                  #221
                                  Von einen Adapter:
                                  https://forum.iobroker.net/topic/32213/test-adapter-gartenbewässerung-v0-0-x
                                  • sigi234S sigi234
                                    Von einen Adapter:
                                    ScroungerS Offline
                                    ScroungerS Offline
                                    Scrounger
                                    #222
                                    @sigi234
                                    Oder max. in sowas hier 2020-05-30 21:25:38
                                    • JB_SullivanJ Offline
                                      JB_Sullivan
                                      #223
                                      Hallo zusammen, darf ich mal rein grätschen?
                                      @Scrounger du bist doch der Entwickler von dem Materialdesign Adapter - richtig?
                                      Hast du ggf. eine Erklärung hierfür - kann das an deinem Adapter / den Widgets liegen?
                                      https://forum.iobroker.net/topic/34195/vis-bilder-remote-unvollständig-verschoben
                                      • echoDaveE Offline
                                        echoDaveE Offline
                                        echoDave
                                        #224
                                        Hi Kann man auch LinkedDevice mit mehreren echten Devices über diesen Adapter verlinken?
                                        Hintergrund, habe 1 Lampe mit 3 Birnen, will nicht die Birnen einzeln steuern sondern die ganze "Gruppe". Überlege ob es mit diesem Adapter machbar ist.
                                        Viele Grüße, David
                                          ak1
                                          #225
                                          Nutzt hier jemand erfolgreich den LinkedDevices Adapter im Zusammenhang mit dem iot-Adapter (Smart-Device)? Ich bitte um Rückmeldung.
                                          Ich habe gerade massive Probleme damit.
                                          Siehe hier: https://forum.iobroker.net/topic/34420/troubleshooting-iot-smart-devices-linkeddevices-hm-rpc
                                          Leider bekomme ich es nun auch nicht hin, über den iot-Adapter direkt unter Umgehung des LinkedDevices Adapter ein Smart-Device (von einem Homematic-Aktor) anzulegen. Solange es eine Verknüpfung des eigentlichen Gerätes mit dem LinkedDevices-Adapter gibt, taucht dann auch das "virtuelle" Gerät unerwünscht im iot-Adapter auf:
                                          Erst gibt es dann eine Fehlermeldung des iot-Adapters, dass das Gerät nicht angelegt werden könne, dann taucht es aber gemeinsam mit seiner virtuellen Variante auf und ich habe keine Edit-Möglichkeit mehr (kein "Stift-Icon").
                                          Ich befürchte gerade, dass ich den LinkedDevices-Adapter entfernen muss. Das wäre aber ich blöd für alle meine Datenpunkte in meiner Vis und meinen Skripten.
                                          ak1
